Failed status reported for RTX3070
iokeith
Post by iokeith »
I have an Dell XPS 8940 running win 10 with a Nvidia GeForce RTX 3070 in slot 1 driven by driver version 30.0.14.7141
On Failed status the log reports a Forced RMSE error with a threshold 5, a Bad work unit, and a Faulty project 13460
Could anyone tell me what is going on here?
Thanks
18:03:14:WU01:FS01:0x22:*********************** Log Started 2022-01-14T18:03:13Z ***********************
18:03:14:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:03:14:WU01:FS01:0x22:       Core: Core22
18:03:14:WU01:FS01:0x22:       Type: 0x22
18:03:14:WU01:FS01:0x22:    Version: 0.0.18
18:03:14:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:03:14:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:03:14:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:03:14:WU01:FS01:0x22:       Date: Sep 28 2021
18:03:14:WU01:FS01:0x22:       Time: 05:55:05
18:03:14:WU01:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:03:14:WU01:FS01:0x22:     Branch: HEAD
18:03:14:WU01:FS01:0x22:   Compiler: Visual C++
18:03:14:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:03:14:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:03:14:WU01:FS01:0x22:   Platform: win32 10
18:03:14:WU01:FS01:0x22:       Bits: 64
18:03:14:WU01:FS01:0x22:       Mode: Release
18:03:14:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:03:14:WU01:FS01:0x22:             <peastman@stanford.edu>
18:03:14:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12316 -checkpoint 15
18:03:14:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:03:14:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:03:14:WU01:FS01:0x22:************************************ libFAH ************************************
18:03:14:WU01:FS01:0x22:       Time: 05:53:43
18:03:14:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:03:14:WU01:FS01:0x22:************************************ CBang *************************************
18:03:14:WU01:FS01:0x22:       Time: 05:52:38
18:03:14:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:03:14:WU01:FS01:0x22:************************************ System ************************************
18:03:14:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:03:14:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:03:14:WU01:FS01:0x22:       CPUs: 16
18:03:14:WU01:FS01:0x22:     Memory: 31.67GiB
18:03:14:WU01:FS01:0x22:Free Memory: 27.00GiB
18:03:14:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:03:14:WU01:FS01:0x22: OS Version: 6.2
18:03:14:WU01:FS01:0x22:Has Battery: false
18:03:14:WU01:FS01:0x22: On Battery: false
18:03:14:WU01:FS01:0x22: UTC Offset: 0
18:03:14:WU01:FS01:0x22:        PID: 1980
18:03:14:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:03:14:WU01:FS01:0x22:************************************ OpenMM ************************************
18:03:14:WU01:FS01:0x22:    Version: 7.6.0
18:03:14:WU01:FS01:0x22:********************************************************************************
18:03:14:WU01:FS01:0x22:Project: 13460 (Run 674, Clone 48, Gen 0)
18:03:14:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:03:14:WU01:FS01:0x22:Reading tar file core.xml
18:03:14:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
18:03:14:WU01:FS01:0x22:Reading tar file state.xml.bz2
18:03:14:WU01:FS01:0x22:Reading tar file system.xml.bz2
18:03:14:WU01:FS01:0x22:Digital signatures verified
18:03:14:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:03:14:WU01:FS01:0x22:Version 0.0.18
18:03:14:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:03:14:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:03:14:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:03:14:WU01:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:03:14:WU01:FS01:0x22:There are 4 platforms available.
18:03:14:WU01:FS01:0x22:Platform 0: Reference
18:03:14:WU01:FS01:0x22:Platform 1: CPU
18:03:14:WU01:FS01:0x22:Platform 2: OpenCL
18:03:14:WU01:FS01:0x22:  opencl-device 0 specified
18:03:14:WU01:FS01:0x22:Platform 3: CUDA
18:03:14:WU01:FS01:0x22:  cuda-device 0 specified
18:03:18:WU00:FS01:Upload complete
18:03:18:WU00:FS01:Server responded WORK_ACK (400)
18:03:18:WU00:FS01:Cleaning up
18:03:43:WU01:FS01:0x22:Attempting to create CUDA context:
18:03:43:WU01:FS01:0x22:  Configuring platform CUDA
18:03:50:WU01:FS01:0x22:ERROR:Force RMSE error of 500834 with threshold of 5
18:03:50:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:03:50:WU01:FS01:0x22:Saving result file science.log
18:03:50:WU01:FS01:0x22:Saving result file state.xml.bz2
18:03:51:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:03:52:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:03:52:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13460 run:674 clone:48 gen:0 core:0x22 unit:0x000000300000000000003494000002a2
18:03:52:WU01:FS01:Uploading 6.27MiB to 54.157.202.86
18:03:52:WU01:FS01:Connecting to 54.157.202.86:8080
18:03:53:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:03:53:WU00:FS01:Assigned to work server 54.157.202.86
18:03:53:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:03:53:WU00:FS01:Connecting to 54.157.202.86:8080
18:04:13:WU01:FS01:Upload 1.99%
18:04:16:WU00:FS01:Downloading 7.76MiB
18:04:19:WU01:FS01:Upload 58.79%
18:04:19:WU00:FS01:Download complete
18:04:19:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13460 run:675 clone:91 gen:0 core:0x22 unit:0x0000005b0000000000003494000002a3
18:04:19:WU00:FS01:Starting
18:04:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:04:19:WU00:FS01:Started FahCore on PID 7628
18:04:19:WU00:FS01:Core PID:14444
18:04:19:WU00:FS01:FahCore 0x22 started
18:04:20:WU00:FS01:0x22:*********************** Log Started 2022-01-14T18:04:19Z ***********************
18:04:20:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:04:20:WU00:FS01:0x22:       Core: Core22
18:04:20:WU00:FS01:0x22:       Type: 0x22
18:04:20:WU00:FS01:0x22:    Version: 0.0.18
18:04:20:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:04:20:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
18:04:20:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
18:04:20:WU00:FS01:0x22:       Date: Sep 28 2021
18:04:20:WU00:FS01:0x22:       Time: 05:55:05
18:04:20:WU00:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:04:20:WU00:FS01:0x22:     Branch: HEAD
18:04:20:WU00:FS01:0x22:   Compiler: Visual C++
18:04:20:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:04:20:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:04:20:WU00:FS01:0x22:   Platform: win32 10
18:04:20:WU00:FS01:0x22:       Bits: 64
18:04:20:WU00:FS01:0x22:       Mode: Release
18:04:20:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:04:20:WU00:FS01:0x22:             <peastman@stanford.edu>
18:04:20:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7628 -checkpoint 15
18:04:20:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:04:20:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:04:20:WU00:FS01:0x22:************************************ libFAH ************************************
18:04:20:WU00:FS01:0x22:       Time: 05:53:43
18:04:20:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:04:20:WU00:FS01:0x22:************************************ CBang *************************************
18:04:20:WU00:FS01:0x22:       Time: 05:52:38
18:04:20:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:04:20:WU00:FS01:0x22:************************************ System ************************************
18:04:20:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:04:20:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:04:20:WU00:FS01:0x22:       CPUs: 16
18:04:20:WU00:FS01:0x22:     Memory: 31.67GiB
18:04:20:WU00:FS01:0x22:Free Memory: 27.00GiB
18:04:20:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:04:20:WU00:FS01:0x22: OS Version: 6.2
18:04:20:WU00:FS01:0x22:Has Battery: false
18:04:20:WU00:FS01:0x22: On Battery: false
18:04:20:WU00:FS01:0x22: UTC Offset: 0
18:04:20:WU00:FS01:0x22:        PID: 14444
18:04:20:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:04:20:WU00:FS01:0x22:************************************ OpenMM ************************************
18:04:20:WU00:FS01:0x22:    Version: 7.6.0
18:04:20:WU00:FS01:0x22:********************************************************************************
18:04:20:WU00:FS01:0x22:Project: 13460 (Run 675, Clone 91, Gen 0)
18:04:20:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:04:20:WU00:FS01:0x22:Reading tar file core.xml
18:04:20:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
18:04:20:WU00:FS01:0x22:Reading tar file state.xml.bz2
18:04:20:WU00:FS01:0x22:Reading tar file system.xml.bz2
18:04:20:WU00:FS01:0x22:Digital signatures verified
18:04:20:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:04:20:WU00:FS01:0x22:Version 0.0.18
18:04:20:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:04:20:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:04:20:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:04:20:WU00:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:04:20:WU00:FS01:0x22:There are 4 platforms available.
18:04:20:WU00:FS01:0x22:Platform 0: Reference
18:04:20:WU00:FS01:0x22:Platform 1: CPU
18:04:20:WU00:FS01:0x22:Platform 2: OpenCL
18:04:20:WU00:FS01:0x22:  opencl-device 0 specified
18:04:20:WU00:FS01:0x22:Platform 3: CUDA
18:04:20:WU00:FS01:0x22:  cuda-device 0 specified
18:04:23:WU01:FS01:Upload complete
18:04:23:WU01:FS01:Server responded WORK_ACK (400)
18:04:23:WU01:FS01:Cleaning up
18:04:48:WU00:FS01:0x22:Attempting to create CUDA context:
18:04:48:WU00:FS01:0x22:  Configuring platform CUDA
18:04:56:WU00:FS01:0x22:ERROR:Force RMSE error of 510821 with threshold of 5
18:04:56:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:04:56:WU00:FS01:0x22:Saving result file science.log
18:04:56:WU00:FS01:0x22:Saving result file state.xml.bz2
18:04:56:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:04:58:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:04:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13460 run:675 clone:91 gen:0 core:0x22 unit:0x0000005b0000000000003494000002a3
18:04:58:WU00:FS01:Uploading 6.27MiB to 54.157.202.86
18:04:58:WU00:FS01:Connecting to 54.157.202.86:8080
18:04:58:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:04:59:WU01:FS01:Assigned to work server 54.157.202.86
18:04:59:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:04:59:WU01:FS01:Connecting to 54.157.202.86:8080
18:05:16:WU00:FS01:Upload 1.99%
18:05:19:WU01:FS01:Downloading 7.76MiB
18:05:22:WU00:FS01:Upload 59.79%
18:05:22:WU01:FS01:Download complete
18:05:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13460 run:675 clone:83 gen:0 core:0x22 unit:0x000000530000000000003494000002a3
18:05:22:WU01:FS01:Starting
18:05:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:05:22:WU01:FS01:Started FahCore on PID 13400
18:05:22:WU01:FS01:Core PID:13636
18:05:22:WU01:FS01:FahCore 0x22 started
18:05:22:WU01:FS01:0x22:*********************** Log Started 2022-01-14T18:05:22Z ***********************
18:05:22:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:05:22:WU01:FS01:0x22:       Core: Core22
18:05:22:WU01:FS01:0x22:       Type: 0x22
18:05:22:WU01:FS01:0x22:    Version: 0.0.18
18:05:22:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:05:22:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:05:22:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:05:22:WU01:FS01:0x22:       Date: Sep 28 2021
18:05:22:WU01:FS01:0x22:       Time: 05:55:05
18:05:22:WU01:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:05:22:WU01:FS01:0x22:     Branch: HEAD
18:05:22:WU01:FS01:0x22:   Compiler: Visual C++
18:05:22:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:05:22:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:05:22:WU01:FS01:0x22:   Platform: win32 10
18:05:22:WU01:FS01:0x22:       Bits: 64
18:05:22:WU01:FS01:0x22:       Mode: Release
18:05:22:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:05:22:WU01:FS01:0x22:             <peastman@stanford.edu>
18:05:22:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13400 -checkpoint 15
18:05:22:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:05:22:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:05:22:WU01:FS01:0x22:************************************ libFAH ************************************
18:05:22:WU01:FS01:0x22:       Time: 05:53:43
18:05:22:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:05:23:WU01:FS01:0x22:       Bits: 64
18:05:23:WU01:FS01:0x22:       Mode: Release
18:05:23:WU01:FS01:0x22:************************************ CBang *************************************
18:05:23:WU01:FS01:0x22:       Date: Sep 28 2021
18:05:23:WU01:FS01:0x22:       Time: 05:52:38
18:05:23:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:05:23:WU01:FS01:0x22:     Branch: HEAD
18:05:23:WU01:FS01:0x22:   Compiler: Visual C++
18:05:23:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:05:23:WU01:FS01:0x22:   Platform: win32 10
18:05:23:WU01:FS01:0x22:************************************ System ************************************
18:05:23:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:05:23:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:05:23:WU01:FS01:0x22:       CPUs: 16
18:05:23:WU01:FS01:0x22:     Memory: 31.67GiB
18:05:23:WU01:FS01:0x22:Free Memory: 27.02GiB
18:05:23:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:05:23:WU01:FS01:0x22: OS Version: 6.2
18:05:23:WU01:FS01:0x22:Has Battery: false
18:05:23:WU01:FS01:0x22: On Battery: false
18:05:23:WU01:FS01:0x22: UTC Offset: 0
18:05:23:WU01:FS01:0x22:        PID: 13636
18:05:23:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:05:23:WU01:FS01:0x22:************************************ OpenMM ************************************
18:05:23:WU01:FS01:0x22:    Version: 7.6.0
18:05:23:WU01:FS01:0x22:********************************************************************************
18:05:23:WU01:FS01:0x22:Project: 13460 (Run 675, Clone 83, Gen 0)
18:05:23:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:05:23:WU01:FS01:0x22:Reading tar file core.xml
18:05:23:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
18:05:23:WU01:FS01:0x22:Reading tar file state.xml.bz2
18:05:23:WU01:FS01:0x22:Reading tar file system.xml.bz2
18:05:23:WU01:FS01:0x22:Digital signatures verified
18:05:23:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:05:23:WU01:FS01:0x22:Version 0.0.18
18:05:23:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:05:23:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:05:23:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:05:23:WU01:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:05:23:WU01:FS01:0x22:There are 4 platforms available.
18:05:23:WU01:FS01:0x22:Platform 0: Reference
18:05:23:WU01:FS01:0x22:Platform 1: CPU
18:05:23:WU01:FS01:0x22:Platform 2: OpenCL
18:05:23:WU01:FS01:0x22:  opencl-device 0 specified
18:05:23:WU01:FS01:0x22:Platform 3: CUDA
18:05:23:WU01:FS01:0x22:  cuda-device 0 specified
18:05:26:WU00:FS01:Upload complete
18:05:26:WU00:FS01:Server responded WORK_ACK (400)
18:05:26:WU00:FS01:Cleaning up
18:05:51:WU01:FS01:0x22:Attempting to create CUDA context:
18:05:51:WU01:FS01:0x22:  Configuring platform CUDA
18:05:59:WU01:FS01:0x22:ERROR:Force RMSE error of 510821 with threshold of 5
18:05:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:05:59:WU01:FS01:0x22:Saving result file science.log
18:05:59:WU01:FS01:0x22:Saving result file state.xml.bz2
18:05:59:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:06:00:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:06:00:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13460 run:675 clone:83 gen:0 core:0x22 unit:0x000000530000000000003494000002a3
18:06:00:WU01:FS01:Uploading 6.27MiB to 54.157.202.86
18:06:00:WU01:FS01:Connecting to 54.157.202.86:8080
18:06:01:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:06:01:WU00:FS01:Assigned to work server 54.157.202.86
18:06:01:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:06:01:WU00:FS01:Connecting to 54.157.202.86:8080
18:06:30:WU01:FS01:Upload 1.99%
18:06:31:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:06:32:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:06:32:WU00:FS01:Assigned to work server 54.157.202.86
18:06:32:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:06:32:WU00:FS01:Connecting to 54.157.202.86:8080
18:06:36:WU01:FS01:Upload 59.79%
18:06:40:WU01:FS01:Upload complete
18:06:40:WU01:FS01:Server responded WORK_ACK (400)
18:06:40:WU01:FS01:Cleaning up
18:07:02:WU00:FS01:Downloading 7.76MiB
18:07:04:WU00:FS01:Download complete
18:07:04:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13460 run:674 clone:35 gen:0 core:0x22 unit:0x000000230000000000003494000002a2
18:07:04:WU00:FS01:Starting
18:07:04:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:07:04:WU00:FS01:Started FahCore on PID 15340
18:07:04:WU00:FS01:Core PID:4456
18:07:04:WU00:FS01:FahCore 0x22 started
18:07:05:WU00:FS01:0x22:*********************** Log Started 2022-01-14T18:07:04Z ***********************
18:07:05:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:07:05:WU00:FS01:0x22:       Core: Core22
18:07:05:WU00:FS01:0x22:       Type: 0x22
18:07:05:WU00:FS01:0x22:    Version: 0.0.18
18:07:05:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:07:05:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
18:07:05:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
18:07:05:WU00:FS01:0x22:       Date: Sep 28 2021
18:07:05:WU00:FS01:0x22:       Time: 05:55:05
18:07:05:WU00:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:07:05:WU00:FS01:0x22:     Branch: HEAD
18:07:05:WU00:FS01:0x22:   Compiler: Visual C++
18:07:05:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:07:05:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:07:05:WU00:FS01:0x22:   Platform: win32 10
18:07:05:WU00:FS01:0x22:       Bits: 64
18:07:05:WU00:FS01:0x22:       Mode: Release
18:07:05:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:07:05:WU00:FS01:0x22:             <peastman@stanford.edu>
18:07:05:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15340 -checkpoint 15
18:07:05:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:07:05:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:07:05:WU00:FS01:0x22:************************************ libFAH ************************************
18:07:05:WU00:FS01:0x22:       Time: 05:53:43
18:07:05:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:07:05:WU00:FS01:0x22:************************************ CBang *************************************
18:07:05:WU00:FS01:0x22:       Time: 05:52:38
18:07:05:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:07:05:WU00:FS01:0x22:************************************ System ************************************
18:07:05:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:07:05:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:07:05:WU00:FS01:0x22:       CPUs: 16
18:07:05:WU00:FS01:0x22:     Memory: 31.67GiB
18:07:05:WU00:FS01:0x22:Free Memory: 27.04GiB
18:07:05:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:07:05:WU00:FS01:0x22: OS Version: 6.2
18:07:05:WU00:FS01:0x22:Has Battery: false
18:07:05:WU00:FS01:0x22: On Battery: false
18:07:05:WU00:FS01:0x22: UTC Offset: 0
18:07:05:WU00:FS01:0x22:        PID: 4456
18:07:05:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:07:05:WU00:FS01:0x22:************************************ OpenMM ************************************
18:07:05:WU00:FS01:0x22:    Version: 7.6.0
18:07:05:WU00:FS01:0x22:********************************************************************************
18:07:05:WU00:FS01:0x22:Project: 13460 (Run 674, Clone 35, Gen 0)
18:07:05:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:07:05:WU00:FS01:0x22:Reading tar file core.xml
18:07:05:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
18:07:05:WU00:FS01:0x22:Reading tar file state.xml.bz2
18:07:05:WU00:FS01:0x22:Reading tar file system.xml.bz2
18:07:05:WU00:FS01:0x22:Digital signatures verified
18:07:05:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:07:05:WU00:FS01:0x22:Version 0.0.18
18:07:05:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:07:05:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:07:05:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:07:05:WU00:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:07:05:WU00:FS01:0x22:There are 4 platforms available.
18:07:05:WU00:FS01:0x22:Platform 0: Reference
18:07:05:WU00:FS01:0x22:Platform 1: CPU
18:07:05:WU00:FS01:0x22:Platform 2: OpenCL
18:07:05:WU00:FS01:0x22:  opencl-device 0 specified
18:07:05:WU00:FS01:0x22:Platform 3: CUDA
18:07:05:WU00:FS01:0x22:  cuda-device 0 specified
18:07:33:WU00:FS01:0x22:Attempting to create CUDA context:
18:07:33:WU00:FS01:0x22:  Configuring platform CUDA
18:07:41:WU00:FS01:0x22:ERROR:Force RMSE error of 500834 with threshold of 5
18:07:41:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:07:41:WU00:FS01:0x22:Saving result file science.log
18:07:41:WU00:FS01:0x22:Saving result file state.xml.bz2
18:07:41:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:07:43:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:07:43:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13460 run:674 clone:35 gen:0 core:0x22 unit:0x000000230000000000003494000002a2
18:07:43:WU00:FS01:Uploading 6.27MiB to 54.157.202.86
18:07:43:WU00:FS01:Connecting to 54.157.202.86:8080
18:07:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:07:43:WU01:FS01:Assigned to work server 54.157.202.86
18:07:43:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:07:43:WU01:FS01:Connecting to 54.157.202.86:8080
18:08:12:WU00:FS01:Upload 1.99%
18:08:14:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:08:14:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:08:14:WU01:FS01:Assigned to work server 54.157.202.86
18:08:14:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:08:14:WU01:FS01:Connecting to 54.157.202.86:8080
18:08:18:WU00:FS01:Upload 56.80%
18:08:22:WU00:FS01:Upload complete
18:08:22:WU00:FS01:Server responded WORK_ACK (400)
18:08:22:WU00:FS01:Cleaning up
18:08:45:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:09:14:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:09:14:WU01:FS01:Assigned to work server 54.157.202.86
18:09:14:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:09:14:WU01:FS01:Connecting to 54.157.202.86:8080
18:09:32:WU01:FS01:Downloading 7.75MiB
18:09:35:WU01:FS01:Download complete
18:09:35:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13460 run:676 clone:71 gen:0 core:0x22 unit:0x000000470000000000003494000002a4
18:09:35:WU01:FS01:Starting
18:09:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:09:35:WU01:FS01:Started FahCore on PID 4440
18:09:35:WU01:FS01:Core PID:14040
18:09:35:WU01:FS01:FahCore 0x22 started
18:09:36:WU01:FS01:0x22:*********************** Log Started 2022-01-14T18:09:35Z ***********************
18:09:36:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:09:36:WU01:FS01:0x22:       Core: Core22
18:09:36:WU01:FS01:0x22:       Type: 0x22
18:09:36:WU01:FS01:0x22:    Version: 0.0.18
18:09:36:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:09:36:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:09:36:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:09:36:WU01:FS01:0x22:       Date: Sep 28 2021
18:09:36:WU01:FS01:0x22:       Time: 05:55:05
18:09:36:WU01:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:09:36:WU01:FS01:0x22:     Branch: HEAD
18:09:36:WU01:FS01:0x22:   Compiler: Visual C++
18:09:36:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:09:36:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:09:36:WU01:FS01:0x22:   Platform: win32 10
18:09:36:WU01:FS01:0x22:       Bits: 64
18:09:36:WU01:FS01:0x22:       Mode: Release
18:09:36:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:09:36:WU01:FS01:0x22:             <peastman@stanford.edu>
18:09:36:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4440 -checkpoint 15
18:09:36:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:09:36:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:09:36:WU01:FS01:0x22:************************************ libFAH ************************************
18:09:36:WU01:FS01:0x22:       Time: 05:53:43
18:09:36:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:09:36:WU01:FS01:0x22:************************************ CBang *************************************
18:09:36:WU01:FS01:0x22:       Time: 05:52:38
18:09:36:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:09:36:WU01:FS01:0x22:************************************ System ************************************
18:09:36:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:09:36:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:09:36:WU01:FS01:0x22:       CPUs: 16
18:09:36:WU01:FS01:0x22:     Memory: 31.67GiB
18:09:36:WU01:FS01:0x22:Free Memory: 27.03GiB
18:09:36:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:09:36:WU01:FS01:0x22: OS Version: 6.2
18:09:36:WU01:FS01:0x22:Has Battery: false
18:09:36:WU01:FS01:0x22: On Battery: false
18:09:36:WU01:FS01:0x22: UTC Offset: 0
18:09:36:WU01:FS01:0x22:        PID: 14040
18:09:36:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:09:36:WU01:FS01:0x22:************************************ OpenMM ************************************
18:09:36:WU01:FS01:0x22:    Version: 7.6.0
18:09:36:WU01:FS01:0x22:********************************************************************************
18:09:36:WU01:FS01:0x22:Project: 13460 (Run 676, Clone 71, Gen 0)
18:09:36:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:09:36:WU01:FS01:0x22:Reading tar file core.xml
18:09:36:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
18:09:36:WU01:FS01:0x22:Reading tar file state.xml.bz2
18:09:36:WU01:FS01:0x22:Reading tar file system.xml.bz2
18:09:36:WU01:FS01:0x22:Digital signatures verified
18:09:36:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:09:36:WU01:FS01:0x22:Version 0.0.18
18:09:36:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:09:36:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:09:36:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:09:36:WU01:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:09:36:WU01:FS01:0x22:There are 4 platforms available.
18:09:36:WU01:FS01:0x22:Platform 0: Reference
18:09:36:WU01:FS01:0x22:Platform 1: CPU
18:09:36:WU01:FS01:0x22:Platform 2: OpenCL
18:09:36:WU01:FS01:0x22:  opencl-device 0 specified
18:09:36:WU01:FS01:0x22:Platform 3: CUDA
18:09:36:WU01:FS01:0x22:  cuda-device 0 specified
18:10:04:WU01:FS01:0x22:Attempting to create CUDA context:
18:10:04:WU01:FS01:0x22:  Configuring platform CUDA
18:10:17:WU01:FS01:0x22:ERROR:Force RMSE error of 758676 with threshold of 5
18:10:17:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:10:17:WU01:FS01:0x22:Saving result file science.log
18:10:17:WU01:FS01:0x22:Saving result file state.xml.bz2
18:10:18:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:10:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:10:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13460 run:676 clone:71 gen:0 core:0x22 unit:0x000000470000000000003494000002a4
18:10:20:WU01:FS01:Uploading 6.27MiB to 54.157.202.86
18:10:20:WU01:FS01:Connecting to 54.157.202.86:8080
18:10:20:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:10:20:WU00:FS01:Assigned to work server 54.157.202.86
18:10:20:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:10:20:WU00:FS01:Connecting to 54.157.202.86:8080
18:10:48:WU01:FS01:Upload 1.99%
18:10:51:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:10:51:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:10:51:WU00:FS01:Assigned to work server 54.157.202.86
18:10:51:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:10:51:WU00:FS01:Connecting to 54.157.202.86:8080
18:10:54:WU01:FS01:Upload 59.84%
18:10:58:WU01:FS01:Upload complete
18:10:58:WU01:FS01:Server responded WORK_ACK (400)
18:10:58:WU01:FS01:Cleaning up
18:11:19:WU00:FS01:Downloading 7.75MiB
18:11:23:WU00:FS01:Download complete
18:11:23:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13460 run:677 clone:74 gen:0 core:0x22 unit:0x0000004a0000000000003494000002a5
18:11:23:WU00:FS01:Starting
18:11:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:11:23:WU00:FS01:Started FahCore on PID 13700
18:11:23:WU00:FS01:Core PID:3272
18:11:23:WU00:FS01:FahCore 0x22 started
18:11:24:WU00:FS01:0x22:*********************** Log Started 2022-01-14T18:11:23Z ***********************
18:11:24:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:11:24:WU00:FS01:0x22:       Core: Core22
18:11:24:WU00:FS01:0x22:       Type: 0x22
18:11:24:WU00:FS01:0x22:    Version: 0.0.18
18:11:24:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:11:24:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
18:11:24:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
18:11:24:WU00:FS01:0x22:       Date: Sep 28 2021
18:11:24:WU00:FS01:0x22:       Time: 05:55:05
18:11:24:WU00:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:11:24:WU00:FS01:0x22:     Branch: HEAD
18:11:24:WU00:FS01:0x22:   Compiler: Visual C++
18:11:24:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:11:24:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:11:24:WU00:FS01:0x22:   Platform: win32 10
18:11:24:WU00:FS01:0x22:       Bits: 64
18:11:24:WU00:FS01:0x22:       Mode: Release
18:11:24:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:11:24:WU00:FS01:0x22:             <peastman@stanford.edu>
18:11:24:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13700 -checkpoint 15
18:11:24:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:11:24:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:11:24:WU00:FS01:0x22:************************************ libFAH ************************************
18:11:24:WU00:FS01:0x22:       Time: 05:53:43
18:11:24:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:11:24:WU00:FS01:0x22:************************************ CBang *************************************
18:11:24:WU00:FS01:0x22:       Time: 05:52:38
18:11:24:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:11:24:WU00:FS01:0x22:************************************ System ************************************
18:11:24:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:11:24:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:11:24:WU00:FS01:0x22:       CPUs: 16
18:11:24:WU00:FS01:0x22:     Memory: 31.67GiB
18:11:24:WU00:FS01:0x22:Free Memory: 27.05GiB
18:11:24:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:11:24:WU00:FS01:0x22: OS Version: 6.2
18:11:24:WU00:FS01:0x22:Has Battery: false
18:11:24:WU00:FS01:0x22: On Battery: false
18:11:24:WU00:FS01:0x22: UTC Offset: 0
18:11:24:WU00:FS01:0x22:        PID: 3272
18:11:24:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:11:24:WU00:FS01:0x22:************************************ OpenMM ************************************
18:11:24:WU00:FS01:0x22:    Version: 7.6.0
18:11:24:WU00:FS01:0x22:********************************************************************************
18:11:24:WU00:FS01:0x22:Project: 13460 (Run 677, Clone 74, Gen 0)
18:11:24:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:11:24:WU00:FS01:0x22:Reading tar file core.xml
18:11:24:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
18:11:24:WU00:FS01:0x22:Reading tar file state.xml.bz2
18:11:24:WU00:FS01:0x22:Reading tar file system.xml.bz2
18:11:24:WU00:FS01:0x22:Digital signatures verified
18:11:24:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:11:24:WU00:FS01:0x22:Version 0.0.18
18:11:24:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:11:24:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:11:24:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:11:24:WU00:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:11:24:WU00:FS01:0x22:There are 4 platforms available.
18:11:24:WU00:FS01:0x22:Platform 0: Reference
18:11:24:WU00:FS01:0x22:Platform 1: CPU
18:11:24:WU00:FS01:0x22:Platform 2: OpenCL
18:11:24:WU00:FS01:0x22:  opencl-device 0 specified
18:11:24:WU00:FS01:0x22:Platform 3: CUDA
18:11:24:WU00:FS01:0x22:  cuda-device 0 specified
18:11:52:WU00:FS01:0x22:Attempting to create CUDA context:
18:11:52:WU00:FS01:0x22:  Configuring platform CUDA
18:12:05:WU00:FS01:0x22:ERROR:Force RMSE error of 557533 with threshold of 5
18:12:05:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:12:05:WU00:FS01:0x22:Saving result file science.log
18:12:05:WU00:FS01:0x22:Saving result file state.xml.bz2
18:12:06:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:12:07:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:12:07:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13460 run:677 clone:74 gen:0 core:0x22 unit:0x0000004a0000000000003494000002a5
18:12:07:WU00:FS01:Uploading 6.27MiB to 54.157.202.86
18:12:07:WU00:FS01:Connecting to 54.157.202.86:8080
18:12:07:WU01:FS01:Connecting to assign1.foldingathome.org:80
18:12:08:WU01:FS01:Assigned to work server 54.157.202.86
18:12:08:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:12:08:WU01:FS01:Connecting to 54.157.202.86:8080
18:12:28:WU00:FS01:Upload 1.99%
18:12:30:WU01:FS01:Downloading 7.75MiB
18:12:34:WU01:FS01:Download complete
18:12:34:WU00:FS01:Upload 56.82%
18:12:34:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13460 run:676 clone:78 gen:0 core:0x22 unit:0x0000004e0000000000003494000002a4
18:12:34:WU01:FS01:Starting
18:12:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:12:34:WU01:FS01:Started FahCore on PID 12728
18:12:34:WU01:FS01:Core PID:12152
18:12:34:WU01:FS01:FahCore 0x22 started
18:12:34:WU01:FS01:0x22:*********************** Log Started 2022-01-14T18:12:34Z ***********************
18:12:34:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:12:34:WU01:FS01:0x22:       Core: Core22
18:12:34:WU01:FS01:0x22:       Type: 0x22
18:12:34:WU01:FS01:0x22:    Version: 0.0.18
18:12:34:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:12:34:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
18:12:34:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
18:12:34:WU01:FS01:0x22:       Date: Sep 28 2021
18:12:34:WU01:FS01:0x22:       Time: 05:55:05
18:12:34:WU01:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:12:34:WU01:FS01:0x22:     Branch: HEAD
18:12:34:WU01:FS01:0x22:   Compiler: Visual C++
18:12:34:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:12:34:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:12:34:WU01:FS01:0x22:   Platform: win32 10
18:12:34:WU01:FS01:0x22:       Bits: 64
18:12:34:WU01:FS01:0x22:       Mode: Release
18:12:34:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:12:34:WU01:FS01:0x22:             <peastman@stanford.edu>
18:12:34:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12728 -checkpoint 15
18:12:34:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:12:34:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:12:34:WU01:FS01:0x22:************************************ libFAH ************************************
18:12:34:WU01:FS01:0x22:       Time: 05:53:43
18:12:34:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:12:34:WU01:FS01:0x22:************************************ CBang *************************************
18:12:34:WU01:FS01:0x22:       Time: 05:52:38
18:12:34:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:12:34:WU01:FS01:0x22:************************************ System ************************************
18:12:34:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:12:34:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:12:34:WU01:FS01:0x22:       CPUs: 16
18:12:34:WU01:FS01:0x22:     Memory: 31.67GiB
18:12:34:WU01:FS01:0x22:Free Memory: 27.05GiB
18:12:34:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:12:34:WU01:FS01:0x22: OS Version: 6.2
18:12:34:WU01:FS01:0x22:Has Battery: false
18:12:34:WU01:FS01:0x22: On Battery: false
18:12:34:WU01:FS01:0x22: UTC Offset: 0
18:12:34:WU01:FS01:0x22:        PID: 12152
18:12:34:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:12:34:WU01:FS01:0x22:************************************ OpenMM ************************************
18:12:34:WU01:FS01:0x22:    Version: 7.6.0
18:12:34:WU01:FS01:0x22:********************************************************************************
18:12:34:WU01:FS01:0x22:Project: 13460 (Run 676, Clone 78, Gen 0)
18:12:34:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:12:34:WU01:FS01:0x22:Reading tar file core.xml
18:12:34:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
18:12:34:WU01:FS01:0x22:Reading tar file state.xml.bz2
18:12:34:WU01:FS01:0x22:Reading tar file system.xml.bz2
18:12:34:WU01:FS01:0x22:Digital signatures verified
18:12:34:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:12:34:WU01:FS01:0x22:Version 0.0.18
18:12:34:WU01:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:12:34:WU01:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:12:34:WU01:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:12:34:WU01:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:12:34:WU01:FS01:0x22:There are 4 platforms available.
18:12:34:WU01:FS01:0x22:Platform 0: Reference
18:12:34:WU01:FS01:0x22:Platform 1: CPU
18:12:34:WU01:FS01:0x22:Platform 2: OpenCL
18:12:34:WU01:FS01:0x22:  opencl-device 0 specified
18:12:34:WU01:FS01:0x22:Platform 3: CUDA
18:12:34:WU01:FS01:0x22:  cuda-device 0 specified
18:12:38:WU00:FS01:Upload complete
18:12:38:WU00:FS01:Server responded WORK_ACK (400)
18:12:38:WU00:FS01:Cleaning up
18:13:02:WU01:FS01:0x22:Attempting to create CUDA context:
18:13:02:WU01:FS01:0x22:  Configuring platform CUDA
18:13:10:WU01:FS01:0x22:ERROR:Force RMSE error of 758676 with threshold of 5
18:13:10:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:13:10:WU01:FS01:0x22:Saving result file science.log
18:13:10:WU01:FS01:0x22:Saving result file state.xml.bz2
18:13:10:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:13:12:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:13:12:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13460 run:676 clone:78 gen:0 core:0x22 unit:0x0000004e0000000000003494000002a4
18:13:12:WU01:FS01:Uploading 6.27MiB to 54.157.202.86
18:13:12:WU01:FS01:Connecting to 54.157.202.86:8080
18:13:12:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:13:12:WU00:FS01:Assigned to work server 54.157.202.86
18:13:12:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GA104 [GeForce RTX 3070] from 54.157.202.86
18:13:12:WU00:FS01:Connecting to 54.157.202.86:8080
18:13:29:WU01:FS01:Upload 1.99%
18:13:32:WU00:FS01:Downloading 7.75MiB
18:13:35:WU01:FS01:Upload 53.86%
18:13:35:WU00:FS01:Download complete
18:13:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13460 run:677 clone:24 gen:0 core:0x22 unit:0x000000180000000000003494000002a5
18:13:35:WU00:FS01:Starting
18:13:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 3216 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:13:35:WU00:FS01:Started FahCore on PID 3444
18:13:35:WU00:FS01:Core PID:11820
18:13:35:WU00:FS01:FahCore 0x22 started
18:13:35:WU00:FS01:0x22:*********************** Log Started 2022-01-14T18:13:35Z ***********************
18:13:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:13:35:WU00:FS01:0x22:       Core: Core22
18:13:35:WU00:FS01:0x22:       Type: 0x22
18:13:35:WU00:FS01:0x22:    Version: 0.0.18
18:13:35:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:13:35:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
18:13:35:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
18:13:35:WU00:FS01:0x22:       Date: Sep 28 2021
18:13:35:WU00:FS01:0x22:       Time: 05:55:05
18:13:35:WU00:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
18:13:35:WU00:FS01:0x22:     Branch: HEAD
18:13:35:WU00:FS01:0x22:   Compiler: Visual C++
18:13:35:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:13:35:WU00:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
18:13:35:WU00:FS01:0x22:   Platform: win32 10
18:13:35:WU00:FS01:0x22:       Bits: 64
18:13:35:WU00:FS01:0x22:       Mode: Release
18:13:35:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:13:35:WU00:FS01:0x22:             <peastman@stanford.edu>
18:13:35:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3444 -checkpoint 15
18:13:35:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:13:35:WU00:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
18:13:35:WU00:FS01:0x22:************************************ libFAH ************************************
18:13:35:WU00:FS01:0x22:       Time: 05:53:43
18:13:35:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:13:35:WU00:FS01:0x22:************************************ CBang *************************************
18:13:35:WU00:FS01:0x22:       Time: 05:52:38
18:13:35:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:13:35:WU00:FS01:0x22:************************************ System ************************************
18:13:35:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
18:13:35:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
18:13:35:WU00:FS01:0x22:       CPUs: 16
18:13:35:WU00:FS01:0x22:     Memory: 31.67GiB
18:13:35:WU00:FS01:0x22:Free Memory: 27.04GiB
18:13:35:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:13:35:WU00:FS01:0x22: OS Version: 6.2
18:13:35:WU00:FS01:0x22:Has Battery: false
18:13:35:WU00:FS01:0x22: On Battery: false
18:13:35:WU00:FS01:0x22: UTC Offset: 0
18:13:35:WU00:FS01:0x22:        PID: 11820
18:13:35:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
18:13:35:WU00:FS01:0x22:************************************ OpenMM ************************************
18:13:35:WU00:FS01:0x22:    Version: 7.6.0
18:13:35:WU00:FS01:0x22:********************************************************************************
18:13:35:WU00:FS01:0x22:Project: 13460 (Run 677, Clone 24, Gen 0)
18:13:35:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:13:35:WU00:FS01:0x22:Reading tar file core.xml
18:13:35:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
18:13:35:WU00:FS01:0x22:Reading tar file state.xml.bz2
18:13:35:WU00:FS01:0x22:Reading tar file system.xml.bz2
18:13:35:WU00:FS01:0x22:Digital signatures verified
18:13:35:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:13:35:WU00:FS01:0x22:Version 0.0.18
18:13:35:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
18:13:35:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
18:13:35:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
18:13:35:WU00:FS01:0x22:  Global context and integrator variables write interval: 2500 steps (0.25%) [400 total]
18:13:35:WU00:FS01:0x22:There are 4 platforms available.
18:13:35:WU00:FS01:0x22:Platform 0: Reference
18:13:35:WU00:FS01:0x22:Platform 1: CPU
18:13:35:WU00:FS01:0x22:Platform 2: OpenCL
18:13:35:WU00:FS01:0x22:  opencl-device 0 specified
18:13:35:WU00:FS01:0x22:Platform 3: CUDA
18:13:35:WU00:FS01:0x22:  cuda-device 0 specified
18:13:39:WU01:FS01:Upload complete
18:13:39:WU01:FS01:Server responded WORK_ACK (400)
18:13:39:WU01:FS01:Cleaning up
18:14:04:WU00:FS01:0x22:Attempting to create CUDA context:
18:14:04:WU00:FS01:0x22:  Configuring platform CUDA
18:14:11:WU00:FS01:0x22:ERROR:Force RMSE error of 557533 with threshold of 5
18:14:11:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:14:11:WU00:FS01:0x22:Saving result file science.log
18:14:11:WU00:FS01:0x22:Saving result file state.xml.bz2
18:14:12:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:14:13:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:14:13:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13460 run:677 clone:24 gen:0 core:0x22 unit:0x000000180000000000003494000002a5
18:14:13:WU00:FS01:Uploading 6.27MiB to 54.157.202.86
18:14:13:WU00:FS01:Connecting to 54.157.202.86:8080
18:14:30:WU00:FS01:Upload 1.99%
18:14:36:WU00:FS01:Upload 57.81%
18:14:40:WU00:FS01:Upload complete
18:14:40:WU00:FS01:Server responded WORK_ACK (400)
18:14:40:WU00:FS01:Cleaning up
******************************* Date: 2022-01-15 *******************************
Re: Failed status reported for RTX3070
It has been fixed, see this topic : viewtopic.php?f=19&t=37675
iokeith
Post by iokeith »
Thanks! I'll try it out :)
