GPU disabled
felix920506
GPU disabled
Post by felix920506 »
I have a Radeon RX Vega 64 GPU
it shows that my gpu is disabled in FAHControl
Driver Version is 21.6.1
Power Slider set to full
Any way to enable this GPU?
aetch
Re: GPU disabled
Post by aetch »
Can you post your log.
Re: GPU disabled
Here is a Link to how to post a log, we want the first 200 lines, where it shows your configuration
viewtopic.php?f=24&t=26036
We don't know enough about your configuration:
MacOS does not support GPUs, nor does 32 bit Windows
Linux does, but needs proprietary drivers with optional installs
64 bit Windows does with drivers right from the vendor, not MS.
And we don't know what you run.
felix920506
Re: GPU disabled
OS is windows 10 64 bit
driver is from AMD website
log below
*********************** Log Started 2021-09-08T04:54:21Z ***********************
04:54:21:******************************* libFAH ********************************
04:54:21:           Date: Oct 20 2020
04:54:21:           Time: 13:36:55
04:54:21:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
04:54:21:         Branch: master
04:54:21:       Compiler: Visual C++ 2015
04:54:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:54:21:       Platform: win32 10
04:54:21:           Bits: 32
04:54:21:           Mode: Release
04:54:21:****************************** FAHClient ******************************
04:54:21:        Version: 7.6.21
04:54:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:54:21:      Copyright: 2020 foldingathome.org
04:54:21:       Homepage: https://foldingathome.org/
04:54:21:           Time: 13:41:04
04:54:21:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
04:54:21:           Bits: 32
04:54:21:         Config: C:\ProgramData\FAHClient\config.xml
04:54:21:******************************** CBang ********************************
04:54:21:           Time: 11:36:18
04:54:21:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
04:54:21:           Bits: 32
04:54:21:******************************* System ********************************
04:54:21:            CPU: AMD Ryzen 5 5600X 6-Core Processor
04:54:21:         CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
04:54:21:           CPUs: 12
04:54:21:         Memory: 31.92GiB
04:54:21:    Free Memory: 27.25GiB
04:54:21:        Threads: WINDOWS_THREADS
04:54:21:     OS Version: 6.2
04:54:21:    Has Battery: false
04:54:21:     On Battery: false
04:54:21:     UTC Offset: 8
04:54:21:            PID: 17092
04:54:21:            CWD: C:\ProgramData\FAHClient
04:54:21:  Win32 Service: false
04:54:21:             OS: Windows 10 Enterprise
04:54:21:        OS Arch: AMD64
04:54:21:           GPUs: 1
04:54:21:          GPU 0: Bus:9 Slot:0 Func:0 AMD:1
04:54:21:           CUDA: Not detected: cuInit() returned 999
04:54:21:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3276.6
04:54:21:***********************************************************************
04:54:21:<config>
04:54:21:  <!-- Slot Control -->
04:54:21:  <power v='FULL'/>
04:54:21:
04:54:21:  <!-- User Information -->
04:54:21:  <passkey v='*****'/>
04:54:21:  <user v='felix920506'/>
04:54:21:
04:54:21:  <!-- Folding Slots -->
04:54:21:  <slot id='0' type='CPU'/>
04:54:21:  <slot id='1' type='GPU'>
04:54:21:    <pci-bus v='9'/>
04:54:21:    <pci-slot v='0'/>
04:54:21:  </slot>
04:54:21:</config>
04:54:21:Trying to access database...
04:54:21:Successfully acquired database lock
04:54:21:FS00:Initialized folding slot 00: cpu:11
04:54:21:WARNING:FS01:Disabling beta GPU slot 01: gpu:9:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
04:54:21:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:21:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:21:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:21:ERROR:WU00:FS00:Exception: Could not get IP address for assign4.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:21:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
04:54:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign4.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:54:22:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
04:55:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:55:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:55:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:55:22:ERROR:WU00:FS00:Exception: Could not get IP address for assign4.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:55:22:ERROR:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
04:57:11:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:57:23:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: µLªkÃgO³o¥x¥D¾÷¡C
04:57:23:WU00:FS00:Connecting to assign3.foldingathome.org:80
04:57:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
04:57:25:ERROR:Receive error: 10053: #Úò«¨;_
„ßÔ-b
04:57:25:WU00:FS00:Assigned to work server 129.32.209.205
04:57:25:WU00:FS00:Requesting new work unit for slot 00: cpu:11 from 129.32.209.205
04:57:25:WU00:FS00:Connecting to 129.32.209.205:8080
04:57:26:WU00:FS00:Downloading 1.47MiB
04:57:28:WU00:FS00:Download complete
04:57:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:35 clone:157 gen:192 core:0xa8 unit:0x0000009d000000c00000423f00000023
04:57:28:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
04:57:28:WU00:FS00:Connecting to cores.foldingathome.org:80
04:57:28:WU00:FS00:FahCore a8: Downloading 7.72MiB
04:57:34:WU00:FS00:FahCore a8: 55.03%
04:57:37:WU00:FS00:FahCore a8: Download complete
04:57:38:WU00:FS00:Valid core signature
04:57:38:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
04:57:38:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
04:57:38:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
04:57:38:WU00:FS00:Starting
04:57:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 17092 -checkpoint 15 -np 11
04:57:38:WU00:FS00:Started FahCore on PID 12844
04:57:38:WU00:FS00:Core PID:9976
04:57:38:WU00:FS00:FahCore 0xa8 started
04:57:38:WU00:FS00:0xa8:*********************** Log Started 2021-09-08T04:57:38Z ***********************
04:57:38:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
04:57:38:WU00:FS00:0xa8:       Core: Gromacs
04:57:38:WU00:FS00:0xa8:       Type: 0xa8
04:57:38:WU00:FS00:0xa8:    Version: 0.0.12
04:57:38:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:57:38:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
04:57:38:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
04:57:38:WU00:FS00:0xa8:       Date: Jan 16 2021
04:57:38:WU00:FS00:0xa8:       Time: 12:29:40
04:57:38:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
04:57:38:WU00:FS00:0xa8:     Branch: master
04:57:38:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
04:57:38:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:57:38:WU00:FS00:0xa8:   Platform: win32 10
04:57:38:WU00:FS00:0xa8:       Bits: 64
04:57:38:WU00:FS00:0xa8:       Mode: Release
04:57:38:WU00:FS00:0xa8:       SIMD: avx2_256
04:57:38:WU00:FS00:0xa8:     OpenMP: ON
04:57:38:WU00:FS00:0xa8:       CUDA: OFF
04:57:38:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 12844 -checkpoint 15 -np
04:57:38:WU00:FS00:0xa8:             11
04:57:38:WU00:FS00:0xa8:************************************ libFAH ************************************
04:57:38:WU00:FS00:0xa8:       Time: 11:24:13
04:57:38:WU00:FS00:0xa8:************************************ CBang *************************************
04:57:38:WU00:FS00:0xa8:       Time: 11:23:53
04:57:38:WU00:FS00:0xa8:************************************ System ************************************
04:57:38:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 5600X 6-Core Processor
04:57:38:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
04:57:38:WU00:FS00:0xa8:       CPUs: 12
04:57:38:WU00:FS00:0xa8:     Memory: 31.92GiB
04:57:38:WU00:FS00:0xa8:Free Memory: 26.04GiB
04:57:38:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
04:57:38:WU00:FS00:0xa8: OS Version: 6.2
04:57:38:WU00:FS00:0xa8:Has Battery: false
04:57:38:WU00:FS00:0xa8: On Battery: false
04:57:38:WU00:FS00:0xa8: UTC Offset: 8
04:57:38:WU00:FS00:0xa8:        PID: 9976
04:57:38:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
04:57:38:WU00:FS00:0xa8:********************************************************************************
04:57:38:WU00:FS00:0xa8:Project: 16959 (Run 35, Clone 157, Gen 192)
04:57:38:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
04:57:38:WU00:FS00:0xa8:Reading tar file core.xml
04:57:38:WU00:FS00:0xa8:Reading tar file frame192.tpr
04:57:38:WU00:FS00:0xa8:Digital signatures verified
04:57:38:WU00:FS00:0xa8:Calling: mdrun -c frame192.gro -s frame192.tpr -x frame192.xtc -cpt 15 -nt 11 -ntmpi 1
04:57:38:WU00:FS00:0xa8:Steps: first=480000000 total=482500000
04:57:38:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
05:00:22:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
05:02:44:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
05:04:31:Saving configuration to config.xml
05:04:31:<config>
05:04:31:  <!-- Network -->
05:04:31:  <proxy v=':8080'/>
05:04:31:
05:04:31:  <!-- Slot Control -->
05:04:31:  <power v='FULL'/>
05:04:31:
05:04:31:  <!-- User Information -->
05:04:31:  <passkey v='*****'/>
05:04:31:  <user v='felix920506'/>
05:04:31:
05:04:31:  <!-- Folding Slots -->
05:04:31:  <slot id='0' type='CPU'/>
05:04:31:  <slot id='1' type='GPU'>
05:04:31:    <pci-bus v='9'/>
05:04:31:    <pci-slot v='0'/>
05:04:31:  </slot>
05:04:31:</config>
05:05:07:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
05:07:39:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
05:09:57:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
05:12:13:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
05:14:32:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
05:14:58:FS00:Shutting core down
05:14:58:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 9976
05:14:58:WU00:FS00:0xa8:Exiting, please wait. . .
05:14:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:14:59:WU00:FS00:Starting
05:14:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 17092 -checkpoint 15 -np 11
05:14:59:WU00:FS00:Started FahCore on PID 4568
05:14:59:WU00:FS00:Core PID:18208
05:14:59:WU00:FS00:FahCore 0xa8 started
05:14:59:WU00:FS00:0xa8:*********************** Log Started 2021-09-08T05:14:59Z ***********************
05:14:59:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
05:14:59:WU00:FS00:0xa8:       Core: Gromacs
05:14:59:WU00:FS00:0xa8:       Type: 0xa8
05:14:59:WU00:FS00:0xa8:    Version: 0.0.12
05:14:59:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:14:59:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
05:14:59:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
05:14:59:WU00:FS00:0xa8:       Date: Jan 16 2021
05:14:59:WU00:FS00:0xa8:       Time: 12:29:40
05:14:59:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:14:59:WU00:FS00:0xa8:     Branch: master
05:14:59:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
05:14:59:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:14:59:WU00:FS00:0xa8:   Platform: win32 10
05:14:59:WU00:FS00:0xa8:       Bits: 64
05:14:59:WU00:FS00:0xa8:       Mode: Release
05:14:59:WU00:FS00:0xa8:       SIMD: avx2_256
05:14:59:WU00:FS00:0xa8:     OpenMP: ON
05:14:59:WU00:FS00:0xa8:       CUDA: OFF
05:14:59:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4568 -checkpoint 15 -np
05:14:59:WU00:FS00:0xa8:             11
05:14:59:WU00:FS00:0xa8:************************************ libFAH ************************************
05:14:59:WU00:FS00:0xa8:       Time: 11:24:13
05:14:59:WU00:FS00:0xa8:************************************ CBang *************************************
05:14:59:WU00:FS00:0xa8:       Time: 11:23:53
05:14:59:WU00:FS00:0xa8:************************************ System ************************************
05:14:59:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 5600X 6-Core Processor
05:14:59:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
05:14:59:WU00:FS00:0xa8:       CPUs: 12
05:14:59:WU00:FS00:0xa8:     Memory: 31.92GiB
05:14:59:WU00:FS00:0xa8:Free Memory: 24.86GiB
05:14:59:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
05:14:59:WU00:FS00:0xa8: OS Version: 6.2
05:14:59:WU00:FS00:0xa8:Has Battery: false
05:14:59:WU00:FS00:0xa8: On Battery: false
05:14:59:WU00:FS00:0xa8: UTC Offset: 8
05:14:59:WU00:FS00:0xa8:        PID: 18208
05:14:59:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
05:14:59:WU00:FS00:0xa8:********************************************************************************
05:14:59:WU00:FS00:0xa8:Project: 16959 (Run 35, Clone 157, Gen 192)
05:14:59:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
05:14:59:WU00:FS00:0xa8:Digital signatures verified
05:14:59:WU00:FS00:0xa8:Calling: mdrun -c frame192.gro -s frame192.tpr -x frame192.xtc -cpi state.cpt -cpt 15 -nt 11 -ntmpi 1
05:14:59:WU00:FS00:0xa8:Steps: first=480000000 total=482500000
05:14:59:WU00:FS00:0xa8:Completed 179352 out of 2500000 steps (7%)
05:15:42:Saving configuration to config.xml
05:15:42:<config>
05:15:42:  <!-- Network -->
05:15:42:  <proxy v=':8080'/>
05:15:42:
05:15:42:  <!-- Slot Control -->
05:15:42:  <power v='full'/>
05:15:42:
05:15:42:  <!-- User Information -->
05:15:42:  <passkey v='*****'/>
05:15:42:  <user v='felix920506'/>
05:15:42:
05:15:42:  <!-- Folding Slots -->
05:15:42:  <slot id='0' type='CPU'/>
05:15:42:  <slot id='1' type='GPU'>
05:15:42:    <pci-bus v='9'/>
05:15:42:    <pci-slot v='0'/>
05:15:42:  </slot>
05:15:42:</config>
05:17:00:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
05:19:25:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
05:21:48:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
05:24:11:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
05:26:36:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
05:29:00:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
05:31:23:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
05:33:48:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
05:36:20:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
05:38:45:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
05:41:08:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
05:43:31:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
05:45:55:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
05:48:19:WU00:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
05:50:42:WU00:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
05:53:04:WU00:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
05:55:25:WU00:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
05:57:46:WU00:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
06:00:08:WU00:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
06:02:30:WU00:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
06:04:51:WU00:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
06:07:12:WU00:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
06:09:33:WU00:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
06:11:54:WU00:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
06:14:15:WU00:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
06:16:36:WU00:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
06:18:57:WU00:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
06:21:19:WU00:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
06:23:40:WU00:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
06:26:02:WU00:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
06:28:23:WU00:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
06:30:45:WU00:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
06:33:07:WU00:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
06:35:29:WU00:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
06:37:50:WU00:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
06:40:12:WU00:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
06:42:34:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
06:44:55:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
06:47:17:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
06:49:38:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
06:52:00:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
06:54:21:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
06:56:43:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
06:59:05:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
07:01:27:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
07:03:49:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
07:06:10:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
07:08:32:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
07:10:54:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
07:13:16:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
07:15:39:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
07:18:01:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
07:20:23:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
07:22:45:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
07:25:07:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
07:27:29:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
07:29:51:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
07:32:14:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
07:34:36:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
07:36:58:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
07:39:20:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
07:41:42:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
07:44:04:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
07:46:27:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
07:48:49:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
07:51:11:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
07:53:34:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
07:55:56:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
07:58:18:WU00:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
08:00:40:WU00:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
08:03:03:WU00:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
08:05:25:WU00:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
08:07:47:WU00:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
08:10:09:WU00:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
08:12:31:WU00:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
08:14:53:WU00:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
08:17:15:WU00:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
08:19:37:WU00:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
08:21:59:WU00:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
08:24:21:WU00:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
08:26:43:WU00:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
08:29:05:WU00:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
08:31:27:WU00:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
08:33:49:WU00:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
08:36:11:WU00:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
08:38:33:WU00:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
08:40:55:WU00:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
08:43:17:WU00:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
08:45:40:WU00:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
08:48:02:WU00:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
08:50:23:WU00:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
08:52:45:WU00:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
08:52:46:WU01:FS00:Connecting to assign1.foldingathome.org:80
08:52:46:WU01:FS00:Assigned to work server 129.32.209.205
08:52:46:WU01:FS00:Requesting new work unit for slot 00: cpu:11 from 129.32.209.205
08:52:46:WU01:FS00:Connecting to 129.32.209.205:8080
08:52:47:WU01:FS00:Downloading 1.47MiB
08:52:49:WU01:FS00:Download complete
08:52:49:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16959 run:24 clone:599 gen:196 core:0xa8 unit:0x00000257000000c40000423f00000018
08:55:07:WU00:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
08:55:08:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
08:55:08:WU00:FS00:0xa8:Saving result file frame192.gro
08:55:08:WU00:FS00:0xa8:Saving result file frame192.xtc
08:55:08:WU00:FS00:0xa8:Saving result file md.log
08:55:08:WU00:FS00:0xa8:Saving result file science.log
08:55:08:WU00:FS00:0xa8:Saving result file state.cpt
08:55:08:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
08:55:08:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:55:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16959 run:35 clone:157 gen:192 core:0xa8 unit:0x0000009d000000c00000423f00000023
08:55:08:WU00:FS00:Uploading 5.13MiB to 129.32.209.205
08:55:08:WU00:FS00:Connecting to 129.32.209.205:8080
08:55:08:WU01:FS00:Starting
08:55:08:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 17092 -checkpoint 15 -np 11
08:55:08:WU01:FS00:Started FahCore on PID 8944
08:55:08:WU01:FS00:Core PID:18392
08:55:08:WU01:FS00:FahCore 0xa8 started
08:55:09:WU01:FS00:0xa8:*********************** Log Started 2021-09-08T08:55:08Z ***********************
08:55:09:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
08:55:09:WU01:FS00:0xa8:       Core: Gromacs
08:55:09:WU01:FS00:0xa8:       Type: 0xa8
08:55:09:WU01:FS00:0xa8:    Version: 0.0.12
08:55:09:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:55:09:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
08:55:09:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
08:55:09:WU01:FS00:0xa8:       Date: Jan 16 2021
08:55:09:WU01:FS00:0xa8:       Time: 12:29:40
08:55:09:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
08:55:09:WU01:FS00:0xa8:     Branch: master
08:55:09:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
08:55:09:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:55:09:WU01:FS00:0xa8:   Platform: win32 10
08:55:09:WU01:FS00:0xa8:       Bits: 64
08:55:09:WU01:FS00:0xa8:       Mode: Release
08:55:09:WU01:FS00:0xa8:       SIMD: avx2_256
08:55:09:WU01:FS00:0xa8:     OpenMP: ON
08:55:09:WU01:FS00:0xa8:       CUDA: OFF
08:55:09:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8944 -checkpoint 15 -np
08:55:09:WU01:FS00:0xa8:             11
08:55:09:WU01:FS00:0xa8:************************************ libFAH ************************************
08:55:09:WU01:FS00:0xa8:       Time: 11:24:13
08:55:09:WU01:FS00:0xa8:************************************ CBang *************************************
08:55:09:WU01:FS00:0xa8:       Time: 11:23:53
08:55:09:WU01:FS00:0xa8:************************************ System ************************************
08:55:09:WU01:FS00:0xa8:        CPU: AMD Ryzen 5 5600X 6-Core Processor
08:55:09:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
08:55:09:WU01:FS00:0xa8:       CPUs: 12
08:55:09:WU01:FS00:0xa8:     Memory: 31.92GiB
08:55:09:WU01:FS00:0xa8:Free Memory: 24.63GiB
08:55:09:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
08:55:09:WU01:FS00:0xa8: OS Version: 6.2
08:55:09:WU01:FS00:0xa8:Has Battery: false
08:55:09:WU01:FS00:0xa8: On Battery: false
08:55:09:WU01:FS00:0xa8: UTC Offset: 8
08:55:09:WU01:FS00:0xa8:        PID: 18392
08:55:09:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
08:55:09:WU01:FS00:0xa8:********************************************************************************
08:55:09:WU01:FS00:0xa8:Project: 16959 (Run 24, Clone 599, Gen 196)
08:55:09:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
08:55:09:WU01:FS00:0xa8:Reading tar file core.xml
08:55:09:WU01:FS00:0xa8:Reading tar file frame196.tpr
08:55:09:WU01:FS00:0xa8:Digital signatures verified
08:55:09:WU01:FS00:0xa8:Calling: mdrun -c frame196.gro -s frame196.tpr -x frame196.xtc -cpt 15 -nt 11 -ntmpi 1
08:55:09:WU01:FS00:0xa8:Steps: first=490000000 total=492500000
08:55:09:WU01:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
08:55:14:WU00:FS00:Upload 9.74%
08:55:20:WU00:FS00:Upload 40.18%
08:55:26:WU00:FS00:Upload 74.26%
08:55:30:WU00:FS00:Upload complete
08:55:31:WU00:FS00:Server responded WORK_ACK (400)
08:55:31:WU00:FS00:Final credit estimate, 39850.00 points
08:55:31:WU00:FS00:Cleaning up
08:57:20:WU01:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
08:59:32:WU01:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
09:01:45:WU01:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
09:03:56:WU01:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
09:06:08:WU01:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
09:08:20:WU01:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
09:10:32:WU01:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
09:12:44:WU01:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
09:14:55:WU01:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
09:17:07:WU01:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
09:19:19:WU01:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
09:21:32:WU01:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
09:23:44:WU01:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
09:25:55:WU01:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
09:28:07:WU01:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
09:30:19:WU01:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
09:32:31:WU01:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
09:34:43:WU01:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
09:36:54:WU01:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
09:39:06:WU01:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
09:41:18:WU01:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
09:43:29:WU01:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
09:45:41:WU01:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
09:47:53:WU01:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
09:50:05:WU01:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
09:52:17:WU01:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
09:54:28:WU01:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
09:56:40:WU01:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
09:58:52:WU01:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
10:01:04:WU01:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
10:03:16:WU01:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
10:05:27:WU01:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
10:07:39:WU01:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
10:09:51:WU01:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
10:12:03:WU01:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
10:14:14:WU01:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
10:16:27:WU01:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
10:18:38:WU01:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
10:20:50:WU01:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
10:23:01:WU01:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
10:25:13:WU01:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
10:27:25:WU01:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
10:29:36:WU01:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
10:31:48:WU01:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
10:33:59:WU01:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
10:36:10:WU01:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
10:38:22:WU01:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
10:40:33:WU01:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
10:42:44:WU01:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
10:44:56:WU01:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
10:47:07:WU01:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
10:49:18:WU01:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
10:51:30:WU01:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
10:53:44:WU01:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
******************************* Date: 2021-09-08 *******************************
10:56:13:WU01:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
10:58:41:WU01:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
11:01:12:WU01:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
11:03:41:WU01:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
11:06:09:WU01:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
11:08:36:WU01:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
11:11:04:WU01:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
11:13:31:WU01:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
11:15:58:WU01:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
11:18:28:WU01:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
11:20:58:WU01:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
11:23:28:WU01:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
11:25:58:WU01:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
11:28:26:WU01:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
11:30:53:WU01:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
11:33:20:WU01:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
11:35:48:WU01:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
11:38:09:WU01:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
11:40:21:WU01:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
11:42:32:WU01:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
11:44:43:WU01:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
11:46:54:WU01:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
11:49:06:WU01:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
11:51:17:WU01:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
11:53:28:WU01:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
11:55:39:WU01:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
11:57:50:WU01:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
12:00:01:WU01:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
12:02:13:WU01:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
12:04:24:WU01:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
12:06:35:WU01:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
12:08:46:WU01:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
12:10:57:WU01:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
12:13:08:WU01:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
12:15:20:WU01:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
12:17:31:WU01:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
12:19:42:WU01:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
12:21:53:WU01:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
12:24:05:WU01:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
12:26:18:WU01:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
12:28:31:WU01:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
12:30:44:WU01:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
12:32:56:WU01:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
12:35:09:WU01:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
12:37:22:WU01:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
12:37:23:WU00:FS00:Connecting to assign1.foldingathome.org:80
12:37:24:WU00:FS00:Assigned to work server 129.32.209.205
12:37:24:WU00:FS00:Requesting new work unit for slot 00: cpu:11 from 129.32.209.205
12:37:24:WU00:FS00:Connecting to 129.32.209.205:8080
12:37:24:WU00:FS00:Downloading 1.49MiB
12:37:26:WU00:FS00:Download complete
12:37:26:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16969 run:11 clone:103 gen:171 core:0xa8 unit:0x00000067000000ab000042490000000b
12:39:35:WU01:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
12:39:35:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
12:39:35:WU01:FS00:0xa8:Saving result file frame196.gro
12:39:35:WU01:FS00:0xa8:Saving result file frame196.xtc
12:39:35:WU01:FS00:0xa8:Saving result file md.log
12:39:35:WU01:FS00:0xa8:Saving result file science.log
12:39:35:WU01:FS00:0xa8:Saving result file state.cpt
12:39:35:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
12:39:36:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:39:36:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16959 run:24 clone:599 gen:196 core:0xa8 unit:0x00000257000000c40000423f00000018
12:39:36:WU01:FS00:Uploading 5.12MiB to 129.32.209.205
12:39:36:WU01:FS00:Connecting to 129.32.209.205:8080
12:39:36:WU00:FS00:Starting
12:39:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 17092 -checkpoint 15 -np 11
12:39:36:WU00:FS00:Started FahCore on PID 16172
12:39:36:WU00:FS00:Core PID:5016
12:39:36:WU00:FS00:FahCore 0xa8 started
12:39:36:WU00:FS00:0xa8:*********************** Log Started 2021-09-08T12:39:36Z ***********************
12:39:36:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
12:39:36:WU00:FS00:0xa8:       Core: Gromacs
12:39:36:WU00:FS00:0xa8:       Type: 0xa8
12:39:36:WU00:FS00:0xa8:    Version: 0.0.12
12:39:36:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:39:36:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
12:39:36:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
12:39:36:WU00:FS00:0xa8:       Date: Jan 16 2021
12:39:36:WU00:FS00:0xa8:       Time: 12:29:40
12:39:36:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
12:39:36:WU00:FS00:0xa8:     Branch: master
12:39:36:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
12:39:36:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:39:36:WU00:FS00:0xa8:   Platform: win32 10
12:39:36:WU00:FS00:0xa8:       Bits: 64
12:39:36:WU00:FS00:0xa8:       Mode: Release
12:39:36:WU00:FS00:0xa8:       SIMD: avx2_256
12:39:36:WU00:FS00:0xa8:     OpenMP: ON
12:39:36:WU00:FS00:0xa8:       CUDA: OFF
12:39:36:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16172 -checkpoint 15 -np
12:39:36:WU00:FS00:0xa8:             11
12:39:36:WU00:FS00:0xa8:************************************ libFAH ************************************
12:39:36:WU00:FS00:0xa8:       Time: 11:24:13
12:39:36:WU00:FS00:0xa8:************************************ CBang *************************************
12:39:36:WU00:FS00:0xa8:       Time: 11:23:53
12:39:36:WU00:FS00:0xa8:************************************ System ************************************
12:39:36:WU00:FS00:0xa8:        CPU: AMD Ryzen 5 5600X 6-Core Processor
12:39:36:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
12:39:36:WU00:FS00:0xa8:       CPUs: 12
12:39:36:WU00:FS00:0xa8:     Memory: 31.92GiB
12:39:36:WU00:FS00:0xa8:Free Memory: 24.63GiB
12:39:36:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
12:39:36:WU00:FS00:0xa8: OS Version: 6.2
12:39:36:WU00:FS00:0xa8:Has Battery: false
12:39:36:WU00:FS00:0xa8: On Battery: false
12:39:36:WU00:FS00:0xa8: UTC Offset: 8
12:39:36:WU00:FS00:0xa8:        PID: 5016
12:39:36:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
12:39:36:WU00:FS00:0xa8:********************************************************************************
12:39:36:WU00:FS00:0xa8:Project: 16969 (Run 11, Clone 103, Gen 171)
12:39:36:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
12:39:36:WU00:FS00:0xa8:Reading tar file core.xml
12:39:36:WU00:FS00:0xa8:Reading tar file frame171.tpr
12:39:36:WU00:FS00:0xa8:Digital signatures verified
12:39:36:WU00:FS00:0xa8:Calling: mdrun -c frame171.gro -s frame171.tpr -x frame171.xtc -cpt 15 -nt 11 -ntmpi 1
12:39:36:WU00:FS00:0xa8:Steps: first=427500000 total=430000000
12:39:36:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
12:39:42:WU01:FS00:Upload 10.99%
12:39:48:WU01:FS00:Upload 42.72%
12:39:54:WU01:FS00:Upload 79.34%
12:39:58:WU01:FS00:Upload complete
12:39:58:WU01:FS00:Server responded WORK_ACK (400)
12:39:58:WU01:FS00:Final credit estimate, 40797.00 points
12:39:58:WU01:FS00:Cleaning up
12:41:49:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
12:44:02:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
12:46:15:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
12:48:28:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
12:50:40:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
12:52:53:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
12:55:06:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
12:57:19:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
12:59:32:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
13:01:45:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
13:03:58:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
13:06:11:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
13:08:23:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
13:10:36:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
13:12:49:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
13:15:01:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
13:17:14:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
13:19:27:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
13:21:39:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
13:23:51:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
13:26:04:WU00:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
13:28:17:WU00:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
13:30:29:WU00:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
13:32:42:WU00:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
13:34:55:WU00:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
13:37:07:WU00:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
13:39:20:WU00:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
13:41:33:WU00:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
13:43:46:WU00:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
13:45:58:WU00:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
13:48:11:WU00:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
13:50:24:WU00:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
13:52:37:WU00:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
13:54:49:WU00:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
13:57:02:WU00:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
13:59:15:WU00:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
14:01:28:WU00:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
14:03:41:WU00:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
14:05:54:WU00:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
14:08:06:WU00:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
14:10:19:WU00:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
14:12:32:WU00:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
14:14:45:WU00:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
14:16:58:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
14:19:10:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
14:21:23:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
14:23:36:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
14:25:49:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
14:28:02:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
14:30:14:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
14:32:27:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
14:34:39:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
14:36:52:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
14:39:04:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
14:41:17:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
14:43:30:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
14:45:42:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
14:47:55:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
14:50:06:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
14:52:17:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
14:54:32:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
14:56:43:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
14:58:54:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
15:01:05:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
15:03:16:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
15:05:27:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
15:07:37:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
15:09:48:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
15:11:59:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
15:14:09:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
15:16:20:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
15:18:31:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
15:20:42:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
15:23:08:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
15:25:28:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
Re: GPU disabled
Given the network connection errors shown in the log it is possible that your client has not downloaded a valid copy of the current GPUs.txt file used to identify a GPU. That is generally done the first time the client starts up after being installed.
The other possibility is that your Vega 64 has a PCI device ID that is not already in the GPUs.txt file. This topic - viewtopic.php?f=83&t=26208#p262894 - gives some methods of getting that device ID to provide to us for adding to the file.
aetch
Re: GPU disabled
Post by aetch »
"GPU 0: Bus:9 Slot:0 Func:0 AMD:1" - the client has failed to identify your graphics card, suggesting it has failed to download the GPU.txt file when the client started.
The progression of "ERROR:WU00:FS00:Exception: Could not get IP address for " to "WU00:FS00:Assigned to work server 129.32.209.205" suggests your internet router took about 3 minutes to connect to the internet.
I'm going to suggest restarting the client.
Right click the FAH bubble icon in the taskbar -> Quit
Start button -> Folding@Home -> Folding@Home
felix920506
Re: GPU disabled
thanks it now works after restarting the client
Re: GPU disabled
Thank you for reporting back, it helps us guess better next time.
