Question about points received VS points per day
burdo
Post by burdo »
Hi all,
I have recently started 'folding from home' and I have a question about the points I have actually been receiving VS the points per day which is stated, as there is a discrepancy and not sure what I am doing wrong.
If that above image doesn't work, the summary of my situation is:
Points per day: ~3,000,000
Base credit per unit: ~43,000
Estimated credit per unit: ~240,000
I have been receiving the base credit amount for a unit, but that is very different to the points per day which is noted. If I were receiving the estimated credit per unit, then it would be more in line with my 'points per day'. So it seems like I am missing out on points somewhere
Not sure I am doing something wrong or is this normal?
I have completed 43 units to date.
Thanks.
gunnarre
Re: Question about points received VS points per day
Post by gunnarre »
The estimated PPD assumes a Quick-return bonus. To be be eligible you need to have a passkey set, returned more than 10 WUs with that passkey, and return at least 80% of them. Also the WU must be returned within the Timeout - not just Expiry.
How to get a passkey: https://apps.foldingathome.org/getpasskey then enter it into your configuration.
How to check if you're eligible for the QRB: https://apps.foldingathome.org/bonus
If you're still not getting the QRB after the above, post please some logs: viewtopic.php?f=24&t=26036
As mentioned, you need to return 10 WUs with a passkey set to get the bonus. The client on your system does not have a means of checking whether your username and passkey combination has qualified for the bonus.
If you are folding under the same username as used for posting here, a total of 12 WUs have been recorded as returned under that username. The bonus lookup provided by gunnarre in the previous post shows a total of 2 WUs returned while using a passkey.
aetch
Post by aetch »
It's probably also worth noting a couple of things regarding the make up of points.
Base credit - this is the minimum points you receive for a work unit returned before the expiry date/time. The base credit wildly varies from a few hundred point to over a hundred thousand points. Summary of current projects -> https://apps.foldingathome.org/psummary
Quick return bonus (QRB) - extra points if the stars align and you complete and return the unit before the timeout.
Estimated Credit/PPD - these are just estimates based on the current workload and performance and include the QRB. These depend on a lot of factors and so should not be counted as points in the bank.
Just now my own system seems to be alternating between 3 projects (18202, 13453 and 17336), some of these units push close to 3million PPD and other drop to 2.2 million PPD. Not a complaint, just a comment - it varies.
Received points - Uh, these are the points you have actually received for work done. There are a number of tools across various websites for tracking this. Personally, I recommend Extreme overclocking -> https://folding.extremeoverclocking.com
Deadlines - There are two deadlines for returning completed work units.
Timeout - this is the first major checkpoint. You can receive bonus points up to the point. At this point the unit is reassigned to someone else to ensure science progresses.
Expiry - Up to this point your contribution still has some value either in who returns it first (you or your replacement) and/or as a double check of the results. I believe this is the point where the unit is deemed worthless and is dumped (I've never seen it happen but that's what I've been lead to believe).
