GPU disabled
Forcinghavok
GPU disabled
Post by Forcinghavok »
hello, after a crash I woke up to a computer saying something and I forgot, and it was a blue screen. Then I loaded f@h and it said the GPU was disabled?!!!! How do I reenable it?
Forcinghavok
Re: GPU disabled
says beta code disabled or something below!!! how did it even get to beta GPU? need to re-enable it somehow!! please help, thanks.
*********************** Log Started 2022-01-22T10:30:32Z ***********************
10:30:32:******************************* libFAH ********************************
10:30:32:           Date: Oct 20 2020
10:30:32:           Time: 13:36:55
10:30:32:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
10:30:32:         Branch: master
10:30:32:       Compiler: Visual C++ 2015
10:30:32:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
10:30:32:       Platform: win32 10
10:30:32:           Bits: 32
10:30:32:           Mode: Release
10:30:32:****************************** FAHClient ******************************
10:30:32:        Version: 7.6.21
10:30:32:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:30:32:      Copyright: 2020 foldingathome.org
10:30:32:       Homepage: https://foldingathome.org/
10:30:32:           Time: 13:41:04
10:30:32:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
10:30:32:           Bits: 32
10:30:32:         Config: C:\ProgramData\FAHClient\config.xml
10:30:32:******************************** CBang ********************************
10:30:32:           Time: 11:36:18
10:30:32:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
10:30:32:           Bits: 32
10:30:32:******************************* System ********************************
10:30:32:            CPU: AMD FX(tm)-8350 Eight-Core Processor
10:30:32:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
10:30:32:           CPUs: 8
10:30:32:         Memory: 15.90GiB
10:30:32:    Free Memory: 13.44GiB
10:30:32:        Threads: WINDOWS_THREADS
10:30:32:     OS Version: 6.2
10:30:32:    Has Battery: false
10:30:32:     On Battery: false
10:30:32:     UTC Offset: -5
10:30:32:            PID: 668
10:30:32:            CWD: C:\ProgramData\FAHClient
10:30:32:  Win32 Service: false
10:30:32:             OS: Windows 10 Home
10:30:32:        OS Arch: AMD64
10:30:32:           GPUs: 1
10:30:32:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1
10:30:32:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:30:32:                 specified module could not be found.
10:30:32:
10:30:32:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3302.6
10:30:32:***********************************************************************
10:30:32:<config>
10:30:32:  <!-- Network -->
10:30:32:  <proxy v=':8080'/>
10:30:32:
10:30:32:  <!-- Slot Control -->
10:30:32:  <power v='full'/>
10:30:32:
10:30:32:  <!-- User Information -->
10:30:32:  <team v='2092'/>
10:30:32:  <user v='ForcingHavok'/>
10:30:32:
10:30:32:  <!-- Folding Slots -->
10:30:32:  <slot id='0' type='CPU'>
10:30:32:    <cpus v='4'/>
10:30:32:  </slot>
10:30:32:  <slot id='1' type='GPU'>
10:30:32:    <pci-bus v='3'/>
10:30:32:    <pci-slot v='0'/>
10:30:32:  </slot>
10:30:32:</config>
10:30:32:Trying to access database...
10:30:32:Successfully acquired database lock
10:30:32:FS00:Initialized folding slot 00: cpu:4
10:30:32:WARNING:FS01:Disabling beta GPU slot 01: gpu:3:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
10:30:32:WU02:FS00:Starting
10:30:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 668 -checkpoint 15 -np 4
10:30:33:WU02:FS00:Started FahCore on PID 8876
10:30:39:WU02:FS00:Core PID:8948
10:30:39:WU02:FS00:FahCore 0xa8 started
10:30:51:WU02:FS00:0xa8:*********************** Log Started 2022-01-22T10:30:44Z ***********************
10:30:51:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
10:30:51:WU02:FS00:0xa8:       Core: Gromacs
10:30:51:WU02:FS00:0xa8:       Type: 0xa8
10:30:51:WU02:FS00:0xa8:    Version: 0.0.12
10:30:51:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:30:51:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
10:30:51:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
10:30:51:WU02:FS00:0xa8:       Date: Jan 16 2021
10:30:51:WU02:FS00:0xa8:       Time: 11:56:07
10:30:51:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
10:30:51:WU02:FS00:0xa8:     Branch: master
10:30:51:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
10:30:51:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
10:30:51:WU02:FS00:0xa8:   Platform: win32 10
10:30:51:WU02:FS00:0xa8:       Bits: 64
10:30:51:WU02:FS00:0xa8:       Mode: Release
10:30:51:WU02:FS00:0xa8:       SIMD: avx_256
10:30:51:WU02:FS00:0xa8:     OpenMP: ON
10:30:51:WU02:FS00:0xa8:       CUDA: OFF
10:30:51:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8876 -checkpoint 15 -np 4
10:30:51:WU02:FS00:0xa8:************************************ libFAH ************************************
10:30:51:WU02:FS00:0xa8:       Time: 11:24:13
10:30:51:WU02:FS00:0xa8:************************************ CBang *************************************
10:30:51:WU02:FS00:0xa8:       Time: 11:23:53
10:30:51:WU02:FS00:0xa8:************************************ System ************************************
10:30:51:WU02:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
10:30:51:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
10:30:51:WU02:FS00:0xa8:       CPUs: 8
10:30:51:WU02:FS00:0xa8:     Memory: 15.90GiB
10:30:51:WU02:FS00:0xa8:Free Memory: 13.21GiB
10:30:51:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
10:30:51:WU02:FS00:0xa8: OS Version: 6.2
10:30:51:WU02:FS00:0xa8:Has Battery: false
10:30:51:WU02:FS00:0xa8: On Battery: false
10:30:51:WU02:FS00:0xa8: UTC Offset: -5
10:30:51:WU02:FS00:0xa8:        PID: 8948
10:30:51:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
10:30:51:WU02:FS00:0xa8:********************************************************************************
10:30:51:WU02:FS00:0xa8:Project: 16815 (Run 16, Clone 768, Gen 68)
10:30:51:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
10:30:51:WU02:FS00:0xa8:Digital signatures verified
10:30:54:WU02:FS00:0xa8:Calling: mdrun -c frame68.gro -s frame68.tpr -x frame68.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
10:30:57:WU02:FS00:0xa8:Steps: first=0 total=500000
10:31:00:WU02:FS00:0xa8:Completed 41601 out of 500000 steps (8%)
bikeaddict
Re: GPU disabled
Post by bikeaddict »
The beta GPU message is what it usually logs when there is no internet connection when the FAH service starts up on boot. It needs to download the gpus.txt file to identify the GPU type and disables GPU folding when it can't connect. Try stopping and starting the FAH service to make it retry.
Re: GPU disabled
Or the drivers have been updated by Windows Updates automatically, and those drivers don't have OpenCL ...
