Will Not Uninstall
HELPMATTY
Will Not Uninstall
Post by HELPMATTY »
The latest FAH will not uninstall from my M1 MacBook. I dragged the entire folder from the Applications into the Trash, but it keeps running in the background. How can I please uninstall it completely? Thank you.
Re: Will Not Uninstall
You need to use the Uninstaller provided with the installed software. Dragging to the Trash is not the way to do it. The Uninstaller is located in the Folding@home folder, or can be installed separately from the Installer package.
