Uncredited p3903
Uncredited p3903
While 171.64.122.83 was in Reject mode earlier today (and yesterday evening), p3903-r4676-c4-g4 folding on my work laptop was completed at 22:18 UTC and then results uploaded succesfully (to a server in reject mode !!!).
The server is accepting again, my WU remains uncredited.
Thanks for the help
Thanks for the help
Re: Uncredited p3903
About the reject mode situation : the serverstatus page refreshes every 10 minutes ... so a server can be back before the page update that still shows it as rejecting
You'll have to wait for a mod to know if to WU has been credited or not
At the moment, that WU isn't in the database.
That is certaihly one possiblity. There's another, though. It may be that the server was continuously rejecting connections but the client, after finding that I could not upload to the primary work server, uploaded to the collection server. Mactin did not post FAHlog.txt showing the upload, but without examining it carefully, the only thing we know is that the WU uploaded and the credit is missing.toTOW wrote:About the reject mode situation : the serverstatus page refreshes every 10 minutes ... so a server can be back before the page update that still shows it as rejecting
Yes you're right, the collection server is now back online, it could have received the WU too
As I said the WU was sent to the 171.64.122.83 server while it was in reject mode... Here is the log :
[16:03:29] + Processing work unit
[16:03:29] Core required: FahCore_79.exe
[16:03:29] Core found.
[16:03:29] - Autosending finished units...
[16:03:29] Trying to send all finished work units
[16:03:29] + No unsent completed units remaining.
[16:03:29] - Autosend completed
[16:03:29] Working on Unit 05 [December 16 16:03:29]
[16:03:29] + Working ...
[16:03:29] - Calling 'FahCore_79.exe -dir work/ -suffix 05 -checkpoint 20 -forceasm -verbose -lifeline 2484 -version 504'
[16:03:29]
[16:03:29] *------------------------------*
[16:03:29] Folding@Home Double Gromacs Core
[16:03:29] Version 1.91 (April 11, 2006)
[16:03:29]
[16:03:29] Preparing to commence simulation
[16:03:29] - Assembly optimizations manually forced on.
[16:03:29] - Not checking prior termination.
[16:03:59] - Expanded 9504363 -> 34521892 (decompressed 363.2 percent)
[16:04:02]
[16:04:02] Project: 3903 (Run 4676, Clone 4, Gen 4)
[16:04:02]
[16:04:03] Assembly optimizations on if available.
[16:04:03] Entering M.D.
[16:04:26] (Starting from checkpoint)
[16:04:26] Protein: IBX in water
[16:04:26]
[16:04:27] Writing local files
[16:04:53] Extra SSE2 boost OK.
[16:04:57] Writing local files
[16:04:57] Completed 0 out of 25000 steps (0)
[16:25:07] Timered checkpoint triggered.
[16:41:40] Writing local files
[16:41:43] Completed 500 out of 25000 steps (2)
... 29 hours later ...
[21:41:11] Completed 24500 out of 25000 steps (98)
[22:01:14] Timered checkpoint triggered.
[22:03:31] - Autosending finished units...
[22:03:31] Trying to send all finished work units
[22:03:31] + No unsent completed units remaining.
[22:03:31] - Autosend completed
[22:17:09] Writing local files
[22:17:10] Completed 25000 out of 25000 steps (100)
[22:17:10] Writing final coordinates.
[22:17:13] Past main M.D. loop
[22:18:13]
[22:18:13] Finished Work Unit:
[22:18:13] - Reading up to 7064324 from "work/wudata_05.arc": Read 7064324
[22:18:13] - Reading up to 942116 from "work/wudata_05.xtc": Read 942116
[22:18:13] goefile size: 0
[22:18:13] logfile size: 28320
[22:18:13] Leaving Run
[22:18:17] - Writing 8103202 bytes of core data to disk...
[22:18:22] Done: 8102690 -> 7751878 (compressed to 95.6 percent)
[22:18:22] ... Done.
[22:18:22] - Shutting down core
[22:18:22]
[22:18:22] Folding@home Core Shutdown: FINISHED_UNIT
[22:18:25] CoreStatus = 64 (100)
[22:18:25] Unit 5 finished with 95 percent of time to deadline remaining.
[22:18:25] Updated performance fraction: 0.955223
[22:18:25] Sending work to server
[22:18:25] + Attempting to send results
[22:18:25] - Reading file work/wuresults_05.dat from core
[22:18:26] (Read 7752390 bytes from disk)
[22:18:26] Connecting to http://171.64.122.83:8080/
[22:19:46] Posted data.
[22:19:46] Initial: 0000; - Uploaded at ~90 kB/s
[22:19:50] - Averaged speed for that direction ~112 kB/s
[22:19:50] + Results successfully sent
[22:19:50] Thank you for your contribution to Folding@Home.
[22:19:50] + Number of Units Completed: 17
It's more likely that the serverstatus page was not updated
3903 was also uncredited for me. I rather suspect the database problem rather than uploading issues. My completion log record was
That was well over 12 hours ago, but my status page still shows only 32 units, and I've seen the updating statistics page cycle several times since then.
The other odd thing about this unit was that the Client never displayed the project number at all, only the "IBX in water" title. I only found the project number from looking at the log:
Rather disappointing not to be credited--it's a sizable WU
bobD
[05:58:13] Folding@home Core Shutdown: FINISHED_UNIT
[05:58:17] CoreStatus = 64 (100)
[05:58:17] Sending work to server
[05:58:17] + Attempting to send results
[05:59:33] + Results successfully sent
[05:59:33] Thank you for your contribution to Folding@Home.
[05:59:33] + Number of Units Completed: 33
[09:11:52] Folding@Home Double Gromacs Core
[09:11:52] Version 1.91 (April 11, 2006)
[09:11:52]
[09:11:52] Preparing to commence simulation
[09:11:52] - Looking at optimizations...
[09:11:52] - Files status OK
[09:14:09] - Expanded 9505455 -> 34521892 (decompressed 363.1 percent)
[09:14:13]
[09:14:13] Project: 3903 (Run 4290, Clone 4, Gen 4)
bobD
Welcome to the forums Bob!
It's probably related to what kasson posted here: viewtopic.php?p=2705#p2705
I have had the same problem with a p3903 WU that was finished on December 18. The relevant section of my FAHlog.txt is as follows:
I would be grateful if someone could check on this WU for me. Thanks in advance.
[18:50:19] Working on Unit 08 [December 18 18:50:19]
[18:50:19] + Working ...
[18:50:19]
[18:50:19] *------------------------------*
[18:50:19] Folding@Home Double Gromacs Core
[18:50:19] Version 1.91 (April 11, 2006)
[18:50:19]
[18:50:19] Preparing to commence simulation
[18:50:19] - Looking at optimizations...
[18:50:19] - Files status OK
[18:50:32] - Expanded 4931288 -> 34524104 (decompressed 700.1 percent)
[18:50:32]
[18:50:32] Project: 3903 (Run 1191, Clone 4, Gen 0)
[18:50:32]
[18:50:33] Assembly optimizations on if available.
[18:50:33] Entering M.D.
[18:50:55] (Starting from checkpoint)
[18:50:56] Protein: IBX in water
[18:50:56]
[18:50:56] Writing local files
[18:50:56] Completed 20750 out of 25000 steps (83)
[18:51:09] Extra SSE2 boost OK.
[19:06:27] Writing local files
[19:06:28] Completed 21000 out of 25000 steps (84)
[19:36:02] Writing local files
[19:36:03] Completed 21500 out of 25000 steps (86)
[20:05:19] Writing local files
[20:05:20] Completed 22000 out of 25000 steps (88)
[20:35:15] Writing local files
[20:35:16] Completed 22500 out of 25000 steps (90)
[21:05:39] Writing local files
[21:05:39] Completed 23000 out of 25000 steps (92)
[21:36:36] Writing local files
[21:36:37] Completed 23500 out of 25000 steps (94)
[22:06:36] Writing local files
[22:06:37] Completed 24000 out of 25000 steps (96)
[22:35:45] Writing local files
[22:35:46] Completed 24500 out of 25000 steps (98)
[23:04:49] Writing local files
[23:04:49] Completed 25000 out of 25000 steps (100)
[23:04:49] Writing final coordinates.
[23:04:51] Past main M.D. loop
[23:05:51]
[23:05:51] Finished Work Unit:
[23:05:51] - Reading up to 7064324 from "work/wudata_08.arc": Read 7064324
[23:05:52] - Reading up to 997776 from "work/wudata_08.xtc": Read 997776
[23:05:52] goefile size: 0
[23:05:52] logfile size: 44458
[23:05:52] Leaving Run
[23:05:55] - Writing 8206172 bytes of core data to disk...
[23:05:59] Done: 8205660 -> 7819868 (compressed to 95.2 percent)
[23:05:59] ... Done.
[23:05:59] - Shutting down core
[23:05:59]
[23:05:59] Folding@home Core Shutdown: FINISHED_UNIT
[23:06:02] CoreStatus = 64 (100)
[23:06:02] Sending work to server
[23:06:02] + Attempting to send results
[23:07:57] + Results successfully sent
[23:07:57] Thank you for your contribution to Folding@Home.
[23:07:57] + Number of Units Completed: 45
See my response above.
My pleasureuncle_fungus wrote:Welcome to the forums Bob!
Bummer. Do you know if there's an ETF (Estimated Time to Fix) ? I'm more than halfway to another upload (88/125 frames)uncle_fungus wrote:It's probably related to what kasson posted here: viewtopic.php?p=2705#p2705
bobD
He posted more info here --> viewtopic.php?f=18&t=331&p=3251#p3251bobdawson wrote: Do you know if there's an ETF (Estimated Time to Fix) ?
