Per GPU-Z
AMD Radeon(TM) Graphics  1002 1638 - 1458 D000
*********************** Log Started 2021-06-11T20:44:34Z ***********************
20:44:34:******************************* libFAH ********************************
20:44:34:           Date: Oct 20 2020
20:44:34:           Time: 13:36:55
20:44:34:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
20:44:34:         Branch: master
20:44:34:       Compiler: Visual C++ 2015
20:44:34:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:44:34:       Platform: win32 10
20:44:34:           Bits: 32
20:44:34:           Mode: Release
20:44:34:****************************** FAHClient ******************************
20:44:34:        Version: 7.6.21
20:44:34:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:44:34:      Copyright: 2020 foldingathome.org
20:44:34:       Homepage: https://foldingathome.org/
20:44:34:           Time: 13:41:04
20:44:34:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
20:44:34:           Bits: 32
20:44:34:         Config: C:\ProgramData\FAHClient\config.xml
20:44:34:******************************** CBang ********************************
20:44:34:           Time: 11:36:18
20:44:34:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
20:44:34:           Bits: 32
20:44:34:******************************* System ********************************
20:44:34:            CPU: AMD Ryzen 7 5700G with Radeon Graphics
20:44:34:         CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
20:44:34:           CPUs: 16
20:44:34:         Memory: 31.39GiB
20:44:34:    Free Memory: 28.96GiB
20:44:34:        Threads: WINDOWS_THREADS
20:44:34:     OS Version: 6.2
20:44:34:    Has Battery: false
20:44:34:     On Battery: false
20:44:34:     UTC Offset: -4
20:44:34:            PID: 3268
20:44:34:            CWD: C:\ProgramData\FAHClient
20:44:34:  Win32 Service: false
20:44:34:             OS: Windows 10 Enterprise
20:44:34:        OS Arch: AMD64
20:44:34:           GPUs: 1
20:44:34:          GPU 0: Bus:6 Slot:0 Func:0 AMD:1
20:44:34:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:44:34:                 specified module could not be found.
20:44:34:
20:44:34:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3240.6
20:44:34:***********************************************************************
20:44:34:<config>
20:44:34:  <!-- Network -->
20:44:34:  <proxy v=':8080'/>
20:44:34:
20:44:34:  <!-- Slot Control -->
20:44:34:  <power v='FULL'/>
20:44:34:
20:44:34:  <!-- User Information -->
20:44:34:  <passkey v='*****'/>
20:44:34:  <team v='224497'/>
20:44:34:  <user v='Donald_E_Smith'/>
20:44:34:
20:44:34:  <!-- Folding Slots -->
20:44:34:  <slot id='0' type='CPU'/>
20:44:34:  <slot id='1' type='GPU'>
20:44:34:    <pci-bus v='6'/>
20:44:34:    <pci-slot v='0'/>
20:44:34:  </slot>
20:44:34:</config>
20:44:34:Trying to access database...
20:44:34:Successfully acquired database lock
20:44:34:FS00:Initialized folding slot 00: cpu:15
20:44:34:WARNING:FS01:Disabling beta GPU slot 01: gpu:6:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
20:44:34:WU01:FS00:Starting
20:44:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 3268 -checkpoint 15 -np 15
20:44:34:WU01:FS00:Started FahCore on PID 1212
20:44:34:WU01:FS00:Core PID:7552
20:44:34:WU01:FS00:FahCore 0xa8 started
20:44:35:WU01:FS00:0xa8:*********************** Log Started 2021-06-11T20:44:34Z ***********************
20:44:35:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:44:35:WU01:FS00:0xa8:       Core: Gromacs
20:44:35:WU01:FS00:0xa8:       Type: 0xa8
20:44:35:WU01:FS00:0xa8:    Version: 0.0.12
20:44:35:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:44:35:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
20:44:35:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
20:44:35:WU01:FS00:0xa8:       Date: Jan 16 2021
20:44:35:WU01:FS00:0xa8:       Time: 12:29:40
20:44:35:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:44:35:WU01:FS00:0xa8:     Branch: master
20:44:35:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:44:35:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:44:35:WU01:FS00:0xa8:   Platform: win32 10
20:44:35:WU01:FS00:0xa8:       Bits: 64
20:44:35:WU01:FS00:0xa8:       Mode: Release
20:44:35:WU01:FS00:0xa8:       SIMD: avx2_256
20:44:35:WU01:FS00:0xa8:     OpenMP: ON
20:44:35:WU01:FS00:0xa8:       CUDA: OFF
20:44:35:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1212 -checkpoint 15 -np
20:44:35:WU01:FS00:0xa8:             15
20:44:35:WU01:FS00:0xa8:************************************ libFAH ************************************
20:44:35:WU01:FS00:0xa8:       Time: 11:24:13
20:44:35:WU01:FS00:0xa8:************************************ CBang *************************************
20:44:35:WU01:FS00:0xa8:       Time: 11:23:53
20:44:35:WU01:FS00:0xa8:************************************ System ************************************
20:44:35:WU01:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
20:44:35:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
20:44:35:WU01:FS00:0xa8:       CPUs: 16
20:44:35:WU01:FS00:0xa8:     Memory: 31.39GiB
20:44:35:WU01:FS00:0xa8:Free Memory: 28.92GiB
20:44:35:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
20:44:35:WU01:FS00:0xa8: OS Version: 6.2
20:44:35:WU01:FS00:0xa8:Has Battery: false
20:44:35:WU01:FS00:0xa8: On Battery: false
20:44:35:WU01:FS00:0xa8: UTC Offset: -4
20:44:35:WU01:FS00:0xa8:        PID: 7552
20:44:35:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
20:44:35:WU01:FS00:0xa8:********************************************************************************
20:44:35:WU01:FS00:0xa8:Project: 16969 (Run 12, Clone 1447, Gen 40)
20:44:35:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:44:35:WU01:FS00:0xa8:Digital signatures verified
20:44:35:WU01:FS00:0xa8:Calling: mdrun -c frame40.gro -s frame40.tpr -x frame40.xtc -cpi state.cpt -cpt 15 -nt 15 -ntmpi 1
20:44:35:WU01:FS00:0xa8:Steps: first=100000000 total=102500000
20:44:35:WU01:FS00:0xa8:Completed 1256752 out of 2500000 steps (50%)
20:46:00:WU01:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
20:47:57:WU01:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
20:49:54:WU01:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
20:51:53:WU01:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
20:54:02:WU01:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
20:56:10:WU01:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
20:58:23:WU01:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
21:00:37:WU01:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
21:02:39:WU01:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
21:04:38:WU01:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
21:06:38:WU01:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
21:08:38:WU01:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
21:10:38:WU01:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
21:12:37:WU01:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
21:14:37:WU01:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
21:16:37:WU01:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
21:18:37:WU01:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
21:20:36:WU01:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
21:22:36:WU01:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
21:24:35:WU01:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
21:26:35:WU01:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
21:28:35:WU01:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
21:30:35:WU01:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
21:32:34:WU01:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
21:34:33:WU01:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
21:36:33:WU01:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
21:38:32:WU01:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
21:40:32:WU01:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
21:42:32:WU01:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
21:44:31:WU01:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
21:46:32:WU01:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
21:48:33:WU01:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
21:50:34:WU01:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
21:52:38:WU01:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
21:54:41:WU01:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
21:56:44:WU01:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
21:58:47:WU01:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
22:00:51:WU01:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
22:02:54:WU01:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
22:04:57:WU01:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
22:07:00:WU01:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
22:09:04:WU01:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
22:11:07:WU01:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
22:13:10:WU01:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
22:15:13:WU01:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
22:17:17:WU01:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
22:19:20:WU01:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
22:21:23:WU01:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
22:23:26:WU01:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
22:23:27:WU00:FS00:Connecting to assign1.foldingathome.org:80
22:23:27:WU00:FS00:Assigned to work server 129.32.209.205
22:23:27:WU00:FS00:Requesting new work unit for slot 00: cpu:15 from 129.32.209.205
22:23:27:WU00:FS00:Connecting to 129.32.209.205:8080
22:23:28:WU00:FS00:Downloading 1.46MiB
22:23:28:WU00:FS00:Download complete
22:23:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:16 clone:437 gen:73 core:0xa8 unit:0x000001b5000000490000423f00000010
22:25:28:WU01:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
22:25:29:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
22:25:29:WU01:FS00:0xa8:Saving result file frame40.gro
22:25:29:WU01:FS00:0xa8:Saving result file frame40.xtc
22:25:29:WU01:FS00:0xa8:Saving result file md.log
22:25:29:WU01:FS00:0xa8:Saving result file science.log
22:25:29:WU01:FS00:0xa8:Saving result file state.cpt
22:25:29:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
22:25:29:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:25:29:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16969 run:12 clone:1447 gen:40 core:0xa8 unit:0x000005a700000028000042490000000c
22:25:29:WU01:FS00:Uploading 5.14MiB to 129.32.209.205
22:25:29:WU01:FS00:Connecting to 129.32.209.205:8080
22:25:30:WU00:FS00:Starting
22:25:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 3268 -checkpoint 15 -np 15
22:25:30:WU00:FS00:Started FahCore on PID 7248
22:25:30:WU00:FS00:Core PID:7252
22:25:30:WU00:FS00:FahCore 0xa8 started
22:25:30:WU00:FS00:0xa8:*********************** Log Started 2021-06-11T22:25:30Z ***********************
22:25:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
22:25:30:WU00:FS00:0xa8:       Core: Gromacs
22:25:30:WU00:FS00:0xa8:       Type: 0xa8
22:25:30:WU00:FS00:0xa8:    Version: 0.0.12
22:25:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
22:25:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
22:25:30:WU00:FS00:0xa8:       Date: Jan 16 2021
22:25:30:WU00:FS00:0xa8:       Time: 12:29:40
22:25:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
22:25:30:WU00:FS00:0xa8:     Branch: master
22:25:30:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
22:25:30:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
22:25:30:WU00:FS00:0xa8:   Platform: win32 10
22:25:30:WU00:FS00:0xa8:       Bits: 64
22:25:30:WU00:FS00:0xa8:       Mode: Release
22:25:30:WU00:FS00:0xa8:       SIMD: avx2_256
22:25:30:WU00:FS00:0xa8:     OpenMP: ON
22:25:30:WU00:FS00:0xa8:       CUDA: OFF
22:25:30:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7248 -checkpoint 15 -np
22:25:30:WU00:FS00:0xa8:             15
22:25:30:WU00:FS00:0xa8:************************************ libFAH ************************************
22:25:30:WU00:FS00:0xa8:       Time: 11:24:13
22:25:30:WU00:FS00:0xa8:************************************ CBang *************************************
22:25:30:WU00:FS00:0xa8:       Time: 11:23:53
22:25:30:WU00:FS00:0xa8:************************************ System ************************************
22:25:30:WU00:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
22:25:30:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
22:25:30:WU00:FS00:0xa8:       CPUs: 16
22:25:30:WU00:FS00:0xa8:     Memory: 31.39GiB
22:25:30:WU00:FS00:0xa8:Free Memory: 27.58GiB
22:25:30:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
22:25:30:WU00:FS00:0xa8: OS Version: 6.2
22:25:30:WU00:FS00:0xa8:Has Battery: false
22:25:30:WU00:FS00:0xa8: On Battery: false
22:25:30:WU00:FS00:0xa8: UTC Offset: -4
22:25:30:WU00:FS00:0xa8:        PID: 7252
22:25:30:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
22:25:30:WU00:FS00:0xa8:********************************************************************************
22:25:30:WU00:FS00:0xa8:Project: 16959 (Run 16, Clone 437, Gen 73)
22:25:30:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
22:25:30:WU00:FS00:0xa8:Reading tar file core.xml
22:25:30:WU00:FS00:0xa8:Reading tar file frame73.tpr
22:25:30:WU00:FS00:0xa8:Digital signatures verified
22:25:30:WU00:FS00:0xa8:Calling: mdrun -c frame73.gro -s frame73.tpr -x frame73.xtc -cpt 15 -nt 15 -ntmpi 1
22:25:30:WU00:FS00:0xa8:Steps: first=182500000 total=185000000
22:25:30:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
22:25:35:WU01:FS00:Upload 29.17%
22:25:41:WU01:FS00:Upload 63.20%
22:25:47:WU01:FS00:Upload 97.24%
22:25:48:WU01:FS00:Upload complete
22:25:48:WU01:FS00:Server responded WORK_ACK (400)
22:25:48:WU01:FS00:Final credit estimate, 41677.00 points
22:25:48:WU01:FS00:Cleaning up
22:27:32:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
22:29:33:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
22:31:34:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
22:33:35:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
22:35:41:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
22:37:43:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
22:39:46:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
22:41:49:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
22:43:53:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
22:45:56:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
22:47:59:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
22:50:02:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
22:52:06:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
22:54:09:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
22:56:12:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
22:58:15:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
23:00:17:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
23:02:20:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
23:04:23:WU00:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
23:06:26:WU00:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
23:08:28:WU00:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
23:10:31:WU00:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
23:12:34:WU00:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
23:14:37:WU00:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
23:16:40:WU00:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
23:18:43:WU00:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
23:20:45:WU00:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
23:22:48:WU00:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
23:24:51:WU00:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
23:26:54:WU00:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
23:28:56:WU00:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
23:30:58:WU00:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
23:33:00:WU00:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
23:35:03:WU00:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
23:37:19:WU00:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
23:39:36:WU00:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
23:41:59:WU00:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
23:44:17:WU00:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
23:46:35:WU00:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
23:48:35:WU00:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
23:50:36:WU00:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
23:52:35:WU00:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
23:54:35:WU00:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
23:56:34:WU00:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
23:58:33:WU00:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
00:00:33:WU00:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
00:02:33:WU00:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
00:04:32:WU00:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
00:06:32:WU00:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
00:08:31:WU00:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
00:10:31:WU00:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
00:12:30:WU00:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
00:14:29:WU00:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
00:16:29:WU00:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
00:18:28:WU00:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
00:20:27:WU00:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
00:22:26:WU00:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
00:24:26:WU00:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
00:26:26:WU00:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
00:28:25:WU00:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
00:30:24:WU00:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
00:32:24:WU00:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
00:34:23:WU00:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
00:36:22:WU00:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
00:38:22:WU00:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
00:40:21:WU00:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
00:42:21:WU00:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
00:44:21:WU00:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
00:46:20:WU00:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
00:48:19:WU00:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
00:50:19:WU00:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
00:52:20:WU00:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
00:54:19:WU00:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
00:56:19:WU00:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
00:58:18:WU00:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
01:00:18:WU00:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
01:02:17:WU00:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
01:04:16:WU00:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
01:06:15:WU00:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
01:08:14:WU00:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
01:10:14:WU00:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
01:12:13:WU00:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
01:14:16:WU00:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
01:16:16:WU00:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
01:18:15:WU00:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
01:20:16:WU00:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
01:22:20:WU00:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
01:24:23:WU00:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
01:26:26:WU00:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
01:28:30:WU00:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
01:30:33:WU00:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
01:32:36:WU00:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
01:34:39:WU00:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
01:36:43:WU00:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
01:38:46:WU00:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
01:40:49:WU00:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
01:42:52:WU00:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
01:44:56:WU00:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
01:46:59:WU00:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
01:46:59:WU01:FS00:Connecting to assign1.foldingathome.org:80
01:47:00:WU01:FS00:Assigned to work server 129.32.209.205
01:47:00:WU01:FS00:Requesting new work unit for slot 00: cpu:15 from 129.32.209.205
01:47:00:WU01:FS00:Connecting to 129.32.209.205:8080
01:47:00:WU01:FS00:Downloading 1.47MiB
01:47:01:WU01:FS00:Download complete
01:47:01:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16959 run:36 clone:401 gen:56 core:0xa8 unit:0x00000191000000380000423f00000024
01:49:02:WU00:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
01:49:02:WU00:FS00:0xa8:Saving result file ..\logfile_01.txt
01:49:02:WU00:FS00:0xa8:Saving result file frame73.gro
01:49:02:WU00:FS00:0xa8:Saving result file frame73.xtc
01:49:02:WU00:FS00:0xa8:Saving result file md.log
01:49:02:WU00:FS00:0xa8:Saving result file science.log
01:49:02:WU00:FS00:0xa8:Saving result file state.cpt
01:49:02:WU00:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
01:49:03:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:49:03:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16959 run:16 clone:437 gen:73 core:0xa8 unit:0x000001b5000000490000423f00000010
01:49:03:WU00:FS00:Uploading 5.10MiB to 129.32.209.205
01:49:03:WU00:FS00:Connecting to 129.32.209.205:8080
01:49:03:WU01:FS00:Starting
01:49:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 3268 -checkpoint 15 -np 15
01:49:03:WU01:FS00:Started FahCore on PID 4760
01:49:03:WU01:FS00:Core PID:10592
01:49:03:WU01:FS00:FahCore 0xa8 started
01:49:03:WU01:FS00:0xa8:*********************** Log Started 2021-06-12T01:49:03Z ***********************
01:49:03:WU01:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
01:49:03:WU01:FS00:0xa8:       Core: Gromacs
01:49:03:WU01:FS00:0xa8:       Type: 0xa8
01:49:03:WU01:FS00:0xa8:    Version: 0.0.12
01:49:03:WU01:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:49:03:WU01:FS00:0xa8:  Copyright: 2020 foldingathome.org
01:49:03:WU01:FS00:0xa8:   Homepage: https://foldingathome.org/
01:49:03:WU01:FS00:0xa8:       Date: Jan 16 2021
01:49:03:WU01:FS00:0xa8:       Time: 12:29:40
01:49:03:WU01:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
01:49:03:WU01:FS00:0xa8:     Branch: master
01:49:03:WU01:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
01:49:03:WU01:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
01:49:03:WU01:FS00:0xa8:   Platform: win32 10
01:49:03:WU01:FS00:0xa8:       Bits: 64
01:49:03:WU01:FS00:0xa8:       Mode: Release
01:49:03:WU01:FS00:0xa8:       SIMD: avx2_256
01:49:03:WU01:FS00:0xa8:     OpenMP: ON
01:49:03:WU01:FS00:0xa8:       CUDA: OFF
01:49:03:WU01:FS00:0xa8:       Args: -dir 01 -suffix 01 -version 706 -lifeline 4760 -checkpoint 15 -np
01:49:03:WU01:FS00:0xa8:             15
01:49:03:WU01:FS00:0xa8:************************************ libFAH ************************************
01:49:03:WU01:FS00:0xa8:       Time: 11:24:13
01:49:03:WU01:FS00:0xa8:************************************ CBang *************************************
01:49:03:WU01:FS00:0xa8:       Time: 11:23:53
01:49:03:WU01:FS00:0xa8:************************************ System ************************************
01:49:03:WU01:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
01:49:03:WU01:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
01:49:03:WU01:FS00:0xa8:       CPUs: 16
01:49:03:WU01:FS00:0xa8:     Memory: 31.39GiB
01:49:03:WU01:FS00:0xa8:Free Memory: 27.64GiB
01:49:03:WU01:FS00:0xa8:    Threads: WINDOWS_THREADS
01:49:03:WU01:FS00:0xa8: OS Version: 6.2
01:49:03:WU01:FS00:0xa8:Has Battery: false
01:49:03:WU01:FS00:0xa8: On Battery: false
01:49:03:WU01:FS00:0xa8: UTC Offset: -4
01:49:03:WU01:FS00:0xa8:        PID: 10592
01:49:03:WU01:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
01:49:03:WU01:FS00:0xa8:********************************************************************************
01:49:03:WU01:FS00:0xa8:Project: 16959 (Run 36, Clone 401, Gen 56)
01:49:03:WU01:FS00:0xa8:Unit: 0x00000000000000000000000000000000
01:49:03:WU01:FS00:0xa8:Reading tar file core.xml
01:49:03:WU01:FS00:0xa8:Reading tar file frame56.tpr
01:49:03:WU01:FS00:0xa8:Digital signatures verified
01:49:03:WU01:FS00:0xa8:Calling: mdrun -c frame56.gro -s frame56.tpr -x frame56.xtc -cpt 15 -nt 15 -ntmpi 1
01:49:03:WU01:FS00:0xa8:Steps: first=140000000 total=142500000
01:49:03:WU01:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
01:49:09:WU00:FS00:Upload 34.34%
01:49:15:WU00:FS00:Upload 68.68%
01:49:20:WU00:FS00:Upload complete
01:49:20:WU00:FS00:Server responded WORK_ACK (400)
01:49:20:WU00:FS00:Final credit estimate, 42853.00 points
01:49:20:WU00:FS00:Cleaning up
01:51:09:WU01:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
01:53:12:WU01:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
01:55:15:WU01:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
01:57:18:WU01:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
01:59:22:WU01:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
02:01:25:WU01:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
02:03:29:WU01:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
02:05:33:WU01:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
02:07:37:WU01:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
02:09:41:WU01:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
02:11:44:WU01:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
02:13:47:WU01:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
02:15:51:WU01:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
02:17:55:WU01:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
02:19:59:WU01:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
02:22:02:WU01:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
02:24:06:WU01:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
02:26:09:WU01:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
02:28:13:WU01:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
02:30:17:WU01:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
02:32:20:WU01:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
02:34:24:WU01:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
02:36:27:WU01:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
02:38:31:WU01:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
02:40:35:WU01:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
02:42:36:WU01:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
******************************* Date: 2021-06-12 *******************************
02:44:39:WU01:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
02:46:42:WU01:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
02:48:45:WU01:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
02:50:51:WU01:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
02:52:55:WU01:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
02:54:58:WU01:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
02:57:02:WU01:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
02:59:05:WU01:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
03:01:09:WU01:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
03:03:12:WU01:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
03:05:16:WU01:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
03:07:20:WU01:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
03:09:23:WU01:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
03:11:26:WU01:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
03:13:30:WU01:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
03:15:33:WU01:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
03:17:49:WU01:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
03:20:10:WU01:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
03:22:43:WU01:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
03:25:06:WU01:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
03:27:31:WU01:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
03:29:45:WU01:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
03:32:07:WU01:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
03:34:23:WU01:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
03:36:38:WU01:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
03:38:49:WU01:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
03:41:02:WU01:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
03:43:15:WU01:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
03:45:35:WU01:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
03:47:48:WU01:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
03:50:01:WU01:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
03:52:15:WU01:FS00:0xa8:Completed 1450000 out of 2500000 steps (58%)
03:54:28:WU01:FS00:0xa8:Completed 1475000 out of 2500000 steps (59%)
03:56:41:WU01:FS00:0xa8:Completed 1500000 out of 2500000 steps (60%)
03:58:45:WU01:FS00:0xa8:Completed 1525000 out of 2500000 steps (61%)
04:00:45:WU01:FS00:0xa8:Completed 1550000 out of 2500000 steps (62%)
04:02:45:WU01:FS00:0xa8:Completed 1575000 out of 2500000 steps (63%)
04:04:45:WU01:FS00:0xa8:Completed 1600000 out of 2500000 steps (64%)
04:06:45:WU01:FS00:0xa8:Completed 1625000 out of 2500000 steps (65%)
04:08:44:WU01:FS00:0xa8:Completed 1650000 out of 2500000 steps (66%)
04:10:45:WU01:FS00:0xa8:Completed 1675000 out of 2500000 steps (67%)
04:12:44:WU01:FS00:0xa8:Completed 1700000 out of 2500000 steps (68%)
04:14:44:WU01:FS00:0xa8:Completed 1725000 out of 2500000 steps (69%)
04:16:43:WU01:FS00:0xa8:Completed 1750000 out of 2500000 steps (70%)
04:18:42:WU01:FS00:0xa8:Completed 1775000 out of 2500000 steps (71%)
04:20:42:WU01:FS00:0xa8:Completed 1800000 out of 2500000 steps (72%)
04:22:41:WU01:FS00:0xa8:Completed 1825000 out of 2500000 steps (73%)
04:24:41:WU01:FS00:0xa8:Completed 1850000 out of 2500000 steps (74%)
04:26:40:WU01:FS00:0xa8:Completed 1875000 out of 2500000 steps (75%)
04:28:40:WU01:FS00:0xa8:Completed 1900000 out of 2500000 steps (76%)
04:30:39:WU01:FS00:0xa8:Completed 1925000 out of 2500000 steps (77%)
04:32:38:WU01:FS00:0xa8:Completed 1950000 out of 2500000 steps (78%)
04:34:38:WU01:FS00:0xa8:Completed 1975000 out of 2500000 steps (79%)
04:36:36:WU01:FS00:0xa8:Completed 2000000 out of 2500000 steps (80%)
04:38:35:WU01:FS00:0xa8:Completed 2025000 out of 2500000 steps (81%)
04:40:35:WU01:FS00:0xa8:Completed 2050000 out of 2500000 steps (82%)
04:42:34:WU01:FS00:0xa8:Completed 2075000 out of 2500000 steps (83%)
04:44:34:WU01:FS00:0xa8:Completed 2100000 out of 2500000 steps (84%)
04:46:33:WU01:FS00:0xa8:Completed 2125000 out of 2500000 steps (85%)
04:48:33:WU01:FS00:0xa8:Completed 2150000 out of 2500000 steps (86%)
04:50:34:WU01:FS00:0xa8:Completed 2175000 out of 2500000 steps (87%)
04:52:33:WU01:FS00:0xa8:Completed 2200000 out of 2500000 steps (88%)
04:54:32:WU01:FS00:0xa8:Completed 2225000 out of 2500000 steps (89%)
04:56:32:WU01:FS00:0xa8:Completed 2250000 out of 2500000 steps (90%)
04:58:31:WU01:FS00:0xa8:Completed 2275000 out of 2500000 steps (91%)
05:00:54:WU01:FS00:0xa8:Completed 2300000 out of 2500000 steps (92%)
05:03:21:WU01:FS00:0xa8:Completed 2325000 out of 2500000 steps (93%)
05:05:47:WU01:FS00:0xa8:Completed 2350000 out of 2500000 steps (94%)
05:08:13:WU01:FS00:0xa8:Completed 2375000 out of 2500000 steps (95%)
05:10:27:WU01:FS00:0xa8:Completed 2400000 out of 2500000 steps (96%)
05:12:28:WU01:FS00:0xa8:Completed 2425000 out of 2500000 steps (97%)
05:14:28:WU01:FS00:0xa8:Completed 2450000 out of 2500000 steps (98%)
05:16:28:WU01:FS00:0xa8:Completed 2475000 out of 2500000 steps (99%)
05:16:29:WU00:FS00:Connecting to assign1.foldingathome.org:80
05:16:29:WU00:FS00:Assigned to work server 129.32.209.205
05:16:29:WU00:FS00:Requesting new work unit for slot 00: cpu:15 from 129.32.209.205
05:16:29:WU00:FS00:Connecting to 129.32.209.205:8080
05:16:30:WU00:FS00:Downloading 1.47MiB
05:16:30:WU00:FS00:Download complete
05:16:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16969 run:14 clone:142 gen:32 core:0xa8 unit:0x0000008e00000020000042490000000e
05:18:28:WU01:FS00:0xa8:Completed 2500000 out of 2500000 steps (100%)
05:18:29:WU01:FS00:0xa8:Saving result file ..\logfile_01.txt
05:18:29:WU01:FS00:0xa8:Saving result file frame56.gro
05:18:29:WU01:FS00:0xa8:Saving result file frame56.xtc
05:18:29:WU01:FS00:0xa8:Saving result file md.log
05:18:29:WU01:FS00:0xa8:Saving result file science.log
05:18:29:WU01:FS00:0xa8:Saving result file state.cpt
05:18:29:WU01:FS00:0xa8:Folding@home Core Shutdown: FINISHED_UNIT
05:18:29:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:18:29:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:16959 run:36 clone:401 gen:56 core:0xa8 unit:0x00000191000000380000423f00000024
05:18:29:WU01:FS00:Uploading 5.12MiB to 129.32.209.205
05:18:29:WU01:FS00:Connecting to 129.32.209.205:8080
05:18:29:WU00:FS00:Starting
05:18:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 3268 -checkpoint 15 -np 15
05:18:29:WU00:FS00:Started FahCore on PID 8960
05:18:29:WU00:FS00:Core PID:2804
05:18:29:WU00:FS00:FahCore 0xa8 started
05:18:30:WU00:FS00:0xa8:*********************** Log Started 2021-06-12T05:18:29Z ***********************
05:18:30:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
05:18:30:WU00:FS00:0xa8:       Core: Gromacs
05:18:30:WU00:FS00:0xa8:       Type: 0xa8
05:18:30:WU00:FS00:0xa8:    Version: 0.0.12
05:18:30:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:18:30:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
05:18:30:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
05:18:30:WU00:FS00:0xa8:       Date: Jan 16 2021
05:18:30:WU00:FS00:0xa8:       Time: 12:29:40
05:18:30:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
05:18:30:WU00:FS00:0xa8:     Branch: master
05:18:30:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
05:18:30:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:18:30:WU00:FS00:0xa8:   Platform: win32 10
05:18:30:WU00:FS00:0xa8:       Bits: 64
05:18:30:WU00:FS00:0xa8:       Mode: Release
05:18:30:WU00:FS00:0xa8:       SIMD: avx2_256
05:18:30:WU00:FS00:0xa8:     OpenMP: ON
05:18:30:WU00:FS00:0xa8:       CUDA: OFF
05:18:30:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 8960 -checkpoint 15 -np
05:18:30:WU00:FS00:0xa8:             15
05:18:30:WU00:FS00:0xa8:************************************ libFAH ************************************
05:18:30:WU00:FS00:0xa8:       Time: 11:24:13
05:18:30:WU00:FS00:0xa8:************************************ CBang *************************************
05:18:30:WU00:FS00:0xa8:       Time: 11:23:53
05:18:30:WU00:FS00:0xa8:************************************ System ************************************
05:18:30:WU00:FS00:0xa8:        CPU: AMD Ryzen 7 5700G with Radeon Graphics
05:18:30:WU00:FS00:0xa8:     CPU ID: AuthenticAMD Family 25 Model 80 Stepping 0
05:18:30:WU00:FS00:0xa8:       CPUs: 16
05:18:30:WU00:FS00:0xa8:     Memory: 31.39GiB
05:18:30:WU00:FS00:0xa8:Free Memory: 28.23GiB
05:18:30:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
05:18:30:WU00:FS00:0xa8: OS Version: 6.2
05:18:30:WU00:FS00:0xa8:Has Battery: false
05:18:30:WU00:FS00:0xa8: On Battery: false
05:18:30:WU00:FS00:0xa8: UTC Offset: -4
05:18:30:WU00:FS00:0xa8:        PID: 2804
05:18:30:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
05:18:30:WU00:FS00:0xa8:********************************************************************************
05:18:30:WU00:FS00:0xa8:Project: 16969 (Run 14, Clone 142, Gen 32)
05:18:30:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
05:18:30:WU00:FS00:0xa8:Reading tar file core.xml
05:18:30:WU00:FS00:0xa8:Reading tar file frame32.tpr
05:18:30:WU00:FS00:0xa8:Digital signatures verified
05:18:30:WU00:FS00:0xa8:Calling: mdrun -c frame32.gro -s frame32.tpr -x frame32.xtc -cpt 15 -nt 15 -ntmpi 1
05:18:30:WU00:FS00:0xa8:Steps: first=80000000 total=82500000
05:18:30:WU00:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
05:18:35:WU01:FS00:Upload 32.97%
05:18:41:WU01:FS00:Upload 67.16%
05:18:47:WU01:FS00:Upload complete
05:18:47:WU01:FS00:Server responded WORK_ACK (400)
05:18:47:WU01:FS00:Final credit estimate, 42254.00 points
05:18:47:WU01:FS00:Cleaning up
05:20:37:WU00:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
05:22:44:WU00:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
05:24:51:WU00:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
05:26:58:WU00:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
05:29:04:WU00:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
05:31:12:WU00:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
05:33:19:WU00:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
05:35:26:WU00:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
05:37:33:WU00:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
05:39:40:WU00:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
05:41:47:WU00:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
05:43:55:WU00:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
05:46:01:WU00:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
05:48:10:WU00:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
05:50:20:WU00:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
05:52:28:WU00:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
05:54:34:WU00:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
05:56:44:WU00:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
						Please add AMD Radeon(TM) Graphics to GPUs.txt
Re: Please add AMD Radeon(TM) Graphics to GPUs.txt
I'm closing this topic.
See the other topic on the same subject: Subject: Ryzen 5700G GPU
