[SOLVED] World-readable permissions on config.xml
ajgringo619
Post by ajgringo619 »
Is it necessary to have world-readable (644) permissions on /etc/foldingathome/config.xml? Curious why this is the default when passwords/keys are stored there.
Re: World-readable permissions on config.xml
Post by calxalot »
It can be 0600 if you like.
ajgringo619
calxalot wrote:It can be 0600 if you like.
Thanks; didn't want to mess anything up when it's working so well.
ajgringo619
To make the change permanent, I had to add this to the foldingathome.service file:
# /etc/systemd/system/foldingathome.service.d/override.conf
[Service]
ExecStartPre=!/usr/bin/chmod 600 /etc/foldingathome/config.xml
Post by calxalot »
You might want to change the umask for user fahclient
ajgringo619
calxalot wrote:You might want to change the umask for user fahclient
Not sure how to do this with a dynamic user, but thanks for the suggestion. My chmod command worked, but it went right back to normal after the next WU was started.
Post by calxalot »
I think you can add
UMask=0077
in your FAHClient.service
ajgringo619
Thank you so much - that did the trick!
