keep getting error 32 and client keeps disconnecting
ipc6
Post by ipc6 »
Hi everyone, I'm folding on an m1 mac as a hobby, and I keep getting the error sigpipe error 32 and my clent is almost always "Client: local Connecting Inactive" or "client: local, updating inactive". How do I fix this? My log is below
06:31:28:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 318 -checkpoint 15 -np 8
06:31:28:WU00:FS00:Started FahCore on PID 6277
06:31:28:WU00:FS00:Core PID:6278
06:31:28:WU00:FS00:FahCore 0xa8 started
06:31:29:WU00:FS00:0xa8:*********************** Log Started 2022-01-15T06:31:28Z ***********************
06:31:29:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
06:31:29:WU00:FS00:0xa8:       Core: Gromacs
06:31:29:WU00:FS00:0xa8:       Type: 0xa8
06:31:29:WU00:FS00:0xa8:    Version: 0.0.12
06:31:29:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:31:29:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
06:31:29:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
06:31:29:WU00:FS00:0xa8:       Date: Jan 16 2021
06:31:29:WU00:FS00:0xa8:       Time: 21:22:16
06:31:29:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
06:31:29:WU00:FS00:0xa8:     Branch: master
06:31:29:WU00:FS00:0xa8:   Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
06:31:29:WU00:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
06:31:29:WU00:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7
06:31:29:WU00:FS00:0xa8:   Platform: darwin 20.2.0
06:31:29:WU00:FS00:0xa8:       Bits: 64
06:31:29:WU00:FS00:0xa8:       Mode: Release
06:31:29:WU00:FS00:0xa8:       SIMD: sse2
06:31:29:WU00:FS00:0xa8:     OpenMP: ON
06:31:29:WU00:FS00:0xa8:       CUDA: OFF
06:31:29:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6277 -checkpoint 15 -np 8
06:31:29:WU00:FS00:0xa8:************************************ libFAH ************************************
06:31:29:WU00:FS00:0xa8:       Time: 21:21:45
06:31:29:WU00:FS00:0xa8:************************************ CBang *************************************
06:31:29:WU00:FS00:0xa8:       Time: 21:21:02
06:31:29:WU00:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7 -fPIC
06:31:29:WU00:FS00:0xa8:************************************ System ************************************
06:31:29:WU00:FS00:0xa8:        CPU: VirtualApple @ 2.50GHz
06:31:29:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
06:31:29:WU00:FS00:0xa8:       CPUs: 8
06:31:29:WU00:FS00:0xa8:     Memory: 16.00GiB
06:31:29:WU00:FS00:0xa8:Free Memory: 7.70GiB
06:31:29:WU00:FS00:0xa8:    Threads: POSIX_THREADS
06:31:29:WU00:FS00:0xa8: OS Version: 12.0
06:31:29:WU00:FS00:0xa8:Has Battery: true
06:31:29:WU00:FS00:0xa8: On Battery: false
06:31:29:WU00:FS00:0xa8: UTC Offset: 8
06:31:29:WU00:FS00:0xa8:        PID: 6278
06:31:29:WU00:FS00:0xa8:        CWD: /Library/Application Support/FAHClient/work
06:31:29:WU00:FS00:0xa8:********************************************************************************
06:31:29:WU00:FS00:0xa8:Project: 16978 (Run 45, Clone 50, Gen 187)
06:31:29:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
06:31:29:WU00:FS00:0xa8:Reading tar file core.xml
06:31:29:WU00:FS00:0xa8:Reading tar file frame187.tpr
06:31:29:WU00:FS00:0xa8:Digital signatures verified
06:31:29:WU00:FS00:0xa8:Calling: mdrun -c frame187.gro -s frame187.tpr -x frame187.xtc -cpt 15 -nt 8 -ntmpi 1
06:31:29:WU00:FS00:0xa8:Steps: first=467500000 total=470000000
06:31:30:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
06:31:42:WU01:FS00:Server responded WORK_ACK (400)
06:31:42:WU01:FS00:Final credit estimate, 3145.00 points
06:31:42:WU01:FS00:Cleaning up
06:33:14:ERROR:Send error: 32: Broken pipe
06:33:14:Caught signal SIGPIPE(13) on PID 318
06:35:21:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
06:35:22:ERROR:Send error: 32: Broken pipe
06:35:22:Caught signal SIGPIPE(13) on PID 318
06:38:59:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
06:42:39:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
06:48:29:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
06:56:12:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
07:03:11:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
07:07:37:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
07:12:08:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
07:16:42:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
07:21:13:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
07:25:44:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
07:27:27:FS00:Paused
07:27:27:ERROR:Send error: 32: Broken pipe
07:27:27:FS00:Shutting core down
07:27:27:Caught signal SIGPIPE(13) on PID 318
07:27:27:WU00:FS00:0xa8:Caught signal SIGINT(2) on PID 6278
07:27:27:WU00:FS00:0xa8:Exiting, please wait. . .
07:27:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:27:45:Removing old file 'configs/config-20220107-011022.xml'
07:27:45:Saving configuration to config.xml
07:27:45:<config>
07:27:45:  <!-- Folding Slot Configuration -->
07:27:45:  <cause v='HIGH_PRIORITY'/>
07:27:45:
07:27:45:  <!-- Network -->
07:27:45:  <proxy v=':8080'/>
07:27:45:
07:27:45:  <!-- Slot Control -->
07:27:45:  <power v='full'/>
07:27:45:
07:27:45:  <!-- User Information -->
07:27:45:  <passkey v='*****'/>
07:27:45:  <team v='234980'/>
07:27:45:  <user v='5qif60ljhsh0'/>
07:27:45:
07:27:45:  <!-- Folding Slots -->
07:27:45:  <slot id='0' type='CPU'>
07:27:45:    <paused v='true'/>
07:27:45:  </slot>
07:27:45:</config>
07:27:57:ERROR:Send error: 32: Broken pipe
07:27:57:Caught signal SIGPIPE(13) on PID 318
08:17:29:FS00:Unpaused
08:17:29:WU00:FS00:Starting
08:17:29:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 318 -checkpoint 15 -np 8
08:17:29:WU00:FS00:Started FahCore on PID 7074
08:17:29:WU00:FS00:Core PID:7075
08:17:29:WU00:FS00:FahCore 0xa8 started
08:17:30:WU00:FS00:0xa8:*********************** Log Started 2022-01-15T08:17:29Z ***********************
08:17:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
08:17:30:WU00:FS00:0xa8:       Core: Gromacs
08:17:30:WU00:FS00:0xa8:       Type: 0xa8
08:17:30:WU00:FS00:0xa8:    Version: 0.0.12
08:17:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:17:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
08:17:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
08:17:30:WU00:FS00:0xa8:       Date: Jan 16 2021
08:17:30:WU00:FS00:0xa8:       Time: 21:22:16
08:17:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
08:17:30:WU00:FS00:0xa8:     Branch: master
08:17:30:WU00:FS00:0xa8:   Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
08:17:30:WU00:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
08:17:30:WU00:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7
08:17:30:WU00:FS00:0xa8:   Platform: darwin 20.2.0
08:17:30:WU00:FS00:0xa8:       Bits: 64
08:17:30:WU00:FS00:0xa8:       Mode: Release
08:17:30:WU00:FS00:0xa8:       SIMD: sse2
08:17:30:WU00:FS00:0xa8:     OpenMP: ON
08:17:30:WU00:FS00:0xa8:       CUDA: OFF
08:17:30:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7074 -checkpoint 15 -np 8
08:17:30:WU00:FS00:0xa8:************************************ libFAH ************************************
08:17:30:WU00:FS00:0xa8:       Time: 21:21:45
08:17:30:WU00:FS00:0xa8:************************************ CBang *************************************
08:17:30:WU00:FS00:0xa8:       Time: 21:21:02
08:17:30:WU00:FS00:0xa8:             -funroll-loops -fno-pie -mmacosx-version-min=10.7 -fPIC
08:17:30:WU00:FS00:0xa8:************************************ System ************************************
08:17:30:WU00:FS00:0xa8:        CPU: VirtualApple @ 2.50GHz
08:17:30:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
08:17:30:WU00:FS00:0xa8:       CPUs: 8
08:17:30:WU00:FS00:0xa8:     Memory: 16.00GiB
08:17:30:WU00:FS00:0xa8:Free Memory: 1.15GiB
08:17:30:WU00:FS00:0xa8:    Threads: POSIX_THREADS
08:17:30:WU00:FS00:0xa8: OS Version: 12.0
08:17:30:WU00:FS00:0xa8:Has Battery: true
08:17:30:WU00:FS00:0xa8: On Battery: false
08:17:30:WU00:FS00:0xa8: UTC Offset: 8
08:17:30:WU00:FS00:0xa8:        PID: 7075
08:17:30:WU00:FS00:0xa8:        CWD: /Library/Application Support/FAHClient/work
08:17:30:WU00:FS00:0xa8:********************************************************************************
08:17:30:WU00:FS00:0xa8:Project: 16978 (Run 45, Clone 50, Gen 187)
08:17:30:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
08:17:30:WU00:FS00:0xa8:Digital signatures verified
08:17:30:WU00:FS00:0xa8:Calling: mdrun -c frame187.gro -s frame187.tpr -x frame187.xtc -cpi state.cpt -cpt 15 -nt 8 -ntmpi 1
08:17:30:WU00:FS00:0xa8:Steps: first=467500000 total=470000000
08:17:31:WU00:FS00:0xa8:Completed 284452 out of 2500000 steps (11%)
08:17:34:Removing old file 'configs/config-20220107-061520.xml'
08:17:34:Saving configuration to config.xml
08:17:34:<config>
08:17:34:  <!-- Folding Slot Configuration -->
08:17:34:  <cause v='HIGH_PRIORITY'/>
08:17:34:
08:17:34:  <!-- Network -->
08:17:34:  <proxy v=':8080'/>
08:17:34:
08:17:34:  <!-- Slot Control -->
08:17:34:  <power v='full'/>
08:17:34:
08:17:34:  <!-- User Information -->
08:17:34:  <passkey v='*****'/>
08:17:34:  <team v='234980'/>
08:17:34:  <user v='5qif60ljhsh0'/>
08:17:34:
08:17:34:  <!-- Folding Slots -->
08:17:34:  <slot id='0' type='CPU'/>
08:17:34:</config>
08:19:58:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
08:24:05:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
08:28:34:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
08:33:22:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
08:38:01:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
08:42:12:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
08:46:10:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
08:50:18:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
08:51:55:ERROR:Send error: 32: Broken pipe
08:51:55:Caught signal SIGPIPE(13) on PID 318
08:54:26:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
Re: keep getting error 32 and client keeps disconnecting
Post by calxalot »
You can ignore the sigpipe errors.
The slow connection from FAHControl can be fixed with some terminal commands:
viewtopic.php?f=108&t=37513
