[tuto] openSUSE >= 15.3,Tumbleweed,How to get a silent and cold PC ?
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
0. some problems may occurs:
- cpu too hot
- fah does not decrease its cpu power consumption when you launch an app.
- setting "folding power"to "light" or "medium" does not work
In this case
see the Bruce solution
http://foldingforum.org/viewtopic.php?f ... 37#p307174
or
see my solution
1. I tested Bruce's solution.
The CPU of my PC gets 4 cores.
FAH settings : Power "full" when i am "working"
Result:
- my solution "cpulimit --exe FahCore_a8 --limit 50" : about 32 °C
- Bruce's solution "only one core for folding" : about 42 °C
Bruce's solution is easy but does nor work with gpu fah core
My solution is complex but works with every type (cpu or gpu) fah core.
2. My solution
We can use cpulimit (supplied with standard repos).
See doc
http://cpulimit.sourceforge.net/
You must start an instance of cpulimit for each core fah expects to use. For example in my case fah expects to use a4 and a7 cores then at startup systemd starts one occurrence for a4 and one for a7.
For each occurrence, you must create a service.
In my case, cpu gets 4 cores and I want to limit to 12.5 % the use of each core and FAH expects to use a7 cores. According to the doc, I must set "limit" to "50"
Obviously, you can replace "a7" by any Fahcore name.
in /etc/systemd/system/
create "cpulimit_a7.service" file
put in it
# /etc/systemd/system/cpulimit_a7.service
[Unit]
Description=Run cpulimit for fah a7 core
[Service]
Type=oneshot
ExecStart=/usr/bin/cpulimit --exe FahCore_a7 --limit 50
[Install]
WantedBy=multi-user.target
update its ownership and permissions as below
$ sudo chown root:root /etc/systemd/system/cpulimit_a7.service
 $ sudo chmod u=rw,go=r /etc/systemd/system/cpulimit_a7.service
Reload systemd manager configuration
        $ sudo systemctl daemon-reload
with "service manager" tool :
- set cpulimit_a7 service to "activate", "start mode" to "At system startup" then "apply" and check start does not fail
Repeat the procedure for all the FAH cores you expect.
Enjoy
If someone can help. I get a little problem. When with "yast service manager" I start the service then the service is well started, but the dialog does not finish then I must kill the service manager. Perhaps we must add something in the service file.
Whompithian
Re: [tuto] openSUSE 15.3,How to get a silent and cold PC ?
Post by Whompithian »
You can condense the steps from:
to
into:
sudo systemctl edit --full --force cpulimit_a7.service
I'm afraid I can't help with the yast problem, though.
promeneur
Re: [tuto] openSUSE >= 15.3,Tumbleweed,How to get a silent and cold PC ?
Post by promeneur »
A simpler solution that you can customize easily.
It is simpler to modify a bash script than a service file.
Contents of cpulimit.service
# /usr/lib/systemd/system/cpulimit.service
[Unit]
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/home/<your id>/bin/cpulimit.sh
[Install]
Contents of cpulimit.sh
The values of “--limit” are examples. You must customize them.
#!/bin/bash
# reducing cpu temp, gpu temp and chassis fan noise
cpulimit --exe FahCore_a7 --limit 50 &
cpulimit --exe FahCore_a8 --limit 50 &
cpulimit --exe FahCore_22 --limit 75 &
If you modify the contents of cpulimit.sh then you must restart cpulimit service.
promeneur
Post by promeneur »
Beware that cpulimit can limit only one occurrence of a core.
If you have for example two a8 then only one will be limited by cpulimit.
Here is a script using cpulimit to limit several occurrences of the same app
https://aweirdimagination.net/2020/08/0 ... processes/
I did not experiment this script.
promeneur
Post by promeneur »
For those using MS Windows, there is a clone of cpulimit.
https://github.com/alquerci/cpulimit
