GPUs active no progress
Hello,
Trying to use a multi GPU system since trying to get back into Folding.
GPUs are showing active green circles spinning but no progress.
CPU is showing progress
These are 5500xt and 6600xt. Any help or ideas would be appreciated!
THanks!
THanks!
Re: GPUs active no progress
Welcome to Folding@Home!
To gain any insight, we would need the first 200 lines of the log, with your configuration.
viewtopic.php?p=327412&f=24#p327412
Here it is!
*********************** Log Started 2022-02-12T15:29:02Z ***********************
15:29:02:******************************* libFAH ********************************
15:29:02: Date: Oct 20 2020
15:29:02: Time: 13:36:55
15:29:02: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:29:02: Branch: master
15:29:02: Compiler: Visual C++ 2015
15:29:02: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:29:02: Platform: win32 10
15:29:02: Bits: 32
15:29:02: Mode: Release
15:29:02:****************************** FAHClient ******************************
15:29:02: Version: 7.6.21
15:29:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:29:02: Copyright: 2020 foldingathome.org
15:29:02: Homepage: https://foldingathome.org/
15:29:02: Time: 13:41:04
15:29:02: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:29:02: Bits: 32
15:29:02: Config: C:\ProgramData\FAHClient\config.xml
15:29:02:******************************** CBang ********************************
15:29:02: Time: 11:36:18
15:29:02: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:29:02: Bits: 32
15:29:02:******************************* System ********************************
15:29:02: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:29:02: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:29:02: CPUs: 2
15:29:02: Memory: 7.93GiB
15:29:02: Free Memory: 5.55GiB
15:29:02: Threads: WINDOWS_THREADS
15:29:02: OS Version: 6.2
15:29:02: Has Battery: false
15:29:02: On Battery: false
15:29:02: UTC Offset: -5
15:29:02: PID: 3256
15:29:02: CWD: C:\ProgramData\FAHClient
15:29:02: Win32 Service: false
15:29:02: OS: Windows 10 Enterprise
15:29:02: OS Arch: AMD64
15:29:02: GPUs: 6
15:29:02: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT1 [HD Graphics 610]
15:29:02: GPU 1: Bus:10 Slot:0 Func:0 AMD:6 Navi 23 [Radeon RX 6600/6600
15:29:02: XT/6600M]
15:29:02: GPU 2: Bus:13 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
15:29:02: 5500M]
15:29:02: GPU 3: Bus:16 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
15:29:02: 5500M]
15:29:02: GPU 4: Bus:3 Slot:0 Func:0 AMD:6 Navi 23 [Radeon RX 6600/6600
15:29:02: XT/6600M]
15:29:02: GPU 5: Bus:7 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600
15:29:02: XT/5700/5700 XT]
15:29:02: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
15:29:02: specified module could not be found.
15:29:02:
15:29:02:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3302.6
15:29:02:OpenCL Device 1: Platform:0 Device:1 Bus:7 Slot:0 Compute:1.2 Driver:3302.6
15:29:02:OpenCL Device 2: Platform:0 Device:2 Bus:10 Slot:0 Compute:1.2 Driver:3302.6
15:29:02:OpenCL Device 3: Platform:0 Device:3 Bus:16 Slot:0 Compute:1.2 Driver:3302.6
15:29:02:OpenCL Device 4: Platform:0 Device:4 Bus:13 Slot:0 Compute:1.2 Driver:3302.6
15:29:02:***********************************************************************
15:29:34:<config>
15:29:34: <!-- Slot Control -->
15:29:34: <power v='FULL'/>
15:29:34:
15:29:34: <!-- User Information -->
15:29:34: <team v='64'/>
15:29:34: <user v='Maliki2'/>
15:29:34:
15:29:34: <!-- Folding Slots -->
15:29:34: <slot id='0' type='CPU'/>
15:29:34: <slot id='1' type='GPU'>
15:29:34: <paused v='true'/>
15:29:34: <pci-bus v='0'/>
15:29:34: <pci-slot v='2'/>
15:29:34: </slot>
15:29:34: <slot id='2' type='GPU'>
15:29:34: <pci-bus v='10'/>
15:29:34: <pci-slot v='0'/>
15:29:34: </slot>
15:29:34: <slot id='3' type='GPU'>
15:29:34: <pci-bus v='13'/>
15:29:34: </slot>
15:29:34: <slot id='4' type='GPU'>
15:29:34: <pci-bus v='16'/>
15:29:34: </slot>
15:29:34: <slot id='5' type='GPU'>
15:29:34: <pci-bus v='3'/>
15:29:34: </slot>
15:29:34: <slot id='6' type='GPU'>
15:29:34: <pci-bus v='7'/>
15:29:34: </slot>
15:29:34:</config>
15:29:35:Trying to access database...
15:29:35:Successfully acquired database lock
15:29:36:FS00:Initialized folding slot 00: cpu:1
15:29:36:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT1 [HD Graphics 610]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
15:29:36:FS02:Initialized folding slot 02: gpu:10:0 Navi 23 [Radeon RX 6600/6600 XT/6600M]
15:29:38:FS03:Initialized folding slot 03: gpu:13:0 Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
15:29:38:FS04:Initialized folding slot 04: gpu:16:0 Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
15:29:39:FS05:Initialized folding slot 05: gpu:3:0 Navi 23 [Radeon RX 6600/6600 XT/6600M]
15:29:40:FS06:Initialized folding slot 06: gpu:7:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT]
15:29:41:WU00:FS00:Starting
15:29:41:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -np 1
15:29:41:WU00:FS00:Started FahCore on PID 5464
15:29:56:WU00:FS00:Core PID:2608
15:29:56:WU00:FS00:FahCore 0xa8 started
15:29:57:WU01:FS02:Starting
15:29:58:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 2 -gpu-vendor amd -gpu 2 -gpu-usage 100
15:30:02:WU01:FS02:Started FahCore on PID 5700
15:30:16:WU00:FS00:0xa8:*********************** Log Started 2022-02-12T15:30:15Z ***********************
15:30:18:WU01:FS02:Core PID:4520
15:30:18:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:30:18:WU01:FS02:FahCore 0x22 started
15:30:18:WU00:FS00:0xa8: Core: Gromacs
15:30:18:WU00:FS00:0xa8: Type: 0xa8
15:30:18:WU00:FS00:0xa8: Version: 0.0.12
15:30:18:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:30:18:WU02:FS03:Starting
15:30:18:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
15:30:18:WU02:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 4 -gpu-vendor amd -gpu 4 -gpu-usage 100
15:30:19:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
15:30:19:WU00:FS00:0xa8: Date: Jan 16 2021
15:30:19:WU02:FS03:Started FahCore on PID 2788
15:30:19:WU00:FS00:0xa8: Time: 11:25:04
15:30:19:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:30:19:WU00:FS00:0xa8: Branch: master
15:30:19:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:30:19:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:19:WU00:FS00:0xa8: Platform: win32 10
15:30:19:WU00:FS00:0xa8: Bits: 64
15:30:19:WU00:FS00:0xa8: Mode: Release
15:30:19:WU00:FS00:0xa8: SIMD: sse2
15:30:20:WU00:FS00:0xa8: OpenMP: ON
15:30:20:WU00:FS00:0xa8: CUDA: OFF
15:30:20:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 5464 -checkpoint 15 -np 1
15:30:20:WU00:FS00:0xa8:************************************ libFAH ************************************
15:30:20:WU00:FS00:0xa8: Date: Jan 16 2021
15:30:20:WU00:FS00:0xa8: Time: 11:24:13
15:30:20:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:30:21:WU00:FS00:0xa8: Branch: master
15:30:21:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:30:21:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:21:WU00:FS00:0xa8: Platform: win32 10
15:30:21:WU00:FS00:0xa8: Bits: 64
15:30:21:WU00:FS00:0xa8: Mode: Release
15:30:21:WU00:FS00:0xa8:************************************ CBang *************************************
15:30:21:WU00:FS00:0xa8: Date: Jan 16 2021
15:30:21:WU00:FS00:0xa8: Time: 11:23:53
15:30:21:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:30:22:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:30:22:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:22:WU00:FS00:0xa8: Platform: win32 10
15:30:22:WU00:FS00:0xa8: Bits: 64
15:30:22:WU00:FS00:0xa8: Mode: Release
15:30:22:WU00:FS00:0xa8:************************************ System ************************************
15:30:22:WU00:FS00:0xa8: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:30:22:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:30:22:WU00:FS00:0xa8: CPUs: 2
15:30:22:WU00:FS00:0xa8: Memory: 7.93GiB
15:30:22:WU00:FS00:0xa8:Free Memory: 5.33GiB
15:30:22:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
15:30:23:WU00:FS00:0xa8: OS Version: 6.2
15:30:23:WU00:FS00:0xa8:Has Battery: false
15:30:23:WU00:FS00:0xa8: On Battery: false
15:30:23:WU00:FS00:0xa8: UTC Offset: -5
15:30:23:WU00:FS00:0xa8: PID: 2608
15:30:23:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
15:30:23:WU00:FS00:0xa8:********************************************************************************
15:30:23:WU00:FS00:0xa8:Project: 16955 (Run 2, Clone 2893, Gen 140)
15:30:23:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:30:23:WU00:FS00:0xa8:Digital signatures verified
15:30:23:WU00:FS00:0xa8:Calling: mdrun -c frame140.gro -s frame140.tpr -x frame140.xtc -cpt 15 -nt 1 -ntmpi 1
15:30:34:WU02:FS03:Core PID:3692
15:30:34:WU02:FS03:FahCore 0x22 started
15:30:34:WU03:FS04:Starting
15:30:34:WU03:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 3 -gpu-vendor amd -gpu 3 -gpu-usage 100
15:30:34:WU03:FS04:Started FahCore on PID 1808
15:30:40:WU03:FS04:Core PID:4264
15:30:40:WU03:FS04:FahCore 0x22 started
15:30:40:WU05:FS06:Starting
15:30:40:WU05:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 05 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1 -gpu-usage 100
15:30:40:WU00:FS00:0xa8:Steps: first=70000000 total=70500000
15:30:40:WU05:FS06:Started FahCore on PID 4452
15:30:50:WU03:FS04:0x22:*********************** Log Started 2022-02-12T15:30:50Z ***********************
15:30:51:WU03:FS04:0x22:*************************** Core22 Folding@home Core ***************************
15:30:51:WU03:FS04:0x22: Core: Core22
15:30:51:WU03:FS04:0x22: Type: 0x22
15:30:51:WU03:FS04:0x22: Version: 0.0.20
15:30:51:WU03:FS04:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:30:51:WU03:FS04:0x22: Copyright: 2020 foldingathome.org
15:30:51:WU03:FS04:0x22: Homepage: https://foldingathome.org/
15:30:51:WU03:FS04:0x22: Date: Jan 20 2022
15:30:51:WU03:FS04:0x22: Time: 01:15:36
15:30:51:WU03:FS04:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:30:52:WU03:FS04:0x22: Branch: HEAD
15:30:52:WU03:FS04:0x22: Compiler: Visual C++
15:30:52:WU03:FS04:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:52:WU03:FS04:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:30:52:WU03:FS04:0x22: Platform: win32 10
15:30:52:WU03:FS04:0x22: Bits: 64
15:30:52:WU03:FS04:0x22: Mode: Release
15:30:52:WU03:FS04:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:30:52:WU03:FS04:0x22: <peastman@stanford.edu>
15:30:52:WU03:FS04:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 1808 -checkpoint 15
15:30:52:WU03:FS04:0x22: -opencl-platform 0 -opencl-device 3 -gpu-vendor amd -gpu 3
15:30:52:WU03:FS04:0x22: -gpu-usage 100
15:30:52:WU03:FS04:0x22:************************************ libFAH ************************************
15:30:53:WU03:FS04:0x22: Date: Jan 20 2022
15:30:53:WU03:FS04:0x22: Time: 01:14:17
15:30:53:WU03:FS04:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:30:53:WU03:FS04:0x22: Branch: HEAD
15:30:53:WU03:FS04:0x22: Compiler: Visual C++
15:30:53:WU03:FS04:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:53:WU03:FS04:0x22: Platform: win32 10
15:30:53:WU03:FS04:0x22: Bits: 64
15:30:53:WU03:FS04:0x22: Mode: Release
15:30:53:WU03:FS04:0x22:************************************ CBang *************************************
15:30:56:WU03:FS04:0x22: Date: Jan 20 2022
15:30:56:WU02:FS03:0x22:*********************** Log Started 2022-02-12T15:30:56Z ***********************
15:30:59:WU03:FS04:0x22: Time: 01:13:20
15:30:59:WU02:FS03:0x22:*************************** Core22 Folding@home Core ***************************
15:30:59:WU03:FS04:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:30:59:WU02:FS03:0x22: Core: Core22
15:30:59:WU03:FS04:0x22: Branch: HEAD
15:30:59:WU02:FS03:0x22: Type: 0x22
15:30:59:WU03:FS04:0x22: Compiler: Visual C++
15:30:59:WU02:FS03:0x22: Version: 0.0.20
15:30:59:WU03:FS04:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:30:59:WU02:FS03:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:31:00:WU03:FS04:0x22: Platform: win32 10
15:31:00:WU02:FS03:0x22: Copyright: 2020 foldingathome.org
15:31:00:WU03:FS04:0x22: Bits: 64
15:31:00:WU02:FS03:0x22: Homepage: https://foldingathome.org/
15:31:00:WU03:FS04:0x22: Mode: Release
15:31:00:WU02:FS03:0x22: Date: Jan 20 2022
15:31:00:WU03:FS04:0x22:************************************ System ************************************
15:31:00:WU02:FS03:0x22: Time: 01:15:36
15:31:00:WU03:FS04:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:31:00:WU02:FS03:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:31:00:WU03:FS04:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:31:00:WU02:FS03:0x22: Branch: HEAD
15:31:00:WU03:FS04:0x22: CPUs: 2
15:31:00:WU02:FS03:0x22: Compiler: Visual C++
15:31:00:WU03:FS04:0x22: Memory: 7.93GiB
15:31:00:WU02:FS03:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:00:WU03:FS04:0x22:Free Memory: 5.33GiB
15:31:00:WU02:FS03:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:31:00:WU03:FS04:0x22: Threads: WINDOWS_THREADS
15:31:00:WU02:FS03:0x22: Platform: win32 10
15:31:00:WU03:FS04:0x22: OS Version: 6.2
15:31:00:WU02:FS03:0x22: Bits: 64
15:31:00:WU03:FS04:0x22:Has Battery: false
15:31:00:WU02:FS03:0x22: Mode: Release
15:31:00:WU03:FS04:0x22: On Battery: false
15:31:00:WU02:FS03:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:31:00:WU03:FS04:0x22: UTC Offset: -5
15:31:00:WU02:FS03:0x22: <peastman@stanford.edu>
15:31:00:WU03:FS04:0x22: PID: 4264
15:31:00:WU02:FS03:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 2788 -checkpoint 15
15:31:00:WU03:FS04:0x22: CWD: C:\ProgramData\FAHClient\work
15:31:00:WU02:FS03:0x22: -opencl-platform 0 -opencl-device 4 -gpu-vendor amd -gpu 4
15:31:00:WU03:FS04:0x22:************************************ OpenMM ************************************
15:31:00:WU02:FS03:0x22: -gpu-usage 100
15:31:00:WU03:FS04:0x22: Version: 7.7.0
15:31:00:WU02:FS03:0x22:************************************ libFAH ************************************
15:31:00:WU03:FS04:0x22:********************************************************************************
15:31:00:WU03:FS04:0x22:Project: 18021 (Run 46, Clone 1, Gen 398)
15:31:00:WU02:FS03:0x22: Time: 01:14:17
15:31:00:WU03:FS04:0x22:Digital signatures verified
15:31:00:WU02:FS03:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:31:00:WU03:FS04:0x22:Folding@home GPU Core22 Folding@home Core
15:31:00:WU03:FS04:0x22:Version 0.0.20
15:31:00:WU02:FS03:0x22:************************************ CBang *************************************
15:31:00:WU02:FS03:0x22: Time: 01:13:20
15:31:00:WU02:FS03:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:31:00:WU02:FS03:0x22:************************************ System ************************************
15:31:01:WU05:FS06:Core PID:2900
15:31:01:WU02:FS03:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:31:01:WU05:FS06:FahCore 0x22 started
15:31:01:WU02:FS03:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:31:01:WU02:FS03:0x22: CPUs: 2
15:31:01:WU02:FS03:0x22: Memory: 7.93GiB
15:31:01:WU02:FS03:0x22:Free Memory: 5.33GiB
15:31:01:WU02:FS03:0x22: Threads: WINDOWS_THREADS
15:31:01:WU02:FS03:0x22: OS Version: 6.2
15:31:01:WU02:FS03:0x22:Has Battery: false
15:31:01:WU02:FS03:0x22: On Battery: false
15:31:01:WU02:FS03:0x22: UTC Offset: -5
15:31:01:WU02:FS03:0x22: PID: 3692
15:31:01:WU02:FS03:0x22: CWD: C:\ProgramData\FAHClient\work
15:31:01:WU04:FS05:Starting
15:31:01:WU02:FS03:0x22:************************************ OpenMM ************************************
15:31:01:WU02:FS03:0x22: Version: 7.7.0
15:31:01:WU02:FS03:0x22:********************************************************************************
15:31:01:WU02:FS03:0x22:Project: 18201 (Run 43634, Clone 1, Gen 9)
15:31:01:WU02:FS03:0x22:Digital signatures verified
15:31:01:WU02:FS03:0x22:Folding@home GPU Core22 Folding@home Core
15:31:01:WU02:FS03:0x22:Version 0.0.20
15:31:01:WU04:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 04 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
15:31:02:WU04:FS05:Started FahCore on PID 2744
15:31:02:WU01:FS02:0x22:*********************** Log Started 2022-02-12T15:31:02Z ***********************
15:31:03:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:31:03:WU01:FS02:0x22: Core: Core22
15:31:03:WU01:FS02:0x22: Type: 0x22
15:31:03:WU01:FS02:0x22: Version: 0.0.20
15:31:03:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:31:03:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
15:31:03:WU01:FS02:0x22: Homepage: https://foldingathome.org/
15:31:03:WU01:FS02:0x22: Date: Jan 20 2022
15:31:03:WU01:FS02:0x22: Time: 01:15:36
15:31:03:WU01:FS02:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:31:03:WU01:FS02:0x22: Branch: HEAD
15:31:03:WU01:FS02:0x22: Compiler: Visual C++
15:31:03:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:05:WU01:FS02:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:31:08:WU05:FS06:0x22:*********************** Log Started 2022-02-12T15:31:08Z ***********************
15:31:11:WU01:FS02:0x22: Platform: win32 10
15:31:11:WU05:FS06:0x22:*************************** Core22 Folding@home Core ***************************
15:31:11:WU01:FS02:0x22: Bits: 64
15:31:11:WU05:FS06:0x22: Core: Core22
15:31:11:WU01:FS02:0x22: Mode: Release
15:31:11:WU05:FS06:0x22: Type: 0x22
15:31:11:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:31:11:WU05:FS06:0x22: Version: 0.0.20
15:31:11:WU01:FS02:0x22: <peastman@stanford.edu>
15:31:11:WU05:FS06:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:31:11:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 5700 -checkpoint 15
15:31:11:WU05:FS06:0x22: Copyright: 2020 foldingathome.org
15:31:11:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 2 -gpu-vendor amd -gpu 2
15:31:11:WU05:FS06:0x22: Homepage: https://foldingathome.org/
15:31:11:WU01:FS02:0x22: -gpu-usage 100
15:31:11:WU05:FS06:0x22: Date: Jan 20 2022
15:31:11:WU01:FS02:0x22:************************************ libFAH ************************************
15:31:11:WU05:FS06:0x22: Time: 01:15:36
15:31:11:WU01:FS02:0x22: Date: Jan 20 2022
15:31:11:WU05:FS06:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:31:11:WU01:FS02:0x22: Time: 01:14:17
15:31:11:WU05:FS06:0x22: Branch: HEAD
15:31:11:WU01:FS02:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:31:11:WU05:FS06:0x22: Compiler: Visual C++
15:31:11:WU01:FS02:0x22: Branch: HEAD
15:31:11:WU05:FS06:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:11:WU01:FS02:0x22: Compiler: Visual C++
15:31:12:WU05:FS06:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:31:12:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:12:WU05:FS06:0x22: Platform: win32 10
15:31:12:WU01:FS02:0x22: Platform: win32 10
15:31:12:WU05:FS06:0x22: Bits: 64
15:31:12:WU01:FS02:0x22: Bits: 64
15:31:12:WU05:FS06:0x22: Mode: Release
15:31:12:WU01:FS02:0x22: Mode: Release
15:31:12:WU05:FS06:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:31:12:WU01:FS02:0x22:************************************ CBang *************************************
15:31:12:WU05:FS06:0x22: <peastman@stanford.edu>
15:31:12:WU01:FS02:0x22: Date: Jan 20 2022
15:31:12:WU05:FS06:0x22: Args: -dir 05 -suffix 01 -version 706 -lifeline 4452 -checkpoint 15
15:31:12:WU01:FS02:0x22: Time: 01:13:20
15:31:12:WU05:FS06:0x22: -opencl-platform 0 -opencl-device 1 -gpu-vendor amd -gpu 1
15:31:12:WU01:FS02:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:31:12:WU05:FS06:0x22: -gpu-usage 100
15:31:12:WU01:FS02:0x22: Branch: HEAD
15:31:14:WU05:FS06:0x22:************************************ libFAH ************************************
15:31:14:WU04:FS05:Core PID:3484
15:31:15:WU01:FS02:0x22: Compiler: Visual C++
15:31:15:WU05:FS06:0x22: Date: Jan 20 2022
15:31:15:WU04:FS05:FahCore 0x22 started
15:31:15:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:15:WU05:FS06:0x22: Time: 01:14:17
15:31:15:WU01:FS02:0x22: Platform: win32 10
15:31:15:WU05:FS06:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:31:15:WU01:FS02:0x22: Bits: 64
15:31:15:WU05:FS06:0x22: Branch: HEAD
15:31:15:WU01:FS02:0x22: Mode: Release
15:31:15:WU05:FS06:0x22: Compiler: Visual C++
15:31:15:WU01:FS02:0x22:************************************ System ************************************
15:31:15:WU05:FS06:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:15:WU01:FS02:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:31:15:WU05:FS06:0x22: Platform: win32 10
15:31:15:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:31:15:WU05:FS06:0x22: Bits: 64
15:31:15:WU01:FS02:0x22: CPUs: 2
15:31:15:WU05:FS06:0x22: Mode: Release
15:31:15:WARNING:WU00:FS00:Detected clock skew (1 mins 18 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
15:31:15:WU01:FS02:0x22: Memory: 7.93GiB
15:31:15:WU05:FS06:0x22:************************************ CBang *************************************
15:31:15:WU01:FS02:0x22:Free Memory: 5.30GiB
15:31:16:WU05:FS06:0x22: Date: Jan 20 2022
15:31:16:WU01:FS02:0x22: Threads: WINDOWS_THREADS
15:31:16:WU05:FS06:0x22: Time: 01:13:20
15:31:16:WU01:FS02:0x22: OS Version: 6.2
15:31:16:WU05:FS06:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:31:16:WU01:FS02:0x22:Has Battery: false
15:31:16:WU05:FS06:0x22: Branch: HEAD
15:31:16:WU01:FS02:0x22: On Battery: false
15:31:16:WU05:FS06:0x22: Compiler: Visual C++
15:31:16:WU01:FS02:0x22: UTC Offset: -5
15:31:16:WU05:FS06:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:16:WU01:FS02:0x22: PID: 4520
15:31:16:WU05:FS06:0x22: Platform: win32 10
15:31:16:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
15:31:18:WU05:FS06:0x22: Bits: 64
15:31:19:WU01:FS02:0x22:************************************ OpenMM ************************************
15:31:19:WU05:FS06:0x22: Mode: Release
15:31:19:WU01:FS02:0x22: Version: 7.7.0
15:31:19:WU05:FS06:0x22:************************************ System ************************************
15:31:19:WU01:FS02:0x22:********************************************************************************
15:31:19:WU05:FS06:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:31:21:WU01:FS02:0x22:Project: 17257 (Run 598, Clone 0, Gen 46)
15:31:21:WU05:FS06:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:31:21:WU01:FS02:0x22:Digital signatures verified
15:31:21:WU05:FS06:0x22: CPUs: 2
15:31:21:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:31:21:WU05:FS06:0x22: Memory: 7.93GiB
15:31:21:WU01:FS02:0x22:Version 0.0.20
15:31:21:WU05:FS06:0x22:Free Memory: 5.35GiB
15:31:22:WU05:FS06:0x22: Threads: WINDOWS_THREADS
15:31:23:WU05:FS06:0x22: OS Version: 6.2
15:31:23:WU05:FS06:0x22:Has Battery: false
15:31:23:WU05:FS06:0x22: On Battery: false
15:31:23:WU05:FS06:0x22: UTC Offset: -5
15:31:23:WU05:FS06:0x22: PID: 2900
15:31:23:WU05:FS06:0x22: CWD: C:\ProgramData\FAHClient\work
15:31:23:WU05:FS06:0x22:************************************ OpenMM ************************************
15:31:23:WU05:FS06:0x22: Version: 7.7.0
15:31:23:WU05:FS06:0x22:********************************************************************************
15:31:23:WU05:FS06:0x22:Project: 18201 (Run 43621, Clone 1, Gen 9)
15:31:23:WU05:FS06:0x22:Digital signatures verified
15:31:23:WU05:FS06:0x22:Folding@home GPU Core22 Folding@home Core
15:31:24:WU05:FS06:0x22:Version 0.0.20
15:31:32:WU04:FS05:0x22:*********************** Log Started 2022-02-12T15:31:31Z ***********************
15:31:32:WU04:FS05:0x22:*************************** Core22 Folding@home Core ***************************
15:31:32:WU04:FS05:0x22: Core: Core22
15:31:32:WU04:FS05:0x22: Type: 0x22
15:31:32:WU04:FS05:0x22: Version: 0.0.20
15:31:32:WU04:FS05:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:31:32:WU04:FS05:0x22: Copyright: 2020 foldingathome.org
15:31:32:WU04:FS05:0x22: Homepage: https://foldingathome.org/
15:31:33:WU04:FS05:0x22: Date: Jan 20 2022
15:31:33:WU04:FS05:0x22: Time: 01:15:36
15:31:33:WU04:FS05:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:31:33:WU04:FS05:0x22: Branch: HEAD
15:31:33:WU04:FS05:0x22: Compiler: Visual C++
15:31:33:WU04:FS05:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:33:WU04:FS05:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:31:33:WU04:FS05:0x22: Platform: win32 10
15:31:33:WU04:FS05:0x22: Bits: 64
15:31:33:WU04:FS05:0x22: Mode: Release
15:31:33:WU04:FS05:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:31:33:WU04:FS05:0x22: <peastman@stanford.edu>
15:31:33:WU04:FS05:0x22: Args: -dir 04 -suffix 01 -version 706 -lifeline 2744 -checkpoint 15
15:31:33:WU04:FS05:0x22: -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
15:31:33:WU04:FS05:0x22: -gpu-usage 100
15:31:33:WU04:FS05:0x22:************************************ libFAH ************************************
15:31:34:WU04:FS05:0x22: Date: Jan 20 2022
15:31:34:WU04:FS05:0x22: Time: 01:14:17
15:31:34:WU04:FS05:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:31:34:WU04:FS05:0x22: Branch: HEAD
15:31:35:WU04:FS05:0x22: Compiler: Visual C++
15:31:35:WU04:FS05:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:36:WU04:FS05:0x22: Platform: win32 10
15:31:36:WU04:FS05:0x22: Bits: 64
15:31:36:WU04:FS05:0x22: Mode: Release
15:31:36:WU04:FS05:0x22:************************************ CBang *************************************
15:31:36:WU04:FS05:0x22: Date: Jan 20 2022
15:31:36:WU04:FS05:0x22: Time: 01:13:20
15:31:36:WU04:FS05:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:31:36:WU04:FS05:0x22: Branch: HEAD
15:31:36:WU04:FS05:0x22: Compiler: Visual C++
15:31:36:WU04:FS05:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:31:37:WU04:FS05:0x22: Bits: 64
15:31:37:WU04:FS05:0x22: Mode: Release
15:31:37:WU04:FS05:0x22:************************************ System ************************************
15:31:37:WU04:FS05:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:31:37:WU04:FS05:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:31:37:WU04:FS05:0x22: CPUs: 2
15:31:38:WU04:FS05:0x22: Memory: 7.93GiB
15:31:38:WU04:FS05:0x22:Free Memory: 5.27GiB
15:31:38:WU04:FS05:0x22: Threads: WINDOWS_THREADS
15:31:38:WU04:FS05:0x22: OS Version: 6.2
15:31:38:WU04:FS05:0x22:Has Battery: false
15:31:38:WU04:FS05:0x22: On Battery: false
15:31:38:WU04:FS05:0x22: UTC Offset: -5
15:31:38:WU04:FS05:0x22: PID: 3484
15:31:38:WU04:FS05:0x22: CWD: C:\ProgramData\FAHClient\work
15:31:38:WU04:FS05:0x22:************************************ OpenMM ************************************
15:31:38:WU04:FS05:0x22: Version: 7.7.0
15:31:38:WU04:FS05:0x22:********************************************************************************
15:31:38:WU04:FS05:0x22:Project: 17257 (Run 125, Clone 2, Gen 24)
15:31:38:WU04:FS05:0x22:Digital signatures verified
15:31:38:WU04:FS05:0x22:Folding@home GPU Core22 Folding@home Core
15:31:38:WU04:FS05:0x22:Version 0.0.20
15:32:13:37:127.0.0.1:New Web session
15:32:53:FS02:Paused
15:32:53:FS02:Shutting core down
15:32:54:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 4520
15:32:54:WU01:FS02:0x22:Exiting, please wait. . .
15:32:58:FS02:Unpaused
15:34:15:WU04:FS05:0x22: Checkpoint write interval: 10000 steps (2%) [50 total]
15:34:15:WU04:FS05:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
15:34:15:WU04:FS05:0x22: XTC frame write interval: 50000 steps (10%) [10 total]
15:34:15:WU04:FS05:0x22: Global context and integrator variables write interval: disabled
15:34:16:WU02:FS03:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
15:34:16:WU02:FS03:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
15:34:17:WU02:FS03:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
15:34:17:WU02:FS03:0x22: Global context and integrator variables write interval: disabled
15:34:18:WU05:FS06:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
15:34:18:WU05:FS06:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
15:34:18:WU05:FS06:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
15:34:19:WU05:FS06:0x22: Global context and integrator variables write interval: disabled
15:34:19:WU01:FS02:0x22: Checkpoint write interval: 10000 steps (2%) [50 total]
15:34:19:WU01:FS02:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
15:34:19:WU01:FS02:0x22: XTC frame write interval: 50000 steps (10%) [10 total]
15:34:19:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
15:34:20:WU04:FS05:0x22:There are 3 platforms available.
15:34:20:WU01:FS02:0x22:There are 3 platforms available.
15:34:20:WU04:FS05:0x22:Platform 0: Reference
15:34:20:WU01:FS02:0x22:Platform 0: Reference
15:34:20:WU04:FS05:0x22:Platform 1: CPU
15:34:21:WU01:FS02:0x22:Platform 1: CPU
15:34:21:WU04:FS05:0x22:Platform 2: OpenCL
15:34:21:WU01:FS02:0x22:Platform 2: OpenCL
15:34:21:WU04:FS05:0x22: opencl-device 0 specified
15:34:21:WU01:FS02:0x22: opencl-device 2 specified
15:34:21:WU01:FS02:0x22:ERROR:102: Core startup was interrupted by client.
15:34:21:WU01:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
15:34:21:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
15:34:22:WU01:FS02:Starting
15:34:22:ERROR:WU01:FS02:Failed to start core: Failed to rename 'work/01/logfile_01.txt' to 'work/01/logfile_01-20220212-153422.txt': The process cannot access the file because it is being used by another process.
15:34:22:WU02:FS03:0x22:There are 3 platforms available.
15:34:22:WU05:FS06:0x22:There are 3 platforms available.
15:34:22:WU02:FS03:0x22:Platform 0: Reference
15:34:22:WU05:FS06:0x22:Platform 0: Reference
15:34:22:WU02:FS03:0x22:Platform 1: CPU
15:34:22:WU05:FS06:0x22:Platform 1: CPU
15:34:22:WU02:FS03:0x22:Platform 2: OpenCL
15:34:22:WU05:FS06:0x22:Platform 2: OpenCL
15:34:22:WU02:FS03:0x22: opencl-device 4 specified
15:34:22:WU05:FS06:0x22: opencl-device 1 specified
15:34:25:WU03:FS04:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
15:34:26:WU03:FS04:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
15:34:26:WU03:FS04:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
15:34:27:WU03:FS04:0x22: Global context and integrator variables write interval: disabled
15:34:27:WU03:FS04:0x22:There are 3 platforms available.
15:34:27:WU03:FS04:0x22:Platform 0: Reference
15:34:27:WU03:FS04:0x22:Platform 1: CPU
15:34:27:WU03:FS04:0x22:Platform 2: OpenCL
15:34:27:WU03:FS04:0x22: opencl-device 3 specified
15:35:59:WU01:FS02:Starting
15:35:59:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -opencl-platform 0 -opencl-device 2 -gpu-vendor amd -gpu 2 -gpu-usage 100
15:35:59:WU01:FS02:Started FahCore on PID 5784
15:36:09:WU01:FS02:Core PID:7128
15:36:09:WU01:FS02:FahCore 0x22 started
15:36:09:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:36:16:WU01:FS02:0x22:*********************** Log Started 2022-02-12T15:36:15Z ***********************
15:36:16:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:36:16:WU01:FS02:0x22: Core: Core22
15:36:16:WU01:FS02:0x22: Type: 0x22
15:36:16:WU01:FS02:0x22: Version: 0.0.20
15:36:17:WU01:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:36:18:WU01:FS02:0x22: Copyright: 2020 foldingathome.org
15:36:18:WU01:FS02:0x22: Homepage: https://foldingathome.org/
15:36:18:WU01:FS02:0x22: Date: Jan 20 2022
15:36:18:WU01:FS02:0x22: Time: 01:15:36
15:36:18:WU01:FS02:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
15:36:18:WU01:FS02:0x22: Branch: HEAD
15:36:18:WU01:FS02:0x22: Compiler: Visual C++
15:36:18:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:36:19:WU01:FS02:0x22: -DOPENMM_VERSION="\"7.7.0\""
15:36:19:WU01:FS02:0x22: Platform: win32 10
15:36:19:WU01:FS02:0x22: Bits: 64
15:36:19:WU01:FS02:0x22: Mode: Release
15:36:19:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:36:19:WU01:FS02:0x22: <peastman@stanford.edu>
15:36:19:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 5784 -checkpoint 15
15:36:19:WU01:FS02:0x22: -opencl-platform 0 -opencl-device 2 -gpu-vendor amd -gpu 2
15:36:20:WU01:FS02:0x22: -gpu-usage 100
15:36:20:WU01:FS02:0x22:************************************ libFAH ************************************
15:36:20:WU01:FS02:0x22: Date: Jan 20 2022
15:36:20:WU01:FS02:0x22: Time: 01:14:17
15:36:20:WU01:FS02:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
15:36:20:WU01:FS02:0x22: Branch: HEAD
15:36:20:WU01:FS02:0x22: Compiler: Visual C++
15:36:20:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:36:20:WU01:FS02:0x22: Platform: win32 10
15:36:21:WU01:FS02:0x22: Bits: 64
15:36:21:WU01:FS02:0x22: Mode: Release
15:36:21:WU01:FS02:0x22:************************************ CBang *************************************
15:36:21:WU01:FS02:0x22: Date: Jan 20 2022
15:36:21:WU01:FS02:0x22: Time: 01:13:20
15:36:21:WU01:FS02:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
15:36:21:WU01:FS02:0x22: Branch: HEAD
15:36:21:WU01:FS02:0x22: Compiler: Visual C++
15:36:21:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:36:21:WU01:FS02:0x22: Platform: win32 10
15:36:22:WU01:FS02:0x22: Mode: Release
15:36:22:WU01:FS02:0x22:************************************ System ************************************
15:36:22:WU01:FS02:0x22: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:36:22:WU01:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:36:22:WU01:FS02:0x22: CPUs: 2
15:36:22:WU01:FS02:0x22: Memory: 7.93GiB
15:36:22:WU01:FS02:0x22:Free Memory: 5.03GiB
15:36:22:WU01:FS02:0x22: Threads: WINDOWS_THREADS
15:36:22:WU01:FS02:0x22: OS Version: 6.2
15:36:22:WU01:FS02:0x22:Has Battery: false
15:36:22:WU01:FS02:0x22: On Battery: false
15:36:22:WU01:FS02:0x22: UTC Offset: -5
15:36:22:WU01:FS02:0x22: PID: 7128
15:36:22:WU01:FS02:0x22: CWD: C:\ProgramData\FAHClient\work
15:36:22:WU01:FS02:0x22:************************************ OpenMM ************************************
15:36:22:WU01:FS02:0x22: Version: 7.7.0
15:36:23:WU01:FS02:0x22:********************************************************************************
15:36:23:WU01:FS02:0x22:Project: 17257 (Run 598, Clone 0, Gen 46)
15:36:23:WU01:FS02:0x22:Digital signatures verified
15:36:23:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:36:23:WU01:FS02:0x22:Version 0.0.20
15:37:28:WU01:FS02:0x22: Checkpoint write interval: 10000 steps (2%) [50 total]
15:37:29:WU01:FS02:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
15:37:29:WU01:FS02:0x22: XTC frame write interval: 50000 steps (10%) [10 total]
15:37:29:WU01:FS02:0x22: Global context and integrator variables write interval: disabled
15:37:29:WU01:FS02:0x22:There are 3 platforms available.
15:37:29:WU01:FS02:0x22:Platform 0: Reference
15:37:29:WU01:FS02:0x22:Platform 1: CPU
15:37:29:WU01:FS02:0x22:Platform 2: OpenCL
15:37:29:WU01:FS02:0x22: opencl-device 2 specified
15:40:12:WU00:FS00:0xa8:Watchdog triggered, requesting soft shutdown down
15:50:12:WU00:FS00:0xa8:Watchdog shutdown failed, hard shutdown triggered
15:50:22:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:50:22:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
15:50:22:WU00:FS00:Starting
15:50:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -np 1
15:50:23:WU00:FS00:Started FahCore on PID 8044
15:50:34:WU00:FS00:Core PID:1288
15:50:34:WU00:FS00:FahCore 0xa8 started
15:50:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:50:42:WU00:FS00:0xa8:*********************** Log Started 2022-02-12T15:50:41Z ***********************
15:50:42:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:50:42:WU00:FS00:0xa8: Core: Gromacs
15:50:42:WU00:FS00:0xa8: Type: 0xa8
15:50:42:WU00:FS00:0xa8: Version: 0.0.12
15:50:42:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:50:42:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
15:50:42:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
15:50:42:WU00:FS00:0xa8: Date: Jan 16 2021
15:50:42:WU00:FS00:0xa8: Time: 11:25:04
15:50:42:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:50:42:WU00:FS00:0xa8: Branch: master
15:50:42:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:50:42:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:50:42:WU00:FS00:0xa8: Platform: win32 10
15:50:42:WU00:FS00:0xa8: Bits: 64
15:50:43:WU00:FS00:0xa8: Mode: Release
15:50:43:WU00:FS00:0xa8: SIMD: sse2
15:50:43:WU00:FS00:0xa8: OpenMP: ON
15:50:43:WU00:FS00:0xa8: CUDA: OFF
15:50:43:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 8044 -checkpoint 15 -np 1
15:50:43:WU00:FS00:0xa8:************************************ libFAH ************************************
15:50:43:WU00:FS00:0xa8: Date: Jan 16 2021
15:50:43:WU00:FS00:0xa8: Time: 11:24:13
15:50:43:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:50:43:WU00:FS00:0xa8: Branch: master
15:50:43:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:50:43:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:50:43:WU00:FS00:0xa8: Platform: win32 10
15:50:43:WU00:FS00:0xa8: Bits: 64
15:50:43:WU00:FS00:0xa8:************************************ CBang *************************************
15:50:43:WU00:FS00:0xa8: Time: 11:23:53
15:50:44:WU00:FS00:0xa8: Branch: master
15:50:44:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
15:50:44:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:50:44:WU00:FS00:0xa8: Platform: win32 10
15:50:44:WU00:FS00:0xa8: Bits: 64
15:50:44:WU00:FS00:0xa8: Mode: Release
15:50:44:WU00:FS00:0xa8:************************************ System ************************************
15:50:44:WU00:FS00:0xa8: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
15:50:44:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:50:44:WU00:FS00:0xa8: CPUs: 2
15:50:44:WU00:FS00:0xa8: Memory: 7.93GiB
15:50:44:WU00:FS00:0xa8:Free Memory: 3.24GiB
15:50:44:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
15:50:44:WU00:FS00:0xa8: OS Version: 6.2
15:50:44:WU00:FS00:0xa8:Has Battery: false
15:50:44:WU00:FS00:0xa8: On Battery: false
15:50:44:WU00:FS00:0xa8: UTC Offset: -5
15:50:44:WU00:FS00:0xa8: PID: 1288
15:50:45:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
15:50:45:WU00:FS00:0xa8:********************************************************************************
15:50:45:WU00:FS00:0xa8:Project: 16955 (Run 2, Clone 2893, Gen 140)
15:50:45:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:50:45:WU00:FS00:0xa8:Digital signatures verified
15:50:45:WU00:FS00:0xa8:Calling: mdrun -c frame140.gro -s frame140.tpr -x frame140.xtc -cpt 15 -nt 1 -ntmpi 1
15:51:15:WU00:FS00:0xa8:Steps: first=70000000 total=70500000
16:00:42:WU00:FS00:0xa8:Watchdog triggered, requesting soft shutdown down
16:02:46:WU03:FS04:0x22:Attempting to create OpenCL context:
16:02:46:WU03:FS04:0x22: Configuring platform OpenCL
16:05:50:Saving configuration to config.xml
16:05:50:<config>
16:05:50: <!-- Network -->
16:05:50: <proxy v=':8080'/>
16:05:50:
16:05:50: <!-- Slot Control -->
16:05:50: <power v='FULL'/>
16:05:50:
16:05:50: <!-- User Information -->
16:05:50: <team v='64'/>
16:05:50: <user v='Maliki2'/>
16:05:50:
16:05:50: <!-- Folding Slots -->
16:05:50: <slot id='0' type='CPU'/>
16:05:50: <slot id='1' type='GPU'>
16:05:50: <paused v='true'/>
16:05:50: <pci-bus v='0'/>
16:05:50: <pci-slot v='2'/>
16:05:50: </slot>
16:05:50: <slot id='2' type='GPU'>
16:05:50: <pci-bus v='10'/>
16:05:50: <pci-slot v='0'/>
16:05:50: </slot>
16:05:50: <slot id='3' type='GPU'>
16:05:50: <pci-bus v='13'/>
16:05:50: </slot>
16:05:50: <slot id='4' type='GPU'>
16:05:50: <pci-bus v='16'/>
16:05:50: </slot>
16:05:50: <slot id='5' type='GPU'>
16:05:50: <pci-bus v='3'/>
16:05:50: </slot>
16:05:50: <slot id='6' type='GPU'>
16:05:50: <pci-bus v='7'/>
16:05:50: </slot>
16:05:50:</config>
16:06:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:08:38:WU00:FS00:0xa8:Completed 1 out of 500000 steps (0%)
16:10:42:WU00:FS00:0xa8:Watchdog shutdown failed, hard shutdown triggered
16:10:58:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:10:59:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
16:10:59:WU00:FS00:Starting
16:10:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 3256 -checkpoint 15 -np 1
16:10:59:WU00:FS00:Started FahCore on PID 3776
16:11:09:WU00:FS00:Core PID:7424
16:11:09:WU00:FS00:FahCore 0xa8 started
16:11:20:WU00:FS00:0xa8:*********************** Log Started 2022-02-12T16:11:20Z ***********************
16:11:20:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:11:21:WU00:FS00:0xa8: Core: Gromacs
16:11:21:WU00:FS00:0xa8: Type: 0xa8
16:11:21:WU00:FS00:0xa8: Version: 0.0.12
16:11:21:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:11:21:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
16:11:21:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
16:11:21:WU00:FS00:0xa8: Date: Jan 16 2021
16:11:21:WU00:FS00:0xa8: Time: 11:25:04
16:11:21:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:11:21:WU00:FS00:0xa8: Branch: master
16:11:21:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
16:11:22:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:11:22:WU00:FS00:0xa8: Platform: win32 10
16:11:22:WU00:FS00:0xa8: Bits: 64
16:11:22:WU00:FS00:0xa8: Mode: Release
16:11:22:WU00:FS00:0xa8: SIMD: sse2
16:11:22:WU00:FS00:0xa8: OpenMP: ON
16:11:22:WU00:FS00:0xa8: CUDA: OFF
16:11:22:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 3776 -checkpoint 15 -np 1
16:11:22:WU00:FS00:0xa8:************************************ libFAH ************************************
16:11:22:WU00:FS00:0xa8: Date: Jan 16 2021
16:11:22:WU00:FS00:0xa8: Time: 11:24:13
16:11:22:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:11:22:WU00:FS00:0xa8: Branch: master
16:11:22:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
16:11:23:WU00:FS00:0xa8:************************************ CBang *************************************
16:11:23:WU00:FS00:0xa8: Date: Jan 16 2021
16:11:23:WU00:FS00:0xa8: Time: 11:23:53
16:11:23:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:11:23:WU00:FS00:0xa8: Branch: master
16:11:23:WU00:FS00:0xa8: Compiler: Visual C++ 2019 16.7
16:11:23:WU00:FS00:0xa8: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:11:23:WU00:FS00:0xa8: Platform: win32 10
16:11:23:WU00:FS00:0xa8: Bits: 64
16:11:23:WU00:FS00:0xa8: Mode: Release
16:11:23:WU00:FS00:0xa8:************************************ System ************************************
16:11:23:WU00:FS00:0xa8: CPU: Intel(R) Celeron(R) CPU G3930 @ 2.90GHz
16:11:23:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:11:24:WU00:FS00:0xa8: CPUs: 2
16:11:24:WU00:FS00:0xa8: Memory: 7.93GiB
16:11:24:WU00:FS00:0xa8:Free Memory: 2.73GiB
16:11:24:WU00:FS00:0xa8: Threads: WINDOWS_THREADS
16:11:24:WU00:FS00:0xa8: OS Version: 6.2
16:11:24:WU00:FS00:0xa8:Has Battery: false
16:11:24:WU00:FS00:0xa8: On Battery: false
16:11:24:WU00:FS00:0xa8: UTC Offset: -5
16:11:24:WU00:FS00:0xa8: PID: 7424
16:11:24:WU00:FS00:0xa8: CWD: C:\ProgramData\FAHClient\work
16:11:24:WU00:FS00:0xa8:********************************************************************************
16:11:24:WU00:FS00:0xa8:Project: 16955 (Run 2, Clone 2893, Gen 140)
16:11:24:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:11:24:WU00:FS00:0xa8:Digital signatures verified
16:11:24:WU00:FS00:0xa8:Calling: mdrun -c frame140.gro -s frame140.tpr -x frame140.xtc -cpt 15 -nt 1 -ntmpi 1
16:11:39:WU00:FS00:0xa8:Steps: first=70000000 total=70500000
Short and simple, you're processor is throttling the rest of your system.
You need at least a thread/core for each GPU, you have just two and you're trying to fold on the cpu as well.
Suggestion:-
1). remove the cpu slot
2). remove/stop three of the AMD GPUs, remove the intel slot.
3). see how the system runs with just a pair of GPUs in it. It may still struggle but it should do something.
Suggestion:-
aetch wrote:Short and simple, you're processor is throttling the rest of your system.
Suggestion:-
Thanks. Going to give that a shot now!!!
Suggestion:-
At this point two are running. No updates still. Just rebooted will see what happens after that.
A few more thoughts.
This feels like a mining rig you're trying to repurpose - small cpu, lots of GPUs, x1 PCIe risers for the GPUs?
A folding rig is a very different beast from a mining rig. The CPU is constantly moving data to and from the GPUs.
It needs bandwidth for the GPUs, x8 recommended, x4 bare minimum. That usually means plugging the GPUs directly into the motherboard.
At least a thread/core for each GPU. 5 GPUs would require and i7 processor. An i5 would do just fine with 2 or 3 GPUs.
Your 16GB of RAM should be plently.
Appreciate all the help. This is generally my mining rig. All on risers. I kicked everything off except one GPU to see where it goes. I will upgrade the CPU and see where it goes. Originally, I wanted cheap and that's what I got. I guess I will have to move up some and see what happens with a I7 or I5. Appreciate all the help.aetch wrote:A few more thoughts.
Just now the bandwidth is the cheap one to try.
Plug a couple of cards directly into the motherboard, I'm assuming the motherboard has a couple of x16 slots.
So, I think there is something else up. I have one GPU running and no updates. I have 2 laptops running and they are getting updates and my other PC. Its just that one computer(miner) that won't update with GPUs. I'm not sure where I'm at, at this pointaetch wrote:A few more thoughts.
It does. Thank you. I will have to rip the rig apart to get them in there and see what happens.aetch wrote:Just now the bandwidth is the cheap one to try.
Possibly related to the inactive slot. Do you have anything running (e.g. antivirus) that might put a lock on the work files?15:34:22:ERROR:WU01:FS02:Failed to start core: Failed to rename 'work/01/logfile_01.txt' to 'work/01/logfile_01-20220212-153422.txt': The process cannot access the file because it is being used by another process.
