RPi4 Not Finishing WUs
I have a headless setup on my Pi 4 (4GB) and FAH runs and gets assigned WUs. However, it NEVER finishes the WUs. For Example, I have a WU sitting at 36% with 8 days left but the status says it has 6 hours left to complete the WU. Is there a setting I'm missing? Is there a type of WU that Pi's are supposed to receive that they can handle within the allotted time frame? Thanks.
Re: RPi4 Not Finishing WUs
What does the log say ?
Thanks for the reply. How do I view the logs? Thanks.
Current log is in /var/lib/fahclient/log.txt ... older ones are in /var/lib/fahclient/logs/ ...
I tend to monitor the logs by tailing the file in a terminal with:
This grabs the last few lines then auto-updates when new lines are added almost like if you had run fahclient from that terminal.
tail -f <path/to/logfile>Re: RPi4 Not Finishing WUs
You do know that you can configure the client for remote control and control it from the advanced control panel installed on another computer?
ya, this was for testing and was relatively short term. I have a topic up describing what I'm trying to do now.
