can't get new wu from all assignment server
hisui
Post by hisui »
I can connect to assignment server in web browser,but I can NOT get wu from them.This situation has began in later May and lasted even now.
It usually last for several hours and automatically resolve itself.During this period I also found error message in windows system as
"schannel error event 36887 code 40 and 70 "I after some google search I doubt it has something to do with encryption transmission/message
below is error log
*********************** Log Started 2021-06-06T01:36:52Z ***********************
01:36:52:Trying to access database...
01:36:52:Successfully acquired database lock
01:36:52:Read GPUs.txt
01:36:52:Enabled folding slot 00: READY cpu:3
01:36:53:****************************** FAHClient ******************************
01:36:53:      Version: 7.6.13
01:36:53:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:36:53:    Copyright: 2020 foldingathome.org
01:36:53:     Homepage: https://foldingathome.org/
01:36:53:         Date: Apr 27 2020
01:36:53:         Time: 21:21:01
01:36:53:     Revision: 5a652817f46116b6e135503af97f18e094414e3b
01:36:53:       Branch: master
01:36:53:     Compiler: Visual C++ 2008
01:36:53:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:36:53:     Platform: win32 10
01:36:53:         Bits: 32
01:36:53:         Mode: Release
01:36:53:         Args: --open-web-control
01:36:53:       Config: E:\FAHdata\config.xml
01:36:53:******************************** CBang ********************************
01:36:53:         Date: Apr 24 2020
01:36:53:         Time: 17:07:55
01:36:53:     Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
01:36:53:         Bits: 32
01:36:53:******************************* System ********************************
01:36:53:          CPU: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz
01:36:53:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
01:36:53:         CPUs: 8
01:36:53:       Memory: 7.94GiB
01:36:53:  Free Memory: 6.50GiB
01:36:53:      Threads: WINDOWS_THREADS
01:36:53:   OS Version: 6.1
01:36:53:  Has Battery: false
01:36:53:   On Battery: false
01:36:53:   UTC Offset: 8
01:36:53:          PID: 2896
01:36:53:          CWD: E:\FAHdata
01:36:53:Win32 Service: false
01:36:53:           OS: Windows Server 2008 R2 Standard
01:36:53:      OS Arch: AMD64
01:36:53:         GPUs: 0
01:36:53:         CUDA: Not detected: cuInit() returned 999
01:36:53:       OpenCL: Not detected: clGetPlatformIDs() returned -1001
01:36:53:******************************* libFAH ********************************
01:36:53:         Date: Apr 15 2020
01:36:53:         Time: 14:53:14
01:36:53:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
01:36:53:         Bits: 32
01:36:53:***********************************************************************
01:36:53:<config>
01:36:53:  <!-- Network -->
01:36:53:  <proxy v=':8080'/>
01:36:53:
01:36:53:  <!-- Slot Control -->
01:36:53:  <power v='light'/>
01:36:53:
01:36:53:  <!-- User Information -->
01:36:53:  <passkey v='*****'/>
01:36:53:  <user v='Hisui'/>
01:36:53:
01:36:53:  <!-- Folding Slots -->
01:36:53:  <slot id='0' type='CPU'/>
01:36:53:</config>
01:36:53:WU00:FS00:Connecting to assign1.foldingathome.org:80
01:36:54:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:36:54:WU00:FS00:Connecting to assign2.foldingathome.org:80
01:36:55:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:36:55:WU00:FS00:Connecting to assign3.foldingathome.org:80
01:36:56:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:36:56:WU00:FS00:Connecting to assign4.foldingathome.org:80
01:36:57:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:36:57:ERROR:WU00:FS00:Exception: Could not get an assignment
01:36:57:WU00:FS00:Connecting to assign1.foldingathome.org:80
01:36:58:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:36:58:WU00:FS00:Connecting to assign2.foldingathome.org:80
01:36:58:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:36:58:WU00:FS00:Connecting to assign3.foldingathome.org:80
01:36:59:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:36:59:WU00:FS00:Connecting to assign4.foldingathome.org:80
01:37:00:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:37:00:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: can't get new wu from all assignment server
There has been a shortage of CPU work units since May.
That may depend on the number of CPU threads that get allocated to process the WU. I have a system with 4 CPU threads an a GPU which grabbed a new WU for 3 threads just a few minutes ago. Further reports from all of you will probably help.
Jonazz
Post by Jonazz »
bruce wrote:That may depend on the number of CPU threads that get allocated to process the WU. I have a system with 4 CPU threads an a GPU which grabbed a new WU for 3 threads just a few minutes ago. Further reports from all of you will probably help.
I experimented a bit. When I set my CPU slot to 3 cores, I have difficulties getting a new WU. When I increase it to 4 cores I get a new WU instantly.
Good. Getting an assignment with either number is a sign that everything is working. I just happened to have a CPU:3 slot request work at that time.
psaam0001
Post by psaam0001 »
@Bruce: As an experiment, I changed the number of cores in use on my Ryzen 9 (3950X), from the usual 1 physical core (2 threads) per job, to 13+ physical cores (26+ threads) per job (as I finished GPU work, I cut those 3 slots--one at a time--in preparation to update Fedora). I was getting nearly 40k+ in a 3 to 3.5 hour time frame with the a8 F@H core tasks. And there was no waiting on work for it.
We just have to be patient folks... Project's are not created overnight.
Paul
aetch
Post by aetch »
psaam0001 wrote:We just have to be patient folks... Project's are not created overnight.
Paul
The scientists usually do this during the day :wink:
Erik
Post by Erik »
I set up FAH on a new lap top and got the CPU (i7) folding but the GPU (Iris Xe) just sat there. No WUs available for this configuration was the message I got for 4 or 5 hours while I checked settings, I gave up!
gunnarre
Post by gunnarre »
Erik wrote:I set up FAH on a new lap top and got the CPU (i7) folding but the GPU (Iris Xe) just sat there.
Intel GPU folding is only experimental at the moment. You have to specifically enable it, and there's not always work available for it. More info here: viewtopic.php?p=346637
Support questions for Intel GPUs go here: viewforum.php?f=111
Erik
Post by Erik »
Thanks for the reply, I will check it out and add feed back here (It is at a remote location so will be a few weeks)
JimF
Post by JimF »
I also can't get work.
*********************** Log Started 2021-06-24T00:59:32Z ***********************
00:59:32:******************************* libFAH ********************************
00:59:32:           Date: Oct 20 2020
00:59:32:           Time: 20:36:39
00:59:32:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
00:59:32:         Branch: master
00:59:32:       Compiler: GNU 8.3.0
00:59:32:        Options: -faligned-new -std=c++11 -fsigned-char -ffunction-sections
00:59:32:                 -fdata-sections -O3 -funroll-loops -fno-pie
00:59:32:       Platform: linux2 5.8.0-1-amd64
00:59:32:           Bits: 64
00:59:32:           Mode: Release
00:59:32:****************************** FAHClient ******************************
00:59:32:        Version: 7.6.21
00:59:32:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:59:32:      Copyright: 2020 foldingathome.org
00:59:32:       Homepage: https://foldingathome.org/
00:59:32:           Time: 20:39:00
00:59:32:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
00:59:32:           Bits: 64
00:59:32:           Args: -v --chdir /var/snap/folding-at-home-fcole90/common
00:59:32:         Config: /var/snap/folding-at-home-fcole90/common/config.xml
00:59:32:******************************** CBang ********************************
00:59:32:           Time: 18:37:59
00:59:32:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
00:59:32:                 -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
00:59:32:           Bits: 64
00:59:32:******************************* System ********************************
00:59:32:            CPU: Intel(R) Core(TM) i9-10900F CPU @ 2.80GHz
00:59:32:         CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
00:59:32:           CPUs: 20
00:59:32:         Memory: 31.27GiB
00:59:32:    Free Memory: 30.20GiB
00:59:32:        Threads: POSIX_THREADS
00:59:32:     OS Version: 5.8
00:59:32:    Has Battery: false
00:59:32:     On Battery: false
00:59:32:     UTC Offset: -4
00:59:32:            PID: 987
00:59:32:            CWD: /var/snap/folding-at-home-fcole90/168
00:59:32:             OS: Linux 5.8.0-55-generic x86_64
00:59:32:        OS Arch: AMD64
00:59:32:           GPUs: 1
00:59:32:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
00:59:32:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.3
00:59:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:465.27
00:59:32:***********************************************************************
00:59:32:<config>
00:59:32:  <!-- Client Control -->
00:59:32:  <client-threads v='6'/>
00:59:32:  <cycle-rate v='4'/>
00:59:32:  <cycles v='-1'/>
00:59:32:  <disable-sleep-when-active v='true'/>
00:59:32:  <exit-when-done v='false'/>
00:59:32:  <fold-anon v='false'/>
00:59:32:  <idle-seconds v='300'/>
00:59:32:  <open-web-control v='false'/>
00:59:32:  <update-gpus-txt v='true'/>
00:59:32:
00:59:32:  <!-- Configuration -->
00:59:32:  <config-rotate v='true'/>
00:59:32:  <config-rotate-dir v='configs'/>
00:59:32:  <config-rotate-max v='16'/>
00:59:32:
00:59:32:  <!-- Debugging -->
00:59:32:  <assignment-servers>
00:59:32:    assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
00:59:32:  </assignment-servers>
00:59:32:  <auth-as v='true'/>
00:59:32:  <capture-directory v='capture'/>
00:59:32:  <capture-on-error v='false'/>
00:59:32:  <capture-packets v='false'/>
00:59:32:  <capture-requests v='false'/>
00:59:32:  <capture-responses v='false'/>
00:59:32:  <capture-sockets v='false'/>
00:59:32:  <debug-sockets v='false'/>
00:59:32:  <exception-locations v='true'/>
00:59:32:  <stack-traces v='false'/>
00:59:32:
00:59:32:  <!-- Error Handling -->
00:59:32:  <max-slot-errors v='10'/>
00:59:32:  <max-unit-errors v='5'/>
00:59:32:
00:59:32:  <!-- Folding Core -->
00:59:32:  <checkpoint v='15'/>
00:59:32:  <core-priority v='low'/>
00:59:32:  <cpu-usage v='100'/>
00:59:32:  <gpu-usage v='100'/>
00:59:32:  <no-assembly v='false'/>
00:59:32:
00:59:32:  <!-- Folding Slot Configuration -->
00:59:32:  <cause v='ANY'/>
00:59:32:  <client-subtype v='LINUX'/>
00:59:32:  <client-type v='normal'/>
00:59:32:  <cpu-species v='X86_PENTIUM_II'/>
00:59:32:  <cpu-type v='AMD64'/>
00:59:32:  <cpus v='-1'/>
00:59:32:  <disable-viz v='false'/>
00:59:32:  <gpu v='true'/>
00:59:32:  <gpu-beta v='false'/>
00:59:32:  <max-packet-size v='normal'/>
00:59:32:  <os-species v='UNKNOWN'/>
00:59:32:  <os-type v='LINUX'/>
00:59:32:  <project-key v='0'/>
00:59:32:  <smp v='true'/>
00:59:32:
00:59:32:  <!-- GUI -->
00:59:32:  <gui-enabled v='true'/>
00:59:32:
00:59:32:  <!-- HTTP Server -->
00:59:32:  <allow v='0.0.0.0/0'/>
00:59:32:  <connection-timeout v='60'/>
00:59:32:  <deny v='0/0'/>
00:59:32:  <http-addresses v='0:7396'/>
00:59:32:  <https-addresses v=''/>
00:59:32:  <max-connect-time v='900'/>
00:59:32:  <max-connections v='800'/>
00:59:32:  <max-request-length v='52428800'/>
00:59:32:  <min-connect-time v='300'/>
00:59:32:
00:59:32:  <!-- Logging -->
00:59:32:  <log v='log.txt'/>
00:59:32:  <log-color v='true'/>
00:59:32:  <log-crlf v='false'/>
00:59:32:  <log-date v='false'/>
00:59:32:  <log-date-periodically v='21600'/>
00:59:32:  <log-domain v='false'/>
00:59:32:  <log-header v='true'/>
00:59:32:  <log-level v='true'/>
00:59:32:  <log-no-info-header v='true'/>
00:59:32:  <log-redirect v='false'/>
00:59:32:  <log-rotate v='true'/>
00:59:32:  <log-rotate-dir v='logs'/>
00:59:32:  <log-rotate-max v='16'/>
00:59:32:  <log-short-level v='false'/>
00:59:32:  <log-simple-domains v='true'/>
00:59:32:  <log-thread-id v='false'/>
00:59:32:  <log-thread-prefix v='true'/>
00:59:32:  <log-time v='true'/>
00:59:32:  <log-to-screen v='true'/>
00:59:32:  <log-truncate v='false'/>
00:59:32:  <verbosity v='3'/>
00:59:32:
00:59:32:  <!-- Network -->
00:59:32:  <proxy v=':8080'/>
00:59:32:  <proxy-enable v='false'/>
00:59:32:  <proxy-pass v='*****'/>
00:59:32:  <proxy-user v=''/>
00:59:32:
00:59:32:  <!-- Process Control -->
00:59:32:  <child v='false'/>
00:59:32:  <daemon v='false'/>
00:59:32:  <fork v='false'/>
00:59:32:  <pid v='false'/>
00:59:32:  <pid-file v='FAHClient.pid'/>
00:59:32:  <respawn v='false'/>
00:59:32:  <service v='false'/>
00:59:32:
00:59:32:  <!-- Remote Command Server -->
00:59:32:  <command-address v='0.0.0.0'/>
00:59:32:  <command-allow-no-pass v='0.0.0.0/0'/>
00:59:32:  <command-deny-no-pass v='0/0'/>
00:59:32:  <command-enable v='true'/>
00:59:32:  <command-port v='36330'/>
00:59:32:
00:59:32:  <!-- Slot Control -->
00:59:32:  <auto-conf v='true'/>
00:59:32:  <idle v='false'/>
00:59:32:  <max-shutdown-wait v='60'/>
00:59:32:  <pause-on-battery v='true'/>
00:59:32:  <pause-on-start v='false'/>
00:59:32:  <paused v='false'/>
00:59:32:  <power v='medium'/>
00:59:32:
00:59:32:  <!-- User Information -->
00:59:32:  <machine-id v='0'/>
00:59:32:  <passkey v='*****'/>
00:59:32:  <team v='0'/>
00:59:32:  <user v='Jim1348'/>
00:59:32:
00:59:32:  <!-- Web Server -->
00:59:32:  <web-allow v='127.0.0.1'/>
00:59:32:  <web-deny v='0/0'/>
00:59:32:  <web-enable v='true'/>
00:59:32:
00:59:32:  <!-- Web Server Sessions -->
00:59:32:  <session-cookie v='sid'/>
00:59:32:  <session-lifetime v='86400'/>
00:59:32:  <session-timeout v='3600'/>
00:59:32:
00:59:32:  <!-- Work Unit Control -->
00:59:32:  <dump-after-deadline v='true'/>
00:59:32:  <max-queue v='16'/>
00:59:32:  <max-units v='0'/>
00:59:32:  <next-unit-percentage v='99'/>
00:59:32:  <stall-detection-enabled v='false'/>
00:59:32:  <stall-percent v='5'/>
00:59:32:  <stall-timeout v='1800'/>
00:59:32:
00:59:32:  <!-- Folding Slots -->
00:59:32:  <slot id='1' type='GPU'>
00:59:32:    <pci-bus v='1'/>
00:59:32:    <pci-slot v='0'/>
00:59:32:  </slot>
00:59:32:</config>
00:59:32:Trying to access database...
00:59:32:Successfully acquired database lock
00:59:32:FS01:Initialized folding slot 01: gpu:1:0 GP104 [GeForce GTX 1070] 6463
[91m00:59:32:ERROR:WU00:FS01:Exception: Could not get IP address for assign1.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:32:ERROR:WU00:FS01:Exception: Could not get IP address for assign2.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:32:ERROR:WU00:FS01:Exception: Could not get IP address for assign3.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:32:ERROR:WU00:FS01:Exception: Could not get IP address for assign4.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:32:ERROR:WU00:FS01:Exception: Failed to find any IP addresses for assignment servers[0m
[91m00:59:33:ERROR:WU00:FS01:Exception: Could not get IP address for assign1.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:33:ERROR:WU00:FS01:Exception: Could not get IP address for assign2.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:33:ERROR:WU00:FS01:Exception: Could not get IP address for assign3.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:33:ERROR:WU00:FS01:Exception: Could not get IP address for assign4.foldingathome.org: Temporary failure in name resolution[0m
[91m00:59:33:ERROR:WU00:FS01:Exception: Failed to find any IP addresses for assignment servers[0m
01:00:33:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m01:00:33:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
01:00:33:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m01:00:33:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
01:00:33:WU00:FS01:Connecting to assign3.foldingathome.org:80
01:00:34:WU00:FS01:Assigned to work server 128.252.203.11
01:00:34:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP104 [GeForce GTX 1070] 6463 from 128.252.203.11
01:00:34:WU00:FS01:Connecting to 128.252.203.11:8080
[91m01:01:04:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0[0m
01:02:10:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m01:02:10:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
01:02:10:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m01:02:10:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
01:02:10:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m01:02:11:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
01:02:11:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m01:02:11:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m01:02:11:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
01:04:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m01:04:47:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
01:04:47:WU00:FS01:Connecting to assign2.foldingathome.org:80
01:04:48:WU00:FS01:Assigned to work server 128.252.203.11
01:04:48:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP104 [GeForce GTX 1070] 6463 from 128.252.203.11
01:04:48:WU00:FS01:Connecting to 128.252.203.11:8080
[91m01:05:22:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0[0m
01:09:02:WU00:FS01:Connecting to assign1.foldingathome.org:80
[93m01:09:02:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration[0m
01:09:02:WU00:FS01:Connecting to assign2.foldingathome.org:80
[93m01:09:02:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration[0m
01:09:02:WU00:FS01:Connecting to assign3.foldingathome.org:80
[93m01:09:03:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration[0m
01:09:03:WU00:FS01:Connecting to assign4.foldingathome.org:80
[93m01:09:03:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration[0m
[91m01:09:03:ERROR:WU00:FS01:Exception: Could not get an assignment[0m
mgetz
Post by mgetz »
Looks like 128.252.203.11 has been given too much weight and has died again... that server is seriously problematic... first it wasn't handling stats and now it's not assigning WUs...
vmzy
Post by vmzy »
01:47:56:WU01:FS01:0x22:Completed 2475000 out of 2500000 steps (99%)
01:47:56:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:47:57:WU00:FS01:Assigned to work server 207.53.233.146
01:47:57:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP108 [GeForce MX150 (GT 1030) Max-Q] 1127 from 207.53.233.146
01:47:57:WU00:FS01:Connecting to 207.53.233.146:8080
01:47:58:ERROR:WU00:FS01:Exception: Server did not assign work unit
01:47:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:47:59:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:47:59:WU00:FS01:Connecting to assign2.foldingathome.org:80
01:48:00:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:48:00:WU00:FS01:Connecting to assign3.foldingathome.org:80
01:48:01:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:48:01:WU00:FS01:Connecting to assign4.foldingathome.org:80
01:48:02:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:48:02:ERROR:WU00:FS01:Exception: Could not get an assignment
01:48:58:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:48:59:WU00:FS01:Assigned to work server 128.252.203.11
01:48:59:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP108 [GeForce MX150 (GT 1030) Max-Q] 1127 from 128.252.203.11
01:48:59:WU00:FS01:Connecting to 128.252.203.11:8080
01:49:37:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
01:50:35:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:50:36:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:50:36:WU00:FS01:Connecting to assign2.foldingathome.org:80
01:50:37:WU00:FS01:Assigned to work server 128.252.203.11
01:50:37:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP108 [GeForce MX150 (GT 1030) Max-Q] 1127 from 128.252.203.11
01:50:37:WU00:FS01:Connecting to 128.252.203.11:8080
01:51:14:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
01:53:13:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:53:13:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:53:13:WU00:FS01:Connecting to assign2.foldingathome.org:80
01:53:14:WARNING:WU00:FS01:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
01:53:14:WU00:FS01:Connecting to assign3.foldingathome.org:80
01:53:15:WARNING:WU00:FS01:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
01:53:15:WU00:FS01:Connecting to assign4.foldingathome.org:80
01:53:16:WARNING:WU00:FS01:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
01:53:16:ERROR:WU00:FS01:Exception: Could not get an assignment
01:57:27:WU00:FS01:Connecting to assign1.foldingathome.org:80
01:57:28:WARNING:WU00:FS01:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
01:57:28:WU00:FS01:Connecting to assign2.foldingathome.org:80
01:57:29:WU00:FS01:Assigned to work server 128.252.203.11
01:57:29:WU00:FS01:Requesting new work unit for slot 01: gpu:1:0 GP108 [GeForce MX150 (GT 1030) Max-Q] 1127 from 128.252.203.11
01:57:29:WU00:FS01:Connecting to 128.252.203.11:8080
01:58:06:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
AS server keeping assign to DOWN WS server 128.252.203.11, there is no WU work for my GPU in sevral hours.
mgetz
Post by mgetz »
As of posting this serverstats is showing no GPU work units at this time. They do seem to be bursting occasional failed units back out to be retried but that's all I'm seeing right now.
NGruia
Post by NGruia »
Only solution for now "client-type beta" and a lot of cancer WU. And 40% of PPD simply gone.
