hello
i am on ubuntu 20.04 and i just installed the snap version of fahclient and fahcontrol. there is no mention of gpu folding in the fahcontrol (folding slots and work queue), but i did try to turn it on by adding a gpu slot. nothing happened. syslog shows it sees nvidia gpu, slot 0, configuration panel, shows no mention of the gpu. i try add slot 0 gpu nothing happens in configure panel.
actual log shows only core 0xa8 (fahcore_a8) running. no mention of starting gpu work. however in my process browser, top, i see fahcore_22 running using a whole processor, in other application showing gpu status i see gpu is running 100 percent load. so fahcore22 is running and it's loaded up the gpu with work, but i don't see credit for it in the control application, and i don't see it there to be able to control it or turn it on or off.
why is this happening? will the work unit complete and upload anyways? will i get credit or am i just burning electricity for fun here? (currently anonymous mode, don't care about the credit, but would like to know if it completed the unit correctly and sent it off)
thanks
fah22 on ubuntu not showing in fahcontrol
Re: fah22 on ubuntu not showing in fahcontrol
Sounds to me like there might be two FAHClients installed running at the same time.
Can you please post the first part of your log, especially the one which shows your system configuration and GPU list. You might need to restart FAH to get this part of the log because it's not shown at the start of a Work Unit. Instructions here: viewtopic.php?p=327413&f=24#p327413
Might also be a good idea to run
and show the output of that here in "CODE" tags.
e.g. this is what is output on my machine:
ps aux|grep fahe.g. this is what is output on my machine:
fahclie+ 1319 0.0 0.0 9325408 9424 ? Ssl Jan04 1:50 /usr/bin/FAHClient /etc/fahclient/config.xml --pid-file=/var/run/fahclient/fahclient.pid --daemon
fahclie+ 1556 0.1 0.7 9989452 116424 ? Sl Jan04 10:57 /usr/bin/FAHClient --child /etc/fahclient/config.xml --pid-file=/var/run/fahclient/fahclient.pid --daemon
fahclie+ 1473087 0.0 0.0 78568 1400 ? SNl 09:03 0:01 /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.18/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1556 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
fahclie+ 1473091 100 2.5 12471268 420524 ? RNl 09:03 136:35 /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.18/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 706 -lifeline 1473087 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100Online: GTX 1660 Super + occasional CPU folding in the cold.
