Quadro 6000 6gb low PPD?
nicrusk01
Post by nicrusk01 »
I have a HP 420 with a e 1650 processor and which gives me between 9k and 15k PPD, I installed a Quadro 6000 6gb new, And day one was 47k PPD and the last two days is down to 17k PPD, should it be that low I was expecting a lot more. Am I doing something wrong or should be doing something different I could really use help on this
psaam0001
Re: Quadro 6000 6gb low PPD?
Post by psaam0001 »
Would you mind posting the first 100 lines from your log, which will start with something like this:
00:27:13:WU01:FS02:Starting
00:27:13:WU01:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit/22-0.0.13/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 706 -lifeline 1729 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:27:13:WU01:FS02:Started FahCore on PID 50553
00:27:13:WU01:FS02:Core PID:50557
00:27:13:WU01:FS02:FahCore 0x22 started
00:27:14:WU01:FS02:0x22:*********************** Log Started 2021-08-19T00:27:13Z ***********************
00:27:14:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
00:27:14:WU01:FS02:0x22:       Core: Core22
00:27:14:WU01:FS02:0x22:       Type: 0x22
00:27:14:WU01:FS02:0x22:    Version: 0.0.13
00:27:14:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:27:14:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
00:27:14:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
00:27:14:WU01:FS02:0x22:       Date: Sep 19 2020
00:27:14:WU01:FS02:0x22:       Time: 01:10:35
00:27:14:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:27:14:WU01:FS02:0x22:     Branch: core22-0.0.13
00:27:14:WU01:FS02:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
00:27:14:WU01:FS02:0x22:    Options: -std=c++11 -fsigned-char -ffunction-sections -fdata-sections -O3
00:27:14:WU01:FS02:0x22:             -funroll-loops -DOPENMM_GIT_HASH="\"189320d0\""
00:27:14:WU01:FS02:0x22:   Platform: linux2 4.19.76-linuxkit
00:27:14:WU01:FS02:0x22:       Bits: 64
00:27:14:WU01:FS02:0x22:       Mode: Release
00:27:14:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:27:14:WU01:FS02:0x22:             <peastman@stanford.edu>
00:27:14:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 50553 -checkpoint 30
00:27:14:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:27:14:WU01:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
00:27:14:WU01:FS02:0x22:************************************ libFAH ************************************
00:27:14:WU01:FS02:0x22:       Date: Sep 15 2020
00:27:14:WU01:FS02:0x22:       Time: 05:14:43
00:27:14:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:27:14:WU01:FS02:0x22:     Branch: HEAD
00:27:14:WU01:FS02:0x22:************************************ CBang *************************************
00:27:14:WU01:FS02:0x22:       Time: 05:11:04
00:27:14:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:27:14:WU01:FS02:0x22:             -funroll-loops -fPIC
00:27:14:WU01:FS02:0x22:************************************ System ************************************
00:27:14:WU01:FS02:0x22:        CPU: AMD Ryzen 9 3950X 16-Core Processor
00:27:14:WU01:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
00:27:14:WU01:FS02:0x22:       CPUs: 32
00:27:14:WU01:FS02:0x22:     Memory: 62.72GiB
00:27:14:WU01:FS02:0x22:Free Memory: 55.09GiB
00:27:14:WU01:FS02:0x22:    Threads: POSIX_THREADS
00:27:14:WU01:FS02:0x22: OS Version: 5.13
00:27:14:WU01:FS02:0x22:Has Battery: false
00:27:14:WU01:FS02:0x22: On Battery: false
00:27:14:WU01:FS02:0x22: UTC Offset: -4
00:27:14:WU01:FS02:0x22:        PID: 50557
00:27:14:WU01:FS02:0x22:        CWD: /var/lib/fahclient/work
00:27:14:WU01:FS02:0x22:************************************ OpenMM ************************************
00:27:14:WU01:FS02:0x22:   Revision: 189320d0
00:27:14:WU01:FS02:0x22:********************************************************************************
00:27:14:WU01:FS02:0x22:Project: 17601 (Run 196, Clone 8, Gen 48)
00:27:14:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
00:27:14:WU01:FS02:0x22:Reading tar file core.xml
00:27:14:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
00:27:14:WU01:FS02:0x22:Reading tar file state.xml.bz2
00:27:14:WU01:FS02:0x22:Reading tar file system.xml.bz2
00:27:14:WU01:FS02:0x22:Digital signatures verified
00:27:14:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
00:27:14:WU01:FS02:0x22:Version 0.0.13
00:27:14:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (2%) [50 total]
00:27:14:WU01:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:27:14:WU01:FS02:0x22:  XTC frame write interval: 12500 steps (0.5%) [200 total]
00:27:14:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
00:27:14:WU01:FS02:0x22:There are 4 platforms available.
00:27:14:WU01:FS02:0x22:Platform 0: Reference
00:27:14:WU01:FS02:0x22:Platform 1: CPU
00:27:14:WU01:FS02:0x22:Platform 2: OpenCL
00:27:14:WU01:FS02:0x22:  opencl-device 0 specified
00:27:14:WU01:FS02:0x22:Platform 3: CUDA
00:27:14:WU01:FS02:0x22:  cuda-device 0 specified
00:27:20:WU01:FS02:0x22:Attempting to create CUDA context:
00:27:20:WU01:FS02:0x22:  Configuring platform CUDA
00:27:21:WU02:FS02:Upload complete
00:27:21:WU02:FS02:Server responded WORK_ACK (400)
00:27:21:WU02:FS02:Final credit estimate, 166252.00 points
00:27:21:WU02:FS02:Cleaning up
00:27:29:WU01:FS02:0x22:  Using CUDA and gpu 0
00:27:29:WU01:FS02:0x22:Completed 0 out of 2500000 steps (0%)
00:27:29:WU01:FS02:0x22:Checkpoint completed at step 0
00:28:08:WU03:FS00:0xa8:Completed 4700000 out of 10000000 steps (47%)
Depending on the O/S you are using, the most recent NVidia Drivers are:
Windows 10/Server 2016/Server 2019 (RTX/Quadro Workstation Card Drivers): R470 U3 (471.68)
Linux (RTX/Quadro Workstation Card Drivers): 470.63.01
I'm sure that one of the more experienced members will be able to help you if updating the drivers does not help.
Paul
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/quadro-6000.c896
I confess I am surprised it folds at all. F@H has two prerequisites: the ability to do 64 bit floating point math (which your card can) and support for OpenCL 1.2 (which your card lacks)
This card is 11 years old and not 'modern', I have heard rumors that some Nvidia cards implemented some parts of OpenCL 1.2 even if they did not implement all of it, perhaps your card is one of those.
https://ark.intel.com/content/www/us/en ... l-qpi.html
Your CPU is fine. Not the most modern for core_a8, but modern enough to run core_a7 full speed.
Did you setup a passkey : https://test.foldingathome.org/support/ ... s/passkey/ ?
Post by Neil-B »
If you have got a passkey you may want to check the bonus status ... there was an issue recently that might have caused your bonus status to drop off if you haven't done many WUs ... https://apps.foldingathome.org/bonus
MeeLee
Post by MeeLee »
Neil-B wrote:If you have got a passkey you may want to check the bonus status ... there was an issue recently that might have caused your bonus status to drop off if you haven't done many WUs ... https://apps.foldingathome.org/bonus
...or if he has lost bonus points due to too many errors or expired WUs.
Post by Neil-B »
The "issue" I was tactfully referring to was the one recently where folders "expired wu" counts were incrementing up through no fault of their own (it was a server side glitch) - for someone with a low wu count that could have very quickly caused a QRB = True status to be lost even though the folder wasn't either failing or expiring wus ... Given the OP had a higher ppd then it significantly dropped I as simply suggesting a check is made to see that the bonus is active or not :)
fz4z
Post by fz4z »
What was the time of server side glitch that caused "expired wu" counts incrementing up ?
Post by Neil-B »
fz4z wrote:What was the time of server side glitch that caused "expired wu" counts incrementing up ?
It was resolved earlier this week iirc ... how long it had been doing this is unknown but my guess would be not for very long ... and yes it might explain you having expired wus on bonus status that don't necessarily match up with what you have seen in your logs .. there was quite a lot of discussion/analysis in the discord support channel
nicrusk01
Post by nicrusk01 »
13:14:36:WU00:FS01:0x22:Completed 1800000 out of 2500000 steps (72%)
13:17:06:WU02:FS00:0xa8:Completed 37500 out of 125000 steps (30%)
13:21:07:WU02:FS00:0xa8:Completed 38750 out of 125000 steps (31%)
13:25:02:WU02:FS00:0xa8:Completed 40000 out of 125000 steps (32%)
13:28:45:WU02:FS00:0xa8:Completed 41250 out of 125000 steps (33%)
13:30:17:WU00:FS01:0x22:Completed 1825000 out of 2500000 steps (73%)
13:32:25:WU02:FS00:0xa8:Completed 42500 out of 125000 steps (34%)
13:36:05:WU02:FS00:0xa8:Completed 43750 out of 125000 steps (35%)
13:39:44:WU02:FS00:0xa8:Completed 45000 out of 125000 steps (36%)
13:43:27:WU02:FS00:0xa8:Completed 46250 out of 125000 steps (37%)
13:45:55:WU00:FS01:0x22:Completed 1850000 out of 2500000 steps (74%)
13:47:06:WU02:FS00:0xa8:Completed 47500 out of 125000 steps (38%)
13:50:46:WU02:FS00:0xa8:Completed 48750 out of 125000 steps (39%)
13:54:24:WU02:FS00:0xa8:Completed 50000 out of 125000 steps (40%)
13:58:07:WU02:FS00:0xa8:Completed 51250 out of 125000 steps (41%)
14:01:32:WU00:FS01:0x22:Completed 1875000 out of 2500000 steps (75%)
14:01:33:WU00:FS01:0x22:Checkpoint completed at step 1875000
14:01:46:WU02:FS00:0xa8:Completed 52500 out of 125000 steps (42%)
14:05:25:WU02:FS00:0xa8:Completed 53750 out of 125000 steps (43%)
14:09:04:WU02:FS00:0xa8:Completed 55000 out of 125000 steps (44%)
14:12:43:WU02:FS00:0xa8:Completed 56250 out of 125000 steps (45%)
14:16:25:WU02:FS00:0xa8:Completed 57500 out of 125000 steps (46%)
14:17:09:WU00:FS01:0x22:Completed 1900000 out of 2500000 steps (76%)
14:20:04:WU02:FS00:0xa8:Completed 58750 out of 125000 steps (47%)
14:23:43:WU02:FS00:0xa8:Completed 60000 out of 125000 steps (48%)
14:27:22:WU02:FS00:0xa8:Completed 61250 out of 125000 steps (49%)
14:31:05:WU02:FS00:0xa8:Completed 62500 out of 125000 steps (50%)
14:32:46:WU00:FS01:0x22:Completed 1925000 out of 2500000 steps (77%)
14:34:44:WU02:FS00:0xa8:Completed 63750 out of 125000 steps (51%)
14:38:22:WU02:FS00:0xa8:Completed 65000 out of 125000 steps (52%)
14:42:02:WU02:FS00:0xa8:Completed 66250 out of 125000 steps (53%)
14:45:46:WU02:FS00:0xa8:Completed 67500 out of 125000 steps (54%)
14:48:24:WU00:FS01:0x22:Completed 1950000 out of 2500000 steps (78%)
14:49:35:WU02:FS00:0xa8:Completed 68750 out of 125000 steps (55%)
14:53:20:WU02:FS00:0xa8:Completed 70000 out of 125000 steps (56%)
14:57:01:WU02:FS00:0xa8:Completed 71250 out of 125000 steps (57%)
15:00:44:WU02:FS00:0xa8:Completed 72500 out of 125000 steps (58%)
15:04:01:WU00:FS01:0x22:Completed 1975000 out of 2500000 steps (79%)
15:04:23:WU02:FS00:0xa8:Completed 73750 out of 125000 steps (59%)
15:08:03:WU02:FS00:0xa8:Completed 75000 out of 125000 steps (60%)
15:11:43:WU02:FS00:0xa8:Completed 76250 out of 125000 steps (61%)
15:15:25:WU02:FS00:0xa8:Completed 77500 out of 125000 steps (62%)
15:19:04:WU02:FS00:0xa8:Completed 78750 out of 125000 steps (63%)
15:19:37:WU00:FS01:0x22:Completed 2000000 out of 2500000 steps (80%)
15:19:38:WU00:FS01:0x22:Checkpoint completed at step 2000000
15:22:43:WU02:FS00:0xa8:Completed 80000 out of 125000 steps (64%)
15:26:22:WU02:FS00:0xa8:Completed 81250 out of 125000 steps (65%)
15:30:05:WU02:FS00:0xa8:Completed 82500 out of 125000 steps (66%)
15:33:44:WU02:FS00:0xa8:Completed 83750 out of 125000 steps (67%)
15:35:14:WU00:FS01:0x22:Completed 2025000 out of 2500000 steps (81%)
15:37:22:WU02:FS00:0xa8:Completed 85000 out of 125000 steps (68%)
15:41:01:WU02:FS00:0xa8:Completed 86250 out of 125000 steps (69%)
15:44:44:WU02:FS00:0xa8:Completed 87500 out of 125000 steps (70%)
15:48:23:WU02:FS00:0xa8:Completed 88750 out of 125000 steps (71%)
15:50:50:WU00:FS01:0x22:Completed 2050000 out of 2500000 steps (82%)
15:52:02:WU02:FS00:0xa8:Completed 90000 out of 125000 steps (72%)
15:55:41:WU02:FS00:0xa8:Completed 91250 out of 125000 steps (73%)
15:59:27:WU02:FS00:0xa8:Completed 92500 out of 125000 steps (74%)
16:03:06:WU02:FS00:0xa8:Completed 93750 out of 125000 steps (75%)
16:06:26:WU00:FS01:0x22:Completed 2075000 out of 2500000 steps (83%)
16:06:44:WU02:FS00:0xa8:Completed 95000 out of 125000 steps (76%)
16:10:23:WU02:FS00:0xa8:Completed 96250 out of 125000 steps (77%)
16:14:10:WU02:FS00:0xa8:Completed 97500 out of 125000 steps (78%)
16:17:48:WU02:FS00:0xa8:Completed 98750 out of 125000 steps (79%)
16:21:27:WU02:FS00:0xa8:Completed 100000 out of 125000 steps (80%)
16:22:02:WU00:FS01:0x22:Completed 2100000 out of 2500000 steps (84%)
16:25:06:WU02:FS00:0xa8:Completed 101250 out of 125000 steps (81%)
16:28:48:WU02:FS00:0xa8:Completed 102500 out of 125000 steps (82%)
16:32:28:WU02:FS00:0xa8:Completed 103750 out of 125000 steps (83%)
16:36:06:WU02:FS00:0xa8:Completed 105000 out of 125000 steps (84%)
16:37:38:WU00:FS01:0x22:Completed 2125000 out of 2500000 steps (85%)
16:37:39:WU00:FS01:0x22:Checkpoint completed at step 2125000
16:39:46:WU02:FS00:0xa8:Completed 106250 out of 125000 steps (85%)
16:43:29:WU02:FS00:0xa8:Completed 107500 out of 125000 steps (86%)
16:47:08:WU02:FS00:0xa8:Completed 108750 out of 125000 steps (87%)
16:50:47:WU02:FS00:0xa8:Completed 110000 out of 125000 steps (88%)
16:53:16:WU00:FS01:0x22:Completed 2150000 out of 2500000 steps (86%)
16:54:25:WU02:FS00:0xa8:Completed 111250 out of 125000 steps (89%)
16:58:08:WU02:FS00:0xa8:Completed 112500 out of 125000 steps (90%)
17:01:47:WU02:FS00:0xa8:Completed 113750 out of 125000 steps (91%)
17:05:27:WU02:FS00:0xa8:Completed 115000 out of 125000 steps (92%)
******************************* Date: 2021-08-20 *******************************
17:08:52:WU00:FS01:0x22:Completed 2175000 out of 2500000 steps (87%)
17:09:05:WU02:FS00:0xa8:Completed 116250 out of 125000 steps (93%)
17:12:45:WU02:FS00:0xa8:Completed 117500 out of 125000 steps (94%)
17:16:27:WU02:FS00:0xa8:Completed 118750 out of 125000 steps (95%)
17:20:06:WU02:FS00:0xa8:Completed 120000 out of 125000 steps (96%)
17:23:45:WU02:FS00:0xa8:Completed 121250 out of 125000 steps (97%)
17:24:28:WU00:FS01:0x22:Completed 2200000 out of 2500000 steps (88%)
17:27:24:WU02:FS00:0xa8:Completed 122500 out of 125000 steps (98%)
17:31:07:WU02:FS00:0xa8:Completed 123750 out of 125000 steps (99%)
17:31:08:WU01:FS00:Connecting to assign1.foldingathome.org:80
17:31:09:WU01:FS00:Assigned to work server 128.252.203.11
17:31:09:WU01:FS00:Requesting new work unit for slot 00: cpu:7 from 128.252.203.11
17:31:09:WU01:FS00:Connecting to 128.252.203.11:8080
17:31:09:WU01:FS00:Downloading 8.34MiB
17:31:10:WU01:FS00:Download complete
17:31:10:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18206 run:9528 clone:8 gen:14 core:0xa8 unit:0x000000080000000e0000471e00002538
17:34:46:WU02:FS00:0xa8:Completed 125000 out of 125000 steps (100%)
17:34:54:WU02:FS00:0xa8:Saving result file ..\logfile_01.txt
17:34:54:WU02:FS00:0xa8:Saving result file frame2.gro
17:34:54:WU02:FS00:0xa8:Saving result file frame2.xtc
17:34:54:WU02:FS00:0xa8:Saving result file md.log
17:34:54:WU02:FS00:0xa8:Saving result file science.log
17:34:54:WU02:FS00:0xa8:Saving result file state.cpt
17:34:55:WU02:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
17:34:55:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:34:55:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:18206 run:14380 clone:7 gen:2 core:0xa8 unit:0x00000007000000020000471e0000382c
17:34:56:WU02:FS00:Uploading 27.85MiB to 128.252.203.11
17:34:56:WU01:FS00:Starting
17:34:56:WU02:FS00:Connecting to 128.252.203.11:8080
17:34:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -np 7
17:34:56:WU01:FS00:Started FahCore on PID 1480
17:34:56:WU01:FS00:Core PID:3036
17:34:56:WU01:FS00:FahCore 0xa8 started
17:34:57:WU01:FS00:0xa8:*********************** Log Started 2021-08-20T17:34:56Z ***********************
17:34:57:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
17:34:57:WU01:FS00:0xa8:       Core: Gromacs
17:34:57:WU01:FS00:0xa8:       Type: 0xa8
17:34:57:WU01:FS00:0xa8:    Version: 0.0.12
17:34:57:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:34:57:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
17:34:57:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
17:34:57:WU01:FS00:0xa8:       Date: Jan 16 2021
17:34:57:WU01:FS00:0xa8:       Time: 11:56:07
17:34:57:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
17:34:57:WU01:FS00:0xa8:     Branch: master
17:34:57:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
17:34:57:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
17:34:57:WU01:FS00:0xa8:   Platform: win32 10
17:34:57:WU01:FS00:0xa8:       Bits: 64
17:34:57:WU01:FS00:0xa8:       Mode: Release
17:34:57:WU01:FS00:0xa8:       SIMD: avx_256
17:34:57:WU01:FS00:0xa8:     OpenMP: ON
17:34:57:WU01:FS00:0xa8:       CUDA: OFF
17:34:57:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1480 -checkpoint 15 -np 7
17:34:57:WU01:FS00:0xa8:************************************ libFAH ************************************
17:34:57:WU01:FS00:0xa8:       Time: 11:24:13
17:34:57:WU01:FS00:0xa8:************************************ CBang *************************************
17:34:57:WU01:FS00:0xa8:       Time: 11:23:53
17:34:57:WU01:FS00:0xa8:************************************ System ************************************
17:34:57:WU01:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
17:34:57:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:34:57:WU01:FS00:0xa8:       CPUs: 8
17:34:57:WU01:FS00:0xa8:     Memory: 15.93GiB
17:34:57:WU01:FS00:0xa8:Free Memory: 12.60GiB
17:34:57:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
17:34:57:WU01:FS00:0xa8: OS Version: 6.2
17:34:57:WU01:FS00:0xa8:Has Battery: false
17:34:57:WU01:FS00:0xa8: On Battery: false
17:34:57:WU01:FS00:0xa8: UTC Offset: -7
17:34:57:WU01:FS00:0xa8:        PID: 3036
17:34:57:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
17:34:57:WU01:FS00:0xa8:********************************************************************************
17:34:57:WU01:FS00:0xa8:Project: 18206 (Run 9528, Clone 8, Gen 14)
17:34:57:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
17:34:57:WU01:FS00:0xa8:Reading tar file core.xml
17:34:57:WU01:FS00:0xa8:Reading tar file frame14.tpr
17:34:57:WU01:FS00:0xa8:Digital signatures verified
17:34:57:WU01:FS00:0xa8:Calling: mdrun -c frame14.gro -s frame14.tpr -x frame14.xtc -cpt 15 -nt 7 -ntmpi 1
17:34:57:WU01:FS00:0xa8:Steps: first=1750000 total=1875000
17:35:00:WU01:FS00:0xa8:Completed 1 out of 125000 steps (0%)
17:35:02:WU02:FS00:Upload 13.02%
17:35:08:WU02:FS00:Upload 28.50%
17:35:14:WU02:FS00:Upload 43.76%
17:35:20:WU02:FS00:Upload 59.25%
17:35:26:WU02:FS00:Upload 74.73%
17:35:32:WU02:FS00:Upload 89.99%
17:35:36:WU02:FS00:Upload complete
17:35:36:WU02:FS00:Server responded WORK_ACK (400)
17:35:36:WU02:FS00:Final credit estimate, 5125.00 points
17:35:36:WU02:FS00:Cleaning up
17:38:41:WU01:FS00:0xa8:Completed 1250 out of 125000 steps (1%)
17:40:04:WU00:FS01:0x22:Completed 2225000 out of 2500000 steps (89%)
17:42:22:WU01:FS00:0xa8:Completed 2500 out of 125000 steps (2%)
17:46:03:WU01:FS00:0xa8:Completed 3750 out of 125000 steps (3%)
17:47:06:WARNING:WU00:FS01:Past final deadline 2021-08-20T17:47:05Z, dumping
17:47:06:WU00:FS01:Shutting core down
17:47:06:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 6276
17:47:06:WU00:FS01:0x22:Exiting, please wait. . .
17:47:06:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
17:47:06:WU02:FS01:Connecting to assign1.foldingathome.org:80
17:47:06:WU02:FS01:Assigned to work server 207.53.233.146
17:47:06:WU02:FS01:Requesting new work unit for slot 01: gpu:5:0 GF100 [Quadro 6000] 1028 from 207.53.233.146
17:47:06:WU02:FS01:Connecting to 207.53.233.146:8080
17:47:06:WU02:FS01:Downloading 6.10MiB
17:47:07:WU02:FS01:Download complete
17:47:08:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:17804 run:32 clone:1 gen:213 core:0x22 unit:0x00000001000000d50000458c00000020
17:47:08:WU02:FS01:Starting
17:47:08:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
17:47:08:WU02:FS01:Started FahCore on PID 8776
17:47:08:WU02:FS01:Core PID:7744
17:47:08:WU02:FS01:FahCore 0x22 started
17:47:08:WU02:FS01:0x22:*********************** Log Started 2021-08-20T17:47:08Z ***********************
17:47:08:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:47:08:WU02:FS01:0x22:       Core: Core22
17:47:08:WU02:FS01:0x22:       Type: 0x22
17:47:08:WU02:FS01:0x22:    Version: 0.0.13
17:47:08:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:47:08:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
17:47:08:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
17:47:08:WU02:FS01:0x22:       Date: Sep 19 2020
17:47:08:WU02:FS01:0x22:       Time: 02:35:58
17:47:08:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
17:47:08:WU02:FS01:0x22:     Branch: core22-0.0.13
17:47:08:WU02:FS01:0x22:   Compiler: Visual C++ 2015
17:47:08:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:47:08:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
17:47:08:WU02:FS01:0x22:   Platform: win32 10
17:47:08:WU02:FS01:0x22:       Bits: 64
17:47:08:WU02:FS01:0x22:       Mode: Release
17:47:08:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:47:08:WU02:FS01:0x22:             <peastman@stanford.edu>
17:47:08:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8776 -checkpoint 15
17:47:08:WU02:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor
17:47:08:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
17:47:08:WU02:FS01:0x22:************************************ libFAH ************************************
17:47:08:WU02:FS01:0x22:       Date: Sep 7 2020
17:47:08:WU02:FS01:0x22:       Time: 19:09:56
17:47:08:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:47:08:WU02:FS01:0x22:     Branch: HEAD
17:47:08:WU02:FS01:0x22:************************************ CBang *************************************
17:47:08:WU02:FS01:0x22:       Time: 19:08:30
17:47:08:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:47:08:WU02:FS01:0x22:************************************ System ************************************
17:47:08:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
17:47:08:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
17:47:08:WU02:FS01:0x22:       CPUs: 8
17:47:08:WU02:FS01:0x22:     Memory: 15.93GiB
17:47:08:WU02:FS01:0x22:Free Memory: 12.35GiB
17:47:08:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
17:47:08:WU02:FS01:0x22: OS Version: 6.2
17:47:08:WU02:FS01:0x22:Has Battery: false
17:47:08:WU02:FS01:0x22: On Battery: false
17:47:08:WU02:FS01:0x22: UTC Offset: -7
17:47:08:WU02:FS01:0x22:        PID: 7744
17:47:08:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:47:08:WU02:FS01:0x22:************************************ OpenMM ************************************
17:47:08:WU02:FS01:0x22:   Revision: 189320d0
17:47:08:WU02:FS01:0x22:********************************************************************************
17:47:08:WU02:FS01:0x22:Project: 17804 (Run 32, Clone 1, Gen 213)
17:47:08:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:47:08:WU02:FS01:0x22:Reading tar file core.xml
17:47:08:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
17:47:08:WU02:FS01:0x22:Reading tar file state.xml.bz2
17:47:08:WU02:FS01:0x22:Reading tar file system.xml.bz2
17:47:08:WU02:FS01:0x22:Digital signatures verified
17:47:08:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:47:08:WU02:FS01:0x22:Version 0.0.13
17:47:08:WU02:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
17:47:08:WU02:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
17:47:08:WU02:FS01:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
17:47:08:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
17:47:08:WU02:FS01:0x22:There are 4 platforms available.
17:47:08:WU02:FS01:0x22:Platform 0: Reference
17:47:08:WU02:FS01:0x22:Platform 1: CPU
17:47:08:WU02:FS01:0x22:Platform 2: OpenCL
17:47:08:WU02:FS01:0x22:  opencl-device 0 specified
17:47:08:WU02:FS01:0x22:Platform 3: CUDA
17:47:08:WU02:FS01:0x22:  cuda-device 0 specified
17:47:18:WU02:FS01:0x22:Attempting to create CUDA context:
17:47:18:WU02:FS01:0x22:  Configuring platform CUDA
17:47:19:WU02:FS01:0x22:Failed to create CUDA context:
17:47:19:WU02:FS01:0x22:Error compiling program: nvrtc: error: invalid value for --gpu-architecture (-arch)
17:47:19:WU02:FS01:0x22:Compilation flags: -arch=compute_20 --use_fast_math
17:47:19:WU02:FS01:0x22:Device compute capability: 2
17:47:19:WU02:FS01:0x22:nvrtc version: 9.2
17:47:19:WU02:FS01:0x22:Attempting to create OpenCL context:
17:47:19:WU02:FS01:0x22:  Configuring platform OpenCL
17:47:22:WU02:FS01:0x22:  Using OpenCL on platformId 1 and gpu 0
17:47:22:WU02:FS01:0x22:Completed 0 out of 2500000 steps (0%)
17:47:22:WU02:FS01:0x22:Checkpoint completed at step 0
17:48:06:WU00:FS01:Cleaning up
17:49:44:WU01:FS00:0xa8:Completed 5000 out of 125000 steps (4%)
17:53:29:WU01:FS00:0xa8:Completed 6250 out of 125000 steps (5%)
17:57:09:WU01:FS00:0xa8:Completed 7500 out of 125000 steps (6%)
18:00:50:WU01:FS00:0xa8:Completed 8750 out of 125000 steps (7%)
18:02:58:WU02:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
18:04:30:WU01:FS00:0xa8:Completed 10000 out of 125000 steps (8%)
18:08:14:WU01:FS00:0xa8:Completed 11250 out of 125000 steps (9%)
18:11:55:WU01:FS00:0xa8:Completed 12500 out of 125000 steps (10%)
18:15:36:WU01:FS00:0xa8:Completed 13750 out of 125000 steps (11%)
18:18:35:WU02:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
18:19:16:WU01:FS00:0xa8:Completed 15000 out of 125000 steps (12%)
18:22:59:WU01:FS00:0xa8:Completed 16250 out of 125000 steps (13%)
18:26:38:WU01:FS00:0xa8:Completed 17500 out of 125000 steps (14%)
18:30:17:WU01:FS00:0xa8:Completed 18750 out of 125000 steps (15%)
18:33:56:WU01:FS00:0xa8:Completed 20000 out of 125000 steps (16%)
18:34:11:WU02:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
18:37:39:WU01:FS00:0xa8:Completed 21250 out of 125000 steps (17%)
18:41:19:WU01:FS00:0xa8:Completed 22500 out of 125000 steps (18%)
18:44:58:WU01:FS00:0xa8:Completed 23750 out of 125000 steps (19%)
18:48:37:WU01:FS00:0xa8:Completed 25000 out of 125000 steps (20%)
18:49:48:WU02:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
18:52:21:WU01:FS00:0xa8:Completed 26250 out of 125000 steps (21%)
18:56:00:WU01:FS00:0xa8:Completed 27500 out of 125000 steps (22%)
18:59:39:WU01:FS00:0xa8:Completed 28750 out of 125000 steps (23%)
19:03:18:WU01:FS00:0xa8:Completed 30000 out of 125000 steps (24%)
19:05:25:WU02:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
19:05:26:WU02:FS01:0x22:Checkpoint completed at step 125000
19:07:01:WU01:FS00:0xa8:Completed 31250 out of 125000 steps (25%)
19:10:41:WU01:FS00:0xa8:Completed 32500 out of 125000 steps (26%)
19:14:21:WU01:FS00:0xa8:Completed 33750 out of 125000 steps (27%)
19:17:59:WU01:FS00:0xa8:Completed 35000 out of 125000 steps (28%)
19:21:03:WU02:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
19:21:42:WU01:FS00:0xa8:Completed 36250 out of 125000 steps (29%)
19:25:21:WU01:FS00:0xa8:Completed 37500 out of 125000 steps (30%)
19:29:00:WU01:FS00:0xa8:Completed 38750 out of 125000 steps (31%)
19:32:40:WU01:FS00:0xa8:Completed 40000 out of 125000 steps (32%)
19:36:23:WU01:FS00:0xa8:Completed 41250 out of 125000 steps (33%)
19:36:39:WU02:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
19:40:02:WU01:FS00:0xa8:Completed 42500 out of 125000 steps (34%)
19:43:42:WU01:FS00:0xa8:Completed 43750 out of 125000 steps (35%)
19:47:21:WU01:FS00:0xa8:Completed 45000 out of 125000 steps (36%)
19:51:04:WU01:FS00:0xa8:Completed 46250 out of 125000 steps (37%)
19:52:15:WU02:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
19:54:43:WU01:FS00:0xa8:Completed 47500 out of 125000 steps (38%)
19:58:21:WU01:FS00:0xa8:Completed 48750 out of 125000 steps (39%)
20:02:06:WU01:FS00:0xa8:Completed 50000 out of 125000 steps (40%)
20:05:53:WU01:FS00:0xa8:Completed 51250 out of 125000 steps (41%)
20:07:53:WU02:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
20:09:33:WU01:FS00:0xa8:Completed 52500 out of 125000 steps (42%)
20:13:13:WU01:FS00:0xa8:Completed 53750 out of 125000 steps (43%)
20:16:52:WU01:FS00:0xa8:Completed 55000 out of 125000 steps (44%)
20:20:35:WU01:FS00:0xa8:Completed 56250 out of 125000 steps (45%)
20:23:29:WU02:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
20:23:30:WU02:FS01:0x22:Checkpoint completed at step 250000
20:24:14:WU01:FS00:0xa8:Completed 57500 out of 125000 steps (46%)
20:27:53:WU01:FS00:0xa8:Completed 58750 out of 125000 steps (47%)
20:31:33:WU01:FS00:0xa8:Completed 60000 out of 125000 steps (48%)
20:35:15:WU01:FS00:0xa8:Completed 61250 out of 125000 steps (49%)
20:38:54:WU01:FS00:0xa8:Completed 62500 out of 125000 steps (50%)
20:39:06:WU02:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
20:42:34:WU01:FS00:0xa8:Completed 63750 out of 125000 steps (51%)
20:46:13:WU01:FS00:0xa8:Completed 65000 out of 125000 steps (52%)
20:49:53:WU01:FS00:0xa8:Completed 66250 out of 125000 steps (53%)
20:53:36:WU01:FS00:0xa8:Completed 67500 out of 125000 steps (54%)
20:54:43:WU02:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
20:57:15:WU01:FS00:0xa8:Completed 68750 out of 125000 steps (55%)
21:00:54:WU01:FS00:0xa8:Completed 70000 out of 125000 steps (56%)
21:04:33:WU01:FS00:0xa8:Completed 71250 out of 125000 steps (57%)
21:08:16:WU01:FS00:0xa8:Completed 72500 out of 125000 steps (58%)
21:10:19:WU02:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
21:11:56:WU01:FS00:0xa8:Completed 73750 out of 125000 steps (59%)
21:15:35:WU01:FS00:0xa8:Completed 75000 out of 125000 steps (60%)
21:19:14:WU01:FS00:0xa8:Completed 76250 out of 125000 steps (61%)
21:22:58:WU01:FS00:0xa8:Completed 77500 out of 125000 steps (62%)
21:25:56:WU02:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
21:26:37:WU01:FS00:0xa8:Completed 78750 out of 125000 steps (63%)
21:30:17:WU01:FS00:0xa8:Completed 80000 out of 125000 steps (64%)
21:33:47:169:127.0.0.1:New Web session
21:33:57:WU01:FS00:0xa8:Completed 81250 out of 125000 steps (65%)
21:34:23:FS00:Shutting core down
21:34:23:FS01:Shutting core down
21:34:23:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 7744
21:34:23:WU02:FS01:0x22:Exiting, please wait. . .
21:34:23:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
21:34:23:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 3036
21:34:23:WU01:FS00:0xa8:Exiting, please wait. . .
21:34:23:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:34:27:195:127.0.0.1:New Web session
21:34:29:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
21:34:29:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:34:55:Removing old file 'configs/config-20210813-020422.xml'
21:34:55:Saving configuration to config.xml
21:34:55:<config>
21:34:55:  <!-- Folding Slot Configuration -->
21:34:55:  <cause v='ALZHEIMERS'/>
21:34:55:
21:34:55:  <!-- Network -->
21:34:55:  <proxy v=':8080'/>
21:34:55:
21:34:55:  <!-- Remote Command Server -->
21:34:55:  <password v='*****'/>
21:34:55:
21:34:55:  <!-- Slot Control -->
21:34:55:  <power v='FULL'/>
21:34:55:
21:34:55:  <!-- User Information -->
21:34:55:  <user v='NichollasRusk'/>
21:34:55:
21:34:55:  <!-- Folding Slots -->
21:34:55:  <slot id='0' type='CPU'>
21:34:55:    <idle v='true'/>
21:34:55:  </slot>
21:34:55:  <slot id='1' type='GPU'>
21:34:55:    <pci-bus v='5'/>
21:34:55:    <pci-slot v='0'/>
21:34:55:  </slot>
21:34:55:</config>
******************************* Date: 2021-08-21 *******************************
00:12:12:WU01:FS00:Starting
00:12:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -np 7
00:12:12:WU01:FS00:Started FahCore on PID 10180
00:12:12:WU01:FS00:Core PID:5580
00:12:12:WU01:FS00:FahCore 0xa8 started
00:12:12:WU02:FS01:Starting
00:12:12:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:12:12:WU02:FS01:Started FahCore on PID 3192
00:12:12:WU01:FS00:0xa8:*********************** Log Started 2021-08-21T00:12:12Z ***********************
00:12:12:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
00:12:12:WU01:FS00:0xa8:       Core: Gromacs
00:12:12:WU01:FS00:0xa8:       Type: 0xa8
00:12:12:WU01:FS00:0xa8:    Version: 0.0.12
00:12:12:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:12:12:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
00:12:12:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
00:12:12:WU01:FS00:0xa8:       Date: Jan 16 2021
00:12:12:WU01:FS00:0xa8:       Time: 11:56:07
00:12:12:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
00:12:12:WU01:FS00:0xa8:     Branch: master
00:12:12:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
00:12:12:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
00:12:12:WU01:FS00:0xa8:   Platform: win32 10
00:12:12:WU01:FS00:0xa8:       Bits: 64
00:12:12:WU01:FS00:0xa8:       Mode: Release
00:12:12:WU01:FS00:0xa8:       SIMD: avx_256
00:12:12:WU01:FS00:0xa8:     OpenMP: ON
00:12:12:WU01:FS00:0xa8:       CUDA: OFF
00:12:12:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10180 -checkpoint 15 -np
00:12:12:WU01:FS00:0xa8:             7
00:12:12:WU01:FS00:0xa8:************************************ libFAH ************************************
00:12:12:WU01:FS00:0xa8:       Time: 11:24:13
00:12:12:WU01:FS00:0xa8:************************************ CBang *************************************
00:12:12:WU01:FS00:0xa8:       Time: 11:23:53
00:12:12:WU01:FS00:0xa8:************************************ System ************************************
00:12:12:WU01:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
00:12:12:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
00:12:12:WU01:FS00:0xa8:       CPUs: 8
00:12:12:WU01:FS00:0xa8:     Memory: 15.93GiB
00:12:12:WU01:FS00:0xa8:Free Memory: 11.80GiB
00:12:12:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
00:12:12:WU01:FS00:0xa8: OS Version: 6.2
00:12:12:WU01:FS00:0xa8:Has Battery: false
00:12:12:WU01:FS00:0xa8: On Battery: false
00:12:12:WU01:FS00:0xa8: UTC Offset: -7
00:12:12:WU01:FS00:0xa8:        PID: 5580
00:12:12:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
00:12:12:WU01:FS00:0xa8:********************************************************************************
00:12:12:WU01:FS00:0xa8:Project: 18206 (Run 9528, Clone 8, Gen 14)
00:12:12:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
00:12:12:WU01:FS00:0xa8:Digital signatures verified
00:12:12:WU01:FS00:0xa8:Calling: mdrun -c frame14.gro -s frame14.tpr -x frame14.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
00:12:12:WU01:FS00:0xa8:Steps: first=1750000 total=1875000
00:12:12:WU02:FS01:Core PID:3276
00:12:12:WU02:FS01:FahCore 0x22 started
00:12:13:WU02:FS01:0x22:*********************** Log Started 2021-08-21T00:12:13Z ***********************
00:12:13:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:12:13:WU02:FS01:0x22:       Core: Core22
00:12:13:WU02:FS01:0x22:       Type: 0x22
00:12:13:WU02:FS01:0x22:    Version: 0.0.13
00:12:13:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:12:13:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
00:12:13:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
00:12:13:WU02:FS01:0x22:       Date: Sep 19 2020
00:12:13:WU02:FS01:0x22:       Time: 02:35:58
00:12:13:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:12:13:WU02:FS01:0x22:     Branch: core22-0.0.13
00:12:13:WU02:FS01:0x22:   Compiler: Visual C++ 2015
00:12:13:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:12:13:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
00:12:13:WU02:FS01:0x22:   Platform: win32 10
00:12:13:WU02:FS01:0x22:       Bits: 64
00:12:13:WU02:FS01:0x22:       Mode: Release
00:12:13:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:12:13:WU02:FS01:0x22:             <peastman@stanford.edu>
00:12:13:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 3192 -checkpoint 15
00:12:13:WU02:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:12:13:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
00:12:13:WU02:FS01:0x22:************************************ libFAH ************************************
00:12:13:WU02:FS01:0x22:       Date: Sep 7 2020
00:12:13:WU02:FS01:0x22:       Time: 19:09:56
00:12:13:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:12:13:WU02:FS01:0x22:     Branch: HEAD
00:12:13:WU02:FS01:0x22:************************************ CBang *************************************
00:12:13:WU02:FS01:0x22:       Time: 19:08:30
00:12:13:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:12:13:WU02:FS01:0x22:************************************ System ************************************
00:12:13:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
00:12:13:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
00:12:13:WU02:FS01:0x22:       CPUs: 8
00:12:13:WU02:FS01:0x22:     Memory: 15.93GiB
00:12:13:WU02:FS01:0x22:Free Memory: 11.72GiB
00:12:13:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
00:12:13:WU02:FS01:0x22: OS Version: 6.2
00:12:13:WU02:FS01:0x22:Has Battery: false
00:12:13:WU02:FS01:0x22: On Battery: false
00:12:13:WU02:FS01:0x22: UTC Offset: -7
00:12:13:WU02:FS01:0x22:        PID: 3276
00:12:13:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
00:12:13:WU02:FS01:0x22:************************************ OpenMM ************************************
00:12:13:WU02:FS01:0x22:   Revision: 189320d0
00:12:13:WU02:FS01:0x22:********************************************************************************
00:12:13:WU02:FS01:0x22:Project: 17804 (Run 32, Clone 1, Gen 213)
00:12:13:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:12:13:WU02:FS01:0x22:Digital signatures verified
00:12:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:12:13:WU02:FS01:0x22:Version 0.0.13
00:12:13:WU02:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
00:12:13:WU02:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:12:13:WU02:FS01:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
00:12:13:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
00:12:14:WU02:FS01:0x22:There are 4 platforms available.
00:12:14:WU02:FS01:0x22:Platform 0: Reference
00:12:14:WU02:FS01:0x22:Platform 1: CPU
00:12:14:WU02:FS01:0x22:Platform 2: OpenCL
00:12:14:WU02:FS01:0x22:  opencl-device 0 specified
00:12:14:WU02:FS01:0x22:Platform 3: CUDA
00:12:14:WU02:FS01:0x22:  cuda-device 0 specified
00:12:16:WU01:FS00:0xa8:Completed 81402 out of 125000 steps (65%)
00:12:19:244:127.0.0.1:New Web session
00:12:23:WU02:FS01:0x22:Attempting to create CUDA context:
00:12:23:WU02:FS01:0x22:  Configuring platform CUDA
00:12:24:WU02:FS01:0x22:Failed to create CUDA context:
00:12:24:WU02:FS01:0x22:Error compiling program: nvrtc: error: invalid value for --gpu-architecture (-arch)
00:12:24:WU02:FS01:0x22:Compilation flags: -arch=compute_20 --use_fast_math
00:12:24:WU02:FS01:0x22:Device compute capability: 2
00:12:24:WU02:FS01:0x22:nvrtc version: 9.2
00:12:24:WU02:FS01:0x22:Attempting to create OpenCL context:
00:12:24:WU02:FS01:0x22:  Configuring platform OpenCL
00:12:28:WU02:FS01:0x22:  Using OpenCL on platformId 1 and gpu 0
00:12:28:WU02:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
00:12:30:Removing old file 'configs/config-20210817-063222.xml'
00:12:30:Saving configuration to config.xml
00:12:30:<config>
00:12:30:  <!-- Folding Slot Configuration -->
00:12:30:  <cause v='ALZHEIMERS'/>
00:12:30:
00:12:30:  <!-- Network -->
00:12:30:  <proxy v=':8080'/>
00:12:30:
00:12:30:  <!-- Remote Command Server -->
00:12:30:  <password v='*****'/>
00:12:30:
00:12:30:  <!-- Slot Control -->
00:12:30:  <power v='FULL'/>
00:12:30:
00:12:30:  <!-- User Information -->
00:12:30:  <user v='NichollasRusk'/>
00:12:30:
00:12:30:  <!-- Folding Slots -->
00:12:30:  <slot id='0' type='CPU'/>
00:12:30:  <slot id='1' type='GPU'>
00:12:30:    <pci-bus v='5'/>
00:12:30:    <pci-slot v='0'/>
00:12:30:  </slot>
00:12:30:</config>
00:15:45:WU01:FS00:0xa8:Completed 82500 out of 125000 steps (66%)
00:20:09:WU01:FS00:0xa8:Completed 83750 out of 125000 steps (67%)
00:24:27:WU01:FS00:0xa8:Completed 85000 out of 125000 steps (68%)
00:28:21:WU02:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
00:28:37:WU01:FS00:0xa8:Completed 86250 out of 125000 steps (69%)
00:32:42:WU01:FS00:0xa8:Completed 87500 out of 125000 steps (70%)
00:36:45:WU01:FS00:0xa8:Completed 88750 out of 125000 steps (71%)
00:40:50:WU01:FS00:0xa8:Completed 90000 out of 125000 steps (72%)
00:44:12:WU02:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
00:44:57:WU01:FS00:0xa8:Completed 91250 out of 125000 steps (73%)
00:49:00:WU01:FS00:0xa8:Completed 92500 out of 125000 steps (74%)
00:53:18:WU01:FS00:0xa8:Completed 93750 out of 125000 steps (75%)
00:57:53:WU01:FS00:0xa8:Completed 95000 out of 125000 steps (76%)
01:00:24:WU02:FS01:0x22:Completed 325000 out of 2500000 steps (13%)
01:02:16:WU01:FS00:0xa8:Completed 96250 out of 125000 steps (77%)
01:06:04:WU01:FS00:0xa8:Completed 97500 out of 125000 steps (78%)
01:09:57:WU01:FS00:0xa8:Completed 98750 out of 125000 steps (79%)
01:14:06:WU01:FS00:0xa8:Completed 100000 out of 125000 steps (80%)
01:16:12:WU02:FS01:0x22:Completed 350000 out of 2500000 steps (14%)
01:18:25:WU01:FS00:0xa8:Completed 101250 out of 125000 steps (81%)
01:22:34:WU01:FS00:0xa8:Completed 102500 out of 125000 steps (82%)
01:26:42:WU01:FS00:0xa8:Completed 103750 out of 125000 steps (83%)
01:30:59:WU01:FS00:0xa8:Completed 105000 out of 125000 steps (84%)
01:32:07:WU02:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
01:32:09:WU02:FS01:0x22:Checkpoint completed at step 375000
01:35:12:WU01:FS00:0xa8:Completed 106250 out of 125000 steps (85%)
01:39:24:WU01:FS00:0xa8:Completed 107500 out of 125000 steps (86%)
01:43:39:WU01:FS00:0xa8:Completed 108750 out of 125000 steps (87%)
01:47:45:WU01:FS00:0xa8:Completed 110000 out of 125000 steps (88%)
01:48:03:WU02:FS01:0x22:Completed 400000 out of 2500000 steps (16%)
01:52:01:WU01:FS00:0xa8:Completed 111250 out of 125000 steps (89%)
01:56:04:WU01:FS00:0xa8:Completed 112500 out of 125000 steps (90%)
02:00:03:WU01:FS00:0xa8:Completed 113750 out of 125000 steps (91%)
02:03:47:WU02:FS01:0x22:Completed 425000 out of 2500000 steps (17%)
02:03:58:WU01:FS00:0xa8:Completed 115000 out of 125000 steps (92%)
02:07:56:WU01:FS00:0xa8:Completed 116250 out of 125000 steps (93%)
02:11:47:WU01:FS00:0xa8:Completed 117500 out of 125000 steps (94%)
02:15:38:WU01:FS00:0xa8:Completed 118750 out of 125000 steps (95%)
02:19:26:WU02:FS01:0x22:Completed 450000 out of 2500000 steps (18%)
02:19:26:WU01:FS00:0xa8:Completed 120000 out of 125000 steps (96%)
02:23:14:WU01:FS00:0xa8:Completed 121250 out of 125000 steps (97%)
02:27:01:WU01:FS00:0xa8:Completed 122500 out of 125000 steps (98%)
02:31:00:WU01:FS00:0xa8:Completed 123750 out of 125000 steps (99%)
02:31:00:WU00:FS00:Connecting to assign1.foldingathome.org:80
02:31:01:WU00:FS00:Assigned to work server 129.32.209.205
02:31:01:WU00:FS00:Requesting new work unit for slot 00: cpu:7 from 129.32.209.205
02:31:01:WU00:FS00:Connecting to 129.32.209.205:8080
02:31:01:WU00:FS00:Downloading 1.47MiB
02:31:01:WU00:FS00:Download complete
02:31:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:23 clone:121 gen:198 core:0xa8 unit:0x00000079000000c60000423f00000017
02:33:45:279:127.0.0.1:New Web session
02:34:01:FS00:Shutting core down
02:34:01:FS01:Shutting core down
02:34:02:WU01:FS00:0xa8:WARNING:Console control signal 1 on PID 5580
02:34:02:WU02:FS01:0x22:WARNING:Console control signal 1 on PID 3276
02:34:02:WU01:FS00:0xa8:Exiting, please wait. . .
02:34:02:WU02:FS01:0x22:Exiting, please wait. . .
02:34:02:WU02:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
02:34:02:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:34:06:WU01:FS00:0xa8:Folding@home Core Shutdown: INTERRUPTED
02:34:07:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:34:09:299:127.0.0.1:New Web session
02:34:50:Removing old file 'configs/config-20210817-063252.xml'
02:34:50:Saving configuration to config.xml
02:34:50:<config>
02:34:50:  <!-- Folding Slot Configuration -->
02:34:50:  <cause v='ALZHEIMERS'/>
02:34:50:
02:34:50:  <!-- Network -->
02:34:50:  <proxy v=':8080'/>
02:34:50:
02:34:50:  <!-- Remote Command Server -->
02:34:50:  <password v='*****'/>
02:34:50:
02:34:50:  <!-- Slot Control -->
02:34:50:  <power v='FULL'/>
02:34:50:
02:34:50:  <!-- User Information -->
02:34:50:  <user v='NichollasRusk'/>
02:34:50:
02:34:50:  <!-- Folding Slots -->
02:34:50:  <slot id='0' type='CPU'>
02:34:50:    <idle v='true'/>
02:34:50:  </slot>
02:34:50:  <slot id='1' type='GPU'>
02:34:50:    <pci-bus v='5'/>
02:34:50:    <pci-slot v='0'/>
02:34:50:  </slot>
02:34:50:</config>
02:44:54:WU01:FS00:Starting
02:44:54:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -np 7
02:44:54:WU01:FS00:Started FahCore on PID 9888
02:44:54:WU01:FS00:Core PID:2816
02:44:54:WU01:FS00:FahCore 0xa8 started
02:44:54:WU02:FS01:Starting
02:44:54:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:44:54:WU02:FS01:Started FahCore on PID 4820
02:44:54:WU02:FS01:Core PID:4032
02:44:54:WU02:FS01:FahCore 0x22 started
02:44:55:WU01:FS00:0xa8:*********************** Log Started 2021-08-21T02:44:54Z ***********************
02:44:55:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
02:44:55:WU01:FS00:0xa8:       Core: Gromacs
02:44:55:WU01:FS00:0xa8:       Type: 0xa8
02:44:55:WU01:FS00:0xa8:    Version: 0.0.12
02:44:55:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:44:55:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
02:44:55:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
02:44:55:WU01:FS00:0xa8:       Date: Jan 16 2021
02:44:55:WU01:FS00:0xa8:       Time: 11:56:07
02:44:55:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
02:44:55:WU01:FS00:0xa8:     Branch: master
02:44:55:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
02:44:55:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:44:55:WU01:FS00:0xa8:   Platform: win32 10
02:44:55:WU01:FS00:0xa8:       Bits: 64
02:44:55:WU01:FS00:0xa8:       Mode: Release
02:44:55:WU01:FS00:0xa8:       SIMD: avx_256
02:44:55:WU01:FS00:0xa8:     OpenMP: ON
02:44:55:WU01:FS00:0xa8:       CUDA: OFF
02:44:55:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9888 -checkpoint 15 -np 7
02:44:55:WU01:FS00:0xa8:************************************ libFAH ************************************
02:44:55:WU01:FS00:0xa8:       Time: 11:24:13
02:44:55:WU01:FS00:0xa8:************************************ CBang *************************************
02:44:55:WU01:FS00:0xa8:       Time: 11:23:53
02:44:55:WU01:FS00:0xa8:************************************ System ************************************
02:44:55:WU01:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
02:44:55:WU01:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
02:44:55:WU01:FS00:0xa8:       CPUs: 8
02:44:55:WU01:FS00:0xa8:     Memory: 15.93GiB
02:44:55:WU01:FS00:0xa8:Free Memory: 11.73GiB
02:44:55:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
02:44:55:WU01:FS00:0xa8: OS Version: 6.2
02:44:55:WU01:FS00:0xa8:Has Battery: false
02:44:55:WU01:FS00:0xa8: On Battery: false
02:44:55:WU01:FS00:0xa8: UTC Offset: -7
02:44:55:WU01:FS00:0xa8:        PID: 2816
02:44:55:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
02:44:55:WU01:FS00:0xa8:********************************************************************************
02:44:55:WU01:FS00:0xa8:Project: 18206 (Run 9528, Clone 8, Gen 14)
02:44:55:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
02:44:55:WU01:FS00:0xa8:Digital signatures verified
02:44:55:WU01:FS00:0xa8:Calling: mdrun -c frame14.gro -s frame14.tpr -x frame14.xtc -cpi state.cpt -cpt 15 -nt 7 -ntmpi 1
02:44:55:WU02:FS01:0x22:*********************** Log Started 2021-08-21T02:44:55Z ***********************
02:44:55:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:44:55:WU02:FS01:0x22:       Core: Core22
02:44:55:WU02:FS01:0x22:       Type: 0x22
02:44:55:WU02:FS01:0x22:    Version: 0.0.13
02:44:55:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:44:55:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
02:44:55:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
02:44:55:WU02:FS01:0x22:       Date: Sep 19 2020
02:44:55:WU02:FS01:0x22:       Time: 02:35:58
02:44:55:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:44:55:WU02:FS01:0x22:     Branch: core22-0.0.13
02:44:55:WU02:FS01:0x22:   Compiler: Visual C++ 2015
02:44:55:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:44:55:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
02:44:55:WU01:FS00:0xa8:Steps: first=1750000 total=1875000
02:44:55:WU02:FS01:0x22:   Platform: win32 10
02:44:55:WU02:FS01:0x22:       Bits: 64
02:44:55:WU02:FS01:0x22:       Mode: Release
02:44:55:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:44:55:WU02:FS01:0x22:             <peastman@stanford.edu>
02:44:55:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4820 -checkpoint 15
02:44:55:WU02:FS01:0x22:             -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:44:55:WU02:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
02:44:55:WU02:FS01:0x22:************************************ libFAH ************************************
02:44:55:WU02:FS01:0x22:       Date: Sep 7 2020
02:44:55:WU02:FS01:0x22:       Time: 19:09:56
02:44:55:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:44:55:WU02:FS01:0x22:     Branch: HEAD
02:44:55:WU02:FS01:0x22:************************************ CBang *************************************
02:44:55:WU02:FS01:0x22:       Time: 19:08:30
02:44:55:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:44:55:WU02:FS01:0x22:************************************ System ************************************
02:44:55:WU02:FS01:0x22:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
02:44:55:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
02:44:55:WU02:FS01:0x22:       CPUs: 8
02:44:55:WU02:FS01:0x22:     Memory: 15.93GiB
02:44:55:WU02:FS01:0x22:Free Memory: 11.73GiB
02:44:55:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
02:44:55:WU02:FS01:0x22: OS Version: 6.2
02:44:55:WU02:FS01:0x22:Has Battery: false
02:44:55:WU02:FS01:0x22: On Battery: false
02:44:55:WU02:FS01:0x22: UTC Offset: -7
02:44:55:WU02:FS01:0x22:        PID: 4032
02:44:55:WU02:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
02:44:55:WU02:FS01:0x22:************************************ OpenMM ************************************
02:44:55:WU02:FS01:0x22:   Revision: 189320d0
02:44:55:WU02:FS01:0x22:********************************************************************************
02:44:55:WU02:FS01:0x22:Project: 17804 (Run 32, Clone 1, Gen 213)
02:44:55:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
02:44:55:WU02:FS01:0x22:Digital signatures verified
02:44:55:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:44:55:WU02:FS01:0x22:Version 0.0.13
02:44:55:WU02:FS01:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
02:44:55:WU02:FS01:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
02:44:55:WU02:FS01:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
02:44:55:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
02:44:56:WU02:FS01:0x22:There are 4 platforms available.
02:44:56:WU02:FS01:0x22:Platform 0: Reference
02:44:56:WU02:FS01:0x22:Platform 1: CPU
02:44:56:WU02:FS01:0x22:Platform 2: OpenCL
02:44:56:WU02:FS01:0x22:  opencl-device 0 specified
02:44:56:WU02:FS01:0x22:Platform 3: CUDA
02:44:56:WU02:FS01:0x22:  cuda-device 0 specified
02:44:59:WU01:FS00:0xa8:Completed 124562 out of 125000 steps (99%)
02:45:01:Removing old file 'configs/config-20210817-063457.xml'
02:45:01:Saving configuration to config.xml
02:45:01:<config>
02:45:01:  <!-- Folding Slot Configuration -->
02:45:01:  <cause v='ALZHEIMERS'/>
02:45:01:
02:45:01:  <!-- Network -->
02:45:01:  <proxy v=':8080'/>
02:45:01:
02:45:01:  <!-- Remote Command Server -->
02:45:01:  <password v='*****'/>
02:45:01:
02:45:01:  <!-- Slot Control -->
02:45:01:  <power v='FULL'/>
02:45:01:
02:45:01:  <!-- User Information -->
02:45:01:  <user v='NichollasRusk'/>
02:45:01:
02:45:01:  <!-- Folding Slots -->
02:45:01:  <slot id='0' type='CPU'/>
02:45:01:  <slot id='1' type='GPU'>
02:45:01:    <pci-bus v='5'/>
02:45:01:    <pci-slot v='0'/>
02:45:01:  </slot>
02:45:01:</config>
02:45:03:326:127.0.0.1:New Web session
02:45:04:WU02:FS01:0x22:Attempting to create CUDA context:
02:45:04:WU02:FS01:0x22:  Configuring platform CUDA
02:45:05:WU02:FS01:0x22:Failed to create CUDA context:
02:45:05:WU02:FS01:0x22:Error compiling program: nvrtc: error: invalid value for --gpu-architecture (-arch)
02:45:05:WU02:FS01:0x22:Compilation flags: -arch=compute_20 --use_fast_math
02:45:05:WU02:FS01:0x22:Device compute capability: 2
02:45:05:WU02:FS01:0x22:nvrtc version: 9.2
02:45:05:WU02:FS01:0x22:Attempting to create OpenCL context:
02:45:05:WU02:FS01:0x22:  Configuring platform OpenCL
02:45:09:WU02:FS01:0x22:  Using OpenCL on platformId 1 and gpu 0
02:45:09:WU02:FS01:0x22:Completed 375000 out of 2500000 steps (15%)
02:46:21:WU01:FS00:0xa8:Completed 125000 out of 125000 steps (100%)
02:46:29:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
02:46:29:WU01:FS00:0xa8:Saving result file frame14.gro
02:46:29:WU01:FS00:0xa8:Saving result file frame14.xtc
02:46:29:WU01:FS00:0xa8:Saving result file md.log
02:46:29:WU01:FS00:0xa8:Saving result file science.log
02:46:29:WU01:FS00:0xa8:Saving result file state.cpt
02:46:29:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
02:46:30:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:46:30:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:18206 run:9528 clone:8 gen:14 core:0xa8 unit:0x000000080000000e0000471e00002538
02:46:30:WU01:FS00:Uploading 27.84MiB to 128.252.203.11
02:46:30:WU00:FS00:Starting
02:46:30:WU01:FS00:Connecting to 128.252.203.11:8080
02:46:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 7416 -checkpoint 15 -np 7
02:46:30:WU00:FS00:Started FahCore on PID 8528
02:46:30:WU00:FS00:Core PID:10716
02:46:30:WU00:FS00:FahCore 0xa8 started
02:46:30:WU00:FS00:0xa8:*********************** Log Started 2021-08-21T02:46:30Z ***********************
02:46:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
02:46:30:WU00:FS00:0xa8:       Core: Gromacs
02:46:30:WU00:FS00:0xa8:       Type: 0xa8
02:46:30:WU00:FS00:0xa8:    Version: 0.0.12
02:46:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
02:46:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
02:46:30:WU00:FS00:0xa8:       Date: Jan 16 2021
02:46:30:WU00:FS00:0xa8:       Time: 11:56:07
02:46:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
02:46:30:WU00:FS00:0xa8:     Branch: master
02:46:30:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
02:46:30:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:46:30:WU00:FS00:0xa8:   Platform: win32 10
02:46:30:WU00:FS00:0xa8:       Bits: 64
02:46:30:WU00:FS00:0xa8:       Mode: Release
02:46:30:WU00:FS00:0xa8:       SIMD: avx_256
02:46:30:WU00:FS00:0xa8:     OpenMP: ON
02:46:30:WU00:FS00:0xa8:       CUDA: OFF
02:46:30:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8528 -checkpoint 15 -np 7
02:46:30:WU00:FS00:0xa8:************************************ libFAH ************************************
02:46:30:WU00:FS00:0xa8:       Time: 11:24:13
02:46:30:WU00:FS00:0xa8:************************************ CBang *************************************
02:46:30:WU00:FS00:0xa8:       Time: 11:23:53
02:46:30:WU00:FS00:0xa8:************************************ System ************************************
02:46:30:WU00:FS00:0xa8:        CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
02:46:30:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
02:46:30:WU00:FS00:0xa8:       CPUs: 8
02:46:30:WU00:FS00:0xa8:     Memory: 15.93GiB
02:46:30:WU00:FS00:0xa8:Free Memory: 11.38GiB
02:46:30:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
02:46:30:WU00:FS00:0xa8: OS Version: 6.2
02:46:30:WU00:FS00:0xa8:Has Battery: false
02:46:30:WU00:FS00:0xa8: On Battery: false
02:46:30:WU00:FS00:0xa8: UTC Offset: -7
02:46:30:WU00:FS00:0xa8:        PID: 10716
02:46:30:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
02:46:30:WU00:FS00:0xa8:********************************************************************************
02:46:30:WU00:FS00:0xa8:Project: 16959 (Run 23, Clone 121, Gen 198)
02:46:30:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
02:46:30:WU00:FS00:0xa8:Reading tar file core.xml
02:46:30:WU00:FS00:0xa8:Reading tar file frame198.tpr
02:46:30:WU00:FS00:0xa8:Digital signatures verified
02:46:31:WU00:FS00:0xa8:Calling: mdrun -c frame198.gro -s frame198.tpr -x frame198.xtc -cpt 15 -nt 7 -ntmpi 1
02:46:31:WU00:FS00:0xa8:Steps: first=495000000 total=497500000
02:46:31:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
02:46:36:WU01:FS00:Upload 8.76%
02:46:42:WU01:FS00:Upload 18.19%
02:46:48:WU01:FS00:Upload 27.39%
02:46:54:WU01:FS00:Upload 36.37%
02:47:00:WU01:FS00:Upload 50.07%
02:47:06:WU01:FS00:Upload 65.56%
02:47:12:WU01:FS00:Upload 80.83%
02:47:18:WU01:FS00:Upload 96.33%
02:47:21:WU01:FS00:Upload complete
02:47:21:WU01:FS00:Server responded WORK_ACK (400)
02:47:21:WU01:FS00:Final credit estimate, 7696.00 points
02:47:21:WU01:FS00:Cleaning up
Reason: added Code tags to log
nicrusk01
Re: Quadro 6000 6gb low PPD?
Post by nicrusk01 »
AND NO PASSKEY
i do not have GPUs this old in my farm, but let me explain.
Nvidia GPUs can use the CUDA interface which only works on Nvidia but is about 30% faster, or the OpenCL interface, which also works on AMD and Intel GPUs. Your card is so old that it does not support the minimum version of CUDA F@H needs,
So you can see it try to use CUDA and fall back to the slower OpenCL, there is a flag to make it use OpenCL by default but it does not take the client much time (one second?) to fail and retry.
nicrusk01
Post by nicrusk01 »
ok thanks
Gary480six
Post by Gary480six »
The Quadro 6000 video card from 2010 is roughly the same card as a GTX 470. Same number of CUDA cores and same GF100 series chip. The GTX 470 is still supported for the Folding program.
The LAR website says that chip is good for about 47,000 PPD.
But your card (or PC) is crashing while Folding. That's different than 'not supported'
I do see that your Folding is configured to Fold 'Only When Idle'. Changing that to 'When I'm Working' may get that video card producing some better points.
Knish
Post by Knish »
wow... i almost bought a quadro 6000 thinking it was a quadro RTX 6000. This thread was the start to me questioning things that lead me to find that there's actually a big difference!
I had the pleasure of using the latter via Linode's cloud services last year. the $100 credit let me fold 13.5 mil points for almost 62 hrs. fyi linode's still offering that same credit for new sign ups. If you had fun following the (now defunct) GCP/Azure guides last time, that's probably enough experience to give Linode a shot. They have good tutorials on their own site. The only difference I can remember from GCP/Azure was installing a firewall for security. As always, a Warning: these are paid services so if you don't track your credits closely, you could end up owing thousands
