GT710 no longer works
Meki01
Hardware configuration: WIN7 HP / Intel i7-4790 CPU @ 3.60 GHz / 16 GB RAM / AMD RX-570P8DFD6
WIN10 pro / AMD RYZEN 7 2700 / 16 GB RAM / NVIDIA GeForce GTX 1050 Ti
Folding since 03 2020 - not always, always more often
Post by Meki01 »
Hi! I have had a system (Win10, Intel i7, GT710) running for a few months with no problems. Now I have the message "Disabeld" on the graphics card. Is the GT710 no longer supported?
Thanks for the quick reply!
05:56:11:WARNING:FS02:No CUDA or OpenCL 1.2+ support detected for GPU slot 02: gpu:-1:-1. Disabling.
Sorry for my bad english - google translator says hello :-)
aetch
Re: GT710 no longer works
Post by aetch »
Can you post the first couple of hundred lines of your log.
PaulTV
Post by PaulTV »
When the FAH client starts before there is internet connection, it won't be able to get the GPUs.txt file, and disable the GPU. Pause folding, stop the fahclient process, and restart it. If that doesn't help, try removing GPUs.txt (from C:\ProgramData\FAHClient, if you're on Windows) after stopping faclient.
Ryzen 5600X / RTX 3070 Ti / Ubuntu 22.04
Ryzen 5600 / RTX 3060 Ti / Windows 11
They are still supported (Kepler chip).
Did you install drivers from nVidia website ?
https://www.techpowerup.com/gpu-specs/g ... -710.c2614
Your card uses a Fermi based micro-architexture, and is no longer supported. F@H requires both a 64 bit floating point math unit and support for OpenCL 1.2. Fermi does not support 1.2,, so is no longer supported. I would not invest in a replacement slower than a GT 1030, which is based on a much newer Pascal micro-architexture.
This one is not listed in GPUs.txt ... there are only 3 models based on GK208 chip.
Meki01
Post by Meki01 »
aetch wrote:Can you post the first couple of hundred lines of your log.
*********************** Log Started 2021-12-30T06:20:29Z ***********************
06:20:29:******************************* libFAH ********************************
06:20:29:           Date: Oct 20 2020
06:20:29:           Time: 13:36:55
06:20:29:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:20:29:         Branch: master
06:20:29:       Compiler: Visual C++ 2015
06:20:29:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:20:29:       Platform: win32 10
06:20:29:           Bits: 32
06:20:29:           Mode: Release
06:20:29:****************************** FAHClient ******************************
06:20:29:        Version: 7.6.21
06:20:29:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:20:29:      Copyright: 2020 foldingathome.org
06:20:29:       Homepage: https://foldingathome.org/
06:20:29:           Time: 13:41:04
06:20:29:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:20:29:           Bits: 32
06:20:29:         Config: C:\ProgramData\FAHClient\config.xml
06:20:29:******************************** CBang ********************************
06:20:29:           Time: 11:36:18
06:20:29:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:20:29:           Bits: 32
06:20:29:******************************* System ********************************
06:20:29:            CPU: Intel(R) Core(TM) i7-4790S CPU @ 3.20GHz
06:20:29:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:20:29:           CPUs: 8
06:20:29:         Memory: 3.96GiB
06:20:29:    Free Memory: 1.72GiB
06:20:29:        Threads: WINDOWS_THREADS
06:20:29:     OS Version: 6.2
06:20:29:    Has Battery: false
06:20:29:     On Battery: false
06:20:29:     UTC Offset: 1
06:20:29:            PID: 5268
06:20:29:            CWD: C:\ProgramData\FAHClient
06:20:29:  Win32 Service: false
06:20:29:             OS: Windows 10 Enterprise
06:20:29:        OS Arch: AMD64
06:20:29:           GPUs: 1
06:20:29:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
06:20:29:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
06:20:29:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:472.12
06:20:29:***********************************************************************
06:20:29:<config>
06:20:29:  <!-- Network -->
06:20:29:  <proxy v=':8080'/>
06:20:29:
06:20:29:  <!-- User Information -->
Meki01
Post by Meki01 »
toTOW wrote:They are still supported (Kepler chip).
Yes, I have. It has worked for a few months now it suddenly stopped. I have already reinstalled the drivers and de-installed and reinstalled the FAH client ...
Meki01
Post by Meki01 »
PaulTV wrote:When the FAH client starts before there is internet connection, it won't be able to get the GPUs.txt file, and disable the GPU. Pause folding, stop the fahclient process, and restart it. If that doesn't help, try removing GPUs.txt (from C:\ProgramData\FAHClient, if you're on Windows) after stopping faclient.
The internet is stable ... I deleted the GPUs.txt, unfortunately that didn't work. The GPU is still disabled ...
Meki01
Post by Meki01 »
JimboPalmer wrote:https://www.techpowerup.com/gpu-specs/g ... -710.c2614
Thank you, then it will be obsolete ...
That Fermi based GT 710 card is not listed in GPUs.txt, I don't think it ever was. There are 3 Kepler based GT 710 models, the only way we can tell which you have is by you providing the PCI ID number of the card. The Fermi based 710 is not even shown on the wikipedia page for nVidia cards. There is a GF119 based GT 705 listed. If you have a Kepler based GT 710 it should still work, but you may need to go to an older driver.
nVidia ended support for Kepler based GPUs in October, they ended support for the older Fermi cards a couple years ago. Legacy support may or may not include working OpenCL support on drivers released since then. Only security fixes will be provided for a couple more years.
Meki01> what's the device ID of your GPU ? (You can get it with GPUZ for instance)
Meki01
Post by Meki01 »
Hi! The problem was apparently due to a firewall - changeover on the part of our IT. I now get work orders again and the graphics card as well. Unfortunately, the work orders can no longer be sent back. IT has already tried some settings, but I still get the error message:
10:25:57:WU00:FS00:Trying to send results to collection server
10:25:57:WU00:FS00:Uploading 20.09MiB to 129.32.209.205
10:25:57:WU00:FS00:Connecting to 129.32.209.205:8080
10:26:27:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
Which ports would have to be open in the firewall? It's a Fortinet.... Thanks for your help!
FAHClient acts as a standard browser and uses ports 8080 and 80 ...
If your firewall has DPI features (traffic inspection), that's what you have to disable ...
MeeLee
Post by MeeLee »
I don't think it's delisted because of not being compatible, but because of not being able to finish the WUs on time.
It's tough to do with a GT 730, but a 710 is way slower.
