DOGE wallet key
gwynivar
DOGE wallet key
Post by gwynivar »
Be gentle with me, I am new to all of this. If I understand correctly, the random string of characters created by my wallet/qr code, are supposed to be my 'name' when I set things up. If thats correct, I did that several days ago... got a bunch of points etc, but never received any payout. Now I see my 'code' is no longer the same as whats in my wallet. The wallet says specifically that it will change when there is a transaction, but I don't have any transactions. I updated my F@H name with the new code, and of course my points are reset to zero.
FYI, I updated it a few hours ago. The code in my wallet is different again.
Any help would be appreciated.
Re: DOGE wallet key
FAH generates points which carry boasting rights but carry no intrinsic value. Some cybercoin sites DO recognize FAH points as proof of work. When we resolve the points issue you may have to contact them about your wallet key and/or any reward that they consider appropriate.
FAH keeps a log of recent activities which can be reached according to the instructions below. Please post the first 200 lines of FAH's log plus one or more segments showing a completed WU. The latter should look something like this:
21:15:50:WU00:FS00:0xa7:Completed 61875 out of 62500 steps (99%)
21:37:50:WU00:FS00:0xa7:Completed 62500 out of 62500 steps (100%)
21:38:20:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
21:38:20:WU00:FS00:0xa7:Saving result file frame73.trr
21:38:20:WU00:FS00:0xa7:Saving result file frame73.xtc
21:38:20:WU00:FS00:0xa7:Saving result file md.log
21:38:20:WU00:FS00:0xa7:Saving result file science.log
21:38:20:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
21:38:21:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:38:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17231 run:4566 clone:2 gen:73 core:0xa7
21:38:21:WU00:FS00:Uploading 18.72MiB to 206.223.170.146
21:38:21:WU00:FS00:Connecting to 206.223.170.146:8080
21:38:27:WU00:FS00:Upload 19.03%
21:38:33:WU00:FS00:Upload 40.40%
21:38:39:WU00:FS00:Upload 62.11%
21:38:45:WU00:FS00:Upload 83.48%
21:38:49:WU00:FS00:Upload complete
21:38:50:WU00:FS00:Server responded WORK_ACK (400)
21:38:50:WU00:FS00:Final credit estimate, 6068.00 points
21:38:50:WU00:FS00:Cleaning up
If you have a supported GPU as well as a CPU, there are likely to be interspersed messages associated with another WU. We can check that in the top 200 lines of the log when you post it.
