Whitelist Request - NVIDIA T1200 (TU117)
bandwith
Post by bandwith »
Seems that another was missed in the TU117 series added here: viewtopic.php?f=83&t=37503#p353581
0x10de:0x1fbc:1:0:0:NVIDIA Corporation:NVIDIA T1200 Laptop GPU
This is a Dell Precision 7560 (P93F002).
.\FAHClient.exe --lspci
0x8086:0x4389:0:31:0:Intel Corporation:Intel(R) LPC Controller (WM590) - 4389
0x10ec:0x5260:148:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIE CardReader
0x8086:0x43fc:0:18:0:Intel Corporation:Intel(R) Integrated Sensor Solution
0x8086:0x9a1f:0:13:2:Intel Corporation:Thunderbolt(TM) Controller - 9A1F
0x8086:0x15f9:0:31:6:Intel Corporation:Intel(R) Ethernet Connection (14) I219-LM
0x8086:0x43b9:0:28:0:Intel Corporation:Intel(R) PCI Express Root Port #2 - 43B9
0x8086:0x43ba:0:28:2:Intel Corporation:Intel(R) PCI Express Root Port #3 - 43BA
0x8086:0x9a0d:0:10:0:Intel Corporation:Intel(R) Platform Monitoring Technology Driver
0x8086:0x9a2d:0:7:1:Intel Corporation:PCI Express Root Port
0x10de:0x10fa:1:0:1:NVIDIA Corporation:High Definition Audio Controller
0x1179:0x011a:2:0:0:Toshiba America Info Systems:Standard NVM Express Controller
0x8086:0x43ed:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x43e9:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 43E9
0x8086:0x2725:147:0:0:Intel Corporation:Intel(R) Wi-Fi 6E AX210 160MHz
0x8086:0x9a01:0:1:0:Intel Corporation:Intel(R) PEG10 - 9A01
0x8086:0x43ef:0:20:2:Intel Corporation:Intel(R) Shared SRAM - 43EF
0x8086:0x43a4:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - 43A4
0x8086:0x43e3:0:22:3:Intel Corporation:Intel(R) Active Management Technology - SOL
0x8086:0x9a17:0:13:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x43ad:0:25:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 43AD
0x8086:0x9a0f:0:6:0:Intel Corporation:Intel(R) PEG60 - 9A0F
0x8086:0x43e0:0:22:0:Intel Corporation:Intel(R) Management Engine Interface #1
0x8086:0x9a03:0:4:0:Intel Corporation:Intel(R) Dynamic Tuning Processor Participant
0x5853:0x1003:0:0:0:XenSource, Inc.:Citrix Indirect Display Adapter
0x8086:0x43e8:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - 43E8
0x8086:0x9a36:0:0:0:Intel Corporation:PCI standard host CPU bridge
0x8086:0x9a11:0:8:0:Intel Corporation:Intel(R) GNA Scoring Accelerator module
0x8086:0x43c8:0:31:3:Intel Corporation:Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
0x8086:0x43a3:0:31:4:Intel Corporation:Intel(R) SMBus - 43A3
0x8086:0x9a2b:0:7:0:Intel Corporation:PCI Express Root Port
*********************** Log Started 2021-11-23T23:26:07Z ***********************
23:26:07:******************************* libFAH ********************************
23:26:07:           Date: Oct 20 2020
23:26:07:           Time: 13:36:55
23:26:07:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
23:26:07:         Branch: master
23:26:07:       Compiler: Visual C++ 2015
23:26:07:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
23:26:07:       Platform: win32 10
23:26:07:           Bits: 32
23:26:07:           Mode: Release
23:26:07:****************************** FAHClient ******************************
23:26:07:        Version: 7.6.21
23:26:07:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:26:07:      Copyright: 2020 foldingathome.org
23:26:07:       Homepage: https://foldingathome.org/
23:26:07:           Time: 13:41:04
23:26:07:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
23:26:07:           Bits: 32
23:26:07:         Config: C:\ProgramData\FAHClient\config.xml
23:26:07:******************************** CBang ********************************
23:26:07:           Time: 11:36:18
23:26:07:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
23:26:07:           Bits: 32
23:26:07:******************************* System ********************************
23:26:07:            CPU: 11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz
23:26:07:         CPU ID: GenuineIntel Family 6 Model 141 Stepping 1
23:26:07:           CPUs: 16
23:26:07:         Memory: 31.27GiB
23:26:07:    Free Memory: 25.82GiB
23:26:07:        Threads: WINDOWS_THREADS
23:26:07:     OS Version: 6.2
23:26:07:    Has Battery: true
23:26:07:     On Battery: false
23:26:07:     UTC Offset: -5
23:26:07:            PID: 16272
23:26:07:            CWD: C:\ProgramData\FAHClient
23:26:07:  Win32 Service: false
23:26:07:             OS: Windows 10 Enterprise
23:26:07:        OS Arch: AMD64
23:26:07:           GPUs: 1
23:26:07:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
23:26:07:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.5
23:26:07:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:496.49
23:26:07:***********************************************************************
23:26:07:<config>
23:26:07:  <!-- Network -->
23:26:07:  <proxy v=':8080'/>
23:26:07:
23:26:07:  <!-- Slot Control -->
23:26:07:  <pause-on-battery v='false'/>
23:26:07:  <power v='medium'/>
23:26:07:
23:26:07:  <!-- User Information -->
23:26:07:  <passkey v='*****'/>
23:26:07:  <team v='*****'/>
23:26:07:  <user v='*****'/>
23:26:07:
23:26:07:  <!-- Folding Slots -->
23:26:07:  <slot id='0' type='CPU'>
23:26:07:    <idle v='true'/>
23:26:07:  </slot>
23:26:07:  <slot id='2' type='GPU'>
23:26:07:    <pci-bus v='1'/>
23:26:07:    <pci-slot v='0'/>
23:26:07:  </slot>
23:26:07:</config>
23:26:07:Trying to access database...
23:26:07:Successfully acquired database lock
23:26:07:FS00:Initialized folding slot 00: cpu:14
23:26:07:WARNING:FS02:Disabling beta GPU slot 02: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
Re: Whitelist Request - NVIDIA T1200 (TU117)
My source still doesn't list it ...
I added it to the list, you should be able to use it after a GPUs.txt update on your client.
bandwith
Post by bandwith »
Nice. It downloaded the update and is starting a WU on Core 22.
I'm just laughing as this new laptop has the currently "best" ranked Intel cpu at https://folding.lar.systems/cpu_ppd/bra ... 50h_250ghz
I'm doing what I can to not turn on a space heater in my home office :D
Post by Neil-B »
bandwith wrote:I'm just laughing as this new laptop has the currently "best" ranked Intel cpu at https://folding.lar.systems/cpu_ppd/bra ... 50h_250ghz
I can see ten so so intel cpus above yours ... https://folding.lar.systems/cpu_ppd/overall_ranks
bandwith
Post by bandwith »
Yeah, that was last night after only two WUs submitted... it's evening out now. Still not terrible results from a laptop.
