RX 6900 XT Update
mavutt
RX 6900 XT Update
Post by mavutt »
GPU-Z shows the card name to be AMD Radeon RX 6900 XT, Device ID 1002 73AF - 1DA2 F440.
Gpus.txt shows the 73bf, 73c3 73df, and 73ff, but not the 73AF that I have.
*********************** Log Started 2021-05-25T06:29:48Z ***********************
06:29:48:******************************* libFAH ********************************
06:29:48:           Date: Oct 20 2020
06:29:48:           Time: 13:36:55
06:29:48:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
06:29:48:         Branch: master
06:29:48:       Compiler: Visual C++ 2015
06:29:48:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
06:29:48:       Platform: win32 10
06:29:48:           Bits: 32
06:29:48:           Mode: Release
06:29:48:****************************** FAHClient ******************************
06:29:48:        Version: 7.6.21
06:29:48:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:29:48:      Copyright: 2020 foldingathome.org
06:29:48:       Homepage: https://foldingathome.org/
06:29:48:           Time: 13:41:04
06:29:48:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
06:29:48:           Bits: 32
06:29:48:           Args: --open-web-control
06:29:48:         Config: C:\ProgramData\FAHClient\config.xml
06:29:48:******************************** CBang ********************************
06:29:48:           Time: 11:36:18
06:29:48:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
06:29:48:           Bits: 32
06:29:48:******************************* System ********************************
06:29:48:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
06:29:48:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
06:29:48:           CPUs: 16
06:29:48:         Memory: 31.93GiB
06:29:48:    Free Memory: 25.39GiB
06:29:48:        Threads: WINDOWS_THREADS
06:29:48:     OS Version: 6.2
06:29:48:    Has Battery: false
06:29:48:     On Battery: false
06:29:48:     UTC Offset: -4
06:29:48:            PID: 3236
06:29:48:            CWD: C:\ProgramData\FAHClient
06:29:48:  Win32 Service: false
06:29:48:             OS: Windows 10 Home
06:29:48:        OS Arch: AMD64
06:29:48:           GPUs: 1
06:29:48:          GPU 0: Bus:3 Slot:0 Func:0 AMD:1
06:29:48:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:29:48:                 specified module could not be found.
06:29:48:
06:29:48:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3240.6
06:29:48:***********************************************************************
06:29:48:<config>
06:29:48:  <!-- Network -->
06:29:48:  <proxy v=':8080'/>
06:29:48:
06:29:48:  <!-- Slot Control -->
06:29:48:  <pause-on-battery v='false'/>
06:29:48:  <power v='FULL'/>
06:29:48:
06:29:48:  <!-- User Information -->
06:29:48:  <passkey v='*****'/>
06:29:48:  <team v='226715'/>
06:29:48:  <user v='DJfCZPFxVokzAzHXEGvmjNBRDmis3xBjyr'/>
06:29:48:
06:29:48:  <!-- Folding Slots -->
06:29:48:  <slot id='0' type='CPU'/>
06:29:48:  <slot id='2' type='GPU'/>
06:29:48:</config>
06:29:48:Trying to access database...
06:29:48:Successfully acquired database lock
06:29:48:FS00:Initialized folding slot 00: cpu:15
06:29:48:WARNING:FS02:Disabling beta GPU slot 02: gpu:3:0.  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
06:29:48:WU00:FS00:Connecting to assign1.foldingathome.org:80
06:29:48:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:29:48:WU00:FS00:Connecting to assign2.foldingathome.org:80
06:29:49:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:29:49:WU00:FS00:Connecting to assign3.foldingathome.org:80
06:29:49:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:29:49:WU00:FS00:Connecting to assign4.foldingathome.org:80
06:29:49:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:29:49:ERROR:WU00:FS00:Exception: Could not get an assignment
06:29:49:3:127.0.0.1:New Web session
06:29:49:WU00:FS00:Connecting to assign1.foldingathome.org:80
06:29:49:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:29:49:WU00:FS00:Connecting to assign2.foldingathome.org:80
06:29:50:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:29:50:WU00:FS00:Connecting to assign4.foldingathome.org:80
06:29:50:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:29:50:ERROR:WU00:FS00:Exception: Could not get an assignment
06:30:49:Saving configuration to config.xml
06:30:49:<config>
06:30:49:  <!-- Network -->
06:30:49:  <proxy v=':8080'/>
06:30:49:
06:30:49:  <!-- Slot Control -->
06:30:49:  <pause-on-battery v='false'/>
06:30:49:  <power v='FULL'/>
06:30:49:
06:30:49:  <!-- User Information -->
06:30:49:  <passkey v='*****'/>
06:30:49:  <team v='226715'/>
06:30:49:  <user v='DJfCZPFxVokzAzHXEGvmjNBRDmis3xBjyr'/>
06:30:49:
06:30:49:  <!-- Folding Slots -->
06:30:49:  <slot id='0' type='CPU'/>
06:30:49:  <slot id='2' type='GPU'>
06:30:49:    <pci-bus v='3'/>
06:30:49:    <pci-slot v='0'/>
06:30:49:  </slot>
06:30:49:</config>
06:30:49:WU00:FS00:Connecting to assign1.foldingathome.org:80
06:30:49:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
06:30:49:WU00:FS00:Connecting to assign2.foldingathome.org:80
06:30:49:WARNING:WU00:FS00:Failed to get assignment from 'assign2.foldingathome.org:80': No WUs available for this configuration
06:30:49:WU00:FS00:Connecting to assign3.foldingathome.org:80
06:30:50:WARNING:WU00:FS00:Failed to get assignment from 'assign3.foldingathome.org:80': No WUs available for this configuration
06:30:50:WU00:FS00:Connecting to assign4.foldingathome.org:80
06:30:50:WARNING:WU00:FS00:Failed to get assignment from 'assign4.foldingathome.org:80': No WUs available for this configuration
06:30:50:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: RX 6900 XT Update
Fixed.
It should be distributable in a few minutes.
If your GPU still does not start, Delete GPUs.txt from your PC, and F@H will download a new version. Otherwise it updates once a month.
mavutt
Post by mavutt »
Thank you for the speedy update. The updated GPUs.txt resolved the issue.
Thank you for letting us know it was resolved!
