18417 No Bonus?
Knish
18417 No Bonus?
Post by Knish »
"new" machine I set up this week for folding purely CPU stuff. I highly doubt I entered my passkey incorrectly, so its weird I seem to only have been awarded base credits for a turn in 1.3 days when the Timeout is 4 days.
************* Log Started 2021-12-10T01:33:37Z ***********************
01:33:37:******************************* libFAH ********************************
01:33:37:       Date: Oct 20 2020
01:33:37:       Time: 20:36:39
01:33:37:   Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
01:33:37:     Branch: master
01:33:37:   Compiler: GNU 8.3.0
01:33:37:    Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
01:33:37:             -fdata-sections -O3 -funroll-loops -fno-pie
01:33:37:   Platform: linux2 5.8.0-1-amd64
01:33:37:       Bits: 64
01:33:37:       Mode: Release
01:33:37:****************************** FAHClient ******************************
01:33:37:    Version: 7.6.21
01:33:37:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:33:37:  Copyright: 2020 foldingathome.org
01:33:37:   Homepage: https://foldingathome.org/
01:33:37:       Time: 20:39:00
01:33:37:   Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
01:33:37:       Bits: 64
01:33:37:       Args: --config /etc/foldingathome/config.xml --log
01:33:37:             /var/log/foldingathome/log.txt --log-rotate-dir
01:33:37:     Config: /etc/foldingathome/config.xml
01:33:37:******************************** CBang ********************************
01:33:37:       Time: 18:37:59
01:33:37:   Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
01:33:37:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
01:33:37:       Bits: 64
01:33:37:******************************* System ********************************
01:33:37:        CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
01:33:37:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
01:33:37:       CPUs: 6
01:33:37:     Memory: 3.70GiB
01:33:37:Free Memory: 3.45GiB
01:33:37:    Threads: POSIX_THREADS
01:33:37: OS Version: 5.15
01:33:37:Has Battery: false
01:33:37: On Battery: false
01:33:37: UTC Offset: -8
01:33:37:        PID: 459
01:33:37:        CWD: /var/lib/private/fah
01:33:37:         OS: Linux 5.15.7-arch1-1 x86_64
01:33:37:    OS Arch: AMD64
01:33:37:       GPUs: 1
01:33:37:      GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
01:33:37:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
01:33:37:             libcuda.so: cannot open shared object file: No such file or
01:33:37:             directory
01:33:37:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
01:33:37:             libOpenCL.so: cannot open shared object file: No such file or
01:33:37:             directory
01:33:37:*******
09:54:50:WU00:FS00:0xa8:Completed 10000000 out of 10000000 steps (100%)
09:54:51:WU00:FS00:0xa8:Saving result file ../logfile_01.txt
09:54:51:WU00:FS00:0xa8:Saving result file dhdl.xvg
09:54:51:WU00:FS00:0xa8:Saving result file frame15.gro
09:54:51:WU00:FS00:0xa8:Saving result file frame15.xtc
09:54:51:WU00:FS00:0xa8:Saving result file md.log
09:54:51:WU00:FS00:0xa8:Saving result file science.log
09:54:51:WU00:FS00:0xa8:Saving result file state.cpt
09:54:51:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
09:54:52:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:54:52:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:18417 run:108
09:54:52:WU00:FS00:Uploading 20.04MiB to 129.32.209.203
09:54:52:WU00:FS00:Connecting to 129.32.209.203:8080
09:54:58:WU00:FS00:Upload 20.27%
09:55:04:WU00:FS00:Upload 40.53%
09:55:10:WU00:FS00:Upload 61.11%
09:55:16:WU00:FS00:Upload 81.69%
09:55:22:WU00:FS00:Upload complete
09:55:22:WU00:FS00:Server responded WORK_ACK (400)
09:55:22:WU00:FS00:Final credit estimate, 138790.00 points
checking the stats WU page and ExtremeOverClocking, I only see base points
Re: 18417 No Bonus?
There's not much I can do but to suggest to check your passkey again. Be careful of some hidden spaces before or after the passkey if you copy/pasted it ...
Knish
Re: 18417 No Bonus?
Post by Knish »
out of curiousity, how would i check the already entered key, isn't it all starred out in the config?
But I checked via the "active CPUs" and the math checks out with how many clients i have running, so that should guarantee it's correct, right?
Knish
Re: 18417 No Bonus?
Post by Knish »
oh, i just realized, that's off username, not passkey... ya, other WU's I see now also are no bonus so i'll re-enter my passkey. sorry for the mistake
aetch
Re: 18417 No Bonus?
Post by aetch »
{Redacted}
Re: 18417 No Bonus?
Post by Neil-B »
Are all the WUs from that machine no bonus or just the 1st ten? ... As a new username/passkey pairing it would need to qualify for QRB.
aetch
Re: 18417 No Bonus?
Post by aetch »
{Redacted}
Knish
Re: 18417 No Bonus?
Post by Knish »
aetch, please check your inbox, thanks
aetch
Re: 18417 No Bonus?
Post by aetch »
Previous posts redacted at request of OP
Knish wrote:If you could kindly remove or at least censor my non-forum username and the links to it
