No WUs available for this configuration
vitsensei
Post by vitsensei »
For the last 48h, I have came across this issue a few times. But for the last ~12h, I have not received any new WUs for my GPU :(.
Have anyone came across the same problem?
*********************** Log Started 2021-06-25T10:26:06Z ***********************
10:26:06:******************************* libFAH ********************************
10:26:06:           Date: Oct 20 2020
10:26:06:           Time: 20:36:39
10:26:06:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
10:26:06:         Branch: master
10:26:06:       Compiler: GNU 8.3.0
10:26:06:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
10:26:06:                 -fdata-sections -O3 -funroll-loops -fno-pie
10:26:06:       Platform: linux2 5.8.0-1-amd64
10:26:06:           Bits: 64
10:26:06:           Mode: Release
10:26:06:****************************** FAHClient ******************************
10:26:06:        Version: 7.6.21
10:26:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:26:06:      Copyright: 2020 foldingathome.org
10:26:06:       Homepage: https://foldingathome.org/
10:26:06:           Time: 20:39:00
10:26:06:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
10:26:06:           Bits: 64
10:26:06:           Args: --child /etc/fahclient/config.xml --run-as fahclient
10:26:06:                 --pid-file=/var/run/fahclient.pid --daemon
10:26:06:         Config: /etc/fahclient/config.xml
10:26:06:******************************** CBang ********************************
10:26:06:           Time: 18:37:59
10:26:06:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
10:26:06:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
10:26:06:           Bits: 64
10:26:06:******************************* System ********************************
10:26:06:            CPU: AMD Ryzen 9 4900HS with Radeon Graphics
10:26:06:         CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
10:26:06:           CPUs: 16
10:26:06:         Memory: 15.13GiB
10:26:06:    Free Memory: 13.53GiB
10:26:06:        Threads: POSIX_THREADS
10:26:06:     OS Version: 5.8
10:26:06:    Has Battery: true
10:26:06:     On Battery: false
10:26:06:     UTC Offset: 10
10:26:06:            PID: 1809
10:26:06:            CWD: /var/lib/fahclient
10:26:06:             OS: Linux 5.8.0-59-generic x86_64
10:26:06:        OS Arch: AMD64
10:26:06:           GPUs: 2
10:26:06:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile /
10:26:06:                 Max-Q] 4550
10:26:06:          GPU 1: Bus:5 Slot:0 Func:0 AMD:5 Renoir [Ryzen 4900HS mobile]
10:26:06:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.2
10:26:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.84
10:26:06:***********************************************************************
10:26:06:<config>
10:26:06:  <!-- Slot Control -->
10:26:06:  <power v='FULL'/>
10:26:06:
10:26:06:  <!-- User Information -->
10:26:06:  <passkey v='*****'/>
10:26:06:  <user v='anhtran0248'/>
10:26:06:
10:26:06:  <!-- Folding Slots -->
10:26:06:  <slot id='0' type='CPU'/>
10:26:06:  <slot id='1' type='GPU'>
10:26:06:    <pci-bus v='1'/>
10:26:06:    <pci-slot v='0'/>
10:26:06:  </slot>
10:26:06:  <slot id='2' type='GPU'>
10:26:06:    <pci-bus v='5'/>
10:26:06:  </slot>
10:26:06:</config>
10:26:06:Trying to access database...
10:26:06:Successfully acquired database lock
10:26:06:FS00:Initialized folding slot 00: cpu:14
10:26:06:FS01:Initialized folding slot 01: gpu:1:0 TU106M [GeForce RTX 2060 Mobile / Max-Q] 4550
[93m10:26:06:WARNING:FS02:No CUDA or OpenCL 1.2+ support detected for GPU slot 02: gpu:5:0 Renoir [Ryzen 4900HS mobile].  Disabling.[0m
10:26:06:WU01:FS00:Starting
10:26:06:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/lin/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8 -dir 01 -suffix 01 -version 706 -lifeline 1809 -checkpoint 15 -np 14
10:26:06:WU01:FS00:Started FahCore on PID 1819
10:26:06:WU01:FS00:Core PID:1823
10:26:06:WU01:FS00:FahCore 0xa8 started
10:26:06:WU00:FS01:Connecting to assign1.foldingathome.org:80
10:26:07:WU01:FS00:0xa8:*********************** Log Started 2021-06-25T10:26:06Z ***********************
10:26:07:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
10:26:07:WU01:FS00:0xa8:       Core: Gromacs
10:26:07:WU01:FS00:0xa8:       Type: 0xa8
10:26:07:WU01:FS00:0xa8:    Version: 0.0.12
10:26:07:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:26:07:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
10:26:07:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
10:26:07:WU01:FS00:0xa8:       Date: Jan 16 2021
10:26:07:WU01:FS00:0xa8:       Time: 19:24:44
10:26:07:WU01:FS00:0xa8:   Compiler: GNU 8.3.0
10:26:07:WU01:FS00:0xa8:    Options: -faligned-new -std=c++14 -fsigned-char -ffunction-sections
10:26:07:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie
10:26:07:WU01:FS00:0xa8:   Platform: linux2 4.15.0-128-generic
10:26:07:WU01:FS00:0xa8:       Bits: 64
10:26:07:WU01:FS00:0xa8:       Mode: Release
10:26:07:WU01:FS00:0xa8:       SIMD: avx2_256
10:26:07:WU01:FS00:0xa8:     OpenMP: ON
10:26:07:WU01:FS00:0xa8:       CUDA: OFF
10:26:07:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1819 -checkpoint 15 -np
10:26:07:WU01:FS00:0xa8:             14
10:26:07:WU01:FS00:0xa8:************************************ libFAH ************************************
10:26:07:WU01:FS00:0xa8:       Time: 19:21:38
10:26:07:WU01:FS00:0xa8:************************************ CBang *************************************
10:26:07:WU01:FS00:0xa8:       Time: 19:21:24
10:26:07:WU01:FS00:0xa8:             -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
10:26:07:WU01:FS00:0xa8:************************************ System ************************************
10:26:07:WU01:FS00:0xa8:        CPU: AMD Ryzen 9 4900HS with Radeon Graphics
10:26:07:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 23 Model 96 Stepping 1
10:26:07:WU01:FS00:0xa8:       CPUs: 16
10:26:07:WU01:FS00:0xa8:     Memory: 15.13GiB
10:26:07:WU01:FS00:0xa8:Free Memory: 13.51GiB
10:26:07:WU01:FS00:0xa8:    Threads: POSIX_THREADS
10:26:07:WU01:FS00:0xa8: OS Version: 5.8
10:26:07:WU01:FS00:0xa8:Has Battery: true
10:26:07:WU01:FS00:0xa8: On Battery: false
10:26:07:WU01:FS00:0xa8: UTC Offset: 10
10:26:07:WU01:FS00:0xa8:        PID: 1823
10:26:07:WU01:FS00:0xa8:        CWD: /var/lib/fahclient/work
10:26:07:WU01:FS00:0xa8:********************************************************************************
10:26:07:WU01:FS00:0xa8:Project: 16959 (Run 35, Clone 485, Gen 75)
10:26:07:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
10:26:07:WU01:FS00:0xa8:Digital signatures verified
10:26:07:WU01:FS00:0xa8:Calling: mdrun -c frame75.gro -s frame75.tpr -x frame75.xtc -cpi state.cpt -cpt 15 -nt 14 -ntmpi 1
10:26:07:WU01:FS00:0xa8:Steps: first=187500000 total=190000000
10:26:07:WU01:FS00:0xa8:Completed 1535202 out of 2500000 steps (61%)
[93m10:26:08:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
10:26:08:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m10:26:09:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
10:26:09:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m10:26:10:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
10:26:10:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m10:26:11:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m10:26:11:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
10:26:11:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m10:26:12:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
10:26:12:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m10:26:13:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
10:26:13:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m10:26:14:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
10:26:14:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m10:26:15:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m10:26:15:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
10:26:46:1:127.0.0.1:New Web session
10:27:11:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m10:27:12:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
10:27:12:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m10:27:13:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
10:27:13:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m10:27:14:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
10:27:14:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m10:27:15:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m10:27:15:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
10:27:43:WU01:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
10:28:48:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m10:28:49:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
10:28:49:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m10:28:50:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
10:28:50:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m10:28:51:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
10:28:51:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m10:28:52:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m10:28:52:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
Reason: change Quote tags to Code for log
Re: No WUs available for this configuration
Yes, sadly the servers have no Work Units for us to do. Since F@H never does 'make work', we just wait for more real work.
