GPU disabled - doesn't meet requirement or needs drivers?
I just started folding on an older rig and noticed the GPU is disabled.
Here's what I got from the log;
GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK106 [GeForce GTX 650 Ti]
CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
specified module could not be found.
OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
WARNING:FS01:No CUDA or OpenCL 1.2+ support detected for GPU slot 01: gpu:1:0 GK106 [GeForce GTX 650 Ti]. Disabling.
What does this mean?
Edit: I searched for drivers, couldn't find any- and came across a cuda tool kit- but it doesnt support windows 7
Re: GPU disabled - doesn't meet requirement or needs drivers
On the nVidia site when searching for drivers you will need to go into the advanced search by clicking "here" for beta drivers. The most recent driver with support for your GPU was just released this week, there are more versions available going back over a year.Richw wrote:Edit: I searched for drivers, couldn't find any- and came across a cuda tool kit- but it doesnt support windows 7
One note, I am assuming you have a 64-bit version of Win7 installed, 32-bit windows is no longer supported for GPU folding.
thank you- I didnt notice the beta drivers
Last 32 bit driver for 650 ti https://www.nvidia.com/en-us/drivers/results/132837/
I'm 64bit- poster before you just mentioned there is no folding at 32bit.JimboPalmer wrote:Last 32 bit driver for 650 ti https://www.nvidia.com/en-us/drivers/results/132837/
Joe, I installed the drivers and just seen in F@H Control that both CPU & GPU are now folding. Thanks again!
You could do an in-place upgrade to Windows 10, get the digital licence and then do a clean install of whatever build/version you want as long as it's the same edition (Home/Pro).
The servers which allow Windows 7/8/8.1 to upgrade to Windows 10 for free are still active, it's just not publicised.
https://www.microsoft.com/en-us/softwar ... /windows10
aetch wrote:You could do an in-place upgrade to Windows 10, get the digital licence and then do a clean install of whatever build/version you want as long as it's the same edition (Home/Pro).
you're saying I can upgrade to windows 10 pro from 7 pro for free? what do you mean by in-place upgrade?
I did it about a month ago (just a few weeks before Windows 11 beta was "leaked") with a 32-bit Vista Home Premium install on a Toshiba Satellite laptop. I first took it to Windows 7 by re-using a retail Windows 7 Home Premium upgrade I bought years ago, then did the in-place upgrade to Windows 10. That laptop now runs Windows 10 Home 64-bit.
As with any upgrade, backup before attempting it. The worst that can happen is that you revert back to Windows 7.
There's plenty of guides for doing the in-place upgrades.
https://www.groovypost.com/howto/downlo ... s-10-free/
https://www.techsupportall.com/upgrade- ... -for-free/
still not sure what you mean by in-place. so I can upgrade to 10 and not have to start at factory settings? all my files and programs will still be available after upgrade?
i've figured it out, you mean i can use my windows 7 key for the 10 upgrade. gonna just do it now and get it over with.
thanks bud
thanks bud
By in-place I mean you download the Windows 10 install files using the media creation tool and then run setup from within your current Windows installation.
Please read up on it. Your files will still be in the same place but the GUI keeps evolving with every new build so accessing different configuration settings changes over time.
JohnChodera
- Pande Group Member
Thanks to everybody who chimed in to help here!
OpenCL.DLL should be distributed with your display drivers, and isn't something we can distribute with the core because it's hardware-specific.
This thread on the NVIDIA support forums is a similar issue, and has good info on which display driver versions might be useful in providing it:
https://forums.developer.nvidia.com/t/o ... sing/18431
Apologies if you've already been through this info!
~ John Chodera // MSKCC
