Who has a no-gpu system?
Don't get excited. I have noting new to announce. I'm just taking a survey.
Who has a CPU-only system?
I'm looking for people who have no GPUs. Of course I exaggerating a bit. What I really mean is that the only GPU in your system is a Intel iGPU (which is probably disabled with respect to FAH.
Just attach a description of your compute devices. The iGPU must be Gen 7 or greater (i.e.- listed in GPUs.txt).
Jonazz
Re: Who has a no-gpu system?
Post by Jonazz »
I have an Intel Core i5-9400 CPU
The iGPU is Intel UHD Graphics 630.
@Jonazz
Please post the system description from the early part of FAH's log.
We need the hex codes for the CPU and GPU
Intel 0x3e91
Intel 0x3e92
Intel 0x3e98
Intel 0x3e9b
Intel 0x9bc5
Intel 0x9bc8
Jonazz
Post by Jonazz »
Here you go, is this sufficient?
13:10:44:******************************* libFAH ********************************
13:10:44:           Date: Oct 20 2020
13:10:44:           Time: 13:36:55
13:10:44:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
13:10:44:         Branch: master
13:10:44:       Compiler: Visual C++ 2015
13:10:44:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
13:10:44:       Platform: win32 10
13:10:44:           Bits: 32
13:10:44:           Mode: Release
13:10:44:****************************** FAHClient ******************************
13:10:44:        Version: 7.6.21
13:10:44:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:10:44:      Copyright: 2020 foldingathome.org
13:10:44:       Homepage: https://foldingathome.org/
13:10:44:           Time: 13:41:04
13:10:44:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
13:10:44:           Bits: 32
13:10:44:         Config: C:\Users\Beheerder\AppData\Roaming\FAHClient\config.xml
13:10:44:******************************** CBang ********************************
13:10:44:           Time: 11:36:18
13:10:44:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
13:10:44:           Bits: 32
13:10:44:******************************* System ********************************
13:10:44:            CPU: Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz
13:10:44:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
13:10:44:           CPUs: 6
13:10:44:         Memory: 15.87GiB
13:10:44:    Free Memory: 12.11GiB
13:10:44:        Threads: WINDOWS_THREADS
13:10:44:     OS Version: 6.2
13:10:44:    Has Battery: false
13:10:44:     On Battery: false
13:10:44:     UTC Offset: 2
13:10:44:            PID: 13524
13:10:44:            CWD: C:\Users\Beheerder\AppData\Roaming\FAHClient
13:10:44:  Win32 Service: false
13:10:44:             OS: Windows 10 Home
13:10:44:        OS Arch: AMD64
13:10:44:           GPUs: 1
13:10:44:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 CFL GT2 [UHD Graphics 630]
13:10:44:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Kan
13:10:44:                 opgegeven module niet vinden.
13:10:44:
13:10:44:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:27.20
SamM
Post by SamM »
I am using a laptop with an iGPU
The GPU is
0x8086:0x5916:3:1:KBL GT2 [HD Graphics 620]
Edit by Mod:
Your log says you have an INTEL CFL GT2 [UHD Graphics 630]
at timestamp 13:10:44
but FAH is, in fact detecting a KBL GT2 [HD Graphics 620] by seeing a 0x5916 device.
I"m confused.
aetch
Post by aetch »
For a good while I ran an AMD system with no GPU, not even an iGPU.
To get a desktop I had to remote into it from another computer.
*********************** Log Started 2021-01-24T18:55:18Z ***********************
18:55:18:Trying to access database...
18:55:18:Successfully acquired database lock
18:55:18:Read GPUs.txt
18:55:18:Enabled folding slot 00: PAUSED cpu:24 (by user)
18:55:18:****************************** FAHClient ******************************
18:55:18:      Version: 7.6.13
18:55:18:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:55:18:    Copyright: 2020 foldingathome.org
18:55:18:     Homepage: https://foldingathome.org/
18:55:18:         Date: Apr 27 2020
18:55:18:         Time: 21:21:01
18:55:18:     Revision: 5a652817f46116b6e135503af97f18e094414e3b
18:55:18:       Branch: master
18:55:18:     Compiler: Visual C++ 2008
18:55:18:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:55:18:     Platform: win32 10
18:55:18:         Bits: 32
18:55:18:         Mode: Release
18:55:18:       Config: C:\Users\Helen\AppData\Roaming\FAHClient\config.xml
18:55:18:******************************** CBang ********************************
18:55:18:         Date: Apr 24 2020
18:55:18:         Time: 17:07:55
18:55:18:     Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
18:55:18:         Bits: 32
18:55:18:******************************* System ********************************
18:55:18:          CPU: AMD Ryzen 9 3900X 12-Core Processor
18:55:18:       CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:55:18:         CPUs: 24
18:55:18:       Memory: 15.95GiB
18:55:18:  Free Memory: 13.54GiB
18:55:18:      Threads: WINDOWS_THREADS
18:55:18:   OS Version: 6.2
18:55:18:  Has Battery: false
18:55:18:   On Battery: false
18:55:18:   UTC Offset: 0
18:55:18:          PID: 7024
18:55:18:          CWD: C:\Users\Helen\AppData\Roaming\FAHClient
18:55:18:Win32 Service: false
18:55:18:           OS: Windows 10 Enterprise
18:55:18:      OS Arch: AMD64
18:55:18:         GPUs: 0
18:55:18:         CUDA: Not detected: cuInit() returned 999
18:55:18:       OpenCL: Not detected: clGetPlatformIDs() returned -1001
18:55:18:******************************* libFAH ********************************
18:55:18:         Date: Apr 15 2020
18:55:18:         Time: 14:53:14
18:55:18:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:55:18:         Bits: 32
18:55:18:***********************************************************************
18:55:18:<config>
18:55:18:  <!-- Client Control -->
18:55:18:  <client-threads v='6'/>
18:55:18:  <cycle-rate v='4'/>
18:55:18:  <cycles v='-1'/>
18:55:18:  <disable-sleep-when-active v='true'/>
18:55:18:  <exit-when-done v='false'/>
18:55:18:  <fold-anon v='false'/>
18:55:18:  <open-web-control v='false'/>
18:55:18:  <update-gpus-txt v='true'/>
18:55:18:
18:55:18:  <!-- Configuration -->
18:55:18:  <config-rotate v='true'/>
18:55:18:  <config-rotate-dir v='configs'/>
18:55:18:  <config-rotate-max v='0'/>
18:55:18:
18:55:18:  <!-- Debugging -->
18:55:18:  <assignment-servers>
18:55:18:    assign1.foldingathome.org assign2.foldingathome.org assign3.foldingathome.org assign4.foldingathome.org
18:55:18:  </assignment-servers>
18:55:18:  <auth-as v='true'/>
18:55:18:  <capture-directory v='capture'/>
18:55:18:  <capture-on-error v='false'/>
18:55:18:  <capture-packets v='false'/>
18:55:18:  <capture-requests v='false'/>
18:55:18:  <capture-responses v='false'/>
18:55:18:  <capture-sockets v='false'/>
18:55:18:  <debug-sockets v='false'/>
18:55:18:  <exception-locations v='true'/>
18:55:18:  <stack-traces v='false'/>
18:55:18:
18:55:18:  <!-- Error Handling -->
18:55:18:  <max-slot-errors v='10'/>
18:55:18:  <max-unit-errors v='5'/>
18:55:18:
18:55:18:  <!-- Folding Core -->
18:55:18:  <checkpoint v='15'/>
18:55:18:  <core-priority v='idle'/>
18:55:18:  <cpu-usage v='100'/>
18:55:18:  <gpu-usage v='100'/>
18:55:18:  <no-assembly v='false'/>
18:55:18:
18:55:18:  <!-- Folding Slot Configuration -->
18:55:18:  <cause v='ANY'/>
18:55:18:  <client-subtype v='STDCLI'/>
18:55:18:  <client-type v='normal'/>
18:55:18:  <cpu-species v='X86_AMD'/>
18:55:18:  <cpu-type v='AMD64'/>
18:55:18:  <cpus v='-1'/>
18:55:18:  <disable-viz v='false'/>
18:55:18:  <gpu v='true'/>
18:55:18:  <max-packet-size v='normal'/>
18:55:18:  <os-species v='WIN_8'/>
18:55:18:  <os-type v='WIN32'/>
18:55:18:  <project-key v='0'/>
18:55:18:  <smp v='true'/>
18:55:18:
18:55:18:  <!-- GUI -->
18:55:18:  <gui-enabled v='true'/>
18:55:18:
18:55:18:  <!-- HTTP Server -->
18:55:18:  <allow v='127.0.0.1 192.168.0.0/24'/>
18:55:18:  <connection-timeout v='60'/>
18:55:18:  <deny v='0/0'/>
18:55:18:  <http-addresses v='0:7396'/>
18:55:18:  <https-addresses v=''/>
18:55:18:  <max-connect-time v='900'/>
18:55:18:  <max-connections v='800'/>
18:55:18:  <max-request-length v='52428800'/>
18:55:18:  <min-connect-time v='300'/>
18:55:18:
18:55:18:  <!-- Logging -->
18:55:18:  <log v='log.txt'/>
18:55:18:  <log-color v='false'/>
18:55:18:  <log-crlf v='true'/>
18:55:18:  <log-date v='false'/>
18:55:18:  <log-date-periodically v='21600'/>
18:55:18:  <log-domain v='false'/>
18:55:18:  <log-header v='true'/>
18:55:18:  <log-level v='true'/>
18:55:18:  <log-no-info-header v='true'/>
18:55:18:  <log-redirect v='false'/>
18:55:18:  <log-rotate v='true'/>
18:55:18:  <log-rotate-dir v='logs'/>
18:55:18:  <log-rotate-max v='0'/>
18:55:18:  <log-short-level v='false'/>
18:55:18:  <log-simple-domains v='true'/>
18:55:18:  <log-thread-id v='false'/>
18:55:18:  <log-thread-prefix v='true'/>
18:55:18:  <log-time v='true'/>
18:55:18:  <log-to-screen v='true'/>
18:55:18:  <log-truncate v='false'/>
18:55:18:  <verbosity v='4'/>
18:55:18:
18:55:18:  <!-- Network -->
18:55:18:  <proxy v=':8080'/>
18:55:18:  <proxy-enable v='false'/>
18:55:18:  <proxy-pass v='*****'/>
18:55:18:  <proxy-user v=''/>
18:55:18:
18:55:18:  <!-- Process Control -->
18:55:18:  <child v='false'/>
18:55:18:  <daemon v='false'/>
18:55:18:  <pid v='false'/>
18:55:18:  <pid-file v='FAHClient.pid'/>
18:55:18:  <respawn v='false'/>
18:55:18:  <service v='false'/>
18:55:18:
18:55:18:  <!-- Remote Command Server -->
18:55:18:  <command-address v='0.0.0.0'/>
18:55:18:  <command-allow-no-pass v='127.0.0.1 192.168.0.0/24'/>
18:55:18:  <command-deny-no-pass v='0/0'/>
18:55:18:  <command-enable v='true'/>
18:55:18:  <command-port v='36330'/>
18:55:18:
18:55:18:  <!-- Slot Control -->
18:55:18:  <idle v='false'/>
18:55:18:  <max-shutdown-wait v='60'/>
18:55:18:  <pause-on-battery v='false'/>
18:55:18:  <pause-on-start v='true'/>
18:55:18:  <paused v='false'/>
18:55:18:  <power v='full'/>
18:55:18:
18:55:18:  <!-- User Information -->
18:55:18:  <machine-id v='0'/>
18:55:18:  <passkey v='*****'/>
18:55:18:  <team v='0'/>
18:55:18:  <user v='Aetch'/>
18:55:18:
18:55:18:  <!-- Web Server -->
18:55:18:  <web-allow v='127.0.0.1'/>
18:55:18:  <web-deny v='0/0'/>
18:55:18:  <web-enable v='false'/>
18:55:18:
18:55:18:  <!-- Web Server Sessions -->
18:55:18:  <session-cookie v='sid'/>
18:55:18:  <session-lifetime v='86400'/>
18:55:18:  <session-timeout v='3600'/>
18:55:18:
18:55:18:  <!-- Windows Service -->
18:55:18:  <service-description v='FAHClient'/>
18:55:18:  <service-restart v='true'/>
18:55:18:  <service-restart-delay v='5000'/>
18:55:18:
18:55:18:  <!-- Work Unit Control -->
18:55:18:  <dump-after-deadline v='true'/>
18:55:18:  <max-queue v='16'/>
18:55:18:  <max-units v='0'/>
18:55:18:  <next-unit-percentage v='99'/>
18:55:18:  <stall-detection-enabled v='false'/>
18:55:18:  <stall-percent v='5'/>
18:55:18:  <stall-timeout v='1800'/>
18:55:18:
18:55:18:  <!-- Folding Slots -->
18:55:18:  <slot id='0' type='CPU'>
18:55:18:    <extra-core-args v='-verbosity 4'/>
18:55:18:  </slot>
18:55:18:</config>
aetch wrote:For a good while I ran an AMD system with no GPU, not even an iGPU.
I guess we should call that "real dedication" No, that's not what I'm looking for. 8-)
aetch
Post by aetch »
I had posted before noticing the thread belonged in the Intel iGP subforum (serves me right for just hitting the active topics button).
Anyway, the two systems in my sig are just the systems setup for folding. One is CPU only folding and the other is GPU only folding.
Beyond that I do have a virtualisation server running on an i5-7400 which has HD Graphics 630, this quite probably is the type of setup you're looking for. I'm just not sure if I want to, or can, provide it for folding as the OS is Windows server core 2019 which can sometimes cause problems with installing and running packages.
*********************** Log Started 2021-05-19T04:27:02Z ***********************
04:27:02:******************************* libFAH ********************************
04:27:02:         Date: Oct 20 2020
04:27:02:         Time: 13:36:55
04:27:02:     Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
04:27:02:       Branch: master
04:27:02:     Compiler: Visual C++ 2015
04:27:02:      Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:27:02:     Platform: win32 10
04:27:02:         Bits: 32
04:27:02:         Mode: Release
04:27:02:****************************** FAHClient ******************************
04:27:02:      Version: 7.6.21
04:27:02:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:27:02:    Copyright: 2020 foldingathome.org
04:27:02:     Homepage: https://foldingathome.org/
04:27:02:         Time: 13:41:04
04:27:02:     Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
04:27:02:         Bits: 32
04:27:02:         Args: --open-web-control
04:27:02:       Config: C:\ProgramData\FAHClient\config.xml
04:27:02:******************************** CBang ********************************
04:27:02:         Time: 11:36:18
04:27:02:     Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
04:27:02:         Bits: 32
04:27:02:******************************* System ********************************
04:27:02:          CPU: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
04:27:02:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:27:02:         CPUs: 4
04:27:02:       Memory: 63.92GiB
04:27:02:  Free Memory: 25.64GiB
04:27:02:      Threads: WINDOWS_THREADS
04:27:02:   OS Version: 6.2
04:27:02:  Has Battery: false
04:27:02:   On Battery: false
04:27:02:   UTC Offset: 1
04:27:02:          PID: 968
04:27:02:          CWD: C:\ProgramData\FAHClient
04:27:02:Win32 Service: false
04:27:02:           OS: Hyper-V Server 2019
04:27:02:      OS Arch: AMD64
04:27:02:         GPUs: 1
04:27:02:        GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
04:27:02:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:27:02:               specified module could not be found.
04:27:02:
04:27:02:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
04:27:02:
04:27:02:***********************************************************************
mik
Post by mik »
i do, but can't make it work.
19:39:18:******************************* System ********************************
19:39:18:            CPU: Intel(R) Celeron(R) N4100 CPU @ 1.10GHz
19:39:18:         CPU ID: GenuineIntel Family 6 Model 122 Stepping 1
19:39:18:           CPUs: 4
19:39:18:         Memory: 3.68GiB
19:39:18:    Free Memory: 3.28GiB
19:39:18:        Threads: POSIX_THREADS
19:39:18:     OS Version: 4.19
19:39:18:    Has Battery: false
19:39:18:     On Battery: false
19:39:18:     UTC Offset: 2
19:39:18:            PID: 2147
19:39:18:            CWD: /var/lib/fahclient
19:39:18:             OS: Linux 4.19.0-16-amd64 x86_64
19:39:18:        OS Arch: AMD64
19:39:18:           GPUs: 1
19:39:18:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 GLK 2 [UHD Graphics 600]
19:39:18:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
19:39:18:                 libcuda.so: cannot open shared object file: No such file or
19:39:18:                 directory
19:39:18:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:1.3
19:39:18:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:3.0 Driver:21.20
i get this:
19:40:51:WU02:FS01:0x22:************************************ OpenMM ************************************
19:40:51:WU02:FS01:0x22:   Revision: 189320d0
19:40:51:WU02:FS01:0x22:********************************************************************************
19:40:51:WU02:FS01:0x22:Project: 13447 (Run 4344, Clone 72, Gen 0)
19:40:51:WU02:FS01:0x22:Unit: 0x00000000000000000000000000000000
19:40:51:WU02:FS01:0x22:Reading tar file core.xml
19:40:51:WU02:FS01:0x22:Reading tar file integrator.xml.bz2
19:40:51:WU02:FS01:0x22:Reading tar file state.xml.bz2
19:40:51:WU02:FS01:0x22:Reading tar file system.xml.bz2
19:40:51:WU02:FS01:0x22:Digital signatures verified
19:40:51:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:40:51:WU02:FS01:0x22:Version 0.0.13
19:40:51:WU02:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
19:40:51:WU02:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
19:40:51:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
19:40:51:WU02:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
19:40:51:WU02:FS01:0x22:There are 3 platforms available.
19:40:51:WU02:FS01:0x22:Platform 0: Reference
19:40:51:WU02:FS01:0x22:Platform 1: CPU
19:40:51:WU02:FS01:0x22:Platform 2: OpenCL
19:40:51:WU02:FS01:0x22:  opencl-device 0 specified
19:40:52:WU02:FS01:0x22:Attempting to create OpenCL context:
19:40:52:WU02:FS01:0x22:  Configuring platform OpenCL
19:40:52:WU02:FS01:0x22:Failed to create OpenCL context:
19:40:52:WU02:FS01:0x22:No compatible OpenCL platform is available
19:40:52:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
19:40:52:WU02:FS01:0x22:Saving result file ../logfile_01.txt
19:40:52:WU02:FS01:0x22:Saving result file science.log
19:40:52:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
19:40:52:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:40:52:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13447 run:4344 clone:72 gen:0 core:0x22 unit:0x000000480000000000003487000010f8
19:40:52:WU02:FS01:Uploading 2.69KiB to 54.157.202.86
19:40:52:WU02:FS01:Connecting to 54.157.202.86:8080
19:40:52:WU02:FS01:Upload complete
19:40:52:WU02:FS01:Server responded WORK_ACK (400)
19:40:52:WU02:FS01:Cleaning up
aetch wrote:I had posted before noticing the thread belonged in the Intel iGP subforum (serves me right for just hitting the active topics button).
04:27:02:
04:27:02:         CPUs: 4
04:27:02:          PID: 968
04:27:02:         GPUs: 1
04:27:02:
04:27:02:
Two things to note here:
1) The Intel KBL GT2 HD Graphics 630 is currently being evaluated as a member of a beta test for benchmarking.
2) You do not have OpenCL drivers, so you'd need to install them before there's a chance of the GPU doing anything useful. (CUDA is optional and would be limited to nVidia GPUs anyway.)
aetch
Post by aetch »
bruce wrote:2) You do not have OpenCL drivers, so you'd need to install them before there's a chance of the GPU doing anything useful. (CUDA is optional and would be limited to nVidia GPUs anyway.)
Hmmm, an intel CPU without discrete GPU but with CUDA. I think you're looking for a non-existent unicorn here. :wink:
Anyways, the intel drivers are now installed.
02:25:12:             OS: Hyper-V Server 2019
02:25:12:        OS Arch: AMD64
02:25:12:           GPUs: 1
02:25:12:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 KBL GT2 [HD Graphics 630]
02:25:12:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
02:25:12:                 specified module could not be found.
02:25:12:
02:25:12:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
02:25:12:***********************************************************************
OpenCL - Yes
CUDA - No, it's not NVidia
mik
Post by mik »
mik wrote:i do, but can't make it work.
so i fixed this, issue is I had 2 drivers installed, now seems to work goes in "running" but can't progress and remains stuck on 0.00% after a full night.
Looking at GPU usage it seems to me it is doing things for FAH but....no progress.
I have an UHD600 (Gen9, N4100 processor)
mik
Post by mik »
Does anyone have a solution for this?
aetch
Post by aetch »
Can you post your updated logs. You might still have a driver problem.
MeeLee
Post by MeeLee »
I have a 2 compute towers running 20x Intel Atom X5-Z8350, with 2GB of 1066Mhz DDR3 RAM on Linux.
I don't really use it for FAH, as Fah has GPU accelerated WUs that run way more efficient.
I do run the Intel GPU (using Beignet OpenCL drivers), to tackle some math problems, Not sure if they're considered Gen 6 or Gen 7 iGPUs.
40 of these using roughly 200W equal about the performance of a single RTX2070 to 2080 doing 140-160W.
I run them, because I have the hardware available, however, I am thinking of permanently disabling them, as the project (The Collatz Conjecture) isn't really anything but a project to get high PPDs...
