Unable to use GPU to fold
AkiyamaSeiran
Post by AkiyamaSeiran »
On my computer with 12th gen core and RTX 3080Ti GPU, I seemed to be unable to get my GPU to fold, the log constantly indicates "WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)" and simply refuses to work, it even occasionally leads to my computer crashes and shuts down. While on my other computer with Ryzen and RTX 3080 mobile it works fine. Any ideas about what's going on?
Re: Unable to use GPU to fold
Post by Neil-B »
Welcome to the Forums :)
You haven't given us much to go on ... could you post your log https://foldingforum.org/viewtopic.php? ... 24#p327416 to give us a better idea of your setup and what the log is showing.
In the mean time a couple of guesses ...
  • Your GPU is overclocked and not stable .. Log may show NaNs errors occurring and core restarts prior to the final bad wu error message
    Your drivers have an issue .. Normally best to use the latest drivers from nvidia
AkiyamaSeiran
17:15:02:WU02:FS01:0x22:*********************** Log Started 2022-01-02T17:15:02Z ***********************
17:15:02:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:15:02:WU02:FS01:0x22:       Core: Core22
17:15:02:WU02:FS01:0x22:       Type: 0x22
17:15:02:WU02:FS01:0x22:    Version: 0.0.18
17:15:02:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:15:02:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
17:15:02:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
17:15:02:WU02:FS01:0x22:       Date: Sep 28 2021
17:15:02:WU02:FS01:0x22:       Time: 05:55:05
17:15:02:WU02:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
17:15:02:WU02:FS01:0x22:     Branch: HEAD
17:15:02:WU02:FS01:0x22:   Compiler: Visual C++
17:15:02:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:15:02:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
17:15:02:WU02:FS01:0x22:   Platform: win32 10
17:15:02:WU02:FS01:0x22:       Bits: 64
17:15:02:WU02:FS01:0x22:       Mode: Release
17:15:02:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:15:02:WU02:FS01:0x22:             <peastman@stanford.edu>
17:15:02:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8864 -checkpoint 15
17:15:02:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:15:02:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
17:15:02:WU02:FS01:0x22:************************************ libFAH ************************************
17:15:02:WU02:FS01:0x22:       Time: 05:53:43
17:15:02:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:15:02:WU02:FS01:0x22:************************************ CBang *************************************
17:15:02:WU02:FS01:0x22:       Time: 05:52:38
17:15:02:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:15:02:WU02:FS01:0x22:************************************ System ************************************
17:15:02:WU02:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i7-12700K
17:15:02:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:15:02:WU02:FS01:0x22:       CPUs: 20
17:15:02:WU02:FS01:0x22:     Memory: 31.80GiB
17:15:02:WU02:FS01:0x22:Free Memory: 22.59GiB
17:15:02:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
17:15:02:WU02:FS01:0x22: OS Version: 6.2
17:15:02:WU02:FS01:0x22:Has Battery: false
17:15:02:WU02:FS01:0x22: On Battery: false
17:15:02:WU02:FS01:0x22: UTC Offset: 8
17:15:02:WU02:FS01:0x22:        PID: 9860
17:15:02:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:15:02:WU02:FS01:0x22:************************************ OpenMM ************************************
17:15:02:WU02:FS01:0x22:    Version: 7.6.0
17:15:02:WU02:FS01:0x22:********************************************************************************
17:15:02:WU02:FS01:0x22:Project: 18201 (Run 3526, Clone 0, Gen 36)
17:15:02:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:15:02:WU02:FS01:0x22:Reading tar file core.xml
17:15:02:WU02:FS01:0x22:Reading tar file integrator.xml
17:15:02:WU02:FS01:0x22:Reading tar file state.xml
17:15:02:WU02:FS01:0x22:Reading tar file system.xml
17:15:03:WU02:FS01:0x22:Digital signatures verified
17:15:03:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:15:03:WU02:FS01:0x22:Version 0.0.18
17:15:03:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:15:03:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:15:03:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
17:15:03:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
17:15:03:WU02:FS01:0x22:There are 4 platforms available.
17:15:03:WU02:FS01:0x22:Platform 0: Reference
17:15:03:WU02:FS01:0x22:Platform 1: CPU
17:15:03:WU02:FS01:0x22:Platform 2: OpenCL
17:15:03:WU02:FS01:0x22:  opencl-device 0 specified
17:15:03:WU02:FS01:0x22:Platform 3: CUDA
17:15:03:WU02:FS01:0x22:  cuda-device 0 specified
17:15:19:WU02:FS01:0x22:Attempting to create CUDA context:
17:15:19:WU02:FS01:0x22:  Configuring platform CUDA
17:15:25:WU02:FS01:0x22:  Using CUDA and gpu 0
17:15:25:WU02:FS01:0x22:Completed 0 out of 1250000 steps (0%)
17:15:26:WU02:FS01:0x22:Checkpoint completed at step 0
17:15:58:WU02:FS01:0x22:An exception occurred at step 7123: Error invoking kernel: CUDA_ERROR_LAUNCH_TIMEOUT (702)
17:15:58:WU02:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
17:15:58:WU02:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
17:16:01:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
17:16:01:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:16:01:WU02:FS01:Starting
17:16:01:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 21296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
17:16:01:WU02:FS01:Started FahCore on PID 2872
17:16:01:WU02:FS01:Core PID:5564
17:16:01:WU02:FS01:FahCore 0x22 started
17:16:01:WU02:FS01:0x22:*********************** Log Started 2022-01-02T17:16:01Z ***********************
17:16:01:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:16:01:WU02:FS01:0x22:       Core: Core22
17:16:01:WU02:FS01:0x22:       Type: 0x22
17:16:01:WU02:FS01:0x22:    Version: 0.0.18
17:16:01:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:16:01:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
17:16:01:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
17:16:01:WU02:FS01:0x22:       Date: Sep 28 2021
17:16:01:WU02:FS01:0x22:       Time: 05:55:05
17:16:01:WU02:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
17:16:01:WU02:FS01:0x22:     Branch: HEAD
17:16:01:WU02:FS01:0x22:   Compiler: Visual C++
17:16:01:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:16:01:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
17:16:01:WU02:FS01:0x22:   Platform: win32 10
17:16:01:WU02:FS01:0x22:       Bits: 64
17:16:01:WU02:FS01:0x22:       Mode: Release
17:16:01:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:16:01:WU02:FS01:0x22:             <peastman@stanford.edu>
17:16:01:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 2872 -checkpoint 15
17:16:01:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:16:01:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
17:16:01:WU02:FS01:0x22:************************************ libFAH ************************************
17:16:01:WU02:FS01:0x22:       Time: 05:53:43
17:16:01:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:16:01:WU02:FS01:0x22:************************************ CBang *************************************
17:16:01:WU02:FS01:0x22:       Time: 05:52:38
17:16:01:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:16:01:WU02:FS01:0x22:************************************ System ************************************
17:16:01:WU02:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i7-12700K
17:16:01:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:16:01:WU02:FS01:0x22:       CPUs: 20
17:16:01:WU02:FS01:0x22:     Memory: 31.80GiB
17:16:01:WU02:FS01:0x22:Free Memory: 22.43GiB
17:16:01:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
17:16:01:WU02:FS01:0x22: OS Version: 6.2
17:16:01:WU02:FS01:0x22:Has Battery: false
17:16:01:WU02:FS01:0x22: On Battery: false
17:16:01:WU02:FS01:0x22: UTC Offset: 8
17:16:01:WU02:FS01:0x22:        PID: 5564
17:16:01:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:16:01:WU02:FS01:0x22:************************************ OpenMM ************************************
17:16:01:WU02:FS01:0x22:    Version: 7.6.0
17:16:01:WU02:FS01:0x22:********************************************************************************
17:16:01:WU02:FS01:0x22:Project: 18201 (Run 3526, Clone 0, Gen 36)
17:16:01:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:16:01:WU02:FS01:0x22:Digital signatures verified
17:16:01:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:16:01:WU02:FS01:0x22:Version 0.0.18
17:16:01:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:16:01:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:16:01:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
17:16:01:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
17:16:01:WU02:FS01:0x22:There are 4 platforms available.
17:16:01:WU02:FS01:0x22:Platform 0: Reference
17:16:01:WU02:FS01:0x22:Platform 1: CPU
17:16:01:WU02:FS01:0x22:Platform 2: OpenCL
17:16:01:WU02:FS01:0x22:  opencl-device 0 specified
17:16:01:WU02:FS01:0x22:Platform 3: CUDA
17:16:01:WU02:FS01:0x22:  cuda-device 0 specified
17:16:16:WU02:FS01:0x22:Attempting to create CUDA context:
17:16:16:WU02:FS01:0x22:  Configuring platform CUDA
17:16:20:WU02:FS01:0x22:  Using CUDA and gpu 0
17:16:20:WU02:FS01:0x22:Completed 0 out of 1250000 steps (0%)
17:16:34:WU02:FS01:0x22:An exception occurred at step 2808: Error invoking kernel: CUDA_ERROR_LAUNCH_TIMEOUT (702)
17:16:34:WU02:FS01:0x22:Max number of attempts to resume from last checkpoint (2) reached. Aborting.
17:16:34:WU02:FS01:0x22:ERROR:114: Max number of attempts to resume from last checkpoint reached.
17:16:34:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
17:16:34:WU02:FS01:0x22:Saving result file science.log
17:16:34:WU02:FS01:0x22:Saving result file state.xml
17:16:37:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
17:16:55:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
17:16:55:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
Here is a session which went wrong. Sometimes I can get it working, but most of the time my computer just stutter for a second and error message pops up.
17:19:06:WU02:FS01:FahCore 0x22 started
17:19:06:WU02:FS01:0x22:*********************** Log Started 2022-01-02T17:19:06Z ***********************
17:19:06:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:19:06:WU02:FS01:0x22:       Core: Core22
17:19:06:WU02:FS01:0x22:       Type: 0x22
17:19:06:WU02:FS01:0x22:    Version: 0.0.18
17:19:06:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:19:06:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
17:19:06:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
17:19:06:WU02:FS01:0x22:       Date: Sep 28 2021
17:19:06:WU02:FS01:0x22:       Time: 05:55:05
17:19:06:WU02:FS01:0x22:   Revision: cfe3d7d990e8f456e371f8ce63b5fcc6daab2103
17:19:06:WU02:FS01:0x22:     Branch: HEAD
17:19:06:WU02:FS01:0x22:   Compiler: Visual C++
17:19:06:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:19:06:WU02:FS01:0x22:             -DOPENMM_VERSION="\"7.6.0\""
17:19:06:WU02:FS01:0x22:   Platform: win32 10
17:19:06:WU02:FS01:0x22:       Bits: 64
17:19:06:WU02:FS01:0x22:       Mode: Release
17:19:06:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:19:06:WU02:FS01:0x22:             <peastman@stanford.edu>
17:19:06:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 24180 -checkpoint 15
17:19:06:WU02:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:19:06:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
17:19:06:WU02:FS01:0x22:************************************ libFAH ************************************
17:19:06:WU02:FS01:0x22:       Time: 05:53:43
17:19:06:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:19:06:WU02:FS01:0x22:************************************ CBang *************************************
17:19:06:WU02:FS01:0x22:       Time: 05:52:38
17:19:06:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:19:06:WU02:FS01:0x22:************************************ System ************************************
17:19:06:WU02:FS01:0x22:        CPU: 12th Gen Intel(R) Core(TM) i7-12700K
17:19:06:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:19:06:WU02:FS01:0x22:       CPUs: 20
17:19:06:WU02:FS01:0x22:     Memory: 31.80GiB
17:19:06:WU02:FS01:0x22:Free Memory: 22.40GiB
17:19:06:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
17:19:06:WU02:FS01:0x22: OS Version: 6.2
17:19:06:WU02:FS01:0x22:Has Battery: false
17:19:06:WU02:FS01:0x22: On Battery: false
17:19:06:WU02:FS01:0x22: UTC Offset: 8
17:19:06:WU02:FS01:0x22:        PID: 3704
17:19:06:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:19:06:WU02:FS01:0x22:************************************ OpenMM ************************************
17:19:06:WU02:FS01:0x22:    Version: 7.6.0
17:19:06:WU02:FS01:0x22:********************************************************************************
17:19:06:WU02:FS01:0x22:Project: 18201 (Run 3526, Clone 0, Gen 36)
17:19:06:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:19:06:WU02:FS01:0x22:Reading tar file core.xml
17:19:06:WU02:FS01:0x22:Reading tar file integrator.xml
17:19:06:WU02:FS01:0x22:Reading tar file state.xml
17:19:06:WU02:FS01:0x22:Reading tar file system.xml
17:19:07:WU02:FS01:0x22:Digital signatures verified
17:19:07:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:19:07:WU02:FS01:0x22:Version 0.0.18
17:19:07:WU02:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:19:07:WU02:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:19:07:WU02:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
17:19:07:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
17:19:07:WU02:FS01:0x22:There are 4 platforms available.
17:19:07:WU02:FS01:0x22:Platform 0: Reference
17:19:07:WU02:FS01:0x22:Platform 1: CPU
17:19:07:WU02:FS01:0x22:Platform 2: OpenCL
17:19:07:WU02:FS01:0x22:  opencl-device 0 specified
17:19:07:WU02:FS01:0x22:Platform 3: CUDA
17:19:07:WU02:FS01:0x22:  cuda-device 0 specified
17:19:22:WU02:FS01:0x22:Attempting to create CUDA context:
17:19:22:WU02:FS01:0x22:  Configuring platform CUDA
17:19:26:WU02:FS01:0x22:  Using CUDA and gpu 0
17:19:26:WU02:FS01:0x22:Completed 0 out of 1250000 steps (0%)
17:19:27:WU02:FS01:0x22:Checkpoint completed at step 0
17:19:44:WU02:FS01:0x22:An exception occurred at step 3502: Error invoking kernel: CUDA_ERROR_LAUNCH_TIMEOUT (702)
17:19:44:WU02:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
17:19:44:WU02:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
17:19:46:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
17:19:46:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
17:19:46:WARNING:WU02:FS01:Too many errors, failing
17:19:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:18201 run:3526 clone:0 gen:36 core:0x22 unit:0x00000000000000240000471900000dc6
17:19:46:WU02:FS01:Uploading 23.75MiB to 128.252.203.11
17:19:46:WU02:FS01:Connecting to 128.252.203.11:8080
17:19:47:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:19:47:WU01:FS01:Assigned to work server 128.252.203.11
17:19:47:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080 Ti] from 128.252.203.11
Here is another piece of log I just get
Post by Neil-B »
Can you post the start of the log - the first 100 lines or so as I am looking for the driver information ... it will have a bit like this:
10:07:32: GPUs: 1
10:07:32: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA104 [GeForce RTX 3070]
10:07:32: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.5
10:07:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:497.29
10:07:32:***********************************************************************
but so far it looks like a driver issue to me ... have you downloaded and installed drivers from nvidia (latest would be 497.29 as above which comes with 11.5 cuda) ... the drivers sup[plied by windows/oem sometimes lack proper cuda drivers iirc ... there are other possibilities but lets check this first.
AkiyamaSeiran
17:40:11:******************************* System ********************************
17:40:11:            CPU: 12th Gen Intel(R) Core(TM) i7-12700K
17:40:11:         CPU ID: GenuineIntel Family 6 Model 151 Stepping 2
17:40:11:           CPUs: 20
17:40:11:         Memory: 31.80GiB
17:40:11:    Free Memory: 25.41GiB
17:40:11:        Threads: WINDOWS_THREADS
17:40:11:     OS Version: 6.2
17:40:11:    Has Battery: false
17:40:11:     On Battery: false
17:40:11:     UTC Offset: 8
17:40:11:            PID: 20624
17:40:11:            CWD: C:\ProgramData\FAHClient
17:40:11:  Win32 Service: false
17:40:11:             OS: Windows 10 Enterprise
17:40:11:        OS Arch: AMD64
17:40:11:           GPUs: 1
17:40:11:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 Ti]
17:40:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.6 Driver:11.5
17:40:11:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:497.29
17:40:11:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:30.0
17:40:11:***********************************************************************
It looks like things are fine here...However after some twinkling myself it seems like this problem somehow related with CPU overclocking, I disabled CPU overclocking and after some restarts now it seemed to work...
