My gpu is disabled
airaani
My gpu is disabled
Post by airaani »
First off, I realize there are other recent threads about this, but my GPU is not Intel, it's nVidia. Log below
*********************** Log Started 2021-05-04T08:32:17Z ***********************
08:32:17:******************************* libFAH ********************************
08:32:17: Date: Oct 20 2020
08:32:17: Time: 13:36:55
08:32:17: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:32:17: Branch: master
08:32:17: Compiler: Visual C++ 2015
08:32:17: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:32:17: Platform: win32 10
08:32:17: Bits: 32
08:32:17: Mode: Release
08:32:17:****************************** FAHClient ******************************
08:32:17: Version: 7.6.21
08:32:17: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:32:17: Copyright: 2020 foldingathome.org
08:32:17: Homepage: https://foldingathome.org/
08:32:17: Time: 13:41:04
08:32:17: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:32:17: Bits: 32
08:32:17: Args: --open-web-control
08:32:17: Config: C:\ProgramData\FAHClient\config.xml
08:32:17:******************************** CBang ********************************
08:32:17: Time: 11:36:18
08:32:17: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:32:17: Bits: 32
08:32:17:******************************* System ********************************
08:32:17: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
08:32:17: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:32:17: CPUs: 8
08:32:17: Memory: 15.82GiB
08:32:17: Free Memory: 13.32GiB
08:32:17: Threads: WINDOWS_THREADS
08:32:17: OS Version: 6.2
08:32:17: Has Battery: false
08:32:17: On Battery: false
08:32:17: UTC Offset: -7
08:32:17: PID: 5032
08:32:17: CWD: C:\ProgramData\FAHClient
08:32:17: Win32 Service: false
08:32:17: OS: Windows 10 Home
08:32:17: OS Arch: AMD64
08:32:17: GPUs: 1
08:32:17: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:1
08:32:17: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.3
08:32:17:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:466.11
08:32:17:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
08:32:17:***********************************************************************
08:32:17:<config>
08:32:17: <!-- Network -->
08:32:17: <proxy v=':8080'/>
08:32:17:
08:32:17: <!-- Slot Control -->
08:32:17: <power v='MEDIUM'/>
08:32:17:
08:32:17: <!-- User Information -->
08:32:17: <passkey v='*****'/>
08:32:17: <team v='234980'/>
08:32:17: <user v='tqugczg2xjbc'/>
08:32:17:
08:32:17: <!-- Folding Slots -->
08:32:17: <slot id='0' type='CPU'>
08:32:17: <cpus v='2'/>
08:32:17: </slot>
08:32:17: <slot id='1' type='GPU'>
08:32:17: <pci-bus v='1'/>
08:32:17: <pci-slot v='0'/>
08:32:17: </slot>
08:32:17:</config>
08:32:17:Trying to access database...
08:32:17:Successfully acquired database lock
08:32:17:FS00:Initialized folding slot 00: cpu:2
08:32:17:WARNING:FS01:Disabling beta GPU slot 01: gpu:1:0. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.
08:32:17:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:32:17:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:32:17:WU00:FS01:Connecting to 140.163.4.200:8080
08:32:17:WU03:FS00:Starting
08:32:17:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 5032 -checkpoint 15 -np 2
08:32:17:WU03:FS00:Started FahCore on PID 3144
08:32:17:WU03:FS00:Core PID:4128
08:32:17:WU03:FS00:FahCore 0xa7 started
08:32:18:WU03:FS00:0xa7:*********************** Log Started 2021-05-04T08:32:18Z ***********************
08:32:18:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:32:18:WU03:FS00:0xa7: Type: 0xa7
08:32:18:WU03:FS00:0xa7: Core: Gromacs
08:32:18:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 706 -lifeline 3144 -checkpoint 15 -np 2
08:32:18:WU03:FS00:0xa7:************************************ CBang *************************************
08:32:18:WU03:FS00:0xa7: Date: Nov 27 2019
08:32:18:WU03:FS00:0xa7: Time: 03:40:09
08:32:18:WU03:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
08:32:18:WU03:FS00:0xa7: Branch: master
08:32:18:WU03:FS00:0xa7: Compiler: Visual C++ 2008
08:32:18:WU03:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:32:18:WU03:FS00:0xa7: Platform: win32 10
08:32:18:WU03:FS00:0xa7: Bits: 64
08:32:18:WU03:FS00:0xa7: Mode: Release
08:32:18:WU03:FS00:0xa7:************************************ System ************************************
08:32:18:WU03:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
08:32:18:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:32:18:WU03:FS00:0xa7: CPUs: 8
08:32:18:WU03:FS00:0xa7: Memory: 15.82GiB
08:32:18:WU03:FS00:0xa7:Free Memory: 13.51GiB
08:32:18:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
08:32:18:WU03:FS00:0xa7: OS Version: 6.2
08:32:18:WU03:FS00:0xa7:Has Battery: false
08:32:18:WU03:FS00:0xa7: On Battery: false
08:32:18:WU03:FS00:0xa7: UTC Offset: -7
08:32:18:WU03:FS00:0xa7: PID: 4128
08:32:18:WU03:FS00:0xa7: CWD: C:\ProgramData\FAHClient\work
08:32:18:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
08:32:18:WU03:FS00:0xa7: Version: 0.0.19
08:32:18:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:32:18:WU03:FS00:0xa7: Copyright: 2019 foldingathome.org
08:32:18:WU03:FS00:0xa7: Homepage: https://foldingathome.org/
08:32:18:WU03:FS00:0xa7: Date: Nov 25 2019
08:32:18:WU03:FS00:0xa7: Time: 17:12:41
08:32:18:WU03:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
08:32:18:WU03:FS00:0xa7:************************************ Build *************************************
08:32:18:WU03:FS00:0xa7: SIMD: avx_256
08:32:18:WU03:FS00:0xa7:********************************************************************************
08:32:18:WU03:FS00:0xa7:Project: 16927 (Run 12, Clone 211, Gen 198)
08:32:18:WU03:FS00:0xa7:Unit: 0x00000000000000000000000000000000
08:32:18:WU03:FS00:0xa7:Digital signatures verified
08:32:18:WU03:FS00:0xa7:Calling: mdrun -s frame198.tpr -o frame198.trr -cpi state.cpt -cpt 15 -nt 2
08:32:18:WU03:FS00:0xa7:Steps: first=99000000 total=500000
08:32:19:WU03:FS00:0xa7:Completed 167901 out of 500000 steps (33%)
08:32:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:32:38:WU00:FS01:Connecting to 140.163.4.200:80
08:32:38:WU00:FS01:Upload 0.26%
08:33:00:WU00:FS01:Upload 0.52%
08:33:00:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:33:00:WU00:FS01:Trying to send results to collection server
08:33:00:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:33:00:WU00:FS01:Connecting to 140.163.4.210:8080
08:33:21:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:33:21:WU00:FS01:Connecting to 140.163.4.210:80
08:33:21:WU00:FS01:Upload 0.26%
08:33:42:WU00:FS01:Upload 0.52%
08:33:42:ERROR:WU00:FS01:Exception: Transfer failed
08:33:43:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:33:43:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:33:43:WU00:FS01:Connecting to 140.163.4.200:8080
08:34:04:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:34:04:WU00:FS01:Connecting to 140.163.4.200:80
08:34:04:WU00:FS01:Upload 0.26%
08:34:23:WU00:FS01:Upload 0.52%
08:34:23:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:34:23:WU00:FS01:Trying to send results to collection server
08:34:23:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:34:23:WU00:FS01:Connecting to 140.163.4.210:8080
08:34:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:34:44:WU00:FS01:Connecting to 140.163.4.210:80
08:34:44:WU00:FS01:Upload 0.26%
08:35:03:WU00:FS01:Upload 0.52%
08:35:03:ERROR:WU00:FS01:Exception: Transfer failed
08:35:03:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:35:03:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:35:03:WU00:FS01:Connecting to 140.163.4.200:8080
08:35:11:WU03:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
08:35:24:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:35:24:WU00:FS01:Connecting to 140.163.4.200:80
08:35:24:WU00:FS01:Upload 0.26%
08:35:43:WU00:FS01:Upload 0.52%
08:35:43:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:35:43:WU00:FS01:Trying to send results to collection server
08:35:43:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:35:43:WU00:FS01:Connecting to 140.163.4.210:8080
08:36:04:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:36:04:WU00:FS01:Connecting to 140.163.4.210:80
08:36:04:WU00:FS01:Upload 0.26%
08:36:23:WU00:FS01:Upload 0.52%
08:36:23:ERROR:WU00:FS01:Exception: Transfer failed
08:36:40:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:36:40:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:36:40:WU00:FS01:Connecting to 140.163.4.200:8080
08:37:01:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:37:01:WU00:FS01:Connecting to 140.163.4.200:80
08:37:01:WU00:FS01:Upload 0.26%
08:37:20:WU00:FS01:Upload 0.52%
08:37:20:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:37:20:WU00:FS01:Trying to send results to collection server
08:37:20:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:37:20:WU00:FS01:Connecting to 140.163.4.210:8080
08:37:41:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:37:41:WU00:FS01:Connecting to 140.163.4.210:80
08:37:41:WU00:FS01:Upload 0.26%
08:38:00:WU00:FS01:Upload 0.52%
08:38:00:ERROR:WU00:FS01:Exception: Transfer failed
08:39:17:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:39:17:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:39:17:WU00:FS01:Connecting to 140.163.4.200:8080
08:39:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:39:38:WU00:FS01:Connecting to 140.163.4.200:80
08:39:38:WU00:FS01:Upload 0.26%
08:39:57:WU00:FS01:Upload 0.52%
08:39:57:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:39:57:WU00:FS01:Trying to send results to collection server
08:39:57:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:39:57:WU00:FS01:Connecting to 140.163.4.210:8080
08:40:19:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:40:19:WU00:FS01:Connecting to 140.163.4.210:80
08:40:19:WU00:FS01:Upload 0.26%
08:40:37:WU00:FS01:Upload 0.52%
08:40:38:ERROR:WU00:FS01:Exception: Transfer failed
08:41:55:WU03:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
08:43:32:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:43:32:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:43:32:WU00:FS01:Connecting to 140.163.4.200:8080
08:43:53:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:43:53:WU00:FS01:Connecting to 140.163.4.200:80
08:43:53:WU00:FS01:Upload 0.26%
08:44:12:WU00:FS01:Upload 0.52%
08:44:12:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
08:44:12:WU00:FS01:Trying to send results to collection server
08:44:12:WU00:FS01:Uploading 24.06MiB to 140.163.4.210
08:44:12:WU00:FS01:Connecting to 140.163.4.210:8080
08:44:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:44:33:WU00:FS01:Connecting to 140.163.4.210:80
08:44:33:WU00:FS01:Upload 0.26%
08:44:52:WU00:FS01:Upload 0.52%
08:44:52:ERROR:WU00:FS01:Exception: Transfer failed
08:48:39:WU03:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
08:50:23:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:17341 run:0 clone:76 gen:70 core:0x22 unit:0x0000004c00000046000043bd00000000
08:50:23:WU00:FS01:Uploading 24.06MiB to 140.163.4.200
08:50:23:WU00:FS01:Connecting to 140.163.4.200:8080
08:50:29:WU00:FS01:Upload 4.94%
08:50:35:WU00:FS01:Upload 20.00%
08:50:41:WU00:FS01:Upload 35.33%
08:50:47:WU00:FS01:Upload 50.40%
08:50:53:WU00:FS01:Upload 65.73%
08:50:59:WU00:FS01:Upload 81.06%
08:51:05:WU00:FS01:Upload 96.38%
08:51:06:WU00:FS01:Upload complete
08:51:07:WU00:FS01:Server responded WORK_ACK (400)
08:51:07:WU00:FS01:Final credit estimate, 136504.00 points
08:51:07:WU00:FS01:Cleaning up
08:54:26:17:127.0.0.1:New Web session
08:55:21:WU03:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
09:02:05:WU03:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
09:08:50:WU03:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
09:15:32:WU03:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
09:22:16:WU03:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
09:28:58:WU03:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
09:35:41:WU03:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
09:42:23:WU03:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
09:49:05:WU03:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
09:55:47:WU03:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
10:02:30:WU03:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
10:09:12:WU03:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
10:15:53:WU03:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
10:22:35:WU03:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
10:29:17:WU03:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
10:35:59:WU03:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
10:42:41:WU03:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
10:49:23:WU03:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
10:56:06:WU03:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
11:02:49:WU03:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
11:09:32:WU03:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
11:16:15:WU03:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
11:22:58:WU03:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
11:29:40:WU03:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
11:36:22:WU03:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
11:43:04:WU03:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
11:49:47:WU03:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
11:56:30:WU03:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
12:03:16:WU03:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
12:09:57:WU03:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
12:16:39:WU03:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
12:23:22:WU03:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
12:30:04:WU03:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
12:36:46:WU03:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
12:43:29:WU03:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
12:50:11:WU03:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
12:56:53:WU03:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
13:03:35:WU03:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
13:10:17:WU03:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
13:16:59:WU03:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
13:23:42:WU03:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
13:30:25:WU03:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
13:37:08:WU03:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
13:43:50:WU03:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
13:50:32:WU03:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
13:57:13:WU03:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
14:03:55:WU03:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
14:10:36:WU03:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
14:17:18:WU03:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
14:24:01:WU03:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
14:30:42:WU03:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
******************************* Date: 2021-05-04 *******************************
14:37:26:WU03:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
14:44:08:WU03:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
14:50:51:WU03:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
14:57:33:WU03:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
15:04:14:WU03:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
15:10:54:WU03:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
15:17:37:WU03:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
15:24:19:WU03:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
15:31:01:WU03:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
15:37:43:WU03:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
15:44:26:WU03:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
15:51:09:WU03:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
15:51:10:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:51:11:WU00:FS00:Assigned to work server 129.32.209.201
15:51:11:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 129.32.209.201
15:51:11:WU00:FS00:Connecting to 129.32.209.201:8080
15:51:11:ERROR:WU00:FS00:Exception: Server did not assign work unit
15:51:11:WU00:FS00:Connecting to assign1.foldingathome.org:80
15:51:12:WARNING:WU00:FS00:Failed to get assignment from 'assign1.foldingathome.org:80': No WUs available for this configuration
15:51:12:WU00:FS00:Connecting to assign2.foldingathome.org:80
15:51:12:WU00:FS00:Assigned to work server 129.32.209.204
15:51:12:WU00:FS00:Requesting new work unit for slot 00: cpu:2 from 129.32.209.204
15:51:12:WU00:FS00:Connecting to 129.32.209.204:8080
15:51:13:WU00:FS00:Downloading 491.00KiB
15:51:13:WU00:FS00:Download complete
15:51:13:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16935 run:15 clone:284 gen:79 core:0xa8 unit:0x0000011c0000004f000042270000000f
15:57:51:WU03:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
15:57:53:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
15:57:53:WU03:FS00:0xa7:Saving result file frame198.trr
15:57:53:WU03:FS00:0xa7:Saving result file md.log
15:57:53:WU03:FS00:0xa7:Saving result file science.log
15:57:53:WU03:FS00:0xa7:Saving result file traj_comp.xtc
15:57:53:WU03:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:57:54:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:57:54:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:16927 run:12 clone:211 gen:198 core:0xa7 unit:0x000000d3000000c60000421f0000000c
15:57:54:WU03:FS00:Uploading 6.31MiB to 129.32.209.201
15:57:54:WU00:FS00:Starting
15:57:54:WU03:FS00:Connecting to 129.32.209.201:8080
15:57:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 00 -suffix 01 -version 706 -lifeline 5032 -checkpoint 15 -np 2
15:57:54:WU00:FS00:Started FahCore on PID 5080
15:57:54:WU00:FS00:Core PID:10812
15:57:54:WU00:FS00:FahCore 0xa8 started
Re: My gpu is disabled
Welcome to Folding@Home!
08:32:17: GPUs: 1
So two itemss and some guesses
F@H does not recognize your GPU, is there a chance it is really new or a laptop?
If you run Gpu-Z and give us the Device ID, someone maybe able to set up an all new GPU
I notice that you have another set of drivers, my guess is an Intel driver, is this a laptop, or have an Intel GPU as well as Nvidia?
You have successfully completed one WU:
https://apps.foldingathome.org/wu#proje ... =76&gen=70
The GPU you have is not currently supported, but you are successfully folding with two threads on you CPU.
Your i7-4790K CPU does have a Haswell iGPU which is currently being beta tested and may be supported soon.
Please open a text window and enter 'FAHClient --lspci' and paste the results in a future post.
airaani
Post by airaani »
It is not new or a laptop, it's a GeForce GTX 1070
My motherboard does have an integrated Intel graphics chip but I'm not attempting to use that - I actually uninstalled the driver for it a couple weeks ago but an update must have reinstalled it.
Thanks for letting me know bruce, I thought that Nvidia graphics cards in general were supported. I hope I did what you asked for correctly, here are the resutls:
0x8086:0x8c9c:0:28:6:Intel Corporation:Intel(R) 9 Series Chipset Family PCI Express Root Port 7 - 8C9C
0x8086:0x8ca2:0:31:3:Intel Corporation:Intel(R) 9 Series Chipset Family SMBus Host Controller - 8CA2
0x8086:0x8c90:0:28:0:Intel Corporation:Intel(R) 9 Series Chipset Family PCI Express Root Port 1 - 8C90
0x8086:0x8cb1:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x0c00:0:0:0:Intel Corporation:PCI standard host CPU bridge
0x8086:0x8cc4:0:31:0:Intel Corporation:Intel(R) Z97 Chipset LPC Controller - 8CC4
0x8086:0x244e:4:0:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x8cba:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x8ca0:0:27:0:Intel Corporation:High Definition Audio Controller
0x1b4b:0x9172:6:0:0:Marvell Technology Group Ltd.:Standard SATA AHCI Controller
0x8086:0x0c0c:0:3:0:Intel Corporation:High Definition Audio Controller
0x10de:0x10f0:1:0:1:NVIDIA Corporation:High Definition Audio Controller
0x8086:0x8c82:0:31:2:Intel Corporation:Standard SATA AHCI Controller
0x8086:0x8c94:0:28:2:Intel Corporation:Intel(R) 9 Series Chipset Family PCI Express Root Port 3 - 8C94
0x8086:0x0412:0:2:0:Intel Corporation:Intel(R) HD Graphics 4600
0x10de:0x1b81:1:0:0:NVIDIA Corporation:NVIDIA GeForce GTX 1070
0x8086:0x0c01:0:1:0:Intel Corporation:PCI Express Root Port
0x8086:0x8cad:0:26:0:Intel Corporation:Standard Enhanced PCI to USB Host Controller
0x1969:0xe091:3:0:0:Qualcomm Atheros:Killer E2200 Gigabit Ethernet Controller
0x8086:0x8c96:0:28:3:Intel Corporation:Intel(R) 9 Series Chipset Family PCI Express Root Port 4 - 8C96
0x8086:0x8ca6:0:29:0:Intel Corporation:Standard Enhanced PCI to USB Host Controller
0x8086:0x153b:0:25:0:Intel Corporation:Intel(R) Ethernet Connection I217-V
You have an Intel GPU with HD Graphics 4600 and a NVIDIA GPU. That suggests you probably have a laptop and it probably contains Optimus. There are many threads discussing Optimus but if that's what you have, i THINK you can only use one at a time. The preferred instillation method is to force it to stay in high-powered mode (NVIDIA) and then be sure you've downloaded and installed the drivers from nvidia.com. Once the drivers are in place, restart your system and re-publish the first 200 lines of the log if you want more help.
The NVIDIA will use more power, generate more heat, and produce more FAH Points.
https://www.nvidia.com/en-us/geforce/te ... echnology/
airaani
Post by airaani »
As I mentioned, it is not a laptop. I don't know what optimus is. Thanks for the driver recommendation though, I updated just two weeks ago but there is already a new one. I updated and restarted and it is now using my gpu!
The Device ID for your GTX 1070 is exactly the Device ID in the GPUs.txt on my PC. If you have a recent GPUs.txt it should also be on your PC (Never edit GPUs.txt, if you need a newer one, delete yours and a new one will download from the server)
0x10de:0x1b81:2:7:GP104 [GeForce GTX 1070] 6463
If you have a Driver directly from Nvidia, you should be good to go.
https://www.nvidia.com/en-us/drivers/results/174664/
airaani wrote:it is not a laptop. I don't know what optimus is
Optimus is a laptop technology to use a low power Intel GPU to save battery life then swap to an Nvidia GPU after a graphics heavy program starts. F@H does not really interact well with Optimus as the Intel fails to fold even before the Nvidia is enabled.
Since you do not have a laptop, Optimus is not installed.
airaani wrote:As I mentioned, it is not a laptop. I don't know what optimus is. Thanks for the driver recommendation though, I updated just two weeks ago but there is already a new one. I updated and restarted and it is now using my gpu!
In fact, most driver updates make changes that improve the graphics in games. FAH doesn't need those updates. I only update when there's a new "studio driver"
In your earlier log the driver being used didn't ebnable the necessary functions. Maybe the one you were using wasn't from nvidia.com or something else.
