GPU work not showing up right.
Sandman192
Post by Sandman192 »
Why am I showing 1 active client, when I've been running 2 WU for over a year? 1 CPU and 1 GPU. I've check, I'm still running 2 WUs on 1 PC. Plus, in I can't see what team I'm using for each PC within the new Donor Statistics like I could before. Also, clicking on my Username within the program and it does bring up the doner names site, but it's also blank.
This is 98% done for GPU work and this is all I get for GPU work.
09:39:58:WU01:FS01:0x22:************************************ OpenMM ************************************
09:39:58:WU01:FS01:0x22: Version: 7.6.0
09:39:58:WU01:FS01:0x22:********************************************************************************
09:39:58:WU01:FS01:0x22:Project: 17257 (Run 783, Clone 2, Gen 31)
09:39:58:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
09:39:58:WU01:FS01:0x22:Digital signatures verified
09:39:58:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:39:58:WU01:FS01:0x22:Version 0.0.18
09:39:58:WU01:FS01:0x22: Checkpoint write interval: 10000 steps (2%) [50 total]
09:39:58:WU01:FS01:0x22: JSON viewer frame write interval: 5000 steps (1%) [100 total]
09:39:58:WU01:FS01:0x22: XTC frame write interval: 50000 steps (10%) [10 total]
09:39:58:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
09:39:59:WU01:FS01:0x22:There are 3 platforms available.
09:39:59:WU01:FS01:0x22:Platform 0: Reference
09:39:59:WU01:FS01:0x22:Platform 1: CPU
09:39:59:WU01:FS01:0x22:Platform 2: OpenCL
09:39:59:WU01:FS01:0x22: opencl-device 0 specified
09:45:53:WU01:FS01:0x22:Attempting to create OpenCL context:
09:45:53:WU01:FS01:0x22: Configuring platform OpenCL
******************************* Date: 2022-01-30 *******************************
******************************* Date: 2022-01-31 *******************************
******************************* Date: 2022-02-01 *******************************
******************************* Date: 2022-02-02 *******************************
Re: GPU work not showing up right.
The useful part of the log is the configuration, usually the first 100 lines. Without it, we don't know your GPU, your OS, or much of anything.
Sandman192
Sorry I was sick and bussie.
*********************** Log Started 2022-02-22T01:14:32Z ***********************
******************************* libFAH ********************************
Date: Oct 20 2020
Time: 13:36:55
Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
Branch: master
Compiler: Visual C++ 2015
Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
Platform: win32 10
Bits: 32
Mode: Release
****************************** FAHClient ******************************
Version: 7.6.21
Author: Joseph Coffland <joseph@cauldrondevelopment.com>
Copyright: 2020 foldingathome.org
Homepage: https://foldingathome.org/
Date: Oct 20 2020
Time: 13:41:04
Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
Branch: master01:14:32:
Compiler: Visual C++ 201501:14:32:
Platform: win32 10
Bits: 32
Mode: Release
Config: E:\Users\******\AppData\Roaming\FAHClient\config.xml
******************************** CBang ********************************
Date: Oct 20 2020
Time: 11:36:18
Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
Branch: master
Platform: win32 10
Bits: 32
Mode: Release
******************************* System ********************************
CPU: AMD E2-3800 APU with Radeon(TM) HD Graphics
CPU ID: AuthenticAMD Family 22 Model 0 Stepping 1
CPUs: 4
Memory: 7.46GiB01:14:32:    Free Memory: 4.59GiB
Threads: WINDOWS_THREADS
OS Version: 6.2
Has Battery: false
On Battery: false
UTC Offset: -6
PID: 1204
CWD: E:\Users\******\AppData\Roaming\FAHClient
Win32 Service: false
OS: Windows 10 Home
OS Arch: AMD64
GPUs: 1
GPU 0: Bus:0 Slot:1 Func:0 AMD:5 Temash [Radeon HD 8280]
CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The specified module could not be found.
OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:3188.4
Your GPU seems to be an HD 8280.
https://www.techpowerup.com/gpu-specs/r ... 280e.c2197
While technically supported ( it does 64 bit floating point math and supports better than OpenCL 1.2) it is so slow it will never complete a Work Unit. It is 12 times slower than the slowest GPU I know will finish a WU.
A modern driver may be
https://www.amd.com/en/support/previous ... on-hd-8280
But I don't think it will help.
I guess we should disable such things ...
Sandman192
toTOW wrote:I guess we should disable such things ...
Disable what thing? The GPU? Wall, the GPU is slow and only has 512 Gigs.
So, I just disabled it. If that what you mean.
It worked on GPUs before and F@H seem to did some changes. I'm not going to update the GPU drivers anymore. It's an old computer anyway.
Thank for the help.
