remote access
Forcinghavok
remote access
Post by Forcinghavok »
Where is setup guide to setup remote access? I can't seem to find it. Thank you.
PaulTV
Re: remote access
Post by PaulTV »
Hi,
Do you mean use FAHControl to access a client on another machine? Some hints:
https://linustechtips.com/topic/990176- ... ahcontrol/
viewtopic.php?f=61&t=30563
Found by
https://www.google.com/search?client=fi ... er+machine
Be aware that if you change the remote access settings on a client, it must be restarted, otherwise the new settings won't be activated. Sometimes I used to have issues restarting the client on a Linux box, so I restarted the entire box instead.
