openSuse 15.3
i5-7400 3 GHz (4 cores)
16 MB RAM
15:43:44: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:3 GK208B [GeForce GT 730] 692.7
15:43:44: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
The PC stays on during about 12 hours a day.
Delay is always equal to 3 days. All computing are lost.
Rarely, delay is equal to 5 days.
This PC with this Nvidia card needs 5 days.
Delay for computing too shrt
promeneur
- Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Ghost_Rider_51
Re: Delay for computing too shrt
Is it possible that the PC may remain on with screen locked when not in use?
promeneur
Yes, but the PC is in my room, then when I go to sleep I stop it.Is it possible that the PC may remain on with screen locked when not in use?
Ghost_Rider_51
So the problem is yours. If you lock & blank the screen (or just turn off the monitor) it should not bother you, but will still run and process the project WU. If you turn it off then the WU is lost.
Seems an easy choice to me.
Two choices :
- let the PC run 24/7
- replace your GPU with a good one.
https://www.techpowerup.com/gpu-specs/g ... -730.c1988
Your card is still supported, as it does 64 bit Floating point math and supports OpenCL 1.2 or higher. (Nvidia has dropped support for your card)
However, it is a very slow card that may not be actually helping the researchers. If you can't run it 24/7, I would not fold on that card.
(Because, in general, researchers have folded simple proteins first, all future proteins are likely to be more complex)
