5700xt doesn't fold on windows 10 but works on linux
xphoenixd
Post by xphoenixd »
So I've been trying to get my 5700xt to fold for a few days now. Here's the logs with the error at the bottom:
*********************** Log Started 2021-05-11T12:42:45Z ***********************
12:42:45:******************************* libFAH ********************************
12:42:45:           Date: Oct 20 2020
12:42:45:           Time: 13:36:55
12:42:45:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
12:42:45:         Branch: master
12:42:45:       Compiler: Visual C++ 2015
12:42:45:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:42:45:       Platform: win32 10
12:42:45:           Bits: 32
12:42:45:           Mode: Release
12:42:45:****************************** FAHClient ******************************
12:42:45:        Version: 7.6.21
12:42:45:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:42:45:      Copyright: 2020 foldingathome.org
12:42:45:       Homepage: https://foldingathome.org/
12:42:45:           Time: 13:41:04
12:42:45:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
12:42:45:           Bits: 32
12:42:45:           Args: --open-web-control
12:42:45:         Config: C:\ProgramData\FAHClient\config.xml
12:42:45:******************************** CBang ********************************
12:42:45:           Time: 11:36:18
12:42:45:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
12:42:45:           Bits: 32
12:42:45:******************************* System ********************************
12:42:45:            CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
12:42:45:         CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:42:45:           CPUs: 16
12:42:45:         Memory: 15.92GiB
12:42:45:    Free Memory: 11.97GiB
12:42:45:        Threads: WINDOWS_THREADS
12:42:45:     OS Version: 6.2
12:42:45:    Has Battery: false
12:42:45:     On Battery: false
12:42:45:     UTC Offset: 9
12:42:45:            PID: 14992
12:42:45:            CWD: C:\ProgramData\FAHClient
12:42:45:  Win32 Service: false
12:42:45:             OS: Windows 10 Enterprise
12:42:45:        OS Arch: AMD64
12:42:45:           GPUs: 1
12:42:45:          GPU 0: Bus:3 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600
12:42:45:                 XT/5700/5700 XT]
12:42:45:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
12:42:45:                 specified module could not be found.
12:42:45:
12:42:45:OpenCL Device 0: Platform:0 Device:0 Bus:3 Slot:0 Compute:1.2 Driver:3240.6
12:42:45:***********************************************************************
12:42:45:<config>
12:42:45:  <!-- Network -->
12:42:45:  <proxy v=':8080'/>
12:42:45:
12:42:45:  <!-- User Information -->
12:42:45:  <passkey v='*****'/>
12:42:45:  <team v='234980'/>
12:42:45:  <user v='osjbo3jd9zrz'/>
12:42:45:
12:42:45:  <!-- Folding Slots -->
12:42:45:  <slot id='0' type='CPU'/>
12:42:45:  <slot id='1' type='GPU'>
12:42:45:    <pci-bus v='3'/>
12:42:45:    <pci-slot v='0'/>
12:42:45:  </slot>
12:42:45:</config>
12:42:45:Trying to access database...
12:42:45:Successfully acquired database lock
12:42:45:FS00:Initialized folding slot 00: cpu:14
12:42:45:FS01:Initialized folding slot 01: gpu:3:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT]
12:42:45:WU00:FS00:Starting
12:42:45:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 14992 -checkpoint 15 -np 14
12:42:46:WU00:FS00:Started FahCore on PID 1716
12:42:46:WU00:FS00:Core PID:13240
12:42:46:WU00:FS00:FahCore 0xa8 started
12:42:46:WU00:FS00:0xa8:*********************** Log Started 2021-05-11T12:42:46Z ***********************
12:42:46:WU00:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
12:42:46:WU00:FS00:0xa8:       Core: Gromacs
12:42:46:WU00:FS00:0xa8:       Type: 0xa8
12:42:46:WU00:FS00:0xa8:    Version: 0.0.12
12:42:46:WU00:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:42:46:WU00:FS00:0xa8:  Copyright: 2020 foldingathome.org
12:42:46:WU00:FS00:0xa8:   Homepage: https://foldingathome.org/
12:42:46:WU00:FS00:0xa8:       Date: Jan 16 2021
12:42:46:WU00:FS00:0xa8:       Time: 12:29:40
12:42:46:WU00:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
12:42:46:WU00:FS00:0xa8:     Branch: master
12:42:46:WU00:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
12:42:46:WU00:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
12:42:46:WU00:FS00:0xa8:   Platform: win32 10
12:42:46:WU00:FS00:0xa8:       Bits: 64
12:42:46:WU00:FS00:0xa8:       Mode: Release
12:42:46:WU00:FS00:0xa8:       SIMD: avx2_256
12:42:46:WU00:FS00:0xa8:     OpenMP: ON
12:42:46:WU00:FS00:0xa8:       CUDA: OFF
12:42:46:WU00:FS00:0xa8:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1716 -checkpoint 15 -np
12:42:46:WU00:FS00:0xa8:             14
12:42:46:WU00:FS00:0xa8:************************************ libFAH ************************************
12:42:46:WU00:FS00:0xa8:       Time: 11:24:13
12:42:46:WU00:FS00:0xa8:************************************ CBang *************************************
12:42:46:WU00:FS00:0xa8:       Time: 11:23:53
12:42:46:WU00:FS00:0xa8:************************************ System ************************************
12:42:46:WU00:FS00:0xa8:        CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
12:42:46:WU00:FS00:0xa8:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:42:46:WU00:FS00:0xa8:       CPUs: 16
12:42:46:WU00:FS00:0xa8:     Memory: 15.92GiB
12:42:46:WU00:FS00:0xa8:Free Memory: 11.85GiB
12:42:46:WU00:FS00:0xa8:    Threads: WINDOWS_THREADS
12:42:46:WU00:FS00:0xa8: OS Version: 6.2
12:42:46:WU00:FS00:0xa8:Has Battery: false
12:42:46:WU00:FS00:0xa8: On Battery: false
12:42:46:WU00:FS00:0xa8: UTC Offset: 9
12:42:46:WU00:FS00:0xa8:        PID: 13240
12:42:46:WU00:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
12:42:46:WU00:FS00:0xa8:********************************************************************************
12:42:46:WU00:FS00:0xa8:Project: 16969 (Run 4, Clone 1516, Gen 2)
12:42:46:WU00:FS00:0xa8:Unit: 0x00000000000000000000000000000000
12:42:46:WU00:FS00:0xa8:Digital signatures verified
12:42:46:WU00:FS00:0xa8:Calling: mdrun -c frame2.gro -s frame2.tpr -x frame2.xtc -cpi state.cpt -cpt 15 -nt 14 -ntmpi 1
12:42:46:WU00:FS00:0xa8:Steps: first=5000000 total=7500000
12:42:47:WU00:FS00:0xa8:Completed 1004452 out of 2500000 steps (40%)
12:42:47:WU01:FS01:Connecting to assign1.foldingathome.org:80
12:42:48:WU01:FS01:Assigned to work server 140.163.4.200
12:42:48:WU01:FS01:Requesting new work unit for slot 01: gpu:3:0 Navi 10 [Radeon RX 5600 OEM/5600 XT/5700/5700 XT] from 140.163.4.200
12:42:48:WU01:FS01:Connecting to 140.163.4.200:8080
12:42:49:3:127.0.0.1:New Web session
12:42:49:WU01:FS01:Downloading 20.25MiB
12:42:55:WU01:FS01:Download 21.91%
12:43:01:WU01:FS01:Download 53.71%
12:43:07:WU01:FS01:Download 82.10%
12:43:11:WU01:FS01:Download complete
12:43:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17343 run:0 clone:359 gen:92 core:0x22 unit:0x000001670000005c000043bf00000000
12:43:11:WU01:FS01:Starting
12:43:11:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 14992 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
12:43:11:WU01:FS01:Started FahCore on PID 18252
12:43:12:WU01:FS01:Core PID:17568
12:43:12:WU01:FS01:FahCore 0x22 started
12:43:13:WU01:FS01:0x22:*********************** Log Started 2021-05-11T12:43:13Z ***********************
12:43:13:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:43:13:WU01:FS01:0x22:       Core: Core22
12:43:13:WU01:FS01:0x22:       Type: 0x22
12:43:13:WU01:FS01:0x22:    Version: 0.0.13
12:43:13:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:43:13:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
12:43:13:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
12:43:13:WU01:FS01:0x22:       Date: Sep 19 2020
12:43:13:WU01:FS01:0x22:       Time: 02:35:58
12:43:13:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
12:43:13:WU01:FS01:0x22:     Branch: core22-0.0.13
12:43:13:WU01:FS01:0x22:   Compiler: Visual C++ 2015
12:43:13:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
12:43:13:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
12:43:13:WU01:FS01:0x22:   Platform: win32 10
12:43:13:WU01:FS01:0x22:       Bits: 64
12:43:13:WU01:FS01:0x22:       Mode: Release
12:43:13:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
12:43:13:WU01:FS01:0x22:             <peastman@stanford.edu>
12:43:13:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 18252 -checkpoint 15
12:43:13:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
12:43:13:WU01:FS01:0x22:             -gpu-usage 100
12:43:13:WU01:FS01:0x22:************************************ libFAH ************************************
12:43:13:WU01:FS01:0x22:       Date: Sep 7 2020
12:43:13:WU01:FS01:0x22:       Time: 19:09:56
12:43:13:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
12:43:13:WU01:FS01:0x22:     Branch: HEAD
12:43:13:WU01:FS01:0x22:************************************ CBang *************************************
12:43:13:WU01:FS01:0x22:       Time: 19:08:30
12:43:13:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
12:43:13:WU01:FS01:0x22:************************************ System ************************************
12:43:13:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
12:43:13:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
12:43:13:WU01:FS01:0x22:       CPUs: 16
12:43:13:WU01:FS01:0x22:     Memory: 15.92GiB
12:43:13:WU01:FS01:0x22:Free Memory: 10.23GiB
12:43:13:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
12:43:13:WU01:FS01:0x22: OS Version: 6.2
12:43:13:WU01:FS01:0x22:Has Battery: false
12:43:13:WU01:FS01:0x22: On Battery: false
12:43:13:WU01:FS01:0x22: UTC Offset: 9
12:43:13:WU01:FS01:0x22:        PID: 17568
12:43:13:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
12:43:13:WU01:FS01:0x22:************************************ OpenMM ************************************
12:43:13:WU01:FS01:0x22:   Revision: 189320d0
12:43:13:WU01:FS01:0x22:********************************************************************************
01:23:25:WU02:FS01:0x22:ERROR:exception: Error invoking kernel reduceEnergy: clEnqueueNDRangeKernel (-54)
01:23:25:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
01:23:25:WU02:FS01:0x22:Saving result file science.log
01:23:25:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
01:23:25:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:23:25:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:17742 run:79 clone:2 gen:108 core:0x22 unit:0x000000020000006c0000454e0000004f
I have never seen a WU run on windows, they all result in the error "Error invoking kernel reduceEnergy: clEnqueueNDRangeKernel". I can fold perfectly on linux.
I have reinstalled F@H multiple times, changed the slots, and reinstalled MANY different versions of the radeon software (20.2.2, 20.4.2, 20.7.2, 21.4.1, 21.5.1). I have also tried DDU and the AMD cleanup utility.
What am I doing wrong?
Re: 5700xt doesn't fold on windows 10 but works on linux
Welcome to Folding@Home!
You did not include the most interesting part of your log, the first 200 lines contain the hardware and software configuration of your PC and F@H.
In the absence of facts, let me suggest a new driver direct from AMD
https://www.amd.com/en/support/graphics ... rx-5700-xt
xphoenixd
Post by xphoenixd »
JimboPalmer wrote: You did not include the most interesting part of your log, the first 200 lines contain the hardware and software configuration of your PC and F@H.
I've edited and pasted the first 200+something lines in now :)
JimboPalmer wrote: In the absence of facts, let me suggest a new driver direct from AMD
I've already tried it with no luck :(
iero
Post by iero »
Did you try DDUing the drivers before re installing the lastest set from AMD? Are you running any overclock/undervolt settings?
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
