nVidia RTX 3070 used to work...
PaulTV
Post by PaulTV »
Hi,
In the couple months I folded over 150M credits with an RTX 3070, but now...
*********************** Log Started 2021-06-16T15:27:23Z ***********************
15:27:23:******************************* libFAH ********************************
15:27:23:           Date: Oct 20 2020
15:27:23:           Time: 13:36:55
15:27:23:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:27:23:         Branch: master
15:27:23:       Compiler: Visual C++ 2015
15:27:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:27:23:       Platform: win32 10
15:27:23:           Bits: 32
15:27:23:           Mode: Release
15:27:23:****************************** FAHClient ******************************
15:27:23:        Version: 7.6.21
15:27:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:27:23:      Copyright: 2020 foldingathome.org
15:27:23:       Homepage: https://foldingathome.org/
15:27:23:           Time: 13:41:04
15:27:23:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:27:23:           Bits: 32
15:27:23:         Config: C:\ProgramData\FAHClient\config.xml
15:27:23:******************************** CBang ********************************
15:27:23:           Time: 11:36:18
15:27:23:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:27:23:           Bits: 32
15:27:23:******************************* System ********************************
15:27:23:            CPU: AMD Ryzen 7 5800X 8-Core Processor
15:27:23:         CPU ID: AuthenticAMD Family 25 Model 33 Stepping 0
15:27:23:           CPUs: 16
15:27:23:         Memory: 31.92GiB
15:27:23:    Free Memory: 28.33GiB
15:27:23:        Threads: WINDOWS_THREADS
15:27:23:     OS Version: 6.2
15:27:23:    Has Battery: false
15:27:23:     On Battery: false
15:27:23:     UTC Offset: 2
15:27:23:            PID: 15976
15:27:23:            CWD: C:\ProgramData\FAHClient
15:27:23:  Win32 Service: false
15:27:23:             OS: Windows 10 Home
15:27:23:        OS Arch: AMD64
15:27:23:           GPUs: 1
15:27:23:          GPU 0: Bus:6 Slot:0 Func:0 NVIDIA:1
15:27:23:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:8.6 Driver:11.2
15:27:23:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:461.40
15:27:23:***********************************************************************
15:27:23:<config>
15:27:23:  <!-- HTTP Server -->
15:27:23:  <allow v='127.0.0.1 192.168.1.0/24'/>
15:27:23:
15:27:23:  <!-- Network -->
15:27:23:  <proxy v=':8080'/>
15:27:23:
15:27:23:  <!-- Remote Command Server -->
15:27:23:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
15:27:23:  <password v='*****'/>
15:27:23:
15:27:23:  <!-- Slot Control -->
15:27:23:  <power v='full'/>
15:27:23:
15:27:23:  <!-- User Information -->
15:27:23:  <passkey v='*****'/>
15:27:23:  <team v='224497'/>
15:27:23:  <user v='Fahnatic'/>
15:27:23:
15:27:23:  <!-- Folding Slots -->
15:27:23:  <slot id='0' type='CPU'>
15:27:23:    <cpus v='14'/>
15:27:23:    <paused v='true'/>
15:27:23:  </slot>
15:27:23:  <slot id='1' type='GPU'>
15:27:23:    <pci-bus v='6'/>
15:27:23:    <pci-slot v='0'/>
15:27:23:  </slot>
15:27:23:</config>
15:27:23:Trying to access database...
15:27:23:Successfully acquired database lock
15:27:23:FS00:Initialized folding slot 00: cpu:14
15:27:23:WARNING:FS01:Disabling beta GPU slot 01: gpu:6:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
I won't be folding much right now - it's already warm enough here - but still :)
Cheers,
Paul
Ryzen 5600X / RTX 3070 Ti / Ubuntu 22.04
Ryzen 5600 / RTX 3060 Ti / Windows 11
Re: nVidia RTX 3070 used to work...
Could you provide the PCI device ID for the 3070. It is possible an edit to the GPUs.txt file inadvertently altered or removed the existing entry, and just needs to be fixed up.
PaulTV
Post by PaulTV »
Is this what you mean?
PCI\VEN_10DE&DEV_2484&SUBSYS_87B81043&REV_A1
PCI\VEN_10DE&DEV_2484&CC_030000
Taken from device manager, hardware ID's of the graphics card
That would be it. Take a look at your current copy of GPUs.txt, it should have this line in it:
0x10de:0x2484:2:8:GA104 [GeForce RTX 3070]
If it doesn't, delete your copy and restart your system to pull down a new copy. That should fix things up.
If not, may need to look into this a bit further.
PaulTV
Post by PaulTV »
My version of GPUs.txt does have that line (local modify time 2021-06-03).
Extra information, not included in the logging:
Windows 10 Home 20H2, build 19042.1052 (Dutch)
I updated the nVidia drivers to 466.77, didn't help
Windows Defender, no additional firewall / virus scanner
Last WU returned, folded using this GPU: 2021-06-13 (p18202, r16550, c4, g5)
Last Windows update installed on 2021-06-12
Hmm, definitely a head scratcher. For some reason the client did not read that entry and use it for ID'ing the 3070 at startup. I haven't seen that before, perhaps someone else has in the past and has a fix.
PaulTV
Re: nVidia RTX 3070 used to work... => working again
Post by PaulTV »
Well now... Fully uninstalled FAH (including removing data), updated Wintendo (it's a nice gaming platform after all) to 21H1, rebooted several times during all that, reinstalled FAh, and guess what... the rig is folding again, on both CPU and GPU.
