Hi,
I've returned results for several jobs to work server 140.163.4.210 (p16466 and p16467) that aren't credited yet. I know 140.163.4.200 is under investigation, 140.163.4.210 may suffer from the same problem. Of course, given the IP addresses, both may suffer from a single cause (routing or firewalling), but then again, who knows...
Work server 140.163.4.210: credits not sent to stats server?
Re: Work server 140.163.4.210: credits not sent to stats ser
Sukrit Singh wrote: Ok! the SSH access is opened again! The stats server will likely have a bunch of updating to get through so give it a day or so to update and then it should be good
Yup, it's done or nearly done catching up already. Goody!
