In the past, problems like this for me have been due to a work or assignment server running out of disk space. The server stats page shows some errors and warnings for the assignment servers, but the work servers I'm trying to reach look OK.
Any suggestions?
Here's the log file:
*********************** Log Started 2021-11-04T16:19:52Z ***********************
16:19:52:******************************* libFAH ********************************
16:19:52: Date: Oct 20 2020
16:19:52: Time: 13:36:55
16:19:52: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
16:19:52: Branch: master
16:19:52: Compiler: Visual C++ 2015
16:19:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:19:52: Platform: win32 10
16:19:52: Bits: 32
16:19:52: Mode: Release
16:19:52:****************************** FAHClient ******************************
16:19:52: Version: 7.6.21
16:19:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:19:52: Copyright: 2020 foldingathome.org
16:19:52: Homepage: https://foldingathome.org/
16:19:52: Time: 13:41:04
16:19:52: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
16:19:52: Bits: 32
16:19:52: Args: --open-web-control
16:19:52: Config: C:\ProgramData\FAHClient\config.xml
16:19:52:******************************** CBang ********************************
16:19:52: Time: 11:36:18
16:19:52: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
16:19:52: Bits: 32
16:19:52:******************************* System ********************************
16:19:52: CPU: Intel(R) Core(TM) i9-10940X CPU @ 3.30GHz
16:19:52: CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
16:19:52: CPUs: 28
16:19:52: Memory: 31.71GiB
16:19:52: Free Memory: 26.37GiB
16:19:52: Threads: WINDOWS_THREADS
16:19:52: OS Version: 6.2
16:19:52: Has Battery: false
16:19:52: On Battery: false
16:19:52: UTC Offset: -4
16:19:52: PID: 16056
16:19:52: CWD: C:\ProgramData\FAHClient
16:19:52: Win32 Service: false
16:19:52: OS: Windows 10 Enterprise
16:19:52: OS Arch: AMD64
16:19:52: GPUs: 1
16:19:52: GPU 0: Bus:101 Slot:0 Func:0 NVIDIA:7 TU104GL [Quadro RTX 5000]
16:19:52: CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:7.5 Driver:11.2
16:19:52:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:1.2 Driver:462.96
16:19:52:***********************************************************************
16:19:53:<config>
16:19:53: <!-- Network -->
16:19:53: <proxy v=':8080'/>
16:19:53:
16:19:53: <!-- User Information -->
16:19:53: <passkey v='*****'/>
16:19:53: <team v='169927'/>
16:19:53: <user v='MungSu'/>
16:19:53:
16:19:53: <!-- Folding Slots -->
16:19:53: <slot id='0' type='CPU'/>
16:19:53: <slot id='1' type='GPU'>
16:19:53: <pci-bus v='101'/>
16:19:53: <pci-slot v='0'/>
16:19:53: </slot>
16:19:53:</config>
16:19:53:Trying to access database...
16:19:53:Successfully acquired database lock
16:19:53:FS00:Initialized folding slot 00: cpu:26
16:19:53:FS01:Initialized folding slot 01: gpu:101:0 TU104GL [Quadro RTX 5000]
16:19:53:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:19:53:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:19:53:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:19:53:WU00:FS00:Connecting to 129.32.209.202:8080
16:19:53:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:19:53:WU01:FS01:Connecting to 207.53.233.146:8080
16:19:53:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:19:53:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:19:53:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:19:53:WU00:FS00:Trying to send results to collection server
16:19:53:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:19:53:WU00:FS00:Connecting to 129.32.209.205:8080
16:19:53:WU03:FS01:Assigned to work server 128.252.203.11
16:19:53:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 128.252.203.11
16:19:53:WU03:FS01:Connecting to 128.252.203.11:8080
16:19:53:WU02:FS00:Assigned to work server 129.32.209.204
16:19:53:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 129.32.209.204
16:19:53:WU02:FS00:Connecting to 129.32.209.204:8080
16:19:53:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:19:53:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:19:54:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:19:54:WU00:FS00:Trying to send results to collection server
16:19:54:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:19:54:WU00:FS00:Connecting to 129.32.209.205:8080
16:19:54:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:19:54:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:19:54:WU02:FS00:Assigned to work server 128.252.203.12
16:19:54:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 128.252.203.12
16:19:54:WU02:FS00:Connecting to 128.252.203.12:8080
16:19:55:4:127.0.0.1:New Web session
16:20:12:WU01:FS01:Upload 49.00%
16:20:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
16:20:12:WU01:FS01:Trying to send results to collection server
16:20:12:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:20:12:WU01:FS01:Connecting to 128.252.203.1:8080
16:20:12:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:20:12:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:20:12:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:20:12:WU01:FS01:Connecting to 207.53.233.146:8080
16:20:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:20:13:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:20:25:WU02:FS00:Downloading 8.34MiB
16:20:34:WU03:FS01:Downloading 26.52MiB
16:20:54:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:20:54:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:20:54:WU00:FS00:Connecting to 129.32.209.202:8080
16:20:54:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:20:54:WU00:FS00:Trying to send results to collection server
16:20:54:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:20:54:WU00:FS00:Connecting to 129.32.209.205:8080
16:20:54:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:21:12:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:21:12:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:21:12:WU01:FS01:Connecting to 207.53.233.146:8080
16:21:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:21:12:WU01:FS01:Trying to send results to collection server
16:21:12:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:21:12:WU01:FS01:Connecting to 128.252.203.1:8080
16:21:12:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:21:25:WU02:FS00:Download 0.01%
16:21:25:ERROR:WU02:FS00:Exception: Transfer failed
16:21:25:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:21:25:WU02:FS00:Assigned to work server 128.252.203.12
16:21:25:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 128.252.203.12
16:21:25:WU02:FS00:Connecting to 128.252.203.12:8080
16:21:34:ERROR:WU03:FS01:Exception: Transfer failed
16:21:34:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:21:35:WU03:FS01:Assigned to work server 34.72.228.44
16:21:35:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 34.72.228.44
16:21:35:WU03:FS01:Connecting to 34.72.228.44:8080
16:21:56:WU02:FS00:Downloading 8.34MiB
16:22:05:WU03:FS01:Downloading 3.25MiB
16:22:31:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:22:31:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:22:31:WU00:FS00:Connecting to 129.32.209.202:8080
16:22:31:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:22:31:WU00:FS00:Trying to send results to collection server
16:22:31:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:22:31:WU00:FS00:Connecting to 129.32.209.205:8080
16:22:31:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:22:49:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:22:49:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:22:49:WU01:FS01:Connecting to 207.53.233.146:8080
16:22:49:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:22:49:WU01:FS01:Trying to send results to collection server
16:22:49:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:22:50:WU01:FS01:Connecting to 128.252.203.1:8080
16:22:50:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:22:56:WU02:FS00:Download 0.01%
16:22:56:ERROR:WU02:FS00:Exception: Transfer failed
16:23:02:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:23:02:WU02:FS00:Assigned to work server 129.32.209.204
16:23:02:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 129.32.209.204
16:23:02:WU02:FS00:Connecting to 129.32.209.204:8080
16:23:03:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:23:05:WU03:FS01:Download 0.02%
16:23:05:ERROR:WU03:FS01:Exception: Transfer failed
16:23:06:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:23:06:WU03:FS01:Assigned to work server 129.32.209.202
16:23:06:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 129.32.209.202
16:23:06:WU03:FS01:Connecting to 129.32.209.202:8080
16:23:06:ERROR:WU03:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:24:43:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:24:43:WU03:FS01:Assigned to work server 129.32.209.202
16:24:43:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 129.32.209.202
16:24:43:WU03:FS01:Connecting to 129.32.209.202:8080
16:24:44:ERROR:WU03:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:25:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:25:08:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:25:08:WU00:FS00:Connecting to 129.32.209.202:8080
16:25:08:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:25:08:WU00:FS00:Trying to send results to collection server
16:25:08:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:25:08:WU00:FS00:Connecting to 129.32.209.205:8080
16:25:08:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:25:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:25:27:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:25:27:WU01:FS01:Connecting to 207.53.233.146:8080
16:25:27:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:25:27:WU01:FS01:Trying to send results to collection server
16:25:27:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:25:27:WU01:FS01:Connecting to 128.252.203.1:8080
16:25:27:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:25:39:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:25:40:WU02:FS00:Assigned to work server 129.32.209.205
16:25:40:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 129.32.209.205
16:25:40:WU02:FS00:Connecting to 129.32.209.205:8080
16:25:40:ERROR:WU02:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:27:20:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:27:27:WU03:FS01:Assigned to work server 128.252.203.11
16:27:28:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 128.252.203.11
16:27:28:WU03:FS01:Connecting to 128.252.203.11:8080
16:28:09:WU03:FS01:Downloading 26.52MiB
16:29:09:ERROR:WU03:FS01:Exception: Transfer failed
16:29:22:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:29:22:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:29:22:WU00:FS00:Connecting to 129.32.209.202:8080
16:29:22:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:29:22:WU00:FS00:Trying to send results to collection server
16:29:22:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:29:22:WU00:FS00:Connecting to 129.32.209.205:8080
16:29:22:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:29:41:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:29:41:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:29:41:WU01:FS01:Connecting to 207.53.233.146:8080
16:29:41:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:29:41:WU01:FS01:Trying to send results to collection server
16:29:41:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:29:41:WU01:FS01:Connecting to 128.252.203.1:8080
16:29:41:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:29:54:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:29:54:WU02:FS00:Assigned to work server 128.252.203.11
16:29:54:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 128.252.203.11
16:29:54:WU02:FS00:Connecting to 128.252.203.11:8080
16:30:25:WU02:FS00:Downloading 8.34MiB
16:31:25:WU02:FS00:Download 0.01%
16:31:25:ERROR:WU02:FS00:Exception: Transfer failed
16:31:34:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:31:34:WU03:FS01:Assigned to work server 207.53.233.146
16:31:42:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 207.53.233.146
16:31:42:WU03:FS01:Connecting to 207.53.233.146:8080
16:32:12:WU03:FS01:Downloading 2.47MiB
16:33:12:WU03:FS01:Download 0.03%
16:33:13:ERROR:WU03:FS01:Exception: Transfer failed
16:36:13:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16978 run:134 clone:51 gen:80 core:0xa8 unit:0x00000033000000500000425200000086
16:36:13:WU00:FS00:Uploading 2.77MiB to 129.32.209.202
16:36:13:WU00:FS00:Connecting to 129.32.209.202:8080
16:36:13:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_FORBIDDEN
16:36:13:WU00:FS00:Trying to send results to collection server
16:36:13:WU00:FS00:Uploading 2.77MiB to 129.32.209.205
16:36:13:WU00:FS00:Connecting to 129.32.209.205:8080
16:36:14:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:36:32:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:36 clone:88 gen:416 core:0x22 unit:0x00000058000001a00000458c00000024
16:36:32:WU01:FS01:Uploading 8.42MiB to 207.53.233.146
16:36:32:WU01:FS01:Connecting to 207.53.233.146:8080
16:36:45:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:36:45:WU02:FS00:Assigned to work server 128.252.203.2
16:36:45:WU02:FS00:Requesting new work unit for slot 00: cpu:26 from 128.252.203.2
16:36:45:WU02:FS00:Connecting to 128.252.203.2:8080
16:36:46:ERROR:WU02:FS00:Exception: Server did not assign work unit
16:36:51:WU01:FS01:Upload 100.00%
16:36:51:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
16:36:51:WU01:FS01:Trying to send results to collection server
16:36:51:WU01:FS01:Uploading 8.42MiB to 128.252.203.1
16:36:51:WU01:FS01:Connecting to 128.252.203.1:8080
16:36:51:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_FORBIDDEN
16:38:26:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:38:26:WU03:FS01:Assigned to work server 128.252.203.11
16:38:33:WU03:FS01:Requesting new work unit for slot 01: gpu:101:0 TU104GL [Quadro RTX 5000] from 128.252.203.11
16:38:33:WU03:FS01:Connecting to 128.252.203.11:8080
16:39:14:WU03:FS01:Downloading 26.51MiB
