Failed reading core package header - CPU core A8
AdrianThePirate
Post by AdrianThePirate »
Mod note: merged two new posts with same error - j
Hey all, been trying to get F@A set up on my new system and the GPU folding works fine, but the CPU keeps running into errors after completing a WU download. I have also tried to config the CPU to 16 core, as well as 22 core (as provided log is for). The log looks the same for both 16 and 22.
I've also updated the chipset drivers, tried rebooting, and deleting previous WU download for CPU and I'm now at a loss for what else to do to fix this. The errors are primarily Unkown exception or 0xc0000005: Exception access violation.
Hope some of you have can help me out :)
*********************** Log Started 2021-09-03T08:15:53Z ***********************
08:15:53:******************************* libFAH ********************************
08:15:53:           Date: Oct 20 2020
08:15:53:           Time: 13:36:55
08:15:53:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:15:53:         Branch: master
08:15:53:       Compiler: Visual C++ 2015
08:15:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:15:53:       Platform: win32 10
08:15:53:           Bits: 32
08:15:53:           Mode: Release
08:15:53:****************************** FAHClient ******************************
08:15:53:        Version: 7.6.21
08:15:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:15:53:      Copyright: 2020 foldingathome.org
08:15:53:       Homepage: https://foldingathome.org/
08:15:53:           Time: 13:41:04
08:15:53:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:15:53:           Bits: 32
08:15:53:         Config: C:\ProgramData\FAHClient\config.xml
08:15:53:******************************** CBang ********************************
08:15:53:           Time: 11:36:18
08:15:53:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:15:53:           Bits: 32
08:15:53:******************************* System ********************************
08:15:53:            CPU: AMD Ryzen 9 5900X 12-Core Processor
08:15:53:         CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
08:15:53:           CPUs: 24
08:15:53:         Memory: 63.91GiB
08:15:53:    Free Memory: 58.75GiB
08:15:53:        Threads: WINDOWS_THREADS
08:15:53:     OS Version: 6.2
08:15:53:    Has Battery: false
08:15:53:     On Battery: false
08:15:53:     UTC Offset: 2
08:15:53:            PID: 12052
08:15:53:            CWD: C:\ProgramData\FAHClient
08:15:53:  Win32 Service: false
08:15:53:             OS: Windows 10 Home
08:15:53:        OS Arch: AMD64
08:15:53:           GPUs: 1
08:15:53:          GPU 0: Bus:8 Slot:0 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080 Ti]
08:15:53:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:8.6 Driver:11.4
08:15:53:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:3.0 Driver:471.96
08:15:53:***********************************************************************
08:15:53:<config>
08:15:53:  <!-- Network -->
08:15:53:  <proxy v=':8080'/>
08:15:53:
08:15:53:  <!-- Slot Control -->
08:15:53:  <power v='full'/>
08:15:53:
08:15:53:  <!-- User Information -->
08:15:53:  <passkey v='*****'/>
08:15:53:  <team v='255822'/>
08:15:53:  <user v='AdrianThePirate'/>
08:15:53:
08:15:53:  <!-- Folding Slots -->
08:15:53:  <slot id='0' type='CPU'>
08:15:53:    <cpus v='22'/>
08:15:53:    <paused v='true'/>
08:15:53:  </slot>
08:15:53:  <slot id='1' type='GPU'>
08:15:53:    <pci-bus v='8'/>
08:15:53:    <pci-slot v='0'/>
08:15:53:  </slot>
08:15:53:</config>
08:15:53:Trying to access database...
08:15:53:Successfully acquired database lock
08:15:53:FS00:Initialized folding slot 00: cpu:22
08:15:53:FS01:Initialized folding slot 01: gpu:8:0 GA102 [GeForce RTX 3080 Ti]
08:15:53:WARNING:WU00:Missing data files, dumping
08:15:53:WU00:FS00:Cleaning up
08:16:53:FS00:Unpaused
08:16:54:WU01:FS00:Connecting to assign1.foldingathome.org:80
08:16:54:WU01:FS00:Assigned to work server 128.252.203.11
08:16:54:WU01:FS00:Requesting new work unit for slot 00: cpu:22 from 128.252.203.11
08:16:54:WU01:FS00:Connecting to 128.252.203.11:8080
08:16:55:WU01:FS00:Downloading 8.34MiB
08:17:00:WU01:FS00:Download complete
08:17:00:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18206 run:15201 clone:0 gen:22 core:0xa8 unit:0x00000000000000160000471e00003b61
08:17:00:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
08:17:00:WU01:FS00:Connecting to cores.foldingathome.org:80
08:17:01:WU01:FS00:FahCore a8: Downloading 7.72MiB
08:17:07:WU01:FS00:FahCore a8: 2.43%
08:21:18:WU01:FS00:FahCore a8: 99.54%
08:21:19:WU01:FS00:FahCore a8: Download complete
08:21:20:ERROR:WU01:FS00:unknown exception
08:21:20:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
08:21:20:WU01:FS00:Connecting to cores.foldingathome.org:80
08:21:21:ERROR:WU01:FS00:Exception: Failed reading core package header.
08:22:57:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
08:22:57:WU01:FS00:Connecting to cores.foldingathome.org:80
08:22:58:WU01:FS00:FahCore a8: Downloading 7.72MiB
08:23:04:WU01:FS00:FahCore a8: 2.43%
08:27:21:WU01:FS00:FahCore a8: 99.54%
08:27:22:WU01:FS00:FahCore a8: Download complete
08:27:22:ERROR:WU01:FS00:unknown exception
08:27:22:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
08:27:22:WU01:FS00:Connecting to cores.foldingathome.org:80
08:27:23:WU01:FS00:FahCore a8: Downloading 7.72MiB
08:27:30:WU01:FS00:FahCore a8: 2.43%
08:31:56:WU01:FS00:FahCore a8: 97.92%
08:32:01:WU01:FS00:FahCore a8: Download complete
08:32:02:ERROR:WU01:FS00:Exception: Win32: 0xc0000005: Exception access violation
08:32:02:WU01:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
08:32:02:WU01:FS00:Connecting to cores.foldingathome.org:80
08:32:02:WU01:FS00:FahCore a8: Downloading 7.72MiB
08:32:09:WU01:FS00:FahCore a8: 2.43%
08:36:29:WU01:FS00:FahCore a8: 99.54%
08:36:31:WU01:FS00:FahCore a8: Download complete
08:36:31:ERROR:WU01:FS00:unknown exception
tvmwd6
can't load core: Failed reading core package header
Post by tvmwd6 »
Hello,
I'm trying to get started with folding but I can't seem to get any machine to download a core, getting the error: Failed reading core package header
I can follow the link and download the core manually in the browser, but FAHClient cannot, apparently due to the headers somehow.
This issue persists across 3 machines on 2 separate networks, all of which allow traffic on port 80/8080 so I don't know what the problem could be.
15:50:59:Trying to access database...
15:50:59:Successfully acquired database lock
15:50:59:FS00:Initialized folding slot 00: cpu:7
15:50:59:WU00:FS00:Downloading core from http://cores.foldingathome.org/lin/64bit-avx-256/a8-0.0.12/Core_a8.fah
15:50:59:WU00:FS00:Connecting to cores.foldingathome.org:80
15:51:00:ERROR:WU00:FS00:Exception: Failed reading core package header.
The last 3 lines then repeat every minute or so until the program is stopped.
I would appreciate any help you can give.
EDIT: This was supposed to be a new post, I don't know what happened here...
debs3759
Re: can't load core: Failed reading core package header
Post by debs3759 »
tvmwd6 wrote:Hello,
I posted the same error earlier, in another part of the forums. Another person replied that they had the same error in Linux today (I'm on Windows 10), so it seems to be server related, although it is possible to download the cores in a browser.
tvmwd6
Re: Failed reading core package header - CPU core
Post by tvmwd6 »
Once you download the core where do you put it? My folder structure isn't even generated yet.
debs3759
Post by debs3759 »
I don't know yet, waiting to see if I get a reply.
The download needs to be handled by the client to unpack it and put the components in the correct place. Downloading in a browser just helps to confirm if the download source is taking connections and allowing downloads at all.
I have come across a message elsewhere that the developer had added a test version of the core and inadvertently also reloaded a bad version. That should have been fixed by now. If your client is still trying to download the bad version, it may take restarting your machine to switch to a good one.
debs3759
Post by debs3759 »
My client is still getting a bad core, even after several reboots and purges.
debs3759
Post by debs3759 »
I don't like deleting work units, but I've been trying to get a good copy of core 22 0.0.13 for about 9 or 10 hours, so am deleting wu in hopes of getting one that uses a different version. Only getting work for 0.0.13.
Good to know it's not my setup that faulty though, hopefully it'll be fixed overnight. I just picked a bad day to downgrade from Windows 11 :)
Post by Neil-B »
debs3759 wrote:I don't like deleting work units, but I've been trying to get a good copy of core 22 0.0.13 for about 9 or 10 hours, so am deleting wu in hopes of getting one that uses a different version. Only getting work for 0.0.13.
Currently that is the only core in play - the 0.0.16 was in use for p13456/7 but none of those wus are around as far as I am aware ... If a dev has to resolve it it may take a while for the servers to update and start pushing out the correct core - fingers crossed it sorts itself by the morrow :)
debs3759
Post by debs3759 »
Thanks for the update.
Luxi23
ERROR:WU02:FS02:Exception: Failed reading core package heade
Post by Luxi23 »
Hello,
I just wanted to start with my theta edge node but F@H is trying to stop me.
I have an old problem again. but I think Im the only one.
00:29:08:</config>
00:29:27:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:29:28:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:29:28:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:29:28:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:29:28:WU01:FS01:Connecting to assign3.foldingathome.org:80
00:29:29:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:29:29:WU01:FS01:Connecting to assign4.foldingathome.org:80
00:29:29:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:29:29:ERROR:WU01:FS01:Exception: Could not get an assignment
00:29:35:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
00:29:35:WU02:FS02:Connecting to cores.foldingathome.org:80
00:29:35:ERROR:WU02:FS02:Exception: Failed reading core package header.
00:31:04:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:31:05:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:31:05:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:31:05:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:31:05:WU01:FS01:Connecting to assign3.foldingathome.org:80
00:31:06:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:31:06:WU01:FS01:Connecting to assign4.foldingathome.org:80
00:31:06:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:31:06:ERROR:WU01:FS01:Exception: Could not get an assignment
00:31:12:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
00:31:12:WU02:FS02:Connecting to cores.foldingathome.org:80
00:31:12:ERROR:WU02:FS02:Exception: Failed reading core package header.
00:32:33:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
00:32:33:WU00:FS00:Connecting to cores.foldingathome.org:80
00:32:33:ERROR:WU00:FS00:Exception: Failed reading core package header.
00:33:41:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:33:42:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:33:42:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:33:42:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:33:42:WU01:FS01:Connecting to assign3.foldingathome.org:80
00:33:43:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:33:43:WU01:FS01:Connecting to assign4.foldingathome.org:80
00:33:43:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:33:43:ERROR:WU01:FS01:Exception: Could not get an assignment
00:33:49:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
00:33:50:WU02:FS02:Connecting to cores.foldingathome.org:80
00:33:50:ERROR:WU02:FS02:Exception: Failed reading core package header.
00:37:55:WU01:FS01:Connecting to assign1.foldingathome.org:80
00:37:56:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
00:37:56:WU01:FS01:Connecting to assign2.foldingathome.org:80
00:37:57:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
00:37:57:WU01:FS01:Connecting to assign3.foldingathome.org:80
00:37:57:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
00:37:57:WU01:FS01:Connecting to assign4.foldingathome.org:80
00:37:58:WARNING:WU01:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
00:37:58:ERROR:WU01:FS01:Exception: Could not get an assignment
00:38:04:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
00:38:04:WU02:FS02:Connecting to cores.foldingathome.org:80
00:38:04:ERROR:WU02:FS02:Exception: Failed reading core package header.
can somebody help me pleas ? :(
aetch
Re: Failed reading core package header - CPU core A8
Post by aetch »
You appear to have two issues there.
1). "No WUs available for this configuration" - The work units are configured by the scientists to run on different hardware whether it be processor, graphics card or something else. Basically there aren't any work units configured to run on your slot 01 (probably graphics card).
2). "Downloading core from http://cores.foldingathome.org/win/64bi ... ore_22.fah" - this is a problem that was identified a few hours ago, whether it's the server or the payload I don't know but it likely won't be fixed until next week when the developers return from the weekend. If you have the cores already downloaded to another machine I suggest copying them across.
debs3759
Post by debs3759 »
Woohoo! Just seen that the core finally successfully downloaded about 45 minutes ago. I noticed it after I went to the kitchen, and noticed the sitting room is again warmer than the rest of the house :)
Luxi23
Post by Luxi23 »
Yes you are right. cores are now working but my gpu is not used. can you tell me how I fix this ? I have 2 gpus . 1) nvidia gtx 1660 max Q and 2) is onboard intel grafik, they are also showen right in the webcontrol but they are not used . I would be very happy if you could tell me how i can fix this :)
Post by Neil-B »
Currently no projects using the Intel igpus that I am aware of - and you need to have a flag set to allow them to fold ... as to the gtx1660 what does the log show? ... you aren't folding on light by any chance as this stops gpu slots
