Problem with Project 18202.
Hi! So anytime I run this project, I finish it completely but it only gives me the base credit of 67770. And even that wont show up on my total points. My passkey is active. All other WUs work perfectly, getting the QRB and it registers on my account as a finished work unit.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Problem with Project 18202.
There have been some issues with uploads and credits on that particular Project.
https://foldingforum.org/viewtopic.php?f=19&t=37214
As for the credits, at times they are slow to post but usually show up. Are your logs showing that it sends and reporting only base points credit?
In any case, more info is better.
Fold them if you get them!
file:///C/Users/User/OneDrive/Desktop/LOG%20FOR%2018202.txt[20/06/2021 5:39:51 pm]
19:01:00:WU00:FS01:0x22:Project: 18202 (Run 17588, Clone 3, Gen 9)
19:01:00:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:01:00:WU00:FS01:0x22:Reading tar file core.xml
19:01:00:WU00:FS01:0x22:Reading tar file integrator.xml
19:01:00:WU00:FS01:0x22:Reading tar file state.xml
19:01:00:WU00:FS01:0x22:Reading tar file system.xml
19:01:01:WU00:FS01:0x22:Digital signatures verified
19:01:01:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:01:01:WU00:FS01:0x22:Version 0.0.13
19:01:01:WU00:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
19:01:01:WU00:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
19:01:01:WU00:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
19:01:01:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
19:01:01:WU00:FS01:0x22:There are 4 platforms available.
19:01:01:WU00:FS01:0x22:Platform 0: Reference
19:01:01:WU00:FS01:0x22:Platform 1: CPU
19:01:01:WU00:FS01:0x22:Platform 2: OpenCL
19:01:01:WU00:FS01:0x22: opencl-device 0 specified
19:01:01:WU00:FS01:0x22:Platform 3: CUDA
19:01:01:WU00:FS01:0x22: cuda-device 0 specified
19:01:05:WU01:FS01:Upload 17.81%
19:01:10:WU00:FS01:0x22:Attempting to create CUDA context:
19:01:10:WU00:FS01:0x22: Configuring platform CUDA
19:01:11:WU01:FS01:Upload 37.09%
19:01:15:WU00:FS01:0x22: Using CUDA and gpu 0
19:01:15:WU00:FS01:0x22:Completed 0 out of 1250000 steps (0%)
19:01:16:WU00:FS01:0x22:Checkpoint completed at step 0
19:01:17:WU01:FS01:Upload 57.13%
19:01:23:WU01:FS01:Upload 76.42%
19:01:29:WU01:FS01:Upload 95.71%
19:01:31:WU01:FS01:Upload complete
19:01:31:WU01:FS01:Server responded WORK_ACK (400)
19:01:31:WU01:FS01:Final credit estimate, 200167.00 points
19:01:31:WU01:FS01:Cleaning up
19:02:17:WU00:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
19:03:18:WU00:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
20:41:18:WU00:FS01:0x22:Checkpoint completed at step 1225000
20:42:19:WU00:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
20:42:19:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:42:20:WU01:FS01:Assigned to work server 54.157.202.86
20:42:20:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GA102 [GeForce RTX 3080] from 54.157.202.86
20:42:20:WU01:FS01:Connecting to 54.157.202.86:8080
20:42:21:WU01:FS01:Downloading 6.91MiB
20:42:27:WU01:FS01:Download 75.11%
20:42:28:WU01:FS01:Download complete
20:42:28:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13446 run:9756 clone:51
gen:0 core:0x22 unit:0x0000003300000000000034860000261c
20:43:19:WU00:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
20:43:19:WU00:FS01:0x22:Average performance: 28.562 ns/day
20:43:20:WU00:FS01:0x22:Checkpoint completed at step 1250000
20:43:24:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:43:24:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml
20:43:24:WU00:FS01:0x22:Saving result file checkpointState.xml
20:43:27:WU00:FS01:0x22:Saving result file positions.xtc
20:43:27:WU00:FS01:0x22:Saving result file science.log
20:43:27:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:43:28:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:43:28:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:18202 run:17588 clone:3 gen:9
core:0x22 unit:0x00000003000000090000471a000044b4
20:43:28:WU00:FS01:Uploading 27.50MiB to 128.252.203.11
20:43:28:WU00:FS01:Connecting to 128.252.203.11:8080
20:43:28:WU01:FS01:Starting
20:43:28:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe"
C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -
suffix 01 -version 706 -lifeline 16672 -checkpoint 30 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
nvidia -gpu 0 -gpu-usage 100
20:43:28:WU01:FS01:Started FahCore on PID 1276
20:43:28:WU01:FS01:Core PID:8756
20:43:28:WU01:FS01:FahCore 0x22 started
20:43:29:WU01:FS01:0x22:*********************** Log Started 2021-06-19T20:43:28Z
20:43:29:WU01:FS01:0x22:*************************** Core22 Folding@home Core
20:43:29:WU01:FS01:0x22: Core: Core22
20:43:29:WU01:FS01:0x22: Type: 0x22
20:43:29:WU01:FS01:0x22: Version: 0.0.13
20:43:29:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:29:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
20:43:29:WU01:FS01:0x22: Homepage: https://foldingathome.org/
20:43:29:WU01:FS01:0x22: Date: Sep 19 2020
20:43:29:WU01:FS01:0x22: Time: 02:35:58
20:43:29:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:43:29:WU01:FS01:0x22: Branch: core22-0.0.13
20:43:29:WU01:FS01:0x22: Compiler: Visual C++ 2015
20:43:29:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:43:29:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
20:43:29:WU01:FS01:0x22: Platform: win32 10
20:43:29:WU01:FS01:0x22: Bits: 64
20:43:29:WU01:FS01:0x22: Mode: Release
20:43:29:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:43:29:WU01:FS01:0x22: <peastman@stanford.edu>
20:43:29:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 1276 -checkpoint 30
20:43:29:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
20:43:29:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
20:43:29:WU01:FS01:0x22:************************************ libFAH
20:43:29:WU01:FS01:0x22: Date: Sep 7 2020
20:43:29:WU01:FS01:0x22: Time: 19:09:56
20:43:29:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:43:29:WU01:FS01:0x22: Branch: HEAD
20:43:29:WU01:FS01:0x22:************************************ CBang
20:43:29:WU01:FS01:0x22: Time: 19:08:30
20:43:29:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:43:29:WU01:FS01:0x22:************************************ System
20:43:29:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
20:43:29:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
20:43:29:WU01:FS01:0x22: CPUs: 16
20:43:29:WU01:FS01:0x22: Memory: 15.89GiB
20:43:29:WU01:FS01:0x22:Free Memory: 11.93GiB
20:43:29:WU01:FS01:0x22: Threads: WINDOWS_THREADS
20:43:29:WU01:FS01:0x22: OS Version: 6.2
20:43:29:WU01:FS01:0x22:Has Battery: false
20:43:29:WU01:FS01:0x22: On Battery: false
20:43:29:WU01:FS01:0x22: UTC Offset: 8
20:43:29:WU01:FS01:0x22: PID: 8756
20:43:29:WU01:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
20:43:29:WU01:FS01:0x22:************************************ OpenMM
20:43:29:WU01:FS01:0x22: Revision: 189320d0
20:43:29:WU01:FS01:0x22:*************************************************************************
20:43:29:WU01:FS01:0x22:Project: 13446 (Run 9756, Clone 51, Gen 0)
20:43:29:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
20:43:29:WU01:FS01:0x22:Reading tar file core.xml
20:43:29:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
20:43:29:WU01:FS01:0x22:Reading tar file state.xml.bz2
20:43:29:WU01:FS01:0x22:Reading tar file system.xml.bz2
20:43:29:WU01:FS01:0x22:Digital signatures verified
20:43:29:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:43:29:WU01:FS01:0x22:Version 0.0.13
20:43:29:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
20:43:29:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
20:43:29:WU01:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
20:43:29:WU01:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
20:43:29:WU01:FS01:0x22:There are 4 platforms available.
20:43:29:WU01:FS01:0x22:Platform 0: Reference
20:43:29:WU01:FS01:0x22:Platform 1: CPU
20:43:29:WU01:FS01:0x22:Platform 2: OpenCL
20:43:29:WU01:FS01:0x22: opencl-device 0 specified
20:43:29:WU01:FS01:0x22:Platform 3: CUDA
20:43:29:WU01:FS01:0x22: cuda-device 0 specified
20:43:34:WU00:FS01:Upload 5.68%
20:43:35:WU01:FS01:0x22:Attempting to create CUDA context:
20:43:35:WU01:FS01:0x22: Configuring platform CUDA
20:43:40:WU00:FS01:Upload 12.27%
20:43:41:WU01:FS01:0x22: Using CUDA and gpu 0
20:43:41:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
20:43:41:WU01:FS01:0x22:Checkpoint completed at step 0
20:43:46:WU00:FS01:Upload 18.63%
20:43:52:WU00:FS01:Upload 24.77%
20:43:58:WU00:FS01:Upload 31.13%
20:44:04:WU00:FS01:Upload 37.50%
20:44:10:WU00:FS01:Upload 43.86%
20:44:16:WU00:FS01:Upload 50.22%
20:44:22:WU00:FS01:Upload 56.59%
20:44:26:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
20:44:28:WU00:FS01:Upload 62.95%
20:44:34:WU00:FS01:Upload 69.31%
20:44:40:WU00:FS01:Upload 75.68%
20:44:46:WU00:FS01:Upload 82.04%
20:44:52:WU00:FS01:Upload 88.40%
20:44:58:WU00:FS01:Upload 94.77%
20:45:04:WU00:FS01:Upload complete
20:45:04:WU00:FS01:Server responded WORK_ACK (400)
20:45:04:WU00:FS01:Final credit estimate, 67770.00 points
20:45:04:WU00:FS01:Cleaning upRe: Problem with Project 18202.
Here are the logs for that particular instance. The base credits still haven't been given to me. Hope they fix it soon.BobWilliams757 wrote:There have been some issues with uploads and credits on that particular Project.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
I'm not sure what is going on with that one. I know there was an instance where the timeout on a certain project was somehow changing to zero, so no matter how fast it was done it was only giving base points. I haven't seen any more mention of that, and think it was only one project that I recall.
In any case, at times the points are delayed by one of the servers or small issues, but then catch up. I've yet to find a WU that I didn't get properly credited for.
Just be glad your rig is folding them so quickly. With my mighty onboard graphics my system takes about 39-40 hours per WU on that project!
Hi all, sorry I'd missed this thread. We had an issue on 18202's work server where it was handling a particularly high load of work due some projects we're looking to roll out which caused delayed responsiveness. At the same time we unexpectedly ran out of storage on the partition where our logs are stored, leading to issues in crediting points. We think we have all of the kinks ironed out now, but are going to monitor for additional reports before opening the project again. So sorry about the disruption!
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
I also have some missing credits for this project.
project:18201 run:51585 clone:0 gen:0
uploaded 2021-06-21T16:49:31Z
project:18202 run:11847 clone:2 gen:6
uploaded 2021-06-21T05:30:41Z
project:18202 run:6089 clone:3 gen:7
uploaded 2021-06-21T00:26:10Z
project:18202 run:4636 clone:4 gen:10
uploaded 2021-06-20T19:20:46Z
project:18202 run:7548 clone:4 gen:9
uploaded 2021-06-19T23:53:59Z
