Running M1 MacBook Air with MacOS 11.4; Client has been productive until Jun 14. Several restarts of both the machine and the client have not resolved the issue. No changes in internet, connectivity otherwise uninterrupted. Possible that the Jun 14 date coincided with my upgrade to MacOS 11.4, but I have not been able to absolutely confirm this yet. Could not retrieve log file using FAHControl, but was able to open the log.txt via Finder. Contents below. Please advise on possible next steps. I did look within the various fora for a recent post on this message but did not see one. Grateful for any feedback! Sincerely, Dan
*********************** Log Started 2021-06-14T15:05:38Z ***********************
15:05:38:******************************* libFAH ********************************
15:05:38: Date: Oct 20 2020
15:05:38: Time: 13:36:42
15:05:38: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:05:38: Branch: master
15:05:38: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
15:05:38: Options: -std=c++11 -fsigned-char -O3 -funroll-loops
15:05:38: -mmacosx-version-min=10.7 -Wno-unused-local-typedefs -stdlib=libc++
15:05:38: Platform: darwin 19.2.0
15:05:38: Bits: 64
15:05:38: Mode: Release
15:05:38:****************************** FAHClient ******************************
15:05:38: Version: 7.6.21
15:05:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:05:38: Copyright: 2020 foldingathome.org
15:05:38: Homepage: https://foldingathome.org/
15:05:38: Time: 13:39:56
15:05:38: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:05:38: Bits: 64
15:05:38: Config: /Library/Application Support/FAHClient/config.xml
15:05:38:******************************** CBang ********************************
15:05:38: Time: 11:39:07
15:05:38: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:05:38: -fPIC
15:05:38: Bits: 64
15:05:38:******************************* System ********************************
15:05:38: CPU: VirtualApple @ 2.50GHz
15:05:38: CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
15:05:38: CPUs: 8
15:05:38: Memory: 8.00GiB
15:05:38:Free Memory: 4.52GiB
15:05:38: Threads: POSIX_THREADS
15:05:38: OS Version: 10.16
15:05:38:Has Battery: true
15:05:38: On Battery: false
15:05:38: UTC Offset: -4
15:05:38: PID: 96
15:05:38: CWD: /Library/Application Support/FAHClient
15:05:38: OS: Darwin 20.3.0 x86_64
15:05:38: OS Arch: AMD64
15:05:38: GPUs: 1
15:05:38: GPU 0: Bus:0 Slot:0 Func:0 AMD:5 Hawaii [Radeon R9 200 Series]
15:05:38: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
15:05:38: dlopen(libcuda.dylib, 1): no suitable image found. Did find:
15:05:38: file system relative paths not allowed in hardened programs
15:05:38: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
15:05:38: dlopen(libOpenCL.dylib, 1): no suitable image found. Did find:
15:05:38:***********************************************************************
15:05:38:<config>
15:05:38: <!-- Folding Slot Configuration -->
15:05:38: <cause v='COVID_19'/>
15:05:38:
15:05:38: <!-- Network -->
15:05:38: <proxy v=':8080'/>
15:05:38:
15:05:38: <!-- Slot Control -->
15:05:38: <pause-on-battery v='false'/>
15:05:38:
15:05:38: <!-- User Information -->
15:05:38: <team v='257242'/>
15:05:38: <user v='In_Memory_of_Badi_(Mirza_Aqa_Buzurg-i-Nishapuri)'/>
15:05:38:
15:05:38: <!-- Folding Slots -->
15:05:38: <slot id='0' type='CPU'/>
15:05:38:</config>
15:05:38:Trying to access database...
15:05:38:Successfully acquired database lock
15:05:38:FS00:Initialized folding slot 00: cpu:4
15:05:38:WU00:FS00:Starting
15:05:38:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-sse2/a8-0.0.12/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 96 -checkpoint 15 -np 4
15:05:38:WU00:FS00:Started FahCore on PID 407
15:05:38:WU00:FS00:Core PID:408
15:05:38:WU00:FS00:FahCore 0xa8 started
15:05:39:WU00:FS00:0xa8:*********************** Log Started 2021-06-14T15:05:38Z ***********************
15:05:39:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
15:05:39:WU00:FS00:0xa8: Core: Gromacs
15:05:39:WU00:FS00:0xa8: Type: 0xa8
15:05:39:WU00:FS00:0xa8: Version: 0.0.12
15:05:39:WU00:FS00:0xa8: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:05:39:WU00:FS00:0xa8: Copyright: 2020 foldingathome.org
15:05:39:WU00:FS00:0xa8: Homepage: https://foldingathome.org/
15:05:39:WU00:FS00:0xa8: Date: Jan 16 2021
15:05:39:WU00:FS00:0xa8: Time: 21:22:16
15:05:39:WU00:FS00:0xa8: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
15:05:39:WU00:FS00:0xa8: Branch: master
15:05:39:WU00:FS00:0xa8: Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
15:05:39:WU00:FS00:0xa8: Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
15:05:39:WU00:FS00:0xa8: -funroll-loops -fno-pie -mmacosx-version-min=10.7
15:05:39:WU00:FS00:0xa8: Platform: darwin 20.2.0
15:05:39:WU00:FS00:0xa8: Bits: 64
15:05:39:WU00:FS00:0xa8: Mode: Release
15:05:39:WU00:FS00:0xa8: SIMD: sse2
15:05:39:WU00:FS00:0xa8: OpenMP: ON
15:05:39:WU00:FS00:0xa8: CUDA: OFF
15:05:39:WU00:FS00:0xa8: Args: -dir 00 -suffix 01 -version 706 -lifeline 407 -checkpoint 15 -np 4
15:05:39:WU00:FS00:0xa8:************************************ libFAH ************************************
15:05:39:WU00:FS00:0xa8: Time: 21:21:45
15:05:39:WU00:FS00:0xa8:************************************ CBang *************************************
15:05:39:WU00:FS00:0xa8: Time: 21:21:02
15:05:39:WU00:FS00:0xa8: -funroll-loops -fno-pie -mmacosx-version-min=10.7 -fPIC
15:05:39:WU00:FS00:0xa8:************************************ System ************************************
15:05:39:WU00:FS00:0xa8: CPU: VirtualApple @ 2.50GHz
15:05:39:WU00:FS00:0xa8: CPU ID: GenuineIntel Family 6 Model 44 Stepping 0
15:05:39:WU00:FS00:0xa8: CPUs: 8
15:05:39:WU00:FS00:0xa8: Memory: 8.00GiB
15:05:39:WU00:FS00:0xa8:Free Memory: 4.38GiB
15:05:39:WU00:FS00:0xa8: Threads: POSIX_THREADS
15:05:39:WU00:FS00:0xa8: OS Version: 11.2
15:05:39:WU00:FS00:0xa8:Has Battery: true
15:05:39:WU00:FS00:0xa8: On Battery: false
15:05:39:WU00:FS00:0xa8: UTC Offset: -4
15:05:39:WU00:FS00:0xa8: PID: 408
15:05:39:WU00:FS00:0xa8: CWD: /Library/Application Support/FAHClient/work
15:05:39:WU00:FS00:0xa8:********************************************************************************
15:05:39:WU00:FS00:0xa8:Project: 16959 (Run 12, Clone 177, Gen 57)
15:05:39:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
15:05:39:WU00:FS00:0xa8:Digital signatures verified
15:05:39:WU00:FS00:0xa8:Calling: mdrun -c frame57.gro -s frame57.tpr -x frame57.xtc -cpi state.cpt -cpt 15 -nt 4 -ntmpi 1
15:05:39:WU00:FS00:0xa8:Steps: first=142500000 total=145000000
15:05:39:WU00:FS00:0xa8:Completed 1335451 out of 2500000 steps (53%)
[91m15:08:02:ERROR:Send error: 32: Broken pipe[0m
15:08:02:Caught signal SIGPIPE(13) on PID 96
15:09:01:Caught signal SIGTERM(15) on PID 96
15:09:01:Exiting, please wait. . .
15:09:02:FS00:Shutting core down
15:09:02:WU00:FS00:0xa8:Caught signal SIGINT(2) on PID 408
15:09:02:WU00:FS00:0xa8:Exiting, please wait. . .
15:09:05:Clean exit
Connecting...Inactive
Re: Connecting...Inactive
Going to suggest a couple of things
1). reinstall OpenCL, the GPU will need it to do anything for FAH.
2). backup your config.xml file, remove the FAHClient and re-install it, restore the config.xml as needed
Using Activity Monitor does the FAHClient process show as running? That needs to be running in the background for there to be something that FAHControl or Web Control can connect to.
It is possible the 11.4 update changed some permissions or network connectivity, I haven't looked at its release notes.
danISfolding4COVID19
Good Afternoon All, I did a "last" within terminal and saw that it was possible that I had not restarted after the client failed originally. MacOS 11.4 was installed 6/14/2021 at 11:15 am ET according to System Information (option apple menu, installation 'tab'), using terminal (using the last command) it appeared that I was within the same login session as was in place during the original client failure occurred. So, I restarted the MacOS (under 11.4) today and it is now running again. The chronology was as follows: upgraded to 11.4, logged in, started FAH, it failed on the first boot into 11.4, but it did not fail on the second boot into 11.4. Thank you for your responsiveness! I think we can close this one. Thanks! Dan
