[EDIT]Are the WUs that failed to download counted as expired
fz4z
Post by fz4z »
I found some WUs Expired on "https://apps.foldingathome.org/bonus", and there are only "WU download fail" in client logs, so are the WUs that failed to download counted as expired ?
08/20/2021 EDIT: There was server side glitch that caused "expired wu" counts incrementing up. https://foldingforum.org/viewtopic.php?f=38&t=37400
Re: Are the WUs that failed to download counted as expired ?
I have no idea ... but I'm worried about your download failures ... this shouldn't happen.
What does you log show ?
fz4z
Post by fz4z »
toTOW wrote:I have no idea ... but I'm worried about your download failures ... this shouldn't happen.
17:49:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:49:24:WU00:FS01:Assigned to work server 128.174.73.74
17:49:24:WU00:FS01:Requesting new work unit for slot 01: gpu:0:11 GA102 [GeForce RTX 3080] from 128.174.73.74
17:49:24:WU00:FS01:Connecting to 128.174.73.74:8080
17:49:37:WU00:FS01:Downloading 11.38MiB
17:51:31:WU00:FS01:Download 0.51%
17:51:31:ERROR:WU00:FS01:Exception: Transfer failed
I judged that my old ISP was not stable and had replaced it with a new one. I will continue to monitor whether WUs Expired is related to download failures. ( I'm worried that there are other problems with my PC, which will cause WUs Expired. )
aetch
Post by aetch »
Can you post the first few hundred lines of your log.
fz4z
Post by fz4z »
aetch wrote:Can you post the first few hundred lines of your log.
17:45:51:WU01:FS00:0xa7:Completed 11875 out of 62500 steps (19%)
17:46:46:WU02:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
17:47:34:WU01:FS00:0xa7:Completed 12500 out of 62500 steps (20%)
17:48:02:WU02:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
17:48:06:WU02:FS01:0x22:Checkpoint completed at step 1225000
17:49:21:WU01:FS00:0xa7:Completed 13125 out of 62500 steps (21%)
17:49:22:WU02:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
17:50:38:WU02:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
17:50:38:WU02:FS01:0x22:Average performance: 22.7368 ns/day
17:50:42:WU02:FS01:0x22:Checkpoint completed at step 1250000
17:50:50:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
17:50:50:WU02:FS01:0x22:Saving result file checkpointIntegrator.xml
17:50:50:WU02:FS01:0x22:Saving result file checkpointState.xml
17:50:57:WU02:FS01:0x22:Saving result file positions.xtc
17:50:57:WU02:FS01:0x22:Saving result file science.log
17:50:57:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:50:58:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:50:58:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:18202 run:5625 clone:0 gen:14 core:0x22 unit:0x000000000000000e0000471a000015f9
17:50:58:WU02:FS01:Uploading 27.51MiB to 128.252.203.11
17:50:58:WU02:FS01:Connecting to 128.252.203.11:8080
17:51:04:WU02:FS01:Upload 2.04%
17:51:05:WU01:FS00:0xa7:Completed 13750 out of 62500 steps (22%)
17:51:10:WU02:FS01:Upload 4.32%
17:51:17:WU02:FS01:Upload 5.68%
17:51:23:WU02:FS01:Upload 6.82%
17:51:29:WU02:FS01:Upload 10.00%
17:51:31:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:51:32:WU00:FS01:Assigned to work server 34.72.228.44
17:51:32:WU00:FS01:Requesting new work unit for slot 01: gpu:0:11 GA102 [GeForce RTX 3080] from 34.72.228.44
17:51:32:WU00:FS01:Connecting to 34.72.228.44:8080
17:51:35:WU02:FS01:Upload 14.77%
17:51:41:WU02:FS01:Upload 18.17%
17:51:44:WU00:FS01:Downloading 5.22MiB
17:51:47:WU02:FS01:Upload 20.67%
17:51:53:WU02:FS01:Upload 23.40%
17:51:59:WU02:FS01:Upload 29.53%
17:52:05:WU02:FS01:Upload 34.31%
17:52:11:WU02:FS01:Upload 37.49%
17:52:17:WU02:FS01:Upload 42.94%
17:52:23:WU02:FS01:Upload 44.98%
17:52:29:WU02:FS01:Upload 46.80%
17:52:35:WU02:FS01:Upload 48.16%
17:52:41:WU02:FS01:Upload 51.80%
17:52:47:WU02:FS01:Upload 57.48%
17:52:51:WU01:FS00:0xa7:Completed 14375 out of 62500 steps (23%)
17:52:53:WU02:FS01:Upload 61.34%
17:52:59:WU02:FS01:Upload 64.52%
17:53:05:WU02:FS01:Upload 69.06%
17:53:11:WU02:FS01:Upload 75.20%
17:53:17:WU02:FS01:Upload 82.24%
17:53:23:WU02:FS01:Upload 87.92%
17:53:29:WU02:FS01:Upload 91.10%
17:53:35:WU02:FS01:Upload 94.28%
17:53:41:WU02:FS01:Upload 98.37%
17:53:46:WU02:FS01:Upload complete
17:53:46:WU02:FS01:Server responded WORK_ACK (400)
17:53:46:WU02:FS01:Final credit estimate, 429704.00 points
17:53:46:WU02:FS01:Cleaning up
17:54:37:WU01:FS00:0xa7:Completed 15000 out of 62500 steps (24%)
17:55:57:WU00:FS01:Download 0.40%
17:55:57:ERROR:WU00:FS01:Exception: Transfer failed
17:55:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
17:55:58:WU00:FS01:Assigned to work server 128.252.203.11
17:55:58:WU00:FS01:Requesting new work unit for slot 01: gpu:0:11 GA102 [GeForce RTX 3080] from 128.252.203.11
17:55:58:WU00:FS01:Connecting to 128.252.203.11:8080
17:56:09:WU00:FS01:Downloading 26.51MiB
17:56:15:WU00:FS01:Download 3.54%
17:56:20:WU01:FS00:0xa7:Completed 15625 out of 62500 steps (25%)
17:56:21:WU00:FS01:Download 8.96%
17:56:27:WU00:FS01:Download 16.97%
17:56:33:WU00:FS01:Download 24.99%
17:56:39:WU00:FS01:Download 32.53%
17:56:45:WU00:FS01:Download 41.25%
17:56:51:WU00:FS01:Download 47.62%
17:56:57:WU00:FS01:Download 55.40%
17:57:03:WU00:FS01:Download 66.95%
17:57:09:WU00:FS01:Download 88.16%
17:57:12:WU00:FS01:Download complete
17:57:12:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:18202 run:10105 clone:4 gen:15 core:0x22 unit:0x000000040000000f0000471a00002779
17:57:12:WU00:FS01:Starting
This is unfiltered logs, including logs of other WUs.
aetch
Post by aetch »
Actually, that's not unfiltered. If you're copying from the advanced control panel you should hit the Refresh button first.
You're log capture should look roughly the same as this
*********************** Log Started 2021-08-08T22:36:00Z ***********************
22:36:00:******************************* libFAH ********************************
22:36:00:           Date: Oct 20 2020
22:36:00:           Time: 13:36:55
22:36:00:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
22:36:00:         Branch: master
22:36:00:       Compiler: Visual C++ 2015
22:36:00:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:36:00:       Platform: win32 10
22:36:00:           Bits: 32
22:36:00:           Mode: Release
22:36:00:****************************** FAHClient ******************************
22:36:00:        Version: 7.6.21
22:36:00:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:36:00:      Copyright: 2020 foldingathome.org
22:36:00:       Homepage: https://foldingathome.org/
22:36:00:           Time: 13:41:04
22:36:00:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
22:36:00:           Bits: 32
22:36:00:         Config: C:\ProgramData\FAHClient\config.xml
22:36:00:******************************** CBang ********************************
22:36:00:           Time: 11:36:18
22:36:00:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
22:36:00:           Bits: 32
22:36:00:******************************* System ********************************
22:36:00:            CPU: AMD Ryzen 9 3900X 12-Core Processor
22:36:00:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:36:00:           CPUs: 24
22:36:00:         Memory: 15.95GiB
22:36:00:    Free Memory: 12.76GiB
22:36:00:        Threads: WINDOWS_THREADS
22:36:00:     OS Version: 6.2
22:36:00:    Has Battery: false
22:36:00:     On Battery: false
22:36:00:     UTC Offset: 1
22:36:00:            PID: 10772
22:36:00:            CWD: C:\ProgramData\FAHClient
22:36:00:  Win32 Service: false
22:36:00:             OS: Windows 10 Enterprise
22:36:00:        OS Arch: AMD64
22:36:00:           GPUs: 1
22:36:00:          GPU 0: Bus:4 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 SUPER]
22:36:00:                 8218
22:36:00:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:7.5 Driver:11.4
22:36:00:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:3.0 Driver:471.11
22:36:00:***********************************************************************
fz4z
Post by fz4z »
aetch wrote:Actually, that's not unfiltered. If you're copying from the advanced control panel you should hit the Refresh button first.
22:36:00:           Bits: 32
22:36:00:           Bits: 32
22:36:00:           Bits: 32
22:36:00:           CPUs: 24
22:36:00:           GPUs: 1
22:36:00:                 8218
*********************** Log Started 2021-07-25T08:06:39Z ***********************
08:06:39:******************************* libFAH ********************************
08:06:39:           Date: Oct 20 2020
08:06:39:           Time: 13:36:55
08:06:39:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:06:39:         Branch: master
08:06:39:       Compiler: Visual C++ 2015
08:06:39:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:06:39:       Platform: win32 10
08:06:39:           Bits: 32
08:06:39:           Mode: Release
08:06:39:****************************** FAHClient ******************************
08:06:39:        Version: 7.6.21
08:06:39:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:06:39:      Copyright: 2020 foldingathome.org
08:06:39:       Homepage: https://foldingathome.org/
08:06:39:           Time: 13:41:04
08:06:39:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:06:39:           Bits: 32
08:06:39:         Config: D:\ProgramData\FAHClient\config.xml
08:06:39:******************************** CBang ********************************
08:06:39:           Time: 11:36:18
08:06:39:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:06:39:           Bits: 32
08:06:39:******************************* System ********************************
08:06:39:            CPU: Intel(R) Xeon(R) CPU E5-2678 v3 @ 2.50GHz
08:06:39:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
08:06:39:           CPUs: 16
08:06:39:         Memory: 32.00GiB
08:06:39:    Free Memory: 29.79GiB
08:06:39:        Threads: WINDOWS_THREADS
08:06:39:     OS Version: 6.2
08:06:39:    Has Battery: false
08:06:39:     On Battery: false
08:06:39:     UTC Offset: 8
08:06:39:            PID: 3392
08:06:39:            CWD: D:\ProgramData\FAHClient
08:06:39:  Win32 Service: false
08:06:39:             OS: Windows 10 Enterprise LTSC 2019
08:06:39:        OS Arch: AMD64
08:06:39:           GPUs: 1
08:06:39:          GPU 0: Bus:0 Slot:11 Func:0 NVIDIA:8 GA102 [GeForce RTX 3080]
08:06:39:  CUDA Device 0: Platform:0 Device:0 Bus:0 Slot:11 Compute:8.6 Driver:11.2
08:06:39:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:1 Compute:1.2 Driver:462.59
08:06:39:***********************************************************************
This is the log.
aetch
Post by aetch »
I'm not sure what kind of help I'll be so I may ask some really weird/obtuse questions.
My first port of call was going to be folder permissions but it's clearly not that as you've had a lot of traffic come and go.
It's unusual for the working directory to be on a different drive from the OS. What kind of drive is your D: drive? Local storage, virtual drive, network drive.
Every internet security application has an exceptions/exclusions list. A list of folders/files/programs/protocols which you can tell the application to ignore to try and avoid false positives.
Did you add "D:\ProgramData\FAHClient" to this list?
FAH recommend that you do it (I've done it). See their notes at the bottom of the following pages.
Windows
MacOS
fz4z
Post by fz4z »
aetch wrote:I'm not sure what kind of help I'll be so I may ask some really weird/obtuse questions.
Windows
MacOS
After replacing ISP with a new one. I haven't see "Transfer failed" again. I will continue to monitor logs.
