ERROR:WU00:FS00:Exception: Failed reading core package heade
ReinhardGross
Post by ReinhardGross »
After updating my Client to 7.6.21 I receive this error message:
09:59:31:            CPU: AMD Ryzen 5 2600 Six-Core Processor
09:59:31:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:59:31:           CPUs: 12
09:59:31:         Memory: 15.93GiB
09:59:31:    Free Memory: 12.87GiB
09:59:31:        Threads: WINDOWS_THREADS
09:59:31:     OS Version: 6.2
09:59:31:    Has Battery: false
09:59:31:     On Battery: false
09:59:31:     UTC Offset: 1
09:59:31:            PID: 13108
09:59:31:            CWD: C:\Users\User\AppData\Roaming\FAHClient
09:59:31:  Win32 Service: false
09:59:31:             OS: Windows 10 Home
09:59:31:        OS Arch: AMD64
09:59:31:           GPUs: 1
09:59:31:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
09:59:31:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:6.1 Driver:11.1
09:59:31:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:456.71
09:59:31:***********************************************************************
09:59:31:<config>
09:59:31:  <!-- Slot Control -->
09:59:31:  <power v='FULL'/>
09:59:31:
09:59:31:  <!-- Folding Slots -->
09:59:31:  <slot id='0' type='CPU'/>
09:59:31:  <slot id='1' type='GPU'/>
09:59:31:</config>
09:59:31:Trying to access database...
09:59:31:Successfully acquired database lock
09:59:31:FS00:Initialized folding slot 00: cpu:11
09:59:31:FS01:Initialized folding slot 01: gpu:8:0 GP106 [GeForce GTX 1060 3GB] 3935
09:59:31:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
09:59:31:WU00:FS00:Connecting to cores.foldingathome.org:80
09:59:31:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
09:59:31:WU01:FS01:Connecting to cores.foldingathome.org:80
09:59:32:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:59:32:ERROR:WU01:FS01:Exception: Failed reading core package header.
09:59:35:9:127.0.0.1:New Web session
10:00:31:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
10:00:31:WU00:FS00:Connecting to cores.foldingathome.org:80
10:00:32:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:00:32:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
10:00:32:WU01:FS01:Connecting to cores.foldingathome.org:80
10:00:32:Saving configuration to config.xml
10:00:32:<config>
10:00:32:  <!-- Slot Control -->
10:00:32:  <power v='FULL'/>
10:00:32:
10:00:32:  <!-- User Information -->
10:00:32:  <team v='3'/>
10:00:32:  <user v='ReinhardGross'/>
10:00:32:
10:00:32:  <!-- Folding Slots -->
10:00:32:  <slot id='0' type='CPU'/>
10:00:32:  <slot id='1' type='GPU'>
10:00:32:    <pci-bus v='8'/>
10:00:32:    <pci-slot v='0'/>
10:00:32:  </slot>
10:00:32:</config>
10:00:32:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:00:54:25:127.0.0.1:New Web session
10:02:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
10:02:09:WU00:FS00:Connecting to cores.foldingathome.org:80
10:02:09:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:02:09:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
10:02:09:WU01:FS01:Connecting to cores.foldingathome.org:80
10:02:09:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:04:46:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
10:04:46:WU00:FS00:Connecting to cores.foldingathome.org:80
10:04:46:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:04:46:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
10:04:46:WU01:FS01:Connecting to cores.foldingathome.org:80
10:04:46:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:05:17:33:127.0.0.1:New Web session
10:09:00:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
10:09:00:WU00:FS00:Connecting to cores.foldingathome.org:80
10:09:00:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:09:00:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
10:09:00:WU01:FS01:Connecting to cores.foldingathome.org:80
10:09:01:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:15:51:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
10:15:51:WU00:FS00:Connecting to cores.foldingathome.org:80
10:15:52:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:15:52:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.18/Core_22.fah
10:15:52:WU01:FS01:Connecting to cores.foldingathome.org:80
10:15:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
Any1 a clue, where to look for the glitch?
Reason: added Code tags to log
Re: ERROR:WU00:FS00:Exception: Failed reading core package h
My first guess would be to look at anti-malware or firewall settings. Some by default will keep executables or downloads like the core package from being read and installed.
aetch
Post by aetch »
I would suggest looking at the file/folder exclusions list for your anti-virus.
It's recommended that you exclude the FAHClient folder.
It should be noted that with version 7.6.21 that location changed.
Prior to 7.6.21 it was c:\users\<your username>\appdata\roaming\FAHClient
7.6.21 it became C:\programdata\FAHClient
check the notes at the bottom of the requirements page for the recommendation
https://foldingathome.org/support/faq/i ... ts/?lng=en
After you have sorted your issues (permissions or antivirus/firewall), you will also have to update your GPU drivers : viewtopic.php?f=24&t=37391
aetch
Post by aetch »
@toTOW @Joe_H
last time this issue popped up it seemed to be a problem on the back-end. Is the cores download server playing up again?
Last time -> viewtopic.php?f=74&t=37434
Bahamut_tmg
Post by Bahamut_tmg »
Having the same issue Debian 10 using FAHCore 7.6.21
