points
PooryaMir
points
Post by PooryaMir »
I have folded for several weeks and also I completed some projects but my point is still 0 ?? what is the problem? could you please help me?
Re: points
The answer that I just gave here: here applies to your situation, too. Please post the necessary information.
PooryaMir
Re: points
Post by PooryaMir »
Team:226715
Re: points
Please post the sections of your log file that show the first 100 lines, and a WU being completed and uploading to the servers.
PooryaMir
Re: points
Post by PooryaMir »
How should I do tha?
Re: points
PooryaMir wrote:How should I do tha?
See the link in Bruce's signature.
rupesh.kokal
Re: points
Post by rupesh.kokal »
I did not receive the points. Details of the logs are given below:
*********************** Log Started 2021-05-16T14:44:12Z ***********************
14:44:12:******************************* libFAH ********************************
14:44:12:           Date: Oct 20 2020
14:44:12:           Time: 13:36:55
14:44:12:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:44:12:         Branch: master
14:44:12:       Compiler: Visual C++ 2015
14:44:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:44:12:       Platform: win32 10
14:44:12:           Bits: 32
14:44:12:           Mode: Release
14:44:12:****************************** FAHClient ******************************
14:44:12:        Version: 7.6.21
14:44:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:44:12:      Copyright: 2020 foldingathome.org
14:44:12:       Homepage: https://foldingathome.org/
14:44:12:           Time: 13:41:04
14:44:12:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:44:12:           Bits: 32
14:44:12:           Args: --open-web-control
14:44:12:******************************** CBang ********************************
14:44:12:           Time: 11:36:18
14:44:12:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:44:12:           Bits: 32
14:44:12:******************************* System ********************************
14:44:12:            CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
14:44:12:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:44:12:           CPUs: 8
14:44:12:         Memory: 31.81GiB
14:44:12:    Free Memory: 17.09GiB
14:44:12:        Threads: WINDOWS_THREADS
14:44:12:     OS Version: 6.2
14:44:12:    Has Battery: true
14:44:12:     On Battery: false
14:44:12:     UTC Offset: 5
14:44:12:            PID: 39052
14:44:12:            CWD: C:\ProgramData\FAHClient
14:44:12:  Win32 Service: false
14:44:12:             OS: Windows 10 Enterprise
14:44:12:        OS Arch: AMD64
14:44:12:           GPUs: 2
14:44:12:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
14:44:12:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [Quadro M2200]
14:44:12:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:11.0
14:44:12:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:452.66
14:44:12:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:27.20
14:44:12:***********************************************************************
14:44:12:<config>
14:44:12:  <!-- Folding Slots -->
14:44:12:</config>
14:44:12:Trying to access database...
14:44:12:Successfully acquired database lock
14:44:12:FS00:Initialized folding slot 00: cpu:3
14:44:12:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:2 KBL GT2 [HD Graphics 630].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
14:44:12:WARNING:FS01:Disabling beta GPU slot 01: gpu:0:2 KBL GT2 [HD Graphics 630].  Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
14:44:12:FS02:Initialized folding slot 02: gpu:1:0 GM206 [Quadro M2200]
14:44:16:17:127.0.0.1:New Web session
14:44:59:48:127.0.0.1:New Web session
14:45:13:Saving configuration to config.xml
14:45:13:<config>
14:45:13:  <!-- Folding Slots -->
14:45:13:  <slot id='0' type='CPU'/>
14:45:13:  <slot id='1' type='GPU'>
14:45:13:    <pci-bus v='0'/>
14:45:13:    <pci-slot v='2'/>
14:45:13:  </slot>
14:45:13:  <slot id='2' type='GPU'>
14:45:13:    <pci-bus v='1'/>
14:45:13:    <pci-slot v='0'/>
14:45:13:  </slot>
14:45:13:</config>
14:45:13:Set client configured
14:45:13:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:45:14:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:45:15:WU00:FS00:Assigned to work server 128.252.203.2
14:45:15:WU00:FS00:Requesting new work unit for slot 00: cpu:3 from 128.252.203.2
14:45:15:WU00:FS00:Connecting to 128.252.203.2:8080
14:45:16:WU00:FS00:Downloading 1.14MiB
14:45:17:WU00:FS00:Download complete
14:45:17:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17236 run:200 clone:96 gen:0 core:0xa7 unit:0x0000000380fccb02609dc1909bfe8829
14:45:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
14:45:18:WU00:FS00:Connecting to cores.foldingathome.org:80
14:45:18:WU00:FS00:FahCore a7: Downloading 6.71MiB
14:45:23:WU00:FS00:FahCore a7: Download complete
14:45:23:WU00:FS00:Valid core signature
14:45:23:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
14:45:23:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
14:45:23:WU00:FS00:Starting
14:45:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -np 3
14:45:23:WU00:FS00:Started FahCore on PID 38512
14:45:24:WU00:FS00:Core PID:22856
14:45:24:WU00:FS00:FahCore 0xa7 started
14:45:25:WU00:FS00:0xa7:*********************** Log Started 2021-05-16T14:45:24Z ***********************
14:45:25:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:45:25:WU00:FS00:0xa7:       Type: 0xa7
14:45:25:WU00:FS00:0xa7:       Core: Gromacs
14:45:25:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 38512 -checkpoint 15 -np
14:45:25:WU00:FS00:0xa7:             3
14:45:25:WU00:FS00:0xa7:************************************ CBang *************************************
14:45:25:WU00:FS00:0xa7:       Date: Nov 27 2019
14:45:25:WU00:FS00:0xa7:       Time: 03:40:09
14:45:25:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:45:25:WU00:FS00:0xa7:     Branch: master
14:45:25:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:45:25:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:45:25:WU00:FS00:0xa7:   Platform: win32 10
14:45:25:WU00:FS00:0xa7:       Bits: 64
14:45:25:WU00:FS00:0xa7:       Mode: Release
14:45:25:WU00:FS00:0xa7:************************************ System ************************************
14:45:25:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
14:45:25:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:45:25:WU00:FS00:0xa7:       CPUs: 8
14:45:25:WU00:FS00:0xa7:     Memory: 31.81GiB
14:45:25:WU00:FS00:0xa7:Free Memory: 16.91GiB
14:45:25:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:45:25:WU00:FS00:0xa7: OS Version: 6.2
14:45:25:WU00:FS00:0xa7:Has Battery: true
14:45:25:WU00:FS00:0xa7: On Battery: false
14:45:25:WU00:FS00:0xa7: UTC Offset: 5
14:45:25:WU00:FS00:0xa7:        PID: 22856
14:45:25:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
14:45:25:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:45:25:WU00:FS00:0xa7:    Version: 0.0.19
14:45:25:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:45:25:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:45:25:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:45:25:WU00:FS00:0xa7:       Date: Nov 25 2019
14:45:25:WU00:FS00:0xa7:       Time: 17:12:41
14:45:25:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:45:25:WU00:FS00:0xa7:************************************ Build *************************************
14:45:25:WU00:FS00:0xa7:       SIMD: avx_256
14:45:25:WU00:FS00:0xa7:********************************************************************************
14:45:25:WU00:FS00:0xa7:Project: 17236 (Run 200, Clone 96, Gen 0)
14:45:25:WU00:FS00:0xa7:Unit: 0x0000000380fccb02609dc1909bfe8829
14:45:25:WU00:FS00:0xa7:Reading tar file core.xml
14:45:25:WU00:FS00:0xa7:Reading tar file frame0.tpr
14:45:25:WU00:FS00:0xa7:Digital signatures verified
14:45:25:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpt 15 -nt 3
14:45:25:WU00:FS00:0xa7:Steps: first=0 total=500000
14:45:26:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:48:06:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:50:40:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
14:53:08:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
14:55:44:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
14:58:25:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
15:00:52:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
15:03:19:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
15:03:31:Saving configuration to config.xml
15:03:31:<config>
15:03:31:  <!-- User Information -->
15:03:31:  <passkey v='*****'/>
15:03:31:  <team v='226715'/>
15:03:31:  <user v='D7oWoihsUz58xHCoCff3iRLfJzvivbW8pt'/>
15:03:31:
15:03:31:  <!-- Folding Slots -->
15:03:31:  <slot id='0' type='CPU'/>
15:03:31:  <slot id='1' type='GPU'>
15:03:31:    <pci-bus v='0'/>
15:03:31:    <pci-slot v='2'/>
15:03:31:  </slot>
15:03:31:  <slot id='2' type='GPU'>
15:03:31:    <pci-bus v='1'/>
15:03:31:    <pci-slot v='0'/>
15:03:31:  </slot>
15:03:31:</config>
15:05:47:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
15:06:20:FS00:Shutting core down
15:06:20:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 22856
15:06:20:WU00:FS00:0xa7:Exiting, please wait. . .
15:06:20:WU01:FS02:Connecting to assign1.foldingathome.org:80
15:06:20:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:06:20:WU00:FS00:Starting
15:06:20:WARNING:WU00:FS00:Changed SMP threads from 3 to 6 this can cause some work units to fail
15:06:20:WARNING:WU00:FS00:AS lowered CPUs from 6 to 3
15:06:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -np 3
15:06:20:WU00:FS00:Started FahCore on PID 35244
15:06:20:WU00:FS00:Core PID:23184
15:06:20:WU00:FS00:FahCore 0xa7 started
15:06:21:WU01:FS02:Assigned to work server 207.53.233.146
15:06:21:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 GM206 [Quadro M2200] from 207.53.233.146
15:06:21:WU01:FS02:Connecting to 207.53.233.146:8080
15:06:21:WU00:FS00:0xa7:*********************** Log Started 2021-05-16T15:06:21Z ***********************
15:06:21:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:06:21:WU00:FS00:0xa7:       Type: 0xa7
15:06:21:WU00:FS00:0xa7:       Core: Gromacs
15:06:21:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 35244 -checkpoint 15 -np
15:06:21:WU00:FS00:0xa7:             3
15:06:21:WU00:FS00:0xa7:************************************ CBang *************************************
15:06:21:WU00:FS00:0xa7:       Date: Nov 27 2019
15:06:21:WU00:FS00:0xa7:       Time: 03:40:09
15:06:21:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:06:21:WU00:FS00:0xa7:     Branch: master
15:06:21:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
15:06:21:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:06:21:WU00:FS00:0xa7:   Platform: win32 10
15:06:21:WU00:FS00:0xa7:       Bits: 64
15:06:21:WU00:FS00:0xa7:       Mode: Release
15:06:21:WU00:FS00:0xa7:************************************ System ************************************
15:06:21:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
15:06:21:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:06:21:WU00:FS00:0xa7:       CPUs: 8
15:06:21:WU00:FS00:0xa7:     Memory: 31.81GiB
15:06:21:WU00:FS00:0xa7:Free Memory: 16.21GiB
15:06:21:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
15:06:21:WU00:FS00:0xa7: OS Version: 6.2
15:06:21:WU00:FS00:0xa7:Has Battery: true
15:06:21:WU00:FS00:0xa7: On Battery: false
15:06:21:WU00:FS00:0xa7: UTC Offset: 5
15:06:21:WU00:FS00:0xa7:        PID: 23184
15:06:21:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
15:06:21:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:06:21:WU00:FS00:0xa7:    Version: 0.0.19
15:06:21:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:06:21:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:06:21:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
15:06:21:WU00:FS00:0xa7:       Date: Nov 25 2019
15:06:21:WU00:FS00:0xa7:       Time: 17:12:41
15:06:21:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:06:21:WU00:FS00:0xa7:************************************ Build *************************************
15:06:21:WU00:FS00:0xa7:       SIMD: avx_256
15:06:21:WU00:FS00:0xa7:********************************************************************************
15:06:21:WU00:FS00:0xa7:Project: 17236 (Run 200, Clone 96, Gen 0)
15:06:21:WU00:FS00:0xa7:Unit: 0x0000000380fccb02609dc1909bfe8829
15:06:21:WU00:FS00:0xa7:Digital signatures verified
15:06:21:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 3
15:06:21:WU00:FS00:0xa7:Steps: first=0 total=500000
15:06:22:WU01:FS02:Downloading 6.15MiB
15:06:22:WU00:FS00:0xa7:Completed 41125 out of 500000 steps (8%)
15:06:28:WU01:FS02:Download 68.06%
15:06:30:WU01:FS02:Download complete
15:06:30:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17804 run:91 clone:8 gen:18 core:0x22 unit:0x00000008000000120000458c0000005b
15:06:30:WU01:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:06:30:WU01:FS02:Connecting to cores.foldingathome.org:80
15:06:31:WU01:FS02:FahCore 22: Downloading 77.67MiB
15:06:34:Saving configuration to config.xml
15:06:34:<config>
15:06:34:  <!-- Slot Control -->
15:06:34:  <power v='FULL'/>
15:06:34:
15:06:34:  <!-- User Information -->
15:06:34:  <passkey v='*****'/>
15:06:34:  <team v='226715'/>
15:06:34:  <user v='D7oWoihsUz58xHCoCff3iRLfJzvivbW8pt'/>
15:06:34:
15:06:34:  <!-- Folding Slots -->
15:06:34:  <slot id='0' type='CPU'/>
15:06:34:  <slot id='1' type='GPU'>
15:06:34:    <pci-bus v='0'/>
15:06:34:    <pci-slot v='2'/>
15:06:34:  </slot>
15:06:34:  <slot id='2' type='GPU'>
15:06:34:    <pci-bus v='1'/>
15:06:34:    <pci-slot v='0'/>
15:06:34:  </slot>
15:06:34:</config>
15:06:37:WU01:FS02:FahCore 22: 13.04%
15:06:43:WU01:FS02:FahCore 22: 29.29%
15:06:49:WU01:FS02:FahCore 22: 45.95%
15:06:55:WU01:FS02:FahCore 22: 56.89%
15:07:01:WU01:FS02:FahCore 22: 67.52%
15:07:07:WU01:FS02:FahCore 22: 85.38%
15:07:10:WU01:FS02:FahCore 22: Download complete
15:07:10:WU01:FS02:Valid core signature
15:07:10:WU01:FS02:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
15:07:10:WU01:FS02:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
15:07:10:WU01:FS02:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
15:07:10:WU01:FS02:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
15:07:10:WU01:FS02:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
15:07:10:WU01:FS02:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
15:07:10:WU01:FS02:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
15:07:10:WU01:FS02:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
15:07:10:WU01:FS02:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
15:07:11:WU01:FS02:Starting
15:07:11:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
15:07:11:WU01:FS02:Started FahCore on PID 41200
15:07:11:WU01:FS02:Core PID:37060
15:07:11:WU01:FS02:FahCore 0x22 started
15:07:12:WU01:FS02:0x22:*********************** Log Started 2021-05-16T15:07:12Z ***********************
15:07:12:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:07:12:WU01:FS02:0x22:       Core: Core22
15:07:12:WU01:FS02:0x22:       Type: 0x22
15:07:12:WU01:FS02:0x22:    Version: 0.0.13
15:07:12:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:07:12:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
15:07:12:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
15:07:12:WU01:FS02:0x22:       Date: Sep 19 2020
15:07:12:WU01:FS02:0x22:       Time: 02:35:58
15:07:12:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
15:07:12:WU01:FS02:0x22:     Branch: core22-0.0.13
15:07:12:WU01:FS02:0x22:   Compiler: Visual C++ 2015
15:07:12:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
15:07:12:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
15:07:12:WU01:FS02:0x22:   Platform: win32 10
15:07:12:WU01:FS02:0x22:       Bits: 64
15:07:12:WU01:FS02:0x22:       Mode: Release
15:07:12:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
15:07:12:WU01:FS02:0x22:             <peastman@stanford.edu>
15:07:12:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 41200 -checkpoint 15
15:07:12:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
15:07:12:WU01:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
15:07:12:WU01:FS02:0x22:************************************ libFAH ************************************
15:07:12:WU01:FS02:0x22:       Date: Sep 7 2020
15:07:12:WU01:FS02:0x22:       Time: 19:09:56
15:07:12:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
15:07:12:WU01:FS02:0x22:     Branch: HEAD
15:07:12:WU01:FS02:0x22:************************************ CBang *************************************
15:07:12:WU01:FS02:0x22:       Time: 19:08:30
15:07:12:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
15:07:12:WU01:FS02:0x22:************************************ System ************************************
15:07:12:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
15:07:12:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:07:12:WU01:FS02:0x22:       CPUs: 8
15:07:12:WU01:FS02:0x22:     Memory: 31.81GiB
15:07:12:WU01:FS02:0x22:Free Memory: 16.07GiB
15:07:12:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
15:07:12:WU01:FS02:0x22: OS Version: 6.2
15:07:12:WU01:FS02:0x22:Has Battery: true
15:07:12:WU01:FS02:0x22: On Battery: false
15:07:12:WU01:FS02:0x22: UTC Offset: 5
15:07:12:WU01:FS02:0x22:        PID: 37060
15:07:12:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
15:07:12:WU01:FS02:0x22:************************************ OpenMM ************************************
15:07:12:WU01:FS02:0x22:   Revision: 189320d0
15:07:12:WU01:FS02:0x22:********************************************************************************
15:07:12:WU01:FS02:0x22:Project: 17804 (Run 91, Clone 8, Gen 18)
15:07:12:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
15:07:12:WU01:FS02:0x22:Reading tar file core.xml
15:07:12:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
15:07:12:WU01:FS02:0x22:Reading tar file state.xml.bz2
15:07:12:WU01:FS02:0x22:Reading tar file system.xml.bz2
15:07:12:WU01:FS02:0x22:Digital signatures verified
15:07:12:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:07:12:WU01:FS02:0x22:Version 0.0.13
15:07:13:WU01:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
15:07:13:WU01:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
15:07:13:WU01:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
15:07:13:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
15:07:18:WU01:FS02:0x22:There are 4 platforms available.
15:07:18:WU01:FS02:0x22:Platform 0: Reference
15:07:18:WU01:FS02:0x22:Platform 1: CPU
15:07:18:WU01:FS02:0x22:Platform 2: OpenCL
15:07:18:WU01:FS02:0x22:  opencl-device 0 specified
15:07:18:WU01:FS02:0x22:Platform 3: CUDA
15:07:18:WU01:FS02:0x22:  cuda-device 0 specified
15:07:25:WU01:FS02:0x22:Attempting to create CUDA context:
15:07:25:WU01:FS02:0x22:  Configuring platform CUDA
15:07:36:WU01:FS02:0x22:  Using CUDA and gpu 0
15:07:36:WU01:FS02:0x22:Completed 0 out of 2500000 steps (0%)
15:07:36:WU01:FS02:0x22:Checkpoint completed at step 0
15:08:28:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
15:11:30:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
15:13:33:WU01:FS02:0x22:Completed 25000 out of 2500000 steps (1%)
15:14:39:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
15:17:50:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
15:19:24:WU01:FS02:0x22:Completed 50000 out of 2500000 steps (2%)
15:21:02:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
15:24:15:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
15:25:15:WU01:FS02:0x22:Completed 75000 out of 2500000 steps (3%)
15:27:33:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
15:30:53:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
15:31:11:WU01:FS02:0x22:Completed 100000 out of 2500000 steps (4%)
15:34:15:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
15:37:02:WU01:FS02:0x22:Completed 125000 out of 2500000 steps (5%)
15:37:03:WU01:FS02:0x22:Checkpoint completed at step 125000
15:37:40:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
15:40:44:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
15:41:00:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
15:42:53:WU01:FS02:0x22:Completed 150000 out of 2500000 steps (6%)
15:44:23:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
15:46:23:79:127.0.0.1:New Web session
15:47:44:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
15:48:45:WU01:FS02:0x22:Completed 175000 out of 2500000 steps (7%)
15:51:06:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
15:54:25:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
15:54:36:WU01:FS02:0x22:Completed 200000 out of 2500000 steps (8%)
15:57:43:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
16:00:25:WU01:FS02:0x22:Completed 225000 out of 2500000 steps (9%)
16:01:02:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
16:04:21:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
16:06:15:WU01:FS02:0x22:Completed 250000 out of 2500000 steps (10%)
16:06:16:WU01:FS02:0x22:Checkpoint completed at step 250000
16:07:39:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
16:10:57:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
16:12:06:WU01:FS02:0x22:Completed 275000 out of 2500000 steps (11%)
16:14:14:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
16:17:32:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
16:17:55:WU01:FS02:0x22:Completed 300000 out of 2500000 steps (12%)
16:20:51:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
16:23:45:WU01:FS02:0x22:Completed 325000 out of 2500000 steps (13%)
16:24:07:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
16:27:22:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
16:29:36:WU01:FS02:0x22:Completed 350000 out of 2500000 steps (14%)
16:30:38:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
16:34:02:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
16:35:08:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
16:35:27:WU01:FS02:0x22:Completed 375000 out of 2500000 steps (15%)
16:35:28:WU01:FS02:0x22:Checkpoint completed at step 375000
16:37:18:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
16:37:47:89:127.0.0.1:New Web session
16:40:37:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
16:41:23:WU01:FS02:0x22:Completed 400000 out of 2500000 steps (16%)
16:44:03:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
16:47:22:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
16:47:26:WU01:FS02:0x22:Completed 425000 out of 2500000 steps (17%)
16:50:44:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
16:53:21:WU01:FS02:0x22:Completed 450000 out of 2500000 steps (18%)
16:54:00:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
16:57:17:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
16:59:14:WU01:FS02:0x22:Completed 475000 out of 2500000 steps (19%)
17:00:40:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
17:03:59:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
17:04:28:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:05:06:WU01:FS02:0x22:Completed 500000 out of 2500000 steps (20%)
17:05:07:WU01:FS02:0x22:Checkpoint completed at step 500000
17:05:49:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:06:10:105:127.0.0.1:New Web session
17:07:20:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
17:07:36:FS00:Shutting core down
17:07:36:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 23184
17:07:36:WU00:FS00:0xa7:Exiting, please wait. . .
17:07:36:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
17:07:36:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:07:36:WU00:FS00:Starting
17:07:36:WARNING:WU00:FS00:Changed SMP threads from 6 to 5 this can cause some work units to fail
17:07:36:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
17:07:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -np 3
17:07:37:WU00:FS00:Started FahCore on PID 28212
17:07:37:WU00:FS00:Core PID:39436
17:07:37:WU00:FS00:FahCore 0xa7 started
17:07:37:WU00:FS00:0xa7:*********************** Log Started 2021-05-16T17:07:37Z ***********************
17:07:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:07:37:WU00:FS00:0xa7:       Type: 0xa7
17:07:37:WU00:FS00:0xa7:       Core: Gromacs
17:07:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 28212 -checkpoint 15 -np
17:07:37:WU00:FS00:0xa7:             3
17:07:37:WU00:FS00:0xa7:************************************ CBang *************************************
17:07:37:WU00:FS00:0xa7:       Date: Nov 27 2019
17:07:37:WU00:FS00:0xa7:       Time: 03:40:09
17:07:37:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
17:07:37:WU00:FS00:0xa7:     Branch: master
17:07:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:07:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:07:37:WU00:FS00:0xa7:   Platform: win32 10
17:07:37:WU00:FS00:0xa7:       Bits: 64
17:07:37:WU00:FS00:0xa7:       Mode: Release
17:07:37:WU00:FS00:0xa7:************************************ System ************************************
17:07:37:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
17:07:37:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:07:37:WU00:FS00:0xa7:       CPUs: 8
17:07:37:WU00:FS00:0xa7:     Memory: 31.81GiB
17:07:37:WU00:FS00:0xa7:Free Memory: 20.24GiB
17:07:37:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:07:37:WU00:FS00:0xa7: OS Version: 6.2
17:07:37:WU00:FS00:0xa7:Has Battery: true
17:07:37:WU00:FS00:0xa7: On Battery: false
17:07:37:WU00:FS00:0xa7: UTC Offset: 5
17:07:37:WU00:FS00:0xa7:        PID: 39436
17:07:37:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
17:07:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:07:37:WU00:FS00:0xa7:    Version: 0.0.19
17:07:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:07:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:07:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:07:37:WU00:FS00:0xa7:       Date: Nov 25 2019
17:07:37:WU00:FS00:0xa7:       Time: 17:12:41
17:07:37:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
17:07:37:WU00:FS00:0xa7:************************************ Build *************************************
17:07:37:WU00:FS00:0xa7:       SIMD: avx_256
17:07:37:WU00:FS00:0xa7:********************************************************************************
17:07:37:WU00:FS00:0xa7:Project: 17236 (Run 200, Clone 96, Gen 0)
17:07:37:WU00:FS00:0xa7:Unit: 0x0000000380fccb02609dc1909bfe8829
17:07:37:WU00:FS00:0xa7:Digital signatures verified
17:07:37:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 3
17:07:41:WU00:FS00:0xa7:Steps: first=0 total=500000
17:07:42:WU00:FS00:0xa7:Completed 225416 out of 500000 steps (45%)
17:08:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:08:41:Saving configuration to config.xml
17:08:41:<config>
17:08:41:  <!-- Slot Control -->
17:08:41:  <power v='medium'/>
17:08:41:
17:08:41:  <!-- User Information -->
17:08:41:  <passkey v='*****'/>
17:08:41:  <team v='226715'/>
17:08:41:  <user v='D7oWoihsUz58xHCoCff3iRLfJzvivbW8pt'/>
17:08:41:
17:08:41:  <!-- Folding Slots -->
17:08:41:  <slot id='0' type='CPU'/>
17:08:41:  <slot id='1' type='GPU'>
17:08:41:    <pci-bus v='0'/>
17:08:41:    <pci-slot v='2'/>
17:08:41:  </slot>
17:08:41:  <slot id='2' type='GPU'>
17:08:41:    <pci-bus v='1'/>
17:08:41:    <pci-slot v='0'/>
17:08:41:  </slot>
17:08:41:</config>
17:08:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:08:53:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
17:10:47:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
17:10:59:WU01:FS02:0x22:Completed 525000 out of 2500000 steps (21%)
17:14:09:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
17:16:48:WU01:FS02:0x22:Completed 550000 out of 2500000 steps (22%)
17:17:27:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
17:20:45:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
17:22:38:WU01:FS02:0x22:Completed 575000 out of 2500000 steps (23%)
17:24:27:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
17:28:13:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
17:28:28:WU01:FS02:0x22:Completed 600000 out of 2500000 steps (24%)
17:31:48:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
17:34:18:WU01:FS02:0x22:Completed 625000 out of 2500000 steps (25%)
17:34:19:WU01:FS02:0x22:Checkpoint completed at step 625000
17:35:20:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
17:39:22:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
17:40:09:WU01:FS02:0x22:Completed 650000 out of 2500000 steps (26%)
17:42:53:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
17:45:58:WU01:FS02:0x22:Completed 675000 out of 2500000 steps (27%)
17:46:24:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
17:50:24:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
17:51:48:WU01:FS02:0x22:Completed 700000 out of 2500000 steps (28%)
17:53:56:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
17:57:38:WU01:FS02:0x22:Completed 725000 out of 2500000 steps (29%)
17:57:41:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
18:01:14:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
18:03:28:WU01:FS02:0x22:Completed 750000 out of 2500000 steps (30%)
18:03:29:WU01:FS02:0x22:Checkpoint completed at step 750000
18:04:31:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
18:08:22:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
18:09:18:WU01:FS02:0x22:Completed 775000 out of 2500000 steps (31%)
18:11:38:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
18:15:07:WU01:FS02:0x22:Completed 800000 out of 2500000 steps (32%)
18:16:13:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
18:19:33:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
18:20:56:WU01:FS02:0x22:Completed 825000 out of 2500000 steps (33%)
18:22:49:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
18:26:06:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
18:26:45:WU01:FS02:0x22:Completed 850000 out of 2500000 steps (34%)
18:29:20:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
18:32:33:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
18:32:35:WU01:FS02:0x22:Completed 875000 out of 2500000 steps (35%)
18:32:36:WU01:FS02:0x22:Checkpoint completed at step 875000
18:35:44:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
18:38:25:WU01:FS02:0x22:Completed 900000 out of 2500000 steps (36%)
18:38:57:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
18:42:18:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
18:44:14:WU01:FS02:0x22:Completed 925000 out of 2500000 steps (37%)
18:45:33:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
18:48:46:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
18:50:03:WU01:FS02:0x22:Completed 950000 out of 2500000 steps (38%)
18:52:25:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
18:55:37:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
18:55:53:WU01:FS02:0x22:Completed 975000 out of 2500000 steps (39%)
18:58:52:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
19:01:42:WU01:FS02:0x22:Completed 1000000 out of 2500000 steps (40%)
19:01:43:WU01:FS02:0x22:Checkpoint completed at step 1000000
19:02:04:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
19:05:14:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
19:07:32:WU01:FS02:0x22:Completed 1025000 out of 2500000 steps (41%)
19:08:26:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
19:11:40:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
19:13:21:WU01:FS02:0x22:Completed 1050000 out of 2500000 steps (42%)
19:15:14:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
19:18:27:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
19:19:10:WU01:FS02:0x22:Completed 1075000 out of 2500000 steps (43%)
19:21:38:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
19:24:55:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
19:25:00:WU01:FS02:0x22:Completed 1100000 out of 2500000 steps (44%)
19:28:07:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
19:30:49:WU01:FS02:0x22:Completed 1125000 out of 2500000 steps (45%)
19:30:49:WU01:FS02:0x22:Checkpoint completed at step 1125000
19:31:24:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
19:34:39:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
19:36:39:WU01:FS02:0x22:Completed 1150000 out of 2500000 steps (46%)
19:37:57:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
19:40:50:118:127.0.0.1:New Web session
19:41:15:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
19:42:08:FS00:Shutting core down
19:42:08:FS02:Shutting core down
19:42:08:WU01:FS02:0x22:WARNING:Console control signal 1 on PID 37060
19:42:08:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 39436
19:42:08:WU01:FS02:0x22:Exiting, please wait. . .
19:42:08:WU00:FS00:0xa7:Exiting, please wait. . .
19:42:08:WU01:FS02:0x22:Folding@home Core Shutdown: INTERRUPTED
19:42:08:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
19:42:09:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:42:18:WU00:FS00:Starting
19:42:18:WARNING:WU00:FS00:AS lowered CPUs from 5 to 3
19:42:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -np 3
19:42:18:WU00:FS00:Started FahCore on PID 43892
19:42:18:WU00:FS00:Core PID:8120
19:42:18:WU00:FS00:FahCore 0xa7 started
19:42:18:WU01:FS02:Starting
19:42:18:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
19:42:18:WU01:FS02:Started FahCore on PID 22028
19:42:18:WU01:FS02:Core PID:44440
19:42:18:WU01:FS02:FahCore 0x22 started
19:42:18:WU00:FS00:0xa7:*********************** Log Started 2021-05-16T19:42:18Z ***********************
19:42:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:42:18:WU00:FS00:0xa7:       Type: 0xa7
19:42:18:WU00:FS00:0xa7:       Core: Gromacs
19:42:18:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 43892 -checkpoint 15 -np
19:42:18:WU00:FS00:0xa7:             3
19:42:18:WU00:FS00:0xa7:************************************ CBang *************************************
19:42:18:WU00:FS00:0xa7:       Date: Nov 27 2019
19:42:18:WU00:FS00:0xa7:       Time: 03:40:09
19:42:18:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
19:42:18:WU00:FS00:0xa7:     Branch: master
19:42:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:42:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:42:18:WU00:FS00:0xa7:   Platform: win32 10
19:42:18:WU00:FS00:0xa7:       Bits: 64
19:42:18:WU00:FS00:0xa7:       Mode: Release
19:42:18:WU00:FS00:0xa7:************************************ System ************************************
19:42:18:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
19:42:18:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:42:18:WU00:FS00:0xa7:       CPUs: 8
19:42:18:WU00:FS00:0xa7:     Memory: 31.81GiB
19:42:18:WU00:FS00:0xa7:Free Memory: 20.16GiB
19:42:18:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:42:18:WU00:FS00:0xa7: OS Version: 6.2
19:42:18:WU00:FS00:0xa7:Has Battery: true
19:42:18:WU00:FS00:0xa7: On Battery: false
19:42:18:WU00:FS00:0xa7: UTC Offset: 5
19:42:18:WU00:FS00:0xa7:        PID: 8120
19:42:18:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
19:42:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:42:18:WU00:FS00:0xa7:    Version: 0.0.19
19:42:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:42:18:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:42:18:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:42:18:WU00:FS00:0xa7:       Date: Nov 25 2019
19:42:18:WU00:FS00:0xa7:       Time: 17:12:41
19:42:18:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
19:42:18:WU00:FS00:0xa7:************************************ Build *************************************
19:42:18:WU00:FS00:0xa7:       SIMD: avx_256
19:42:18:WU00:FS00:0xa7:********************************************************************************
19:42:18:WU00:FS00:0xa7:Project: 17236 (Run 200, Clone 96, Gen 0)
19:42:18:WU00:FS00:0xa7:Unit: 0x0000000380fccb02609dc1909bfe8829
19:42:18:WU00:FS00:0xa7:Digital signatures verified
19:42:18:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 3
19:42:18:WU00:FS00:0xa7:Steps: first=0 total=500000
19:42:18:WU01:FS02:0x22:*********************** Log Started 2021-05-16T19:42:18Z ***********************
19:42:18:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
19:42:18:WU01:FS02:0x22:       Core: Core22
19:42:18:WU01:FS02:0x22:       Type: 0x22
19:42:18:WU01:FS02:0x22:    Version: 0.0.13
19:42:18:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:42:18:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
19:42:18:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
19:42:18:WU01:FS02:0x22:       Date: Sep 19 2020
19:42:18:WU01:FS02:0x22:       Time: 02:35:58
19:42:18:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
19:42:18:WU01:FS02:0x22:     Branch: core22-0.0.13
19:42:18:WU01:FS02:0x22:   Compiler: Visual C++ 2015
19:42:18:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
19:42:18:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
19:42:18:WU01:FS02:0x22:   Platform: win32 10
19:42:18:WU01:FS02:0x22:       Bits: 64
19:42:18:WU01:FS02:0x22:       Mode: Release
19:42:18:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
19:42:18:WU01:FS02:0x22:             <peastman@stanford.edu>
19:42:18:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 22028 -checkpoint 15
19:42:18:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
19:42:18:WU01:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
19:42:18:WU01:FS02:0x22:************************************ libFAH ************************************
19:42:18:WU01:FS02:0x22:       Date: Sep 7 2020
19:42:18:WU01:FS02:0x22:       Time: 19:09:56
19:42:18:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
19:42:18:WU01:FS02:0x22:     Branch: HEAD
19:42:18:WU01:FS02:0x22:************************************ CBang *************************************
19:42:18:WU01:FS02:0x22:       Time: 19:08:30
19:42:18:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
19:42:18:WU01:FS02:0x22:************************************ System ************************************
19:42:18:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
19:42:18:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
19:42:18:WU01:FS02:0x22:       CPUs: 8
19:42:18:WU01:FS02:0x22:     Memory: 31.81GiB
19:42:18:WU01:FS02:0x22:Free Memory: 20.15GiB
19:42:18:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
19:42:18:WU01:FS02:0x22: OS Version: 6.2
19:42:18:WU01:FS02:0x22:Has Battery: true
19:42:18:WU01:FS02:0x22: On Battery: false
19:42:18:WU01:FS02:0x22: UTC Offset: 5
19:42:18:WU01:FS02:0x22:        PID: 44440
19:42:18:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
19:42:18:WU01:FS02:0x22:************************************ OpenMM ************************************
19:42:18:WU01:FS02:0x22:   Revision: 189320d0
19:42:18:WU01:FS02:0x22:********************************************************************************
19:42:18:WU01:FS02:0x22:Project: 17804 (Run 91, Clone 8, Gen 18)
19:42:18:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
19:42:18:WU01:FS02:0x22:Digital signatures verified
19:42:18:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
19:42:18:WU01:FS02:0x22:Version 0.0.13
19:42:18:WU01:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
19:42:18:WU01:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
19:42:18:WU01:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
19:42:18:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
19:42:18:WU01:FS02:0x22:There are 4 platforms available.
19:42:18:WU01:FS02:0x22:Platform 0: Reference
19:42:18:WU01:FS02:0x22:Platform 1: CPU
19:42:18:WU01:FS02:0x22:Platform 2: OpenCL
19:42:18:WU01:FS02:0x22:  opencl-device 0 specified
19:42:18:WU01:FS02:0x22:Platform 3: CUDA
19:42:18:WU01:FS02:0x22:  cuda-device 0 specified
19:42:19:WU00:FS00:0xa7:Completed 451285 out of 500000 steps (90%)
19:42:27:WU01:FS02:0x22:Attempting to create CUDA context:
19:42:27:WU01:FS02:0x22:  Configuring platform CUDA
19:42:29:WU01:FS02:0x22:  Using CUDA and gpu 0
19:42:29:WU01:FS02:0x22:Completed 1125000 out of 2500000 steps (45%)
19:44:40:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
19:47:51:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
19:48:18:WU01:FS02:0x22:Completed 1150000 out of 2500000 steps (46%)
19:51:02:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
19:54:07:WU01:FS02:0x22:Completed 1175000 out of 2500000 steps (47%)
19:54:14:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
19:57:26:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
19:59:57:WU01:FS02:0x22:Completed 1200000 out of 2500000 steps (48%)
20:00:37:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
20:03:49:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
20:05:46:WU01:FS02:0x22:Completed 1225000 out of 2500000 steps (49%)
20:07:02:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
20:10:15:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
20:10:16:WU02:FS00:Connecting to assign1.foldingathome.org:80
20:10:18:WU02:FS00:Assigned to work server 129.32.209.205
20:10:18:WU02:FS00:Requesting new work unit for slot 00: cpu:5 from 129.32.209.205
20:10:18:WU02:FS00:Connecting to 129.32.209.205:8080
20:10:18:WU02:FS00:Downloading 1.47MiB
20:10:21:WU02:FS00:Download complete
20:10:21:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16969 run:4 clone:742 gen:2 core:0xa8 unit:0x000002e6000000020000424900000004
20:10:21:WU02:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
20:10:21:WU02:FS00:Connecting to cores.foldingathome.org:80
20:10:22:WU02:FS00:FahCore a8: Downloading 7.72MiB
20:10:28:WU02:FS00:FahCore a8: 97.92%
20:10:28:WU02:FS00:FahCore a8: Download complete
20:10:28:WU02:FS00:Valid core signature
20:10:28:WU02:FS00:Unpacked 20.93MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe
20:10:28:WU02:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/libfftw3f-3.dll
20:10:28:WU02:FS00:Unpacked 172.88KiB to cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/vcomp140.dll
20:11:35:WU01:FS02:0x22:Completed 1250000 out of 2500000 steps (50%)
20:11:36:WU01:FS02:0x22:Checkpoint completed at step 1250000
20:13:29:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
20:13:29:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:13:29:WU00:FS00:0xa7:Saving result file frame0.trr
20:13:29:WU00:FS00:0xa7:Saving result file frame0.xtc
20:13:29:WU00:FS00:0xa7:Saving result file md.log
20:13:29:WU00:FS00:0xa7:Saving result file science.log
20:13:29:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:13:30:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:13:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:17236 run:200 clone:96 gen:0 core:0xa7 unit:0x0000000380fccb02609dc1909bfe8829
20:13:30:WU00:FS00:Uploading 2.63MiB to 128.252.203.2
20:13:30:WU00:FS00:Connecting to 128.252.203.2:8080
20:13:30:WU02:FS00:Starting
20:13:30:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -np 5
20:13:30:WU02:FS00:Started FahCore on PID 25868
20:13:31:WU02:FS00:Core PID:25864
20:13:31:WU02:FS00:FahCore 0xa8 started
20:13:31:WU02:FS00:0xa8:*********************** Log Started 2021-05-16T20:13:31Z ***********************
20:13:31:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
20:13:31:WU02:FS00:0xa8:       Core: Gromacs
20:13:31:WU02:FS00:0xa8:       Type: 0xa8
20:13:31:WU02:FS00:0xa8:    Version: 0.0.12
20:13:31:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:13:31:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
20:13:31:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
20:13:31:WU02:FS00:0xa8:       Date: Jan 16 2021
20:13:31:WU02:FS00:0xa8:       Time: 12:29:40
20:13:31:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:13:31:WU02:FS00:0xa8:     Branch: master
20:13:31:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:13:31:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:13:31:WU02:FS00:0xa8:   Platform: win32 10
20:13:31:WU02:FS00:0xa8:       Bits: 64
20:13:31:WU02:FS00:0xa8:       Mode: Release
20:13:31:WU02:FS00:0xa8:       SIMD: avx2_256
20:13:31:WU02:FS00:0xa8:     OpenMP: ON
20:13:31:WU02:FS00:0xa8:       CUDA: OFF
20:13:32:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 25868 -checkpoint 15 -np
20:13:32:WU02:FS00:0xa8:             5
20:13:32:WU02:FS00:0xa8:************************************ libFAH ************************************
20:13:32:WU02:FS00:0xa8:       Date: Jan 16 2021
20:13:32:WU02:FS00:0xa8:       Time: 11:24:13
20:13:32:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
20:13:32:WU02:FS00:0xa8:     Branch: master
20:13:32:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
20:13:32:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
20:13:32:WU02:FS00:0xa8:   Platform: win32 10
20:13:32:WU02:FS00:0xa8:       Bits: 64
20:13:32:WU02:FS00:0xa8:       Mode: Release
20:13:32:WU02:FS00:0xa8:************************************ CBang *************************************
20:13:32:WU02:FS00:0xa8:       Time: 11:23:53
20:13:32:WU02:FS00:0xa8:************************************ System ************************************
20:13:32:WU02:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
20:13:32:WU02:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:13:32:WU02:FS00:0xa8:       CPUs: 8
20:13:32:WU02:FS00:0xa8:     Memory: 31.81GiB
20:13:32:WU02:FS00:0xa8:Free Memory: 19.64GiB
20:13:32:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
20:13:32:WU02:FS00:0xa8: OS Version: 6.2
20:13:32:WU02:FS00:0xa8:Has Battery: true
20:13:32:WU02:FS00:0xa8: On Battery: false
20:13:32:WU02:FS00:0xa8: UTC Offset: 5
20:13:32:WU02:FS00:0xa8:        PID: 25864
20:13:32:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
20:13:32:WU02:FS00:0xa8:********************************************************************************
20:13:32:WU02:FS00:0xa8:Project: 16969 (Run 4, Clone 742, Gen 2)
20:13:32:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
20:13:32:WU02:FS00:0xa8:Reading tar file core.xml
20:13:32:WU02:FS00:0xa8:Reading tar file frame2.tpr
20:13:32:WU02:FS00:0xa8:Digital signatures verified
20:13:32:WU02:FS00:0xa8:Calling: mdrun -c frame2.gro -s frame2.tpr -x frame2.xtc -cpt 15 -nt 5 -ntmpi 1
20:13:32:WU02:FS00:0xa8:Steps: first=5000000 total=7500000
20:13:32:WU02:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
20:13:36:WU00:FS00:Upload 52.26%
20:13:41:WU00:FS00:Upload complete
20:13:41:WU00:FS00:Server responded WORK_ACK (400)
20:13:41:WU00:FS00:Final credit estimate, 3109.00 points
20:13:41:WU00:FS00:Cleaning up
20:17:10:129:127.0.0.1:New Web session
20:17:27:WU01:FS02:0x22:Completed 1275000 out of 2500000 steps (51%)
20:22:36:WU02:FS00:0xa8:Completed 25000 out of 2500000 steps (1%)
20:23:18:WU01:FS02:0x22:Completed 1300000 out of 2500000 steps (52%)
20:29:09:WU01:FS02:0x22:Completed 1325000 out of 2500000 steps (53%)
20:31:40:WU02:FS00:0xa8:Completed 50000 out of 2500000 steps (2%)
20:34:59:WU01:FS02:0x22:Completed 1350000 out of 2500000 steps (54%)
Re: points
rupesh.kokal wrote:I did not receive the points. Details of the logs are given below:
You have received credit for 2 WUs so far - https://apps.foldingathome.org/cpu?q=D7 ... JzvivbW8pt. They received the base points as you have not yet returned 10 WUs. The estimate in the client is based on there being a passkey, however the client does not does not check to see if a passkey and username have qualified yet for the bonus.
rupesh.kokal
Re: points
Received the points as per the earlier post, but did not receive newer points. Also I don't see my stats updated in the url https://stats.foldingathome.org/donor/D ... JzvivbW8pt.
Below is the log for other points not reflecting:
15:06:34:
15:06:34:
15:06:34:  </slot>
15:06:34:  </slot>
15:06:34:</config>
17:08:41:<config>
17:08:41:
17:08:41:
17:08:41:  </slot>
17:08:41:  </slot>
17:08:41:</config>
20:40:40:WU02:FS00:0xa8:Completed 75000 out of 2500000 steps (3%)
20:40:50:WU01:FS02:0x22:Completed 1375000 out of 2500000 steps (55%)
20:40:51:WU01:FS02:0x22:Checkpoint completed at step 1375000
******************************* Date: 2021-05-16 *******************************
20:46:42:WU01:FS02:0x22:Completed 1400000 out of 2500000 steps (56%)
20:49:53:WU02:FS00:0xa8:Completed 100000 out of 2500000 steps (4%)
20:52:33:WU01:FS02:0x22:Completed 1425000 out of 2500000 steps (57%)
20:57:16:141:127.0.0.1:New Web session
20:58:26:WU01:FS02:0x22:Completed 1450000 out of 2500000 steps (58%)
20:59:21:WU02:FS00:0xa8:Completed 125000 out of 2500000 steps (5%)
21:00:51:149:127.0.0.1:New Web session
21:04:18:WU01:FS02:0x22:Completed 1475000 out of 2500000 steps (59%)
21:06:32:ERROR:Send error: 10054: An existing connection was forcibly closed by the remote host.
21:07:07:157:127.0.0.1:New Web session
21:08:31:WU02:FS00:0xa8:Completed 150000 out of 2500000 steps (6%)
21:09:32:165:127.0.0.1:New Web session
21:09:43:173:127.0.0.1:New Web session
21:10:09:WU01:FS02:0x22:Completed 1500000 out of 2500000 steps (60%)
21:10:10:WU01:FS02:0x22:Checkpoint completed at step 1500000
21:10:34:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
21:16:03:WU01:FS02:0x22:Completed 1525000 out of 2500000 steps (61%)
21:17:37:WU02:FS00:0xa8:Completed 175000 out of 2500000 steps (7%)
21:21:53:WU01:FS02:0x22:Completed 1550000 out of 2500000 steps (62%)
21:26:23:WU02:FS00:0xa8:Completed 200000 out of 2500000 steps (8%)
21:27:43:WU01:FS02:0x22:Completed 1575000 out of 2500000 steps (63%)
21:33:33:WU01:FS02:0x22:Completed 1600000 out of 2500000 steps (64%)
21:35:09:WU02:FS00:0xa8:Completed 225000 out of 2500000 steps (9%)
21:39:23:WU01:FS02:0x22:Completed 1625000 out of 2500000 steps (65%)
21:39:24:WU01:FS02:0x22:Checkpoint completed at step 1625000
21:43:52:WU02:FS00:0xa8:Completed 250000 out of 2500000 steps (10%)
21:45:14:WU01:FS02:0x22:Completed 1650000 out of 2500000 steps (66%)
21:51:04:WU01:FS02:0x22:Completed 1675000 out of 2500000 steps (67%)
21:52:34:WU02:FS00:0xa8:Completed 275000 out of 2500000 steps (11%)
21:56:54:WU01:FS02:0x22:Completed 1700000 out of 2500000 steps (68%)
22:01:17:WU02:FS00:0xa8:Completed 300000 out of 2500000 steps (12%)
22:02:44:WU01:FS02:0x22:Completed 1725000 out of 2500000 steps (69%)
22:08:35:WU01:FS02:0x22:Completed 1750000 out of 2500000 steps (70%)
22:08:36:WU01:FS02:0x22:Checkpoint completed at step 1750000
22:10:34:WU02:FS00:0xa8:Completed 325000 out of 2500000 steps (13%)
22:14:31:WU01:FS02:0x22:Completed 1775000 out of 2500000 steps (71%)
22:19:18:WU02:FS00:0xa8:Completed 350000 out of 2500000 steps (14%)
22:20:21:WU01:FS02:0x22:Completed 1800000 out of 2500000 steps (72%)
22:26:11:WU01:FS02:0x22:Completed 1825000 out of 2500000 steps (73%)
22:28:03:WU02:FS00:0xa8:Completed 375000 out of 2500000 steps (15%)
22:32:02:WU01:FS02:0x22:Completed 1850000 out of 2500000 steps (74%)
22:36:47:WU02:FS00:0xa8:Completed 400000 out of 2500000 steps (16%)
22:37:51:WU01:FS02:0x22:Completed 1875000 out of 2500000 steps (75%)
22:37:52:WU01:FS02:0x22:Checkpoint completed at step 1875000
22:43:43:WU01:FS02:0x22:Completed 1900000 out of 2500000 steps (76%)
22:45:31:WU02:FS00:0xa8:Completed 425000 out of 2500000 steps (17%)
22:49:33:WU01:FS02:0x22:Completed 1925000 out of 2500000 steps (77%)
22:54:16:WU02:FS00:0xa8:Completed 450000 out of 2500000 steps (18%)
22:55:23:WU01:FS02:0x22:Completed 1950000 out of 2500000 steps (78%)
23:01:13:WU01:FS02:0x22:Completed 1975000 out of 2500000 steps (79%)
23:03:00:WU02:FS00:0xa8:Completed 475000 out of 2500000 steps (19%)
23:07:03:WU01:FS02:0x22:Completed 2000000 out of 2500000 steps (80%)
23:07:04:WU01:FS02:0x22:Checkpoint completed at step 2000000
23:11:43:WU02:FS00:0xa8:Completed 500000 out of 2500000 steps (20%)
23:12:54:WU01:FS02:0x22:Completed 2025000 out of 2500000 steps (81%)
23:18:44:WU01:FS02:0x22:Completed 2050000 out of 2500000 steps (82%)
23:20:27:WU02:FS00:0xa8:Completed 525000 out of 2500000 steps (21%)
23:24:34:WU01:FS02:0x22:Completed 2075000 out of 2500000 steps (83%)
23:29:10:WU02:FS00:0xa8:Completed 550000 out of 2500000 steps (22%)
23:30:24:WU01:FS02:0x22:Completed 2100000 out of 2500000 steps (84%)
23:36:14:WU01:FS02:0x22:Completed 2125000 out of 2500000 steps (85%)
23:36:15:WU01:FS02:0x22:Checkpoint completed at step 2125000
23:37:55:WU02:FS00:0xa8:Completed 575000 out of 2500000 steps (23%)
23:42:05:WU01:FS02:0x22:Completed 2150000 out of 2500000 steps (86%)
23:46:38:WU02:FS00:0xa8:Completed 600000 out of 2500000 steps (24%)
23:47:55:WU01:FS02:0x22:Completed 2175000 out of 2500000 steps (87%)
23:53:46:WU01:FS02:0x22:Completed 2200000 out of 2500000 steps (88%)
23:55:21:WU02:FS00:0xa8:Completed 625000 out of 2500000 steps (25%)
23:59:36:WU01:FS02:0x22:Completed 2225000 out of 2500000 steps (89%)
00:04:04:WU02:FS00:0xa8:Completed 650000 out of 2500000 steps (26%)
00:05:26:WU01:FS02:0x22:Completed 2250000 out of 2500000 steps (90%)
00:05:27:WU01:FS02:0x22:Checkpoint completed at step 2250000
00:11:17:WU01:FS02:0x22:Completed 2275000 out of 2500000 steps (91%)
00:12:48:WU02:FS00:0xa8:Completed 675000 out of 2500000 steps (27%)
00:17:07:WU01:FS02:0x22:Completed 2300000 out of 2500000 steps (92%)
00:21:36:WU02:FS00:0xa8:Completed 700000 out of 2500000 steps (28%)
00:22:57:WU01:FS02:0x22:Completed 2325000 out of 2500000 steps (93%)
00:28:47:WU01:FS02:0x22:Completed 2350000 out of 2500000 steps (94%)
00:30:17:WU02:FS00:0xa8:Completed 725000 out of 2500000 steps (29%)
00:34:37:WU01:FS02:0x22:Completed 2375000 out of 2500000 steps (95%)
00:34:38:WU01:FS02:0x22:Checkpoint completed at step 2375000
00:39:00:WU02:FS00:0xa8:Completed 750000 out of 2500000 steps (30%)
00:40:28:WU01:FS02:0x22:Completed 2400000 out of 2500000 steps (96%)
00:46:18:WU01:FS02:0x22:Completed 2425000 out of 2500000 steps (97%)
00:47:43:WU02:FS00:0xa8:Completed 775000 out of 2500000 steps (31%)
00:52:08:WU01:FS02:0x22:Completed 2450000 out of 2500000 steps (98%)
00:56:25:WU02:FS00:0xa8:Completed 800000 out of 2500000 steps (32%)
00:57:59:WU01:FS02:0x22:Completed 2475000 out of 2500000 steps (99%)
00:58:00:WU00:FS02:Connecting to assign1.foldingathome.org:80
00:58:01:WU00:FS02:Assigned to work server 207.53.233.146
00:58:01:WU00:FS02:Requesting new work unit for slot 02: gpu:1:0 GM206 [Quadro M2200] from 207.53.233.146
00:58:01:WU00:FS02:Connecting to 207.53.233.146:8080
00:58:02:WU00:FS02:Downloading 6.10MiB
00:58:08:WU00:FS02:Download 82.97%
00:58:08:WU00:FS02:Download complete
00:58:08:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17804 run:42 clone:84 gen:18 core:0x22 unit:0x00000054000000120000458c0000002a
01:03:48:WU01:FS02:0x22:Completed 2500000 out of 2500000 steps (100%)
01:03:48:WU01:FS02:0x22:Average performance: 4.93714 ns/day
01:03:50:WU01:FS02:0x22:Checkpoint completed at step 2500000
01:04:01:WU01:FS02:0x22:Saving result file ..\logfile_01.txt
01:04:01:WU01:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
01:04:01:WU01:FS02:0x22:Saving result file checkpointState.xml.bz2
01:04:02:WU01:FS02:0x22:Saving result file positions.xtc
01:04:02:WU01:FS02:0x22:Saving result file science.log
01:04:02:WU01:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
01:04:02:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:04:02:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:17804 run:91 clone:8 gen:18 core:0x22 unit:0x00000008000000120000458c0000005b
01:04:02:WU01:FS02:Uploading 8.61MiB to 207.53.233.146
01:04:02:WU01:FS02:Connecting to 207.53.233.146:8080
01:04:02:WU00:FS02:Starting
01:04:02:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 39052 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
01:04:02:WU00:FS02:Started FahCore on PID 34632
01:04:02:WU00:FS02:Core PID:14108
01:04:02:WU00:FS02:FahCore 0x22 started
01:04:03:WU00:FS02:0x22:*********************** Log Started 2021-05-17T01:04:02Z ***********************
01:04:03:WU00:FS02:0x22:*************************** Core22 Folding@home Core ***************************
01:04:03:WU00:FS02:0x22:       Core: Core22
01:04:03:WU00:FS02:0x22:       Type: 0x22
01:04:03:WU00:FS02:0x22:    Version: 0.0.13
01:04:03:WU00:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:04:03:WU00:FS02:0x22:  Copyright: 2020 foldingathome.org
01:04:03:WU00:FS02:0x22:   Homepage: https://foldingathome.org/
01:04:03:WU00:FS02:0x22:       Date: Sep 19 2020
01:04:03:WU00:FS02:0x22:       Time: 02:35:58
01:04:03:WU00:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
01:04:03:WU00:FS02:0x22:     Branch: core22-0.0.13
01:04:03:WU00:FS02:0x22:   Compiler: Visual C++ 2015
01:04:03:WU00:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
01:04:03:WU00:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
01:04:03:WU00:FS02:0x22:   Platform: win32 10
01:04:03:WU00:FS02:0x22:       Bits: 64
01:04:03:WU00:FS02:0x22:       Mode: Release
01:04:03:WU00:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
01:04:03:WU00:FS02:0x22:             <peastman@stanford.edu>
01:04:03:WU00:FS02:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 34632 -checkpoint 15
01:04:03:WU00:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
01:04:03:WU00:FS02:0x22:             nvidia -
01:04:03:WU00:FS02:0x22:************************************ libFAH ************************************
01:04:03:WU00:FS02:0x22:       Date: Sep 7 2020
01:04:03:WU00:FS02:0x22:       Time: 19:09:56
01:04:03:WU00:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
01:04:03:WU00:FS02:0x22:     Branch: HEAD
01:04:03:WU00:FS02:0x22:************************************ CBang *************************************
01:04:03:WU00:FS02:0x22:       Time: 19:08:30
01:04:03:WU00:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
01:04:03:WU00:FS02:0x22:************************************ System ************************************
01:04:03:WU00:FS02:0x22:        CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
01:04:03:WU00:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
01:04:03:WU00:FS02:0x22:       CPUs: 8
01:04:03:WU00:FS02:0x22:     Memory: 31.81GiB
01:04:03:WU00:FS02:0x22:Free Memory: 19.38GiB
01:04:03:WU00:FS02:0x22:    Threads: WINDOWS_THREADS
01:04:03:WU00:FS02:0x22: OS Version: 6.2
01:04:03:WU00:FS02:0x22:Has Battery: true
01:04:03:WU00:FS02:0x22: On Battery: false
01:04:03:WU00:FS02:0x22: UTC Offset: 5
01:04:03:WU00:FS02:0x22:        PID: 14108
01:04:03:WU00:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
01:04:03:WU00:FS02:0x22:************************************ OpenMM ************************************
01:04:03:WU00:FS02:0x22:   Revision: 189320d0
01:04:03:WU00:FS02:0x22:********************************************************************************
01:04:03:WU00:FS02:0x22:Project: 17804 (Run 42, Clone 84, Gen 18)
01:04:03:WU00:FS02:0x22:Unit: 0x00000000000000000000000000000000
01:04:03:WU00:FS02:0x22:Reading tar file core.xml
01:04:03:WU00:FS02:0x22:Reading tar file integrator.xml.bz2
01:04:03:WU00:FS02:0x22:Reading tar file state.xml.bz2
01:04:03:WU00:FS02:0x22:Reading tar file system.xml.bz2
01:04:03:WU00:FS02:0x22:Digital signatures verified
01:04:03:WU00:FS02:0x22:Folding@home GPU Core22 Folding@home Core
01:04:03:WU00:FS02:0x22:Version 0.0.13
01:04:03:WU00:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
01:04:03:WU00:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
01:04:03:WU00:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
01:04:03:WU00:FS02:0x22:  Global context and integrator variables write interval: disabled
01:04:03:WU00:FS02:0x22:There are 4 platforms available.
01:04:03:WU00:FS02:0x22:Platform 0: Reference
01:04:03:WU00:FS02:0x22:Platform 1: CPU
01:04:03:WU00:FS02:0x22:Platform 2: OpenCL
01:04:03:WU00:FS02:0x22:  opencl-device 0 specified
01:04:03:WU00:FS02:0x22:Platform 3: CUDA
01:04:03:WU00:FS02:0x22:  cuda-device 0 specified
01:04:08:WU01:FS02:Upload 17.43%
01:04:12:WU00:FS02:0x22:Attempting to create CUDA context:
01:04:12:WU00:FS02:0x22:  Configuring platform CUDA
01:04:14:WU01:FS02:Upload 37.04%
01:04:20:WU01:FS02:Upload 57.37%
01:04:22:WU00:FS02:0x22:  Using CUDA and gpu 0
01:04:22:WU00:FS02:0x22:Completed 0 out of 2500000 steps (0%)
01:04:23:WU00:FS02:0x22:Checkpoint completed at step 0
01:04:26:WU01:FS02:Upload 76.98%
01:04:32:WU01:FS02:Upload 96.59%
01:04:33:WU01:FS02:Upload complete
01:04:33:WU01:FS02:Server responded WORK_ACK (400)
01:04:33:WU01:FS02:Final credit estimate, 75438.00 points
01:04:33:WU01:FS02:Cleaning up
01:05:07:WU02:FS00:0xa8:Completed 825000 out of 2500000 steps (33%)
01:10:10:WU00:FS02:0x22:Completed 25000 out of 2500000 steps (1%)
01:13:47:WU02:FS00:0xa8:Completed 850000 out of 2500000 steps (34%)
01:15:55:WU00:FS02:0x22:Completed 50000 out of 2500000 steps (2%)
01:21:41:WU00:FS02:0x22:Completed 75000 out of 2500000 steps (3%)
01:22:32:WU02:FS00:0xa8:Completed 875000 out of 2500000 steps (35%)
01:27:27:WU00:FS02:0x22:Completed 100000 out of 2500000 steps (4%)
01:31:17:WU02:FS00:0xa8:Completed 900000 out of 2500000 steps (36%)
01:33:12:WU00:FS02:0x22:Completed 125000 out of 2500000 steps (5%)
01:33:13:WU00:FS02:0x22:Checkpoint completed at step 125000
01:38:59:WU00:FS02:0x22:Completed 150000 out of 2500000 steps (6%)
01:40:03:WU02:FS00:0xa8:Completed 925000 out of 2500000 steps (37%)
01:44:44:WU00:FS02:0x22:Completed 175000 out of 2500000 steps (7%)
01:48:51:WU02:FS00:0xa8:Completed 950000 out of 2500000 steps (38%)
01:50:30:WU00:FS02:0x22:Completed 200000 out of 2500000 steps (8%)
01:56:16:WU00:FS02:0x22:Completed 225000 out of 2500000 steps (9%)
01:57:37:WU02:FS00:0xa8:Completed 975000 out of 2500000 steps (39%)
02:02:02:WU00:FS02:0x22:Completed 250000 out of 2500000 steps (10%)
02:02:02:WU00:FS02:0x22:Checkpoint completed at step 250000
02:06:26:WU02:FS00:0xa8:Completed 1000000 out of 2500000 steps (40%)
02:07:48:WU00:FS02:0x22:Completed 275000 out of 2500000 steps (11%)
02:13:34:WU00:FS02:0x22:Completed 300000 out of 2500000 steps (12%)
02:15:09:WU02:FS00:0xa8:Completed 1025000 out of 2500000 steps (41%)
02:19:19:WU00:FS02:0x22:Completed 325000 out of 2500000 steps (13%)
02:23:50:WU02:FS00:0xa8:Completed 1050000 out of 2500000 steps (42%)
02:25:05:WU00:FS02:0x22:Completed 350000 out of 2500000 steps (14%)
02:30:50:WU00:FS02:0x22:Completed 375000 out of 2500000 steps (15%)
02:30:51:WU00:FS02:0x22:Checkpoint completed at step 375000
02:32:30:WU02:FS00:0xa8:Completed 1075000 out of 2500000 steps (43%)
02:36:36:WU00:FS02:0x22:Completed 400000 out of 2500000 steps (16%)
02:41:11:WU02:FS00:0xa8:Completed 1100000 out of 2500000 steps (44%)
02:42:22:WU00:FS02:0x22:Completed 425000 out of 2500000 steps (17%)
******************************* Date: 2021-05-17 *******************************
02:48:07:WU00:FS02:0x22:Completed 450000 out of 2500000 steps (18%)
02:49:51:WU02:FS00:0xa8:Completed 1125000 out of 2500000 steps (45%)
02:53:53:WU00:FS02:0x22:Completed 475000 out of 2500000 steps (19%)
02:58:35:WU02:FS00:0xa8:Completed 1150000 out of 2500000 steps (46%)
02:59:39:WU00:FS02:0x22:Completed 500000 out of 2500000 steps (20%)
02:59:40:WU00:FS02:0x22:Checkpoint completed at step 500000
03:05:25:WU00:FS02:0x22:Completed 525000 out of 2500000 steps (21%)
03:07:19:WU02:FS00:0xa8:Completed 1175000 out of 2500000 steps (47%)
03:11:11:WU00:FS02:0x22:Completed 550000 out of 2500000 steps (22%)
03:16:02:WU02:FS00:0xa8:Completed 1200000 out of 2500000 steps (48%)
03:16:57:WU00:FS02:0x22:Completed 575000 out of 2500000 steps (23%)
03:22:43:WU00:FS02:0x22:Completed 600000 out of 2500000 steps (24%)
03:24:46:WU02:FS00:0xa8:Completed 1225000 out of 2500000 steps (49%)
03:28:28:WU00:FS02:0x22:Completed 625000 out of 2500000 steps (25%)
03:28:29:WU00:FS02:0x22:Checkpoint completed at step 625000
03:33:30:WU02:FS00:0xa8:Completed 1250000 out of 2500000 steps (50%)
03:34:15:WU00:FS02:0x22:Completed 650000 out of 2500000 steps (26%)
03:40:01:WU00:FS02:0x22:Completed 675000 out of 2500000 steps (27%)
03:42:15:WU02:FS00:0xa8:Completed 1275000 out of 2500000 steps (51%)
03:45:47:WU00:FS02:0x22:Completed 700000 out of 2500000 steps (28%)
03:51:02:WU02:FS00:0xa8:Completed 1300000 out of 2500000 steps (52%)
03:51:32:WU00:FS02:0x22:Completed 725000 out of 2500000 steps (29%)
03:57:18:WU00:FS02:0x22:Completed 750000 out of 2500000 steps (30%)
03:57:19:WU00:FS02:0x22:Checkpoint completed at step 750000
03:59:48:WU02:FS00:0xa8:Completed 1325000 out of 2500000 steps (53%)
04:03:04:WU00:FS02:0x22:Completed 775000 out of 2500000 steps (31%)
04:08:34:WU02:FS00:0xa8:Completed 1350000 out of 2500000 steps (54%)
04:08:50:WU00:FS02:0x22:Completed 800000 out of 2500000 steps (32%)
04:14:35:WU00:FS02:0x22:Completed 825000 out of 2500000 steps (33%)
04:17:20:WU02:FS00:0xa8:Completed 1375000 out of 2500000 steps (55%)
04:20:21:WU00:FS02:0x22:Completed 850000 out of 2500000 steps (34%)
04:26:05:WU02:FS00:0xa8:Completed 1400000 out of 2500000 steps (56%)
04:26:06:WU00:FS02:0x22:Completed 875000 out of 2500000 steps (35%)
04:26:07:WU00:FS02:0x22:Checkpoint completed at step 875000
04:29:17:181:127.0.0.1:New Web session
04:31:56:WU00:FS02:0x22:Completed 900000 out of 2500000 steps (36%)
04:33:47:190:127.0.0.1:New Web session
04:35:43:WU02:FS00:0xa8:Completed 1425000 out of 2500000 steps (57%)
04:37:45:WU00:FS02:0x22:Completed 925000 out of 2500000 steps (37%)
04:41:58:198:127.0.0.1:New Web session
04:43:34:WU00:FS02:0x22:Completed 950000 out of 2500000 steps (38%)
PaulTV
Re: points
Post by PaulTV »
Hi Rupesh,
There's a known issue that the link from web control to the stats page doesn't work, either the former should send the donor ID, or the latter should accept the name. Your page on the old stats system is https://statsclassic.foldingathome.org/ ... JzvivbW8pt. Your page on the new stats system is https://stats.foldingathome.org/donor/513524864 (found by looking up your user name). On those sites you can see that you have returned 2 WUs so far.
As for the folding results, you can look up those lines:
By entering the project/run/clone/gen numbers on https://apps.foldingathome.org/wu#proje ... e=8&gen=18, you can see that the WU is credited to you. You'll see that the credit estimate in the logging is far higher than on the WU status site, that's because you have to have returned 10+ WUs with a success rate of 80% to be eligible for the quick return bonus. You can check your bonus status on https://apps.foldingathome.org/bonus?us ... JzvivbW8pt.
rupesh.kokal
Re: points
Post by rupesh.kokal »
When 10 WUs are completed, would the bonus points show up for those 10 WUs?
Also does this WUs count which were completed, would get reset in the next week?
Thanks in advance.
Re: points
No, you get bonus points for all WUs completed after the first 10 as long as you maintain an 80% or better return rate. This does not get reset each week.
belloq
Re: points
Post by belloq »
I'm noticing that my mobile GPU is getting a lot of WUs from Project 17434, but the credit being given in the Recent CPUs lookup is about 64k per WU instead of the estimate from the log file of 87k. This difference has been pretty consistent. I realize the server is the final authority on the credit given, but any ideas on why this is so consistently inconsistent?
EDIT
Or ... hmmm. I am seeing https://apps.foldingathome.org/wu#proje ... 380&gen=83 say I returned that WU back in March, but the CPUs page shows me with that lower credit from today. https://apps.foldingathome.org/cpu?q=belloq.
The log is showing errors in the processing. Maybe that's the difference here.
21:35:31:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:17804 run:39 clone:120 gen:26 core:0x22 unit:0x000000780000001a0000458c00000027
21:39:33:WU00:FS02:0x22:Completed 2500000 out of 2500000 steps (100%)
21:39:33:WU00:FS02:0x22:Average performance: 6.83544 ns/day
21:39:35:WU00:FS02:0x22:Checkpoint completed at step 2500000
21:39:55:WU00:FS02:0x22:Saving result file ..\logfile_01.txt
21:39:55:WU00:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
21:39:55:WU00:FS02:0x22:Saving result file checkpointState.xml.bz2
21:39:55:WU00:FS02:0x22:Saving result file positions.xtc
21:39:55:WU00:FS02:0x22:Saving result file science.log
21:39:55:WU00:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:39:56:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:39:56:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:17804 run:60 clone:20 gen:42 core:0x22 unit:0x000000140000002a0000458c0000003c
21:39:56:WU00:FS02:Uploading 8.60MiB to 207.53.233.146
21:39:56:WU00:FS02:Connecting to 207.53.233.146:8080
21:39:56:WU02:FS02:Starting
21:39:56:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9424 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
21:39:57:WU02:FS02:Started FahCore on PID 11920
21:39:58:WU02:FS02:Core PID:32084
21:39:58:WU02:FS02:FahCore 0x22 started
21:39:58:WU02:FS02:0x22:*********************** Log Started 2021-05-24T21:39:58Z ***********************
21:39:58:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:39:58:WU02:FS02:0x22:       Core: Core22
21:39:58:WU02:FS02:0x22:       Type: 0x22
21:39:58:WU02:FS02:0x22:    Version: 0.0.13
21:39:58:WU02:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:39:58:WU02:FS02:0x22:  Copyright: 2020 foldingathome.org
21:39:58:WU02:FS02:0x22:   Homepage: https://foldingathome.org/
21:39:58:WU02:FS02:0x22:       Date: Sep 19 2020
21:39:58:WU02:FS02:0x22:       Time: 02:35:58
21:39:58:WU02:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
21:39:58:WU02:FS02:0x22:     Branch: core22-0.0.13
21:39:58:WU02:FS02:0x22:   Compiler: Visual C++ 2015
21:39:58:WU02:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:39:58:WU02:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
21:39:58:WU02:FS02:0x22:   Platform: win32 10
21:39:58:WU02:FS02:0x22:       Bits: 64
21:39:58:WU02:FS02:0x22:       Mode: Release
21:39:58:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:39:58:WU02:FS02:0x22:             <peastman@stanford.edu>
21:39:58:WU02:FS02:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 11920 -checkpoint 15
21:39:58:WU02:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
21:39:58:WU02:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
21:39:58:WU02:FS02:0x22:************************************ libFAH ************************************
21:39:58:WU02:FS02:0x22:       Date: Sep 7 2020
21:39:58:WU02:FS02:0x22:       Time: 19:09:56
21:39:58:WU02:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
21:39:58:WU02:FS02:0x22:     Branch: HEAD
21:39:58:WU02:FS02:0x22:************************************ CBang *************************************
21:39:58:WU02:FS02:0x22:       Time: 19:08:30
21:39:58:WU02:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
21:39:58:WU02:FS02:0x22:************************************ System ************************************
21:39:58:WU02:FS02:0x22:        CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
21:39:58:WU02:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
21:39:58:WU02:FS02:0x22:       CPUs: 12
21:39:58:WU02:FS02:0x22:     Memory: 31.71GiB
21:39:58:WU02:FS02:0x22:Free Memory: 17.10GiB
21:39:58:WU02:FS02:0x22:    Threads: WINDOWS_THREADS
21:39:58:WU02:FS02:0x22: OS Version: 6.2
21:39:58:WU02:FS02:0x22:Has Battery: true
21:39:58:WU02:FS02:0x22: On Battery: false
21:39:58:WU02:FS02:0x22: UTC Offset: -7
21:39:58:WU02:FS02:0x22:        PID: 32084
21:39:58:WU02:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
21:39:58:WU02:FS02:0x22:************************************ OpenMM ************************************
21:39:58:WU02:FS02:0x22:   Revision: 189320d0
21:39:58:WU02:FS02:0x22:********************************************************************************
21:39:58:WU02:FS02:0x22:Project: 17804 (Run 39, Clone 120, Gen 26)
21:39:58:WU02:FS02:0x22:Unit: 0x00000000000000000000000000000000
21:39:58:WU02:FS02:0x22:Reading tar file core.xml
21:39:58:WU02:FS02:0x22:Reading tar file integrator.xml.bz2
21:39:58:WU02:FS02:0x22:Reading tar file state.xml.bz2
21:39:58:WU02:FS02:0x22:Reading tar file system.xml.bz2
21:39:58:WU02:FS02:0x22:Digital signatures verified
21:39:58:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:39:58:WU02:FS02:0x22:Version 0.0.13
21:39:59:WU02:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
21:39:59:WU02:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
21:39:59:WU02:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
21:39:59:WU02:FS02:0x22:  Global context and integrator variables write interval: disabled
21:39:59:WU02:FS02:0x22:There are 4 platforms available.
21:39:59:WU02:FS02:0x22:Platform 0: Reference
21:39:59:WU02:FS02:0x22:Platform 1: CPU
21:39:59:WU02:FS02:0x22:Platform 2: OpenCL
21:39:59:WU02:FS02:0x22:  opencl-device 0 specified
21:39:59:WU02:FS02:0x22:Platform 3: CUDA
21:39:59:WU02:FS02:0x22:  cuda-device 0 specified
21:40:02:WU00:FS02:Upload 7.99%
21:40:05:WU02:FS02:0x22:Attempting to create CUDA context:
21:40:05:WU02:FS02:0x22:  Configuring platform CUDA
21:40:08:WU00:FS02:Upload 11.62%
21:40:09:WU02:FS02:0x22:  Using CUDA and gpu 0
21:40:09:WU02:FS02:0x22:Completed 0 out of 2500000 steps (0%)
21:40:10:WU02:FS02:0x22:Checkpoint completed at step 0
21:40:14:WU00:FS02:Upload 15.26%
21:40:20:WU00:FS02:Upload 20.34%
21:40:26:WU00:FS02:Upload 25.43%
21:40:32:WU00:FS02:Upload 29.06%
21:40:38:WU00:FS02:Upload 33.42%
21:40:44:WU00:FS02:Upload 39.96%
21:40:50:WU00:FS02:Upload 44.32%
21:40:56:WU00:FS02:Upload 47.95%
21:41:04:WU00:FS02:Upload 50.85%
21:41:11:WU00:FS02:Upload 53.76%
21:41:17:WU00:FS02:Upload 54.49%
21:41:23:WU00:FS02:Upload 57.39%
21:41:31:WU00:FS02:Upload 59.57%
21:41:37:WU00:FS02:Upload 63.93%
21:41:43:WU00:FS02:Upload 73.38%
21:41:49:WU00:FS02:Upload 83.55%
21:41:55:WU00:FS02:Upload 94.44%
21:41:58:WU00:FS02:Upload complete
21:41:58:WU00:FS02:Server responded WORK_ACK (400)
21:41:58:WU00:FS02:Final credit estimate, 88626.00 points
21:41:58:WU00:FS02:Cleaning up
21:44:20:WU02:FS02:0x22:Completed 25000 out of 2500000 steps (1%)
21:48:29:WU02:FS02:0x22:Completed 50000 out of 2500000 steps (2%)
21:52:40:WU02:FS02:0x22:Completed 75000 out of 2500000 steps (3%)
21:56:48:WU02:FS02:0x22:Completed 100000 out of 2500000 steps (4%)
22:00:58:WU02:FS02:0x22:Completed 125000 out of 2500000 steps (5%)
22:00:59:WU02:FS02:0x22:Checkpoint completed at step 125000
22:05:13:WU02:FS02:0x22:Completed 150000 out of 2500000 steps (6%)
22:09:22:WU02:FS02:0x22:Completed 175000 out of 2500000 steps (7%)
22:13:31:WU02:FS02:0x22:Completed 200000 out of 2500000 steps (8%)
22:17:40:WU02:FS02:0x22:Completed 225000 out of 2500000 steps (9%)
22:21:55:WU02:FS02:0x22:Completed 250000 out of 2500000 steps (10%)
22:21:58:WU02:FS02:0x22:Checkpoint completed at step 250000
22:26:12:WU02:FS02:0x22:Completed 275000 out of 2500000 steps (11%)
22:30:21:WU02:FS02:0x22:Completed 300000 out of 2500000 steps (12%)
22:34:33:WU02:FS02:0x22:Completed 325000 out of 2500000 steps (13%)
22:38:46:WU02:FS02:0x22:Completed 350000 out of 2500000 steps (14%)
22:42:57:WU02:FS02:0x22:Completed 375000 out of 2500000 steps (15%)
22:43:00:WU02:FS02:0x22:Checkpoint completed at step 375000
22:47:15:WU02:FS02:0x22:Completed 400000 out of 2500000 steps (16%)
22:51:39:WU02:FS02:0x22:Completed 425000 out of 2500000 steps (17%)
22:55:58:WU02:FS02:0x22:Completed 450000 out of 2500000 steps (18%)
23:00:09:WU02:FS02:0x22:Completed 475000 out of 2500000 steps (19%)
23:04:20:WU02:FS02:0x22:Completed 500000 out of 2500000 steps (20%)
23:04:23:WU02:FS02:0x22:Checkpoint completed at step 500000
23:08:34:WU02:FS02:0x22:Completed 525000 out of 2500000 steps (21%)
23:12:43:WU02:FS02:0x22:Completed 550000 out of 2500000 steps (22%)
23:16:52:WU02:FS02:0x22:Completed 575000 out of 2500000 steps (23%)
23:21:02:WU02:FS02:0x22:Completed 600000 out of 2500000 steps (24%)
23:25:12:WU02:FS02:0x22:Completed 625000 out of 2500000 steps (25%)
23:25:15:WU02:FS02:0x22:Checkpoint completed at step 625000
23:29:23:WU02:FS02:0x22:Completed 650000 out of 2500000 steps (26%)
23:33:32:WU02:FS02:0x22:Completed 675000 out of 2500000 steps (27%)
23:37:40:WU02:FS02:0x22:Completed 700000 out of 2500000 steps (28%)
23:41:54:WU02:FS02:0x22:Completed 725000 out of 2500000 steps (29%)
23:46:10:WU02:FS02:0x22:Completed 750000 out of 2500000 steps (30%)
23:46:11:WU02:FS02:0x22:Checkpoint completed at step 750000
23:50:27:WU02:FS02:0x22:Completed 775000 out of 2500000 steps (31%)
23:54:51:WU02:FS02:0x22:Completed 800000 out of 2500000 steps (32%)
23:59:20:WU02:FS02:0x22:Completed 825000 out of 2500000 steps (33%)
00:02:53:WU02:FS02:0x22:An exception occurred at step 846024: Error downloading array energySum: CUDA_ERROR_LAUNCH_FAILED (719)
00:02:53:WU02:FS02:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
00:02:53:WU02:FS02:0x22:Folding@home Core Shutdown: CORE_RESTART
00:02:58:WARNING:WU02:FS02:FahCore returned an unknown error code which probably indicates that it crashed
00:02:58:WARNING:WU02:FS02:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
00:02:59:WU02:FS02:Starting
00:02:59:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 9424 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
00:02:59:WU02:FS02:Started FahCore on PID 6824
00:03:01:WU02:FS02:Core PID:34492
00:03:01:WU02:FS02:FahCore 0x22 started
00:03:01:WU02:FS02:0x22:*********************** Log Started 2021-05-25T00:03:01Z ***********************
00:03:01:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
00:03:01:WU02:FS02:0x22:       Core: Core22
00:03:01:WU02:FS02:0x22:       Type: 0x22
00:03:01:WU02:FS02:0x22:    Version: 0.0.13
00:03:01:WU02:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:03:01:WU02:FS02:0x22:  Copyright: 2020 foldingathome.org
00:03:02:WU02:FS02:0x22:   Homepage: https://foldingathome.org/
00:03:02:WU02:FS02:0x22:       Date: Sep 19 2020
00:03:02:WU02:FS02:0x22:       Time: 02:35:58
00:03:02:WU02:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:03:02:WU02:FS02:0x22:     Branch: core22-0.0.13
00:03:02:WU02:FS02:0x22:   Compiler: Visual C++ 2015
00:03:02:WU02:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:03:02:WU02:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
00:03:02:WU02:FS02:0x22:   Platform: win32 10
00:03:02:WU02:FS02:0x22:       Bits: 64
00:03:02:WU02:FS02:0x22:       Mode: Release
00:03:02:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:03:02:WU02:FS02:0x22:             <peastman@stanford.edu>
00:03:02:WU02:FS02:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 6824 -checkpoint 15
00:03:02:WU02:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
00:03:02:WU02:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
00:03:02:WU02:FS02:0x22:************************************ libFAH ************************************
00:03:02:WU02:FS02:0x22:       Date: Sep 7 2020
00:03:02:WU02:FS02:0x22:       Time: 19:09:56
00:03:02:WU02:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:03:02:WU02:FS02:0x22:     Branch: HEAD
00:03:02:WU02:FS02:0x22:************************************ CBang *************************************
00:03:02:WU02:FS02:0x22:       Time: 19:08:30
00:03:02:WU02:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:03:02:WU02:FS02:0x22:************************************ System ************************************
00:03:02:WU02:FS02:0x22:        CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
00:03:02:WU02:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
00:03:02:WU02:FS02:0x22:       CPUs: 12
00:03:02:WU02:FS02:0x22:     Memory: 31.71GiB
00:03:02:WU02:FS02:0x22:Free Memory: 14.93GiB
00:03:02:WU02:FS02:0x22:    Threads: WINDOWS_THREADS
00:03:02:WU02:FS02:0x22: OS Version: 6.2
00:03:02:WU02:FS02:0x22:Has Battery: true
00:03:02:WU02:FS02:0x22: On Battery: false
00:03:02:WU02:FS02:0x22: UTC Offset: -7
00:03:02:WU02:FS02:0x22:        PID: 34492
00:03:02:WU02:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
00:03:02:WU02:FS02:0x22:************************************ OpenMM ************************************
00:03:02:WU02:FS02:0x22:   Revision: 189320d0
00:03:02:WU02:FS02:0x22:********************************************************************************
00:03:02:WU02:FS02:0x22:Project: 17804 (Run 39, Clone 120, Gen 26)
00:03:02:WU02:FS02:0x22:Unit: 0x00000000000000000000000000000000
00:03:02:WU02:FS02:0x22:Digital signatures verified
00:03:02:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
00:03:02:WU02:FS02:0x22:Version 0.0.13
00:03:03:WU02:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
00:03:03:WU02:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
00:03:03:WU02:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
00:03:03:WU02:FS02:0x22:  Global context and integrator variables write interval: disabled
00:03:03:WU02:FS02:0x22:There are 4 platforms available.
00:03:03:WU02:FS02:0x22:Platform 0: Reference
00:03:03:WU02:FS02:0x22:Platform 1: CPU
00:03:03:WU02:FS02:0x22:Platform 2: OpenCL
00:03:03:WU02:FS02:0x22:  opencl-device 0 specified
00:03:03:WU02:FS02:0x22:Platform 3: CUDA
00:03:03:WU02:FS02:0x22:  cuda-device 0 specified
00:03:14:WU02:FS02:0x22:Attempting to create CUDA context:
00:03:14:WU02:FS02:0x22:  Configuring platform CUDA
00:03:17:WU02:FS02:0x22:  Using CUDA and gpu 0
00:03:17:WU02:FS02:0x22:Completed 750000 out of 2500000 steps (30%)
00:07:26:WU02:FS02:0x22:Completed 775000 out of 2500000 steps (31%)
00:11:43:WU02:FS02:0x22:Completed 800000 out of 2500000 steps (32%)
00:15:55:WU02:FS02:0x22:Completed 825000 out of 2500000 steps (33%)
00:20:16:WU02:FS02:0x22:Completed 850000 out of 2500000 steps (34%)
00:24:36:WU02:FS02:0x22:Completed 875000 out of 2500000 steps (35%)
00:24:41:WU02:FS02:0x22:Checkpoint completed at step 875000
00:29:00:WU02:FS02:0x22:Completed 900000 out of 2500000 steps (36%)
00:33:15:WU02:FS02:0x22:Completed 925000 out of 2500000 steps (37%)
00:37:29:WU02:FS02:0x22:Completed 950000 out of 2500000 steps (38%)
00:41:40:WU02:FS02:0x22:Completed 975000 out of 2500000 steps (39%)
00:46:00:WU02:FS02:0x22:Completed 1000000 out of 2500000 steps (40%)
00:46:02:WU02:FS02:0x22:Checkpoint completed at step 1000000
00:50:13:WU02:FS02:0x22:Completed 1025000 out of 2500000 steps (41%)
00:54:32:WU02:FS02:0x22:Completed 1050000 out of 2500000 steps (42%)
00:59:03:WU02:FS02:0x22:Completed 1075000 out of 2500000 steps (43%)
01:03:20:WU02:FS02:0x22:Completed 1100000 out of 2500000 steps (44%)
01:07:37:WU02:FS02:0x22:Completed 1125000 out of 2500000 steps (45%)
01:07:40:WU02:FS02:0x22:Checkpoint completed at step 1125000
01:12:02:WU02:FS02:0x22:Completed 1150000 out of 2500000 steps (46%)
01:16:28:WU02:FS02:0x22:Completed 1175000 out of 2500000 steps (47%)
01:20:43:WU02:FS02:0x22:Completed 1200000 out of 2500000 steps (48%)
01:24:58:WU02:FS02:0x22:Completed 1225000 out of 2500000 steps (49%)
01:29:15:WU02:FS02:0x22:Completed 1250000 out of 2500000 steps (50%)
01:29:17:WU02:FS02:0x22:Checkpoint completed at step 1250000
01:33:36:WU02:FS02:0x22:Completed 1275000 out of 2500000 steps (51%)
01:37:49:WU02:FS02:0x22:Completed 1300000 out of 2500000 steps (52%)
01:42:03:WU02:FS02:0x22:Completed 1325000 out of 2500000 steps (53%)
01:46:19:WU02:FS02:0x22:Completed 1350000 out of 2500000 steps (54%)
01:50:33:WU02:FS02:0x22:Completed 1375000 out of 2500000 steps (55%)
01:50:35:WU02:FS02:0x22:Checkpoint completed at step 1375000
01:54:45:WU02:FS02:0x22:Completed 1400000 out of 2500000 steps (56%)
01:58:54:WU02:FS02:0x22:Completed 1425000 out of 2500000 steps (57%)
02:03:07:WU02:FS02:0x22:Completed 1450000 out of 2500000 steps (58%)
02:07:16:WU02:FS02:0x22:Completed 1475000 out of 2500000 steps (59%)
20:06:48:WU00:FS02:0x22:Completed 1975000 out of 2500000 steps (79%)
20:12:11:WU00:FS02:0x22:Completed 2000000 out of 2500000 steps (80%)
20:12:14:WU00:FS02:0x22:Checkpoint completed at step 2000000
******************************* Date: 2021-05-24 *******************************
20:16:36:WU00:FS02:0x22:Completed 2025000 out of 2500000 steps (81%)
20:20:54:WU00:FS02:0x22:Completed 2050000 out of 2500000 steps (82%)
20:25:06:WU00:FS02:0x22:Completed 2075000 out of 2500000 steps (83%)
20:29:21:WU00:FS02:0x22:Completed 2100000 out of 2500000 steps (84%)
20:33:41:WU00:FS02:0x22:Completed 2125000 out of 2500000 steps (85%)
20:33:45:WU00:FS02:0x22:Checkpoint completed at step 2125000
20:38:07:WU00:FS02:0x22:Completed 2150000 out of 2500000 steps (86%)
20:42:28:WU00:FS02:0x22:Completed 2175000 out of 2500000 steps (87%)
20:47:09:WU00:FS02:0x22:Completed 2200000 out of 2500000 steps (88%)
20:51:33:WU00:FS02:0x22:Completed 2225000 out of 2500000 steps (89%)
20:55:46:WU00:FS02:0x22:Completed 2250000 out of 2500000 steps (90%)
20:55:48:WU00:FS02:0x22:Checkpoint completed at step 2250000
21:00:01:WU00:FS02:0x22:Completed 2275000 out of 2500000 steps (91%)
21:04:33:WU00:FS02:0x22:Completed 2300000 out of 2500000 steps (92%)
21:09:12:WU00:FS02:0x22:Completed 2325000 out of 2500000 steps (93%)
21:13:38:WU00:FS02:0x22:Completed 2350000 out of 2500000 steps (94%)
21:18:26:WU00:FS02:0x22:Completed 2375000 out of 2500000 steps (95%)
21:18:29:WU00:FS02:0x22:Checkpoint completed at step 2375000
21:22:46:WU00:FS02:0x22:Completed 2400000 out of 2500000 steps (96%)
21:26:58:WU00:FS02:0x22:Completed 2425000 out of 2500000 steps (97%)
21:31:08:WU00:FS02:0x22:Completed 2450000 out of 2500000 steps (98%)
21:35:22:WU00:FS02:0x22:Completed 2475000 out of 2500000 steps (99%)
21:35:22:WU02:FS02:Connecting to assign1.foldingathome.org:80
21:35:23:WU02:FS02:Assigned to work server 207.53.233.146
21:35:23:WU02:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117GLM [Quadro T2000 Mobile / Max-Q] from 207.53.233.146
21:35:23:WU02:FS02:Connecting to 207.53.233.146:8080
21:35:24:WU02:FS02:Downloading 6.14MiB
21:35:30:WU02:FS02:Download 78.35%
21:35:31:WU02:FS02:Download complete
02:11:26:WU02:FS02:0x22:Completed 1500000 out of 2500000 steps (60%)
02:11:28:WU02:FS02:0x22:Checkpoint completed at step 1500000
02:15:38:WU02:FS02:0x22:Completed 1525000 out of 2500000 steps (61%)
******************************* Date: 2021-05-25 *******************************
02:19:50:WU02:FS02:0x22:Completed 1550000 out of 2500000 steps (62%)
02:23:58:WU02:FS02:0x22:Completed 1575000 out of 2500000 steps (63%)
02:28:07:WU02:FS02:0x22:Completed 1600000 out of 2500000 steps (64%)
02:32:16:WU02:FS02:0x22:Completed 1625000 out of 2500000 steps (65%)
02:32:18:WU02:FS02:0x22:Checkpoint completed at step 1625000
02:36:30:WU02:FS02:0x22:Completed 1650000 out of 2500000 steps (66%)
02:40:38:WU02:FS02:0x22:Completed 1675000 out of 2500000 steps (67%)
02:44:47:WU02:FS02:0x22:Completed 1700000 out of 2500000 steps (68%)
02:48:55:WU02:FS02:0x22:Completed 1725000 out of 2500000 steps (69%)
02:53:07:WU02:FS02:0x22:Completed 1750000 out of 2500000 steps (70%)
02:53:08:WU02:FS02:0x22:Checkpoint completed at step 1750000
02:57:16:WU02:FS02:0x22:Completed 1775000 out of 2500000 steps (71%)
03:01:25:WU02:FS02:0x22:Completed 1800000 out of 2500000 steps (72%)
03:05:36:WU02:FS02:0x22:Completed 1825000 out of 2500000 steps (73%)
03:09:45:WU02:FS02:0x22:Completed 1850000 out of 2500000 steps (74%)
03:13:53:WU02:FS02:0x22:Completed 1875000 out of 2500000 steps (75%)
03:13:55:WU02:FS02:0x22:Checkpoint completed at step 1875000
03:18:05:WU02:FS02:0x22:Completed 1900000 out of 2500000 steps (76%)
03:22:16:WU02:FS02:0x22:Completed 1925000 out of 2500000 steps (77%)
03:26:24:WU02:FS02:0x22:Completed 1950000 out of 2500000 steps (78%)
03:30:32:WU02:FS02:0x22:Completed 1975000 out of 2500000 steps (79%)
03:34:41:WU02:FS02:0x22:Completed 2000000 out of 2500000 steps (80%)
03:34:43:WU02:FS02:0x22:Checkpoint completed at step 2000000
03:38:55:WU02:FS02:0x22:Completed 2025000 out of 2500000 steps (81%)
03:43:04:WU02:FS02:0x22:Completed 2050000 out of 2500000 steps (82%)
03:47:13:WU02:FS02:0x22:Completed 2075000 out of 2500000 steps (83%)
03:51:21:WU02:FS02:0x22:Completed 2100000 out of 2500000 steps (84%)
03:55:31:WU02:FS02:0x22:Completed 2125000 out of 2500000 steps (85%)
03:55:33:WU02:FS02:0x22:Checkpoint completed at step 2125000
03:59:41:WU02:FS02:0x22:Completed 2150000 out of 2500000 steps (86%)
04:03:50:WU02:FS02:0x22:Completed 2175000 out of 2500000 steps (87%)
04:07:58:WU02:FS02:0x22:Completed 2200000 out of 2500000 steps (88%)
04:12:10:WU02:FS02:0x22:Completed 2225000 out of 2500000 steps (89%)
04:16:18:WU02:FS02:0x22:Completed 2250000 out of 2500000 steps (90%)
04:16:20:WU02:FS02:0x22:Checkpoint completed at step 2250000
04:20:28:WU02:FS02:0x22:Completed 2275000 out of 2500000 steps (91%)
04:24:39:WU02:FS02:0x22:Completed 2300000 out of 2500000 steps (92%)
04:28:48:WU02:FS02:0x22:Completed 2325000 out of 2500000 steps (93%)
04:32:56:WU02:FS02:0x22:Completed 2350000 out of 2500000 steps (94%)
04:37:04:WU02:FS02:0x22:Completed 2375000 out of 2500000 steps (95%)
04:37:06:WU02:FS02:0x22:Checkpoint completed at step 2375000
04:41:18:WU02:FS02:0x22:Completed 2400000 out of 2500000 steps (96%)
04:45:29:WU02:FS02:0x22:Completed 2425000 out of 2500000 steps (97%)
04:49:43:WU02:FS02:0x22:Completed 2450000 out of 2500000 steps (98%)
04:54:00:WU02:FS02:0x22:Completed 2475000 out of 2500000 steps (99%)
04:54:02:WU01:FS02:Connecting to assign1.foldingathome.org:80
04:54:03:WU01:FS02:Assigned to work server 207.53.233.146
04:54:03:WU01:FS02:Requesting new work unit for slot 02: gpu:1:0 TU117GLM [Quadro T2000 Mobile / Max-Q] from 207.53.233.146
04:54:03:WU01:FS02:Connecting to 207.53.233.146:8080
04:54:03:WU01:FS02:Downloading 6.14MiB
04:54:08:WU01:FS02:Download complete
04:54:08:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17804 run:39 clone:194 gen:29 core:0x22 unit:0x000000c20000001d0000458c00000027
04:58:14:WU02:FS02:0x22:Completed 2500000 out of 2500000 steps (100%)
04:58:14:WU02:FS02:0x22:Average performance: 6.81388 ns/day
04:58:16:WU02:FS02:0x22:Checkpoint completed at step 2500000
04:58:32:WU02:FS02:0x22:Saving result file ..\logfile_01.txt
04:58:32:WU02:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
04:58:32:WU02:FS02:0x22:Saving result file checkpointState.xml.bz2
04:58:32:WU02:FS02:0x22:Saving result file positions.xtc
04:58:32:WU02:FS02:0x22:Saving result file science.log
04:58:32:WU02:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
04:58:34:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:58:34:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:17804 run:39 clone:120 gen:26 core:0x22 unit:0x000000780000001a0000458c00000027
04:58:34:WU02:FS02:Uploading 8.58MiB to 207.53.233.146
04:58:34:WU02:FS02:Connecting to 207.53.233.146:8080
04:58:34:WU01:FS02:Starting
04:58:34:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 9424 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
04:58:35:WU01:FS02:Started FahCore on PID 31772
04:58:36:WU01:FS02:Core PID:3916
04:58:36:WU01:FS02:FahCore 0x22 started
04:58:36:WU01:FS02:0x22:*********************** Log Started 2021-05-25T04:58:36Z ***********************
04:58:36:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
04:58:36:WU01:FS02:0x22:       Core: Core22
04:58:36:WU01:FS02:0x22:       Type: 0x22
04:58:36:WU01:FS02:0x22:    Version: 0.0.13
04:58:36:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:58:36:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
04:58:36:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
04:58:36:WU01:FS02:0x22:       Date: Sep 19 2020
04:58:36:WU01:FS02:0x22:       Time: 02:35:58
04:58:36:WU01:FS02:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
04:58:36:WU01:FS02:0x22:     Branch: core22-0.0.13
04:58:36:WU01:FS02:0x22:   Compiler: Visual C++ 2015
04:58:36:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
04:58:36:WU01:FS02:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
04:58:36:WU01:FS02:0x22:   Platform: win32 10
04:58:36:WU01:FS02:0x22:       Bits: 64
04:58:36:WU01:FS02:0x22:       Mode: Release
04:58:36:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:58:36:WU01:FS02:0x22:             <peastman@stanford.edu>
04:58:36:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 31772 -checkpoint 15
04:58:36:WU01:FS02:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
04:58:36:WU01:FS02:0x22:             nvidia -gpu 0 -gpu-usage 100
04:58:36:WU01:FS02:0x22:************************************ libFAH ************************************
04:58:36:WU01:FS02:0x22:       Date: Sep 7 2020
04:58:36:WU01:FS02:0x22:       Time: 19:09:56
04:58:36:WU01:FS02:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
04:58:36:WU01:FS02:0x22:     Branch: HEAD
04:58:36:WU01:FS02:0x22:************************************ CBang *************************************
04:58:36:WU01:FS02:0x22:       Time: 19:08:30
04:58:36:WU01:FS02:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
04:58:36:WU01:FS02:0x22:************************************ System ************************************
04:58:36:WU01:FS02:0x22:        CPU: Intel(R) Xeon(R) E-2276M CPU @ 2.80GHz
04:58:36:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
04:58:36:WU01:FS02:0x22:       CPUs: 12
04:58:36:WU01:FS02:0x22:     Memory: 31.71GiB
04:58:36:WU01:FS02:0x22:Free Memory: 16.81GiB
04:58:36:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
04:58:36:WU01:FS02:0x22: OS Version: 6.2
04:58:36:WU01:FS02:0x22:Has Battery: true
04:58:36:WU01:FS02:0x22: On Battery: false
04:58:36:WU01:FS02:0x22: UTC Offset: -7
04:58:36:WU01:FS02:0x22:        PID: 3916
04:58:36:WU01:FS02:0x22:        CWD: C:\ProgramData\FAHClient\work
04:58:36:WU01:FS02:0x22:************************************ OpenMM ************************************
04:58:36:WU01:FS02:0x22:   Revision: 189320d0
04:58:36:WU01:FS02:0x22:********************************************************************************
04:58:36:WU01:FS02:0x22:Project: 17804 (Run 39, Clone 194, Gen 29)
04:58:36:WU01:FS02:0x22:Unit: 0x00000000000000000000000000000000
04:58:36:WU01:FS02:0x22:Reading tar file core.xml
04:58:36:WU01:FS02:0x22:Reading tar file integrator.xml.bz2
04:58:36:WU01:FS02:0x22:Reading tar file state.xml.bz2
04:58:36:WU01:FS02:0x22:Reading tar file system.xml.bz2
04:58:36:WU01:FS02:0x22:Digital signatures verified
04:58:36:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
04:58:36:WU01:FS02:0x22:Version 0.0.13
04:58:37:WU01:FS02:0x22:  Checkpoint write interval: 125000 steps (5%) [20 total]
04:58:37:WU01:FS02:0x22:  JSON viewer frame write interval: 25000 steps (1%) [100 total]
04:58:37:WU01:FS02:0x22:  XTC frame write interval: 25000 steps (1%) [100 total]
04:58:37:WU01:FS02:0x22:  Global context and integrator variables write interval: disabled
04:58:37:WU01:FS02:0x22:There are 4 platforms available.
04:58:37:WU01:FS02:0x22:Platform 0: Reference
04:58:37:WU01:FS02:0x22:Platform 1: CPU
04:58:37:WU01:FS02:0x22:Platform 2: OpenCL
04:58:37:WU01:FS02:0x22:  opencl-device 0 specified
04:58:37:WU01:FS02:0x22:Platform 3: CUDA
04:58:37:WU01:FS02:0x22:  cuda-device 0 specified
04:58:40:WU02:FS02:Upload 16.03%
04:58:45:WU01:FS02:0x22:Attempting to create CUDA context:
04:58:45:WU01:FS02:0x22:  Configuring platform CUDA
04:58:46:WU02:FS02:Upload 32.05%
04:58:48:WU01:FS02:0x22:  Using CUDA and gpu 0
04:58:48:WU01:FS02:0x22:Completed 0 out of 2500000 steps (0%)
04:58:49:WU01:FS02:0x22:Checkpoint completed at step 0
04:58:52:WU02:FS02:Upload 48.80%
04:58:58:WU02:FS02:Upload 66.29%
04:59:04:WU02:FS02:Upload 85.23%
04:59:09:WU02:FS02:Upload complete
04:59:09:WU02:FS02:Server responded WORK_ACK (400)
04:59:09:WU02:FS02:Final credit estimate, 87587.00 points
04:59:09:WU02:FS02:Cleaning up
05:02:58:WU01:FS02:0x22:Completed 25000 out of 2500000 steps (1%)
05:07:07:WU01:FS02:0x22:Completed 50000 out of 2500000 steps (2%)
05:11:16:WU01:FS02:0x22:Completed 75000 out of 2500000 steps (3%)
05:15:28:WU01:FS02:0x22:Completed 100000 out of 2500000 steps (4%)
05:19:38:WU01:FS02:0x22:Completed 125000 out of 2500000 steps (5%)
05:19:40:WU01:FS02:0x22:Checkpoint completed at step 125000
05:23:49:WU01:FS02:0x22:Completed 150000 out of 2500000 steps (6%)
05:28:03:WU01:FS02:0x22:Completed 175000 out of 2500000 steps (7%)
05:32:30:WU01:FS02:0x22:Completed 200000 out of 2500000 steps (8%)
05:36:42:WU01:FS02:0x22:Completed 225000 out of 2500000 steps (9%)
05:40:56:WU01:FS02:0x22:Completed 250000 out of 2500000 steps (10%)
05:40:59:WU01:FS02:0x22:Checkpoint completed at step 250000
05:45:16:WU01:FS02:0x22:Completed 275000 out of 2500000 steps (11%)
05:49:30:WU01:FS02:0x22:Completed 300000 out of 2500000 steps (12%)
05:53:42:WU01:FS02:0x22:Completed 325000 out of 2500000 steps (13%)
05:57:54:WU01:FS02:0x22:Completed 350000 out of 2500000 steps (14%)
Though the most recently uploaded was "04:58:34:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:17804 run:39 clone:120 gen:26 core:0x22 unit:0x000000780000001a0000458c00000027" and not what is showing on the CPUs page.
Knish
Re: points
Post by Knish »
I too am noticing inconsistencies on what is shown on the Recent CPUs page. What drew my attention was the non matching points with my logs. On the web page although the Timestamps the WUs were turned in seem to match, the Proj IDs seem way off. The web page displays a 17431, 17432, and 17423 for my recent turn ins (*edit: but if I click on them the WU page says i turned these in back in March), and although the times are right, what I've actually turned in are 18202 run:17726 , 16935 run:5, and 18202 run:16278
when I do a WU check on those, they do return results, so it looks like a weird bug with possibly these projects happening for the Recent CPUs webpage
Re: points
Points don't always get applied immediately. WUs can be uploaded to EITHER the WS or the CS. Either one puts an official timestamp on the results. Later, that information will need to be moved to the WS (which depends to a server-to-server link that you're not responsible for and then moved from the WS to the stats server over another server-to-server link that you're not responsible for. Those inter-server links seem to have had a lot of troubles recently ... and then "magically" they just start to for again. ;)
