no more cuda computing
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
Today, after one week without any problem, nvidia gpu slot diabled and no more igp slot
the log
*********************** Log Started 2021-11-23T07:01:42Z ***********************
07:01:42:******************************* libFAH ********************************
07:01:42:           Date: Oct 20 2020
07:01:42:           Time: 20:36:41
07:01:42:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
07:01:42:         Branch: master
07:01:42:       Compiler: GNU 4.9.4
07:01:42:        Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections
07:01:42:                 -O3 -funroll-loops
07:01:42:       Platform: linux2 5.8.0-1-amd64
07:01:42:           Bits: 64
07:01:42:           Mode: Release
07:01:42:****************************** FAHClient ******************************
07:01:42:        Version: 7.6.21
07:01:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:42:      Copyright: 2020 foldingathome.org
07:01:42:       Homepage: https://foldingathome.org/
07:01:42:           Time: 20:38:59
07:01:42:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
07:01:42:           Bits: 64
07:01:42:           Args: /etc/fahclient/config.xml
07:01:42:                 --pid-file=/run/fahclient/fahclient.pid
07:01:42:         Config: /etc/fahclient/config.xml
07:01:42:******************************** CBang ********************************
07:01:42:           Time: 18:38:01
07:01:42:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
07:01:42:                 -O3 -funroll-loops -fPIC
07:01:42:           Bits: 64
07:01:42:******************************* System ********************************
07:01:42:            CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:01:42:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:01:42:           CPUs: 4
07:01:42:         Memory: 15.50GiB
07:01:42:    Free Memory: 14.59GiB
07:01:42:        Threads: POSIX_THREADS
07:01:42:     OS Version: 5.3
07:01:42:    Has Battery: false
07:01:42:     On Battery: false
07:01:42:     UTC Offset: 1
07:01:42:            PID: 1875
07:01:42:            CWD: /var/lib/fahclient
07:01:42:             OS: Linux 5.3.18-59.34-default x86_64
07:01:42:        OS Arch: AMD64
07:01:42:           GPUs: 1
07:01:42:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
07:01:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:11.4
07:01:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:470.86
07:01:42:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:1.3
07:01:42:***********************************************************************
07:01:42:<config>
07:01:42:  <!-- Network -->
07:01:42:  <proxy v=':8080'/>
07:01:42:
07:01:42:  <!-- Slot Control -->
07:01:42:  <power v='FULL'/>
07:01:42:
07:01:42:  <!-- User Information -->
07:01:42:  <passkey v='*****'/>
07:01:42:  <team v='51'/>
07:01:42:  <user v='philippe_roubach'/>
07:01:42:
07:01:42:  <!-- Folding Slots -->
07:01:42:  <slot id='0' type='CPU'/>
07:01:42:  <slot id='2' type='GPU'>
07:01:42:    <pci-bus v='1'/>
07:01:42:    <pci-slot v='0'/>
07:01:42:  </slot>
07:01:42:  <slot id='1' type='GPU'>
07:01:42:    <gpu-beta v='True'/>
07:01:42:    <opencl-index v='0'/>
07:01:42:    <paused v='true'/>
07:01:42:    <pci-bus v='0'/>
07:01:42:    <pci-slot v='2'/>
07:01:42:  </slot>
07:01:42:</config>
07:01:42:Trying to access database...
07:01:42:Successfully acquired database lock
07:01:42:ERROR:GPU with PCI bus 0 and slot 2 not found.: Deleting folding slot.
07:01:42:FS00:Initialized folding slot 00: cpu:3
07:01:42:WARNING:FS02:Disabling beta GPU slot 02: gpu:1:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
07:01:42:WARNING:FS01:``opencl-index`` 0 did not match GPU
07:01:42:WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:-1:-1.  Disabling.
07:01:42:WARNING:WU03:No longer matches Slot 2's configuration and there are no other matching slots, dumping
07:01:42:WU03:FS02:Sending unit results: id:03 state:SEND error:DUMPED project:16608 run:128 clone:1 gen:109 core:0x22 unit:0x000000010000006d000040e000000080
07:01:42:WU03:FS02:Connecting to 66.170.111.50:8080
07:01:42:WU01:FS00:Starting
07:01:42:WARNING:WU01:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
07:01:42:WARNING:WU01:FS00:AS lowered CPUs from 3 to 2
07:01:42:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
07:01:42:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 1875 -checkpoint 15 -np 2
07:01:42:WU01:FS00:Started FahCore on PID 1975
07:01:42:WU01:FS00:Core PID:1979
07:01:42:WU01:FS00:FahCore 0xa8 started
07:01:43:WU01:FS00:0xa8:*********************** Log Started 2021-11-23T07:01:42Z ***********************
07:01:43:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
07:01:43:WU01:FS00:0xa8:       Core: Gromacs
07:01:43:WU01:FS00:0xa8:       Type: 0xa8
07:01:43:WU01:FS00:0xa8:    Version: 0.0.12
07:01:43:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:01:43:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
07:01:43:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
07:01:43:WU01:FS00:0xa8:       Date: Jan 16 2021
07:01:43:WU01:FS00:0xa8:       Time: 19:24:44
07:01:43:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
07:01:43:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
07:01:43:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
07:01:43:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
07:01:43:WU01:FS00:0xa8:       Bits: 64
07:01:43:WU01:FS00:0xa8:       Mode: Release
07:01:43:WU01:FS00:0xa8:       SIMD: avx2_256
07:01:43:WU01:FS00:0xa8:     OpenMP: ON
07:01:43:WU01:FS00:0xa8:       CUDA: OFF
07:01:43:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1975 -checkpoint 15 -np 2
07:01:43:WU01:FS00:0xa8:************************************ libFAH ************************************
07:01:43:WU01:FS00:0xa8:       Time: 19:21:38
07:01:43:WU01:FS00:0xa8:************************************ CBang *************************************
07:01:43:WU01:FS00:0xa8:       Time: 19:21:24
07:01:43:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
07:01:43:WU01:FS00:0xa8:************************************ System ************************************
07:01:43:WU01:FS00:0xa8:        CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
07:01:43:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
07:01:43:WU01:FS00:0xa8:       CPUs: 4
07:01:43:WU01:FS00:0xa8:     Memory: 15.50GiB
07:01:43:WU01:FS00:0xa8:Free Memory: 14.33GiB
07:01:43:WU01:FS00:0xa8:    Threads: POSIX_THREADS
07:01:43:WU01:FS00:0xa8: OS Version: 5.3
07:01:43:WU01:FS00:0xa8:Has Battery: false
07:01:43:WU01:FS00:0xa8: On Battery: false
07:01:43:WU01:FS00:0xa8: UTC Offset: 1
07:01:43:WU01:FS00:0xa8:        PID: 1979
07:01:43:WU01:FS00:0xa8:        CWD: /var/lib/fahclient/work
07:01:43:WU01:FS00:0xa8:********************************************************************************
07:01:43:WU01:FS00:0xa8:Project: 18210 (Run 21210, Clone 0, Gen 31)
07:01:43:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
07:01:43:WU01:FS00:0xa8:Digital signatures verified
07:01:43:WU01:FS00:0xa8:Calling: mdrun -c frame31.gro -s frame31.tpr -x frame31.xtc -cpi state.cpt -cpt 15 -nt 2 -ntmpi 1
07:01:43:WU01:FS00:0xa8:Steps: first=3875000 total=4000000
07:01:44:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 66.170.111.50:80: Network is unreachable
07:01:44:WU03:FS02:Trying to send results to collection server
07:01:44:WU03:FS02:Connecting to 128.252.203.13:8080
07:01:44:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
07:01:45:ERROR:WU03:FS02:Exception: Failed to connect to 128.252.203.13:80: Network is unreachable
07:01:45:WU03:FS02:Sending unit results: id:03 state:SEND error:DUMPED project:16608 run:128 clone:1 gen:109 core:0x22 unit:0x000000010000006d000040e000000080
07:01:45:WU03:FS02:Connecting to 66.170.111.50:8080
07:01:45:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
07:01:46:WARNING:WU03:FS02:Exception: Failed to send results to work server: Failed to connect to 66.170.111.50:80: Network is unreachable
07:01:46:WU03:FS02:Trying to send results to collection server
07:01:46:WU03:FS02:Connecting to 128.252.203.13:8080
07:01:46:WARNING:WU03:FS02:WorkServer connection failed on port 8080 trying 80
07:01:47:ERROR:WU03:FS02:Exception: Failed to connect to 128.252.203.13:80: Network is unreachable
07:01:49:WU01:FS00:0xa8:Completed 102222 out of 125000 steps (81%)
07:02:43:Removing old file 'configs/config-20211117-130008.xml'
07:02:43:Saving configuration to /etc/fahclient/config.xml
07:02:43:<config>
07:02:43:  <!-- Network -->
07:02:43:  <proxy v=':8080'/>
07:02:43:
07:02:43:  <!-- Slot Control -->
07:02:43:  <power v='FULL'/>
07:02:43:
07:02:43:  <!-- User Information -->
07:02:43:  <passkey v='*****'/>
07:02:43:  <team v='51'/>
07:02:43:  <user v='philippe_roubach'/>
07:02:43:
07:02:43:  <!-- Folding Slots -->
07:02:43:  <slot id='0' type='CPU'/>
07:02:43:  <slot id='2' type='GPU'>
07:02:43:    <pci-bus v='1'/>
07:02:43:    <pci-slot v='0'/>
07:02:43:  </slot>
07:02:43:</config>
07:02:46:WU03:FS02:Sending unit results: id:03 state:SEND error:DUMPED project:16608 run:128 clone:1 gen:109 core:0x22 unit:0x000000010000006d000040e000000080
07:02:46:WU03:FS02:Connecting to 66.170.111.50:8080
07:02:46:WU03:FS02:Server responded WORK_ACK (400)
07:02:46:WU03:FS02:Cleaning up
07:05:10:WU01:FS00:0xa8:Completed 102500 out of 125000 steps (82%)
07:20:14:WU01:FS00:0xa8:Completed 103750 out of 125000 steps (83%)
07:36:09:WU01:FS00:0xa8:Completed 105000 out of 125000 steps (84%)
07:53:04:WU01:FS00:0xa8:Completed 106250 out of 125000 steps (85%)
08:08:05:WU01:FS00:0xa8:Completed 107500 out of 125000 steps (86%)
08:23:19:WU01:FS00:0xa8:Completed 108750 out of 125000 steps (87%)
08:38:25:WU01:FS00:0xa8:Completed 110000 out of 125000 steps (88%)
promeneur
Re: no more cuda computing
Post by promeneur »
ok
i deleted the nvidia slot
i restarted fahclient
then
no more problem. igpu (intel) and dgpu (nvidia) slots are well detected and came back.
Make sure you have access to the Internet when you start the client. If the client fails to download GPUs.txt at startup, all GPUs will be disabled until it can download it again.
promeneur
Post by promeneur »
toTOW wrote: If the client fails to download GPUs.txt at startup, all GPUs will be disabled until it can download it again.
This is not the case. The cpu slot is not disabled.
toTOW wrote:Make sure you have access to the Internet when you start the client.
The user has no access to settings to make sure internet access is activated when fahclient starts.
I assume we must modify the systemd fahclient service file according fahclient waits for the internet access for starting. It is too techie.
I think fah@home must supply such a service file.
promeneur
Post by promeneur »
In the fahclient service file, I found this:
[Unit]
Description=Folding@Home V7 Client
Documentation=https://foldingathome.org/support/faq/i ... des/linux/
After=syslog.target network-online.target remote-fs.target
Wants=network-online.target
I guess fahclient waits for the network is activated.
I conclude that the problem is not a network problem. No ?
The file is called GPUs.txt ... :roll:
promeneur wrote:In the fahclient service file, I found this:
[Unit]
It's not because network manager service is started that the link to Internet is operational ... it might wait for user actions (like login to a portal or something) or for the wireless network to be in range ...
