project 18405 stuck at 99 percent
slonas
Post by slonas »
this issue is going on the work unit is stuck at 99 percent
PRCG 18405 (120, 4, 13)
this is the logs
*********************** Log Started 2022-01-17T14:31:18Z ***********************
14:31:18:******************************* libFAH ********************************
14:31:18:           Date: Oct 20 2020
14:31:18:           Time: 13:36:55
14:31:18:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:31:18:         Branch: master
14:31:18:       Compiler: Visual C++ 2015
14:31:18:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:31:18:       Platform: win32 10
14:31:18:           Bits: 32
14:31:18:           Mode: Release
14:31:18:****************************** FAHClient ******************************
14:31:18:        Version: 7.6.21
14:31:18:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:31:18:      Copyright: 2020 foldingathome.org
14:31:18:       Homepage: https://foldingathome.org/
14:31:18:           Time: 13:41:04
14:31:18:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:31:18:           Bits: 32
14:31:18:           Args: --open-web-control
14:31:18:         Config: C:\ProgramData\FAHClient\config.xml
14:31:18:******************************** CBang ********************************
14:31:18:           Time: 11:36:18
14:31:18:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:31:18:           Bits: 32
14:31:18:******************************* System ********************************
14:31:18:            CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
14:31:18:         CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
14:31:18:           CPUs: 8
14:31:18:         Memory: 15.79GiB
14:31:18:    Free Memory: 10.54GiB
14:31:18:        Threads: WINDOWS_THREADS
14:31:18:     OS Version: 6.2
14:31:18:    Has Battery: true
14:31:18:     On Battery: false
14:31:18:     UTC Offset: -7
14:31:18:            PID: 9596
14:31:18:            CWD: C:\ProgramData\FAHClient
14:31:18:  Win32 Service: false
14:31:18:             OS: Windows 10 Home
14:31:18:        OS Arch: AMD64
14:31:18:           GPUs: 1
14:31:18:          GPU 0: Bus:6 Slot:0 Func:0 NVIDIA:5 GP108M [GeForce MX250]
14:31:18:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:6.1 Driver:11.5
14:31:18:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:3.0 Driver:497.29
14:31:18:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
14:31:18:***********************************************************************
14:31:18:<config>
14:31:18:  <!-- Folding Slot Configuration -->
14:31:18:  <cause v='COVID_19'/>
14:31:18:
14:31:18:  <!-- Network -->
14:31:18:  <proxy v=':8080'/>
14:31:18:
14:31:18:  <!-- Slot Control -->
14:31:18:  <idle v='true'/>
14:31:18:  <power v='FULL'/>
14:31:18:
14:31:18:  <!-- User Information -->
14:31:18:  <passkey v='*****'/>
14:31:18:  <team v='224497'/>
14:31:18:  <user v='slonas_1LW1BvKjTDqtKUwouLH68qkQvrKDCr8eF2'/>
14:31:18:
14:31:18:  <!-- Folding Slots -->
14:31:18:  <slot id='0' type='CPU'>
14:31:18:    <idle v='false'/>
14:31:18:  </slot>
14:31:18:  <slot id='1' type='GPU'>
14:31:18:    <max-packet-size v='big'/>
14:31:18:    <pci-bus v='6'/>
14:31:18:    <pci-slot v='0'/>
14:31:18:  </slot>
14:31:18:</config>
14:31:18:Trying to access database...
14:31:18:Successfully acquired database lock
14:31:18:FS00:Initialized folding slot 00: cpu:7
14:31:18:FS01:Initialized folding slot 01: gpu:6:0 GP108M [GeForce MX250]
14:31:19:WU00:FS00:Starting
14:31:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 9596 -checkpoint 15 -np 7
14:31:19:WU00:FS00:Started FahCore on PID 16156
14:31:19:WU00:FS00:Core PID:13296
14:31:19:WU00:FS00:FahCore 0xa8 started
14:31:19:WU02:FS01:Starting
14:31:19:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9596 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
14:31:19:WU02:FS01:Started FahCore on PID 13664
14:31:19:WU02:FS01:Core PID:8828
14:31:19:WU02:FS01:FahCore 0x22 started
14:31:19:WU00:FS00:0xa8:*********************** Log Started 2022-01-17T14:31:19Z ***********************
14:31:19:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
14:31:19:WU00:FS00:0xa8:       Core: Gromacs
14:31:19:WU00:FS00:0xa8:       Type: 0xa8
14:31:19:WU00:FS00:0xa8:    Version: 0.0.12
14:31:19:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:31:19:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
14:31:19:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
14:31:19:WU00:FS00:0xa8:       Date: Jan 16 2021
14:31:19:WU00:FS00:0xa8:       Time: 12:29:40
14:31:19:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:31:19:WU00:FS00:0xa8:     Branch: master
14:31:19:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
14:31:19:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:31:19:WU00:FS00:0xa8:   Platform: win32 10
14:31:19:WU00:FS00:0xa8:       Bits: 64
14:31:19:WU00:FS00:0xa8:       Mode: Release
14:31:19:WU00:FS00:0xa8:       SIMD: avx2_256
14:31:19:WU00:FS00:0xa8:     OpenMP: ON
14:31:19:WU00:FS00:0xa8:       CUDA: OFF
14:31:19:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16156 -checkpoint 15 -np
14:31:19:WU00:FS00:0xa8:             7
14:31:19:WU00:FS00:0xa8:************************************ libFAH ************************************
14:31:19:WU00:FS00:0xa8:       Time: 11:24:13
14:31:19:WU00:FS00:0xa8:************************************ CBang *************************************
14:31:19:WU00:FS00:0xa8:       Time: 11:23:53
14:31:19:WU00:FS00:0xa8:************************************ System ************************************
14:31:19:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
14:31:19:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
14:31:19:WU00:FS00:0xa8:       CPUs: 8
14:31:19:WU00:FS00:0xa8:     Memory: 15.79GiB
14:31:19:WU00:FS00:0xa8:Free Memory: 10.52GiB
14:31:19:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
14:31:19:WU00:FS00:0xa8: OS Version: 6.2
14:31:19:WU00:FS00:0xa8:Has Battery: true
14:31:19:WU00:FS00:0xa8: On Battery: false
14:31:19:WU00:FS00:0xa8: UTC Offset: -7
14:31:19:WU00:FS00:0xa8:        PID: 13296
14:31:19:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
14:31:19:WU00:FS00:0xa8:********************************************************************************
14:31:19:WU00:FS00:0xa8:Project: 18405 (Run 120, Clone 4, Gen 13)
14:31:19:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
14:31:19:WU00:FS00:0xa8:Digital signatures verified
14:31:19:WU00:FS00:0xa8:Calling: mdrun -c frame13.gro -s frame13.tpr -x frame13.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
14:31:19:WU00:FS00:0xa8:Steps: first=130000000 total=140000000
14:31:20:WU02:FS01:0x22:*********************** Log Started 2022-01-17T14:31:19Z ***********************
14:31:20:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:31:20:WU02:FS01:0x22:       Core: Core22
14:31:20:WU02:FS01:0x22:       Type: 0x22
14:31:20:WU02:FS01:0x22:    Version: 0.0.18
14:31:20:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:31:20:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
14:31:20:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
14:31:20:WU02:FS01:0x22:       Date: Sep 28 2021
14:31:20:WU02:FS01:0x22:       Time: 05:55:05
14:31:20:WU02:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
14:31:20:WU02:FS01:0x22:     Branch: HEAD
14:31:20:WU02:FS01:0x22:   Compiler: Visual C++
14:31:20:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:31:20:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
14:31:20:WU02:FS01:0x22:   Platform: win32 10
14:31:20:WU02:FS01:0x22:       Bits: 64
14:31:20:WU02:FS01:0x22:       Mode: Release
14:31:20:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:31:20:WU02:FS01:0x22:             <peastman@stanford.edu>
14:31:20:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 13664 -checkpoint 15
14:31:20:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
14:31:20:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
14:31:20:WU02:FS01:0x22:************************************ libFAH ************************************
14:31:20:WU02:FS01:0x22:       Time: 05:53:43
14:31:20:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:31:20:WU02:FS01:0x22:************************************ CBang *************************************
14:31:20:WU02:FS01:0x22:       Time: 05:52:38
14:31:20:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:31:20:WU02:FS01:0x22:************************************ System ************************************
14:31:20:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
14:31:20:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 126 Stepping 5
14:31:20:WU02:FS01:0x22:       CPUs: 8
14:31:20:WU02:FS01:0x22:     Memory: 15.79GiB
14:31:20:WU02:FS01:0x22:Free Memory: 10.50GiB
14:31:20:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
14:31:20:WU02:FS01:0x22: OS Version: 6.2
14:31:20:WU02:FS01:0x22:Has Battery: true
14:31:20:WU02:FS01:0x22: On Battery: false
14:31:20:WU02:FS01:0x22: UTC Offset: -7
14:31:20:WU02:FS01:0x22:        PID: 8828
14:31:20:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
14:31:20:WU02:FS01:0x22:************************************ OpenMM ************************************
14:31:20:WU02:FS01:0x22:    Version: 7.6.0
14:31:20:WU02:FS01:0x22:********************************************************************************
14:31:20:WU02:FS01:0x22:Project: 18123 (Run 8, Clone 41, Gen 67)
14:31:20:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
14:31:20:WU02:FS01:0x22:Digital signatures verified
14:31:20:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:31:20:WU02:FS01:0x22:Version 0.0.18
14:31:20:WU02:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
14:31:20:WU02:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
14:31:20:WU02:FS01:0x22:  XTC frame write interval: 50000 steps (1%) [100 total]
14:31:20:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
14:31:20:WU02:FS01:0x22:There are 4 platforms available.
14:31:20:WU02:FS01:0x22:Platform 0: Reference
14:31:20:WU02:FS01:0x22:Platform 1: CPU
14:31:20:WU02:FS01:0x22:Platform 2: OpenCL
14:31:20:WU02:FS01:0x22:  opencl-device 0 specified
14:31:20:WU02:FS01:0x22:Platform 3: CUDA
14:31:20:WU02:FS01:0x22:  cuda-device 0 specified
14:31:22:17:127.0.0.1:New Web session
14:31:22:WU00:FS00:0xa8:Completed 2336021 out of 10000000 steps (23%)
14:31:26:WU02:FS01:0x22:Attempting to create CUDA context:
14:31:26:WU02:FS01:0x22:  Configuring platform CUDA
14:31:36:WU02:FS01:0x22:  Using CUDA and gpu 0
14:31:36:WU02:FS01:0x22:Completed 1500000 out of 5000000 steps (30%)
14:34:21:Removing old file 'configs/config-20220110-061945.xml'
14:34:21:Saving configuration to config.xml
14:34:21:<config>
14:34:21:  <!-- Folding Slot Configuration -->
14:34:21:  <cause v='COVID_19'/>
14:34:21:
14:34:21:  <!-- Network -->
14:34:21:  <proxy v=':8080'/>
14:34:21:
14:34:21:  <!-- Slot Control -->
14:34:21:  <idle v='true'/>
14:34:21:  <power v='FULL'/>
14:34:21:
14:34:21:  <!-- User Information -->
14:34:21:  <passkey v='*****'/>
14:34:21:  <team v='224497'/>
14:34:21:  <user v='slonas'/>
14:34:21:
14:34:21:  <!-- Folding Slots -->
14:34:21:  <slot id='0' type='CPU'>
14:34:21:    <idle v='false'/>
14:34:21:  </slot>
14:34:21:  <slot id='1' type='GPU'>
14:34:21:    <max-packet-size v='big'/>
14:34:21:    <pci-bus v='6'/>
14:34:21:    <pci-slot v='0'/>
14:34:21:  </slot>
14:34:21:</config>
14:36:41:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
14:38:09:WU02:FS01:0x22:Completed 1550000 out of 5000000 steps (31%)
14:40:27:Removing old file 'configs/config-20220110-072634.xml'
14:40:27:Saving configuration to config.xml
Reason: added code tags to log
Re: project 18405 stuck at 99 percent
According to your log, it's at 23% ... and the GPU WU (p18123) is at 31% ...
slonas
Post by slonas »
thats weird it must of glitched for me in the main screen its 99 percent but after i posted this i think it fixed itself and uploaded.
MarkH
Post by MarkH »
I saw this happen with a few WUs (do not have the ID numbers). I stopped the job if I could and re-booted my machine. After that the issue corrected itself. I had jobs telling me wild numbers like xxx,xxx,xxx,xxx,xxx PPD; In other words, I won the entire Internet! :D
"N-Not like I like science, or f-female scientists, B-Baka!" :e)
"Whatever it is, I'm against it!" -- Groucho Marx
