Folding system: Auto mode
Mustung
Hardware configuration: Asus Z170p
Intel 6700k
AMD Rx Vega 56
8GB DDR4
Intel 760P 256G
Post by Mustung »
yes sir, foling system is now in auto mode :D
AMD 5800x Gigabyte 3090 LC
RTX2060(s) x 6
aetch
Re: Folding slot option ignored during boot up?
Post by aetch »
I believe the client is designed to automatically detect and add new GPUs, it's a feature.
To stop it:-
Go to the "Expert client options", Advanced Control -> Configure -> Expert, and add an entry name = 'gpu', value 'false'.
Remove the slot you don't want.
Reboot/restart to make sure it works.
If it interests you, I also use an option named 'pause-on-start' to make sure the client only starts folding when I tell it to.
Don't touch pci-bus and pci-slot settings in a GPU slot, they are handled automatically by the client.
