I have spent the last two hours trying to get my F@H working. It's not working on any of my pc's. It just says "update_core" at the status for all of them.
I made the firewall exeptions, I made exceptions in my anti virus.
I clicked every link that says update core (can't post links yet)
I have tried everything I can and yet the update_core status remains unchanged. Any help will be appreciated.
Windows 7
Intel® Core™ i5-4590 Processor
4GB Ram
No GPU
update_core on all devices
Re: update_core on all devices
If you have multiple devices all trying to update the core, you'll have data conflicts.
Pause FAH. Select on GPU and unpause only it. Does the update work?
When it finishes you can unpause any GPU that's using the same FAHCore. If necessary, allow the download of a second core before proceeding.
Steve12345
So I uninstalled on all but one. Still update core problem.
I don't have a gpu it's cpu only.
I can't get it to download even one core, let alone a second core. I've been struggling 3 days now.
[*********************** Log Started 2021-06-09T14:04:23Z ***********************
14:04:23:******************************* libFAH ********************************
14:04:23: Date: Oct 20 2020
14:04:23: Time: 13:36:55
14:04:23: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:04:23: Branch: master
14:04:23: Compiler: Visual C++ 2015
14:04:23: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:04:23: Platform: win32 10
14:04:23: Bits: 32
14:04:23: Mode: Release
14:04:23:****************************** FAHClient ******************************
14:04:23: Version: 7.6.21
14:04:23: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:04:23: Copyright: 2020 foldingathome.org
14:04:23: Homepage: https://foldingathome.org/
14:04:23: Time: 13:41:04
14:04:23: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:04:23: Bits: 32
14:04:23: Args: --open-web-control
14:04:23:******************************** CBang ********************************
14:04:23: Time: 11:36:18
14:04:23: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:04:23: Bits: 32
14:04:23:******************************* System ********************************
14:04:23: CPU: Intel(R) Core(TM) i5-4590S CPU @ 3.00GHz
14:04:23: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:04:23: CPUs: 4
14:04:23: Memory: 3.43GiB
14:04:23: Free Memory: 1.71GiB
14:04:23: Threads: WINDOWS_THREADS
14:04:23: OS Version: 6.1
14:04:23: Has Battery: false
14:04:23: On Battery: false
14:04:23: UTC Offset: 2
14:04:23: PID: 4780
14:04:23: CWD: C:\ProgramData\FAHClient
14:04:23:Win32 Service: false
14:04:23: OS: Windows 7 Professional
14:04:23: OS Arch: X86
14:04:23: GPUs: 0
14:04:23: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:04:23: specified module could not be found.
14:04:23:
14:04:23: OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
14:04:23:
14:04:23:***********************************************************************
14:04:23:<config>
14:04:23: <!-- Folding Slots -->
14:04:23:</config>
14:04:23:Trying to access database...
14:04:23:Successfully acquired database lock
14:04:23:FS00:Initialized folding slot 00: cpu:3
14:04:24:3:127.0.0.1:New Web session
14:05:24:Saving configuration to config.xml
14:05:24:<config>
14:05:24: <!-- Folding Slots -->
14:05:24: <slot id='0' type='CPU'/>
14:05:24:</config>
14:05:24:Set client configured
14:05:24:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:05:25:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:05:26:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:05:26:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:05:27:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:05:27:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:05:28:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:05:28:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:05:29:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:05:29:ERROR:WU00:FS00:Exception: Could not get an assignment
14:05:29:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:05:30:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:05:30:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:05:31:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:05:31:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:05:32:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:05:32:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:05:33:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:05:33:ERROR:WU00:FS00:Exception: Could not get an assignment
14:06:29:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:06:30:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
14:06:30:WU00:FS00:Connecting to assign2.foldingathome.org:80
14:06:31:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
14:06:31:WU00:FS00:Connecting to assign3.foldingathome.org:80
14:06:32:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
14:06:32:WU00:FS00:Connecting to assign4.foldingathome.org:80
14:06:33:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
14:06:33:ERROR:WU00:FS00:Exception: Could not get an assignment
14:07:26:Saving configuration to config.xml
14:07:26:<config>
14:07:26: <!-- User Information -->
14:07:26: <passkey v='*****'/>
14:07:26: <team v='234980'/>
14:07:26: <user v='034cim3fy8n8'/>
14:07:26:
14:07:26: <!-- Folding Slots -->
14:07:26: <slot id='0' type='CPU'/>
14:07:26:</config>
14:07:29:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:07:30:WU00:FS00:Assigned to work server 129.32.209.205
14:07:30:WU00:FS00:Requesting new work unit for slot 00: cpu:4 from 129.32.209.205
14:07:30:WU00:FS00:Connecting to 129.32.209.205:8080
14:07:31:WU00:FS00:Downloading 1.47MiB
14:07:34:WU00:FS00:Download complete
14:07:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16959 run:12 clone:440 gen:52 core:0xa8 unit:0x000001b8000000340000423f0000000c
14:07:35:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/32bi ... ore_a8.fah
14:07:35:WU00:FS00:Connecting to cores.foldingathome.org:80
14:07:35:ERROR:WU00:FS00:Exception: Failed reading core package header.
14:07:52:FS00:Paused
14:08:00:FS00:Unpaused
14:08:27:Saving configuration to config.xml
14:08:27:<config>
14:08:27: <!-- Slot Control -->
14:08:27: <power v='FULL'/>
14:08:27:
14:08:27: <!-- User Information -->
14:08:27: <passkey v='*****'/>
14:08:27: <team v='234980'/>
14:08:27: <user v='034cim3fy8n8'/>
14:08:27:
14:08:27: <!-- Folding Slots -->
14:08:27: <slot id='0' type='CPU'/>
14:08:27:</config>
14:08:35:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/32bi ... ore_a8.fah
14:08:35:WU00:FS00:Connecting to cores.foldingathome.org:80
14:08:35:ERROR:WU00:FS00:Exception: Failed reading core package header.
14:10:12:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/32bi ... ore_a8.fah
14:10:12:WU00:FS00:Connecting to cores.foldingathome.org:80
14:10:13:ERROR:WU00:FS00:Exception: Failed reading core package header.
14:12:49:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/32bi ... ore_a8.fah
14:12:49:WU00:FS00:Connecting to cores.foldingathome.org:80
14:12:50:ERROR:WU00:FS00:Exception: Failed reading core package header.
14:17:03:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/32bi ... ore_a8.fah
14:17:03:WU00:FS00:Connecting to cores.foldingathome.org:80
14:17:04:ERROR:WU00:FS00:Exception: Failed reading core package header.]
14:04:23: Bits: 32
14:04:23: Bits: 32
14:04:23: Bits: 32
14:04:23: CPUs: 4
14:04:23: PID: 4780
14:04:23: GPUs: 0
14:04:23:
14:04:23:
14:04:23:<config>
14:04:23:</config>
14:05:24:<config>
14:05:24:</config>
14:07:26:<config>
14:07:26:
14:07:26:</config>
14:08:27:<config>
14:08:27:
14:08:27:
14:08:27:</config>
I know Windows 7.0 is no longer supported by Microsoft (they want you to spend the $150.00 to switch to Windows 10), but when was the last time you were able to get updates for your system using their update tool?? And was it folding decently before the most recent updates that you can remember installing?
Paul
Paul
If I am reading the information in the log as it relates to the Windows OS correctly, you are running a 32-bit version of Windows 7.
I don't think there is a 32-bit version of Core_A8, and not certain of the status of one for Core_A7. F@h has been moving towards non-support of 32-bit OS's for some time, already it requires 64-bit for Linux, OS X and any GPU folding.
14:04:23: OS Arch: X86Re: update_core on all devices
They want you to spend the pennies but you don't need to. You can download an ISO and do an inplace upgrade. Over the weekend just there I upgraded a 32-bit vista laptop to 7 and then onto 10 just to get the digital licence so I could then do a clean install of 64-bit windows 10. The downside is that my ex-vista laptop is still running on a processor from 2008/2009 but it is running 64-bit windows 10.psaam0001 wrote:I know Windows 7.0 is no longer supported by Microsoft (they want you to spend the $150.00 to switch to Windows 10), but when was the last time you were able to get updates for your system using their update tool?? And was it folding decently before the most recent updates that you can remember installing?
Paul
I have done all that.
https://www.microsoft.com/en-gb/softwar ... /windows10
