Units uploaded but no updates in the stats
Hello
I have checked the EOC and official Stats page and since quite some time, we do not see any updates for the Work Units my colleagues and me have uploaded successfully for our team.
We are still folding right now but it looks that there might be an issue with the stats server. I see that EVL and Megware Computer teams have the same issue.
Re: Units uploaded but no updates in the stats
Sometimes the connection from a particular Work Server and the statistics server breaks and someone on the back end has to fix it. Do you have the PRCG numbers (project, run, clone, gen) from the WUs missing from the statistics?
I assume that the passkey and nickname is set correctly in the clients? The official stats are separated by both the nickname and passkey, while the EOC stats only use the nickname if I recall correctly.
Hi,
In the logging (e.g. in FAHControl), you can see if a job is successfully uploaded, e.g.
On https://apps.foldingathome.org/wu you can enter the PRCG (project, run, clone, gen) numbers and check if the results are known in the stats database. If you have returned a unit successfully, but don't see the results in the stats database after a day or two, please give the those numbers. The F@h teams can then check if something is broken.
15:22:07:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:22:07:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:22:07:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13823 run:713 clone:3 gen:186 core:0xa7 unit:0x00000003000000ba000035ff000002c9
15:22:07:WU01:FS00:Uploading 11.28MiB to 128.252.203.9
15:22:07:WU01:FS00:Connecting to 128.252.203.9:8080
15:22:13:WU01:FS00:Upload 31.57%
15:22:19:WU01:FS00:Upload 62.58%
15:22:25:WU01:FS00:Upload 92.49%
15:22:27:WU01:FS00:Upload complete
15:22:27:WU01:FS00:Server responded WORK_ACK (400)
Yes, the keys and the nicknames are fine, we have around 10 PCs (mostly with two GPUs) that fold non-stop. It's unlikely that all these clients are badly configured.
I will have to check for the PRCG numbers, we have logs but due to the difference between Eastern Europe time and the F@H client time, it's a bit difficult to find the exact units that were send and were not taken into account.
LE: We have checked, the WU were uploaded successfully.
LLE: how can you attach a text file (the log is quite large) ?
How to post a log -> viewtopic.php?f=24&t=26036#p327412
06:39:41:WU02:FS00:0x22:*********************** Log Started 2021-08-24T06:39:41Z ***********************
06:39:41:WU02:FS00:0x22:*************************** Core22 Folding@home Core ***************************
06:39:41:WU02:FS00:0x22: Core: Core22
06:39:41:WU02:FS00:0x22: Type: 0x22
06:39:41:WU02:FS00:0x22: Version: 0.0.13
06:39:41:WU02:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:39:41:WU02:FS00:0x22: Copyright: 2020 foldingathome.org
06:39:41:WU02:FS00:0x22: Homepage: https://foldingathome.org/
06:39:41:WU02:FS00:0x22: Date: Sep 19 2020
06:39:41:WU02:FS00:0x22: Time: 02:35:58
06:39:41:WU02:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
06:39:41:WU02:FS00:0x22: Branch: core22-0.0.13
06:39:41:WU02:FS00:0x22: Compiler: Visual C++ 2015
06:39:41:WU02:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
06:39:41:WU02:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
06:39:41:WU02:FS00:0x22: Platform: win32 10
06:39:41:WU02:FS00:0x22: Bits: 64
06:39:41:WU02:FS00:0x22: Mode: Release
06:39:41:WU02:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
06:39:41:WU02:FS00:0x22: <peastman@stanford.edu>
06:39:41:WU02:FS00:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 5116 -checkpoint 15
06:39:41:WU02:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
06:39:41:WU02:FS00:0x22: 1 -gpu 1
06:39:41:WU02:FS00:0x22:************************************ libFAH ************************************
06:39:41:WU02:FS00:0x22: Date: Sep 7 2020
06:39:41:WU02:FS00:0x22: Time: 19:09:56
06:39:41:WU02:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
06:39:41:WU02:FS00:0x22: Branch: HEAD
06:39:41:WU02:FS00:0x22:************************************ CBang *************************************
06:39:41:WU02:FS00:0x22: Time: 19:08:30
06:39:41:WU02:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
06:39:41:WU02:FS00:0x22:************************************ System ************************************
06:39:41:WU02:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
06:39:41:WU02:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
06:39:41:WU02:FS00:0x22: CPUs: 4
06:39:41:WU02:FS00:0x22: Memory: 15.94GiB
06:39:41:WU02:FS00:0x22:Free Memory: 10.80GiB
06:39:41:WU02:FS00:0x22: Threads: WINDOWS_THREADS
06:39:41:WU02:FS00:0x22: OS Version: 6.2
06:39:41:WU02:FS00:0x22:Has Battery: false
06:39:41:WU02:FS00:0x22: On Battery: false
06:39:41:WU02:FS00:0x22: UTC Offset: 3
06:39:41:WU02:FS00:0x22: PID: 10544
06:39:41:WU02:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
06:39:41:WU02:FS00:0x22:************************************ OpenMM ************************************
06:39:41:WU02:FS00:0x22: Revision: 189320d0
06:39:41:WU02:FS00:0x22:********************************************************************************
06:39:41:WU02:FS00:0x22:Project: 16476 (Run 1, Clone 9, Gen 10)
06:39:41:WU02:FS00:0x22:Unit: 0x00000000000000000000000000000000
06:39:41:WU02:FS00:0x22:Reading tar file core.xml
06:39:41:WU02:FS00:0x22:Reading tar file integrator.xml.bz2
06:39:41:WU02:FS00:0x22:Reading tar file state.xml.bz2
06:39:41:WU02:FS00:0x22:Reading tar file system.xml.bz2
06:39:41:WU02:FS00:0x22:Digital signatures verified
06:39:41:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
06:39:41:WU02:FS00:0x22:Version 0.0.13
06:39:41:WU02:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
06:39:41:WU02:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
06:39:41:WU02:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
06:39:41:WU02:FS00:0x22: Global context and integrator variables write interval: disabled
06:39:42:WU02:FS00:0x22:There are 4 platforms available.
06:39:42:WU02:FS00:0x22:Platform 0: Reference
06:39:42:WU02:FS00:0x22:Platform 1: CPU
06:39:42:WU02:FS00:0x22:Platform 2: OpenCL
06:39:42:WU02:FS00:0x22: opencl-device 1 specified
06:39:42:WU02:FS00:0x22:Platform 3: CUDA
06:39:42:WU02:FS00:0x22: cuda-device 1 specified
06:39:47:WU00:FS00:Upload 25.53%
06:39:53:WU00:FS00:Upload 51.52%
06:39:54:WU02:FS00:0x22:Attempting to create CUDA context:
06:39:54:WU02:FS00:0x22: Configuring platform CUDA
06:39:58:WU01:FS01:0x22:Completed 1350000 out of 2500000 steps (54%)
06:39:59:WU00:FS00:Upload 77.51%
06:40:02:WU02:FS00:0x22: Using CUDA and gpu 1
06:40:02:WU02:FS00:0x22:Completed 0 out of 2500000 steps (0%)
06:40:03:WU02:FS00:0x22:Checkpoint completed at step 0
06:40:04:WU00:FS00:Upload complete
06:40:04:WU00:FS00:Server responded WORK_ACK (400)
06:40:04:WU00:FS00:Final credit estimate, 373778.00 points
06:40:04:WU00:FS00:Cleaning up
07:28:54:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
07:28:54:WU00:FS01:Connecting to assign1.foldingathome.org:80
07:28:54:WU00:FS01:Assigned to work server 140.163.4.200
07:28:54:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
07:28:54:WU00:FS01:Connecting to 140.163.4.200:8080
07:28:55:WU00:FS01:Downloading 13.11MiB
07:29:01:WU00:FS01:Download 87.24%
07:29:01:WU00:FS01:Download complete
07:29:02:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16483 run:0 clone:4 gen:24 core:0x22 unit:0x00000004000000180000406300000000
07:29:58:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
07:29:58:WU01:FS01:0x22:Average performance: 266.667 ns/day
07:30:00:WU01:FS01:0x22:Checkpoint completed at step 2500000
07:30:07:WU02:FS00:0x22:Completed 675000 out of 2500000 steps (27%)
07:30:08:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
07:30:08:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
07:30:08:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
07:30:08:WU01:FS01:0x22:Saving result file positions.xtc
07:30:08:WU01:FS01:0x22:Saving result file science.log
07:30:08:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
07:30:09:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:30:09:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16477 run:0 clone:1 gen:33 core:0x22 unit:0x00000001000000210000405d00000000
07:30:09:WU01:FS01:Uploading 13.47MiB to 140.163.4.200
07:30:09:WU00:FS01:Starting
07:30:09:WU01:FS01:Connecting to 140.163.4.200:8080
07:30:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:30:09:WU00:FS01:Started FahCore on PID 9720
07:30:09:WU00:FS01:Core PID:4964
07:30:09:WU00:FS01:FahCore 0x22 started
07:30:09:WU00:FS01:0x22:*********************** Log Started 2021-08-24T07:30:09Z ***********************
07:30:09:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:30:09:WU00:FS01:0x22: Core: Core22
07:30:09:WU00:FS01:0x22: Type: 0x22
07:30:09:WU00:FS01:0x22: Version: 0.0.13
07:30:09:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:30:09:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
07:30:09:WU00:FS01:0x22: Homepage: https://foldingathome.org/
07:30:09:WU00:FS01:0x22: Date: Sep 19 2020
07:30:09:WU00:FS01:0x22: Time: 02:35:58
07:30:09:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
07:30:09:WU00:FS01:0x22: Branch: core22-0.0.13
07:30:09:WU00:FS01:0x22: Compiler: Visual C++ 2015
07:30:09:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
07:30:09:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
07:30:09:WU00:FS01:0x22: Platform: win32 10
07:30:09:WU00:FS01:0x22: Bits: 64
07:30:09:WU00:FS01:0x22: Mode: Release
07:30:09:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
07:30:09:WU00:FS01:0x22: <peastman@stanford.edu>
07:30:09:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9720 -checkpoint 15
07:30:09:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:30:09:WU00:FS01:0x22: 0 -gpu 0
07:30:09:WU00:FS01:0x22:************************************ libFAH ************************************
07:30:09:WU00:FS01:0x22: Date: Sep 7 2020
07:30:09:WU00:FS01:0x22: Time: 19:09:56
07:30:09:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
07:30:09:WU00:FS01:0x22: Branch: HEAD
07:30:09:WU00:FS01:0x22:************************************ CBang *************************************
07:30:09:WU00:FS01:0x22: Time: 19:08:30
07:30:09:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
07:30:09:WU00:FS01:0x22:************************************ System ************************************
07:30:09:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
07:30:09:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
07:30:09:WU00:FS01:0x22: CPUs: 4
07:30:09:WU00:FS01:0x22: Memory: 15.94GiB
07:30:09:WU00:FS01:0x22:Free Memory: 10.71GiB
07:30:09:WU00:FS01:0x22: Threads: WINDOWS_THREADS
07:30:09:WU00:FS01:0x22: OS Version: 6.2
07:30:09:WU00:FS01:0x22:Has Battery: false
07:30:09:WU00:FS01:0x22: On Battery: false
07:30:09:WU00:FS01:0x22: UTC Offset: 3
07:30:09:WU00:FS01:0x22: PID: 4964
07:30:09:WU00:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
07:30:09:WU00:FS01:0x22:************************************ OpenMM ************************************
07:30:09:WU00:FS01:0x22: Revision: 189320d0
07:30:09:WU00:FS01:0x22:********************************************************************************
07:30:09:WU00:FS01:0x22:Project: 16483 (Run 0, Clone 4, Gen 24)
07:30:09:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
07:30:09:WU00:FS01:0x22:Reading tar file core.xml
07:30:09:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
07:30:09:WU00:FS01:0x22:Reading tar file state.xml.bz2
07:30:09:WU00:FS01:0x22:Reading tar file system.xml.bz2
07:30:09:WU00:FS01:0x22:Digital signatures verified
07:30:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:30:09:WU00:FS01:0x22:Version 0.0.13
07:30:09:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
07:30:09:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:30:09:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
07:30:09:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
07:30:09:WU00:FS01:0x22:There are 4 platforms available.
07:30:09:WU00:FS01:0x22:Platform 0: Reference
07:30:09:WU00:FS01:0x22:Platform 1: CPU
07:30:09:WU00:FS01:0x22:Platform 2: OpenCL
07:30:09:WU00:FS01:0x22: opencl-device 0 specified
07:30:09:WU00:FS01:0x22:Platform 3: CUDA
07:30:09:WU00:FS01:0x22: cuda-device 0 specified
07:30:15:WU01:FS01:Upload 24.13%
07:30:21:WU01:FS01:Upload 50.57%
07:30:21:WU00:FS01:0x22:Attempting to create CUDA context:
07:30:21:WU00:FS01:0x22: Configuring platform CUDA
07:30:27:WU01:FS01:Upload 76.55%
07:30:27:WU00:FS01:0x22: Using CUDA and gpu 0
07:30:27:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
07:30:28:WU00:FS01:0x22:Checkpoint completed at step 0
07:30:32:WU01:FS01:Upload complete
07:30:32:WU01:FS01:Server responded WORK_ACK (400)
07:30:32:WU01:FS01:Final credit estimate, 488059.00 points
07:30:32:WU01:FS01:Cleaning up
07:31:32:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
09:19:05:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
09:19:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:19:06:WU01:FS01:Assigned to work server 140.163.4.200
09:19:06:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
09:19:06:WU01:FS01:Connecting to 140.163.4.200:8080
09:19:07:WU01:FS01:Downloading 13.09MiB
09:19:12:WU01:FS01:Download complete
09:19:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16473 run:1 clone:4 gen:16 core:0x22 unit:0x00000004000000100000405900000001
09:19:40:WU02:FS00:0x22:Completed 2150000 out of 2500000 steps (86%)
09:20:11:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
09:20:11:WU00:FS01:0x22:Average performance: 258.683 ns/day
09:20:13:WU00:FS01:0x22:Checkpoint completed at step 2500000
09:20:21:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
09:20:21:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
09:20:21:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
09:20:21:WU00:FS01:0x22:Saving result file positions.xtc
09:20:21:WU00:FS01:0x22:Saving result file science.log
09:20:21:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:20:22:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:20:22:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16483 run:0 clone:4 gen:24 core:0x22 unit:0x00000004000000180000406300000000
09:20:22:WU00:FS01:Uploading 13.48MiB to 140.163.4.200
09:20:22:WU01:FS01:Starting
09:20:22:WU00:FS01:Connecting to 140.163.4.200:8080
09:20:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:20:22:WU01:FS01:Started FahCore on PID 10524
09:20:22:WU01:FS01:Core PID:5004
09:20:22:WU01:FS01:FahCore 0x22 started
09:20:22:WU01:FS01:0x22:*********************** Log Started 2021-08-24T09:20:22Z ***********************
09:20:22:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:20:22:WU01:FS01:0x22: Core: Core22
09:20:22:WU01:FS01:0x22: Type: 0x22
09:20:22:WU01:FS01:0x22: Version: 0.0.13
09:20:22:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:20:22:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
09:20:22:WU01:FS01:0x22: Homepage: https://foldingathome.org/
09:20:22:WU01:FS01:0x22: Date: Sep 19 2020
09:20:22:WU01:FS01:0x22: Time: 02:35:58
09:20:22:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
09:20:22:WU01:FS01:0x22: Branch: core22-0.0.13
09:20:22:WU01:FS01:0x22: Compiler: Visual C++ 2015
09:20:22:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:20:22:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
09:20:22:WU01:FS01:0x22: Platform: win32 10
09:20:22:WU01:FS01:0x22: Bits: 64
09:20:22:WU01:FS01:0x22: Mode: Release
09:20:22:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:20:22:WU01:FS01:0x22: <peastman@stanford.edu>
09:20:22:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 10524 -checkpoint 15
09:20:22:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
09:20:22:WU01:FS01:0x22: 0 -gpu 0
09:20:22:WU01:FS01:0x22:************************************ libFAH ************************************
09:20:22:WU01:FS01:0x22: Date: Sep 7 2020
09:20:22:WU01:FS01:0x22: Time: 19:09:56
09:20:22:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
09:20:22:WU01:FS01:0x22: Branch: HEAD
09:20:22:WU01:FS01:0x22:************************************ CBang *************************************
09:20:22:WU01:FS01:0x22: Time: 19:08:30
09:20:22:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
09:20:22:WU01:FS01:0x22:************************************ System ************************************
09:20:22:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
09:20:22:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:20:22:WU01:FS01:0x22: CPUs: 4
09:20:22:WU01:FS01:0x22: Memory: 15.94GiB
09:20:22:WU01:FS01:0x22:Free Memory: 10.79GiB
09:20:22:WU01:FS01:0x22: Threads: WINDOWS_THREADS
09:20:22:WU01:FS01:0x22: OS Version: 6.2
09:20:22:WU01:FS01:0x22:Has Battery: false
09:20:22:WU01:FS01:0x22: On Battery: false
09:20:22:WU01:FS01:0x22: UTC Offset: 3
09:20:22:WU01:FS01:0x22: PID: 5004
09:20:22:WU01:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
09:20:22:WU01:FS01:0x22:************************************ OpenMM ************************************
09:20:22:WU01:FS01:0x22: Revision: 189320d0
09:20:22:WU01:FS01:0x22:********************************************************************************
09:20:22:WU01:FS01:0x22:Project: 16473 (Run 1, Clone 4, Gen 16)
09:20:22:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
09:20:22:WU01:FS01:0x22:Reading tar file core.xml
09:20:22:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
09:20:22:WU01:FS01:0x22:Reading tar file state.xml.bz2
09:20:22:WU01:FS01:0x22:Reading tar file system.xml.bz2
09:20:22:WU01:FS01:0x22:Digital signatures verified
09:20:22:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:20:22:WU01:FS01:0x22:Version 0.0.13
09:20:22:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
09:20:22:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
09:20:22:WU01:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
09:20:23:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
09:20:23:WU01:FS01:0x22:There are 4 platforms available.
09:20:23:WU01:FS01:0x22:Platform 0: Reference
09:20:23:WU01:FS01:0x22:Platform 1: CPU
09:20:23:WU01:FS01:0x22:Platform 2: OpenCL
09:20:23:WU01:FS01:0x22: opencl-device 0 specified
09:20:23:WU01:FS01:0x22:Platform 3: CUDA
09:20:23:WU01:FS01:0x22: cuda-device 0 specified
09:20:28:WU00:FS01:Upload 23.65%
09:20:34:WU00:FS01:Upload 50.08%
09:20:35:WU01:FS01:0x22:Attempting to create CUDA context:
09:20:35:WU01:FS01:0x22: Configuring platform CUDA
09:20:40:WU00:FS01:Upload 76.05%
09:20:42:WU01:FS01:0x22: Using CUDA and gpu 0
09:20:42:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
09:20:43:WU01:FS01:0x22:Checkpoint completed at step 0
09:20:45:WU00:FS01:Upload complete
09:20:46:WU00:FS01:Server responded WORK_ACK (400)
09:20:46:WU00:FS01:Final credit estimate, 485533.00 points
09:20:46:WU00:FS01:Cleaning up
09:21:31:WU02:FS00:0x22:Completed 2175000 out of 2500000 steps (87%)
09:21:49:WU01:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
09:43:48:WU02:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
09:43:49:WU00:FS00:Connecting to assign1.foldingathome.org:80
09:43:50:WU00:FS00:Assigned to work server 140.163.4.200
09:43:50:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
09:43:50:WU00:FS00:Connecting to 140.163.4.200:8080
09:43:50:WU00:FS00:Downloading 13.11MiB
09:43:56:WU00:FS00:Download 81.06%
09:43:57:WU00:FS00:Download complete
09:43:57:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16477 run:1 clone:10 gen:7 core:0x22 unit:0x0000000a000000070000405d00000001
09:44:46:WU01:FS01:0x22:Completed 550000 out of 2500000 steps (22%)
09:45:39:WU02:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
09:45:39:WU02:FS00:0x22:Average performance: 155.676 ns/day
09:45:41:WU02:FS00:0x22:Checkpoint completed at step 2500000
09:45:48:WU02:FS00:0x22:Saving result file ..\logfile_01.txt
09:45:48:WU02:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
09:45:48:WU02:FS00:0x22:Saving result file checkpointState.xml.bz2
09:45:49:WU02:FS00:0x22:Saving result file positions.xtc
09:45:49:WU02:FS00:0x22:Saving result file science.log
09:45:49:WU02:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:45:49:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:45:49:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16476 run:1 clone:9 gen:10 core:0x22 unit:0x000000090000000a0000405c00000001
09:45:49:WU02:FS00:Uploading 13.47MiB to 140.163.4.200
09:45:49:WU00:FS00:Starting
09:45:49:WU02:FS00:Connecting to 140.163.4.200:8080
09:45:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
09:45:49:WU00:FS00:Started FahCore on PID 8148
09:45:49:WU00:FS00:Core PID:732
09:45:49:WU00:FS00:FahCore 0x22 started
09:45:50:WU00:FS00:0x22:*********************** Log Started 2021-08-24T09:45:49Z ***********************
09:45:50:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
09:45:50:WU00:FS00:0x22: Core: Core22
09:45:50:WU00:FS00:0x22: Type: 0x22
09:45:50:WU00:FS00:0x22: Version: 0.0.13
09:45:50:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:45:50:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
09:45:50:WU00:FS00:0x22: Homepage: https://foldingathome.org/
09:45:50:WU00:FS00:0x22: Date: Sep 19 2020
09:45:50:WU00:FS00:0x22: Time: 02:35:58
09:45:50:WU00:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
09:45:50:WU00:FS00:0x22: Branch: core22-0.0.13
09:45:50:WU00:FS00:0x22: Compiler: Visual C++ 2015
09:45:50:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
09:45:50:WU00:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
09:45:50:WU00:FS00:0x22: Platform: win32 10
09:45:50:WU00:FS00:0x22: Bits: 64
09:45:50:WU00:FS00:0x22: Mode: Release
09:45:50:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
09:45:50:WU00:FS00:0x22: <peastman@stanford.edu>
09:45:50:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 8148 -checkpoint 15
09:45:50:WU00:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
09:45:50:WU00:FS00:0x22: 1 -gpu 1
09:45:50:WU00:FS00:0x22:************************************ libFAH ************************************
09:45:50:WU00:FS00:0x22: Date: Sep 7 2020
09:45:50:WU00:FS00:0x22: Time: 19:09:56
09:45:50:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
09:45:50:WU00:FS00:0x22: Branch: HEAD
09:45:50:WU00:FS00:0x22:************************************ CBang *************************************
09:45:50:WU00:FS00:0x22: Time: 19:08:30
09:45:50:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
09:45:50:WU00:FS00:0x22:************************************ System ************************************
09:45:50:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
09:45:50:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
09:45:50:WU00:FS00:0x22: CPUs: 4
09:45:50:WU00:FS00:0x22: Memory: 15.94GiB
09:45:50:WU00:FS00:0x22:Free Memory: 10.75GiB
09:45:50:WU00:FS00:0x22: Threads: WINDOWS_THREADS
09:45:50:WU00:FS00:0x22: OS Version: 6.2
09:45:50:WU00:FS00:0x22:Has Battery: false
09:45:50:WU00:FS00:0x22: On Battery: false
09:45:50:WU00:FS00:0x22: UTC Offset: 3
09:45:50:WU00:FS00:0x22: PID: 732
09:45:50:WU00:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
09:45:50:WU00:FS00:0x22:************************************ OpenMM ************************************
09:45:50:WU00:FS00:0x22: Revision: 189320d0
09:45:50:WU00:FS00:0x22:********************************************************************************
09:45:50:WU00:FS00:0x22:Project: 16477 (Run 1, Clone 10, Gen 7)
09:45:50:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
09:45:50:WU00:FS00:0x22:Reading tar file core.xml
09:45:50:WU00:FS00:0x22:Reading tar file integrator.xml.bz2
09:45:50:WU00:FS00:0x22:Reading tar file state.xml.bz2
09:45:50:WU00:FS00:0x22:Reading tar file system.xml.bz2
09:45:50:WU00:FS00:0x22:Digital signatures verified
09:45:50:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
09:45:50:WU00:FS00:0x22:Version 0.0.13
09:45:50:WU00:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
09:45:50:WU00:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
09:45:50:WU00:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
09:45:50:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
09:45:50:WU00:FS00:0x22:There are 4 platforms available.
09:45:50:WU00:FS00:0x22:Platform 0: Reference
09:45:50:WU00:FS00:0x22:Platform 1: CPU
09:45:50:WU00:FS00:0x22:Platform 2: OpenCL
09:45:50:WU00:FS00:0x22: opencl-device 1 specified
09:45:50:WU00:FS00:0x22:Platform 3: CUDA
09:45:50:WU00:FS00:0x22: cuda-device 1 specified
09:45:51:WU01:FS01:0x22:Completed 575000 out of 2500000 steps (23%)
09:45:55:WU02:FS00:Upload 20.42%
09:46:01:WU02:FS00:Upload 46.41%
09:46:02:WU00:FS00:0x22:Attempting to create CUDA context:
09:46:02:WU00:FS00:0x22: Configuring platform CUDA
09:46:07:WU02:FS00:Upload 72.87%
09:46:07:WU00:FS00:0x22: Using CUDA and gpu 1
09:46:07:WU00:FS00:0x22:Completed 0 out of 2500000 steps (0%)
09:46:08:WU00:FS00:0x22:Checkpoint completed at step 0
09:46:13:WU02:FS00:Upload 98.86%
09:46:13:WU02:FS00:Upload complete
09:46:13:WU02:FS00:Server responded WORK_ACK (400)
09:46:13:WU02:FS00:Final credit estimate, 376864.00 points
09:46:13:WU02:FS00:Cleaning up
09:46:56:WU01:FS01:0x22:Completed 600000 out of 2500000 steps (24%)
09:47:59:WU00:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
11:08:12:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
11:08:13:WU02:FS01:Connecting to assign1.foldingathome.org:80
11:08:14:WU02:FS01:Assigned to work server 140.163.4.200
11:08:14:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
11:08:14:WU02:FS01:Connecting to 140.163.4.200:8080
11:08:14:WU02:FS01:Downloading 13.11MiB
11:08:20:WU02:FS01:Download 73.42%
11:08:21:WU02:FS01:Download complete
11:08:21:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16482 run:0 clone:4 gen:22 core:0x22 unit:0x00000004000000160000406200000000
11:09:17:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
11:09:17:WU01:FS01:0x22:Average performance: 267.492 ns/day
11:09:19:WU01:FS01:0x22:Checkpoint completed at step 2500000
11:09:26:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
11:09:26:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
11:09:26:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
11:09:26:WU01:FS01:0x22:Saving result file positions.xtc
11:09:26:WU01:FS01:0x22:Saving result file science.log
11:09:26:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:09:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:09:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16473 run:1 clone:4 gen:16 core:0x22 unit:0x00000004000000100000405900000001
11:09:27:WU01:FS01:Uploading 13.46MiB to 140.163.4.200
11:09:27:WU01:FS01:Connecting to 140.163.4.200:8080
11:09:27:WU02:FS01:Starting
11:09:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
11:09:27:WU02:FS01:Started FahCore on PID 7204
11:09:27:WU02:FS01:Core PID:8052
11:09:27:WU02:FS01:FahCore 0x22 started
11:09:28:WU02:FS01:0x22:*********************** Log Started 2021-08-24T11:09:27Z ***********************
11:09:28:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:09:28:WU02:FS01:0x22: Core: Core22
11:09:28:WU02:FS01:0x22: Type: 0x22
11:09:28:WU02:FS01:0x22: Version: 0.0.13
11:09:28:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:09:28:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
11:09:28:WU02:FS01:0x22: Homepage: https://foldingathome.org/
11:09:28:WU02:FS01:0x22: Date: Sep 19 2020
11:09:28:WU02:FS01:0x22: Time: 02:35:58
11:09:28:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
11:09:28:WU02:FS01:0x22: Branch: core22-0.0.13
11:09:28:WU02:FS01:0x22: Compiler: Visual C++ 2015
11:09:28:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
11:09:28:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
11:09:28:WU02:FS01:0x22: Platform: win32 10
11:09:28:WU02:FS01:0x22: Bits: 64
11:09:28:WU02:FS01:0x22: Mode: Release
11:09:28:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
11:09:28:WU02:FS01:0x22: <peastman@stanford.edu>
11:09:28:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 7204 -checkpoint 15
11:09:28:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
11:09:28:WU02:FS01:0x22: 0 -gpu 0
11:09:28:WU02:FS01:0x22:************************************ libFAH ************************************
11:09:28:WU02:FS01:0x22: Date: Sep 7 2020
11:09:28:WU02:FS01:0x22: Time: 19:09:56
11:09:28:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
11:09:28:WU02:FS01:0x22: Branch: HEAD
11:09:28:WU02:FS01:0x22:************************************ CBang *************************************
11:09:28:WU02:FS01:0x22: Time: 19:08:30
11:09:28:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
11:09:28:WU02:FS01:0x22:************************************ System ************************************
11:09:28:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
11:09:28:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:09:28:WU02:FS01:0x22: CPUs: 4
11:09:28:WU02:FS01:0x22: Memory: 15.94GiB
11:09:28:WU02:FS01:0x22:Free Memory: 10.87GiB
11:09:28:WU02:FS01:0x22: Threads: WINDOWS_THREADS
11:09:28:WU02:FS01:0x22: OS Version: 6.2
11:09:28:WU02:FS01:0x22:Has Battery: false
11:09:28:WU02:FS01:0x22: On Battery: false
11:09:28:WU02:FS01:0x22: UTC Offset: 3
11:09:28:WU02:FS01:0x22: PID: 8052
11:09:28:WU02:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
11:09:28:WU02:FS01:0x22:************************************ OpenMM ************************************
11:09:28:WU02:FS01:0x22: Revision: 189320d0
11:09:28:WU02:FS01:0x22:********************************************************************************
11:09:28:WU02:FS01:0x22:Project: 16482 (Run 0, Clone 4, Gen 22)
11:09:28:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
11:09:28:WU02:FS01:0x22:Reading tar file core.xml
11:09:28:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
11:09:28:WU02:FS01:0x22:Reading tar file state.xml.bz2
11:09:28:WU02:FS01:0x22:Reading tar file system.xml.bz2
11:09:28:WU02:FS01:0x22:Digital signatures verified
11:09:28:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:09:28:WU02:FS01:0x22:Version 0.0.13
11:09:28:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
11:09:28:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
11:09:28:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
11:09:28:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
11:09:28:WU02:FS01:0x22:There are 4 platforms available.
11:09:28:WU02:FS01:0x22:Platform 0: Reference
11:09:28:WU02:FS01:0x22:Platform 1: CPU
11:09:28:WU02:FS01:0x22:Platform 2: OpenCL
11:09:28:WU02:FS01:0x22: opencl-device 0 specified
11:09:28:WU02:FS01:0x22:Platform 3: CUDA
11:09:28:WU02:FS01:0x22: cuda-device 0 specified
11:09:33:WU01:FS01:Upload 24.15%
11:09:39:WU01:FS01:Upload 50.16%
11:09:39:WU02:FS01:0x22:Attempting to create CUDA context:
11:09:39:WU02:FS01:0x22: Configuring platform CUDA
11:09:43:WU00:FS00:0x22:Completed 1125000 out of 2500000 steps (45%)
11:09:45:WU01:FS01:Upload 76.64%
11:09:45:WU00:FS00:0x22:Checkpoint completed at step 1125000
11:09:45:WU02:FS01:0x22: Using CUDA and gpu 0
11:09:45:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
11:09:46:WU02:FS01:0x22:Checkpoint completed at step 0
11:09:50:WU01:FS01:Upload complete
11:09:50:WU01:FS01:Server responded WORK_ACK (400)
11:09:50:WU01:FS01:Final credit estimate, 466537.00 points
11:09:50:WU01:FS01:Cleaning up
11:10:51:WU02:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
12:50:03:WU00:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
12:50:04:WU01:FS00:Connecting to assign1.foldingathome.org:80
12:50:04:WU01:FS00:Assigned to work server 140.163.4.200
12:50:04:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
12:50:04:WU01:FS00:Connecting to 140.163.4.200:8080
12:50:05:WU01:FS00:Downloading 13.11MiB
12:50:11:WU01:FS00:Download 93.92%
12:50:11:WU01:FS00:Download complete
12:50:11:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16482 run:0 clone:10 gen:5 core:0x22 unit:0x0000000a000000050000406200000000
12:50:42:WU02:FS01:0x22:Completed 2325000 out of 2500000 steps (93%)
12:51:47:WU02:FS01:0x22:Completed 2350000 out of 2500000 steps (94%)
12:51:54:WU00:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
12:51:54:WU00:FS00:0x22:Average performance: 155.676 ns/day
12:51:56:WU00:FS00:0x22:Checkpoint completed at step 2500000
12:52:04:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
12:52:04:WU00:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
12:52:04:WU00:FS00:0x22:Saving result file checkpointState.xml.bz2
12:52:04:WU00:FS00:0x22:Saving result file positions.xtc
12:52:04:WU00:FS00:0x22:Saving result file science.log
12:52:04:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:52:05:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:52:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16477 run:1 clone:10 gen:7 core:0x22 unit:0x0000000a000000070000405d00000001
12:52:05:WU00:FS00:Uploading 13.47MiB to 140.163.4.200
12:52:05:WU01:FS00:Starting
12:52:05:WU00:FS00:Connecting to 140.163.4.200:8080
12:52:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
12:52:05:WU01:FS00:Started FahCore on PID 1040
12:52:05:WU01:FS00:Core PID:9904
12:52:05:WU01:FS00:FahCore 0x22 started
12:52:05:WU01:FS00:0x22:*********************** Log Started 2021-08-24T12:52:05Z ***********************
12:52:05:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
12:52:05:WU01:FS00:0x22: Core: Core22
12:52:05:WU01:FS00:0x22: Type: 0x22
12:52:05:WU01:FS00:0x22: Version: 0.0.13
12:52:05:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:52:05:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
12:52:05:WU01:FS00:0x22: Homepage: https://foldingathome.org/
12:52:05:WU01:FS00:0x22: Date: Sep 19 2020
12:52:05:WU01:FS00:0x22: Time: 02:35:58
12:52:05:WU01:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:52:05:WU01:FS00:0x22: Branch: core22-0.0.13
12:52:05:WU01:FS00:0x22: Compiler: Visual C++ 2015
12:52:05:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:52:05:WU01:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
12:52:05:WU01:FS00:0x22: Platform: win32 10
12:52:05:WU01:FS00:0x22: Bits: 64
12:52:05:WU01:FS00:0x22: Mode: Release
12:52:05:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:52:05:WU01:FS00:0x22: <peastman@stanford.edu>
12:52:05:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 1040 -checkpoint 15
12:52:05:WU01:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
12:52:05:WU01:FS00:0x22: 1 -gpu 1
12:52:05:WU01:FS00:0x22:************************************ libFAH ************************************
12:52:05:WU01:FS00:0x22: Date: Sep 7 2020
12:52:05:WU01:FS00:0x22: Time: 19:09:56
12:52:05:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:52:05:WU01:FS00:0x22: Branch: HEAD
12:52:06:WU01:FS00:0x22: Bits: 64
12:52:06:WU01:FS00:0x22: Mode: Release
12:52:06:WU01:FS00:0x22:************************************ CBang *************************************
12:52:06:WU01:FS00:0x22: Date: Sep 7 2020
12:52:06:WU01:FS00:0x22: Time: 19:08:30
12:52:06:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:52:06:WU01:FS00:0x22: Branch: HEAD
12:52:06:WU01:FS00:0x22: Compiler: Visual C++ 2015
12:52:06:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:52:06:WU01:FS00:0x22: Platform: win32 10
12:52:06:WU01:FS00:0x22:************************************ System ************************************
12:52:06:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
12:52:06:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:52:06:WU01:FS00:0x22: CPUs: 4
12:52:06:WU01:FS00:0x22: Memory: 15.94GiB
12:52:06:WU01:FS00:0x22:Free Memory: 10.71GiB
12:52:06:WU01:FS00:0x22: Threads: WINDOWS_THREADS
12:52:06:WU01:FS00:0x22: OS Version: 6.2
12:52:06:WU01:FS00:0x22:Has Battery: false
12:52:06:WU01:FS00:0x22: On Battery: false
12:52:06:WU01:FS00:0x22: UTC Offset: 3
12:52:06:WU01:FS00:0x22: PID: 9904
12:52:06:WU01:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
12:52:06:WU01:FS00:0x22:************************************ OpenMM ************************************
12:52:06:WU01:FS00:0x22: Revision: 189320d0
12:52:06:WU01:FS00:0x22:********************************************************************************
12:52:06:WU01:FS00:0x22:Project: 16482 (Run 0, Clone 10, Gen 5)
12:52:06:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
12:52:06:WU01:FS00:0x22:Reading tar file core.xml
12:52:06:WU01:FS00:0x22:Reading tar file integrator.xml.bz2
12:52:06:WU01:FS00:0x22:Reading tar file state.xml.bz2
12:52:06:WU01:FS00:0x22:Reading tar file system.xml.bz2
12:52:06:WU01:FS00:0x22:Digital signatures verified
12:52:06:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
12:52:06:WU01:FS00:0x22:Version 0.0.13
12:52:06:WU01:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
12:52:06:WU01:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
12:52:06:WU01:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
12:52:06:WU01:FS00:0x22: Global context and integrator variables write interval: disabled
12:52:06:WU01:FS00:0x22:There are 4 platforms available.
12:52:06:WU01:FS00:0x22:Platform 0: Reference
12:52:06:WU01:FS00:0x22:Platform 1: CPU
12:52:06:WU01:FS00:0x22:Platform 2: OpenCL
12:52:06:WU01:FS00:0x22: opencl-device 1 specified
12:52:06:WU01:FS00:0x22:Platform 3: CUDA
12:52:06:WU01:FS00:0x22: cuda-device 1 specified
12:52:11:WU00:FS00:Upload 23.67%
12:52:17:WU00:FS00:Upload 49.66%
12:52:18:WU01:FS00:0x22:Attempting to create CUDA context:
12:52:18:WU01:FS00:0x22: Configuring platform CUDA
12:52:23:WU00:FS00:Upload 76.12%
12:52:23:WU01:FS00:0x22: Using CUDA and gpu 1
12:52:23:WU01:FS00:0x22:Completed 0 out of 2500000 steps (0%)
12:52:24:WU01:FS00:0x22:Checkpoint completed at step 0
12:52:28:WU00:FS00:Upload complete
12:52:28:WU00:FS00:Server responded WORK_ACK (400)
12:52:28:WU00:FS00:Final credit estimate, 373795.00 points
12:52:28:WU00:FS00:Cleaning up
12:52:52:WU02:FS01:0x22:Completed 2375000 out of 2500000 steps (95%)
12:52:54:WU02:FS01:0x22:Checkpoint completed at step 2375000
12:53:59:WU02:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
12:54:15:WU01:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
12:55:03:WU02:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
12:56:07:WU01:FS00:0x22:Completed 50000 out of 2500000 steps (2%)
12:56:08:WU02:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
12:57:13:WU02:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
12:57:14:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:57:14:WU00:FS01:Assigned to work server 140.163.4.200
12:57:14:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
12:57:15:WU00:FS01:Connecting to 140.163.4.200:8080
12:57:15:WU00:FS01:Downloading 13.09MiB
12:57:21:WU00:FS01:Download 78.28%
12:57:22:WU00:FS01:Download complete
12:57:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16473 run:0 clone:1 gen:40 core:0x22 unit:0x00000001000000280000405900000000
12:57:59:WU01:FS00:0x22:Completed 75000 out of 2500000 steps (3%)
12:58:18:WU02:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
12:58:18:WU02:FS01:0x22:Average performance: 266.667 ns/day
12:58:20:WU02:FS01:0x22:Checkpoint completed at step 2500000
12:58:27:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
12:58:27:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
12:58:27:WU02:FS01:0x22:Saving result file checkpointState.xml.bz2
12:58:27:WU02:FS01:0x22:Saving result file positions.xtc
12:58:27:WU02:FS01:0x22:Saving result file science.log
12:58:27:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
12:58:28:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:58:28:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:16482 run:0 clone:4 gen:22 core:0x22 unit:0x00000004000000160000406200000000
12:58:28:WU02:FS01:Uploading 13.48MiB to 140.163.4.200
12:58:28:WU02:FS01:Connecting to 140.163.4.200:8080
12:58:28:WU00:FS01:Starting
12:58:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
12:58:28:WU00:FS01:Started FahCore on PID 2428
12:58:28:WU00:FS01:Core PID:5756
12:58:28:WU00:FS01:FahCore 0x22 started
12:58:28:WU00:FS01:0x22:*********************** Log Started 2021-08-24T12:58:28Z ***********************
12:58:28:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:58:28:WU00:FS01:0x22: Core: Core22
12:58:28:WU00:FS01:0x22: Type: 0x22
12:58:28:WU00:FS01:0x22: Version: 0.0.13
12:58:28:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:58:28:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
12:58:28:WU00:FS01:0x22: Homepage: https://foldingathome.org/
12:58:28:WU00:FS01:0x22: Date: Sep 19 2020
12:58:28:WU00:FS01:0x22: Time: 02:35:58
12:58:28:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:58:28:WU00:FS01:0x22: Branch: core22-0.0.13
12:58:28:WU00:FS01:0x22: Compiler: Visual C++ 2015
12:58:28:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:58:28:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
12:58:28:WU00:FS01:0x22: Platform: win32 10
12:58:28:WU00:FS01:0x22: Bits: 64
12:58:28:WU00:FS01:0x22: Mode: Release
12:58:28:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:58:28:WU00:FS01:0x22: <peastman@stanford.edu>
12:58:28:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 2428 -checkpoint 15
12:58:28:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
12:58:28:WU00:FS01:0x22: 0 -gpu 0
12:58:28:WU00:FS01:0x22:************************************ libFAH ************************************
12:58:28:WU00:FS01:0x22: Date: Sep 7 2020
12:58:28:WU00:FS01:0x22: Time: 19:09:56
12:58:28:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:58:28:WU00:FS01:0x22: Branch: HEAD
12:58:28:WU00:FS01:0x22:************************************ CBang *************************************
12:58:28:WU00:FS01:0x22: Time: 19:08:30
12:58:28:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:58:28:WU00:FS01:0x22:************************************ System ************************************
12:58:28:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
12:58:28:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
12:58:28:WU00:FS01:0x22: CPUs: 4
12:58:28:WU00:FS01:0x22: Memory: 15.94GiB
12:58:28:WU00:FS01:0x22:Free Memory: 10.77GiB
12:58:28:WU00:FS01:0x22: Threads: WINDOWS_THREADS
12:58:28:WU00:FS01:0x22: OS Version: 6.2
12:58:28:WU00:FS01:0x22:Has Battery: false
12:58:28:WU00:FS01:0x22: On Battery: false
12:58:28:WU00:FS01:0x22: UTC Offset: 3
12:58:28:WU00:FS01:0x22: PID: 5756
12:58:28:WU00:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
12:58:28:WU00:FS01:0x22:************************************ OpenMM ************************************
12:58:28:WU00:FS01:0x22: Revision: 189320d0
12:58:28:WU00:FS01:0x22:********************************************************************************
12:58:28:WU00:FS01:0x22:Project: 16473 (Run 0, Clone 1, Gen 40)
12:58:28:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
12:58:29:WU00:FS01:0x22:Reading tar file core.xml
12:58:29:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
12:58:29:WU00:FS01:0x22:Reading tar file state.xml.bz2
12:58:29:WU00:FS01:0x22:Reading tar file system.xml.bz2
12:58:29:WU00:FS01:0x22:Digital signatures verified
12:58:29:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:58:29:WU00:FS01:0x22:Version 0.0.13
12:58:29:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
12:58:29:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
12:58:29:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
12:58:29:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
12:58:29:WU00:FS01:0x22:There are 4 platforms available.
12:58:29:WU00:FS01:0x22:Platform 0: Reference
12:58:29:WU00:FS01:0x22:Platform 1: CPU
12:58:29:WU00:FS01:0x22:Platform 2: OpenCL
12:58:29:WU00:FS01:0x22: opencl-device 0 specified
12:58:29:WU00:FS01:0x22:Platform 3: CUDA
12:58:29:WU00:FS01:0x22: cuda-device 0 specified
12:58:34:WU02:FS01:Upload 25.05%
12:58:40:WU02:FS01:Upload 51.48%
12:58:40:WU00:FS01:0x22:Attempting to create CUDA context:
12:58:40:WU00:FS01:0x22: Configuring platform CUDA
12:58:46:WU02:FS01:Upload 77.45%
12:58:48:WU00:FS01:0x22: Using CUDA and gpu 0
12:58:48:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
12:58:49:WU00:FS01:0x22:Checkpoint completed at step 0
12:58:51:WU02:FS01:Upload complete
12:58:51:WU02:FS01:Server responded WORK_ACK (400)
12:58:51:WU02:FS01:Final credit estimate, 488093.00 points
12:58:51:WU02:FS01:Cleaning up
12:59:50:WU01:FS00:0x22:Completed 100000 out of 2500000 steps (4%)
12:59:54:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
14:46:09:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
14:46:09:WU02:FS01:Connecting to assign1.foldingathome.org:80
14:46:09:WU02:FS01:Assigned to work server 140.163.4.200
14:46:09:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
14:46:09:WU02:FS01:Connecting to 140.163.4.200:8080
14:46:10:WU02:FS01:Downloading 13.11MiB
14:46:15:WU01:FS00:0x22:Completed 1525000 out of 2500000 steps (61%)
14:46:16:WU02:FS01:Download 90.08%
14:46:16:WU02:FS01:Download complete
14:46:16:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16478 run:0 clone:3 gen:17 core:0x22 unit:0x00000003000000110000405e00000000
14:47:13:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
14:47:13:WU00:FS01:0x22:Average performance: 267.492 ns/day
14:47:15:WU00:FS01:0x22:Checkpoint completed at step 2500000
14:47:23:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
14:47:23:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
14:47:23:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
14:47:23:WU00:FS01:0x22:Saving result file positions.xtc
14:47:23:WU00:FS01:0x22:Saving result file science.log
14:47:23:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
14:47:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:47:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16473 run:0 clone:1 gen:40 core:0x22 unit:0x00000001000000280000405900000000
14:47:23:WU00:FS01:Uploading 13.46MiB to 140.163.4.200
14:47:23:WU00:FS01:Connecting to 140.163.4.200:8080
14:47:24:WU02:FS01:Starting
14:47:24:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:47:24:WU02:FS01:Started FahCore on PID 5024
14:47:24:WU02:FS01:Core PID:1620
14:47:24:WU02:FS01:FahCore 0x22 started
14:47:24:WU02:FS01:0x22:*********************** Log Started 2021-08-24T14:47:24Z ***********************
14:47:24:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:47:24:WU02:FS01:0x22: Core: Core22
14:47:24:WU02:FS01:0x22: Type: 0x22
14:47:24:WU02:FS01:0x22: Version: 0.0.13
14:47:24:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:47:24:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
14:47:24:WU02:FS01:0x22: Homepage: https://foldingathome.org/
14:47:24:WU02:FS01:0x22: Date: Sep 19 2020
14:47:24:WU02:FS01:0x22: Time: 02:35:58
14:47:24:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:47:24:WU02:FS01:0x22: Branch: core22-0.0.13
14:47:24:WU02:FS01:0x22: Compiler: Visual C++ 2015
14:47:24:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:47:24:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
14:47:24:WU02:FS01:0x22: Platform: win32 10
14:47:24:WU02:FS01:0x22: Bits: 64
14:47:24:WU02:FS01:0x22: Mode: Release
14:47:24:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:47:24:WU02:FS01:0x22: <peastman@stanford.edu>
14:47:24:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 5024 -checkpoint 15
14:47:24:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:47:24:WU02:FS01:0x22: 0 -gpu 0
14:47:24:WU02:FS01:0x22:************************************ libFAH ************************************
14:47:24:WU02:FS01:0x22: Date: Sep 7 2020
14:47:24:WU02:FS01:0x22: Time: 19:09:56
14:47:24:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:47:24:WU02:FS01:0x22: Branch: HEAD
14:47:24:WU02:FS01:0x22:************************************ CBang *************************************
14:47:24:WU02:FS01:0x22: Time: 19:08:30
14:47:24:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:47:24:WU02:FS01:0x22:************************************ System ************************************
14:47:24:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
14:47:24:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
14:47:24:WU02:FS01:0x22: CPUs: 4
14:47:24:WU02:FS01:0x22: Memory: 15.94GiB
14:47:24:WU02:FS01:0x22:Free Memory: 10.81GiB
14:47:24:WU02:FS01:0x22: Threads: WINDOWS_THREADS
14:47:24:WU02:FS01:0x22: OS Version: 6.2
14:47:24:WU02:FS01:0x22:Has Battery: false
14:47:24:WU02:FS01:0x22: On Battery: false
14:47:24:WU02:FS01:0x22: UTC Offset: 3
14:47:24:WU02:FS01:0x22: PID: 1620
14:47:24:WU02:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
14:47:24:WU02:FS01:0x22:************************************ OpenMM ************************************
14:47:24:WU02:FS01:0x22: Revision: 189320d0
14:47:24:WU02:FS01:0x22:********************************************************************************
14:47:24:WU02:FS01:0x22:Project: 16478 (Run 0, Clone 3, Gen 17)
14:47:24:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
14:47:24:WU02:FS01:0x22:Reading tar file core.xml
14:47:24:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
14:47:24:WU02:FS01:0x22:Reading tar file state.xml.bz2
14:47:24:WU02:FS01:0x22:Reading tar file system.xml.bz2
14:47:24:WU02:FS01:0x22:Digital signatures verified
14:47:24:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:47:24:WU02:FS01:0x22:Version 0.0.13
14:47:24:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
14:47:24:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
14:47:24:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
14:47:24:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
14:47:24:WU02:FS01:0x22:There are 4 platforms available.
14:47:24:WU02:FS01:0x22:Platform 0: Reference
14:47:24:WU02:FS01:0x22:Platform 1: CPU
14:47:24:WU02:FS01:0x22:Platform 2: OpenCL
14:47:24:WU02:FS01:0x22: opencl-device 0 specified
14:47:24:WU02:FS01:0x22:Platform 3: CUDA
14:47:24:WU02:FS01:0x22: cuda-device 0 specified
14:47:29:WU00:FS01:Upload 21.35%
14:47:35:WU00:FS01:Upload 45.96%
14:47:36:WU02:FS01:0x22:Attempting to create CUDA context:
14:47:36:WU02:FS01:0x22: Configuring platform CUDA
14:47:41:WU00:FS01:Upload 72.42%
14:47:41:WU02:FS01:0x22: Using CUDA and gpu 0
14:47:41:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
14:47:42:WU02:FS01:0x22:Checkpoint completed at step 0
14:47:47:WU00:FS01:Upload 98.88%
14:47:47:WU00:FS01:Upload complete
14:47:47:WU00:FS01:Server responded WORK_ACK (400)
14:47:47:WU00:FS01:Final credit estimate, 467029.00 points
14:47:47:WU00:FS01:Cleaning up
14:48:07:WU01:FS00:0x22:Completed 1550000 out of 2500000 steps (62%)
14:48:47:WU02:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
15:57:07:WU01:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
15:57:08:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:57:09:WU00:FS00:Assigned to work server 140.163.4.200
15:57:09:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
15:57:09:WU00:FS00:Connecting to 140.163.4.200:8080
15:57:09:WU00:FS00:Downloading 13.11MiB
15:57:10:WU02:FS01:0x22:Completed 1600000 out of 2500000 steps (64%)
15:57:15:WU00:FS00:Download 75.34%
15:57:16:WU00:FS00:Download complete
15:57:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16478 run:1 clone:13 gen:0 core:0x22 unit:0x0000000d000000000000405e00000001
15:58:15:WU02:FS01:0x22:Completed 1625000 out of 2500000 steps (65%)
15:58:17:WU02:FS01:0x22:Checkpoint completed at step 1625000
15:58:58:WU01:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
15:58:58:WU01:FS00:0x22:Average performance: 155.117 ns/day
15:59:00:WU01:FS00:0x22:Checkpoint completed at step 2500000
15:59:08:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
15:59:08:WU01:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
15:59:08:WU01:FS00:0x22:Saving result file checkpointState.xml.bz2
15:59:08:WU01:FS00:0x22:Saving result file positions.xtc
15:59:08:WU01:FS00:0x22:Saving result file science.log
15:59:08:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
15:59:09:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:59:09:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16482 run:0 clone:10 gen:5 core:0x22 unit:0x0000000a000000050000406200000000
15:59:09:WU01:FS00:Uploading 13.47MiB to 140.163.4.200
15:59:09:WU00:FS00:Starting
15:59:09:WU01:FS00:Connecting to 140.163.4.200:8080
15:59:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
15:59:09:WU00:FS00:Started FahCore on PID 4328
15:59:09:WU00:FS00:Core PID:10524
15:59:09:WU00:FS00:FahCore 0x22 started
15:59:10:WU00:FS00:0x22:*********************** Log Started 2021-08-24T15:59:09Z ***********************
15:59:10:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
15:59:10:WU00:FS00:0x22: Core: Core22
15:59:10:WU00:FS00:0x22: Type: 0x22
15:59:10:WU00:FS00:0x22: Version: 0.0.13
15:59:10:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:59:10:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
15:59:10:WU00:FS00:0x22: Homepage: https://foldingathome.org/
15:59:10:WU00:FS00:0x22: Date: Sep 19 2020
15:59:10:WU00:FS00:0x22: Time: 02:35:58
15:59:10:WU00:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:59:10:WU00:FS00:0x22: Branch: core22-0.0.13
15:59:10:WU00:FS00:0x22: Compiler: Visual C++ 2015
15:59:10:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:59:10:WU00:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
15:59:10:WU00:FS00:0x22: Platform: win32 10
15:59:10:WU00:FS00:0x22: Bits: 64
15:59:10:WU00:FS00:0x22: Mode: Release
15:59:10:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:59:10:WU00:FS00:0x22: <peastman@stanford.edu>
15:59:10:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4328 -checkpoint 15
15:59:10:WU00:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
15:59:10:WU00:FS00:0x22: 1 -gpu 1
15:59:10:WU00:FS00:0x22:************************************ libFAH ************************************
15:59:10:WU00:FS00:0x22: Date: Sep 7 2020
15:59:10:WU00:FS00:0x22: Time: 19:09:56
15:59:10:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:59:10:WU00:FS00:0x22: Branch: HEAD
15:59:10:WU00:FS00:0x22:************************************ CBang *************************************
15:59:10:WU00:FS00:0x22: Time: 19:08:30
15:59:10:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:59:10:WU00:FS00:0x22:************************************ System ************************************
15:59:10:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
15:59:10:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
15:59:10:WU00:FS00:0x22: CPUs: 4
15:59:10:WU00:FS00:0x22: Memory: 15.94GiB
15:59:10:WU00:FS00:0x22:Free Memory: 10.72GiB
15:59:10:WU00:FS00:0x22: Threads: WINDOWS_THREADS
15:59:10:WU00:FS00:0x22: OS Version: 6.2
15:59:10:WU00:FS00:0x22:Has Battery: false
15:59:10:WU00:FS00:0x22: On Battery: false
15:59:10:WU00:FS00:0x22: UTC Offset: 3
15:59:10:WU00:FS00:0x22: PID: 10524
15:59:10:WU00:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
15:59:10:WU00:FS00:0x22:************************************ OpenMM ************************************
15:59:10:WU00:FS00:0x22: Revision: 189320d0
15:59:10:WU00:FS00:0x22:********************************************************************************
15:59:10:WU00:FS00:0x22:Project: 16478 (Run 1, Clone 13, Gen 0)
15:59:10:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
15:59:10:WU00:FS00:0x22:Reading tar file core.xml
15:59:10:WU00:FS00:0x22:Reading tar file integrator.xml.bz2
15:59:10:WU00:FS00:0x22:Reading tar file state.xml.bz2
15:59:10:WU00:FS00:0x22:Reading tar file system.xml.bz2
15:59:10:WU00:FS00:0x22:Digital signatures verified
15:59:10:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:59:10:WU00:FS00:0x22:Version 0.0.13
15:59:10:WU00:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
15:59:10:WU00:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
15:59:10:WU00:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
15:59:10:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
15:59:10:WU00:FS00:0x22:There are 4 platforms available.
15:59:10:WU00:FS00:0x22:Platform 0: Reference
15:59:10:WU00:FS00:0x22:Platform 1: CPU
15:59:10:WU00:FS00:0x22:Platform 2: OpenCL
15:59:10:WU00:FS00:0x22: opencl-device 1 specified
15:59:10:WU00:FS00:0x22:Platform 3: CUDA
15:59:10:WU00:FS00:0x22: cuda-device 1 specified
15:59:15:WU01:FS00:Upload 22.73%
15:59:21:WU01:FS00:Upload 48.70%
15:59:22:WU00:FS00:0x22:Attempting to create CUDA context:
15:59:22:WU00:FS00:0x22: Configuring platform CUDA
15:59:22:WU02:FS01:0x22:Completed 1650000 out of 2500000 steps (66%)
15:59:27:WU01:FS00:Upload 74.68%
15:59:28:WU00:FS00:0x22: Using CUDA and gpu 1
15:59:28:WU00:FS00:0x22:Completed 0 out of 2500000 steps (0%)
15:59:29:WU00:FS00:0x22:Checkpoint completed at step 0
15:59:33:WU01:FS00:Upload complete
15:59:33:WU01:FS00:Server responded WORK_ACK (400)
15:59:33:WU01:FS00:Final credit estimate, 372979.00 points
15:59:33:WU01:FS00:Cleaning up
16:00:27:WU02:FS01:0x22:Completed 1675000 out of 2500000 steps (67%)
16:01:20:WU00:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
16:35:11:WU02:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
16:35:12:WU01:FS01:Connecting to assign1.foldingathome.org:80
16:35:13:WU01:FS01:Assigned to work server 140.163.4.200
16:35:13:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
16:35:13:WU01:FS01:Connecting to 140.163.4.200:8080
16:35:13:WU01:FS01:Downloading 13.09MiB
16:35:19:WU01:FS01:Download 77.34%
16:35:20:WU01:FS01:Download complete
16:35:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16474 run:0 clone:11 gen:1 core:0x22 unit:0x0000000b000000010000405a00000000
16:36:16:WU02:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
16:36:16:WU02:FS01:0x22:Average performance: 266.667 ns/day
16:36:18:WU02:FS01:0x22:Checkpoint completed at step 2500000
16:36:25:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
16:36:25:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
16:36:25:WU02:FS01:0x22:Saving result file checkpointState.xml.bz2
16:36:25:WU02:FS01:0x22:Saving result file positions.xtc
16:36:25:WU02:FS01:0x22:Saving result file science.log
16:36:25:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:36:26:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:36:26:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:16478 run:0 clone:3 gen:17 core:0x22 unit:0x00000003000000110000405e00000000
16:36:26:WU02:FS01:Uploading 13.47MiB to 140.163.4.200
16:36:26:WU02:FS01:Connecting to 140.163.4.200:8080
16:36:26:WU01:FS01:Starting
16:36:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:36:26:WU01:FS01:Started FahCore on PID 10336
16:36:26:WU01:FS01:Core PID:10008
16:36:26:WU01:FS01:FahCore 0x22 started
16:36:27:WU01:FS01:0x22:*********************** Log Started 2021-08-24T16:36:26Z ***********************
16:36:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:36:27:WU01:FS01:0x22: Core: Core22
16:36:27:WU01:FS01:0x22: Type: 0x22
16:36:27:WU01:FS01:0x22: Version: 0.0.13
16:36:27:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:36:27:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
16:36:27:WU01:FS01:0x22: Homepage: https://foldingathome.org/
16:36:27:WU01:FS01:0x22: Date: Sep 19 2020
16:36:27:WU01:FS01:0x22: Time: 02:35:58
16:36:27:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
16:36:27:WU01:FS01:0x22: Branch: core22-0.0.13
16:36:27:WU01:FS01:0x22: Compiler: Visual C++ 2015
16:36:27:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:36:27:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
16:36:27:WU01:FS01:0x22: Platform: win32 10
16:36:27:WU01:FS01:0x22: Bits: 64
16:36:27:WU01:FS01:0x22: Mode: Release
16:36:27:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:36:27:WU01:FS01:0x22: <peastman@stanford.edu>
16:36:27:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 10336 -checkpoint 15
16:36:27:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:36:27:WU01:FS01:0x22: 0 -gpu 0
16:36:27:WU01:FS01:0x22:************************************ libFAH ************************************
16:36:27:WU01:FS01:0x22: Date: Sep 7 2020
16:36:27:WU01:FS01:0x22: Time: 19:09:56
16:36:27:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:36:27:WU01:FS01:0x22: Branch: HEAD
16:36:27:WU01:FS01:0x22:************************************ CBang *************************************
16:36:27:WU01:FS01:0x22: Time: 19:08:30
16:36:27:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:36:27:WU01:FS01:0x22:************************************ System ************************************
16:36:27:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
16:36:27:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:36:27:WU01:FS01:0x22: CPUs: 4
16:36:27:WU01:FS01:0x22: Memory: 15.94GiB
16:36:27:WU01:FS01:0x22:Free Memory: 10.77GiB
16:36:27:WU01:FS01:0x22: Threads: WINDOWS_THREADS
16:36:27:WU01:FS01:0x22: OS Version: 6.2
16:36:27:WU01:FS01:0x22:Has Battery: false
16:36:27:WU01:FS01:0x22: On Battery: false
16:36:27:WU01:FS01:0x22: UTC Offset: 3
16:36:27:WU01:FS01:0x22: PID: 10008
16:36:27:WU01:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
16:36:27:WU01:FS01:0x22:************************************ OpenMM ************************************
16:36:27:WU01:FS01:0x22: Revision: 189320d0
16:36:27:WU01:FS01:0x22:********************************************************************************
16:36:27:WU01:FS01:0x22:Project: 16474 (Run 0, Clone 11, Gen 1)
16:36:27:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
16:36:27:WU01:FS01:0x22:Reading tar file core.xml
16:36:27:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
16:36:27:WU01:FS01:0x22:Reading tar file state.xml.bz2
16:36:27:WU01:FS01:0x22:Reading tar file system.xml.bz2
16:36:27:WU01:FS01:0x22:Digital signatures verified
16:36:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:36:27:WU01:FS01:0x22:Version 0.0.13
16:36:27:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
16:36:27:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
16:36:27:WU01:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
16:36:27:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
16:36:27:WU01:FS01:0x22:There are 4 platforms available.
16:36:27:WU01:FS01:0x22:Platform 0: Reference
16:36:27:WU01:FS01:0x22:Platform 1: CPU
16:36:27:WU01:FS01:0x22:Platform 2: OpenCL
16:36:27:WU01:FS01:0x22: opencl-device 0 specified
16:36:27:WU01:FS01:0x22:Platform 3: CUDA
16:36:27:WU01:FS01:0x22: cuda-device 0 specified
16:36:32:WU02:FS01:Upload 23.66%
16:36:38:WU02:FS01:Upload 49.63%
16:36:38:WU00:FS00:0x22:Completed 500000 out of 2500000 steps (20%)
16:36:39:WU01:FS01:0x22:Attempting to create CUDA context:
16:36:39:WU01:FS01:0x22: Configuring platform CUDA
16:36:39:WU00:FS00:0x22:Checkpoint completed at step 500000
16:36:44:WU02:FS01:Upload 75.61%
16:36:46:WU01:FS01:0x22: Using CUDA and gpu 0
16:36:46:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
16:36:47:WU01:FS01:0x22:Checkpoint completed at step 0
16:36:49:WU02:FS01:Upload complete
16:36:49:WU02:FS01:Server responded WORK_ACK (400)
16:36:49:WU02:FS01:Final credit estimate, 488826.00 points
16:36:49:WU02:FS01:Cleaning up
16:37:52:WU01:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
18:24:12:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
18:24:13:WU02:FS01:Connecting to assign1.foldingathome.org:80
18:24:14:WU02:FS01:Assigned to work server 140.163.4.200
18:24:14:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
18:24:14:WU02:FS01:Connecting to 140.163.4.200:8080
18:24:14:WU02:FS01:Downloading 13.09MiB
18:24:20:WU02:FS01:Download 75.90%
18:24:21:WU02:FS01:Download complete
18:24:21:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16475 run:0 clone:1 gen:49 core:0x22 unit:0x00000001000000310000405b00000000
18:24:28:WU00:FS00:0x22:Completed 1950000 out of 2500000 steps (78%)
18:25:17:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
18:25:17:WU01:FS01:0x22:Average performance: 267.492 ns/day
18:25:18:WU01:FS01:0x22:Checkpoint completed at step 2500000
18:25:26:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:25:26:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
18:25:26:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
18:25:26:WU01:FS01:0x22:Saving result file positions.xtc
18:25:26:WU01:FS01:0x22:Saving result file science.log
18:25:26:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:25:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:25:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16474 run:0 clone:11 gen:1 core:0x22 unit:0x0000000b000000010000405a00000000
18:25:27:WU01:FS01:Uploading 13.46MiB to 140.163.4.200
18:25:27:WU01:FS01:Connecting to 140.163.4.200:8080
18:25:27:WU02:FS01:Starting
18:25:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:25:27:WU02:FS01:Started FahCore on PID 4572
18:25:27:WU02:FS01:Core PID:3476
18:25:27:WU02:FS01:FahCore 0x22 started
18:25:28:WU02:FS01:0x22:*********************** Log Started 2021-08-24T18:25:27Z ***********************
18:25:28:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:25:28:WU02:FS01:0x22: Core: Core22
18:25:28:WU02:FS01:0x22: Type: 0x22
18:25:28:WU02:FS01:0x22: Version: 0.0.13
18:25:28:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:25:28:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
18:25:28:WU02:FS01:0x22: Homepage: https://foldingathome.org/
18:25:28:WU02:FS01:0x22: Date: Sep 19 2020
18:25:28:WU02:FS01:0x22: Time: 02:35:58
18:25:28:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:25:28:WU02:FS01:0x22: Branch: core22-0.0.13
18:25:28:WU02:FS01:0x22: Compiler: Visual C++ 2015
18:25:28:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:25:28:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
18:25:28:WU02:FS01:0x22: Platform: win32 10
18:25:28:WU02:FS01:0x22: Bits: 64
18:25:28:WU02:FS01:0x22: Mode: Release
18:25:28:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:25:28:WU02:FS01:0x22: <peastman@stanford.edu>
18:25:28:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 4572 -checkpoint 15
18:25:28:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:25:28:WU02:FS01:0x22: 0 -gpu 0
18:25:28:WU02:FS01:0x22:************************************ libFAH ************************************
18:25:28:WU02:FS01:0x22: Date: Sep 7 2020
18:25:28:WU02:FS01:0x22: Time: 19:09:56
18:25:28:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:25:28:WU02:FS01:0x22: Branch: HEAD
18:25:28:WU02:FS01:0x22:************************************ CBang *************************************
18:25:28:WU02:FS01:0x22: Time: 19:08:30
18:25:28:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:25:28:WU02:FS01:0x22:************************************ System ************************************
18:25:28:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
18:25:28:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:25:28:WU02:FS01:0x22: CPUs: 4
18:25:28:WU02:FS01:0x22: Memory: 15.94GiB
18:25:28:WU02:FS01:0x22:Free Memory: 10.62GiB
18:25:28:WU02:FS01:0x22: Threads: WINDOWS_THREADS
18:25:28:WU02:FS01:0x22: OS Version: 6.2
18:25:28:WU02:FS01:0x22:Has Battery: false
18:25:28:WU02:FS01:0x22: On Battery: false
18:25:28:WU02:FS01:0x22: UTC Offset: 3
18:25:28:WU02:FS01:0x22: PID: 3476
18:25:28:WU02:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
18:25:28:WU02:FS01:0x22:************************************ OpenMM ************************************
18:25:28:WU02:FS01:0x22: Revision: 189320d0
18:25:28:WU02:FS01:0x22:********************************************************************************
18:25:28:WU02:FS01:0x22:Project: 16475 (Run 0, Clone 1, Gen 49)
18:25:28:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:25:28:WU02:FS01:0x22:Reading tar file core.xml
18:25:28:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
18:25:28:WU02:FS01:0x22:Reading tar file state.xml.bz2
18:25:28:WU02:FS01:0x22:Reading tar file system.xml.bz2
18:25:28:WU02:FS01:0x22:Digital signatures verified
18:25:28:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:25:28:WU02:FS01:0x22:Version 0.0.13
18:25:28:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
18:25:28:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
18:25:28:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
18:25:28:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
18:25:28:WU02:FS01:0x22:There are 4 platforms available.
18:25:28:WU02:FS01:0x22:Platform 0: Reference
18:25:28:WU02:FS01:0x22:Platform 1: CPU
18:25:28:WU02:FS01:0x22:Platform 2: OpenCL
18:25:28:WU02:FS01:0x22: opencl-device 0 specified
18:25:28:WU02:FS01:0x22:Platform 3: CUDA
18:25:28:WU02:FS01:0x22: cuda-device 0 specified
18:25:33:WU01:FS01:Upload 23.67%
18:25:39:WU01:FS01:Upload 49.67%
18:25:40:WU02:FS01:0x22:Attempting to create CUDA context:
18:25:40:WU02:FS01:0x22: Configuring platform CUDA
18:25:45:WU01:FS01:Upload 76.12%
18:25:48:WU02:FS01:0x22: Using CUDA and gpu 0
18:25:48:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
18:25:49:WU02:FS01:0x22:Checkpoint completed at step 0
18:25:50:WU01:FS01:Upload complete
18:25:50:WU01:FS01:Server responded WORK_ACK (400)
18:25:50:WU01:FS01:Final credit estimate, 486253.00 points
18:25:50:WU01:FS01:Cleaning up
18:26:20:WU00:FS00:0x22:Completed 1975000 out of 2500000 steps (79%)
18:26:55:WU02:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
19:03:31:WU00:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
19:03:32:WU01:FS00:Connecting to assign1.foldingathome.org:80
19:03:33:WU01:FS00:Assigned to work server 140.163.4.200
19:03:33:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
19:03:33:WU01:FS00:Connecting to 140.163.4.200:8080
19:03:33:WU01:FS00:Downloading 13.09MiB
19:03:39:WU01:FS00:Download 89.74%
19:03:39:WU01:FS00:Download complete
19:03:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16473 run:1 clone:7 gen:12 core:0x22 unit:0x000000070000000c0000405900000001
19:03:42:WU02:FS01:0x22:Completed 875000 out of 2500000 steps (35%)
19:03:44:WU02:FS01:0x22:Checkpoint completed at step 875000
19:04:49:WU02:FS01:0x22:Completed 900000 out of 2500000 steps (36%)
19:05:22:WU00:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
19:05:22:WU00:FS00:0x22:Average performance: 155.676 ns/day
19:05:24:WU00:FS00:0x22:Checkpoint completed at step 2500000
19:05:32:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
19:05:32:WU00:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
19:05:32:WU00:FS00:0x22:Saving result file checkpointState.xml.bz2
19:05:32:WU00:FS00:0x22:Saving result file positions.xtc
19:05:32:WU00:FS00:0x22:Saving result file science.log
19:05:32:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:05:33:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:05:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16478 run:1 clone:13 gen:0 core:0x22 unit:0x0000000d000000000000405e00000001
19:05:33:WU00:FS00:Uploading 13.47MiB to 140.163.4.200
19:05:33:WU01:FS00:Starting
19:05:33:WU00:FS00:Connecting to 140.163.4.200:8080
19:05:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
19:05:33:WU01:FS00:Started FahCore on PID 6160
19:05:33:WU01:FS00:Core PID:10164
19:05:33:WU01:FS00:FahCore 0x22 started
19:05:33:WU01:FS00:0x22:*********************** Log Started 2021-08-24T19:05:33Z ***********************
19:05:33:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
19:05:33:WU01:FS00:0x22: Core: Core22
19:05:33:WU01:FS00:0x22: Type: 0x22
19:05:33:WU01:FS00:0x22: Version: 0.0.13
19:05:33:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:05:33:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
19:05:33:WU01:FS00:0x22: Homepage: https://foldingathome.org/
19:05:33:WU01:FS00:0x22: Date: Sep 19 2020
19:05:33:WU01:FS00:0x22: Time: 02:35:58
19:05:33:WU01:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:05:33:WU01:FS00:0x22: Branch: core22-0.0.13
19:05:33:WU01:FS00:0x22: Compiler: Visual C++ 2015
19:05:33:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:05:33:WU01:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
19:05:33:WU01:FS00:0x22: Platform: win32 10
19:05:33:WU01:FS00:0x22: Bits: 64
19:05:33:WU01:FS00:0x22: Mode: Release
19:05:33:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:05:33:WU01:FS00:0x22: <peastman@stanford.edu>
19:05:33:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 6160 -checkpoint 15
19:05:33:WU01:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
19:05:33:WU01:FS00:0x22: 1 -gpu 1
19:05:33:WU01:FS00:0x22:************************************ libFAH ************************************
19:05:33:WU01:FS00:0x22: Date: Sep 7 2020
19:05:33:WU01:FS00:0x22: Time: 19:09:56
19:05:33:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:05:33:WU01:FS00:0x22: Branch: HEAD
19:05:33:WU01:FS00:0x22:************************************ CBang *************************************
19:05:33:WU01:FS00:0x22: Time: 19:08:30
19:05:33:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:05:33:WU01:FS00:0x22:************************************ System ************************************
19:05:33:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
19:05:33:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:05:33:WU01:FS00:0x22: CPUs: 4
19:05:33:WU01:FS00:0x22: Memory: 15.94GiB
19:05:33:WU01:FS00:0x22:Free Memory: 10.78GiB
19:05:33:WU01:FS00:0x22: Threads: WINDOWS_THREADS
19:05:33:WU01:FS00:0x22: OS Version: 6.2
19:05:33:WU01:FS00:0x22:Has Battery: false
19:05:33:WU01:FS00:0x22: On Battery: false
19:05:33:WU01:FS00:0x22: UTC Offset: 3
19:05:33:WU01:FS00:0x22: PID: 10164
19:05:33:WU01:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
19:05:33:WU01:FS00:0x22:************************************ OpenMM ************************************
19:05:33:WU01:FS00:0x22: Revision: 189320d0
19:05:33:WU01:FS00:0x22:********************************************************************************
19:05:33:WU01:FS00:0x22:Project: 16473 (Run 1, Clone 7, Gen 12)
19:05:33:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
19:05:33:WU01:FS00:0x22:Reading tar file core.xml
19:05:33:WU01:FS00:0x22:Reading tar file integrator.xml.bz2
19:05:33:WU01:FS00:0x22:Reading tar file state.xml.bz2
19:05:33:WU01:FS00:0x22:Reading tar file system.xml.bz2
19:05:33:WU01:FS00:0x22:Digital signatures verified
19:05:33:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
19:05:33:WU01:FS00:0x22:Version 0.0.13
19:05:33:WU01:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
19:05:33:WU01:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:05:33:WU01:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
19:05:33:WU01:FS00:0x22: Global context and integrator variables write interval: disabled
19:05:33:WU01:FS00:0x22:There are 4 platforms available.
19:05:33:WU01:FS00:0x22:Platform 0: Reference
19:05:33:WU01:FS00:0x22:Platform 1: CPU
19:05:33:WU01:FS00:0x22:Platform 2: OpenCL
19:05:33:WU01:FS00:0x22: opencl-device 1 specified
19:05:33:WU01:FS00:0x22:Platform 3: CUDA
19:05:33:WU01:FS00:0x22: cuda-device 1 specified
19:05:39:WU00:FS00:Upload 25.06%
19:05:45:WU00:FS00:Upload 51.06%
19:05:45:WU01:FS00:0x22:Attempting to create CUDA context:
19:05:45:WU01:FS00:0x22: Configuring platform CUDA
19:05:51:WU00:FS00:Upload 77.51%
19:05:51:WU01:FS00:0x22: Using CUDA and gpu 1
19:05:51:WU01:FS00:0x22:Completed 0 out of 2500000 steps (0%)
19:05:52:WU01:FS00:0x22:Checkpoint completed at step 0
19:05:54:WU02:FS01:0x22:Completed 925000 out of 2500000 steps (37%)
19:05:56:WU00:FS00:Upload complete
19:05:56:WU00:FS00:Server responded WORK_ACK (400)
19:05:56:WU00:FS00:Final credit estimate, 374294.00 points
19:05:56:WU00:FS00:Cleaning up
19:06:58:WU02:FS01:0x22:Completed 950000 out of 2500000 steps (38%)
19:07:43:WU01:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
20:12:59:WU02:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
20:13:00:WU00:FS01:Connecting to assign1.foldingathome.org:80
20:13:00:WU00:FS01:Assigned to work server 140.163.4.200
20:13:00:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
20:13:00:WU00:FS01:Connecting to 140.163.4.200:8080
20:13:01:WU00:FS01:Downloading 13.11MiB
20:13:01:WU01:FS00:0x22:Completed 900000 out of 2500000 steps (36%)
20:13:07:WU00:FS01:Download 79.14%
20:13:08:WU00:FS01:Download complete
20:13:08:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16476 run:0 clone:10 gen:13 core:0x22 unit:0x0000000a0000000d0000405c00000000
20:14:04:WU02:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
20:14:04:WU02:FS01:0x22:Average performance: 267.492 ns/day
20:14:06:WU02:FS01:0x22:Checkpoint completed at step 2500000
20:14:14:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
20:14:14:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
20:14:14:WU02:FS01:0x22:Saving result file checkpointState.xml.bz2
20:14:14:WU02:FS01:0x22:Saving result file positions.xtc
20:14:14:WU02:FS01:0x22:Saving result file science.log
20:14:14:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:14:14:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:14:14:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:16475 run:0 clone:1 gen:49 core:0x22 unit:0x00000001000000310000405b00000000
20:14:14:WU02:FS01:Uploading 13.47MiB to 140.163.4.200
20:14:14:WU02:FS01:Connecting to 140.163.4.200:8080
20:14:15:WU00:FS01:Starting
20:14:15:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:14:15:WU00:FS01:Started FahCore on PID 7348
20:14:15:WU00:FS01:Core PID:1080Re: Units uploaded but no updates in the stats
20:14:15:WU00:FS01:FahCore 0x22 started
20:14:15:WU00:FS01:0x22:*********************** Log Started 2021-08-24T20:14:15Z ***********************
20:14:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:14:15:WU00:FS01:0x22: Core: Core22
20:14:15:WU00:FS01:0x22: Type: 0x22
20:14:15:WU00:FS01:0x22: Version: 0.0.13
20:14:15:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:14:15:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
20:14:15:WU00:FS01:0x22: Homepage: https://foldingathome.org/
20:14:15:WU00:FS01:0x22: Date: Sep 19 2020
20:14:15:WU00:FS01:0x22: Time: 02:35:58
20:14:15:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:14:15:WU00:FS01:0x22: Branch: core22-0.0.13
20:14:15:WU00:FS01:0x22: Compiler: Visual C++ 2015
20:14:15:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:14:15:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
20:14:15:WU00:FS01:0x22: Platform: win32 10
20:14:15:WU00:FS01:0x22: Bits: 64
20:14:15:WU00:FS01:0x22: Mode: Release
20:14:15:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:14:15:WU00:FS01:0x22: <peastman@stanford.edu>
20:14:15:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7348 -checkpoint 15
20:14:15:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:14:15:WU00:FS01:0x22: 0 -gpu 0
20:14:15:WU00:FS01:0x22:************************************ libFAH ************************************
20:14:15:WU00:FS01:0x22: Date: Sep 7 2020
20:14:15:WU00:FS01:0x22: Time: 19:09:56
20:14:15:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:14:15:WU00:FS01:0x22: Branch: HEAD
20:14:15:WU00:FS01:0x22:************************************ CBang *************************************
20:14:15:WU00:FS01:0x22: Time: 19:08:30
20:14:15:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:14:15:WU00:FS01:0x22:************************************ System ************************************
20:14:15:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
20:14:15:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:14:15:WU00:FS01:0x22: CPUs: 4
20:14:15:WU00:FS01:0x22: Memory: 15.94GiB
20:14:15:WU00:FS01:0x22:Free Memory: 10.80GiB
20:14:15:WU00:FS01:0x22: Threads: WINDOWS_THREADS
20:14:15:WU00:FS01:0x22: OS Version: 6.2
20:14:15:WU00:FS01:0x22:Has Battery: false
20:14:15:WU00:FS01:0x22: On Battery: false
20:14:15:WU00:FS01:0x22: UTC Offset: 3
20:14:15:WU00:FS01:0x22: PID: 1080
20:14:15:WU00:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
20:14:15:WU00:FS01:0x22:************************************ OpenMM ************************************
20:14:15:WU00:FS01:0x22: Revision: 189320d0
20:14:15:WU00:FS01:0x22:********************************************************************************
20:14:15:WU00:FS01:0x22:Project: 16476 (Run 0, Clone 10, Gen 13)
20:14:15:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
20:14:15:WU00:FS01:0x22:Reading tar file core.xml
20:14:15:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
20:14:15:WU00:FS01:0x22:Reading tar file state.xml.bz2
20:14:15:WU00:FS01:0x22:Reading tar file system.xml.bz2
20:14:15:WU00:FS01:0x22:Digital signatures verified
20:14:15:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:14:15:WU00:FS01:0x22:Version 0.0.13
20:14:15:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
20:14:15:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
20:14:15:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
20:14:15:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
20:14:15:WU00:FS01:0x22:There are 4 platforms available.
20:14:15:WU00:FS01:0x22:Platform 0: Reference
20:14:15:WU00:FS01:0x22:Platform 1: CPU
20:14:15:WU00:FS01:0x22:Platform 2: OpenCL
20:14:15:WU00:FS01:0x22: opencl-device 0 specified
20:14:15:WU00:FS01:0x22:Platform 3: CUDA
20:14:15:WU00:FS01:0x22: cuda-device 0 specified
20:14:20:WU02:FS01:Upload 21.81%
20:14:26:WU02:FS01:Upload 46.41%
20:14:27:WU00:FS01:0x22:Attempting to create CUDA context:
20:14:27:WU00:FS01:0x22: Configuring platform CUDA
20:14:32:WU02:FS01:Upload 72.40%
20:14:32:WU00:FS01:0x22: Using CUDA and gpu 0
20:14:32:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
20:14:33:WU00:FS01:0x22:Checkpoint completed at step 0
20:14:38:WU02:FS01:Upload 98.86%
20:14:38:WU02:FS01:Upload complete
20:14:38:WU02:FS01:Server responded WORK_ACK (400)
20:14:38:WU02:FS01:Final credit estimate, 487290.00 points
20:14:38:WU02:FS01:Cleaning up
20:14:53:WU01:FS00:0x22:Completed 925000 out of 2500000 steps (37%)
20:15:37:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
22:01:47:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
22:01:48:WU02:FS01:Connecting to assign1.foldingathome.org:80
22:01:49:WU02:FS01:Assigned to work server 140.163.4.200
22:01:49:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
22:01:49:WU02:FS01:Connecting to 140.163.4.200:8080
22:01:49:WU02:FS01:Downloading 13.09MiB
22:01:55:WU02:FS01:Download 78.76%
22:01:56:WU02:FS01:Download complete
22:01:56:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16475 run:0 clone:15 gen:0 core:0x22 unit:0x0000000f000000000000405b00000000
22:02:52:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
22:02:52:WU00:FS01:0x22:Average performance: 267.492 ns/day
22:02:54:WU00:FS01:0x22:Checkpoint completed at step 2500000
22:03:01:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
22:03:01:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
22:03:01:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
22:03:01:WU00:FS01:0x22:Saving result file positions.xtc
22:03:01:WU00:FS01:0x22:Saving result file science.log
22:03:01:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:03:02:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:03:02:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16476 run:0 clone:10 gen:13 core:0x22 unit:0x0000000a0000000d0000405c00000000
22:03:02:WU00:FS01:Uploading 13.47MiB to 140.163.4.200
22:03:02:WU02:FS01:Starting
22:03:02:WU00:FS01:Connecting to 140.163.4.200:8080
22:03:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:03:02:WU02:FS01:Started FahCore on PID 7240
22:03:02:WU02:FS01:Core PID:8428
22:03:02:WU02:FS01:FahCore 0x22 started
22:03:03:WU02:FS01:0x22:*********************** Log Started 2021-08-24T22:03:02Z ***********************
22:03:03:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:03:03:WU02:FS01:0x22: Core: Core22
22:03:03:WU02:FS01:0x22: Type: 0x22
22:03:03:WU02:FS01:0x22: Version: 0.0.13
22:03:03:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:03:03:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
22:03:03:WU02:FS01:0x22: Homepage: https://foldingathome.org/
22:03:03:WU02:FS01:0x22: Date: Sep 19 2020
22:03:03:WU02:FS01:0x22: Time: 02:35:58
22:03:03:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:03:03:WU02:FS01:0x22: Branch: core22-0.0.13
22:03:03:WU02:FS01:0x22: Compiler: Visual C++ 2015
22:03:03:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:03:03:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
22:03:03:WU02:FS01:0x22: Platform: win32 10
22:03:03:WU02:FS01:0x22: Bits: 64
22:03:03:WU02:FS01:0x22: Mode: Release
22:03:03:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:03:03:WU02:FS01:0x22: <peastman@stanford.edu>
22:03:03:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 7240 -checkpoint 15
22:03:03:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
22:03:03:WU02:FS01:0x22: 0 -gpu 0
22:03:03:WU02:FS01:0x22:************************************ libFAH ************************************
22:03:03:WU02:FS01:0x22: Date: Sep 7 2020
22:03:03:WU02:FS01:0x22: Time: 19:09:56
22:03:03:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:03:03:WU02:FS01:0x22: Branch: HEAD
22:03:03:WU02:FS01:0x22:************************************ CBang *************************************
22:03:03:WU02:FS01:0x22: Time: 19:08:30
22:03:03:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:03:03:WU02:FS01:0x22:************************************ System ************************************
22:03:03:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
22:03:03:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:03:03:WU02:FS01:0x22: CPUs: 4
22:03:03:WU02:FS01:0x22: Memory: 15.94GiB
22:03:03:WU02:FS01:0x22:Free Memory: 10.70GiB
22:03:03:WU02:FS01:0x22: Threads: WINDOWS_THREADS
22:03:03:WU02:FS01:0x22: OS Version: 6.2
22:03:03:WU02:FS01:0x22:Has Battery: false
22:03:03:WU02:FS01:0x22: On Battery: false
22:03:03:WU02:FS01:0x22: UTC Offset: 3
22:03:03:WU02:FS01:0x22: PID: 8428
22:03:03:WU02:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
22:03:03:WU02:FS01:0x22:************************************ OpenMM ************************************
22:03:03:WU02:FS01:0x22: Revision: 189320d0
22:03:03:WU02:FS01:0x22:********************************************************************************
22:03:03:WU02:FS01:0x22:Project: 16475 (Run 0, Clone 15, Gen 0)
22:03:03:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
22:03:03:WU02:FS01:0x22:Reading tar file core.xml
22:03:03:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
22:03:03:WU02:FS01:0x22:Reading tar file state.xml.bz2
22:03:03:WU02:FS01:0x22:Reading tar file system.xml.bz2
22:03:03:WU02:FS01:0x22:Digital signatures verified
22:03:03:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:03:03:WU02:FS01:0x22:Version 0.0.13
22:03:03:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
22:03:03:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
22:03:03:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
22:03:03:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
22:03:03:WU02:FS01:0x22:There are 4 platforms available.
22:03:03:WU02:FS01:0x22:Platform 0: Reference
22:03:03:WU02:FS01:0x22:Platform 1: CPU
22:03:03:WU02:FS01:0x22:Platform 2: OpenCL
22:03:03:WU02:FS01:0x22: opencl-device 0 specified
22:03:03:WU02:FS01:0x22:Platform 3: CUDA
22:03:03:WU02:FS01:0x22: cuda-device 0 specified
22:03:08:WU00:FS01:Upload 23.19%
22:03:09:WU01:FS00:0x22:Completed 2375000 out of 2500000 steps (95%)
22:03:11:WU01:FS00:0x22:Checkpoint completed at step 2375000
22:03:14:WU00:FS01:Upload 48.24%
22:03:15:WU02:FS01:0x22:Attempting to create CUDA context:
22:03:15:WU02:FS01:0x22: Configuring platform CUDA
22:03:20:WU00:FS01:Upload 74.22%
22:03:22:WU02:FS01:0x22: Using CUDA and gpu 0
22:03:22:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
22:03:23:WU02:FS01:0x22:Checkpoint completed at step 0
22:03:26:WU00:FS01:Upload complete
22:03:26:WU00:FS01:Server responded WORK_ACK (400)
22:03:26:WU00:FS01:Final credit estimate, 492472.00 points
22:03:26:WU00:FS01:Cleaning up
22:04:27:WU02:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
22:10:37:WU01:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
22:10:38:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:10:38:WU00:FS00:Assigned to work server 140.163.4.200
22:10:38:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
22:10:38:WU00:FS00:Connecting to 140.163.4.200:8080
22:10:39:WU00:FS00:Downloading 13.11MiB
22:10:45:WU00:FS00:Download 88.19%
22:10:45:WU00:FS00:Download complete
22:10:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16477 run:0 clone:10 gen:8 core:0x22 unit:0x0000000a000000080000405d00000000
22:10:57:WU02:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
22:12:01:WU02:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
22:12:29:WU01:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
22:12:29:WU01:FS00:0x22:Average performance: 154.839 ns/day
22:12:31:WU01:FS00:0x22:Checkpoint completed at step 2500000
22:12:39:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
22:12:39:WU01:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
22:12:39:WU01:FS00:0x22:Saving result file checkpointState.xml.bz2
22:12:39:WU01:FS00:0x22:Saving result file positions.xtc
22:12:39:WU01:FS00:0x22:Saving result file science.log
22:12:39:WU01:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:12:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:12:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16473 run:1 clone:7 gen:12 core:0x22 unit:0x000000070000000c0000405900000001
22:12:39:WU01:FS00:Uploading 13.46MiB to 140.163.4.200
22:12:39:WU01:FS00:Connecting to 140.163.4.200:8080
22:12:40:WU00:FS00:Starting
22:12:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
22:12:40:WU00:FS00:Started FahCore on PID 11112
22:12:40:WU00:FS00:Core PID:10560
22:12:40:WU00:FS00:FahCore 0x22 started
22:12:40:WU00:FS00:0x22:*********************** Log Started 2021-08-24T22:12:40Z ***********************
22:12:40:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
22:12:40:WU00:FS00:0x22: Core: Core22
22:12:40:WU00:FS00:0x22: Type: 0x22
22:12:40:WU00:FS00:0x22: Version: 0.0.13
22:12:40:WU00:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:12:40:WU00:FS00:0x22: Copyright: 2020 foldingathome.org
22:12:40:WU00:FS00:0x22: Homepage: https://foldingathome.org/
22:12:40:WU00:FS00:0x22: Date: Sep 19 2020
22:12:40:WU00:FS00:0x22: Time: 02:35:58
22:12:40:WU00:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
22:12:40:WU00:FS00:0x22: Branch: core22-0.0.13
22:12:40:WU00:FS00:0x22: Compiler: Visual C++ 2015
22:12:40:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
22:12:40:WU00:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
22:12:40:WU00:FS00:0x22: Platform: win32 10
22:12:40:WU00:FS00:0x22: Bits: 64
22:12:40:WU00:FS00:0x22: Mode: Release
22:12:40:WU00:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
22:12:40:WU00:FS00:0x22: <peastman@stanford.edu>
22:12:40:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 11112 -checkpoint 15
22:12:40:WU00:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
22:12:40:WU00:FS00:0x22: 1 -gpu 1
22:12:40:WU00:FS00:0x22:************************************ libFAH ************************************
22:12:40:WU00:FS00:0x22: Date: Sep 7 2020
22:12:40:WU00:FS00:0x22: Time: 19:09:56
22:12:40:WU00:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
22:12:40:WU00:FS00:0x22: Branch: HEAD
22:12:40:WU00:FS00:0x22:************************************ CBang *************************************
22:12:40:WU00:FS00:0x22: Time: 19:08:30
22:12:40:WU00:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
22:12:40:WU00:FS00:0x22:************************************ System ************************************
22:12:40:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
22:12:40:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:12:40:WU00:FS00:0x22: CPUs: 4
22:12:40:WU00:FS00:0x22: Memory: 15.94GiB
22:12:40:WU00:FS00:0x22:Free Memory: 10.71GiB
22:12:40:WU00:FS00:0x22: Threads: WINDOWS_THREADS
22:12:40:WU00:FS00:0x22: OS Version: 6.2
22:12:40:WU00:FS00:0x22:Has Battery: false
22:12:40:WU00:FS00:0x22: On Battery: false
22:12:40:WU00:FS00:0x22: UTC Offset: 3
22:12:40:WU00:FS00:0x22: PID: 10560
22:12:40:WU00:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
22:12:40:WU00:FS00:0x22:************************************ OpenMM ************************************
22:12:40:WU00:FS00:0x22: Revision: 189320d0
22:12:40:WU00:FS00:0x22:********************************************************************************
22:12:40:WU00:FS00:0x22:Project: 16477 (Run 0, Clone 10, Gen 8)
22:12:40:WU00:FS00:0x22:Unit: 0x00000000000000000000000000000000
22:12:40:WU00:FS00:0x22:Reading tar file core.xml
22:12:40:WU00:FS00:0x22:Reading tar file integrator.xml.bz2
22:12:40:WU00:FS00:0x22:Reading tar file state.xml.bz2
22:12:40:WU00:FS00:0x22:Reading tar file system.xml.bz2
22:12:40:WU00:FS00:0x22:Digital signatures verified
22:12:40:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
22:12:40:WU00:FS00:0x22:Version 0.0.13
22:12:40:WU00:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
22:12:40:WU00:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
22:12:40:WU00:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
22:12:40:WU00:FS00:0x22: Global context and integrator variables write interval: disabled
22:12:40:WU00:FS00:0x22:There are 4 platforms available.
22:12:40:WU00:FS00:0x22:Platform 0: Reference
22:12:40:WU00:FS00:0x22:Platform 1: CPU
22:12:40:WU00:FS00:0x22:Platform 2: OpenCL
22:12:40:WU00:FS00:0x22: opencl-device 1 specified
22:12:40:WU00:FS00:0x22:Platform 3: CUDA
22:12:40:WU00:FS00:0x22: cuda-device 1 specified
22:12:45:WU01:FS00:Upload 21.37%
22:12:51:WU01:FS00:Upload 47.37%
22:12:52:WU00:FS00:0x22:Attempting to create CUDA context:
22:12:52:WU00:FS00:0x22: Configuring platform CUDA
22:12:57:WU01:FS00:Upload 73.85%
22:12:58:WU00:FS00:0x22: Using CUDA and gpu 1
22:12:58:WU00:FS00:0x22:Completed 0 out of 2500000 steps (0%)
22:12:59:WU00:FS00:0x22:Checkpoint completed at step 0
22:13:03:WU01:FS00:Upload 100.00%
22:13:03:WU01:FS00:Upload complete
22:13:03:WU01:FS00:Server responded WORK_ACK (400)
22:13:03:WU01:FS00:Final credit estimate, 356616.00 points
22:13:03:WU01:FS00:Cleaning up
22:13:06:WU02:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
22:14:11:WU02:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
22:14:13:WU02:FS01:0x22:Checkpoint completed at step 250000
22:14:50:WU00:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
23:50:39:WU02:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
23:50:39:WU01:FS01:Connecting to assign1.foldingathome.org:80
23:50:40:WU01:FS01:Assigned to work server 140.163.4.200
23:50:40:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
23:50:40:WU01:FS01:Connecting to 140.163.4.200:8080
23:50:40:WU01:FS01:Downloading 13.11MiB
23:50:46:WU01:FS01:Download 85.81%
23:50:46:WU01:FS01:Download complete
23:50:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16483 run:0 clone:11 gen:7 core:0x22 unit:0x0000000b000000070000406300000000
23:51:43:WU02:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
23:51:43:WU02:FS01:0x22:Average performance: 267.492 ns/day
23:51:45:WU02:FS01:0x22:Checkpoint completed at step 2500000
23:51:48:WU00:FS00:0x22:Completed 1325000 out of 2500000 steps (53%)
23:51:53:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
23:51:53:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
23:51:53:WU02:FS01:0x22:Saving result file checkpointState.xml.bz2
23:51:53:WU02:FS01:0x22:Saving result file positions.xtc
23:51:53:WU02:FS01:0x22:Saving result file science.log
23:51:53:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
23:51:54:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:51:54:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:16475 run:0 clone:15 gen:0 core:0x22 unit:0x0000000f000000000000405b00000000
23:51:54:WU02:FS01:Uploading 13.47MiB to 140.163.4.200
23:51:54:WU01:FS01:Starting
23:51:54:WU02:FS01:Connecting to 140.163.4.200:8080
23:51:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
23:51:54:WU01:FS01:Started FahCore on PID 9856
23:51:54:WU01:FS01:Core PID:2088
23:51:54:WU01:FS01:FahCore 0x22 started
23:51:54:WU01:FS01:0x22:*********************** Log Started 2021-08-24T23:51:54Z ***********************
23:51:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
23:51:54:WU01:FS01:0x22: Core: Core22
23:51:54:WU01:FS01:0x22: Type: 0x22
23:51:54:WU01:FS01:0x22: Version: 0.0.13
23:51:54:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:51:54:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
23:51:54:WU01:FS01:0x22: Homepage: https://foldingathome.org/
23:51:54:WU01:FS01:0x22: Date: Sep 19 2020
23:51:54:WU01:FS01:0x22: Time: 02:35:58
23:51:54:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
23:51:54:WU01:FS01:0x22: Branch: core22-0.0.13
23:51:54:WU01:FS01:0x22: Compiler: Visual C++ 2015
23:51:54:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
23:51:54:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
23:51:54:WU01:FS01:0x22: Platform: win32 10
23:51:54:WU01:FS01:0x22: Bits: 64
23:51:54:WU01:FS01:0x22: Mode: Release
23:51:54:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
23:51:54:WU01:FS01:0x22: <peastman@stanford.edu>
23:51:54:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 9856 -checkpoint 15
23:51:54:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
23:51:54:WU01:FS01:0x22: 0 -gpu 0
23:51:54:WU01:FS01:0x22:************************************ libFAH ************************************
23:51:54:WU01:FS01:0x22: Date: Sep 7 2020
23:51:54:WU01:FS01:0x22: Time: 19:09:56
23:51:54:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
23:51:54:WU01:FS01:0x22: Branch: HEAD
23:51:54:WU01:FS01:0x22:************************************ CBang *************************************
23:51:54:WU01:FS01:0x22: Time: 19:08:30
23:51:54:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
23:51:54:WU01:FS01:0x22:************************************ System ************************************
23:51:54:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
23:51:54:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
23:51:54:WU01:FS01:0x22: CPUs: 4
23:51:54:WU01:FS01:0x22: Memory: 15.94GiB
23:51:54:WU01:FS01:0x22:Free Memory: 10.68GiB
23:51:54:WU01:FS01:0x22: Threads: WINDOWS_THREADS
23:51:54:WU01:FS01:0x22: OS Version: 6.2
23:51:54:WU01:FS01:0x22:Has Battery: false
23:51:54:WU01:FS01:0x22: On Battery: false
23:51:54:WU01:FS01:0x22: UTC Offset: 3
23:51:54:WU01:FS01:0x22: PID: 2088
23:51:54:WU01:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
23:51:54:WU01:FS01:0x22:************************************ OpenMM ************************************
23:51:54:WU01:FS01:0x22: Revision: 189320d0
23:51:54:WU01:FS01:0x22:********************************************************************************
23:51:54:WU01:FS01:0x22:Project: 16483 (Run 0, Clone 11, Gen 7)
23:51:54:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
23:51:54:WU01:FS01:0x22:Reading tar file core.xml
23:51:54:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
23:51:54:WU01:FS01:0x22:Reading tar file state.xml.bz2
23:51:54:WU01:FS01:0x22:Reading tar file system.xml.bz2
23:51:54:WU01:FS01:0x22:Digital signatures verified
23:51:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
23:51:54:WU01:FS01:0x22:Version 0.0.13
23:51:54:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
23:51:54:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
23:51:54:WU01:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
23:51:54:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
23:51:54:WU01:FS01:0x22:There are 4 platforms available.
23:51:54:WU01:FS01:0x22:Platform 0: Reference
23:51:54:WU01:FS01:0x22:Platform 1: CPU
23:51:54:WU01:FS01:0x22:Platform 2: OpenCL
23:51:54:WU01:FS01:0x22: opencl-device 0 specified
23:51:54:WU01:FS01:0x22:Platform 3: CUDA
23:51:54:WU01:FS01:0x22: cuda-device 0 specified
23:52:00:WU02:FS01:Upload 25.06%
23:52:06:WU02:FS01:Upload 51.99%
23:52:06:WU01:FS01:0x22:Attempting to create CUDA context:
23:52:06:WU01:FS01:0x22: Configuring platform CUDA
23:52:11:WU01:FS01:0x22: Using CUDA and gpu 0
23:52:11:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
23:52:12:WU02:FS01:Upload 77.98%
23:52:12:WU01:FS01:0x22:Checkpoint completed at step 0
23:52:17:WU02:FS01:Upload complete
23:52:17:WU02:FS01:Server responded WORK_ACK (400)
23:52:17:WU02:FS01:Final credit estimate, 487143.00 points
23:52:17:WU02:FS01:Cleaning upRe: Units uploaded but no updates in the stats
23:53:17:WU01:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
01:17:37:WU00:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
01:17:38:WU02:FS00:Connecting to assign1.foldingathome.org:80
01:17:39:WU02:FS00:Assigned to work server 140.163.4.200
01:17:39:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
01:17:39:WU02:FS00:Connecting to 140.163.4.200:8080
01:17:39:WU02:FS00:Downloading 13.09MiB
01:17:45:WU02:FS00:Download 80.19%
01:17:46:WU02:FS00:Download complete
01:17:46:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16473 run:0 clone:7 gen:15 core:0x22 unit:0x000000070000000f0000405900000000
01:18:07:WU01:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
01:19:11:WU01:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
01:19:13:WU01:FS01:0x22:Checkpoint completed at step 2000000
01:19:29:WU00:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
01:19:29:WU00:FS00:0x22:Average performance: 154.839 ns/day
01:19:31:WU00:FS00:0x22:Checkpoint completed at step 2500000
01:19:39:WU00:FS00:0x22:Saving result file ..\logfile_01.txt
01:19:39:WU00:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
01:19:39:WU00:FS00:0x22:Saving result file checkpointState.xml.bz2
01:19:39:WU00:FS00:0x22:Saving result file positions.xtc
01:19:39:WU00:FS00:0x22:Saving result file science.log
01:19:39:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
01:19:39:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:19:39:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16477 run:0 clone:10 gen:8 core:0x22 unit:0x0000000a000000080000405d00000000
01:19:39:WU00:FS00:Uploading 13.47MiB to 140.163.4.200
01:19:39:WU00:FS00:Connecting to 140.163.4.200:8080
01:19:40:WU02:FS00:Starting
01:19:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
01:19:40:WU02:FS00:Started FahCore on PID 2400
01:19:40:WU02:FS00:Core PID:9876
01:19:40:WU02:FS00:FahCore 0x22 started
01:19:40:WU02:FS00:0x22:*********************** Log Started 2021-08-25T01:19:40Z ***********************
01:19:40:WU02:FS00:0x22:*************************** Core22 Folding@home Core ***************************
01:19:40:WU02:FS00:0x22: Core: Core22
01:19:40:WU02:FS00:0x22: Type: 0x22
01:19:40:WU02:FS00:0x22: Version: 0.0.13
01:19:40:WU02:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:19:40:WU02:FS00:0x22: Copyright: 2020 foldingathome.org
01:19:40:WU02:FS00:0x22: Homepage: https://foldingathome.org/
01:19:40:WU02:FS00:0x22: Date: Sep 19 2020
01:19:40:WU02:FS00:0x22: Time: 02:35:58
01:19:40:WU02:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
01:19:40:WU02:FS00:0x22: Branch: core22-0.0.13
01:19:40:WU02:FS00:0x22: Compiler: Visual C++ 2015
01:19:40:WU02:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:19:40:WU02:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
01:19:40:WU02:FS00:0x22: Platform: win32 10
01:19:40:WU02:FS00:0x22: Bits: 64
01:19:40:WU02:FS00:0x22: Mode: Release
01:19:40:WU02:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:19:40:WU02:FS00:0x22: <peastman@stanford.edu>
01:19:40:WU02:FS00:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 2400 -checkpoint 15
01:19:40:WU02:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
01:19:40:WU02:FS00:0x22: 1 -gpu 1
01:19:40:WU02:FS00:0x22:************************************ libFAH ************************************
01:19:40:WU02:FS00:0x22: Date: Sep 7 2020
01:19:40:WU02:FS00:0x22: Time: 19:09:56
01:19:40:WU02:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
01:19:40:WU02:FS00:0x22: Branch: HEAD
01:19:40:WU02:FS00:0x22:************************************ CBang *************************************
01:19:40:WU02:FS00:0x22: Time: 19:08:30
01:19:40:WU02:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
01:19:40:WU02:FS00:0x22:************************************ System ************************************
01:19:40:WU02:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
01:19:40:WU02:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
01:19:40:WU02:FS00:0x22: CPUs: 4
01:19:40:WU02:FS00:0x22: Memory: 15.94GiB
01:19:40:WU02:FS00:0x22:Free Memory: 10.71GiB
01:19:40:WU02:FS00:0x22: Threads: WINDOWS_THREADS
01:19:40:WU02:FS00:0x22: OS Version: 6.2
01:19:40:WU02:FS00:0x22:Has Battery: false
01:19:40:WU02:FS00:0x22: On Battery: false
01:19:40:WU02:FS00:0x22: UTC Offset: 3
01:19:40:WU02:FS00:0x22: PID: 9876
01:19:40:WU02:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
01:19:40:WU02:FS00:0x22:************************************ OpenMM ************************************
01:19:40:WU02:FS00:0x22: Revision: 189320d0
01:19:40:WU02:FS00:0x22:********************************************************************************
01:19:40:WU02:FS00:0x22:Project: 16473 (Run 0, Clone 7, Gen 15)
01:19:40:WU02:FS00:0x22:Unit: 0x00000000000000000000000000000000
01:19:40:WU02:FS00:0x22:Reading tar file core.xml
01:19:40:WU02:FS00:0x22:Reading tar file integrator.xml.bz2
01:19:40:WU02:FS00:0x22:Reading tar file state.xml.bz2
01:19:40:WU02:FS00:0x22:Reading tar file system.xml.bz2
01:19:40:WU02:FS00:0x22:Digital signatures verified
01:19:40:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
01:19:40:WU02:FS00:0x22:Version 0.0.13
01:19:40:WU02:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
01:19:40:WU02:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:19:40:WU02:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
01:19:40:WU02:FS00:0x22: Global context and integrator variables write interval: disabled
01:19:40:WU02:FS00:0x22:There are 4 platforms available.
01:19:40:WU02:FS00:0x22:Platform 0: Reference
01:19:40:WU02:FS00:0x22:Platform 1: CPU
01:19:40:WU02:FS00:0x22:Platform 2: OpenCL
01:19:40:WU02:FS00:0x22: opencl-device 1 specified
01:19:40:WU02:FS00:0x22:Platform 3: CUDA
01:19:40:WU02:FS00:0x22: cuda-device 1 specified
01:19:45:WU00:FS00:Upload 21.34%
01:19:51:WU00:FS00:Upload 47.31%
01:19:52:WU02:FS00:0x22:Attempting to create CUDA context:
01:19:52:WU02:FS00:0x22: Configuring platform CUDA
01:19:57:WU00:FS00:Upload 73.29%
01:19:58:WU02:FS00:0x22: Using CUDA and gpu 1
01:19:58:WU02:FS00:0x22:Completed 0 out of 2500000 steps (0%)
01:19:59:WU02:FS00:0x22:Checkpoint completed at step 0
01:20:03:WU00:FS00:Upload 99.73%
01:20:03:WU00:FS00:Upload complete
01:20:03:WU00:FS00:Server responded WORK_ACK (400)
01:20:03:WU00:FS00:Final credit estimate, 373054.00 points
01:20:03:WU00:FS00:Cleaning up
01:20:18:WU01:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
01:21:23:WU01:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
01:21:50:WU02:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
01:39:51:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
01:39:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:39:52:WU00:FS01:Assigned to work server 140.163.4.200
01:39:52:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
01:39:52:WU00:FS01:Connecting to 140.163.4.200:8080
01:39:53:WU00:FS01:Downloading 13.11MiB
01:39:59:WU00:FS01:Download 79.15%
01:40:00:WU00:FS01:Download complete
01:40:00:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16476 run:1 clone:11 gen:9 core:0x22 unit:0x0000000b000000090000405c00000001
01:40:30:WU02:FS00:0x22:Completed 275000 out of 2500000 steps (11%)
01:40:56:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
01:40:56:WU01:FS01:0x22:Average performance: 266.667 ns/day
01:40:58:WU01:FS01:0x22:Checkpoint completed at step 2500000
01:41:06:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
01:41:06:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
01:41:06:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
01:41:06:WU01:FS01:0x22:Saving result file positions.xtc
01:41:06:WU01:FS01:0x22:Saving result file science.log
01:41:06:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
01:41:06:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:41:06:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16483 run:0 clone:11 gen:7 core:0x22 unit:0x0000000b000000070000406300000000
01:41:06:WU01:FS01:Uploading 13.47MiB to 140.163.4.200
01:41:06:WU01:FS01:Connecting to 140.163.4.200:8080
01:41:07:WU00:FS01:Starting
01:41:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:41:07:WU00:FS01:Started FahCore on PID 4328
01:41:07:WU00:FS01:Core PID:11096
01:41:07:WU00:FS01:FahCore 0x22 started
01:41:07:WU00:FS01:0x22:*********************** Log Started 2021-08-25T01:41:07Z ***********************
01:41:07:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:41:07:WU00:FS01:0x22: Core: Core22
01:41:07:WU00:FS01:0x22: Type: 0x22
01:41:07:WU00:FS01:0x22: Version: 0.0.13
01:41:07:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:41:07:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
01:41:07:WU00:FS01:0x22: Homepage: https://foldingathome.org/
01:41:07:WU00:FS01:0x22: Date: Sep 19 2020
01:41:07:WU00:FS01:0x22: Time: 02:35:58
01:41:07:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
01:41:07:WU00:FS01:0x22: Branch: core22-0.0.13
01:41:07:WU00:FS01:0x22: Compiler: Visual C++ 2015
01:41:07:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:41:07:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
01:41:07:WU00:FS01:0x22: Platform: win32 10
01:41:07:WU00:FS01:0x22: Bits: 64
01:41:07:WU00:FS01:0x22: Mode: Release
01:41:07:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:41:07:WU00:FS01:0x22: <peastman@stanford.edu>
01:41:07:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4328 -checkpoint 15
01:41:07:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:41:07:WU00:FS01:0x22: 0 -gpu 0
01:41:07:WU00:FS01:0x22:************************************ libFAH ************************************
01:41:07:WU00:FS01:0x22: Date: Sep 7 2020
01:41:07:WU00:FS01:0x22: Time: 19:09:56
01:41:07:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
01:41:07:WU00:FS01:0x22: Branch: HEAD
01:41:07:WU00:FS01:0x22:************************************ CBang *************************************
01:41:07:WU00:FS01:0x22: Time: 19:08:30
01:41:07:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
01:41:07:WU00:FS01:0x22:************************************ System ************************************
01:41:07:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
01:41:07:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
01:41:07:WU00:FS01:0x22: CPUs: 4
01:41:07:WU00:FS01:0x22: Memory: 15.94GiB
01:41:07:WU00:FS01:0x22:Free Memory: 10.82GiB
01:41:07:WU00:FS01:0x22: Threads: WINDOWS_THREADS
01:41:07:WU00:FS01:0x22: OS Version: 6.2
01:41:07:WU00:FS01:0x22:Has Battery: false
01:41:07:WU00:FS01:0x22: On Battery: false
01:41:07:WU00:FS01:0x22: UTC Offset: 3
01:41:07:WU00:FS01:0x22: PID: 11096
01:41:07:WU00:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
01:41:07:WU00:FS01:0x22:************************************ OpenMM ************************************
01:41:07:WU00:FS01:0x22: Revision: 189320d0
01:41:07:WU00:FS01:0x22:********************************************************************************
01:41:07:WU00:FS01:0x22:Project: 16476 (Run 1, Clone 11, Gen 9)
01:41:07:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
01:41:07:WU00:FS01:0x22:Reading tar file core.xml
01:41:07:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
01:41:07:WU00:FS01:0x22:Reading tar file state.xml.bz2
01:41:07:WU00:FS01:0x22:Reading tar file system.xml.bz2
01:41:07:WU00:FS01:0x22:Digital signatures verified
01:41:07:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:41:07:WU00:FS01:0x22:Version 0.0.13
01:41:07:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
01:41:07:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:41:07:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
01:41:07:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
01:41:07:WU00:FS01:0x22:There are 4 platforms available.
01:41:07:WU00:FS01:0x22:Platform 0: Reference
01:41:07:WU00:FS01:0x22:Platform 1: CPU
01:41:07:WU00:FS01:0x22:Platform 2: OpenCL
01:41:07:WU00:FS01:0x22: opencl-device 0 specified
01:41:07:WU00:FS01:0x22:Platform 3: CUDA
01:41:07:WU00:FS01:0x22: cuda-device 0 specified
01:41:12:WU01:FS01:Upload 21.34%
01:41:18:WU01:FS01:Upload 47.78%
01:41:19:WU00:FS01:0x22:Attempting to create CUDA context:
01:41:19:WU00:FS01:0x22: Configuring platform CUDA
01:41:24:WU01:FS01:Upload 73.76%
01:41:24:WU00:FS01:0x22: Using CUDA and gpu 0
01:41:24:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
01:41:25:WU00:FS01:0x22:Checkpoint completed at step 0
01:41:30:WU01:FS01:Upload complete
01:41:30:WU01:FS01:Server responded WORK_ACK (400)
01:41:30:WU01:FS01:Final credit estimate, 487718.00 points
01:41:30:WU01:FS01:Cleaning up
01:42:22:WU02:FS00:0x22:Completed 300000 out of 2500000 steps (12%)
01:42:29:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
03:27:10:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
03:27:11:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:27:12:WU01:FS01:Assigned to work server 140.163.4.200
03:27:12:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
03:27:12:WU01:FS01:Connecting to 140.163.4.200:8080
03:27:12:WU01:FS01:Downloading 13.09MiB
03:27:18:WU01:FS01:Download 74.47%
03:27:19:WU01:FS01:Download complete
03:27:19:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16475 run:1 clone:3 gen:37 core:0x22 unit:0x00000003000000250000405b00000001
03:28:14:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
03:28:14:WU00:FS01:0x22:Average performance: 270.846 ns/day
03:28:16:WU00:FS01:0x22:Checkpoint completed at step 2500000
03:28:24:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
03:28:24:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
03:28:24:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
03:28:24:WU00:FS01:0x22:Saving result file positions.xtc
03:28:24:WU00:FS01:0x22:Saving result file science.log
03:28:24:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:28:24:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:28:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16476 run:1 clone:11 gen:9 core:0x22 unit:0x0000000b000000090000405c00000001
03:28:24:WU00:FS01:Uploading 13.47MiB to 140.163.4.200
03:28:24:WU01:FS01:Starting
03:28:24:WU00:FS01:Connecting to 140.163.4.200:8080
03:28:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:28:24:WU01:FS01:Started FahCore on PID 3732
03:28:24:WU01:FS01:Core PID:1892
03:28:24:WU01:FS01:FahCore 0x22 started
03:28:25:WU01:FS01:0x22:*********************** Log Started 2021-08-25T03:28:24Z ***********************
03:28:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:28:25:WU01:FS01:0x22: Core: Core22
03:28:25:WU01:FS01:0x22: Type: 0x22
03:28:25:WU01:FS01:0x22: Version: 0.0.13
03:28:25:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:28:25:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
03:28:25:WU01:FS01:0x22: Homepage: https://foldingathome.org/
03:28:25:WU01:FS01:0x22: Date: Sep 19 2020
03:28:25:WU01:FS01:0x22: Time: 02:35:58
03:28:25:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
03:28:25:WU01:FS01:0x22: Branch: core22-0.0.13
03:28:25:WU01:FS01:0x22: Compiler: Visual C++ 2015
03:28:25:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
03:28:25:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
03:28:25:WU01:FS01:0x22: Platform: win32 10
03:28:25:WU01:FS01:0x22: Bits: 64
03:28:25:WU01:FS01:0x22: Mode: Release
03:28:25:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
03:28:25:WU01:FS01:0x22: <peastman@stanford.edu>
03:28:25:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 3732 -checkpoint 15
03:28:25:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:28:25:WU01:FS01:0x22: 0 -gpu 0
03:28:25:WU01:FS01:0x22:************************************ libFAH ************************************
03:28:25:WU01:FS01:0x22: Date: Sep 7 2020
03:28:25:WU01:FS01:0x22: Time: 19:09:56
03:28:25:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
03:28:25:WU01:FS01:0x22: Branch: HEAD
03:28:25:WU01:FS01:0x22:************************************ CBang *************************************
03:28:25:WU01:FS01:0x22: Time: 19:08:30
03:28:25:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
03:28:25:WU01:FS01:0x22:************************************ System ************************************
03:28:25:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
03:28:25:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
03:28:25:WU01:FS01:0x22: CPUs: 4
03:28:25:WU01:FS01:0x22: Memory: 15.94GiB
03:28:25:WU01:FS01:0x22:Free Memory: 10.68GiB
03:28:25:WU01:FS01:0x22: Threads: WINDOWS_THREADS
03:28:25:WU01:FS01:0x22: OS Version: 6.2
03:28:25:WU01:FS01:0x22:Has Battery: false
03:28:25:WU01:FS01:0x22: On Battery: false
03:28:25:WU01:FS01:0x22: UTC Offset: 3
03:28:25:WU01:FS01:0x22: PID: 1892
03:28:25:WU01:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
03:28:25:WU01:FS01:0x22:************************************ OpenMM ************************************
03:28:25:WU01:FS01:0x22: Revision: 189320d0
03:28:25:WU01:FS01:0x22:********************************************************************************
03:28:25:WU01:FS01:0x22:Project: 16475 (Run 1, Clone 3, Gen 37)
03:28:25:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
03:28:25:WU01:FS01:0x22:Reading tar file core.xml
03:28:25:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
03:28:25:WU01:FS01:0x22:Reading tar file state.xml.bz2
03:28:25:WU01:FS01:0x22:Reading tar file system.xml.bz2
03:28:25:WU01:FS01:0x22:Digital signatures verified
03:28:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:28:25:WU01:FS01:0x22:Version 0.0.13
03:28:25:WU01:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
03:28:25:WU01:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
03:28:25:WU01:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
03:28:25:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
03:28:25:WU01:FS01:0x22:There are 4 platforms available.
03:28:25:WU01:FS01:0x22:Platform 0: Reference
03:28:25:WU01:FS01:0x22:Platform 1: CPU
03:28:25:WU01:FS01:0x22:Platform 2: OpenCL
03:28:25:WU01:FS01:0x22: opencl-device 0 specified
03:28:25:WU01:FS01:0x22:Platform 3: CUDA
03:28:25:WU01:FS01:0x22: cuda-device 0 specified
03:28:30:WU00:FS01:Upload 22.74%
03:28:36:WU00:FS01:Upload 49.19%
03:28:36:WU01:FS01:0x22:Attempting to create CUDA context:
03:28:36:WU01:FS01:0x22: Configuring platform CUDA
03:28:42:WU00:FS01:Upload 75.17%
03:28:44:WU01:FS01:0x22: Using CUDA and gpu 0
03:28:44:WU01:FS01:0x22:Completed 0 out of 2500000 steps (0%)
03:28:45:WU02:FS00:0x22:Completed 1725000 out of 2500000 steps (69%)
03:28:45:WU01:FS01:0x22:Checkpoint completed at step 0
03:28:48:WU00:FS01:Upload complete
03:28:48:WU00:FS01:Server responded WORK_ACK (400)
03:28:48:WU00:FS01:Final credit estimate, 495813.00 points
03:28:48:WU00:FS01:Cleaning upRe: Units uploaded but no updates in the stats
07:36:02:WU02:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
08:54:04:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
08:54:04:WU00:FS01:Connecting to assign1.foldingathome.org:80
08:54:04:WU00:FS01:Assigned to work server 140.163.4.200
08:54:04:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
08:54:04:WU00:FS01:Connecting to 140.163.4.200:8080
08:54:05:WU00:FS01:Downloading 13.08MiB
08:54:11:WU00:FS01:Download 80.24%
08:54:12:WU00:FS01:Download complete
08:54:12:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16472 run:1 clone:11 gen:3 core:0x22 unit:0x0000000b000000030000405800000001
08:54:18:WU02:FS00:0x22:Completed 1075000 out of 2500000 steps (43%)
08:55:08:WU01:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
08:55:09:WU01:FS01:0x22:Average performance: 267.492 ns/day
08:55:11:WU01:FS01:0x22:Checkpoint completed at step 2500000
08:55:18:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
08:55:18:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
08:55:18:WU01:FS01:0x22:Saving result file checkpointState.xml.bz2
08:55:18:WU01:FS01:0x22:Saving result file positions.xtc
08:55:18:WU01:FS01:0x22:Saving result file science.log
08:55:18:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
08:55:19:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:55:19:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:16483 run:0 clone:7 gen:16 core:0x22 unit:0x00000007000000100000406300000000
08:55:19:WU01:FS01:Uploading 13.48MiB to 140.163.4.200
08:55:19:WU00:FS01:Starting
08:55:19:WU01:FS01:Connecting to 140.163.4.200:8080
08:55:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:55:19:WU00:FS01:Started FahCore on PID 9928
08:55:19:WU00:FS01:Core PID:6400
08:55:19:WU00:FS01:FahCore 0x22 started
08:55:20:WU00:FS01:0x22:*********************** Log Started 2021-08-25T08:55:19Z ***********************
08:55:20:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:55:20:WU00:FS01:0x22: Core: Core22
08:55:20:WU00:FS01:0x22: Type: 0x22
08:55:20:WU00:FS01:0x22: Version: 0.0.13
08:55:20:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:55:20:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
08:55:20:WU00:FS01:0x22: Homepage: https://foldingathome.org/
08:55:20:WU00:FS01:0x22: Date: Sep 19 2020
08:55:20:WU00:FS01:0x22: Time: 02:35:58
08:55:20:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
08:55:20:WU00:FS01:0x22: Branch: core22-0.0.13
08:55:20:WU00:FS01:0x22: Compiler: Visual C++ 2015
08:55:20:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
08:55:20:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
08:55:20:WU00:FS01:0x22: Platform: win32 10
08:55:20:WU00:FS01:0x22: Bits: 64
08:55:20:WU00:FS01:0x22: Mode: Release
08:55:20:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
08:55:20:WU00:FS01:0x22: <peastman@stanford.edu>
08:55:20:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 9928 -checkpoint 15
08:55:20:WU00:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:55:20:WU00:FS01:0x22: 0 -gpu 0
08:55:20:WU00:FS01:0x22:************************************ libFAH ************************************
08:55:20:WU00:FS01:0x22: Date: Sep 7 2020
08:55:20:WU00:FS01:0x22: Time: 19:09:56
08:55:20:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
08:55:20:WU00:FS01:0x22: Branch: HEAD
08:55:20:WU00:FS01:0x22:************************************ CBang *************************************
08:55:20:WU00:FS01:0x22: Time: 19:08:30
08:55:20:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
08:55:20:WU00:FS01:0x22:************************************ System ************************************
08:55:20:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
08:55:20:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
08:55:20:WU00:FS01:0x22: CPUs: 4
08:55:20:WU00:FS01:0x22: Memory: 15.94GiB
08:55:20:WU00:FS01:0x22:Free Memory: 10.72GiB
08:55:20:WU00:FS01:0x22: Threads: WINDOWS_THREADS
08:55:20:WU00:FS01:0x22: OS Version: 6.2
08:55:20:WU00:FS01:0x22:Has Battery: false
08:55:20:WU00:FS01:0x22: On Battery: false
08:55:20:WU00:FS01:0x22: UTC Offset: 3
08:55:20:WU00:FS01:0x22: PID: 6400
08:55:20:WU00:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
08:55:20:WU00:FS01:0x22:************************************ OpenMM ************************************
08:55:20:WU00:FS01:0x22: Revision: 189320d0
08:55:20:WU00:FS01:0x22:********************************************************************************
08:55:20:WU00:FS01:0x22:Project: 16472 (Run 1, Clone 11, Gen 3)
08:55:20:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
08:55:20:WU00:FS01:0x22:Reading tar file core.xml
08:55:20:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
08:55:20:WU00:FS01:0x22:Reading tar file state.xml.bz2
08:55:20:WU00:FS01:0x22:Reading tar file system.xml.bz2
08:55:20:WU00:FS01:0x22:Digital signatures verified
08:55:20:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:55:20:WU00:FS01:0x22:Version 0.0.13
08:55:20:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
08:55:20:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
08:55:20:WU00:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
08:55:20:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
08:55:20:WU00:FS01:0x22:There are 4 platforms available.
08:55:20:WU00:FS01:0x22:Platform 0: Reference
08:55:20:WU00:FS01:0x22:Platform 1: CPU
08:55:20:WU00:FS01:0x22:Platform 2: OpenCL
08:55:20:WU00:FS01:0x22: opencl-device 0 specified
08:55:20:WU00:FS01:0x22:Platform 3: CUDA
08:55:20:WU00:FS01:0x22: cuda-device 0 specified
08:55:25:WU01:FS01:Upload 23.19%
08:55:31:WU01:FS01:Upload 49.63%
08:55:31:WU00:FS01:0x22:Attempting to create CUDA context:
08:55:31:WU00:FS01:0x22: Configuring platform CUDA
08:55:37:WU01:FS01:Upload 76.06%
08:55:39:WU00:FS01:0x22: Using CUDA and gpu 0
08:55:39:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
08:55:40:WU00:FS01:0x22:Checkpoint completed at step 0
08:55:42:WU01:FS01:Upload complete
08:55:42:WU01:FS01:Server responded WORK_ACK (400)
08:55:43:WU01:FS01:Final credit estimate, 487902.00 points
08:55:43:WU01:FS01:Cleaning up
08:56:10:WU02:FS00:0x22:Completed 1100000 out of 2500000 steps (44%)
08:56:46:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
10:38:49:WU02:FS00:0x22:Completed 2475000 out of 2500000 steps (99%)
10:38:50:WU01:FS00:Connecting to assign1.foldingathome.org:80
10:38:51:WU01:FS00:Assigned to work server 140.163.4.200
10:38:51:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GA104 [GeForce RTX 3070] from 140.163.4.200
10:38:51:WU01:FS00:Connecting to 140.163.4.200:8080
10:38:51:WU01:FS00:Downloading 13.11MiB
10:38:57:WU01:FS00:Download 77.71%
10:38:58:WU01:FS00:Download complete
10:38:58:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16480 run:0 clone:5 gen:18 core:0x22 unit:0x00000005000000120000406000000000
10:39:31:WU00:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
10:40:36:WU00:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
10:40:41:WU02:FS00:0x22:Completed 2500000 out of 2500000 steps (100%)
10:40:41:WU02:FS00:0x22:Average performance: 154.839 ns/day
10:40:43:WU02:FS00:0x22:Checkpoint completed at step 2500000
10:40:51:WU02:FS00:0x22:Saving result file ..\logfile_01.txt
10:40:51:WU02:FS00:0x22:Saving result file checkpointIntegrator.xml.bz2
10:40:51:WU02:FS00:0x22:Saving result file checkpointState.xml.bz2
10:40:51:WU02:FS00:0x22:Saving result file positions.xtc
10:40:51:WU02:FS00:0x22:Saving result file science.log
10:40:51:WU02:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:40:51:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:40:51:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16483 run:0 clone:8 gen:16 core:0x22 unit:0x00000008000000100000406300000000
10:40:51:WU02:FS00:Uploading 13.48MiB to 140.163.4.200
10:40:51:WU01:FS00:Starting
10:40:51:WU02:FS00:Connecting to 140.163.4.200:8080
10:40:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
10:40:51:WU01:FS00:Started FahCore on PID 10340
10:40:51:WU01:FS00:Core PID:3316
10:40:51:WU01:FS00:FahCore 0x22 started
10:40:52:WU01:FS00:0x22:*********************** Log Started 2021-08-25T10:40:51Z ***********************
10:40:52:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
10:40:52:WU01:FS00:0x22: Core: Core22
10:40:52:WU01:FS00:0x22: Type: 0x22
10:40:52:WU01:FS00:0x22: Version: 0.0.13
10:40:52:WU01:FS00:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:40:52:WU01:FS00:0x22: Copyright: 2020 foldingathome.org
10:40:52:WU01:FS00:0x22: Homepage: https://foldingathome.org/
10:40:52:WU01:FS00:0x22: Date: Sep 19 2020
10:40:52:WU01:FS00:0x22: Time: 02:35:58
10:40:52:WU01:FS00:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
10:40:52:WU01:FS00:0x22: Branch: core22-0.0.13
10:40:52:WU01:FS00:0x22: Compiler: Visual C++ 2015
10:40:52:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
10:40:52:WU01:FS00:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
10:40:52:WU01:FS00:0x22: Platform: win32 10
10:40:52:WU01:FS00:0x22: Bits: 64
10:40:52:WU01:FS00:0x22: Mode: Release
10:40:52:WU01:FS00:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:40:52:WU01:FS00:0x22: <peastman@stanford.edu>
10:40:52:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 10340 -checkpoint 15
10:40:52:WU01:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
10:40:52:WU01:FS00:0x22: 1 -gpu 1
10:40:52:WU01:FS00:0x22:************************************ libFAH ************************************
10:40:52:WU01:FS00:0x22: Date: Sep 7 2020
10:40:52:WU01:FS00:0x22: Time: 19:09:56
10:40:52:WU01:FS00:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
10:40:52:WU01:FS00:0x22: Branch: HEAD
10:40:52:WU01:FS00:0x22:************************************ CBang *************************************
10:40:52:WU01:FS00:0x22: Time: 19:08:30
10:40:52:WU01:FS00:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
10:40:52:WU01:FS00:0x22:************************************ System ************************************
10:40:52:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
10:40:52:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:40:52:WU01:FS00:0x22: CPUs: 4
10:40:52:WU01:FS00:0x22: Memory: 15.94GiB
10:40:52:WU01:FS00:0x22:Free Memory: 10.63GiB
10:40:52:WU01:FS00:0x22: Threads: WINDOWS_THREADS
10:40:52:WU01:FS00:0x22: OS Version: 6.2
10:40:52:WU01:FS00:0x22:Has Battery: false
10:40:52:WU01:FS00:0x22: On Battery: false
10:40:52:WU01:FS00:0x22: UTC Offset: 3
10:40:52:WU01:FS00:0x22: PID: 3316
10:40:52:WU01:FS00:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
10:40:52:WU01:FS00:0x22:************************************ OpenMM ************************************
10:40:52:WU01:FS00:0x22: Revision: 189320d0
10:40:52:WU01:FS00:0x22:********************************************************************************
10:40:52:WU01:FS00:0x22:Project: 16480 (Run 0, Clone 5, Gen 18)
10:40:52:WU01:FS00:0x22:Unit: 0x00000000000000000000000000000000
10:40:52:WU01:FS00:0x22:Reading tar file core.xml
10:40:52:WU01:FS00:0x22:Reading tar file integrator.xml.bz2
10:40:52:WU01:FS00:0x22:Reading tar file state.xml.bz2
10:40:52:WU01:FS00:0x22:Reading tar file system.xml.bz2
10:40:52:WU01:FS00:0x22:Digital signatures verified
10:40:52:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
10:40:52:WU01:FS00:0x22:Version 0.0.13
10:40:52:WU01:FS00:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
10:40:52:WU01:FS00:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
10:40:52:WU01:FS00:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
10:40:52:WU01:FS00:0x22: Global context and integrator variables write interval: disabled
10:40:52:WU01:FS00:0x22:There are 4 platforms available.
10:40:52:WU01:FS00:0x22:Platform 0: Reference
10:40:52:WU01:FS00:0x22:Platform 1: CPU
10:40:52:WU01:FS00:0x22:Platform 2: OpenCL
10:40:52:WU01:FS00:0x22: opencl-device 1 specified
10:40:52:WU01:FS00:0x22:Platform 3: CUDA
10:40:52:WU01:FS00:0x22: cuda-device 1 specified
10:40:57:WU02:FS00:Upload 21.80%
10:41:03:WU02:FS00:Upload 47.77%
10:41:04:WU01:FS00:0x22:Attempting to create CUDA context:
10:41:04:WU01:FS00:0x22: Configuring platform CUDA
10:41:09:WU02:FS00:Upload 74.21%
10:41:10:WU01:FS00:0x22: Using CUDA and gpu 1
10:41:10:WU01:FS00:0x22:Completed 0 out of 2500000 steps (0%)
10:41:11:WU01:FS00:0x22:Checkpoint completed at step 0
10:41:15:WU02:FS00:Upload complete
10:41:15:WU02:FS00:Server responded WORK_ACK (400)
10:41:15:WU02:FS00:Final credit estimate, 373118.00 points
10:41:15:WU02:FS00:Cleaning up
10:41:41:WU00:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
10:42:45:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
10:42:46:WU02:FS01:Connecting to assign1.foldingathome.org:80
10:42:47:WU02:FS01:Assigned to work server 140.163.4.200
10:42:47:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GA102 [GeForce RTX 3090] from 140.163.4.200
10:42:47:WU02:FS01:Connecting to 140.163.4.200:8080
10:42:47:WU02:FS01:Downloading 13.11MiB
10:42:53:WU02:FS01:Download 73.44%
10:42:54:WU02:FS01:Download complete
10:42:54:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16482 run:1 clone:1 gen:35 core:0x22 unit:0x00000001000000230000406200000001
10:43:02:WU01:FS00:0x22:Completed 25000 out of 2500000 steps (1%)
10:43:50:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
10:43:50:WU00:FS01:0x22:Average performance: 268.323 ns/day
10:43:51:WU00:FS01:0x22:Checkpoint completed at step 2500000
10:43:59:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
10:43:59:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
10:43:59:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
10:43:59:WU00:FS01:0x22:Saving result file positions.xtc
10:43:59:WU00:FS01:0x22:Saving result file science.log
10:43:59:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
10:44:00:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:44:00:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:16472 run:1 clone:11 gen:3 core:0x22 unit:0x0000000b000000030000405800000001
10:44:00:WU00:FS01:Uploading 13.46MiB to 140.163.4.200
10:44:00:WU00:FS01:Connecting to 140.163.4.200:8080
10:44:00:WU02:FS01:Starting
10:44:00:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\egrui\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 8336 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
10:44:00:WU02:FS01:Started FahCore on PID 2012
10:44:00:WU02:FS01:Core PID:2088
10:44:00:WU02:FS01:FahCore 0x22 started
10:44:01:WU02:FS01:0x22:*********************** Log Started 2021-08-25T10:44:00Z ***********************
10:44:01:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
10:44:01:WU02:FS01:0x22: Core: Core22
10:44:01:WU02:FS01:0x22: Type: 0x22
10:44:01:WU02:FS01:0x22: Version: 0.0.13
10:44:01:WU02:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:44:01:WU02:FS01:0x22: Copyright: 2020 foldingathome.org
10:44:01:WU02:FS01:0x22: Homepage: https://foldingathome.org/
10:44:01:WU02:FS01:0x22: Date: Sep 19 2020
10:44:01:WU02:FS01:0x22: Time: 02:35:58
10:44:01:WU02:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
10:44:01:WU02:FS01:0x22: Branch: core22-0.0.13
10:44:01:WU02:FS01:0x22: Compiler: Visual C++ 2015
10:44:01:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
10:44:01:WU02:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
10:44:01:WU02:FS01:0x22: Platform: win32 10
10:44:01:WU02:FS01:0x22: Bits: 64
10:44:01:WU02:FS01:0x22: Mode: Release
10:44:01:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
10:44:01:WU02:FS01:0x22: <peastman@stanford.edu>
10:44:01:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 2012 -checkpoint 15
10:44:01:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
10:44:01:WU02:FS01:0x22: 0 -gpu 0
10:44:01:WU02:FS01:0x22:************************************ libFAH ************************************
10:44:01:WU02:FS01:0x22: Date: Sep 7 2020
10:44:01:WU02:FS01:0x22: Time: 19:09:56
10:44:01:WU02:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
10:44:01:WU02:FS01:0x22: Branch: HEAD
10:44:01:WU02:FS01:0x22:************************************ CBang *************************************
10:44:01:WU02:FS01:0x22: Time: 19:08:30
10:44:01:WU02:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
10:44:01:WU02:FS01:0x22:************************************ System ************************************
10:44:01:WU02:FS01:0x22: CPU: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
10:44:01:WU02:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:44:01:WU02:FS01:0x22: CPUs: 4
10:44:01:WU02:FS01:0x22: Memory: 15.94GiB
10:44:01:WU02:FS01:0x22:Free Memory: 10.71GiB
10:44:01:WU02:FS01:0x22: Threads: WINDOWS_THREADS
10:44:01:WU02:FS01:0x22: OS Version: 6.2
10:44:01:WU02:FS01:0x22:Has Battery: false
10:44:01:WU02:FS01:0x22: On Battery: false
10:44:01:WU02:FS01:0x22: UTC Offset: 3
10:44:01:WU02:FS01:0x22: PID: 2088
10:44:01:WU02:FS01:0x22: CWD: C:\Users\egrui\AppData\Roaming\FAHClient\work
10:44:01:WU02:FS01:0x22:************************************ OpenMM ************************************
10:44:01:WU02:FS01:0x22: Revision: 189320d0
10:44:01:WU02:FS01:0x22:********************************************************************************
10:44:01:WU02:FS01:0x22:Project: 16482 (Run 1, Clone 1, Gen 35)
10:44:01:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
10:44:01:WU02:FS01:0x22:Reading tar file core.xml
10:44:01:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
10:44:01:WU02:FS01:0x22:Reading tar file state.xml.bz2
10:44:01:WU02:FS01:0x22:Reading tar file system.xml.bz2
10:44:01:WU02:FS01:0x22:Digital signatures verified
10:44:01:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
10:44:01:WU02:FS01:0x22:Version 0.0.13
10:44:01:WU02:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
10:44:01:WU02:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
10:44:01:WU02:FS01:0x22: XTC frame write interval: 250000 steps (10%) [10 total]
10:44:01:WU02:FS01:0x22: Global context and integrator variables write interval: disabled
10:44:01:WU02:FS01:0x22:There are 4 platforms available.
10:44:01:WU02:FS01:0x22:Platform 0: Reference
10:44:01:WU02:FS01:0x22:Platform 1: CPU
10:44:01:WU02:FS01:0x22:Platform 2: OpenCL
10:44:01:WU02:FS01:0x22: opencl-device 0 specified
10:44:01:WU02:FS01:0x22:Platform 3: CUDA
10:44:01:WU02:FS01:0x22: cuda-device 0 specified
10:44:06:WU00:FS01:Upload 23.69%
10:44:12:WU00:FS01:Upload 50.16%
10:44:12:WU02:FS01:0x22:Attempting to create CUDA context:
10:44:12:WU02:FS01:0x22: Configuring platform CUDA
10:44:18:WU00:FS01:Upload 76.63%
10:44:18:WU02:FS01:0x22: Using CUDA and gpu 0
10:44:18:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
10:44:19:WU02:FS01:0x22:Checkpoint completed at step 0
10:44:23:WU00:FS01:Upload complete
10:44:23:WU00:FS01:Server responded WORK_ACK (400)
10:44:23:WU00:FS01:Final credit estimate, 467011.00 points
10:44:23:WU00:FS01:Cleaning upI hope it is enough, took me quite some time to edit.
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
From the log posted first (8:36am EDT) based on this, C:\Users\egrui if this is you
using this tool: https://apps.foldingathome.org/wu
you can see the work unit was uploaded and credited yesterday
Hi NGruia (team 261416), Your WU (P16477 R1 C10 G7) was added to the stats database on Tue, 24 Aug 2021 16:52:31 GMT for 373799 points of credit.
Or am I wrong?
Or am I wrong?
I pasted the logs starting from 24-08-2021 until today so some of the units may have received credit, however the issue is with work units that were solved today and uploaded but were not taken into account.
Usually it's fine to give it a couple days. If a WU isn't credited by then, it's time to alert the teams. Last night I solved a WU for p17602 that wasn't credited, for example, (for the same work server that had issues a last week or so, or the week before - may be related). I'll start complaining by Friday if that's still the case.
Date of last Work Unit 2021-08-24 19:54:43 NGruia
Date of last work unit 2021-08-24 19:54:42 zadadrian
Date of last Work Unit 2021-08-24 20:24:49 Foxter
Last seven Hourly production were :
08.25, 9am 0 0
08.25, 6am 0 0
08.25, 3am 0 0
08.25, 12am 0 0
08.24, 9pm 0 0
08.24, 6pm 3,308,521 9
08.24, 3pm 8,402,179 21
08.24, 12pm 8,302,793 22
User zadadrian is folding also for team 144545 and there is no problem, the stats are updated correctly.
Now, after o quick verification daily PPD for 261416 team is about 62 mil.
3090
3080
3070 Ti x2
3070 x 3
3060 Ti x2
2080 Ti x 5
2080 S x2
2080
2060 S x2 (stopped from 10:00 pm to 8:00 am daily)
1650 S
Team 263148 seems to be in this situation too.
08.25, 9am 0 0
08.25, 6am 0 0
08.25, 3am 0 0
08.25, 12am 0 0
08.24, 9pm 0 0
3090
3080
3070 Ti x2
3070 x 3
3060 Ti x2
2080 Ti x 5
2080 S x2
2080
1650 S
I have flagged this to the researcher for these projects - hopefully a quick "kick" of the WS/Stats Server connection might resolve things .. Stats issues can take a bit of time to resolve (days/weeks/even months rather than minutes/hours) but in my experience they do get resolved - usually with a big "spike" of points being awarded at once.
Most of the WUs I spotted missing in your logs belong to the 164** projects - can you confirm if all projects are failing to get points for those not getting points (or just the 164** Wus) - and could you confirm if the folder who is getting points is getting them for all projects (including 164**)?
I believe most of the 164** series WUs in play at the moment are beta projects - could it be that the folder not having issues does not have the beta flag set and therefore is not getting wus from these projects?
