I do not appear as a team member in some views
chrisvonsimson
Post by chrisvonsimson »
Hi there
In some views I do appear as a team member, but not yet on the team view. A sync delay, or something else?
For example, here's where I can see my complete details:
the control panel
the donor home
but I do not see my name or work units (15) on the team page view. Is this just a synch delay?
(This is a large image that will need opening in it's own browser tab)
aetch
Re: I do not appear as a team member in some views
Post by aetch »
Taking a quick look at extremeoverclockers.com I can see that the team "Atheists, Skeptics, & Humanists - ASH Folding" has nearly 2000 donors folding for them.
https://folding.extremeoverclocking.com ... ist.php?s=
https://folding.extremeoverclocking.com ... =&t=182116
They list 2off folders in the 100K range - https://folding.extremeoverclocking.com ... 6&m=100000
I think the reason you are not seeing yourself listed in the team on the FAH stats site is because it's limited to the top 1000 folders, which you're not in yet.
I'd suggest maybe extremeoverclockers.com is the place to track your points for now.
kiore
Post by kiore »
Hi and welcome to the help forum and thank you for your contribution to FAH,
I am in the same team and see you here:
https://folding.extremeoverclocking.com ... &u=1289121
chrisvonsimson
Thanks very much to both @aetch and @kiore.
I just took a look and now I do show up in the team list. Very encouraging. Before I understood about the top 1000 Folders matter I started up two additional clients this morning (three is my maximum as that's all the possible clients active). Likely that boosted me into the rankings. Thanks very much indeed for your replies.
