Expiration of proj 13448 is too short for a Radeon R7 M370
takino
Post by takino »
Expiration of Project 13448 is 2.00days,but my Radeon R7 M370(on Thinkpad E560) requires 3.27days for complete this project,even if CPU's folding is all off and set Folding@home Client "full".
For this reason,my computer can NOT complete project,but Folding@home Client get same project,EVERY MANY TIMES.
It's wasteful.
I want to don't assign Project 13448 to Radeon R7 M370,or give more long Expiraion.
Please teach me,what should I do?
*)Now,my Folding@home Client(FAHClient.exe) misrecognize that my GPU is Radeon HD 8600/8700M Series).
Re: Expiration of project 13448 is too short.
please post the log per the instructions below:
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/r ... m370.c2695
The good news is that his card meets the minimum prerequisites needed by F@H.
It supports both OpenCL 1.2 and 64 Floating Point math. (Double Precision)
However is is slow, so while it can start, it may not finish. It is about 2/3 the speed of a GT 1030, the slowest card that finishes all Work Units.
Project 13448 are intentionally complex, designed for wide GPUs (NVIDIA GPUSpecies >5; AMD GPUSpecies >=5)
Project 13449 are much simpler, designed for narrow GPUs (NVIDIA GPUSpecies <=5; AMD GPUSpecies <5; Intel GPUSpecies <5)
Those species limitations are supposed to allow everybody to finish the WUs. What is the speed of the PCIe connection?
Those choices probably still need some tuning up.
takino
Re: Expiration of proj 13448 is too short for a Radeon R7 M3
Post by takino »
******************************* Date: 2021-05-20 *******************************
01:46:01:FS02:Unpaused
01:46:01:WU01:FS02:Starting
01:46:01:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9468 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
01:46:01:WU01:FS02:Started FahCore on PID 8460
01:46:01:WU01:FS02:Core PID:8612
01:46:01:WU01:FS02:FahCore 0x22 started
01:46:02:WU01:FS02:0x22:*********************** Log Started 2021-05-21T01:46:01Z ***********************
01:46:02:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
01:46:02:WU01:FS02:0x22:       Core: Core22
01:46:02:WU01:FS02:0x22:       Type: 0x22
01:46:02:WU01:FS02:0x22:    Version: 0.0.13
01:46:02:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:46:02:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
01:46:02:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
01:46:02:WU01:FS02:0x22:       Date: Sep 19 2020
01:46:02:WU01:FS02:0x22:       Time: 02:35:58
01:46:02:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
01:46:02:WU01:FS02:0x22:     Branch: core22-0.0.13
01:46:02:WU01:FS02:0x22:   Compiler: Visual C++ 2015
01:46:02:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:46:02:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
01:46:02:WU01:FS02:0x22:   Platform: win32 10
01:46:02:WU01:FS02:0x22:       Bits: 64
01:46:02:WU01:FS02:0x22:       Mode: Release
01:46:02:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:46:02:WU01:FS02:0x22:             <peastman@stanford.edu>
01:46:02:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 8460 -checkpoint 15
01:46:02:WU01:FS02:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
01:46:02:WU01:FS02:0x22:             -gpu-usage 100
01:46:02:WU01:FS02:0x22:************************************ libFAH ************************************
01:46:02:WU01:FS02:0x22:       Date: Sep 7 2020
01:46:02:WU01:FS02:0x22:       Time: 19:09:56
01:46:02:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
01:46:02:WU01:FS02:0x22:     Branch: HEAD
01:46:02:WU01:FS02:0x22:************************************ CBang *************************************
01:46:02:WU01:FS02:0x22:       Time: 19:08:30
01:46:02:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
01:46:02:WU01:FS02:0x22:************************************ System ************************************
01:46:02:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
01:46:02:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
01:46:02:WU01:FS02:0x22:       CPUs: 4
01:46:02:WU01:FS02:0x22:     Memory: 15.89GiB
01:46:02:WU01:FS02:0x22:Free Memory: 10.67GiB
01:46:02:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
01:46:02:WU01:FS02:0x22: OS Version: 6.2
01:46:02:WU01:FS02:0x22:Has Battery: true
01:46:02:WU01:FS02:0x22: On Battery: false
01:46:02:WU01:FS02:0x22: UTC Offset: 9
01:46:02:WU01:FS02:0x22:        PID: 8612
01:46:02:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
01:46:02:WU01:FS02:0x22:************************************ OpenMM ************************************
01:46:02:WU01:FS02:0x22:   Revision: 189320d0
01:46:02:WU01:FS02:0x22:********************************************************************************
01:46:02:WU01:FS02:0x22:Project: 13448 (Run 1125, Clone 17, Gen 1)
01:46:02:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
01:46:02:WU01:FS02:0x22:Digital signatures verified
01:46:02:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
01:46:02:WU01:FS02:0x22:Version 0.0.13
01:46:03:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
01:46:03:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
01:46:03:WU01:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
01:46:03:WU01:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
01:46:03:WU01:FS02:0x22:There are 3 platforms available.
01:46:03:WU01:FS02:0x22:Platform 0: Reference
01:46:03:WU01:FS02:0x22:Platform 1: CPU
01:46:03:WU01:FS02:0x22:Platform 2: OpenCL
01:46:03:WU01:FS02:0x22:  opencl-device 0 specified
01:46:23:WU01:FS02:0x22:Attempting to create OpenCL context:
01:46:23:WU01:FS02:0x22:  Configuring platform OpenCL
01:46:44:FS02:Paused
01:46:44:FS02:Shutting core down
01:46:44:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 8612
01:46:44:WU01:FS02:0x22:Exiting, please wait. . .
01:46:49:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
01:48:33:FS02:Unpaused
01:48:33:WU01:FS02:Starting
01:48:34:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9468 -checkpoint 15 -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
01:48:34:WU01:FS02:Started FahCore on PID 10852
01:48:34:WU01:FS02:Core PID:11516
01:48:34:WU01:FS02:FahCore 0x22 started
01:48:34:WU01:FS02:0x22:*********************** Log Started 2021-05-21T01:48:34Z ***********************
01:48:34:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
01:48:34:WU01:FS02:0x22:       Core: Core22
01:48:34:WU01:FS02:0x22:       Type: 0x22
01:48:34:WU01:FS02:0x22:    Version: 0.0.13
01:48:34:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:48:34:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
01:48:34:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
01:48:34:WU01:FS02:0x22:       Date: Sep 19 2020
01:48:34:WU01:FS02:0x22:       Time: 02:35:58
01:48:34:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
01:48:34:WU01:FS02:0x22:     Branch: core22-0.0.13
01:48:34:WU01:FS02:0x22:   Compiler: Visual C++ 2015
01:48:34:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:48:34:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
01:48:34:WU01:FS02:0x22:   Platform: win32 10
01:48:34:WU01:FS02:0x22:       Bits: 64
01:48:34:WU01:FS02:0x22:       Mode: Release
01:48:34:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:48:34:WU01:FS02:0x22:             <peastman@stanford.edu>
01:48:34:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10852 -checkpoint 15
01:48:34:WU01:FS02:0x22:             -opencl-platform 1 -opencl-device 0 -gpu-vendor amd -gpu 0
01:48:34:WU01:FS02:0x22:             -gpu-usage 100
01:48:34:WU01:FS02:0x22:************************************ libFAH ************************************
01:48:34:WU01:FS02:0x22:       Date: Sep 7 2020
01:48:34:WU01:FS02:0x22:       Time: 19:09:56
01:48:34:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
01:48:34:WU01:FS02:0x22:     Branch: HEAD
01:48:34:WU01:FS02:0x22:************************************ CBang *************************************
01:48:34:WU01:FS02:0x22:       Time: 19:08:30
01:48:34:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
01:48:34:WU01:FS02:0x22:************************************ System ************************************
01:48:34:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
01:48:34:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
01:48:34:WU01:FS02:0x22:       CPUs: 4
01:48:34:WU01:FS02:0x22:     Memory: 15.89GiB
01:48:34:WU01:FS02:0x22:Free Memory: 10.71GiB
01:48:34:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
01:48:34:WU01:FS02:0x22: OS Version: 6.2
01:48:34:WU01:FS02:0x22:Has Battery: true
01:48:34:WU01:FS02:0x22: On Battery: false
01:48:34:WU01:FS02:0x22: UTC Offset: 9
01:48:34:WU01:FS02:0x22:        PID: 11516
01:48:34:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
01:48:34:WU01:FS02:0x22:************************************ OpenMM ************************************
01:48:34:WU01:FS02:0x22:   Revision: 189320d0
01:48:34:WU01:FS02:0x22:********************************************************************************
01:48:34:WU01:FS02:0x22:Project: 13448 (Run 1125, Clone 17, Gen 1)
01:48:34:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
01:48:34:WU01:FS02:0x22:Digital signatures verified
01:48:34:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
01:48:34:WU01:FS02:0x22:Version 0.0.13
01:48:34:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
01:48:34:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
01:48:34:WU01:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
01:48:34:WU01:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
01:48:34:WU01:FS02:0x22:There are 3 platforms available.
01:48:34:WU01:FS02:0x22:Platform 0: Reference
01:48:34:WU01:FS02:0x22:Platform 1: CPU
01:48:34:WU01:FS02:0x22:Platform 2: OpenCL
01:48:34:WU01:FS02:0x22:  opencl-device 0 specified
01:48:49:WU01:FS02:0x22:Attempting to create OpenCL context:
01:48:49:WU01:FS02:0x22:  Configuring platform OpenCL
01:49:29:WU01:FS02:0x22:  Using OpenCL on platformId 1 and gpu 0
01:49:29:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
01:49:30:WU01:FS02:0x22:Checkpoint completed at step 0
02:33:12:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
takino
Post by takino »
And GPU-Z 2.39.0 displays
Bus Interface "PCIe x8 2.0 @ x4 2.0"
Bus Width "128bit"
Memory Size "2048MB"
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
In theory the card is about the same speed as my 2400G. I'm finishing work units in 20-21 hours with the graphics slightly overclocked. Stock clocks might be lucky to meet the timeout, but should meet the deadline with no issues. It does seem to use a little more graphics memory than some WU's, but not really crazy high or anything.
Do you have any way of checking the clocks and such on the card? That frame time that is showing indicates that the card is running really slow.... much slower than it should IMHO. I would think they should be in the 13-14 minute range at most. Are the frame times consistent when you do let a WU try to keep running?
Fold them if you get them!
MeeLee
Post by MeeLee »
So no longer the GT 730?
