No GPU WU, shortage or other cause?
Monersus
Post by Monersus »
Hello at all
I've been running the client again for the last few months. for a long time with a GTX 970 and that has always worked flawlessly. Now I temporarily switched to a 3070 about 2 weeks ago, because I wanted to play a game again. Yesterday I switched back to the 970. Since then, I no longer get a WU for the GPU. And I get error messages in the log for the first time. Can anyone tell me if this is still due to the WU shortage or if there is another problem at my end?
*********************** Log Started 2021-06-24T09:57:05Z ***********************
09:57:05:******************************* libFAH ********************************
09:57:05:           Date: Oct 20 2020
09:57:05:           Time: 13:36:55
09:57:05:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
09:57:05:         Branch: master
09:57:05:       Compiler: Visual C++ 2015
09:57:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
09:57:05:       Platform: win32 10
09:57:05:           Bits: 32
09:57:05:           Mode: Release
09:57:05:****************************** FAHClient ******************************
09:57:05:        Version: 7.6.21
09:57:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:57:05:      Copyright: 2020 foldingathome.org
09:57:05:       Homepage: https://foldingathome.org/
09:57:05:           Time: 13:41:04
09:57:05:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
09:57:05:           Bits: 32
09:57:05:           Args: --open-web-control
09:57:05:******************************** CBang ********************************
09:57:05:           Time: 11:36:18
09:57:05:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
09:57:05:           Bits: 32
09:57:05:******************************* System ********************************
09:57:05:            CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
09:57:05:         CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
09:57:05:           CPUs: 16
09:57:05:         Memory: 15.75GiB
09:57:05:    Free Memory: 9.50GiB
09:57:05:        Threads: WINDOWS_THREADS
09:57:05:     OS Version: 6.2
09:57:05:    Has Battery: false
09:57:05:     On Battery: false
09:57:05:     UTC Offset: 2
09:57:05:            PID: 18684
09:57:05:            CWD: C:\ProgramData\FAHClient
09:57:05:  Win32 Service: false
09:57:05:             OS: Windows 10 Home
09:57:05:        OS Arch: AMD64
09:57:05:           GPUs: 1
09:57:05:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 970] 3494
09:57:05:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.3
09:57:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:466.27
09:57:05:***********************************************************************
09:57:06:<config>
09:57:06:  <!-- Folding Slots -->
09:57:06:</config>
09:57:06:Trying to access database...
09:57:06:Successfully acquired database lock
09:57:06:FS00:Initialized folding slot 00: cpu:14
09:57:06:FS01:Initialized folding slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494
09:57:07:3:127.0.0.1:New Web session
09:57:08:4:127.0.0.1:New Web session
09:57:42:Set client configured
09:57:42:WU00:FS00:Connecting to assign1.foldingathome.org:80
09:57:43:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:57:43:WU00:FS00:Connecting to assign1.foldingathome.org:80
09:57:43:WU00:FS00:Assigned to work server 129.32.209.205
09:57:43:WU00:FS00:Requesting new work unit for slot 00: cpu:14 from 129.32.209.205
09:57:43:WU00:FS00:Connecting to 129.32.209.205:8080
09:57:43:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
09:57:43:WU01:FS01:Connecting to assign2.foldingathome.org:80
09:57:44:WU00:FS00:Downloading 1.48MiB
09:57:44:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
09:57:44:WU01:FS01:Connecting to assign3.foldingathome.org:80
09:57:45:WU01:FS01:Assigned to work server 128.252.203.11
09:57:45:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
09:57:45:WU01:FS01:Connecting to 128.252.203.11:8080
09:57:45:WU00:FS00:Download complete
09:57:45:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:8 clone:238 gen:49 core:0xa8 unit:0x000000ee000000310000423f00000008
09:57:45:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
09:57:45:WU00:FS00:Connecting to cores.foldingathome.org:80
09:57:45:WU00:FS00:FahCore a8: Downloading 7.72MiB
09:57:50:WU00:FS00:FahCore a8: Download complete
09:57:50:WU00:FS00:Valid core signature
09:57:50:WU00:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
09:57:50:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
09:57:50:WU00:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
09:57:50:WU00:FS00:Starting
09:57:50:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 18684 -checkpoint 15 -np 14
09:57:50:WU00:FS00:Started FahCore on PID 7628
09:57:50:WU00:FS00:Core PID:17416
09:57:50:WU00:FS00:FahCore 0xa8 started
09:57:51:WU00:FS00:0xa8:*********************** Log Started 2021-06-24T09:57:50Z ***********************
09:57:51:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
09:57:51:WU00:FS00:0xa8:       Core: Gromacs
09:57:51:WU00:FS00:0xa8:       Type: 0xa8
09:57:51:WU00:FS00:0xa8:    Version: 0.0.12
09:57:51:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:57:51:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
09:57:51:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
09:57:51:WU00:FS00:0xa8:       Date: Jan 16 2021
09:57:51:WU00:FS00:0xa8:       Time: 12:29:40
09:57:51:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
09:57:51:WU00:FS00:0xa8:     Branch: master
09:57:51:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
09:57:51:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
09:57:51:WU00:FS00:0xa8:   Platform: win32 10
09:57:51:WU00:FS00:0xa8:       Bits: 64
09:57:51:WU00:FS00:0xa8:       Mode: Release
09:57:51:WU00:FS00:0xa8:       SIMD: avx2_256
09:57:51:WU00:FS00:0xa8:     OpenMP: ON
09:57:51:WU00:FS00:0xa8:       CUDA: OFF
09:57:51:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7628 -checkpoint 15 -np
09:57:51:WU00:FS00:0xa8:             14
09:57:51:WU00:FS00:0xa8:************************************ libFAH ************************************
09:57:51:WU00:FS00:0xa8:       Time: 11:24:13
09:57:51:WU00:FS00:0xa8:************************************ CBang *************************************
09:57:51:WU00:FS00:0xa8:       Time: 11:23:53
09:57:51:WU00:FS00:0xa8:************************************ System ************************************
09:57:51:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
09:57:51:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
09:57:51:WU00:FS00:0xa8:       CPUs: 16
09:57:51:WU00:FS00:0xa8:     Memory: 15.75GiB
09:57:51:WU00:FS00:0xa8:Free Memory: 9.40GiB
09:57:51:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
09:57:51:WU00:FS00:0xa8: OS Version: 6.2
09:57:51:WU00:FS00:0xa8:Has Battery: false
09:57:51:WU00:FS00:0xa8: On Battery: false
09:57:51:WU00:FS00:0xa8: UTC Offset: 2
09:57:51:WU00:FS00:0xa8:        PID: 17416
09:57:51:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
09:57:51:WU00:FS00:0xa8:********************************************************************************
09:57:51:WU00:FS00:0xa8:Project: 16959 (Run 8, Clone 238, Gen 49)
09:57:51:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
09:57:51:WU00:FS00:0xa8:Reading tar file core.xml
09:57:51:WU00:FS00:0xa8:Reading tar file frame49.tpr
09:57:51:WU00:FS00:0xa8:Digital signatures verified
09:57:51:WU00:FS00:0xa8:Calling: mdrun -c frame49.gro -s frame49.tpr -x frame49.xtc -cpt 15 -nt 14 -ntmpi 1
09:57:51:WU00:FS00:0xa8:Steps: first=122500000 total=125000000
09:57:51:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
09:57:55:FS00:Shutting core down
09:57:55:WU00:FS00:0xa8:WARNING:Console control signal 1 on PID 17416
09:57:55:WU00:FS00:0xa8:Exiting, please wait. . .
09:57:55:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:57:56:WU00:FS00:Starting
09:57:56:WARNING:WU00:FS00:Changed SMP threads from 14 to 15 this can cause some work units to fail
09:57:56:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
09:57:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 18684 -checkpoint 15 -np 14
09:57:56:WU00:FS00:Started FahCore on PID 3696
09:57:56:WU00:FS00:Core PID:9388
09:57:56:WU00:FS00:FahCore 0xa8 started
09:57:56:WU00:FS00:0xa8:*********************** Log Started 2021-06-24T09:57:56Z ***********************
09:57:56:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
09:57:56:WU00:FS00:0xa8:       Core: Gromacs
09:57:56:WU00:FS00:0xa8:       Type: 0xa8
09:57:56:WU00:FS00:0xa8:    Version: 0.0.12
09:57:56:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:57:56:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
09:57:56:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
09:57:56:WU00:FS00:0xa8:       Date: Jan 16 2021
09:57:56:WU00:FS00:0xa8:       Time: 12:29:40
09:57:56:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
09:57:56:WU00:FS00:0xa8:     Branch: master
09:57:56:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
09:57:56:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
09:57:56:WU00:FS00:0xa8:   Platform: win32 10
09:57:56:WU00:FS00:0xa8:       Bits: 64
09:57:56:WU00:FS00:0xa8:       Mode: Release
09:57:56:WU00:FS00:0xa8:       SIMD: avx2_256
09:57:56:WU00:FS00:0xa8:     OpenMP: ON
09:57:56:WU00:FS00:0xa8:       CUDA: OFF
09:57:56:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 3696 -checkpoint 15 -np
09:57:56:WU00:FS00:0xa8:             14
09:57:56:WU00:FS00:0xa8:************************************ libFAH ************************************
09:57:56:WU00:FS00:0xa8:       Time: 11:24:13
09:57:56:WU00:FS00:0xa8:************************************ CBang *************************************
09:57:56:WU00:FS00:0xa8:       Time: 11:23:53
09:57:56:WU00:FS00:0xa8:************************************ System ************************************
09:57:56:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
09:57:56:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
09:57:56:WU00:FS00:0xa8:       CPUs: 16
09:57:56:WU00:FS00:0xa8:     Memory: 15.75GiB
09:57:56:WU00:FS00:0xa8:Free Memory: 9.39GiB
09:57:56:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
09:57:56:WU00:FS00:0xa8: OS Version: 6.2
09:57:56:WU00:FS00:0xa8:Has Battery: false
09:57:56:WU00:FS00:0xa8: On Battery: false
09:57:56:WU00:FS00:0xa8: UTC Offset: 2
09:57:56:WU00:FS00:0xa8:        PID: 9388
09:57:56:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
09:57:56:WU00:FS00:0xa8:********************************************************************************
09:57:56:WU00:FS00:0xa8:Project: 16959 (Run 8, Clone 238, Gen 49)
09:57:56:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
09:57:56:WU00:FS00:0xa8:Digital signatures verified
09:57:56:WU00:FS00:0xa8:Calling: mdrun -c frame49.gro -s frame49.tpr -x frame49.xtc -cpi state.cpt -cpt 15 -nt 14 -ntmpi 1
09:57:56:WU00:FS00:0xa8:Steps: first=122500000 total=125000000
09:57:56:WU00:FS00:0xa8:Completed 652 out of 2500000 steps (0%)
09:58:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:58:06:WU01:FS01:Connecting to 128.252.203.11:80
09:58:07:Saving configuration to config.xml
09:58:07:<config>
09:58:07:  <!-- Slot Control -->
09:58:07:  <power v='FULL'/>
09:58:07:
09:58:07:  <!-- User Information -->
09:58:07:  <passkey v='*****'/>
09:58:07:  <team v='234980'/>
09:58:07:  <user v='8fd5i319me9h'/>
09:58:07:
09:58:07:  <!-- Folding Slots -->
09:58:07:  <slot id='0' type='CPU'/>
09:58:07:  <slot id='1' type='GPU'>
09:58:07:    <pci-bus v='1'/>
09:58:07:    <pci-slot v='0'/>
09:58:07:  </slot>
09:58:07:</config>
09:58:27:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.11:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
09:58:28:WU01:FS01:Connecting to assign1.foldingathome.org:80
09:58:28:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
09:58:28:WU01:FS01:Connecting to assign2.foldingathome.org:80
09:58:28:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
09:58:28:WU01:FS01:Connecting to assign3.foldingathome.org:80
09:58:29:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
09:58:29:WU01:FS01:Connecting to assign4.foldingathome.org:80
09:58:30:WU01:FS01:Assigned to work server 128.252.203.11
09:58:30:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
09:58:30:WU01:FS01:Connecting to 128.252.203.11:8080
09:58:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:58:51:WU01:FS01:Connecting to 128.252.203.11:80
09:59:22:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:00:05:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:00:05:WU01:FS01:Assigned to work server 128.252.203.11
10:00:07:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
10:00:07:WU01:FS01:Connecting to 128.252.203.11:8080
10:00:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:00:28:WU01:FS01:Connecting to 128.252.203.11:80
10:00:41:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
10:01:01:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:02:42:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:02:43:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:02:43:WU01:FS01:Connecting to assign2.foldingathome.org:80
10:02:43:WU01:FS01:Assigned to work server 128.252.203.11
10:02:44:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
10:02:44:WU01:FS01:Connecting to 128.252.203.11:8080
10:03:14:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:03:33:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
10:06:25:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
10:06:56:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:06:57:WARNING:WU01:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
10:06:57:WU01:FS01:Connecting to assign2.foldingathome.org:80
10:06:57:WARNING:WU01:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
10:06:57:WU01:FS01:Connecting to assign3.foldingathome.org:80
10:06:58:WARNING:WU01:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
10:06:58:WU01:FS01:Connecting to assign4.foldingathome.org:80
10:06:58:WU01:FS01:Assigned to work server 128.252.203.11
10:06:58:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
10:06:58:WU01:FS01:Connecting to 128.252.203.11:8080
10:07:19:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:07:19:WU01:FS01:Connecting to 128.252.203.11:80
10:08:05:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:09:16:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
10:12:07:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
10:13:48:WU01:FS01:Connecting to assign1.foldingathome.org:80
10:13:48:WU01:FS01:Assigned to work server 128.252.203.11
10:13:50:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GM204 [GeForce GTX 970] 3494 from 128.252.203.11
10:13:50:WU01:FS01:Connecting to 128.252.203.11:8080
10:14:11:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:14:11:WU01:FS01:Connecting to 128.252.203.11:80
10:14:42:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:15:00:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
aetch
Re: No GPU WU, shortage or other cause?
Post by aetch »
Check the server stats for yourself.
GRO_A7 and GRO_A8 are CPU jobs.
OPENMM_22 is GPU jobs.
https://apps.foldingathome.org/serverstats
My GPUs are also low on WUs. I always assume it is at F@H end. (GTX 1060 and RTX 3060)
psaam0001
Post by psaam0001 »
I'm waiting for work too.... Though it did not help to have to do an O/S re-installation from scratch on my 16-core system (including drivers and F@H; to fix something I messed up).
Paul
kiore
Post by kiore »
psaam0001 wrote:I'm waiting for work too.... Though it did not help to have to do an O/S re-installation from scratch on my 16-core system (including drivers and F@H; to fix something I messed up).
Paul
When there are workunit shortages like currently this is IMO the best time to do reinstalls, updates, case clean outs and stuff. I just dedusted some case fans and suddenly getting much better cooling, a bonus.
erich56
Post by erich56 »
I also ran out of GPU jobs on all of my machines :-(
Could someone from the FAH team please tell us when new jobs will be available?
aetch
Post by aetch »
Paul
About a month ago I replaced the motherboard in my Ryzen system. It had power cycled three days on the trot. That system was down for about a fortnight getting diagnosed, waiting for parts and finally stress tested to ensure it was stable.
I think this current lack of work unit could be tied into the problems they're having with projects 18201/2, the work/collection servers for those projects and it possibly being that quiet time of the year.
zotric
Hardware configuration: HOMEBREW
Processor 12th Gen Intel(R) Core(TM) i9-12900K 3.19 GHz
Installed RAM 32.0 GB (31.8 GB usable)
RTX 3080 Ti
LEGION T7 34IMZ5
Processor Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz 3.79 GHz
Installed RAM 16.0 GB (15.8 GB usable)
RTX 3070
Post by zotric »
Same here on both my GPU based folding machines for COVID-19 which have run almost non stop for a month.
They stopped getting WUs early yesterday morning (before 7 am UK time) so after a while I decided to leave both machines off all day. Restarted them earlier this morning but no COVID-19 WUs so far (11:00 UK).
I Changed one of the GPU machines to look for 'Any Disease' instead of COVID-19 and it is folding normally with work server 207.53.233.146.
Did I just see the work server change when it picked up a new work unit?
As of 11:00 (UK BST) I'm still waiting for a COVID-19 WU from 206.223.170.146 but I'll change the target sometime today if nothing turns up.
'Work servers' shown in FAHControl when waiting for a COVID-19 WU and failing to get one:
128.174.73.74 (OPENMM_22) which had a warning and 'No' in column 'Has CS'
206.223.170.146 (GRO_A7, OPENMM_22) which looks OK.
(are these actual work servers?)
Earlier, the work server was set to 0.0.0.0 for both machines.
Using current Windows 10 Pro 64 bit with NVIDIA GPUs
No Windows updates since 22nd June when NVIDIA Driver updated to 27.21.14.6679
FAH Core 0x22
Scraig
Post by Scraig »
It's frustrating. Tens thousands of people worldwide are ready to make their computers and power resources available in the fight against diseases, but the FAH support team does not communicate with us if there are problems with the provision of work packages.
The FAH support team should report problems promptly. Ideally, temporarily on the start page or at least on that of the support. As it is now, many people waste time with seeming solutions that doesn't work and some give up in frustration.
silverpulser
Post by silverpulser »
Me too. No GPU WU for over half a day on Nvidia 1650 Super.
Keep getting:
*********************** Log Started 2021-06-25T11:51:20Z ***********************
11:51:20:FS01:Initialized folding slot 01: gpu:1:0 TU116 [GeForce GTX 1650 SUPER]
11:51:21:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:51:22:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:51:22:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:51:22:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:51:22:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:51:22:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:51:22:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:51:23:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:51:23:ERROR:WU00:FS01:Exception: Could not get an assignment
11:51:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:51:23:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:51:23:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:51:24:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:51:24:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:51:24:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:51:24:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:51:25:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:51:25:ERROR:WU00:FS01:Exception: Could not get an assignment
11:52:23:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:52:23:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:52:24:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:52:24:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:52:24:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:52:25:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:52:25:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:52:25:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:52:25:ERROR:WU00:FS01:Exception: Could not get an assignment
11:54:00:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:54:01:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:54:01:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:54:01:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:54:01:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:54:02:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:54:02:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:54:02:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:54:02:ERROR:WU00:FS01:Exception: Could not get an assignment
11:56:37:WU00:FS01:Connecting to assign1.foldingathome.org:80
11:56:38:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
11:56:38:WU00:FS01:Connecting to assign2.foldingathome.org:80
11:56:38:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
11:56:38:WU00:FS01:Connecting to assign3.foldingathome.org:80
11:56:39:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
11:56:39:WU00:FS01:Connecting to assign4.foldingathome.org:80
11:56:39:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
11:56:40:ERROR:WU00:FS01:Exception: Could not get an assignment
12:00:52:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:00:52:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:00:52:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:00:53:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:00:53:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:00:54:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:00:54:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:00:54:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:00:54:ERROR:WU00:FS01:Exception: Could not get an assignment
12:07:43:WU00:FS01:Connecting to assign1.foldingathome.org:80
12:07:44:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
12:07:44:WU00:FS01:Connecting to assign2.foldingathome.org:80
12:07:44:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
12:07:44:WU00:FS01:Connecting to assign3.foldingathome.org:80
12:07:45:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
12:07:45:WU00:FS01:Connecting to assign4.foldingathome.org:80
12:07:45:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
12:07:45:ERROR:WU00:FS01:Exception: Could not get an assignment
mgetz
Post by mgetz »
Just an FYI, it's not just y'all it's everybody. There are currently (as of posting) no public GPU WUs according to Serverstats. It also looks like projects 182xx were withdrawn (at least temporarily) for a variety of reasons. But if the scientist sees this they can expound on the why without me speculating.
jjmiller
Scientist
Post by jjmiller »
Hi all,
Sorry for the silence from FAH science team. There is indeed both a GPU and CPU work unit shortage. A couple of reasons drive this- first and foremost we do our best to make sure that every WU we release is scientifically valuable so that you are not wasting your time or electricity on meaningless calculations. Recently, due to the huge support from the community, the COVID moonshot sprint which was contributing a significant number of GPU WUs to F@H was completed. We cannot thank you enough for your contributions.
I've been working on releasing several CPU and GPU projects to understand one of the proteins involved in Alzheimer's disease. These WUs are appearing in the 182xx series. Unfortunately, as we were scaling up to send these WUs out we ended up overloading our work server (128.252.203.11). As a result we've had issues assigning points from that server and also receiving WUs back. I've put a pause on all of the 182xx projects until we can get our server woes resolved as we want to make sure that any WU we send out we can properly receive back. Our current plan is to wait for all WUs assigned by that server to return before we begin to reassign jobs in that series. Based on the deadline for the 182xx project series, the timeline for this is ~5 days from now. In the meantime we're working to get another work server online and stocked with both CPU and GPU WUs.
In addition to my project series, several other project series are currently working their way through testing. As I'm not involved in those project series, I can't comment on the projected timeline but hope that that series is available soon. Thank you for your continued support for F@H and apologies for the lack of work to do.
Scraig
Post by Scraig »
Thanks for the detailed answer. Still, it would be good to report a problem right away. Then everyone affected knows that it has been recognized and that work is being carried out to rectify it, instead of looking for errors elsewhere or even giving up.
zotric
RTX 3080 Ti
LEGION T7 34IMZ5
RTX 3070
Post by zotric »
I'm getting GPU work now - thanks to everyone who mitigated or fixed the problem.
I wonder if it would be possible to have a fixed location for general announcements on the server, project and WU status.
A report on the issues and expected time to fix would allow people to switch off the machines when not used for other work.
gunnarre
Post by gunnarre »
Thank you for the update.
Scraig wrote:The FAH support team should report problems promptly. Ideally, temporarily on the start page or at least on that of the support.
The front page of this forum does indeed say:
The Folding@home team know about the work unit shortage.
That message is a bit outdated, since it was put there in the big ramp-up in spring of 2020. So new reports of lack of work, or server problems, are appreciated, and perhaps it should be updated more often with known issues which don't need to be reported.
I would, however, like to remind my fellow folders that the scientists are the "customers" of the F@H project, and apart from one (or two?) salaried developers, all the rest of the support "staff" are volunteers like you and me. Again, updates are appreciated, and I'd rather see the GPUs go idle than do pointless work.
There are people who have set up their rigs to automatically run other projects (like in BOINC) if F@H doesn't have WUs available.
