Download problems
Haziq_Hafiz
Download problems
Post by Haziq_Hafiz »
I'm having problem downloading FahCore 22 apparently, it keeps getting disconnected, I think? i also tried downloading manually but really x3 slow like bytes/sec
*********************** Log Started 2021-05-08T15:00:23Z ***********************
15:00:23:******************************* libFAH ********************************
15:00:23:           Date: Oct 20 2020
15:00:23:           Time: 13:36:55
15:00:23:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
15:00:23:         Branch: master
15:00:23:       Compiler: Visual C++ 2015
15:00:23:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
15:00:23:       Platform: win32 10
15:00:23:           Bits: 32
15:00:23:           Mode: Release
15:00:23:****************************** FAHClient ******************************
15:00:23:        Version: 7.6.21
15:00:23:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:00:23:      Copyright: 2020 foldingathome.org
15:00:23:       Homepage: https://foldingathome.org/
15:00:23:           Time: 13:41:04
15:00:23:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
15:00:23:           Bits: 32
15:00:23:           Args: --open-web-control
15:00:23:         Config: C:\ProgramData\FAHClient\config.xml
15:00:23:******************************** CBang ********************************
15:00:23:           Time: 11:36:18
15:00:23:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
15:00:23:           Bits: 32
15:00:23:******************************* System ********************************
15:00:23:            CPU: AMD Ryzen 7 1700 Eight-Core Processor
15:00:23:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
15:00:23:           CPUs: 16
15:00:23:         Memory: 47.95GiB
15:00:23:    Free Memory: 44.88GiB
15:00:23:        Threads: WINDOWS_THREADS
15:00:23:     OS Version: 6.2
15:00:23:    Has Battery: false
15:00:23:     On Battery: false
15:00:23:     UTC Offset: 8
15:00:23:            PID: 1824
15:00:23:            CWD: C:\ProgramData\FAHClient
15:00:23:  Win32 Service: false
15:00:23:             OS: Windows 10 Enterprise
15:00:23:        OS Arch: AMD64
15:00:23:           GPUs: 3
15:00:23:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
15:00:23:          GPU 1: Bus:8 Slot:0 Func:0 NVIDIA:3 GK107 [Quadro K600]
15:00:23:          GPU 2: Bus:6 Slot:0 Func:0 NVIDIA:7 GP106 [P106-090]
15:00:23:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:6.1 Driver:10.0
15:00:23:  CUDA Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:6.1 Driver:10.0
15:00:23:  CUDA Device 2: Platform:0 Device:2 Bus:8 Slot:0 Compute:3.0 Driver:10.0
15:00:23:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:417.22
15:00:23:OpenCL Device 1: Platform:0 Device:1 Bus:10 Slot:0 Compute:1.2 Driver:417.22
15:00:23:OpenCL Device 2: Platform:0 Device:2 Bus:8 Slot:0 Compute:1.2 Driver:417.22
15:00:23:Trying to access database...
15:00:23:Successfully acquired database lock
15:00:23:FS00:Initialized folding slot 00: cpu:13
15:00:23:FS01:Initialized folding slot 01: gpu:10:0 GP106 [P106-090]
15:00:23:FS02:Initialized folding slot 02: gpu:8:0 GK107 [Quadro K600]
15:00:23:FS03:Initialized folding slot 03: gpu:6:0 GP106 [P106-090]
15:00:26:3:127.0.0.1:New Web session
15:00:51:FS00:Unpaused
15:00:51:FS01:Unpaused
15:00:51:FS02:Unpaused
15:00:51:FS03:Unpaused
15:00:51:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
15:00:51:WU00:FS00:Connecting to cores.foldingathome.org:80
15:00:51:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:00:51:WU02:FS02:Connecting to cores.foldingathome.org:80
15:00:52:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:00:53:WU02:FS02:FahCore 22: Downloading 77.67MiB
15:00:58:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
15:01:24:Saving configuration to config.xml
15:01:52:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:01:52:WU01:FS01:Connecting to cores.foldingathome.org:80
15:01:53:WU01:FS01:FahCore 22: Downloading 77.67MiB
15:02:00:WU00:FS00:FahCore a8: 0.81%
15:02:28:WU02:FS02:FahCore 22: 0.02%
15:02:28:ERROR:WU02:FS02:Exception: Transfer failed
15:03:29:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:03:29:WU02:FS02:Connecting to cores.foldingathome.org:80
15:04:01:WU02:FS02:FahCore 22: Downloading 77.67MiB
15:04:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:04:42:WU00:FS00:FahCore a8: 1.10%
15:04:42:ERROR:WU00:FS00:Exception: Transfer failed
15:04:42:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
15:04:42:WU00:FS00:Connecting to cores.foldingathome.org:80
15:04:43:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:05:24:WU00:FS00:FahCore a8: 0.81%
15:05:28:Saving configuration to config.xml
15:05:34:WU01:FS01:FahCore 22: 0.04%
15:05:34:ERROR:WU01:FS01:Exception: Transfer failed
15:05:49:WU02:FS02:FahCore 22: 0.01%
15:05:49:ERROR:WU02:FS02:Exception: Transfer failed
15:06:06:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:06:06:WU02:FS02:Connecting to cores.foldingathome.org:80
15:06:22:WU02:FS02:FahCore 22: Downloading 77.67MiB
15:06:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:07:29:WU00:FS00:FahCore a8: 1.32%
15:07:29:ERROR:WU00:FS00:Exception: Transfer failed
15:07:29:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
15:07:29:WU00:FS00:Connecting to cores.foldingathome.org:80
15:07:36:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:09:39:WU00:FS00:FahCore a8: 0.38%
15:09:39:ERROR:WU00:FS00:Exception: Transfer failed
15:10:06:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
15:10:06:WU00:FS00:Connecting to cores.foldingathome.org:80
15:10:07:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:10:20:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:10:20:WU01:FS01:Connecting to cores.foldingathome.org:80
15:10:21:WU02:FS02:FahCore 22: 0.03%
15:10:21:ERROR:WU02:FS02:Exception: Transfer failed
15:10:36:WU01:FS01:FahCore 22: Downloading 77.67MiB
15:10:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:12:26:WU00:FS00:FahCore a8: 0.25%
15:12:26:ERROR:WU00:FS00:Exception: Transfer failed
15:13:25:WU01:FS01:FahCore 22: 0.04%
15:13:25:ERROR:WU01:FS01:Exception: Transfer failed
15:14:21:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx2-256/a8-0.0.12/Core_a8.fah
15:14:21:WU00:FS00:Connecting to cores.foldingathome.org:80
15:15:02:WU00:FS00:FahCore a8: Downloading 7.72MiB
15:15:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:16:40:WU00:FS00:FahCore a8: 0.02%
15:16:40:ERROR:WU00:FS00:Exception: Transfer failed
15:17:11:WU02:FS02:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
15:17:11:WU02:FS02:Connecting to cores.foldingathome.org:80
Re: Download problems
The following might work:
Pause all folding slots.
Reboot
Unpause one of them and wait for that FAHCore to finish downloading.
Unpause a second slot ...
Repeat as necessary if you need a copy of a third FAHCore
When 2 slots both try to download the same FAHCore, it often fails.
Haziq_Hafiz
I can download it normally now.. Did something happen? was the server down? or the problem was my ISP? FYI, nothing changed on my side except now its morning
I don't know what initiated the problem. I do know that if you happen to need the same new FAHCore in more than one slot, the only way to download it is do so with a SINGLE slot.
