edit:folding on pc lvl so those gpu;s where tested for normal use/gaming and folding. is there a way to retrieve those un/finished/ wu\s or some public log to see how many wu\s certain user has finished/failed?
cards I try to use are titan xp and 980ti when i switch cards the log also resets is there a way to retrieve older logs?
edit:when i start folding with the 980 and "forget" to finish the WU and change cards would it i be possible to finish the WU with the titan?
*********************** Log Started 2021-06-09T18:40:17Z ***********************
18:40:17:******************************* libFAH ********************************
18:40:17: Date: Oct 20 2020
18:40:17: Time: 13:36:55
18:40:17: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:40:17: Branch: master
18:40:17: Compiler: Visual C++ 2015
18:40:17: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:40:17: Platform: win32 10
18:40:17: Bits: 32
18:40:17: Mode: Release
18:40:17:****************************** FAHClient ******************************
18:40:17: Version: 7.6.21
18:40:17: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:40:17: Copyright: 2020 foldingathome.org
18:40:17: Homepage: https://foldingathome.org/
18:40:17: Time: 13:41:04
18:40:17: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:40:17: Bits: 32
18:40:17: Config: C:\ProgramData\FAHClient\config.xml
18:40:17:******************************** CBang ********************************
18:40:17: Time: 11:36:18
18:40:17: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:40:17: Bits: 32
18:40:17:******************************* System ********************************
18:40:17: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
18:40:17: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:40:17: CPUs: 8
18:40:17: Memory: 7.92GiB
18:40:17: Free Memory: 5.59GiB
18:40:17: Threads: WINDOWS_THREADS
18:40:17: OS Version: 6.2
18:40:17: Has Battery: false
18:40:17: On Battery: false
18:40:17: UTC Offset: 2
18:40:17: PID: 10296
18:40:17: CWD: C:\ProgramData\FAHClient
18:40:17: Win32 Service: false
18:40:17: OS: Windows 10 Enterprise
18:40:17: OS Arch: AMD64
18:40:17: GPUs: 1
18:40:17: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [TITAN Xp] 12150
18:40:17: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.2
18:40:17:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:460.89
18:40:17:***********************************************************************
18:40:17:<config>
18:40:17: <!-- Network -->
18:40:17: <proxy v=':8080'/>
18:40:17:
18:40:17: <!-- Slot Control -->
18:40:17: <power v='full'/>
18:40:17:
18:40:17: <!-- User Information -->
18:40:17: <passkey v='*****'/>
18:40:17: <team v='234980'/>
18:40:17: <user v='5i9at8u2pohp'/>
18:40:17:
18:40:17: <!-- Folding Slots -->
18:40:17: <slot id='1' type='GPU'>
18:40:17: <pci-bus v='1'/>
18:40:17: <pci-slot v='0'/>
18:40:17: </slot>
18:40:17:</config>
18:40:17:Trying to access database...
18:40:17:Successfully acquired database lock
18:40:17:FS01:Initialized folding slot 01: gpu:1:0 GP102 [TITAN Xp] 12150
18:40:17:WU00:FS01:Connecting to assign1.foldingathome.org:80
18:40:18:WU00:FS01:Assigned to work server 207.53.233.146
18:40:18:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP102 [TITAN Xp] 12150 from 207.53.233.146
18:40:18:WU00:FS01:Connecting to 207.53.233.146:8080
18:40:19:WU00:FS01:Downloading 6.15MiB
18:40:21:WU00:FS01:Download complete
18:40:21:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17804 run:87 clone:230 gen:32 core:0x22 unit:0x000000e6000000200000458c00000057
18:40:21:WU00:FS01:Starting
18:40:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:40:21:WU00:FS01:Started FahCore on PID 1572
18:40:21:WU00:FS01:Core PID:5836
18:40:21:WU00:FS01:FahCore 0x22 started
18:40:22:WU00:FS01:0x22:*********************** Log Started 2021-06-09T18:40:22Z ***********************
18:40:22:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:40:22:WU00:FS01:0x22: Core: Core22
18:40:22:WU00:FS01:0x22: Type: 0x22
18:40:22:WU00:FS01:0x22: Version: 0.0.13
18:40:22:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:40:22:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
18:40:22:WU00:FS01:0x22: Homepage: https://foldingathome.org/
18:40:22:WU00:FS01:0x22: Date: Sep 19 2020
18:40:22:WU00:FS01:0x22: Time: 02:35:58
18:40:22:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:40:22:WU00:FS01:0x22: Branch: core22-0.0.13
18:40:22:WU00:FS01:0x22: Compiler: Visual C++ 2015
18:40:23:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:40:23:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
18:40:23:WU00:FS01:0x22: Platform: win32 10
18:40:23:WU00:FS01:0x22: Bits: 64
18:40:23:WU00:FS01:0x22: Mode: Release
18:40:23:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:40:23:WU00:FS01:0x22: <peastman@stanford.edu>
18:40:23:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 1572 -checkpoint 15
18:40:23:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:40:23:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
18:40:23:WU00:FS01:0x22:************************************ libFAH ************************************
18:40:23:WU00:FS01:0x22: Date: Sep 7 2020
18:40:23:WU00:FS01:0x22: Time: 19:09:56
18:40:23:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:40:23:WU00:FS01:0x22: Branch: HEAD
18:40:23:WU00:FS01:0x22: Compiler: Visual C++ 2015
18:40:23:WU00:FS01:0x22:************************************ CBang *************************************
18:40:23:WU00:FS01:0x22: Time: 19:08:30
18:40:23:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:40:23:WU00:FS01:0x22:************************************ System ************************************
18:40:23:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
18:40:23:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:40:23:WU00:FS01:0x22: CPUs: 8
18:40:23:WU00:FS01:0x22: Memory: 7.92GiB
18:40:23:WU00:FS01:0x22:Free Memory: 5.19GiB
18:40:23:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:40:23:WU00:FS01:0x22: OS Version: 6.2
18:40:23:WU00:FS01:0x22:Has Battery: false
18:40:23:WU00:FS01:0x22: On Battery: false
18:40:23:WU00:FS01:0x22: UTC Offset: 2
18:40:23:WU00:FS01:0x22: PID: 5836
18:40:23:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
18:40:23:WU00:FS01:0x22:************************************ OpenMM ************************************
18:40:23:WU00:FS01:0x22: Revision: 189320d0
18:40:23:WU00:FS01:0x22:********************************************************************************
18:40:23:WU00:FS01:0x22:Project: 17804 (Run 87, Clone 230, Gen 32)
18:40:23:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:40:23:WU00:FS01:0x22:Reading tar file core.xml
18:40:23:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
18:40:23:WU00:FS01:0x22:Reading tar file state.xml.bz2
18:40:23:WU00:FS01:0x22:Reading tar file system.xml.bz2
18:40:23:WU00:FS01:0x22:Digital signatures verified
18:40:23:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:40:23:WU00:FS01:0x22:Version 0.0.13
18:40:23:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
18:40:23:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
18:40:23:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
18:40:23:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
18:40:24:WU00:FS01:0x22:There are 4 platforms available.
18:40:24:WU00:FS01:0x22:Platform 0: Reference
18:40:24:WU00:FS01:0x22:Platform 1: CPU
18:40:24:WU00:FS01:0x22:Platform 2: OpenCL
18:40:24:WU00:FS01:0x22: opencl-device 0 specified
18:40:24:WU00:FS01:0x22:Platform 3: CUDA
18:40:24:WU00:FS01:0x22: cuda-device 0 specified
18:40:29:WU00:FS01:0x22:Attempting to create CUDA context:
18:40:29:WU00:FS01:0x22: Configuring platform CUDA
18:40:35:WU00:FS01:0x22: Using CUDA and gpu 0
18:40:35:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
18:40:35:WU00:FS01:0x22:Checkpoint completed at step 0
18:40:37:FS01:Paused
18:40:37:FS01:Shutting core down
18:40:37:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 5836
18:40:37:WU00:FS01:0x22:Exiting, please wait. . .
18:40:37:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
18:40:38:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:41:18:Removing old file 'configs/config-20210607-130508.xml'
18:41:18:Saving configuration to config.xml
18:41:18:<config>
18:41:18: <!-- Network -->
18:41:18: <proxy v=':8080'/>
18:41:18:
18:41:18: <!-- Slot Control -->
18:41:18: <power v='full'/>
18:41:18:
18:41:18: <!-- User Information -->
18:41:18: <passkey v='*****'/>
18:41:18: <team v='234980'/>
18:41:18: <user v='5i9at8u2pohp'/>
18:41:18:
18:41:18: <!-- Folding Slots -->
18:41:18: <slot id='1' type='GPU'>
18:41:18: <paused v='true'/>
18:41:18: <pci-bus v='1'/>
18:41:18: <pci-slot v='0'/>
18:41:18: </slot>
18:41:18:</config>
18:41:21:FS01:Unpaused
18:41:21:WU00:FS01:Starting
18:41:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
18:41:21:WU00:FS01:Started FahCore on PID 11532
18:41:21:WU00:FS01:Core PID:12244
18:41:21:WU00:FS01:FahCore 0x22 started
18:41:22:WU00:FS01:0x22:*********************** Log Started 2021-06-09T18:41:21Z ***********************
18:41:22:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:41:22:WU00:FS01:0x22: Core: Core22
18:41:22:WU00:FS01:0x22: Type: 0x22
18:41:22:WU00:FS01:0x22: Version: 0.0.13
18:41:22:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:41:22:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
18:41:22:WU00:FS01:0x22: Homepage: https://foldingathome.org/
18:41:22:WU00:FS01:0x22: Date: Sep 19 2020
18:41:22:WU00:FS01:0x22: Time: 02:35:58
18:41:22:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
18:41:22:WU00:FS01:0x22: Branch: core22-0.0.13
18:41:22:WU00:FS01:0x22: Compiler: Visual C++ 2015
18:41:22:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
18:41:22:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
18:41:22:WU00:FS01:0x22: Platform: win32 10
18:41:22:WU00:FS01:0x22: Bits: 64
18:41:22:WU00:FS01:0x22: Mode: Release
18:41:22:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
18:41:22:WU00:FS01:0x22: <peastman@stanford.edu>
18:41:22:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 11532 -checkpoint 15
18:41:22:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
18:41:22:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
18:41:22:WU00:FS01:0x22:************************************ libFAH ************************************
18:41:22:WU00:FS01:0x22: Date: Sep 7 2020
18:41:22:WU00:FS01:0x22: Time: 19:09:56
18:41:22:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
18:41:22:WU00:FS01:0x22: Branch: HEAD
18:41:22:WU00:FS01:0x22:************************************ CBang *************************************
18:41:22:WU00:FS01:0x22: Time: 19:08:30
18:41:22:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
18:41:22:WU00:FS01:0x22:************************************ System ************************************
18:41:22:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
18:41:22:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:41:22:WU00:FS01:0x22: CPUs: 8
18:41:22:WU00:FS01:0x22: Memory: 7.92GiB
18:41:22:WU00:FS01:0x22:Free Memory: 5.09GiB
18:41:22:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:41:22:WU00:FS01:0x22: OS Version: 6.2
18:41:22:WU00:FS01:0x22:Has Battery: false
18:41:22:WU00:FS01:0x22: On Battery: false
18:41:22:WU00:FS01:0x22: UTC Offset: 2
18:41:22:WU00:FS01:0x22: PID: 12244
18:41:22:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
18:41:22:WU00:FS01:0x22:************************************ OpenMM ************************************
18:41:22:WU00:FS01:0x22: Revision: 189320d0
18:41:22:WU00:FS01:0x22:********************************************************************************
18:41:22:WU00:FS01:0x22:Project: 17804 (Run 87, Clone 230, Gen 32)
18:41:22:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
18:41:22:WU00:FS01:0x22:Digital signatures verified
18:41:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:41:22:WU00:FS01:0x22:Version 0.0.13
18:41:22:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
18:41:22:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
18:41:22:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
18:41:22:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
18:41:22:WU00:FS01:0x22:There are 4 platforms available.
18:41:22:WU00:FS01:0x22:Platform 0: Reference
18:41:22:WU00:FS01:0x22:Platform 1: CPU
18:41:22:WU00:FS01:0x22:Platform 2: OpenCL
18:41:22:WU00:FS01:0x22: opencl-device 0 specified
18:41:22:WU00:FS01:0x22:Platform 3: CUDA
18:41:22:WU00:FS01:0x22: cuda-device 0 specified
18:41:27:WU00:FS01:0x22:Attempting to create CUDA context:
18:41:27:WU00:FS01:0x22: Configuring platform CUDA
18:41:28:WU00:FS01:0x22: Using CUDA and gpu 0
18:41:29:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
18:41:29:WU00:FS01:0x22:Checkpoint completed at step 0
18:42:19:Removing old file 'configs/config-20210607-160101.xml'
18:42:19:Saving configuration to config.xml
18:42:19:<config>
18:42:19: <!-- Network -->
18:42:19: <proxy v=':8080'/>
18:42:19:
18:42:19: <!-- Slot Control -->
18:42:19: <power v='full'/>
18:42:19:
18:42:19: <!-- User Information -->
18:42:19: <passkey v='*****'/>
18:42:19: <team v='234980'/>
18:42:19: <user v='5i9at8u2pohp'/>
18:42:19:
18:42:19: <!-- Folding Slots -->
18:42:19: <slot id='1' type='GPU'>
18:42:19: <pci-bus v='1'/>
18:42:19: <pci-slot v='0'/>
18:42:19: </slot>
18:42:19:</config>
18:42:43:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
20:35:24:WU00:FS01:0x22:Checkpoint completed at step 2375000
20:36:34:WU00:FS01:0x22:Completed 2400000 out of 2500000 steps (96%)
20:37:44:WU00:FS01:0x22:Completed 2425000 out of 2500000 steps (97%)
20:38:55:WU00:FS01:0x22:Completed 2450000 out of 2500000 steps (98%)
20:40:05:WU00:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
20:40:06:WU01:FS01:Connecting to assign1.foldingathome.org:80
20:40:06:WU01:FS01:Assigned to work server 128.252.203.11
20:40:06:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 GP102 [TITAN Xp] 12150 from 128.252.203.11
20:40:06:WU01:FS01:Connecting to 128.252.203.11:8080
20:40:17:WU01:FS01:Downloading 26.55MiB
20:40:23:WU01:FS01:Download 61.69%
20:40:26:WU01:FS01:Download complete
20:40:26:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:18202 run:16290 clone:2 gen:5 core:0x22 unit:0x00000002000000050000471a00003fa2
20:41:16:WU00:FS01:0x22:Completed 2500000 out of 2500000 steps (100%)
20:41:16:WU00:FS01:0x22:Average performance: 24.4759 ns/day
20:41:16:WU00:FS01:0x22:Checkpoint completed at step 2500000
20:41:22:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:41:22:WU00:FS01:0x22:Saving result file checkpointIntegrator.xml.bz2
20:41:22:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
20:41:22:WU00:FS01:0x22:Saving result file positions.xtc
20:41:22:WU00:FS01:0x22:Saving result file science.log
20:41:22:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
20:41:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:41:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17804 run:87 clone:230 gen:32 core:0x22 unit:0x000000e6000000200000458c00000057
20:41:23:WU00:FS01:Uploading 8.61MiB to 207.53.233.146
20:41:23:WU00:FS01:Connecting to 207.53.233.146:8080
20:41:23:WU01:FS01:Starting
20:41:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
20:41:23:WU01:FS01:Started FahCore on PID 8696
20:41:23:WU01:FS01:Core PID:1132
20:41:23:WU01:FS01:FahCore 0x22 started
20:41:23:WU01:FS01:0x22:*********************** Log Started 2021-06-09T20:41:23Z ***********************
20:41:23:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:41:23:WU01:FS01:0x22: Core: Core22
20:41:23:WU01:FS01:0x22: Type: 0x22
20:41:23:WU01:FS01:0x22: Version: 0.0.13
20:41:23:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:41:23:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
20:41:23:WU01:FS01:0x22: Homepage: https://foldingathome.org/
20:41:23:WU01:FS01:0x22: Date: Sep 19 2020
20:41:23:WU01:FS01:0x22: Time: 02:35:58
20:41:23:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
20:41:23:WU01:FS01:0x22: Branch: core22-0.0.13
20:41:23:WU01:FS01:0x22: Compiler: Visual C++ 2015
20:41:23:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
20:41:23:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
20:41:23:WU01:FS01:0x22: Platform: win32 10
20:41:23:WU01:FS01:0x22: Bits: 64
20:41:23:WU01:FS01:0x22: Mode: Release
20:41:23:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
20:41:23:WU01:FS01:0x22: <peastman@stanford.edu>
20:41:23:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 8696 -checkpoint 15
20:41:23:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
20:41:23:WU01:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
20:41:23:WU01:FS01:0x22:************************************ libFAH ************************************
20:41:23:WU01:FS01:0x22: Date: Sep 7 2020
20:41:23:WU01:FS01:0x22: Time: 19:09:56
20:41:23:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
20:41:23:WU01:FS01:0x22: Branch: HEAD
20:41:23:WU01:FS01:0x22:************************************ CBang *************************************
20:41:23:WU01:FS01:0x22: Time: 19:08:30
20:41:23:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
20:41:23:WU01:FS01:0x22:************************************ System ************************************
20:41:23:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
20:41:23:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:41:23:WU01:FS01:0x22: CPUs: 8
20:41:23:WU01:FS01:0x22: Memory: 7.92GiB
20:41:23:WU01:FS01:0x22:Free Memory: 2.93GiB
20:41:23:WU01:FS01:0x22: Threads: WINDOWS_THREADS
20:41:23:WU01:FS01:0x22: OS Version: 6.2
20:41:23:WU01:FS01:0x22:Has Battery: false
20:41:23:WU01:FS01:0x22: On Battery: false
20:41:23:WU01:FS01:0x22: UTC Offset: 2
20:41:23:WU01:FS01:0x22: PID: 1132
20:41:23:WU01:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
20:41:23:WU01:FS01:0x22:************************************ OpenMM ************************************
20:41:23:WU01:FS01:0x22: Revision: 189320d0
20:41:23:WU01:FS01:0x22:********************************************************************************
20:41:23:WU01:FS01:0x22:Project: 18202 (Run 16290, Clone 2, Gen 5)
20:41:23:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
20:41:23:WU01:FS01:0x22:Reading tar file core.xml
20:41:23:WU01:FS01:0x22:Reading tar file integrator.xml
20:41:23:WU01:FS01:0x22:Reading tar file state.xml
20:41:24:WU01:FS01:0x22:Reading tar file system.xml
20:41:25:WU01:FS01:0x22:Digital signatures verified
20:41:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:41:25:WU01:FS01:0x22:Version 0.0.13
20:41:25:WU01:FS01:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
20:41:25:WU01:FS01:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
20:41:25:WU01:FS01:0x22: XTC frame write interval: 20000 steps (1.6%) [62 total]
20:41:25:WU01:FS01:0x22: Global context and integrator variables write interval: disabled
20:41:25:WU01:FS01:0x22:There are 4 platforms available.
20:41:25:WU01:FS01:0x22:Platform 0: Reference
20:41:25:WU01:FS01:0x22:Platform 1: CPU
20:41:25:WU01:FS01:0x22:Platform 2: OpenCL
20:41:25:WU01:FS01:0x22: opencl-device 0 specified
20:41:25:WU01:FS01:0x22:Platform 3: CUDA
20:41:25:WU01:FS01:0x22: cuda-device 0 specified
20:41:29:WU00:FS01:Upload 52.28%
20:41:34:WU00:FS01:Upload complete
20:41:34:WU00:FS01:Server responded WORK_ACK (400)
20:41:34:WU00:FS01:Final credit estimate, 167550.00 points
20:41:34:WU00:FS01:Cleaning up
20:41:39:WU01:FS01:0x22:Attempting to create CUDA context:
20:41:39:WU01:FS01:0x22: Configuring platform CUDA
20:41:48:WU01:FS01:0x22: Using CUDA and gpu 0
20:41:48:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
20:41:49:WU01:FS01:0x22:Checkpoint completed at step 0
20:43:44:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
20:45:38:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
20:45:40:WU01:FS01:0x22:Checkpoint completed at step 25000
20:47:34:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
20:49:29:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
20:49:31:WU01:FS01:0x22:Checkpoint completed at step 50000
20:51:25:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
20:53:19:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
20:53:22:WU01:FS01:0x22:Checkpoint completed at step 75000
20:55:16:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
20:57:10:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
20:57:13:WU01:FS01:0x22:Checkpoint completed at step 100000
20:59:07:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
21:01:01:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
21:01:03:WU01:FS01:0x22:Checkpoint completed at step 125000
21:02:58:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
21:04:52:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
21:04:54:WU01:FS01:0x22:Checkpoint completed at step 150000
21:06:49:WU01:FS01:0x22:Completed 162500 out of 1250000 steps (13%)
21:08:43:WU01:FS01:0x22:Completed 175000 out of 1250000 steps (14%)
21:08:45:WU01:FS01:0x22:Checkpoint completed at step 175000
21:10:40:WU01:FS01:0x22:Completed 187500 out of 1250000 steps (15%)
21:12:35:WU01:FS01:0x22:Completed 200000 out of 1250000 steps (16%)
21:12:37:WU01:FS01:0x22:Checkpoint completed at step 200000
21:14:31:WU01:FS01:0x22:Completed 212500 out of 1250000 steps (17%)
21:16:26:WU01:FS01:0x22:Completed 225000 out of 1250000 steps (18%)
21:16:28:WU01:FS01:0x22:Checkpoint completed at step 225000
21:18:23:WU01:FS01:0x22:Completed 237500 out of 1250000 steps (19%)
21:20:17:WU01:FS01:0x22:Completed 250000 out of 1250000 steps (20%)
21:20:19:WU01:FS01:0x22:Checkpoint completed at step 250000
21:22:14:WU01:FS01:0x22:Completed 262500 out of 1250000 steps (21%)
21:24:08:WU01:FS01:0x22:Completed 275000 out of 1250000 steps (22%)
21:24:10:WU01:FS01:0x22:Checkpoint completed at step 275000
21:26:05:WU01:FS01:0x22:Completed 287500 out of 1250000 steps (23%)
21:27:59:WU01:FS01:0x22:Completed 300000 out of 1250000 steps (24%)
21:28:02:WU01:FS01:0x22:Checkpoint completed at step 300000
21:29:56:WU01:FS01:0x22:Completed 312500 out of 1250000 steps (25%)
21:31:51:WU01:FS01:0x22:Completed 325000 out of 1250000 steps (26%)
21:31:53:WU01:FS01:0x22:Checkpoint completed at step 325000
21:33:48:WU01:FS01:0x22:Completed 337500 out of 1250000 steps (27%)
21:35:42:WU01:FS01:0x22:Completed 350000 out of 1250000 steps (28%)
21:35:44:WU01:FS01:0x22:Checkpoint completed at step 350000
21:37:39:WU01:FS01:0x22:Completed 362500 out of 1250000 steps (29%)
21:39:33:WU01:FS01:0x22:Completed 375000 out of 1250000 steps (30%)
21:39:35:WU01:FS01:0x22:Checkpoint completed at step 375000
21:41:30:WU01:FS01:0x22:Completed 387500 out of 1250000 steps (31%)
21:43:24:WU01:FS01:0x22:Completed 400000 out of 1250000 steps (32%)
21:43:27:WU01:FS01:0x22:Checkpoint completed at step 400000
21:45:21:WU01:FS01:0x22:Completed 412500 out of 1250000 steps (33%)
21:47:19:WU01:FS01:0x22:Completed 425000 out of 1250000 steps (34%)
21:47:21:WU01:FS01:0x22:Checkpoint completed at step 425000
21:49:27:WU01:FS01:0x22:Completed 437500 out of 1250000 steps (35%)
21:51:35:WU01:FS01:0x22:Completed 450000 out of 1250000 steps (36%)
21:51:38:WU01:FS01:0x22:Checkpoint completed at step 450000
21:53:45:WU01:FS01:0x22:Completed 462500 out of 1250000 steps (37%)
21:55:51:WU01:FS01:0x22:Completed 475000 out of 1250000 steps (38%)
21:55:53:WU01:FS01:0x22:Checkpoint completed at step 475000
21:57:56:WU01:FS01:0x22:Completed 487500 out of 1250000 steps (39%)
21:59:54:WU01:FS01:0x22:Completed 500000 out of 1250000 steps (40%)
21:59:57:WU01:FS01:0x22:Checkpoint completed at step 500000
22:01:57:WU01:FS01:0x22:Completed 512500 out of 1250000 steps (41%)
22:04:01:WU01:FS01:0x22:Completed 525000 out of 1250000 steps (42%)
22:04:03:WU01:FS01:0x22:Checkpoint completed at step 525000
22:04:26:18:127.0.0.1:New Web session
22:05:15:44:127.0.0.1:New Web session
22:06:11:WU01:FS01:0x22:Completed 537500 out of 1250000 steps (43%)
22:08:13:WU01:FS01:0x22:Completed 550000 out of 1250000 steps (44%)
22:08:15:WU01:FS01:0x22:Checkpoint completed at step 550000
22:10:19:WU01:FS01:0x22:Completed 562500 out of 1250000 steps (45%)
22:12:25:WU01:FS01:0x22:Completed 575000 out of 1250000 steps (46%)
22:12:27:WU01:FS01:0x22:Checkpoint completed at step 575000
22:14:32:WU01:FS01:0x22:Completed 587500 out of 1250000 steps (47%)
22:16:37:WU01:FS01:0x22:Completed 600000 out of 1250000 steps (48%)
22:16:39:WU01:FS01:0x22:Checkpoint completed at step 600000
22:18:43:WU01:FS01:0x22:Completed 612500 out of 1250000 steps (49%)
22:20:45:WU01:FS01:0x22:Completed 625000 out of 1250000 steps (50%)
22:20:48:WU01:FS01:0x22:Checkpoint completed at step 625000
22:22:47:WU01:FS01:0x22:Completed 637500 out of 1250000 steps (51%)
22:24:45:WU01:FS01:0x22:Completed 650000 out of 1250000 steps (52%)
22:24:48:WU01:FS01:0x22:Checkpoint completed at step 650000
22:26:48:WU01:FS01:0x22:Completed 662500 out of 1250000 steps (53%)
22:28:44:WU01:FS01:0x22:Completed 675000 out of 1250000 steps (54%)
22:28:47:WU01:FS01:0x22:Checkpoint completed at step 675000
22:30:46:WU01:FS01:0x22:Completed 687500 out of 1250000 steps (55%)
22:32:43:WU01:FS01:0x22:Completed 700000 out of 1250000 steps (56%)
22:32:46:WU01:FS01:0x22:Checkpoint completed at step 700000
22:34:46:WU01:FS01:0x22:Completed 712500 out of 1250000 steps (57%)
22:36:43:WU01:FS01:0x22:Completed 725000 out of 1250000 steps (58%)
22:36:45:WU01:FS01:0x22:Checkpoint completed at step 725000
22:38:45:WU01:FS01:0x22:Completed 737500 out of 1250000 steps (59%)
22:40:40:WU01:FS01:0x22:Completed 750000 out of 1250000 steps (60%)
22:40:43:WU01:FS01:0x22:Checkpoint completed at step 750000
22:42:38:WU01:FS01:0x22:Completed 762500 out of 1250000 steps (61%)
22:44:32:WU01:FS01:0x22:Completed 775000 out of 1250000 steps (62%)
22:44:35:WU01:FS01:0x22:Checkpoint completed at step 775000
22:46:32:WU01:FS01:0x22:Completed 787500 out of 1250000 steps (63%)
22:48:30:WU01:FS01:0x22:Completed 800000 out of 1250000 steps (64%)
22:48:33:WU01:FS01:0x22:Checkpoint completed at step 800000
22:50:29:WU01:FS01:0x22:Completed 812500 out of 1250000 steps (65%)
22:52:25:WU01:FS01:0x22:Completed 825000 out of 1250000 steps (66%)
22:52:28:WU01:FS01:0x22:Checkpoint completed at step 825000
22:54:24:WU01:FS01:0x22:Completed 837500 out of 1250000 steps (67%)
22:56:21:WU01:FS01:0x22:Completed 850000 out of 1250000 steps (68%)
22:56:24:WU01:FS01:0x22:Checkpoint completed at step 850000
22:58:23:WU01:FS01:0x22:Completed 862500 out of 1250000 steps (69%)
23:00:20:WU01:FS01:0x22:Completed 875000 out of 1250000 steps (70%)
23:00:23:WU01:FS01:0x22:Checkpoint completed at step 875000
23:02:21:WU01:FS01:0x22:Completed 887500 out of 1250000 steps (71%)
23:04:23:WU01:FS01:0x22:Completed 900000 out of 1250000 steps (72%)
23:04:26:WU01:FS01:0x22:Checkpoint completed at step 900000
23:06:25:WU01:FS01:0x22:Completed 912500 out of 1250000 steps (73%)
23:08:27:WU01:FS01:0x22:Completed 925000 out of 1250000 steps (74%)
23:08:30:WU01:FS01:0x22:Checkpoint completed at step 925000
23:10:32:WU01:FS01:0x22:Completed 937500 out of 1250000 steps (75%)
23:12:35:WU01:FS01:0x22:Completed 950000 out of 1250000 steps (76%)
23:12:38:WU01:FS01:0x22:Checkpoint completed at step 950000
23:14:40:WU01:FS01:0x22:Completed 962500 out of 1250000 steps (77%)
23:16:42:WU01:FS01:0x22:Completed 975000 out of 1250000 steps (78%)
23:16:45:WU01:FS01:0x22:Checkpoint completed at step 975000
23:18:47:WU01:FS01:0x22:Completed 987500 out of 1250000 steps (79%)
23:20:49:WU01:FS01:0x22:Completed 1000000 out of 1250000 steps (80%)
23:20:52:WU01:FS01:0x22:Checkpoint completed at step 1000000
23:22:54:WU01:FS01:0x22:Completed 1012500 out of 1250000 steps (81%)
23:24:56:WU01:FS01:0x22:Completed 1025000 out of 1250000 steps (82%)
23:24:58:WU01:FS01:0x22:Checkpoint completed at step 1025000
23:27:01:WU01:FS01:0x22:Completed 1037500 out of 1250000 steps (83%)
23:29:06:WU01:FS01:0x22:Completed 1050000 out of 1250000 steps (84%)
23:29:09:WU01:FS01:0x22:Checkpoint completed at step 1050000
23:31:11:WU01:FS01:0x22:Completed 1062500 out of 1250000 steps (85%)
23:33:13:WU01:FS01:0x22:Completed 1075000 out of 1250000 steps (86%)
23:33:16:WU01:FS01:0x22:Checkpoint completed at step 1075000
23:35:18:WU01:FS01:0x22:Completed 1087500 out of 1250000 steps (87%)
23:37:20:WU01:FS01:0x22:Completed 1100000 out of 1250000 steps (88%)
23:37:23:WU01:FS01:0x22:Checkpoint completed at step 1100000
23:39:25:WU01:FS01:0x22:Completed 1112500 out of 1250000 steps (89%)
23:41:27:WU01:FS01:0x22:Completed 1125000 out of 1250000 steps (90%)
23:41:30:WU01:FS01:0x22:Checkpoint completed at step 1125000
23:43:32:WU01:FS01:0x22:Completed 1137500 out of 1250000 steps (91%)
23:45:34:WU01:FS01:0x22:Completed 1150000 out of 1250000 steps (92%)
23:45:37:WU01:FS01:0x22:Checkpoint completed at step 1150000
23:47:40:WU01:FS01:0x22:Completed 1162500 out of 1250000 steps (93%)
23:49:51:WU01:FS01:0x22:Completed 1175000 out of 1250000 steps (94%)
23:49:54:WU01:FS01:0x22:Checkpoint completed at step 1175000
23:52:04:WU01:FS01:0x22:Completed 1187500 out of 1250000 steps (95%)
23:54:06:WU01:FS01:0x22:Completed 1200000 out of 1250000 steps (96%)
23:54:09:WU01:FS01:0x22:Checkpoint completed at step 1200000
23:56:16:WU01:FS01:0x22:Completed 1212500 out of 1250000 steps (97%)
23:57:41:66:127.0.0.1:New Web session
23:58:28:WU01:FS01:0x22:Completed 1225000 out of 1250000 steps (98%)
23:58:31:WU01:FS01:0x22:Checkpoint completed at step 1225000
00:00:38:WU01:FS01:0x22:Completed 1237500 out of 1250000 steps (99%)
00:00:38:WU00:FS01:Connecting to assign1.foldingathome.org:80
00:00:38:WU00:FS01:Assigned to work server 207.53.233.146
00:00:38:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP102 [TITAN Xp] 12150 from 207.53.233.146
00:00:38:WU00:FS01:Connecting to 207.53.233.146:8080
00:00:39:WU00:FS01:Downloading 6.10MiB
00:00:41:WU00:FS01:Download complete
00:00:41:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17804 run:15 clone:194 gen:70 core:0x22 unit:0x000000c2000000460000458c0000000f
00:02:47:WU01:FS01:0x22:Completed 1250000 out of 1250000 steps (100%)
00:02:47:WU01:FS01:0x22:Average performance: 13.4475 ns/day
00:02:50:WU01:FS01:0x22:Checkpoint completed at step 1250000
00:02:56:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
00:02:56:WU01:FS01:0x22:Saving result file checkpointIntegrator.xml
00:02:56:WU01:FS01:0x22:Saving result file checkpointState.xml
00:03:01:WU01:FS01:0x22:Saving result file positions.xtc
00:03:01:WU01:FS01:0x22:Saving result file science.log
00:03:01:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:03:02:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:03:02:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:18202 run:16290 clone:2 gen:5 core:0x22 unit:0x00000002000000050000471a00003fa2
00:03:03:WU01:FS01:Uploading 27.51MiB to 128.252.203.11
00:03:03:WU00:FS01:Starting
00:03:03:WU01:FS01:Connecting to 128.252.203.11:8080
00:03:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:03:03:WU00:FS01:Started FahCore on PID 14476
00:03:03:WU00:FS01:Core PID:15032
00:03:03:WU00:FS01:FahCore 0x22 started
00:03:03:WU00:FS01:0x22:*********************** Log Started 2021-06-10T00:03:03Z ***********************
00:03:03:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:03:03:WU00:FS01:0x22: Core: Core22
00:03:03:WU00:FS01:0x22: Type: 0x22
00:03:03:WU00:FS01:0x22: Version: 0.0.13
00:03:03:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:03:03:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
00:03:03:WU00:FS01:0x22: Homepage: https://foldingathome.org/
00:03:03:WU00:FS01:0x22: Date: Sep 19 2020
00:03:03:WU00:FS01:0x22: Time: 02:35:58
00:03:03:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:03:03:WU00:FS01:0x22: Branch: core22-0.0.13
00:03:03:WU00:FS01:0x22: Compiler: Visual C++ 2015
00:03:03:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:03:03:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
00:03:03:WU00:FS01:0x22: Platform: win32 10
00:03:03:WU00:FS01:0x22: Bits: 64
00:03:03:WU00:FS01:0x22: Mode: Release
00:03:03:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:03:03:WU00:FS01:0x22: <peastman@stanford.edu>
00:03:03:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 14476 -checkpoint 15
00:03:03:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:03:03:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:03:03:WU00:FS01:0x22:************************************ libFAH ************************************
00:03:03:WU00:FS01:0x22: Date: Sep 7 2020
00:03:03:WU00:FS01:0x22: Time: 19:09:56
00:03:03:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:03:03:WU00:FS01:0x22: Branch: HEAD
00:03:03:WU00:FS01:0x22:************************************ CBang *************************************
00:03:03:WU00:FS01:0x22: Time: 19:08:30
00:03:03:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:03:03:WU00:FS01:0x22:************************************ System ************************************
00:03:03:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:03:03:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:03:03:WU00:FS01:0x22: CPUs: 8
00:03:03:WU00:FS01:0x22: Memory: 7.92GiB
00:03:03:WU00:FS01:0x22:Free Memory: 2.12GiB
00:03:03:WU00:FS01:0x22: Threads: WINDOWS_THREADS
00:03:03:WU00:FS01:0x22: OS Version: 6.2
00:03:03:WU00:FS01:0x22:Has Battery: false
00:03:03:WU00:FS01:0x22: On Battery: false
00:03:03:WU00:FS01:0x22: UTC Offset: 2
00:03:03:WU00:FS01:0x22: PID: 15032
00:03:03:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
00:03:03:WU00:FS01:0x22:************************************ OpenMM ************************************
00:03:03:WU00:FS01:0x22: Revision: 189320d0
00:03:03:WU00:FS01:0x22:********************************************************************************
00:03:03:WU00:FS01:0x22:Project: 17804 (Run 15, Clone 194, Gen 70)
00:03:03:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:03:03:WU00:FS01:0x22:Reading tar file core.xml
00:03:03:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
00:03:03:WU00:FS01:0x22:Reading tar file state.xml.bz2
00:03:03:WU00:FS01:0x22:Reading tar file system.xml.bz2
00:03:03:WU00:FS01:0x22:Digital signatures verified
00:03:03:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:03:03:WU00:FS01:0x22:Version 0.0.13
00:03:03:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
00:03:03:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:03:03:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
00:03:03:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
00:03:04:WU00:FS01:0x22:There are 4 platforms available.
00:03:04:WU00:FS01:0x22:Platform 0: Reference
00:03:04:WU00:FS01:0x22:Platform 1: CPU
00:03:04:WU00:FS01:0x22:Platform 2: OpenCL
00:03:04:WU00:FS01:0x22: opencl-device 0 specified
00:03:04:WU00:FS01:0x22:Platform 3: CUDA
00:03:04:WU00:FS01:0x22: cuda-device 0 specified
00:03:09:WU01:FS01:Upload 10.91%
00:03:09:WU00:FS01:0x22:Attempting to create CUDA context:
00:03:09:WU00:FS01:0x22: Configuring platform CUDA
00:03:15:WU01:FS01:Upload 22.27%
00:03:16:WU00:FS01:0x22: Using CUDA and gpu 0
00:03:16:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
00:03:17:WU00:FS01:0x22:Checkpoint completed at step 0
00:03:21:WU01:FS01:Upload 33.63%
00:03:27:WU01:FS01:Upload 44.76%
00:03:33:WU01:FS01:Upload 56.12%
00:03:39:WU01:FS01:Upload 67.48%
00:03:45:WU01:FS01:Upload 78.62%
00:03:51:WU01:FS01:Upload 89.98%
00:04:35:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
00:04:49:WU01:FS01:Upload complete
00:04:49:WU01:FS01:Server responded WORK_ACK (400)
00:04:49:WU01:FS01:Final credit estimate, 348787.00 points
00:04:49:WU01:FS01:Cleaning up
00:05:06:FS01:Paused
00:05:06:FS01:Shutting core down
00:05:07:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 15032
00:05:07:WU00:FS01:0x22:Exiting, please wait. . .
00:05:07:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
00:05:07:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:05:37:Removing old file 'configs/config-20210607-172423.xml'
00:05:37:Saving configuration to config.xml
00:05:37:<config>
00:05:37: <!-- Network -->
00:05:37: <proxy v=':8080'/>
00:05:37:
00:05:37: <!-- Slot Control -->
00:05:37: <power v='full'/>
00:05:37:
00:05:37: <!-- User Information -->
00:05:37: <passkey v='*****'/>
00:05:37: <team v='234980'/>
00:05:37: <user v='5i9at8u2pohp'/>
00:05:37:
00:05:37: <!-- Folding Slots -->
00:05:37: <slot id='1' type='GPU'>
00:05:37: <paused v='true'/>
00:05:37: <pci-bus v='1'/>
00:05:37: <pci-slot v='0'/>
00:05:37: </slot>
00:05:37:</config>
00:12:27:FS01:Unpaused
00:12:27:WU00:FS01:Starting
00:12:27:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:12:27:WU00:FS01:Started FahCore on PID 5952
00:12:27:WU00:FS01:Core PID:13980
00:12:27:WU00:FS01:FahCore 0x22 started
00:12:27:WU00:FS01:0x22:*********************** Log Started 2021-06-10T00:12:27Z ***********************
00:12:27:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:12:27:WU00:FS01:0x22: Core: Core22
00:12:27:WU00:FS01:0x22: Type: 0x22
00:12:27:WU00:FS01:0x22: Version: 0.0.13
00:12:27:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:12:27:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
00:12:27:WU00:FS01:0x22: Homepage: https://foldingathome.org/
00:12:27:WU00:FS01:0x22: Date: Sep 19 2020
00:12:27:WU00:FS01:0x22: Time: 02:35:58
00:12:27:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:12:27:WU00:FS01:0x22: Branch: core22-0.0.13
00:12:27:WU00:FS01:0x22: Compiler: Visual C++ 2015
00:12:27:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:12:27:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
00:12:27:WU00:FS01:0x22: Platform: win32 10
00:12:27:WU00:FS01:0x22: Bits: 64
00:12:27:WU00:FS01:0x22: Mode: Release
00:12:27:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:12:27:WU00:FS01:0x22: <peastman@stanford.edu>
00:12:27:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 5952 -checkpoint 15
00:12:27:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:12:27:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:12:27:WU00:FS01:0x22:************************************ libFAH ************************************
00:12:27:WU00:FS01:0x22: Date: Sep 7 2020
00:12:27:WU00:FS01:0x22: Time: 19:09:56
00:12:27:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:12:27:WU00:FS01:0x22: Branch: HEAD
00:12:27:WU00:FS01:0x22:************************************ CBang *************************************
00:12:27:WU00:FS01:0x22: Time: 19:08:30
00:12:27:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:12:27:WU00:FS01:0x22:************************************ System ************************************
00:12:27:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:12:27:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:12:27:WU00:FS01:0x22: CPUs: 8
00:12:27:WU00:FS01:0x22: Memory: 7.92GiB
00:12:27:WU00:FS01:0x22:Free Memory: 2.82GiB
00:12:27:WU00:FS01:0x22: Threads: WINDOWS_THREADS
00:12:27:WU00:FS01:0x22: OS Version: 6.2
00:12:27:WU00:FS01:0x22:Has Battery: false
00:12:27:WU00:FS01:0x22: On Battery: false
00:12:27:WU00:FS01:0x22: UTC Offset: 2
00:12:27:WU00:FS01:0x22: PID: 13980
00:12:27:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
00:12:27:WU00:FS01:0x22:************************************ OpenMM ************************************
00:12:27:WU00:FS01:0x22: Revision: 189320d0
00:12:27:WU00:FS01:0x22:********************************************************************************
00:12:27:WU00:FS01:0x22:Project: 17804 (Run 15, Clone 194, Gen 70)
00:12:27:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:12:27:WU00:FS01:0x22:Digital signatures verified
00:12:27:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:12:27:WU00:FS01:0x22:Version 0.0.13
00:12:27:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
00:12:27:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:12:27:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
00:12:27:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
00:12:27:WU00:FS01:0x22:There are 4 platforms available.
00:12:27:WU00:FS01:0x22:Platform 0: Reference
00:12:27:WU00:FS01:0x22:Platform 1: CPU
00:12:27:WU00:FS01:0x22:Platform 2: OpenCL
00:12:27:WU00:FS01:0x22: opencl-device 0 specified
00:12:27:WU00:FS01:0x22:Platform 3: CUDA
00:12:27:WU00:FS01:0x22: cuda-device 0 specified
00:12:32:WU00:FS01:0x22:Attempting to create CUDA context:
00:12:32:WU00:FS01:0x22: Configuring platform CUDA
00:12:33:WU00:FS01:0x22: Using CUDA and gpu 0
00:12:34:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
00:12:34:WU00:FS01:0x22:Checkpoint completed at step 0
00:12:44:Removing old file 'configs/config-20210607-225145.xml'
00:12:44:Saving configuration to config.xml
00:12:44:<config>
00:12:44: <!-- Network -->
00:12:44: <proxy v=':8080'/>
00:12:44:
00:12:44: <!-- Slot Control -->
00:12:44: <power v='full'/>
00:12:44:
00:12:44: <!-- User Information -->
00:12:44: <passkey v='*****'/>
00:12:44: <team v='234980'/>
00:12:44: <user v='5i9at8u2pohp'/>
00:12:44:
00:12:44: <!-- Folding Slots -->
00:12:44: <slot id='1' type='GPU'>
00:12:44: <pci-bus v='1'/>
00:12:44: <pci-slot v='0'/>
00:12:44: </slot>
00:12:44:</config>
00:13:48:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
00:15:00:WU00:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
00:15:40:FS01:Paused
00:15:40:FS01:Shutting core down
00:15:40:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:15:47:Removing old file 'configs/config-20210607-233341.xml'
00:15:47:Saving configuration to config.xml
00:15:47:<config>
00:15:47: <!-- Network -->
00:15:47: <proxy v=':8080'/>
00:15:47:
00:15:47: <!-- Slot Control -->
00:15:47: <power v='full'/>
00:15:47:
00:15:47: <!-- User Information -->
00:15:47: <passkey v='*****'/>
00:15:47: <team v='234980'/>
00:15:47: <user v='5i9at8u2pohp'/>
00:15:47:
00:15:47: <!-- Folding Slots -->
00:15:47: <slot id='1' type='GPU'>
00:15:47: <paused v='true'/>
00:15:47: <pci-bus v='1'/>
00:15:47: <pci-slot v='0'/>
00:15:47: </slot>
00:15:47:</config>
00:30:34:FS01:Unpaused
00:30:34:WU00:FS01:Starting
00:30:34:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10296 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:30:34:WU00:FS01:Started FahCore on PID 4956
00:30:34:WU00:FS01:Core PID:14360
00:30:34:WU00:FS01:FahCore 0x22 started
00:30:34:WU00:FS01:0x22:*********************** Log Started 2021-06-10T00:30:34Z ***********************
00:30:34:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:30:34:WU00:FS01:0x22: Core: Core22
00:30:34:WU00:FS01:0x22: Type: 0x22
00:30:34:WU00:FS01:0x22: Version: 0.0.13
00:30:34:WU00:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:30:34:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
00:30:34:WU00:FS01:0x22: Homepage: https://foldingathome.org/
00:30:34:WU00:FS01:0x22: Date: Sep 19 2020
00:30:34:WU00:FS01:0x22: Time: 02:35:58
00:30:34:WU00:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:30:34:WU00:FS01:0x22: Branch: core22-0.0.13
00:30:34:WU00:FS01:0x22: Compiler: Visual C++ 2015
00:30:34:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:30:34:WU00:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
00:30:34:WU00:FS01:0x22: Platform: win32 10
00:30:34:WU00:FS01:0x22: Bits: 64
00:30:34:WU00:FS01:0x22: Mode: Release
00:30:34:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:30:34:WU00:FS01:0x22: <peastman@stanford.edu>
00:30:34:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 4956 -checkpoint 15
00:30:34:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:30:34:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
00:30:34:WU00:FS01:0x22:************************************ libFAH ************************************
00:30:34:WU00:FS01:0x22: Date: Sep 7 2020
00:30:34:WU00:FS01:0x22: Time: 19:09:56
00:30:34:WU00:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:30:34:WU00:FS01:0x22: Branch: HEAD
00:30:34:WU00:FS01:0x22:************************************ CBang *************************************
00:30:34:WU00:FS01:0x22: Time: 19:08:30
00:30:34:WU00:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:30:34:WU00:FS01:0x22:************************************ System ************************************
00:30:34:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:30:34:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:30:34:WU00:FS01:0x22: CPUs: 8
00:30:34:WU00:FS01:0x22: Memory: 7.92GiB
00:30:34:WU00:FS01:0x22:Free Memory: 3.30GiB
00:30:34:WU00:FS01:0x22: Threads: WINDOWS_THREADS
00:30:34:WU00:FS01:0x22: OS Version: 6.2
00:30:34:WU00:FS01:0x22:Has Battery: false
00:30:34:WU00:FS01:0x22: On Battery: false
00:30:34:WU00:FS01:0x22: UTC Offset: 2
00:30:34:WU00:FS01:0x22: PID: 14360
00:30:34:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
00:30:34:WU00:FS01:0x22:************************************ OpenMM ************************************
00:30:34:WU00:FS01:0x22: Revision: 189320d0
00:30:34:WU00:FS01:0x22:********************************************************************************
00:30:34:WU00:FS01:0x22:Project: 17804 (Run 15, Clone 194, Gen 70)
00:30:34:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
00:30:34:WU00:FS01:0x22:Digital signatures verified
00:30:34:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:30:34:WU00:FS01:0x22:Version 0.0.13
00:30:34:WU00:FS01:0x22: Checkpoint write interval: 125000 steps (5%) [20 total]
00:30:34:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:30:34:WU00:FS01:0x22: XTC frame write interval: 25000 steps (1%) [100 total]
00:30:34:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
00:30:34:WU00:FS01:0x22:There are 4 platforms available.
00:30:34:WU00:FS01:0x22:Platform 0: Reference
00:30:34:WU00:FS01:0x22:Platform 1: CPU
00:30:34:WU00:FS01:0x22:Platform 2: OpenCL
00:30:34:WU00:FS01:0x22: opencl-device 0 specified
00:30:34:WU00:FS01:0x22:Platform 3: CUDA
00:30:34:WU00:FS01:0x22: cuda-device 0 specified
00:30:39:WU00:FS01:0x22:Attempting to create CUDA context:
00:30:39:WU00:FS01:0x22: Configuring platform CUDA
00:30:40:WU00:FS01:0x22: Using CUDA and gpu 0
00:30:41:WU00:FS01:0x22:Completed 0 out of 2500000 steps (0%)
00:30:41:WU00:FS01:0x22:Checkpoint completed at step 0
00:31:02:Removing old file 'configs/config-20210608-094846.xml'
00:31:02:Saving configuration to config.xml
00:31:02:<config>
00:31:02: <!-- Network -->
00:31:02: <proxy v=':8080'/>
00:31:02:
00:31:02: <!-- Slot Control -->
00:31:02: <power v='full'/>
00:31:02:
00:31:02: <!-- User Information -->
00:31:02: <passkey v='*****'/>
00:31:02: <team v='234980'/>
00:31:02: <user v='5i9at8u2pohp'/>
00:31:02:
00:31:02: <!-- Folding Slots -->
00:31:02: <slot id='1' type='GPU'>
00:31:02: <pci-bus v='1'/>
00:31:02: <pci-slot v='0'/>
00:31:02: </slot>
00:31:02:</config>
00:31:52:WU00:FS01:0x22:Completed 25000 out of 2500000 steps (1%)
00:33:02:WU00:FS01:0x22:Completed 50000 out of 2500000 steps (2%)
00:34:13:WU00:FS01:0x22:Completed 75000 out of 2500000 steps (3%)
00:35:25:WU00:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
00:36:36:WU00:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
00:36:36:WU00:FS01:0x22:Checkpoint completed at step 125000
00:37:47:WU00:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
00:39:01:WU00:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
00:40:15:WU00:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
******************************* Date: 2021-06-10 *******************************
00:41:29:WU00:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
00:42:44:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
00:42:44:WU00:FS01:0x22:Checkpoint completed at step 250000
00:43:59:WU00:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
00:45:13:WU00:FS01:0x22:Completed 300000 out of 2500000 steps (12%)
