redryder508
Posts: 3 Joined: Sat Jul 24, 2021 5:05 pm
Post
by redryder508 » Sat Jul 24, 2021 5:55 pm
Fully patched WIN10
Machine re-booted and FAH client did not start automatically ...
started FAHClient.exe manually and the cmd box shows what looks like an error
16:59:18:Trying to access database...
16:59:18:Successfully acquired database lock
16:59:18:FS00:Initialized folding slot 00: cpu:5
16:59:18:FS01:Initialized folding slot 01: gpu:1:0 TU117M [GeForce GTX 1650 Ti Mobile]
16:59:18:WARNING:FS02:Guessing ambiguous GPU to OpenCL device mapping for 02: gpu:0:2 CML GT2 [UHD Graphics]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
16:59:18:WARNING:FS02:Disabling beta GPU slot 02: gpu:0:2 CML GT2 [UHD Graphics]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
16:59:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
16:59:18:WU00:FS00:Connecting to cores.foldingathome.org:80
16:59:18:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
16:59:18:WU01:FS01:Connecting to cores.foldingathome.org:80
16:59:19:WU00:FS00:FahCore a7: Downloading 6.71MiB
16:59:19:WU01:FS01:FahCore 22: Downloading 77.67MiB
16:59:20:WU00:FS00:FahCore a7: Download complete
16:59:20:WU00:FS00:Valid core signature
16:59:20:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
16:59:20:ERROR:WU00:FS00:: iostream stream error: Access is denied.
16:59:25:WU01:FS01:FahCore 22: 95.20%
16:59:25:WU01:FS01:FahCore 22: Download complete
16:59:25:WU01:FS01:Valid core signature
16:59:25:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
16:59:25:ERROR:WU01:FS01:: iostream stream error: Access is denied.
Downloaded again, re-installed, re-booted ... no change
Started manually again received same error output.
What can I check/change on my end?
Regards,
aetch
Posts: 436 Joined: Thu Jun 25, 2020 3:04 pm
Post
by aetch » Sat Jul 24, 2021 6:49 pm
Can you post the first couple hundred lines of your log.
redryder508
Post
by redryder508 » Sat Jul 24, 2021 7:58 pm
From the beginning
16:59:18:Read GPUs.txt
16:59:18:******************************* libFAH ********************************
16:59:18: Date: Oct 20 2020
16:59:18: Time: 13:36:55
16:59:18: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
16:59:18: Branch: master
16:59:18: Compiler: Visual C++ 2015
16:59:18: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:59:18: Platform: win32 10
16:59:18: Bits: 32
16:59:18: Mode: Release
16:59:18:****************************** FAHClient ******************************
16:59:18: Version: 7.6.21
16:59:18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:59:18: Copyright: 2020 foldingathome.org
16:59:18: Homepage: https://foldingathome.org/
16:59:18: Time: 13:41:04
16:59:18: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
16:59:18: Bits: 32
16:59:18: Config: C:\Program Files (x86)\FAHClient\config.xml
16:59:18:******************************** CBang ********************************
16:59:18: Time: 11:36:18
16:59:18: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
16:59:18: Bits: 32
16:59:18:******************************* System ********************************
16:59:18: CPU: Intel(R) Core(TM) i5-10300H CPU @ 2.50GHz
16:59:18: CPU ID: GenuineIntel Family 6 Model 165 Stepping 2
16:59:18: CPUs: 8
16:59:18: Memory: 11.78GiB
16:59:18: Free Memory: 5.81GiB
16:59:18: Threads: WINDOWS_THREADS
16:59:18: OS Version: 6.2
16:59:18: Has Battery: true
16:59:18: On Battery: false
16:59:18: UTC Offset: -5
16:59:18: PID: 13564
16:59:18: CWD: C:\Program Files (x86)\FAHClient
16:59:18: Win32 Service: false
16:59:18: OS: Windows 10 Home
16:59:18: OS Arch: AMD64
16:59:18: GPUs: 2
16:59:18: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117M [GeForce GTX 1650 Ti
16:59:18: Mobile]
16:59:18: GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 CML GT2 [UHD Graphics]
16:59:18: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.2
16:59:18:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:462.80
16:59:18:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
16:59:18:***********************************************************************
16:59:18:<config>
16:59:18: <!-- Slot Control -->
16:59:18: <power v='MEDIUM'/>
16:59:18:
16:59:18: <!-- User Information -->
16:59:18: <passkey v='*****'/>
16:59:18: <team v='14'/>
16:59:18: <user v='redryder508'/>
16:59:18:
16:59:18: <!-- Folding Slots -->
16:59:18: <slot id='0' type='CPU'/>
16:59:18: <slot id='1' type='GPU'>
16:59:18: <pci-bus v='1'/>
16:59:18: <pci-slot v='0'/>
16:59:18: </slot>
16:59:18: <slot id='2' type='GPU'>
16:59:18: <pci-bus v='0'/>
16:59:18: <pci-slot v='2'/>
16:59:18: </slot>
16:59:18:</config>
17:00:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:00:18:WU00:FS00:Connecting to cores.foldingathome.org:80
17:00:18:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:00:19:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:00:19:WU01:FS01:Connecting to cores.foldingathome.org:80
17:00:19:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:00:19:WU00:FS00:FahCore a7: Download complete
17:00:20:WU00:FS00:Valid core signature
17:00:20:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:00:20:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:00:24:WU01:FS01:FahCore 22: Download complete
17:00:25:WU01:FS01:Valid core signature
17:00:25:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:00:25:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:01:56:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:01:56:WU00:FS00:Connecting to cores.foldingathome.org:80
17:01:56:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:01:56:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:01:56:WU01:FS01:Connecting to cores.foldingathome.org:80
17:01:56:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:01:57:WU00:FS00:FahCore a7: Download complete
17:01:57:WU00:FS00:Valid core signature
17:01:57:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:01:57:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:02:02:WU01:FS01:FahCore 22: 77.74%
17:02:03:WU01:FS01:FahCore 22: Download complete
17:02:03:WU01:FS01:Valid core signature
17:02:03:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:02:03:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:02:11:6:127.0.0.1:New Web session
17:04:33:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:04:33:WU00:FS00:Connecting to cores.foldingathome.org:80
17:04:33:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:04:33:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:04:33:WU01:FS01:Connecting to cores.foldingathome.org:80
17:04:33:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:04:34:WU00:FS00:FahCore a7: Download complete
17:04:34:WU00:FS00:Valid core signature
17:04:34:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:04:34:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:04:39:WU01:FS01:FahCore 22: 50.05%
17:04:43:WU01:FS01:FahCore 22: Download complete
17:04:43:WU01:FS01:Valid core signature
17:04:43:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:04:43:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:08:47:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:08:47:WU00:FS00:Connecting to cores.foldingathome.org:80
17:08:47:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:08:47:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:08:47:WU01:FS01:Connecting to cores.foldingathome.org:80
17:08:47:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:08:48:WU00:FS00:FahCore a7: Download complete
17:08:48:WU00:FS00:Valid core signature
17:08:48:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:08:48:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:08:53:WU01:FS01:FahCore 22: 80.55%
17:08:54:WU01:FS01:FahCore 22: Download complete
17:08:54:WU01:FS01:Valid core signature
17:08:54:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:08:54:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:15:38:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:15:38:WU00:FS00:Connecting to cores.foldingathome.org:80
17:15:38:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:15:38:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:15:38:WU01:FS01:Connecting to cores.foldingathome.org:80
17:15:39:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:15:39:WU00:FS00:FahCore a7: Download complete
17:15:39:WU00:FS00:Valid core signature
17:15:39:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:15:39:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:15:45:WU01:FS01:FahCore 22: 80.15%
17:15:46:WU01:FS01:FahCore 22: Download complete
17:15:46:WU01:FS01:Valid core signature
17:15:46:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:15:46:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:26:44:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:26:44:WU00:FS00:Connecting to cores.foldingathome.org:80
17:26:44:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:26:44:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:26:44:WU01:FS01:Connecting to cores.foldingathome.org:80
17:26:44:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:26:45:WU00:FS00:FahCore a7: Download complete
17:26:45:WU00:FS00:Valid core signature
17:26:45:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:26:45:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:26:50:WU01:FS01:FahCore 22: 36.53%
17:26:56:WU01:FS01:FahCore 22: 91.82%
17:26:56:WU01:FS01:FahCore 22: Download complete
17:26:56:WU01:FS01:Valid core signature
17:26:56:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:26:56:ERROR:WU01:FS01:: iostream stream error: Access is denied.
17:44:41:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
17:44:41:WU00:FS00:Connecting to cores.foldingathome.org:80
17:44:41:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:44:41:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
17:44:41:WU01:FS01:Connecting to cores.foldingathome.org:80
17:44:41:WU01:FS01:FahCore 22: Downloading 77.67MiB
17:44:42:WU00:FS00:FahCore a7: Download complete
17:44:42:WU00:FS00:Valid core signature
17:44:42:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
17:44:42:ERROR:WU00:FS00:: iostream stream error: Access is denied.
17:44:47:WU01:FS01:FahCore 22: 46.92%
17:44:53:WU01:FS01:FahCore 22: 89.16%
17:44:54:WU01:FS01:FahCore 22: Download complete
17:44:54:WU01:FS01:Valid core signature
17:44:54:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
17:44:54:ERROR:WU01:FS01:: iostream stream error: Access is denied.
18:12:49:17:127.0.0.1:New Web session
18:13:03:FS00:Paused
18:13:03:FS01:Paused
18:13:03:FS02:Paused
18:13:06:FS00:Unpaused
18:13:06:FS01:Unpaused
18:13:06:FS02:Unpaused
18:13:43:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
18:13:43:WU00:FS00:Connecting to cores.foldingathome.org:80
18:13:43:WU00:FS00:FahCore a7: Downloading 6.71MiB
18:13:43:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
18:13:43:WU01:FS01:Connecting to cores.foldingathome.org:80
18:13:43:WU01:FS01:FahCore 22: Downloading 77.67MiB
18:13:45:WU00:FS00:FahCore a7: Download complete
18:13:45:WU00:FS00:Valid core signature
18:13:45:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
18:13:45:ERROR:WU00:FS00:: iostream stream error: Access is denied.
18:13:49:WU01:FS01:FahCore 22: 49.65%
18:13:55:WU01:FS01:FahCore 22: 97.85%
18:13:55:WU01:FS01:FahCore 22: Download complete
18:13:55:WU01:FS01:Valid core signature
18:13:55:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
18:13:55:ERROR:WU01:FS01:: iostream stream error: Access is denied.
19:00:42:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
19:00:42:WU00:FS00:Connecting to cores.foldingathome.org:80
19:00:42:WU00:FS00:FahCore a7: Downloading 6.71MiB
19:00:42:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
19:00:42:WU01:FS01:Connecting to cores.foldingathome.org:80
19:00:42:WU01:FS01:FahCore 22: Downloading 77.67MiB
19:00:43:WU00:FS00:FahCore a7: Download complete
19:00:43:WU00:FS00:Valid core signature
19:00:43:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe': Access is denied.
19:00:43:ERROR:WU00:FS00:: iostream stream error: Access is denied.
19:00:48:WU01:FS01:FahCore 22: 65.02%
19:00:50:WU01:FS01:FahCore 22: Download complete
19:00:50:WU01:FS01:Valid core signature
19:00:50:ERROR:WU01:FS01:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe': Access is denied.
19:00:50:ERROR:WU01:FS01:: iostream stream error: Access is denied.
Regards,
aetch
Post
by aetch » Sun Jul 25, 2021 5:47 am
It's a Windows install.
It sees the working directory (CWD) as being the installation directory, this is wrong. The default working directory for 7.6.21 is "C:\ProgramData\FAHClient"
I can think of a couple of reasons how this could happen:-
1). You changed the location of the data directory during install.
2). You didn't use the Folding@Home shortcut to start the client.
I'm going to suggest uninstalling the FAHClient completely, re-installing it and when asked about folder locations leave them as they are.
redryder508
Post
by redryder508 » Sun Jul 25, 2021 3:13 pm
Re 1. - Took all defaults during install
Re 2. - Most likely the cause. I had deleted the desktop icon about two weeks ago to clean up desktop, and was using the tray icon to start the web viewer. That was working until the machine rebooted. If that doesn't have the full path that the shortcut had then it's not getting all the right options.
The desktop icon is more complex then most - "C:\Program Files (x86)\FAHClient\HideConsole.exe" "C:\Program Files (x86)\FAHClient\FAHClient.exe" --open-web-control
A complete de-install and then re-install (again taking all the defaults) has the client up and running again. Another thread mentioned that the tray icon was still a work in progress, so I do not have enabled at this time. Will have to use the start menu, or make a "tile" if I want to un-clutter the desktop.
Regards,
debs3759
Posts: 134 Joined: Fri Oct 07, 2011 3:29 am
Post
by debs3759 » Sun Jul 25, 2021 4:16 pm
I only ever use the tray icon and fahcontrol (Advanced Control) so am surprised to read that is a work in progress. That's the only way I used it for over a decade, on multiple Windows 7 and 10 PCs
Posts: 8371 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Sun Jul 25, 2021 6:06 pm
debs3759 wrote: I only ever use the tray icon and fahcontrol (Advanced Control) so am surprised to read that is a work in progress. That's the only way I used it for over a decade, on multiple Windows 7 and 10 PCs
"Work in progress" = works much of the time, but variations in Windows setup, and anti-malware present can make it a pain to figure out when it doesn't.
aetch
Post
by aetch » Mon Jul 26, 2021 9:40 am
Glad it's working.
As a note, one of the parameters of the shortcut link is the "start in" which should be "C:\ProgramData\FAHClient", this is what sets the working folder for the FAHClient program.
Something I did was when I had the FAH Advanced Control open was I right clicked its taskbar icon and "Pin to Taskbar".
Korwin
Posts: 11 Joined: Mon Aug 26, 2013 8:20 pm
Post
by Korwin » Fri Jun 16, 2023 12:47 pm
redryder508 wrote: ↑ Sun Jul 25, 2021 3:13 pm I had deleted the desktop icon about two weeks ago to clean up desktop
I also remove installed application shortcuts from the desktop because I don't use the desktop as a place for installed application shortcuts. I have the F@H client installed in the D:\FAH folder. The properties of the shortcut are as
follows . In
the work log , there are often errors of the form:
20:45:32:ERROR:WU00:FS00:Exception: Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe': Failed to open 'cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe': Отказано в доступе.
20:45:32:ERROR:WU00:FS00:: iostream stream error: Отказано в доступе.
It seems to me that if the application did not have the ability to work out of the box in an arbitrary folder specified during installation, this application would not have the opportunity to specify a non-standard folder for installation.
FAHClient 7.6.21
Microsoft Windows 10.0.19045.3086
