How to decrease temperature of the nvidia card ?
- Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
The temperature of the nvidia card is 70 °C. This is very hot. Nvidia's settings manager says it is a yellow temp. I want to decrease the temperature to reach a green temperature, about 60 °C.
I tried to use "gpu-usage = 50". The temperature stays at 70 °C.
How to decrease temp of the nvidia card ?
Thanks
Thanks
Re: How to decrease temperature of the nvidia card ?
The card is designed to operate within a specific temperature window.
Assuming you're running windows you can download MSI afterburner.
This will let you control the power limit and fan speed of the card, both up and down.
It can be done in linux but it's a bit more involved.
The "gpu-usage" option shouldn't be used. 70 °C GPU junction temperature for a modern GPU is not high - a modern Nvidia GPU can run up to around 93 °C depending on model.
The good news is that a slight power limit reduction tends to give much less power usage while not hurting PPD that much. On Linux can use to set the number of watts to run on. The allowed numbers depends on the GPU. For example, my 1660 Super can be set between 50 and 150 W. There is a bit more work to make that setting persistent, but you can make little script that runs the command when the graphics launch.
On Windows you can use tools like MSI Afterburner to reduce the power limit to e.g. 80%. It is possible to make the setting persistent so that MSI Afterburner remebers the settings on boot.
Otherwise, you can play around with the fan curves of your case and/or GPU to balance noise and cooling. If your case is a 65 °C hotbox with bad airflow, that limits the cooling ability of the GPU compared to if your internal case temperature is 34 °C. I have a Corsair ML fan tied to the case or GPU temperature to keep the case nice and cool.
sudo nvidia-smi -pl ???
My Os is linux openSuse 15.3.
my nvidia card is NVIDIA GeForce GT 1030.
I don't know the power limits. Where I can find them ?
Thanks
Thanks
nvidia-smi -q|grep Limit
Power Limit : 150.00 W
Default Power Limit : 125.00 W
Enforced Power Limit : 150.00 W
Min Power Limit : 70.00 W
Max Power Limit : 150.00 W
By the way, the 1030 has a max GPU temperature of 97 °C, so 70 °C is not hot at all - it is a normal working temperature. I wouldn't worry about it.
I get no problem with case temp. The fan pulse a fresh air out of the case.
Only the case fan moves from about 1200 rpm to 1300 rpm. A bit noisier.
I will let the things as they are.
Thanks
Thanks
I used to run my passive 1030 GPUs with a case fan.promeneur wrote:I get no problem with case temp. The fan pulse a fresh air out of the case.
Thanks
An 80 mm case fan running at 6V, only consumes 0.25W, and keeps those GPUs below 50C.
If you already have an active heat sink, you could try to fit a case fan of a slightly larger size, with curved blades. They make less noise.
My NVIDIA card is an ASUS SL one, One with a passive cooling, no fan.
It's a perfectly fine temperature.promeneur wrote:The temperature of the nvidia card is 70 °C. This is very hot. Nvidia's settings manager says it is a yellow temp. I want to decrease the temperature to reach a green temperature, about 60 °C.
Thanks
If you want to decrease it, increase fan speed manually with a dedicated tool (like MSI Afterburner) ...
So to decrease its temperature, it's easier to add a case fan on it.promeneur wrote:My NVIDIA card is an ASUS SL one, One with a passive cooling, no fan.
I think what is being proposed is adding a case fan directed at this passively cooled card may actively cool it a bit more.promeneur wrote:My NVIDIA card is an ASUS SL one, One with a passive cooling, no fan.
